  4. JavaScript
  5. IP Devices im Netzwerk - HTML Tabelle vis, Iqontrol
    6.3k
javascripttemplate
493 Beiträge 26 Kommentatoren 133.5k Aufrufe 41 Beobachtet
  • Mono990M Mono990
    Hallo ich bekomme im log vom iobroker immer diese fehlermeldung. Kann mir jemand helfen?
    iobroker ist auf einem raspi4
    javascript.0	2020-09-30 22:33:20.023	error	(979) at processTimers (internal/timers.js:494:7)
    javascript.0	2020-09-30 22:33:20.023	error	(979) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-09-30 22:33:20.023	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
    javascript.0	2020-09-30 22:33:20.023	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:487:26)
    javascript.0	2020-09-30 22:33:20.023	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
    javascript.0	2020-09-30 22:32:20.025	error	(979) at processTimers (internal/timers.js:494:7)
    javascript.0	2020-09-30 22:32:20.025	error	(979) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-09-30 22:32:20.024	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
    javascript.0	2020-09-30 22:32:20.024	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:487:26)
    javascript.0	2020-09-30 22:32:20.024	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
    javascript.0	2020-09-30 22:31:20.022	error	(979) at processTimers (internal/timers.js:494:7)
    javascript.0	2020-09-30 22:31:20.022	error	(979) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-09-30 22:31:20.022	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
    javascript.0	2020-09-30 22:31:20.022	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:487:26)
    javascript.0	2020-09-30 22:31:20.021	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
    javascript.0	2020-09-30 22:30:20.023	error	(979) at processTimers (internal/timers.js:494:7)
    javascript.0	2020-09-30 22:30:20.023	error	(979) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-09-30 22:30:20.023	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
    javascript.0	2020-09-30 22:30:20.023	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:487:26)
    javascript.0	2020-09-30 22:30:20.022	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
    liv-in-skyL Offline
    liv-in-skyL Offline
    #190
    @Mono990
    bitte poste mal dein script - die zeilennummern unterscheiden sich von meinen
    ist das eine erstinstallation oder lief das vorher schon ?
    Mono990M 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      @Mono990
      Mono990M Offline
      Mono990M Offline
      Mono990
      #191
      @liv-in-sky das ist eine erstinstallation
      //@liv-in-sky 2020  23.8.-17:42
      //HIER WIRD PFAD UND FILENAME DEFINIERT
      const path = "/htmlexample.html";                   //FIlenamen definieren
      const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
      let   braucheEinFile=true;                          // bei true wird ein file geschrieben
      let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
      let   braucheMaterialDesignWidget=true;             // bei true wird ein json in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
      let dpMaterialWidget="0_userdata.0.mein_Ordner.Controll-List-Widget";            // WICHTIG wenn braucheMaterialDesignWidget auf true MATERIALDESIGN List Widget - datenpunkt anlegen : zeichenkette
      let dpVIS="0_userdata.0.mein_Ordner.Linux-Control"         //WICHTIG wenn "braucheEinVISWidget" auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
      let dpMaterialWidgetExtra="0_userdata.0.mein_Ordner.Controll-List-Widgetextra"   // WICHTIG wenn braucheMaterialDesignWidget auf true MATERIALDESIGN List Widget - datenpunkt anlegen : zeichenkette
      let mySchedule=" * * * * * ";                       //jede minute
      let leerzeile=true;                   // leerzeile vor neuem server
      let farbeUeber="#A0C2A0"              //"#4da6ff" (blau)             // farbe der servernamen
      let styleUeber="span"                 // style der server namen:  möglich b fett; i kursiv; span normal
      var mylum=0.0                         //farbveränderung im bezug zum servernamen von HD uns IP
      var mylumFolder=0.0                   //farbveränderung im bezug zur Standarsschriftfarbe von Folder Anzeige
      var mylumService=0.0                 //farbveränderung im bezug zur Standarsschriftfarbe von Serviceanzeige
      var mylumButtons=0.0                  //farbveränderung im bezug zur Standarsschriftfarbe von Buttonsanzeige
      var mylumBefehle=0.0                   //farbveränderung im bezug zur Standarsschriftfarbe von Befehleanzeige
      let mysonderFarbeHDundTEMP="#33ff33"   // farbe in MD List Widget von Temp und root-festplatte
      var serviceTrue="🟢"                 //"🔵"       //⚪      //emoji für dienste die laufen
      var serviceFalse="✖️"                //"🔴"
      var mitShutdownBotton=true;           // zeigt shutdown und restart button an
      var symbolLinkRestart="☢️"
      var symbolLinkShutdown="☢️"
      var symbolLinkCommands="🔘" //"⚠️"
      var farbeOffline="#466d46"            //farbe für server , die offline sind
      var farbeMDbackgroundOffline= "#484837"          //farbe der kachel in MaterialDesign wenn offline
      var farbeMDschriftOffline="#33ff33"//            //farbe der schrift in MaterialDesign wenn offline
      var debug=false;                                  // für script debuggen
      // zweites MD List Widget
      var wantExtra=["Proxmox","IOBroker"]             //  server NAme für extra angezeigte Server - eigenes MD List Widget (dpMaterialWidgetExtra) // leer ist []
      var removeOthers=true;                           // wenn true wird die wantExtra Server aus dem Haupt MD List Widget gelöscht
      var thresholHD=80;
      var thresholTemp=75;
      var thresholPakete=0;
      var braucheShellInaBox=false;          // SHELL IN A BOX einstellungen
      var shellBox="🥟"
      var laengeServiceNamen=11;            // dient zum kürzen von langen service namen
      var bildergröße=17
      const apName = { "FileServer"      : { aname: "https://forum.iobroker.net/assets/uploads/files/1597247720123-fileserver.png"},
                       "IOBroker"        : { aname: "https://upload.wikimedia.org/wikipedia/commons/8/82/IoBroker_Logo.png"},
                       "MotionEye"       : { aname: "https://forum.iobroker.net/assets/uploads/files/1597247718354-motioneye.png"},
                       "Pi-Hole"         : { aname: "https://forum.iobroker.net/assets/uploads/files/1597247720225-pi-hole.png"},
                       "PlexServer"      : { aname: "https://forum.iobroker.net/assets/uploads/files/1597247718413-plexserver.png"},
                       "Proxmox"         : { aname: "https://forum.iobroker.net/assets/uploads/files/1597247718381-proxmox.png"},
                       "SQLTulla"        : { aname: "https://forum.iobroker.net/assets/uploads/files/1597247720017-sqltulla.png"},
                        "AX--HD-60"        : { aname: "https://forum.iobroker.net/assets/uploads/files/1597941596015-ax-hd60.png"},
                        "GalaxyTab2"        : { aname: "https://forum.iobroker.net/assets/uploads/files/1598105726154-samsung.png"},
                       "Raspi"           : { aname: "https://forum.iobroker.net/assets/uploads/files/1597247719882-raspi.png"}}    // oder lokal gespeichert: vis.0/armin/img//server/IOBroker.png
      //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 4
      var htmlFeld1='Server';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
      var htmlFeld2='';             var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
      var htmlFeld3='';             var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
      var htmlFeld4='';             var Feld4lAlign="right";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
      //ÜBERSCHRIFT ÜBER TABELLE
      let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
      let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
      const htmlFeldUeber='Linux Server';              // Überschrift und Signature
      const htmlFarbUber="white";                         // Farbe der Überschrift
      const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
      const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
      //MEHRERE TABELLEN NEBENEINANDER
      let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
      const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
      const farbetrennungsLinie="white";
      const htmlFarbZweiteTabelle="#BDBDBD";                // Farbe der Überschrift bei jeder 2.ten Tabelle
      const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
      //ÜBERSCHRIFT SPALTEN
      const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
      const LinieUnterUeberschrift="3";                   // Linie nur unter Spaltenüberschrift -
      const farbeLinieUnterUeberschrift="white";
      const groesseUeberschrift=16;
      const UeberschriftStyle="normal"                     // möglich "bold"
      //GANZE TABELLE
      let abstandZelle="2";
      let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
      let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
      let weite="auto";                                     //Weite der Tabelle
      let zentriert=true;                                   //ganze tabelle zentriert
      const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
      const htmlSchriftart="Ubuntu-Regular";
      const htmlSchriftgroesse="16px";
      //FELDER UND RAHMEN
      let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
      const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
      const htmlFarbFelderschrift2="#BDBDBD";                 // SchriftFarbe der Felder für jede 2te Tabelle
      const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
      const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
      const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
      let htmlRahmenLinien="all";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
      const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
      // HIER NICHTS  ÄNDERN
      let borderHelpBottum;
      let borderHelpRight;
      let htmlcenterHelp;
      let htmlcenterHelp2;
      if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
      if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
      if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
      if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
      zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
      zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
      const htmlZentriert='<center>'
      const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                       "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                       " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                      // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                       " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                       " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                       "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                       " </style></head><body> <div>";
