  4. Probleme mit CUL 868
    5.5k
18 Beiträge 5 Kommentatoren 3.0k Aufrufe
  • a200A Offline
    a200A Offline
    a200
    Hallo mein CUL startet nicht.
    host-minime	2016-10-31 19:50:34.986	info	Restart adapter system.adapter.cul.0 because enabled
    host-minime	2016-10-31 19:50:34.985	error	instance system.adapter.cul.0 terminated with code 0 (OK)
    cul-0	2016-10-31 19:50:34.958	info	terminating
    TypeError:	2016-10-31 19:50:34.916	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    TypeError:	2016-10-31 19:50:34.916	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    TypeError:	2016-10-31 19:50:34.916	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:394:29)
    TypeError:	2016-10-31 19:50:34.916	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3004:14)
    TypeError:	2016-10-31 19:50:34.916	error	at Adapter.emit (events.js:166:7)
    TypeError:	2016-10-31 19:50:34.916	error	at emitNone (events.js:67:13)
    TypeError:	2016-10-31 19:50:34.916	error	at Adapter. (/opt/iobroker/node_modules/iobroker.cul/cul.js:32:5)
    TypeError:	2016-10-31 19:50:34.916	error	at main (/opt/iobroker/node_modules/iobroker.cul/cul.js:42:11)
    TypeError:	2016-10-31 19:50:34.916	error	at new Cul (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/cul.js:89:22)
    TypeError:	2016-10-31 19:50:34.916	error	at new SerialPort (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/node_modules/serialport/lib/serialport.js:101:11)
    TypeError:	2016-10-31 19:50:34.916	error	Invalid "baudRate" must be a number got: 9600
    uncaught	2016-10-31 19:50:34.907	error	exception: Invalid "baudRate" must be a number got: 9600
    cul-0	2016-10-31 19:50:34.874	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.cul
    host-minime	2016-10-31 19:50:33.437	info	instance system.adapter.cul.0 started with pid 13772
    host-minime	2016-10-31 19:50:33.422	info	object change system.adapter.cul.0
    Meine Einstellungen:
    "serialport": "/dev/ttyACM0", "baudrate": 9600, "mode": "SlowRF", "parse": true, "init": true, "coc": false, "rssi": true
    unter FHEM geht das Ding:
    CMDS             BbCFiAZNkGMKUYRTVWXefmLltux
    CUL_0_MSGCNT        78
    CUL_0_TIME             2016-10-31 19:08:32
    Clients                     :FS20:FHT.*:KS300:USF1000:BS:HMS: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN:
                                  :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY:
                                  :STACKABLE_CC:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
    DEF	                      /dev/ttyACM0@9600 1034
    DeviceName              /dev/ttyACM0@9600
    FD                          11
    FHTID                     1034
    NAME                      CUL_0
    NR                          20
    PARTIAL
    RAWMSG                  HCF0420862151F4
    RSSI                        -80
    STATE                      Initialized
    TYPE                        CUL
    VERSION                   V 1.66 CUL868
    initString                   X21
    Wer kennt sich mit CUL aus?
    Danke im Voraus,
    a200.
    IoBroker auf QNAP TS-451, Raspi und NUC
    • BluefoxB Offline
      BluefoxB Offline
      Kannst du vom git ausprobieren?
      • a200A Offline
        a200A Offline
        a200
        @Bluefox:
        Kannst du vom git ausprobieren? `
        Heute Abend. Hier in Hessen haben wir heute keinen Feiertag! ;(
        • a200A Offline
          a200A Offline
          a200
          @Bluefox:
          yup! jetzt gehts. Danke.
            Super, dass der Adapter jetzt auch läuft.
            Habe zwar noch keine Ahnung was und vor allem wie damit arbeiten, aber er läuft!
            Ich musste auch als Port eingeben:
            ttyACM0
            Dann kam die Fehlermeldung:
            cul.0	2016-11-01 19:38:05.583	info	List of port: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS3"}]
            cul.0	2016-11-01 19:37:30.772	error	Cannot open port: Error: Error: No such file or directory, cannot open /dev/ttyACM0
            Nach einem restart der Instanz lief er aber.
            • a200A Offline
              a200A Offline
              a200
              ich sehe zwar die zustände der CUL, aber unter Objekte kann ich sie nicht sehen.
              was läuft da falsch?
              • a200A Offline
                a200A Offline
                a200
                entwarnung. im experten-modus sind die werte des CULs sichtbar.
                • eric2905E Offline
                  eric2905E Offline
                  eric2905
                  @a200:
                  entwarnung. im experten-modus sind die werte des CULs sichtbar. `
                  Vorsicht, das sind die Werte des Adapters selber - keine "Empfangsdaten".
                  Gruß,
                  Eric
                  • a200A Offline
                    a200A Offline
                    a200
                    Ja, das sehe ich auch so. Denn bis jetzt wurden keine Geräte gefunden.
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      @a200:
                      Ja, das sehe ich auch so. Denn bis jetzt wurden keine Geräte gefunden. `
                      mal zur neuier und fehler suche, was fuer geraete moechtest du den mit dem CUL 868 betreiben ?
