  4. ioBroker als Standard User anmelden
userbenutzer
56 Beiträge 3 Kommentatoren 9.6k Aufrufe 2 Beobachtet
    @Homoran
    top?
    Eher
    ps aux | grep iobroker
    Aber
    dmesg
    ist auch immer gern gesehen, stimmt.
    Habedere
    @Thomas-Braun sagte in ioBroker als Standard User anmelden:
    dmesg
    pi@orangepizero:~$ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.13-sunxi (root@nightly) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5.69 SMP Wed Jan 9 16:26:48 CET 2019
    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Zero
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 128 MiB at 0x57c00000
    [    0.000000] On node 0 totalpages: 131072
    [    0.000000]   Normal zone: 1152 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
    [    0.000000] random: get_random_bytes called from start_kernel+0x8d/0x3c2 with crng_init=0
    [    0.000000] percpu: Embedded 18 pages/cpu @(ptrval) s41484 r8192 d24052 u73728
    [    0.000000] pcpu-alloc: s41484 r8192 d24052 u73728 alloc=18*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
    [    0.000000] Kernel command line: root=UUID=9cecf84e-027e-40ad-b711-ae5d323d9043 rootwait rootfstype=ext4 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=3b2f264b-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] allocated 524288 bytes of page_ext
    [    0.000000] Memory: 368240K/524288K available (8192K kernel code, 896K rwdata, 2420K rodata, 1024K init, 316K bss, 24976K reserved, 131072K cma-reserved, 0K highmem)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
                       lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
                       pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                       modules : 0xbf800000 - 0xbfe00000   (   6 MB)
                         .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                         .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                         .data : 0x(ptrval) - 0x(ptrval)   ( 897 kB)
                          .bss : 0x(ptrval) - 0x(ptrval)   ( 317 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 36585 entries in 72 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    [    0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    [    0.000026] Switching to timer-based delay loop, resolution 41ns
    [    0.000341] Console: colour dummy device 80x30
    [    0.000429] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    [    0.000449] pid_max: default: 32768 minimum: 301
    [    0.000904] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.000921] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.002445] CPU: Testing write buffer coherency: ok
    [    0.003192] CPU0: update cpu_capacity 1024
    [    0.003205] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.004232] Setting up static identity map for 0x40100000 - 0x40100054
    [    0.004511] rcu: Hierarchical SRCU implementation.
    [    0.005902] smp: Bringing up secondary CPUs ...
    [    0.017138] CPU1: update cpu_capacity 1024
    [    0.017150] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.028529] CPU2: update cpu_capacity 1024
    [    0.028540] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.039816] CPU3: update cpu_capacity 1024
    [    0.039827] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.039996] smp: Brought up 1 node, 4 CPUs
    [    0.040009] SMP: Total of 4 processors activated (192.00 BogoMIPS).
    [    0.040016] CPU: All CPU(s) started in HYP mode.
    [    0.040021] CPU: Virtualization extensions available.
    [    0.042020] devtmpfs: initialized
    [    0.054509] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
    [    0.054892] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.054921] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.064069] xor: measuring software checksum speed
    [    0.103906]    arm4regs  :   598.000 MB/sec
    [    0.144015]    8regs     :   356.000 MB/sec
    [    0.184149]    32regs    :   365.000 MB/sec
    [    0.224269]    neon      :   605.000 MB/sec
    [    0.224277] xor: using function: neon (605.000 MB/sec)
    [    0.224385] pinctrl core: initialized pinctrl subsystem
    [    0.226143] NET: Registered protocol family 16
    [    0.230542] DMA: preallocated 2048 KiB pool for atomic coherent allocations
    [    0.231502] audit: initializing netlink subsys (disabled)
    [    0.231819] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
    [    0.232663] cpuidle: using governor ladder
    [    0.232723] cpuidle: using governor menu
    [    0.233706] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.233716] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.328928] raid6: int32x1  gen()    89 MB/s
    [    0.397143] raid6: int32x1  xor()    76 MB/s
    [    0.465314] raid6: int32x2  gen()   122 MB/s
    [    0.533438] raid6: int32x2  xor()    94 MB/s
    [    0.601603] raid6: int32x4  gen()   123 MB/s
    [    0.670085] raid6: int32x4  xor()    92 MB/s
    [    0.738306] raid6: int32x8  gen()   118 MB/s
    [    0.806356] raid6: int32x8  xor()    82 MB/s
    [    0.874429] raid6: neonx1   gen()   235 MB/s
    [    0.942637] raid6: neonx1   xor()   219 MB/s
    [    1.010974] raid6: neonx2   gen()   316 MB/s
    [    1.079094] raid6: neonx2   xor()   282 MB/s
    [    1.147305] raid6: neonx4   gen()   379 MB/s
    [    1.215560] raid6: neonx4   xor()   318 MB/s
    [    1.283817] raid6: neonx8   gen()   341 MB/s
    [    1.351968] raid6: neonx8   xor()   288 MB/s
    [    1.351975] raid6: using algorithm neonx4 gen() 379 MB/s
    [    1.351981] raid6: .... xor() 318 MB/s, rmw enabled
    [    1.351988] raid6: using neon recovery algorithm
    [    1.354762] SCSI subsystem initialized
    [    1.355156] libata version 3.00 loaded.