      //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
      const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                          "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
      const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
      const htmlTabUeber3="</tr>";
      //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 4
      //htmlFeld2="last Update"
      //htmlFeld4=formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")
      const buttonScript =   '<script> function setOnDblClickCustom1( myvalue ) {var Self = this; objID = myvalue;  console.log(myvalue); Self.servConn.setState(objID, true); console.log(objID)} '+
                            '</script>'
      function dlog(message) {
        if(debug)
            console.log(message);
      var htmlOut="";
      var mix;
      var counter;
      var val1; var val2; var val0; var val3;
      var htmlTabUeber="";
      let myArr=[];
      let myArrFolder=[];
      let myArrService=[];
      let myArrButtons=[];
      let myArrBefehle=[];
      let myArrRefresh=[];
      let obj1=[]
       let obj2=[]
      let   countMYWerte;
      let idOld="";
      let helpRestart; let helpShutdown;let helpVersion;let upgrade;let up_date;let up_pack;let helpBild;let helpMem;let helpSwap;let helpTopProcess;let helpLastRefresh;
      let is_running=false
      var myJsonWidget2=[];
      function writeHTML(){
         is_running=true
      let  htmlFeld4help=formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")
      var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+htmlFeld4help+"&ensp;</td>";
      var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align=="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+""+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                         "&ensp;</td><td  align=="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                         "&ensp;</td>";
      htmlOut="";
      counter=-1;
      htmlTabUeber="";
      switch (mehrfachTabelle) {
         case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
         case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
         case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
         case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
      if (!UeberschriftSpalten) {htmlTabUeber=""}
      //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
      //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3 !!!---------------------------------------------------------------------
      myArr=[]; myArrFolder=[]; myArrService=[]; myArrButtons=[]; myArrBefehle=[]; myArrRefresh=[];
      $('linux-control.0.*.info.is_online').each(function(id, i) {         //YXJtaW4uc2xpdmluc2t5QGdtYWlsLm  // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
            var ida = id.split('.');
                  //  linux-control.0.Pi-Hole.control.shutdown
                    //linux-control.0.Pi-Hole.info.is_online
                      val0= ida[2]
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".root") ? val1=getState(ida[0]+"."+ida[1]+"."+ida[2]+".root").val : val1="missing"
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".info.ip") ? val2=getState(ida[0]+"."+ida[1]+"."+ida[2]+".info.ip").val : val2="missing"
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".cpu-temp") ? val3=getState(ida[0]+"."+ida[1]+"."+ida[2]+".cpu-temp").val :val3=""
                      //helpRestart;
                    //  if ( existsState(id.replace("info.is_online","control.restart")))  {mitShutdownBotton ?  helpRestart=id.replace("info.is_online","control.restart") : helpRestart=""} else{helpRestart=""}
                      //helpShutdown;
                    //  log(id)
                     // log ( existsState(id.replace("info.is_online","control.shutdown")).toString())
                    //  if ( existsState(id.replace("info.is_online","control.shutdown"))) {mitShutdownBotton ? helpShutdown=id.replace("info.is_online","control.shutdown") : helpShutdown="";} else{helpShutdown=""}
                   //  log(helpShutdown)
                      //helpVersion
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".distribution.fullname") ? helpVersion=getState(ida[0]+"."+ida[1]+"."+ida[2]+".distribution.fullname").val.replace(/.+ (.+ )\((.+)\)/,"$2 ($1)") : helpVersion=" unknown "
                      //upgrade
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".updates.upgradable") ? upgrade=(getState(ida[0]+"."+ida[1]+"."+ida[2]+".updates.upgradable").val) : up_pack="missing"
                      upgrade ? upgrade="Ja" : upgrade="Nein"
                      //up_date
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".updates.lastUpdate") ? up_date=formatDate(getDateObject(((new Date(getState(ida[0]+"."+ida[1]+"."+ida[2]+".updates.lastUpdate").val).getTime()))), "TT.MM.YY") : up_date="missing"
                      //up_pack;
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".updates.newPackages") ? up_pack=(getState(ida[0]+"."+ida[1]+"."+ida[2]+".updates.newPackages").val) : up_pack="missing"
                      //helpMem
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".mem") ? helpMem=getState(ida[0]+"."+ida[1]+"."+ida[2]+".mem").val :helpMem=""
                      //helpSwap
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".swap") ? helpSwap=getState(ida[0]+"."+ida[1]+"."+ida[2]+".swap").val :helpSwap=""
                      //helpTopProcess
                      existsState(ida[0]+"."+ida[1]+"."+ida[2]+".top-process") ? helpTopProcess=getState(ida[0]+"."+ida[1]+"."+ida[2]+".top-process").val :helpTopProcess=""
                      //helpLastRefresh
                      if ( existsState(id.replace("info.is_online","info.lastRefresh")))  {helpLastRefresh=getState(id.replace("info.is_online","info.lastRefresh")).val } else{helpLastRefresh=""}
                      //helpBild;
                      helpBild="<img src=https://upload.wikimedia.org/wikipedia/commons/8/82/IoBroker_Logo.png height=\""+bildergröße+"\" width=\""+bildergröße+"\">"
                    for(let device_name in apName) {
                           if (val0==device_name) {helpBild="<img src="+apName[device_name].aname+" height=\""+bildergröße+"\" width=\""+bildergröße+"\">"; }}
                    let helpOnline=getState(ida[0]+"."+ida[1]+"."+ida[2]+".info.is_online").val
                    let myhelp=[val0,val1,val2,val3,helpRestart,helpShutdown,helpVersion,helpBild,helpOnline,upgrade,up_date,up_pack,helpMem,helpSwap,helpTopProcess,helpLastRefresh]        ;
                    dlog(myhelp.toString())
                    myArr.push(myhelp)
      //--------------------------Folder
                    let mySelektor="linux-control.0."+ida[2]+".folders.*.size"
                  //  let mymycount=0
                    $(mySelektor).each(function(id2, i) {
                         var ids = id2.split('.');
                          myArrFolder.push([ids[2],ids[4],getState(ids[0]+"."+ids[1]+"."+ids[2]+"."+ids[3]+"."+ids[4]+"."+ids[5]).val,i,getObject(ids[0]+"."+ids[1]+"."+ids[2]+"."+ids[3]+"."+ids[4]+"."+ids[5]).common.unit,id] )
      //--------------------------Services
                    mySelektor="linux-control.0."+ida[2]+".services.*.running"
                    $(mySelektor).each(function(id3, i) {
                         var idx = id3.split('.');
                      //   log(idx[4].replace(/(.+)server.+/g,"$1"))
                        //  myArrService.push([idx[2],idx[4].substring(0,laengeServiceNamen),getState(id3).val,i,id3] )
                          idx[4]=idx[4].replace(/(.+)service/g,"$1")
                          idx[4]=idx[4].replace(/(.+)server\*+/g,"$1")
                          idx[4]=idx[4].substring(0,laengeServiceNamen)
                          myArrService.push([idx[2],idx[4],getState(id3).val,i,id3] )
      //--------------------------Buttons
                    let mycounty=-1
                    mySelektor="state[id=linux-control.0."+ida[2]+".*][role=button]"
                          $(mySelektor).each( function( id4, i){
                            var idy = id4.split('.'); if  (idy.length==4)  mycounty++
                            if  (idy.length==4)  {myArrButtons.push([idy[2],idy[3],mycounty,id4] ); myArrRefresh.push(id4)}
           /////-----------für refresh
                      mycounty=-1
                    mySelektor="state[id=linux-control.0."+ida[2]+".*][role=value]"
                            if  (idy.length==4)  {/*myArrButtons.push([idy[2],idy[3],mycounty,id4] );*/ myArrRefresh.push(id4)}
      //--------------------------Befehle
                    let mycounty2=-1
                    mySelektor="linux-control.0."+ida[2]+".befehle.*"
                          $(mySelektor).each( function( id5, i){  mycounty2++
                            var idz = id5.split('.');  // log(id);mycounty2++
                              myArrBefehle.push([idz[2],idz[4],mycounty2,getState(id5).val] ) ; myArrRefresh.push(id5)
            // counter++; tabelleBind()
        dlog("Länge Server: "+myArr.length.toString())         // ;log(myArr.toString())
        dlog("Länge Folder: "+myArrFolder.length.toString())    //dlog(myArrFolder.toString())
        dlog("Länge Service: "+myArrService.length.toString())   //dlog(myArrService.toString())
        dlog("Länge Buttons: "+myArrButtons.length.toString())   //dlog(myArrButtons.toString())
        dlog("Länge Buttons: "+myArrRefresh.length.toString())   //;log(myArrRefresh.toString())
        dlog("Länge Buttons: "+myArrBefehle.length.toString())   //;log(myArrBefehle.toString())
        countMYWerte=0;
                         for(var i=0;i<myArr.length;i++) {
                          dlog(myArr[i][0] +" und "+idOld)
                     //  if(myArr[i][0]!=idOld){ dlog("erster Ablauf Durchlauf")
                            countMYWerte++
                            tabelleMachSchoen()
                            counter=-1
                            if(leerzeile){
                                          if(countMYWerte>1) for(var a=0;a<mehrfachTabelle;a++ ) { //leerzeile
                                                val0=""; val1=""; val2="";val3="";counter++;tabelleBind();
                if (myArr[i][8])     {
      // ----------------------------erste zeile Zeile
                   for(var ic=0;ic<mehrfachTabelle;ic++ ) { if (i==0 && ic==0)  dlog("Verarbeite erste Zeile");
                        if  (ic==0) { val0=myArr[i][7]+"&ensp; <span style=\"font-size:130%\"><font color=\""+farbeUeber +"\"><"+styleUeber+">"+myArr[i][0]+"<span>";
                                      if(braucheShellInaBox) {val0=val0+" <a style=\" font-size:70% \" href=\"https:\/\/"+ myArr[i][2] + ":4200\" target=\"_blank\" onclick=\"window.open(this.href,this.target,\'width=760,height=640\'); return false;\">"+shellBox+"</a>"}
                          // val1="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][1];
                            myArr[i][1]!="" ? val1="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">HD: "+myArr[i][1]+" %" : val1="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][1];