                      • a200A Offline
                        a200A Offline
                        a200
                        @Dutchman:
                        mal zur neuier und fehler suche, was fuer geraete moechtest du den mit dem CUL 868 betreiben ? `
                        Thermometer. der wird in fhem problemlos gefunden. ich wollte mir den umweg und die ressourcen über fhem sparen.
                        • BluefoxB Offline
                          BluefoxB Offline
                          Kannst du paar Logs besorgen? MIT debug Level.
                          • a200A Offline
                            a200A Offline
                            a200
                            Kann ich gerne machen. Allerdings erst morgen.
                            Danke und LG
                            • a200A Offline
                              a200A Offline
                              a200
                              Das ist alles, was bei mir im Log zu CUL steht:
                              cul.0	2016-11-02 18:59:35.608	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 18:59:35.479	debug	statesDB connected
                              cul.0	2016-11-02 18:59:35.453	debug	objectDB connected
                              cul.0	2016-11-02 18:58:51.451	info	terminating
                              cul.0	2016-11-02 18:58:43.608	error	Cannot open port: Port is not selected
                              cul.0	2016-11-02 18:58:43.592	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 18:47:52.299	info	terminating
                              cul.0	2016-11-02 15:34:53.954	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 15:19:14.938	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 14:16:38.777	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 14:00:59.691	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 13:50:33.703	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 13:40:07.647	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 13:29:41.649	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 12:53:10.482	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 12:32:18.414	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              cul.0	2016-11-02 12:16:39.539	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                              Irgendwelche Vorschläge Bluefox?
                              • a200A Offline
                                a200A Offline
                                a200
                                schon wieder gabs im Log eine Überraschung:
                                cul.0	2016-11-03 18:58:12.679	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.cul
                                cul.0	2016-11-03 18:58:12.580	debug	statesDB connected
                                cul.0	2016-11-03 18:58:12.548	debug	objectDB connected
                                host.minime	2016-11-03 18:58:11.262	info	instance system.adapter.cul.0 started with pid 17467
                                host.minime	2016-11-03 18:57:41.231	info	Restart adapter system.adapter.cul.0 because enabled
                                host.minime	2016-11-03 18:57:41.226	error	instance system.adapter.cul.0 terminated with code 0 (OK)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at FSReqWrap.wrapper [as oncomplete] (fs.js:576:17)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/lib/serialport.js:306:7)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/lib/serialport.js:293:14)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort._emitData (/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/lib/serialport.js:313:18)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort.module.exports.raw (/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/lib/parsers.js:7:13)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort.emit (events.js:169:7)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at emitOne (events.js:77:13)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/cul.js:128:70)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at parse (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/cul.js:183:43)
                                ReferenceError:	2016-11-03 18:57:41.186	error	at Object.module.exports.parse (/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/lib/hms.js:47:26)
                                ReferenceError:	2016-11-03 18:57:41.186	error	data is not defined
                                uncaught	2016-11-03 18:57:41.180	error	exception: data is not defined
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  @a200:
                                  Da ist jetzt hobbyquaker dran.
                                  Du kannst aber auch ausprobieren wenn du die Datei__/opt/iobroker/node_modules/iobroker.cul/node_modules/cul/lib/hms.js__ bei sich wie folgt änderst:
                                  https://github.com/hobbyquaker/cul/pull/4/files
                                  • a200A Offline
                                    a200A Offline
                                    a200
                                    nach der installation:
                                    ` > root@minime:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.cul/tarball/master –production
                                    serialport@4.0.4 install /opt/iobroker/node_modules/iobroker.cul/node_modules/serialport
                                    node-pre-gyp install --fallback-to-build
                                    node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz
                                    node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.4 and node@4.6.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                                    make: Entering directory '/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/build'
                                    CXX(target) Release/obj.target/serialport/src/serialport.o
                                    CXX(target) Release/obj.target/serialport/src/serialport_unix.o
                                    CXX(target) Release/obj.target/serialport/src/serialport_poller.o
                                    SOLINK_MODULE(target) Release/obj.target/serialport.node
                                    COPY Release/serialport.node
                                    make: Leaving directory '/opt/iobroker/node_modules/iobroker.cul/node_modules/serialport/build'
                                    iobroker.cul@0.1.0 node_modules/iobroker.cul
                                    ├── cul@0.2.1
                                    └── serialport@4.0.4 (bindings@1.2.1, commander@2.9.0, debug@2.2.0, lie@3.1.0, nan@2.4.0, object.assign@4.0.4) `
                                    ist mein lib verzeichnis fast leer:
                                    root@minime:/opt/iobroker/node_modules/iobroker.cul/lib# ls -la
                                    total 12
                                    drwxr-xr-x 2 root root 4096 Nov  3 20:20 .
                                    drwxr-xr-x 6 root root 4096 Nov  3 20:20 ..
                                    -rw-r--r-- 1 root root 2577 Nov  1 09:22 utils.js
                                    was mache ich falsch, bei der installation? muss ich vorher das cul paket https://github.com/hobbyquaker/cul installieren?
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      @a200:
                                      ├── cul@0.2.1
                                      total 12
                                      was mache ich falsch, bei der installation? muss ich vorher das cul paket https://github.com/hobbyquaker/cul installieren? `
                                      Lasse es. Hobbyquaker hat schon erledigt. KannSt du noch mal vom gut einfach updaten?