    [    1.355513] usbcore: registered new interface driver usbfs
    [    1.355588] usbcore: registered new interface driver hub
    [    1.355725] usbcore: registered new device driver usb
    [    1.356046] media: Linux media interface: v0.10
    [    1.356105] videodev: Linux video capture interface: v2.00
    [    1.356324] pps_core: LinuxPPS API ver. 1 registered
    [    1.356333] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.356363] PTP clock support registered
    [    1.358970] clocksource: Switched to clocksource arch_sys_counter
    [    1.530678] VFS: Disk quotas dquot_6.6.0
    [    1.530834] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.546089] NET: Registered protocol family 2
    [    1.547496] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    1.547546] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [    1.547652] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    [    1.547774] TCP: Hash tables configured (established 4096 bind 4096)
    [    1.547948] UDP hash table entries: 256 (order: 1, 8192 bytes)
    [    1.548010] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    [    1.548348] NET: Registered protocol family 1
    [    1.549326] RPC: Registered named UNIX socket transport module.
    [    1.549335] RPC: Registered udp transport module.
    [    1.549341] RPC: Registered tcp transport module.
    [    1.549347] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.549766] Trying to unpack rootfs image as initramfs...
    [    2.154854] Freeing initrd memory: 4820K
    [    2.158179] Initialise system trusted keyrings
    [    2.158551] workingset: timestamp_bits=14 max_order=17 bucket_order=3
    [    2.169924] zbud: loaded
    [    2.174057] NFS: Registering the id_resolver key type
    [    2.174097] Key type id_resolver registered
    [    2.174104] Key type id_legacy registered
    [    2.174126] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    2.174135] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    [    2.176383] JFS: nTxBlock = 3938, nTxLock = 31508
    [    2.197263] Key type asymmetric registered
    [    2.197280] Asymmetric key parser 'x509' registered
    [    2.197397] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
    [    2.197662] io scheduler noop registered
    [    2.197671] io scheduler deadline registered
    [    2.198011] io scheduler cfq registered (default)
    [    2.198020] io scheduler mq-deadline registered
    [    2.198028] io scheduler kyber registered
    [    2.198290] io scheduler bfq registered
    [    2.200531] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
    [    2.208281] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
    [    2.211205] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
    [    2.308627] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
    [    2.312989] console [ttyS0] disabled
    [    2.333244] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A
    [    2.333340] console [ttyS0] enabled
    [    2.343874] brd: module loaded
    [    2.354349] loop: module loaded
    [    2.358571] libphy: Fixed MDIO Bus: probed
    [    2.359647] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
    [    2.359720] dwmac-sun8i 1c30000.ethernet: No regulator found
    [    2.360249] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
    [    2.360286] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
    [    2.360297] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
    [    2.360308] dwmac-sun8i 1c30000.ethernet: COE Type 2
    [    2.360319] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
    [    2.360331] dwmac-sun8i 1c30000.ethernet: Normal descriptors
    [    2.360343] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
    [    2.360575] libphy: stmmac: probed
    [    2.361506] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
    [    2.361685] libphy: mdio_mux: probed
    [    2.361721] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
    [    2.361736] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
    [    2.370124] libphy: mdio_mux: probed
    [    2.371805] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.371814] ehci-platform: EHCI generic platform driver
    [    2.372140] ehci-platform 1c1a000.usb: EHCI Host Controller
    [    2.372210] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
    [    2.373540] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000
    [    2.386998] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
    [    2.387509] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [    2.387525] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.387536] usb usb1: Product: EHCI Host Controller
    [    2.387548] usb usb1: Manufacturer: Linux 4.19.13-sunxi ehci_hcd
    [    2.387559] usb usb1: SerialNumber: 1c1a000.usb
    [    2.388618] hub 1-0:1.0: USB hub found