                            myArr[i][2]!="" ? val2="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][2] : val2="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][2];
                            myArr[i][3]!="" ? val3="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][3]+" °C" : val3="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][3];
                            //Threshold
                           if( myArr[i][1]!="" && myArr[i][1]>thresholHD ) val1="<font color=\""+"red" +"\">HD: <b>"+myArr[i][1]+" %</b>";
                           if( myArr[i][3]!="" && myArr[i][1]>thresholTemp) val3="<font color=\""+"red" +"\"><b>"+myArr[i][3]+" °C</b>" ;
                            } else {val0=""
                                    val1="";
                                    val2="";
                                    val3=""}
                  counter++;
                  tabelleBind();}
      // ----------------------------zweite Zeile
                   if(myArr[i][12]!="")  { let myMemTab=myArr[i][12].split(";");
                      if  (ic==0) { val0="<font color=\""+ColorLuminance(farbeUeber,mylumFolder) +"\">"+"Memory(MB)";
                            if (i==0 && ic==0 )  dlog("Verarbeite zweite Zeile");
                           val1="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">Total: "+myMemTab[0]
                           val2="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">Used: "+myMemTab[1]
                           val3="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">Free :"+myMemTab[2]
                             } else {val0=""
                                     val1="";
                                     val2="";
                                     val3=""}
                  counter++;
                  tabelleBind();}}
                   if(myArr[i][13]!="")  { let myMemTab=myArr[i][13].split(";");
                      if  (ic==0) { val0="<font color=\""+ColorLuminance(farbeUeber,mylumFolder) +"\">"+"Swap(MB)";
                             } else {val0=""
                                     val1="";
                                     val2="";
                                     val3=""}
                  counter++;
                  tabelleBind();}       }
                      if  (ic==0) { val0="<font color=\""+ColorLuminance(farbeUeber,mylumFolder) +"\">"+"Updates";
                           val1="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][9]
                           val2="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][11]+" Paket(e)"
                           val3="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+" zuletzt: "+myArr[i][10]
                             } else {val0=""
                                     val1="";
                                     val2="";
                                     val3=""}
                  counter++;
                  tabelleBind();
      // ----------------------------dritte Zeile
                      if  (ic==0) { val0=""; if (i==0 && ic==0 )  dlog("Verarbeite dritte Zeile");
                            myArr[i][6]!="" ? val1="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][6]+"" : val1="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+myArr[i][6];
                            let valButton=myArr[i][4];
                            myArr[i][4]!="" ? val2="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+ "Restart!&emsp;"+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'"+valButton+"\')\">"+symbolLinkRestart  + "</button>" : val2="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">-" ;
                            valButton=myArr[i][5]
                            myArr[i][5]!="" ? val3="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">"+"Shutdown!&emsp;"+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'"+valButton+"\')\">"+symbolLinkShutdown + "</button>" : val3="<font color=\""+ColorLuminance(farbeUeber,mylum) +"\">-";
                             } else {val0=""
                                     val1="";
                                     val2="";
                                     val3=""}
                  counter++;
                  tabelleBind();
                     } else{
                         if  (ic==0) { val0=myArr[i][7]+"&ensp; <span style=\"font-size:130%\"><font color=\""+farbeMDschriftOffline +"\"><"+styleUeber+"><i>"+myArr[i][0]+"</i><span>";
                             myArr[i][1]!="" ? val1="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\"><i>HD: "+myArr[i][1]+" %</i>" : val1="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\">"+myArr[i][1];
                             myArr[i][2]!="" ? val2="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\"><i>"+myArr[i][2]+"</i>" : val2="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\">"+myArr[i][2];
                             myArr[i][3]!="" ? val3="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\"><i>"+myArr[i][3]+" °C</i>" : val3="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\">"+myArr[i][3];
                             } else {val0=""
                                     val1="";
                                     val2="";
                                     val3=""}
                   counter++;
                   tabelleBind();}
                    if  (ic==0) { val0="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\"><i>"+"Updates"+"</i>" ;
                           val1="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\"><i>"+myArr[i][9]+"</i>"
                           val2="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\"><i>"+myArr[i][11]+"</i>"
                           val3="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\"><i>"+myArr[i][10]+"</i>"
                             } else {val0=""
                                     val1="";
                                     val2="";
                                     val3=""}
                  counter++;
                  tabelleBind();}
                             myArr[i][6]!="" ? val1="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\"><i>"+myArr[i][6]+"</i>" : val1="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\">"+myArr[i][6];
                             myArr[i][4]!="" ? val2="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\">"+ "<i>Restart!&emsp;</i> " : val2="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\">-" ;
                             myArr[i][5]!="" ? val3="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\">"+"<i>Shutdown!&emsp;</i> ": val3="<font color=\""+ColorLuminance(farbeOffline,mylum) +"\">-";
                              } else {val0=""
                                      val1="";
                                      val2="";
                                      val3=""}
                   counter++;
                   tabelleBind(); }
                  tabelleMachSchoen()
                            counter=-1
      //  --------------------------------------------(Folder)
               for(var ib=0;ib<myArrFolder.length;ib++) {  if (i==0 && ib==0) dlog("Verarbeite Folder");
               if (myArrFolder[ib][0]==myArr[i][0]){
                      if (myArr[i][8])     {
                              myArrFolder[ib][3]==0? val0="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumFolder) +"\">"+"Folder"  :val0="";
                              val1="";
                              val2="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumFolder) +"\">"+myArrFolder[ib][1]
                              val3="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumFolder) +"\">"+myArrFolder[ib][2] +" "+myArrFolder[ib][4]
                              counter++; tabelleBind();
                              } else{
                         /*     myArrFolder[ib][3]==0? val0="<font color=\""+ColorLuminance(farbeOffline,mylumFolder) +"\"><i>"+"Folder</i>"  :val0="";
                              val1="";
                              val2="<font color=\""+ColorLuminance(farbeOffline,mylumFolder) +"\"><i>"+myArrFolder[ib][1]+"</i>"
                              val3="<font color=\""+ColorLuminance(farbeOffline,mylumFolder) +"\"><i>"+myArrFolder[ib][2] +" "+myArrFolder[ib][4]+"</i>"
                              counter++; tabelleBind();*/
      //  --------------------------------------------(Service)
             tabelleMachSchoen()
             counter=-1
               for(var ia=0;ia<myArrService.length;ia++) {  if (i==0&& ia==0) dlog("Verarbeite Service");
               if (myArrService[ia][0]==myArr[i][0]){
                     if (myArr[i][8])     {
                              myArrService[ia][3]==0? val0="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumService) +"\">"+"Service"  :val0="";
                              val1="";
                              val2="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumService) +"\">"+myArrService[ia][1]
                              myArrService[ia][2] ? val3=serviceTrue :val3=serviceFalse
                            } else {
                         /*     myArrService[ia][3]==0? val0="<font color=\""+ColorLuminance(farbeOffline,mylumService) +"\"><i>"+"Service</i>"  :val0="";
                              val1="";
                              val2="<font color=\""+ColorLuminance(farbeOffline,mylumService) +"\"><i>"+myArrService[ia][1]+"</i>"
                              val3=serviceFalse
                              counter++; tabelleBind();   */
      //  --------------------------------------------Buttons)
            tabelleMachSchoen()
            counter=-1
                for(var ix=0;ix<myArrButtons.length;ix++) {  if (i==0 && ix==0) dlog("Verarbeite Buttons");
                if (myArrButtons[ix][0]==myArr[i][0]){
                      if (myArr[i][8])     {
                              myArrButtons[ix][2]==0? val0="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumButtons) +"\">" +"Buttons"  :val0="";
                              val1="";
                              val2="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumButtons) +"\">" +myArrButtons[ix][1]
                              let valButton=myArrButtons[ix][3];
                            val3="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumButtons) +"\">" +"(press) <button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:right\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'"+valButton+"\')\">"+symbolLinkCommands; //  myArrButtons[ia][2] ? val3=serviceTrue :val3=serviceFalse
                            } else {
                    /*    myArrButtons[ix][3]==0? val0="<font color=\""+ColorLuminance(farbeOffline,mylumFolder) +"\"><i>"+"Buttons</i>"  :val0="";
                              val1="";
                              val2="<font color=\""+ColorLuminance(farbeOffline,mylumButtons) +"\"><i>"+myArrButtons[ix][1]+"</i>"
                              val3=serviceFalse
      // --------------------------------------------ENDE Buttons
       //  --------------------------------------------Befehle)
            tabelleMachSchoen()
            counter=-1
