  4. Aktualisierungen der Adapter funktionieren nicht
adapter update error
44 Beiträge 5 Kommentatoren 5.0k Aufrufe 3 Beobachtet
    @Guido-Spoltmann
    ping 104.16.22.35
    Guido SpoltmannG Offline
    Guido Spoltmann
    @Thomas-Braun sagte in Aktualisierungen der Adapter funktionieren nicht:
    ping 104.16.22.35
    pi@raspberrypi:/opt/iobroker $ ping 104.16.22.35
    PING 104.16.22.35 (104.16.22.35) 56(84) bytes of data.
    64 bytes from 104.16.22.35: icmp_seq=1 ttl=58 time=10.4 ms
    64 bytes from 104.16.22.35: icmp_seq=2 ttl=58 time=9.59 ms
    64 bytes from 104.16.22.35: icmp_seq=3 ttl=58 time=9.53 ms
    64 bytes from 104.16.22.35: icmp_seq=4 ttl=58 time=9.33 ms
    64 bytes from 104.16.22.35: icmp_seq=5 ttl=58 time=8.94 ms
    64 bytes from 104.16.22.35: icmp_seq=6 ttl=58 time=9.68 ms
    64 bytes from 104.16.22.35: icmp_seq=7 ttl=58 time=9.41 ms
    64 bytes from 104.16.22.35: icmp_seq=8 ttl=58 time=9.49 ms
    64 bytes from 104.16.22.35: icmp_seq=9 ttl=58 time=9.28 ms
    64 bytes from 104.16.22.35: icmp_seq=10 ttl=58 time=9.39 ms
    64 bytes from 104.16.22.35: icmp_seq=11 ttl=58 time=23.2 ms
    64 bytes from 104.16.22.35: icmp_seq=12 ttl=58 time=22.3 ms
    64 bytes from 104.16.22.35: icmp_seq=13 ttl=58 time=9.21 ms
    64 bytes from 104.16.22.35: icmp_seq=14 ttl=58 time=9.29 ms
    64 bytes from 104.16.22.35: icmp_seq=15 ttl=58 time=9.27 ms
    64 bytes from 104.16.22.35: icmp_seq=16 ttl=58 time=9.45 ms
    64 bytes from 104.16.22.35: icmp_seq=17 ttl=58 time=30.4 ms
    64 bytes from 104.16.22.35: icmp_seq=18 ttl=58 time=9.33 ms
    64 bytes from 104.16.22.35: icmp_seq=19 ttl=58 time=25.3 ms
    64 bytes from 104.16.22.35: icmp_seq=20 ttl=58 time=8.86 ms
    64 bytes from 104.16.22.35: icmp_seq=21 ttl=58 time=9.44 ms
    64 bytes from 104.16.22.35: icmp_seq=22 ttl=58 time=9.70 ms
    ^C
    --- 104.16.22.35 ping statistics ---
    22 packets transmitted, 22 received, 0% packet loss, time 54ms
    rtt min/avg/max/mdev = 8.855/12.307/30.355/6.268 ms
    Platform linux
    Betriebssystem linux
    Architektur arm
    CPUs 4
    Geschwindigkeit 600 MHz
    Modell ARMv7 Processor rev 3 (v7l)
    RAM 3.73 GB
    Node.js v12.20.0
    NPM 6.14.8
    Festplatte Größe 26.51 GB
    • Guido SpoltmannG Guido Spoltmann
      ping 104.16.22.35
      ^C
      @Guido-Spoltmann Gut, also raus kommst du. Nur die Namensauflösung tickt nicht sauber.
      Ich vermute ja immer noch eine Einstellung in der Fritzbox.
      Kannst du die mal durchstarten?
      Guido SpoltmannG 1 Antwort Letzte Antwort
        Guido Spoltmann
        @Thomas-Braun
        So Neustart ist erledigt...