    [    2.388708] hub 1-0:1.0: 1 port detected
    [    2.390264] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    2.390309] ohci-platform: OHCI generic platform driver
    [    2.390601] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
    [    2.390639] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
    [    2.391056] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400
    [    2.455474] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
    [    2.455489] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.455501] usb usb2: Product: Generic Platform OHCI controller
    [    2.455513] usb usb2: Manufacturer: Linux 4.19.13-sunxi ohci_hcd
    [    2.455524] usb usb2: SerialNumber: 1c1a400.usb
    [    2.456460] hub 2-0:1.0: USB hub found
    [    2.456550] hub 2-0:1.0: 1 port detected
    [    2.458780] usbcore: registered new interface driver usb-storage
    [    2.460179] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
    [    2.460192] sun6i-rtc 1f00000.rtc: RTC enabled
    [    2.460554] i2c /dev entries driver
    [    2.463070] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
    [    2.464504] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
    [    2.465394] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.465498] sunxi-mmc 1c0f000.mmc: Got CD GPIO
    [    2.465530] hidraw: raw HID events driver (C) Jiri Kosina
    [    2.465776] usbcore: registered new interface driver usbhid
    [    2.465782] usbhid: USB HID core driver
    [    2.473488] Initializing XFRM netlink socket
    [    2.474717] NET: Registered protocol family 10
    [    2.491078] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
    [    2.504753] Segment Routing with IPv6
    [    2.504951] NET: Registered protocol family 17
    [    2.504994] NET: Registered protocol family 15
    [    2.505095] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    2.505191] 8021q: 802.1Q VLAN Support v1.8
    [    2.505281] Key type dns_resolver registered
    [    2.506084] Registering SWP/SWPB emulation handler
    [    2.507168] registered taskstats version 1
    [    2.507176] Loading compiled-in X.509 certificates
    [    2.507351] zswap: loaded using pool lzo/zbud
    [    2.510923] Btrfs loaded, crc32c=crc32c-generic
    [    2.524087] Key type encrypted registered
    [    2.527236] mmc0: host does not support reading read-only switch, assuming write-enable
    [    2.530417] mmc0: new high speed SDHC card at address aaaa
    [    2.532781] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
    [    2.543617] ehci-platform 1c1b000.usb: EHCI Host Controller
    [    2.543673] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
    [    2.544057]  mmcblk0: p1
    [    2.545665] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000
    [    2.562983] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
    [    2.563393] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [    2.563409] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.563421] usb usb3: Product: EHCI Host Controller
    [    2.563433] usb usb3: Manufacturer: Linux 4.19.13-sunxi ehci_hcd
    [    2.563443] usb usb3: SerialNumber: 1c1b000.usb
    [    2.564359] hub 3-0:1.0: USB hub found
    [    2.564433] hub 3-0:1.0: 1 port detected
    [    2.565914] ehci-platform 1c1c000.usb: EHCI Host Controller
    [    2.565973] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
    [    2.566460] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000
    [    2.578985] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
    [    2.579358] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [    2.579372] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.579383] usb usb4: Product: EHCI Host Controller
    [    2.579395] usb usb4: Manufacturer: Linux 4.19.13-sunxi ehci_hcd
    [    2.579406] usb usb4: SerialNumber: 1c1c000.usb
    [    2.580255] hub 4-0:1.0: USB hub found
    [    2.580326] hub 4-0:1.0: 1 port detected
    [    2.581670] ehci-platform 1c1d000.usb: EHCI Host Controller
    [    2.581710] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
    [    2.582130] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000
    [    2.594995] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
    [    2.595406] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [    2.595421] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.595432] usb usb5: Product: EHCI Host Controller
    [    2.595444] usb usb5: Manufacturer: Linux 4.19.13-sunxi ehci_hcd
    [    2.595454] usb usb5: SerialNumber: 1c1d000.usb
    [    2.596319] hub 5-0:1.0: USB hub found
    [    2.596389] hub 5-0:1.0: 1 port detected
    [    2.597724] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
    [    2.597777] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
    [    2.598163] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400