                for(var ix=0;ix<myArrBefehle.length;ix++) {  if (i==0 && ix==0) dlog("Verarbeite Befehle");
                if (myArrBefehle[ix][0]==myArr[i][0]){
                      if (myArr[i][8])     {
                              myArrBefehle[ix][2]==0? val0="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumBefehle) +"\">"+"Sonstiges"  :val0="";
                              val1="";
                              val2="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumBefehle) +"\">"+myArrBefehle[ix][1]
                              val3="<font color=\""+ColorLuminance(htmlFarbFelderschrift,mylumBefehle) +"\">"+myArrBefehle[ix][3]
                            } else {
                      /*        myArrBefehle[ix][2]==0? val0="<font color=\""+ColorLuminance(farbeOffline,mylumService) +"\"><i>"+"Sonstiges</i>"  :val0="";
                              val1="";
                              val2="<font color=\""+ColorLuminance(farbeOffline,mylumService) +"\"><i>"+myArrBefehle[ix][1]+"</i>"
                              val3="<font color=\""+ColorLuminance(farbeOffline,mylumService) +"\">"+" - "
      // --------------------------------------------ENDE Befehle
                  //  idOld=""//myArr[i][0];
      //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
            tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
          let  timeout22 = setTimeout(function () {
              is_running=false
      }, 5000);
      } // function ende
      //MAIN:
      schedule(mySchedule,  function () {
       writeHTML();
       if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
      writeHTML();
      function tabelleBind(){
           //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 4 Felder definiert, braucht man hier 4 Werte
              case 1:  if(counter%2==0){  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td></tr>"; break;} else
                                       {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td></tr>"; break;}
              case 2: if(counter%4==0){
                       if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                          ";\"align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td>"; }
                                    else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td></tr>";} break;
                          }else{
                       if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                          ";\" align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td>"; }
                                    else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td></tr>";} break;}
              case 3:  if(counter%2==0)   {
                        if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                    else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                                              ";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td>";}
                                                     else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td></tr>";}
                                               } break;}else{
                        if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                               } break;}
              case 4:  if(counter%8==0)   {
                       if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\" align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td>"; }
                                        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td>";}
                                                     else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\"&ensp;>"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+ "color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td></tr>";}
        else    {htmlOut  = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td>";}}
                                               } break;}else{
                       if(counter%4==0)   {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\" align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td>"; }
                                        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+ ";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td>";}
                                                     else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\"&ensp;>"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+"  color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td></tr>";}
                                               } break;     }
           } //switch ende
      function tabelleFinish() {
           dlog("verbeite tableFinish")
           // tabelle fertigstellen
             case 1:    break;
             case 2:
                        if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                        break;
             case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                       if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                       if(counter%3==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                        break;
             case 4:   if(counter%4==3) {  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");}
                       if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                       if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                       if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                       break; }
               var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
              if (!htmlSignature) htmlUnter="";
                //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                 var htmlOutVIS="";
               //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                  if (htmlUberschrift)
                      { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript ;
                    } else {
                     zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript;
        // log("bin raus aus tabelleBind");
                 if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
       var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
       var htmlEnd="</table>"+htmlUnter+"</div></body>";
       //mit oder ohne überschrift - zentriert oder links
      htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
       //log(htmlOut);
      if (braucheMaterialDesignWidget) {
           makeJsonWidget(myArr,myArrFolder,myArrService,myArrButtons,myArrBefehle)
           if(wantExtra)    getProxmox()
           removeOthers  ?  setState(dpMaterialWidget,JSON.stringify(obj2)) : setState(dpMaterialWidget,JSON.stringify(myJsonWidget2));  ;
             myJsonWidget2=[];
      function tabelleMachSchoen(){
             case 1:    break;
             case 2:
                        break;
                        break;
                       break; }
      function ColorLuminance(hex, lum) {
         // validate hex string
         hex = String(hex).replace(/[^0-9a-f]/gi, '');
         if (hex.length < 6) {
         	hex = hex[0]+hex[0]+hex[1]+hex[1]+hex[2]+hex[2];
         lum = lum || 0;
         // convert to decimal and change luminosity
         var rgb = "#", c, i;
         for (i = 0; i < 3; i++) {
         	c = parseInt(hex.substr(i*2,2), 16);
         	c = Math.round(Math.min(Math.max(0, c + (c * lum)), 255)).toString(16);
         	rgb += ("00"+c).substr(c.length);
         return rgb;
      function makeJsonWidget(vax1,vax2,vax3,vax4,vax5) {
      //	log(myJsonWidget)
        //  log(vax1.toString())
          //log(vax2.toString())
          //log(vax3.toString())
          for (var iii=0;iii<vax1.length;iii++){
      let  mystatuscolorbar="";
         //  vax1[iii][8] ? mystatuscolorbar=farbeUeber : mystatuscolorbar=farbeOffline
      let  myimage="";
      let myschriftgroesse=(parseInt(htmlSchriftgroesse.replace("px",""))+10)+"px"
      let mytext
      let mybkgd;
      //myshellIp= `<a href="https://${vax1[iii][2]}:4200"> target="_blank" onclick="window.open(this.href,this.target,width=760,height=640)> </a> ${shellBox} `
      let   myshellIp= ""
       if(braucheShellInaBox) myshellIp= " <a href=\"https:\/\/"+ vax1[iii][2] + ":4200\" target=\"_blank\" onclick=\"window.open(this.href,this.target,\'width=800,height=640\'); return false;\">"+shellBox+"</a>"
        vax1[iii][8] ? mytext=`<span style="color:  ${farbeUeber}; font-size: ${(myschriftgroesse)}"> ${vax1[iii][0]}  </span>${myshellIp}<span style="color:  ${farbeUeber}; font-size: ${(htmlSchriftgroesse)}">${vax1[iii][6]}`  :
                       mytext=`<span style="color:  ${farbeMDschriftOffline}; font-size: ${(htmlSchriftgroesse)}"> ${vax1[iii][0]}  </span><span style="color:  ${farbeMDschriftOffline}; font-size: ${(myschriftgroesse)}">OFFLINE` ;
       vax1[iii][8] ? mybkgd="" : mybkgd=farbeMDbackgroundOffline
          myimage="https://upload.wikimedia.org/wikipedia/commons/8/82/IoBroker_Logo.png"
      for(let device_name in apName) { //log(device_name)                           //Abfrage welches bild
                          for (var i=0;i<vax1.length;i++){
                           if (vax1[iii][0].trim()==device_name.trim()) myimage=apName[device_name].aname; }}//" height=\""+bildergröße+"\" width=\""+bildergröße+"\">"; } } // log(myimage)
       //ColorLuminance(farbeUeber,0.6); log(mysonderFarbe)
      let mysubText
      //let mytemp; vax1[iii][3]!="" ? mytemp="CPU Temp: "+vax1[iii][3] + "°C"  :  mytemp="";
      let mysonderFarbeHDundTEMP2;
      let mysonderFarbeHDundTEMP3;
      let blinkklasse=""
      let blinkklasse2=""
      let arrMem;let arrSwap;let arrTProc; let myMem="";let mySwap="";let myTProc=""; let myMemTable="";let myProcess="";let mySwapRow;let myMemRow
      if(vax1[iii][12]!=""){arrMem=vax1[iii][12].split(";");myMemRow="MEM"} else{arrMem=["","",""];myMemRow=""}
      if(vax1[iii][13]!=""){arrSwap=vax1[iii][13].split(";");mySwapRow="SWAP"} else{arrSwap=["","",""];mySwapRow=""}
      if(vax1[iii][14]!=""){arrTProc=vax1[iii][14].split(";")} else{arrTProc=["","",""]}
      //if(vax1[iii][12]!="") log(arrMem[0]+"  " +arrSwap[0] +"  " +arrTProc[0])
      if(arrMem[0]!="" || arrSwap[0]!="") {myMemTable=`</br>
                       <table  rules="cols" align="center" > <tr><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">(in MB)</td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Total</td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Used</td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Free</td></tr>
                      <tr><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">${myMemRow}</td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align="center"> ${arrMem[0]} </td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align="center"> ${arrMem[1]} </td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align="center"> ${arrMem[2]}</td></tr>
                      <tr><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">${mySwapRow}</td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align="center"> ${arrSwap[0]} </td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align="center"> ${arrSwap[1]}  </td><td style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse}; align="center">${arrSwap[2]}</td></tr></table>`} else{myMemTable=""}