        Habe jetzt nochmal die letzten Befehle in Putty eingetragen:
        pi@raspberrypi:/opt/iobroker $ ping npmjs.org
        PING npmjs.org(2606:4700::6810:1a23 (2606:4700::6810:1a23)) 56 data bytes
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=1 ttl=57 tim        e=9.73 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=2 ttl=57 tim        e=9.47 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=3 ttl=57 tim        e=9.08 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=4 ttl=57 tim        e=9.29 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=5 ttl=57 tim        e=9.33 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=6 ttl=57 time=32.2 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=7 ttl=57 time=39.2 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=8 ttl=57 time=9.58 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=9 ttl=57 time=9.51 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=10 ttl=57 time=9.27 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=11 ttl=57 time=9.20 ms
        64 bytes from 2606:4700::6810:1a23 (2606:4700::6810:1a23): icmp_seq=12 ttl=57 time=36.5 ms
        ^C
        --- npmjs.org ping statistics ---
        12 packets transmitted, 12 received, 0% packet loss, time 25ms
        rtt min/avg/max/mdev = 9.079/16.029/39.242/11.600 ms
        pi@raspberrypi:/opt/iobroker $ traceroute npmjs.org
        traceroute to npmjs.org (104.16.20.35), 30 hops max, 60 byte packets
         1  fritz.box (192.168.178.1)  0.392 ms  0.350 ms  0.295 ms
         2  185.113.144.6 (185.113.144.6)  4.897 ms  4.829 ms  4.719 ms
         3  185.113.144.2 (185.113.144.2)  4.658 ms  4.552 ms  4.622 ms
         4  185.113.144.1 (185.113.144.1)  4.555 ms  4.445 ms  4.381 ms
         5  ae0-408.dus10.core-backbone.com (81.95.15.37)  9.165 ms  9.097 ms  9.078 ms
         6  ae15-2029.fra30.core-backbone.com (81.95.15.70)  12.090 ms  10.177 ms  9.994 ms
         7  core-backbone.cloudflare.com (80.255.9.34)  10.854 ms  10.597 ms  10.815 ms
         8  104.16.20.35 (104.16.20.35)  10.522 ms  10.632 ms  10.632 ms
        Sieht besser aus oder?
        Platform linux
        Architektur arm
        CPUs 4
        RAM 3.73 GB
        Node.js v12.20.0
        NPM 6.14.8
        • wendy2702W Online
          wendy2702W Online
          @Guido-Spoltmann sagte in Aktualisierungen der Adapter funktionieren nicht:
          https://registry.npmjs.org/iobroker.js-controller
          Kannst das auch mal an einem PC in einem Browser eingeben und schauen ob die Seite erreichbar ist.
          Klappt das liegt es wohl am PI.
          Klappt es nicht: Netzwerk bzw. Fritzbox
          • wendy2702W wendy2702
            Guido Spoltmann
            @wendy2702 sagte in Aktualisierungen der Adapter funktionieren nicht:
            Platform linux
            Architektur arm
            CPUs 4
            RAM 3.73 GB
            Node.js v12.20.0
            NPM 6.14.8
              @Guido-Spoltmann Dann sollte es ja jetzt funktionieren.
                @Guido-Spoltmann
                Das ist nicht gut...
                iobroker -v
                iobroker status
                cd /opt/iobroker
                npm i iobroker.js-controller@3.1.6 --production
                wendy2702W Online
                wendy2702W Online
                @Guido-Spoltmann
                iobroker -v
                iobroker status
                cd /opt/iobroker
                Dann das erneut ausführen
                  @Guido-Spoltmann
                  iobroker -v
                  iobroker status
                  cd /opt/iobroker
                  @wendy2702 Aber nicht die Zeile mit npm i..., wenn es schon läuft.
                  Guido SpoltmannG wendy2702W 2 Antworten Letzte Antwort
                    Guido Spoltmann
                    @Thomas-Braun
                    Bin im Admin Bereich angekommen, vielen Dank für die Unterstützung. Hab ja nebenbei wieder was dazu gelernt.
                    LG
                    Guido
                    Platform linux
                    Architektur arm
                    CPUs 4
                    RAM 3.73 GB
                    Node.js v12.20.0
                    NPM 6.14.8
                      wendy2702W Online
                      wendy2702W Online
                      Das stimmt, allerdings konnte ich kein logfile sehen in dem die Installation bzw. Der Start als erfolgreich zu erkennen war.
                      Gucke aber auch nur am Handy und habe es vielleicht übersehen oder überlesen.