      if( arrTProc[0]!="") {myProcess=`<div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};"> Top-Proc: <span style="font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse+2}; color: ${mysonderFarbeHDundTEMP};" >${arrTProc[0]}%</span> ${arrTProc[1].substring(0,15)} </div>`} else {myProcess=""}
      if(vax1[iii][3]>thresholTemp) { mysonderFarbeHDundTEMP2="yellow"; blinkklasse="blinkklasse" } else {mysonderFarbeHDundTEMP2=mysonderFarbeHDundTEMP;blinkklasse="nix"}
      let mytemp; vax1[iii][3]!="" ? mytemp="CPU Temp: "+`<span class=${blinkklasse} style="font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse+2}; color: ${mysonderFarbeHDundTEMP2};" >${vax1[iii][3]} </span>` + `<span lass=${blinkklasse} style="color: ${mysonderFarbeHDundTEMP2};">°C</span> ` :  mytemp="";
      if(vax1[iii][1]>thresholHD) {mysonderFarbeHDundTEMP2="yellow"; blinkklasse="blinkklasse"} else {mysonderFarbeHDundTEMP2=mysonderFarbeHDundTEMP; blinkklasse="nix"}
      if(vax1[iii][11]>thresholPakete) {mysonderFarbeHDundTEMP3="yellow";blinkklasse2="blinkklasse"} else {mysonderFarbeHDundTEMP3=mysonderFarbeHDundTEMP;blinkklasse2="nix"}
      vax1[iii][8] ?  mysubText =
                      ` <div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};"> ${vax1[iii][2]}</div>
                      <div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};"> ${mytemp}</div>
                      <div  style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Festplatte: <span  class=${blinkklasse} style="font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse+2}; color: ${mysonderFarbeHDundTEMP2};" >${vax1[iii][1]}</span><span style="font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse+2}; color: ${mysonderFarbeHDundTEMP2};" > %</span></div>
                      ${myProcess}
                       <div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Update:  ${vax1[iii][9]} <span class=${blinkklasse2} style="font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse+2}; color: ${mysonderFarbeHDundTEMP3};" >${vax1[iii][11]}</span> Paket(e)</div>
                      ${myMemTable}
                       mysubText =   ` </br>
      {1}
                       <div style="color: ${farbeMDschriftOffline}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};"> ${vax1[iii][2]}</div>
                       <div style="color: ${farbeMDschriftOffline}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Festplatte:  ${vax1[iii][1]}%</div>
                       <div style="color: ${farbeMDschriftOffline}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Update:  ${vax1[iii][9]} ${vax1[iii][11]} Paket(e)</div>
      if (vax1[iii][8]) {
                    mysubText=mysubText.concat(`</br>
                                                <table align="center" ><tr><td valign="top"> <div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Folder:</div>
                    mysubText=mysubText.concat(`<span display: flex; flex-direction: row;> <table align="center" >`)
      for (var i=0;i<vax2.length;i++){
                   if (vax2[i][0]==vax1[iii][0]) {
                     mysubText=mysubText.concat(`<tr><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align=\"left\">${vax2[i][1]}</td><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align=\"left\">&ensp;${vax2[i][2]} ${vax2[i][4]}</td></tr>` )
                      mysubText=mysubText.concat(`</table></span></td>`)
                      mysubText=mysubText.concat(`<td valign="top"><div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Service:</div>
      for (var i=0;i<vax3.length;i++){
                   if (vax3[i][0]==vax1[iii][0]) {
                      let helpextra; vax3[i][2] ? helpextra=serviceTrue :helpextra=serviceFalse
                     mysubText=mysubText.concat( `<tr><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};"  align=\"left\">&ensp;${vax3[i][1]}</td><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align=\"left\">${helpextra}</td></tr>`)
                      mysubText=mysubText.concat("</table></span></td></tr></table>"  )
      //---------------------BUTTONS
      let arrcounter=0
      for (var i=0;i<vax4.length;i++){
                   if (vax4[i][0]==vax1[iii][0]) {arrcounter++;
                   }} //log(vax1[iii][0]+ "   "+ arrcounter.toString())
      if (arrcounter>0) {mysubText=mysubText.concat(`</br>
                                                   <div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Buttons:</div>
      arrcounter=arrcounter-1;
      let mynewi=-1
                       mynewi++
         			//  log(mynewi+"  "+ arrcounter)
         			 if (arrcounter>=1){
         			    if(mynewi%2==1 && mynewi<=arrcounter) mysubText=mysubText.concat( `<tr ><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};"  align=\"left\">&ensp;${vax4[i-1][1]}</td><td  align=\"left\">&ensp; <button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:${htmlSchriftgroesse}\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'${vax4[i-1][3]}')\">${symbolLinkCommands} </td><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align=\"left\">&ensp;${vax4[i][1]}</td><td  align=\"left\">&ensp; <button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:${htmlSchriftgroesse}\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'${vax4[i][3]}')\">${symbolLinkCommands} </td></tr>`)
         				if(mynewi%2==0 && mynewi==arrcounter) mysubText=mysubText.concat( `<tr><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align=\"left\">&ensp;${vax4[i][1]}</td><td align=\"left\">&ensp; <button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:${htmlSchriftgroesse}\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'${vax4[i][3]}')\">${symbolLinkCommands} </td><td></td><td></td></tr>`)
         			 } else {
         			 mysubText=mysubText.concat( `<tr><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align=\"left\">&ensp;${vax4[i][1]}</td><td align=\"left\">&ensp; <button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:${htmlSchriftgroesse}\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'${vax4[i][3]}')\">${symbolLinkCommands} </td></tr>`)
                   //  mysubText=mysubText.concat( `<tr><td align=\"left\">&ensp;${vax4[i][1]}</td><td align=\"left\">&ensp;(press) <button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'${helpextra}')\">${symbolLinkCommands} </td></tr>`)
                      }  // wenn servername stimmt
                      }  // durch button array
                      mysubText=mysubText.concat("</table></span>")
          } //buttons größer 0
      //---------------------Ssonstiges
      arrcounter=0
      for (var i=0;i<vax5.length;i++){
                   if (vax5[i][0]==vax1[iii][0]) {arrcounter++;
      if (arrcounter>0) {
                                                <div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">Sonstige:</div>
                   if (vax5[i][0]==vax1[iii][0]) { let mybool = vax5[i][3] ;  if(mybool=="true") mybool= serviceTrue  ;
                     mysubText=mysubText.concat(`<tr><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align=\"left\">${vax5[i][1]}</td><td style="color: ${htmlFarbFelderschrift}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};" align=\"left\">&ensp;${vax5[i][3]} </td></tr>` )
                      mysubText=mysubText.concat(`</table></span>`)
       }  //ist online - alle arrays
      //  log(vax1[iii][15])                  //+formatDate(getDateObject(((new Date(vax1[iii][15]).getTime()))), "SS:mm:ss")
        vax1[iii][8] ?  mysubText = mysubText+
                      ` <div style="color: ${farbeUeber}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">last refresh: ${formatDate(getDateObject(((new Date(vax1[iii][15]).getTime()))), "SS:mm:ss")}</div>
                       mysubText = mysubText + ` </br>
      {1}
                       <div style="color: ${farbeMDschriftOffline}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">last refresh: ${formatDate(getDateObject(((new Date(vax1[iii][15]).getTime()))), "SS:mm:ss")}</div>
                       <div style="color: ${farbeMDschriftOffline}; font-family: ${htmlSchriftart}; font-size: ${htmlSchriftgroesse};">         am:     ${formatDate(getDateObject(((new Date(vax1[iii][15]).getTime()))), "TT.MM.JJJJ")}</div>
      //log(mytext)
         //    if(vax3<=1)   vax5=farbeNurEinTag
           myJsonWidget2.push({
                     text: mytext,
                     subText: mysubText,
                     statusBarColor: mystatuscolorbar,
                     image: myimage,
                     background: mybkgd,
                     imageColor: "",
                     listType: "text",
                     showValueLabel: false,
                     status: "",
                     Wert : "",
                     Hersteller : ""
      // struktur der array
      // server:     servername,   Hd  ,   ip  , temp,     restart-pfad,     shutdown-pfad.,  version    ,bild mit style,   isOnline,     upgrade,   last update,   anzahl update, mem,  swap , top-process
      // folder:     servername,ordnername,ordnergröße,lauf. zähler ordner,einheit,id
      // service:    servername,servicename,lauf. anzahl service, id
      // buttons:    servername,buttonname,lauf. anzahl button,id
      // befehle:    servername,befehlnname,lauf. anzahl befehl, Wert vin id
      function getProxmox () {
      let merker=0;
      let mynewObj
       let mynewObj2
       obj1=[]
        obj2=[]
      for(var index in myJsonWidget2 ) {
            merker=0;
         for(var me in wantExtra){
         if(myJsonWidget2[index].text.replace(/.+px\"\> (.+) \<\/span\>.+/g,"$1").trim()== wantExtra[me]) { //log(me)
                mynewObj=JSON.parse(JSON.stringify(myJsonWidget2[index]));
                obj1.push(mynewObj)
                merker=1
                } //proxarr
             /*   else { log("jetzt  "+ myJsonWidget2[index].text.replace(/.+px\"\> (.+) \<\/span\>.+/g,"$1")+ "  "+ wantExtra[me] )
                 if(parseInt(me)==0){    mynewObj2=JSON.parse(JSON.stringify(myJsonWidget2[index]));
                     obj2.push(mynewObj2)}
          if(merker==0) {mynewObj2=JSON.parse(JSON.stringify(myJsonWidget2[index]));
                        obj2.push(mynewObj2) ;
                        merker=0;}
      } setState(dpMaterialWidgetExtra,JSON.stringify(obj1)) ;}
          on({id: myArrRefresh ,  change: "ne"}, function (obj) {
        let timeout = setTimeout(function () {
       dlog("BIN DRIN in Refresh")
          if (!is_running) writeHTML();
          if (braucheEinFile && !is_running) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
      }, 5000);
      • Mono990M Mono990
        var thresholHD=80;
        var shellBox="🥟"
        var bildergröße=17
        //GANZE TABELLE
        //FELDER UND RAHMEN
        let htmlcenterHelp;
                              '</script>'
          if(debug)
        var htmlOut="";
        var mix;
        var counter;
        let myArr=[];
        let myArrFolder=[];
        let obj1=[]
         let obj2=[]
        let   countMYWerte;
        let idOld="";
           is_running=true
                           "&ensp;</td>";
        htmlOut="";
        counter=-1;
        htmlTabUeber="";
                        val0= ida[2]
                        //helpRestart;
                        //helpShutdown;
                      //  log(id)
                        //helpVersion
                        //upgrade
                        //up_date
                        //up_pack;
                        //helpMem
                        //helpSwap
                        //helpTopProcess
                        //helpLastRefresh
                        //helpBild;
                      myArr.push(myhelp)
                    //  let mymycount=0
                      let mycounty=-1
                        mycounty=-1
                      let mycounty2=-1
          countMYWerte=0;
                              countMYWerte++
                              tabelleMachSchoen()
                              counter=-1
                              if(leerzeile){
                  if (myArr[i][8])     {
                              //Threshold
                              } else {val0=""
                                      val1="";
                                      val2="";
                                      val3=""}
                    counter++;
                    tabelleBind();}
                               } else {val0=""
                                       val1="";
                                       val2="";
                                       val3=""}
                    counter++;
                    tabelleBind();}}
                               } else {val0=""
                                       val1="";
                                       val2="";
                                       val3=""}
                    counter++;
                    tabelleBind();}       }
                               } else {val0=""
                                       val1="";
                                       val2="";
                                       val3=""}
                    counter++;
                    tabelleBind();
                               } else {val0=""
                                       val1="";
                                       val2="";
                                       val3=""}
                    counter++;
                    tabelleBind();
                       } else{
                               } else {val0=""
                                       val1="";
                                       val2="";
                                       val3=""}
                     counter++;
                     tabelleBind();}
                               } else {val0=""
                                       val1="";
                                       val2="";
                                       val3=""}
                    counter++;
                    tabelleBind();}
                                } else {val0=""
                                        val1="";
                                        val2="";
                                        val3=""}
                     counter++;
                     tabelleBind(); }
                    tabelleMachSchoen()
                              counter=-1
                        if (myArr[i][8])     {
                                val1="";
                                } else{
                                val1="";
               tabelleMachSchoen()
               counter=-1
                       if (myArr[i][8])     {
                                val1="";
                              } else {
                                val1="";
                                val3=serviceFalse
              tabelleMachSchoen()
              counter=-1
                        if (myArr[i][8])     {
                                val1="";
                              } else {
                                val1="";
                                val3=serviceFalse
              tabelleMachSchoen()
              counter=-1
                        if (myArr[i][8])     {
                                val1="";
                              } else {
                                val1="";
                is_running=false
        }, 5000);
        } // function ende
        //MAIN:
         writeHTML();
        writeHTML();
                            }else{
                                                 } break;}else{
                                                 } break;}
                                                 } break;}else{
                                                 } break;     }
             } //switch ende
               case 1:    break;
               case 2:
                          break;
                          break;
                         break; }
                   var htmlOutVIS="";
                      } else {
         //log(htmlOut);
               myJsonWidget2=[];
               case 1:    break;
               case 2:
                          break;
                          break;
                         break; }
           lum = lum || 0;
           return rgb;
        let  myimage="";
        let mytext
        let mybkgd;
        let   myshellIp= ""
        let mysubText
        let blinkklasse=""
        let blinkklasse2=""
                        ${myProcess}
                        ${myMemTable}
                         mysubText =   ` </br>
        {1}
        if (vax1[iii][8]) {
        let arrcounter=0
        let mynewi=-1
                         mynewi++
           			 if (arrcounter>=1){
           			 } else {
        arrcounter=0
        if (arrcounter>0) {
        {1}
        //log(mytext)
                       text: mytext,
                       subText: mysubText,
                       image: myimage,
                       background: mybkgd,
                       imageColor: "",
                       listType: "text",
                       status: "",
                       Wert : "",
                       Hersteller : ""
        let merker=0;
        let mynewObj
         let mynewObj2
         obj1=[]
          obj2=[]
              merker=0;
                  obj1.push(mynewObj)
                  merker=1
                  } //proxarr
                          merker=0;}
        }, 5000);
        liv-in-skyL Offline
        liv-in-skyL Offline
        #192
        @Mono990
        bitte kopiere dir das script vom ersten post und zwar mit dem chrome browser - oder ähnlich - es sollten dann nicht so viele leerzeichen im script sein
        firefox macht da immer ärger - du kannst dann die setting ja "rüber" kopieren
        wenn dann immer noch fehler, machen wir weiter
          @Mono990
          Mono990M Offline
          Mono990M Offline
          Mono990
          #193
          @liv-in-sky habe jetzt alles mit chrome gemacht aber leider immer noch der Fehler.
          javascript.0	2020-10-01 12:34:15.035	error	(979) at processTimers (internal/timers.js:494:7)
          javascript.0	2020-10-01 12:34:15.035	error	(979) at listOnTimeout (internal/timers.js:551:17)
          javascript.0	2020-10-01 12:34:15.035	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
          javascript.0	2020-10-01 12:34:15.034	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:243:26)
          javascript.0	2020-10-01 12:34:15.033	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
          javascript.0	2020-10-01 12:33:15.031	error	(979) at processTimers (internal/timers.js:494:7)
          javascript.0	2020-10-01 12:33:15.031	error	(979) at listOnTimeout (internal/timers.js:551:17)
          javascript.0	2020-10-01 12:33:15.031	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
          javascript.0	2020-10-01 12:33:15.031	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:243:26)
          javascript.0	2020-10-01 12:33:15.030	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
          javascript.0	2020-10-01 12:32:15.029	error	(979) at processTimers (internal/timers.js:494:7)
          javascript.0	2020-10-01 12:32:15.029	error	(979) at listOnTimeout (internal/timers.js:551:17)
          javascript.0	2020-10-01 12:32:15.029	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
          javascript.0	2020-10-01 12:32:15.029	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:243:26)
          javascript.0	2020-10-01 12:32:15.028	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
          javascript.0	2020-10-01 12:31:15.026	error	(979) at processTimers (internal/timers.js:494:7)
          javascript.0	2020-10-01 12:31:15.025	error	(979) at listOnTimeout (internal/timers.js:551:17)
          javascript.0	2020-10-01 12:31:15.025	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
          javascript.0	2020-10-01 12:31:15.025	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:243:26)
          javascript.0	2020-10-01 12:31:15.024	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
          javascript.0	2020-10-01 12:30:15.028	error	(979) at processTimers (internal/timers.js:494:7)
          javascript.0	2020-10-01 12:30:15.028	error	(979) at listOnTimeout (internal/timers.js:551:17)
          javascript.0	2020-10-01 12:30:15.027	error	(979) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
          javascript.0	2020-10-01 12:30:15.027	error	(979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:243:26)
          javascript.0	2020-10-01 12:30:15.026	error	(979) Error in callback: TypeError: Cannot read property 'toString' of null
           //@liv-in-sky Januar 2020 11.2-18:15
          const path = "/htmlip.html";                   //FIlenamen definieren
          let   braucheEinFile=false;                          // bei true wird ein file geschrieben
          let dpVIS="0_userdata.0.mein_Ordner.IP_Devices_im_Netzwerk"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
          let mySchedule=" * * * * * ";                       //jede minute  -  nicht unter eine minute gehen -besser 3 oder 5 minuten nutzen !!!
          const domainName="fritz.box";                  // domainname in der fritzbox definiert
          const ipbereich="192.168.188.0/24";           //  gilt nicht für windows
          const dnsServer="192.168.188.1"               // gilt nicht für windows
          let sortiereClient=true;                     //true nach client false nach ip
          const waitTime=15000;                        // falls längere zeit keine daten kommen - diesen wert erhöhn um 5000 (ms)
          const lastZellColorSetting="lightgreen"      // farbe der zusammenfassung in der letzten zelle der tabelle
          const oerationSystemchange=false;              // false ist linux, true ist windows
          const onlyWinEthernetIF="eth0"                // nur windows über befehl "nmap --iflist" herausfinden
          const farbeNichtErreichbar="#FFBF00";         // farbe für devices, die gerade nicht online sind
          const styleNichtErreichbar="i";             // möglich i=schräg, b ist fett und span ist normal - nur eines  davon !!!
          const kuerzungNamen=23;                      // länge der namen kürzen
          //hier eintragen für die übersetzung der standardnamen - aliase - rechte seite wird statt linker  angezeigt - die beispiele kann man raus löschen
          // BITTE AUF DIE KOMMAs ACHTEN
          const myDeviceNames={ "192.168.178.24"  :"HF Küche Licht",     // ein leeres array wird so erzeugt: const myDeviceNames=[];
                               "192.168.178.29"  :"TrekStor13",
                               "192.168.178.10"  :"Proxmox",
                               "192.168.178.156" :"EchoShow5",
                               "192.168.178.73"  :"MediaPadT5",
                               "192.168.178.151" :"FireTab7",
                               "192.168.178.126" :"Matrix Büro",
                               "192.168.178.20"  :"Matrix Küche",
                               "192.168.178.21"  :"GoSund 2 Matrix",
                               "192.168.178.155" :"GoSund 3 Freezer",
                               "192.168.178.150" :"Gosund 1",
                               "192.168.178.33"  :"SonoffS26",
                               "192.168.178.77"  :"WerBinIch",
                               "192.168.178.81"  :"GalaxyTabA16",
                               "192.168.178.56"  :"FireHDStick",
                               "192.168.178.148" :"Echo Dot 3",
                               "192.168.178.118" :"Echo Beige",
                               "192.168.178.100" :"Echo Plus",
                               "192.168.178.50"  :"Echo Dot Zimmer",
                               "192.168.178.68"  :"HF Desk Haupt"
          var symbolOK="✔️";     // auch möglich: ="✅"   🟩   ✔️  🌎
          var symbolKO="🔔";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz  oder : ="❌"  ⚪   🟢 ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀 😡 🟥 ⬜ 🧊 💬 🗑️ 🔔
          var symbolWARN="ℹ️";    // ="⚠️" oder info: "ℹ️"
          var externalOhneInfo=false;  //noch nicht integriert
          //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
          var htmlFeld1='Name';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
          var htmlFeld2='IP';        var Feld2lAlign="left";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
          var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
          let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
          const htmlFeldUeber='IP Devices List';              // Überschrift und Signature
          let   mehrfachTabelle=3;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
          const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
          const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
          const farbeLinieUnterUeberschrift="lightblue";
          //GANZE TABELLE
          let abstandZelle="1";
          let weite="1200";                                     //Weite der Tabelle
          const htmlSchriftart="Helvetica";
          const htmlSchriftgroesse="14px";
          //FELDER UND RAHMEN
          const htmlFarbFelderschrift="#D8D8D8";                  // SchriftFarbe der Felder
          let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
          // HIER NICHTS  ÄNDERN ---------------------SETTING ENDE ----------------------------------------
          const dpPrefix = "javascript."+ instance +".";
          let htmlcenterHelp;
                             " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:0px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                             " </style></head><body>"; // <div>";
          const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"1px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
          const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\"; style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
          //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
          var htmlTabUeber2=  "<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
          var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                             "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
          var rootcount=true;
          var myObjOld=[];
          var htmlOut="";
          var mix;
          var counter;
          //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
          var val1; var val0; var val2;
          htmlOut="";
          counter=-1;
          htmlTabUeber="";
             case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
          //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
          var myData="xxxxx";
          let myArr=[];
          let myObjExtra=[];
          if(oerationSystemchange ==false){
          exec("sudo -u root nmap -sPR --dns-servers "+dnsServer+" "+ipbereich  , function (error, result, stderr) {
             myData=result
            // setState("0_userdata.0.Tabellen.IPDeviceERROR", result)
             // console.log(result);
          });} else {
          exec((['"C:\\\\Program Files (x86)\\\\Nmap\\\\nmap" ','-sPR  -e ',onlyWinEthernetIF,' --dns-servers ',dnsServer,' ',ipbereich].join('')), function (error, result, stderr) {
             myData=result
          // myData=getState("0_userdata.0.Tabellen.DeviceIPFake").val       //   FÜR TEST
          ////////////////////////////////log(myData)
           if (!myData.includes("xxxx")) {
          var myTimeScanArr=myData.match(/(scanned in) (\d+\.\d+ seconds)/g); //log(myTimeScan)
          // myArr=myData.match(/for\s+([A-Za-z0-9-_]+).f[^(]+\((\d+.\d+.\d+.\d+)\)|(fritz.\w+)\s+\((\d+.\d+.\d+.\d+)\)|(\d+.\d+.\d+.\d+)$/g)
          myArr=myData.match(/for\s+([A-Za-z0-9-_]+).f[^(]+\((\d+\.\d+\.\d+\.\d+)\)|(fritz\.\w+)\s+\((\d+\.\d+\.\d+\.\d+)\)|(\d+\.\d+\.\d+\.\d+)$/gm)
          // log(myArr.toString())
          //myArr.push("10.0.1.200")
          //myArr.push("for iobroker (10.0.1.200)")
          //myArr.push("10.0.1.201")
          //myArr.push("fritz.repeater (10.0.1.200)")
          /////////////////////////////////////log(myArr.toString())
          if(myArr!=null) {
          let var1; let var2; let var3; let varOhneName=[];
          var myObj=[]
              var1="na"; var2="na";
              var1=myArr[i].replace(/(for .+) \(\d+\.\d+\.\d+\.\d+\)/,"$1")
              var1=var1.replace(/(.+)\(.+\)/," $1")
              var2=myArr[i].replace(/for .+ \((\d+\.\d+\.\d+\.\d+)\)/,"$1");//log(var2)
              var2=var2.replace(/.+\((.+)\)/,"$1")
              varOhneName=myArr[i].match(/^(\d+\.\d+\.\d+\.\d+)$/)
              if (varOhneName!=null) {var1=varOhneName[0];var2=varOhneName[0]}
              var3="true";
             /* var2=var2.replace(/[(,)]/g,"")
              for (var index in myDeviceNames) {                   //ersetze mit aliasnamen
                                        //log(index)
                                         if ((var2.trim()).match(index)) {var1="for "+myDeviceNames[index];
                                        // log(val0+" - "+index)
          {1}
            let help=[var1.trim(),var2.trim(),var3]
            if (!(var1=="na" || var2=="na")) myObj.push(help)
            if (rootcount) {/* myObjOld= getState("0_userdata.0.Tabellen.IPDeviceERROR").val */
                            myObjOld.push(help);
                           // myObjOld.push(help);
                            createState(dpPrefix+"Tabellen.IPDevices.Device_Collection", myObjOld,  { name: 'Device_Collection', desc: 'Device_Collection', type: 'array',read: true, write: true });
                            else{
                            myObjOld=getState(dpPrefix+"Tabellen.IPDevices.Device_Collection").val;
          //log("++++++++++++++++++ "+myObj.toString())
          //setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString())
             let varhelp1; let varhelp2; let varhelp3="true";    //neue erkannt geräte zu datenbank hinzufügen
            for (var i=0;i<myObj.length;i++){
                 //  log(myObj[i][0]+"-----"+myObjOld[i][0])
                     if (!myObjOld.toString().includes(myObj[i][1]))  {  varhelp1=myObj[i][0].trim() ; varhelp2=myObj[i][1]; varhelp3="true";
                                                              let help=[varhelp1,varhelp2,varhelp3]
                                                             if (!(varhelp1.indexOf("scanned")>-1)) myObjOld.push(help)
            for (var i=0;i<myObjOld.length;i++){                // ist gerät noch da ???
                     if (!myObj.toString().includes(myObjOld[i][1]))  {  varhelp1=myObjOld[i][0].trim() ; varhelp2=myObjOld[i][1]; varhelp3="false";
                                                              myObj.push(help)
             // log("------------------------------------------------"+myObjOld[1].toString())
           /*    if (sortiereClient){
          {1}
                  myObj.sort(function (alpha, beta) {
                      if (alpha[0].toUpperCase().trim() > beta[0].toUpperCase().trim())
                         return 1;
                      if (beta[0].toUpperCase().trim() > alpha[0].toUpperCase().trim())
                         return -1;
                      return 0;
                     });} else {  */
          if (!sortiereClient){
                         if (parseFloat(beta[1].replace(/.+\.(.+)$/,"$1")) > parseFloat(alpha[1].replace(/.+\.(.+)$/,"$1")))
                             return -1;
                         if (parseFloat(alpha[1].replace(/.+\.(.+)$/,"$1")) > parseFloat(beta[1].replace(/.+\.(.+)$/,"$1")))
                             return 1;
                      return 0;
              var1="scanned in" //nur scanned seconds
             var3="true"
             var2=myTimeScanArr[0].replace(/.+ (\d+\.\d+.+$)/,"$1");//log(var2)
             let help=[var1,var2,var3]
            if (sortiereClient) help=["xxxx"+var1,var2,var3]
            myObj.push(help)
          if (!rootcount)  setState(dpPrefix+"Tabellen.IPDevices.Device_Collection", myObjOld)
          ///////////////////////////log("myObject ------- "+myObj.length.toString()+"---- ")
           // setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString())   // zur fehlersuche
          for(var i=0;i<myObj.length;i++) {            // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                    counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                  //  log(myObj[i][0].toString())
                    val0=myObj[i][0].replace("for","").trim()
                    val0=val0.replace("."+domainName,"")
                    val0=val0.replace(/[(,)]/g,"")
                    val1=myObj[i][1]
                    val1=val1.replace(/[(,)]/g,"")
                                        //log(index)
                                         if ((val1.trim()).match(index.trim()) && val1.trim().length == index.trim().length) {val0=myDeviceNames[index];
                                         //log(val0+" - "+index)
                      if (val0.length>=(kuerzungNamen)+2)  val0=val0.substring(0,kuerzungNamen)+" ..."
                    var val2help=myObj[i][2]
                    if (val2help=="false") {val2=symbolKO;
                                            val0=("<font color=\""+farbeNichtErreichbar+"\"><"+styleNichtErreichbar+">")+val0+ "<\/"+styleNichtErreichbar+">";
                                            val1=("<font color=\""+farbeNichtErreichbar+"\"><"+styleNichtErreichbar+">")+val1+ "<\/"+styleNichtErreichbar+">";}  else{val2=symbolOK}
               if(val0=="scanned in") {val2=symbolWARN;val0="<font color=\""+lastZellColorSetting+"\"><i>"+" Anzahl "+counter+"</i>"; val1="<font color=\""+lastZellColorSetting+"\"><i>"+val1+"</i>"}
               tabelleBind(); }//HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
               else {let help=[val0.trim(),val1,val2help];myObjExtra.push(help);}
          }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                 counter=-1;
                  myObjExtra.sort(function (alpha, beta) {
                      if ((alpha[0].toUpperCase()).trim() > (beta[0].toUpperCase()).trim())
                         return 1;
                      if ((beta[0].toUpperCase()).trim() > (alpha[0].toUpperCase()).trim())
                         return -1;
                      return 0;
                     for(var i=0;i<myObjExtra.length;i++) {
                         counter++
                         val0=myObjExtra[i][0] ;
                         val1=myObjExtra[i][1] ;
                         val2help=myObjExtra[i][2] ;
                         if(val0=="xxxxscanned in") {val2=symbolWARN;
                         tabelleBind();
                                                       tabelleFinish();
                                                     }, 2000);
                 }  else {log("no Array","warn")} //Ende Array falsch
                 } else {log("no Data","warn")} // ende daten falsch
                 rootcount=false;
          }, waitTime);
          } // function ende
          //MAIN:
           if (!rootcount) writeHTML();
          // if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
          writeHTML();
             //  counter=counter+mehrfachTabelle;
                 switch (mehrfachTabelle) {
                   case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td></tr>"; break;}else
                                                    {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td></tr>"; break;}
                              if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">"+val2+"</td>"; }
                                         else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td></tr>";} break;
                                }else{
                                          if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">"+val2+"</td>"; }
                                         else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td></tr>";} break;}
                   case 3:if(counter%2==0)   {
                              if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                         else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td>";}
                                                          else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td></tr>";}
                                                    } break;}else{
                              if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                                    } break;}
                   case 4:  // counter=counter+8;
                             if(counter%8==0)   {
                             if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
                                             else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
                                                          else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut =htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
                                                    } break;}else{
                             if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
                                             else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
                                                          else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
                                                    } break;}
                  } //switch ende
                 case 1:    break;
                 case 2:
                            if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                            break;
                           if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                           if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                            break;
                 case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                           if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                           if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                           if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                           break; }
                //  log(" ist htmlUnter - signature "+htmlUnter)
                     var htmlOutVIS="";
                          { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                        } else {
                         zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
           //log(htmlOut);
          Mono990M 1 Antwort Letzte Antwort
          • Mono990M Mono990
            //HIER WIRD PFAD UND FILENAME DEFINIERT
            const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
            let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
            //ÜBERSCHRIFT ÜBER TABELLE
            let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
            const htmlFarbUber="white";                         // Farbe der Überschrift
            const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
            const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
            //MEHRERE TABELLEN NEBENEINANDER
            const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
            const farbetrennungsLinie="white";
            const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
            //ÜBERSCHRIFT SPALTEN
            const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
            const groesseUeberschrift=16;
            const UeberschriftStyle="normal"                     // möglich "bold"
            //GANZE TABELLE
            let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
            let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
            let zentriert=true;                                   //ganze tabelle zentriert
            const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
            //FELDER UND RAHMEN
            let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
            const htmlFarbFelderschrift2="#BDBDBD";                 // SchriftFarbe der Felder für jede 2te Tabelle
            const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
            const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
            const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
            const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
            let borderHelpBottum;
            let borderHelpRight;
            let htmlcenterHelp;
            let htmlcenterHelp2;
            if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
            if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
            if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
            if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
            zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
            zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
            const htmlZentriert='<center>'
            const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                               "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                               " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                              // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                               " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                               "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
            //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                                  "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
            const htmlTabUeber3="</tr>";
            var rootcount=true;
            var myObjOld=[];
            var htmlTabUeber="";
            var htmlOut="";
            var mix;
            var counter;
            function writeHTML(){
            htmlOut="";
            counter=-1;
            htmlTabUeber="";
               case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
               case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
               case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
            if (!UeberschriftSpalten) {htmlTabUeber=""}
            //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
            var myData="xxxxx";
            let myArr=[];
            let myObjExtra=[];
               myData=result
            });} else {
               myData=result
            if(myArr!=null) {
            var myObj=[]
            for(var i=0;i<myArr.length;i++) {
                var3="true";
                                          //log(index)
            {1}
                              else{
        myObj.push(help)
            {1}
                           return 1;
                           return -1;
                        return 0;
                       });} else {  */
                               return -1;
                               return 1;
                        return 0;
               var3="true"
              myObj.push(help)
                      val1=myObj[i][1]
                                          //log(index)
                   counter=-1;
                           return 1;
                           return -1;
                        return 0;
                           counter++
                           tabelleBind();
                                                         tabelleFinish();
                                                       }, 2000);
                   rootcount=false;
            }, waitTime);
            } // function ende
            //MAIN:
            writeHTML();
                                  }else{
                                                      } break;}else{
                                                      } break;}
                               if(counter%8==0)   {
                                                      } break;}else{
                                                      } break;}
                    } //switch ende
                   case 1:    break;
                   case 2:
                              break;
                              break;
                             break; }
                       var htmlOutVIS="";
                          } else {
             //log(htmlOut);
            Mono990M Offline
            Mono990M Offline
            Mono990
            #194
            bei scripte kommt unten auch der fehler
            12:37:15.029	error	javascript.0 (979) at Object.<anonymous> (script.js.common.ip_adressen_im_netzwerk:243:26)
            • Mono990M Mono990
              liv-in-skyL Offline
              liv-in-skyL Offline
              #195
              @Mono990
              so wie es aussieht, ist im ersten post ein abgeschnittenes script drin gewesen - eine alte version
              bitte lösche den ganzen datenpunkt "javascript.0.Tabellen.IPDevices.Device_Collection"
              kopiere dir das neue script vom ersten post - diesmal ist hoffentlich das richtige drin (ca 580 zeilen)
              es gab mal eine zeit, da hatte ich beim kopieren der scripte ins forum den fehler, dass beim sichern nicht alles geklappt hat - das jetztige script läuft bei mir und funktioniert auch - die settings können etwas anders sein - daher vorsicht beim reinkopieren deiner settings
              es gibt in dem script 2 variablen, die gleichzeitig genutzt werden können - bitte keine doppelten einträge - entweder in myDeviceNames oder in myDeviceNamesNew eintragen - aber nicht in beide - im 2ten hat man die möglichkeit, links zu den adminseiten der jeweiligen geräte zu definieren
              • liv-in-skyL liv-in-sky
                @Mono990
                Mono990M Offline
                Mono990M Offline
                Mono990
                #196
                @liv-in-sky Jetzt läuft es einwandfrei vielen dank
                • Holger EtzelH Offline
                  Holger Etzel
                  #197
                  habe wohl ein Problem mit der Installation von nmap.
                  Im Hauptverzeichnis vom Raspi den Befehl apt-get install nmap ergibt:
                  E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                  E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                  mit sudo apt-get install nmap:
                  Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                  rpi-eeprom-images
                  Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                  Die folgenden zusätzlichen Pakete werden installiert:
                  libblas3 libgfortran5 liblinear3 liblua5.3-0 libpcap0.8 nmap-common
                  Vorgeschlagene Pakete:
                  liblinear-tools liblinear-dev ncat ndiff zenmap
                  Die folgenden NEUEN Pakete werden installiert:
                  libblas3 libgfortran5 liblinear3 liblua5.3-0 libpcap0.8 nmap nmap-common
                  0 aktualisiert, 7 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                  Es müssen noch 5.665 kB von 6.229 kB an Archiven heruntergeladen werden.
                  Nach dieser Operation werden 27,3 MB Plattenplatz zusätzlich benutzt.
                  Möchten Sie fortfahren? [J/n] j
                  Fehl:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf nmap-common all 7.70+dfsg1-6
                  404 Not Found
                  Fehl:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf nmap armhf 7.70+dfsg1-6
                  404 Not Found
                  E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/n/nmap/nmap-common_7.70+dfsg1-6_all.deb 404 Not Found
                  E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/n/nmap/nmap_7.70+dfsg1-6_armhf.deb 404 Not Found
                  E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                  Hat jemand eine Ahnung was ich hier machen muss?
                  gruß
                  Holger
                  • Holger EtzelH Holger Etzel
                    rpi-eeprom-images
                    404 Not Found
                    404 Not Found
                    gruß
                    Holger
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #198
                    @Holger-Etzel sagte in IP Devices im Netzwerk - HTML Tabelle vis, Iqontrol:
                    hast du ein "sudo apt-get update" zuvor ausgeführt ?
                    Holger EtzelH 1 Antwort Letzte Antwort
                      Holger Etzel
                      #199
                      @liv-in-sky natürlich nicht. Habe das jetzt gemacht und die Daten wurden geholt und installiert.
                      Bekomme in der VIS aber keine Anzeige.
                      Bekomme im LOG die Fehlermeldung:
                      script.js.System.Status_Geräte_online: no Array
                      Datenpunkte sind angelegt und im Skript eingetragen
                      Holger
                        Holger
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #200
                        @Holger-Etzel
                        hast du mal den befehl nmap auf der konsole ausgeführt - no array heißt, der befehl hat keine daten zurückgegeben
                        nmap -sPR --dns-servers 192.168.178.1 192.168.178.0/24
                        oder eigener ip bereich
                        muss als root ausgeführt werden
                        Holger EtzelH 2 Antworten Letzte Antwort
                          @Holger-Etzel
                          Holger Etzel
                          #201
                          @liv-in-sky hier werden die Netzwerkgeräte gefunden
                            @Holger-Etzel
                            Holger Etzel
                            #202
                            @liv-in-sky jetzt habe ich eine Tabelle mit den Geräten und IP-Adressen.
                            Was bedeutet die Angabe 0/24 bei den IP-Adressen?
                            Danke schon mal
                              Danke schon mal
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #203
                              @Holger-Etzel der bereich 192.168.178.0 bis 192.168.178.255 wird genutzt - also 256 adressen insgesamt
                                Danke schon mal
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #204
                                @Holger-Etzel
                                manchmal kommt beim script dieses no array - ist bei mir auch so - hat irgendwas mit dem nmap und linux zu tun
                                  @Holger-Etzel
                                  Holger Etzel
                                  #205
                                  @liv-in-sky
                                  bin schon mal begeistert.
                                  Kann es sein das die Sortierung nach IP nicht funktioniert.
                                  An der Tabelle ändert sich nichts, egal ob ich true oder false im sortiereClient eingebe ???
                                    @liv-in-sky
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #206
                                    @Holger-Etzel
                                    irgendwie ist da ein fehler drin - schaue ich mir morgen mal an
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #207
                                      @Holger-Etzel
                                      ich weiß nicht mehr warum, aber wenn "braucheMaterialDesignWidget" oder "braucheMaterialDesignWidgetList" auf true gesetzt sind, wird nicht mehr sortiert - das hat einen grund, habe ich aber vergessen
                                      wenn du die html tabelle nutzt, setze die beiden auf false und "sortiereClient" auch auf false, dann wird sortiert auf IP
                                        @Holger-Etzel
                                        Holger Etzel
                                        #208
                                        @liv-in-sky
                                        danke, Läuft soweit.
                                        • L Offline
                                          luft-post
                                          #209
                                          Moin,
                                          einmal kurz nachgefragt: Kann es sein das gerade sortieren nach IP Adressen (sortiereClient=false) nicht funktioniert?
                                          Matthias