    [    2.659336] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
    [    2.659351] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.659363] usb usb6: Product: Generic Platform OHCI controller
    [    2.659374] usb usb6: Manufacturer: Linux 4.19.13-sunxi ohci_hcd
    [    2.659385] usb usb6: SerialNumber: 1c1b400.usb
    [    2.660269] hub 6-0:1.0: USB hub found
    [    2.660341] hub 6-0:1.0: 1 port detected
    [    2.661672] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
    [    2.661715] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
    [    2.662063] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400
    [    2.723307] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
    [    2.723323] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.723335] usb usb7: Product: Generic Platform OHCI controller
    [    2.723346] usb usb7: Manufacturer: Linux 4.19.13-sunxi ohci_hcd
    [    2.723357] usb usb7: SerialNumber: 1c1c400.usb
    [    2.724215] hub 7-0:1.0: USB hub found
    [    2.724286] hub 7-0:1.0: 1 port detected
    [    2.725573] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
    [    2.725613] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
    [    2.726003] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400
    [    2.787324] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
    [    2.787341] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.787352] usb usb8: Product: Generic Platform OHCI controller
    [    2.787364] usb usb8: Manufacturer: Linux 4.19.13-sunxi ohci_hcd
    [    2.787374] usb usb8: SerialNumber: 1c1d400.usb
    [    2.788210] hub 8-0:1.0: USB hub found
    [    2.788291] hub 8-0:1.0: 1 port detected
    [    2.789673] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
    [    2.789781] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
    [    2.792217] of_cfs_init
    [    2.792376] of_cfs_init: OK
    [    2.792488] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4
    [    2.792645] vcc3v0: disabling
    [    2.792656] vcc5v0: disabling
    [    2.792663] vcc-wifi: disabling
    [    2.794100] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.4
    [    2.802999] Freeing unused kernel memory: 1024K
    [    2.815358] Run /init as init process
    [    2.900772] random: systemd-udevd: uninitialized urandom read (16 bytes read)
    [    2.901765] random: systemd-udevd: uninitialized urandom read (16 bytes read)
    [    2.901998] random: systemd-udevd: uninitialized urandom read (16 bytes read)
    [    3.227067] usb 6-1: new full-speed USB device number 2 using ohci-platform
    [    3.465293] usb 6-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
    [    3.465313] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    3.465325] usb 6-1: Product: FT232R USB UART
    [    3.465337] usb 6-1: Manufacturer: FTDI
    [    3.465347] usb 6-1: SerialNumber: A107NKE7
    [    3.474363] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4
    [    3.476236] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.4
    [    3.744334] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4
    [    3.745890] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
    [    3.979087] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
    [    3.996058] mmc1: new high speed SDIO card at address 0001
    [    4.477932] random: fast init done
    [    4.831608] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
    [    5.455610] systemd[1]: System time before build time, advancing clock.
    [    5.542906] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
    [    5.543885] systemd[1]: Detected architecture arm.
    [    5.570102] systemd[1]: Set hostname to <orangepizero>.
    [    6.317508] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [    6.336878] systemd[1]: Created slice User and Session Slice.
    [    6.351968] systemd[1]: Listening on Journal Audit Socket.
    [    6.363505] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    6.375528] systemd[1]: Listening on Journal Socket (/dev/log).
    [    6.387405] systemd[1]: Listening on udev Kernel Socket.
    [    6.399537] systemd[1]: Listening on Journal Socket.
    [    6.683119] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
    [    6.767298] g_serial gadget: Gadget Serial v2.4
    [    6.767319] g_serial gadget: g_serial ready
    [    7.354518] systemd-journald[215]: Received request to flush runtime journal from PID 1
    [    8.253460] zram: Added device: zram0
    [    8.254754] zram: Added device: zram1
    [    8.257965] zram: Added device: zram2
    [    8.259548] zram: Added device: zram3
    [    8.263279] zram: Added device: zram4
    [    8.265691] zram: Added device: zram5
    [    8.392700] zram1: detected capacity change from 0 to 64663552
    [    8.541115] cpu cpu0: Linked as a consumer to regulator.5
    [    8.541266] cpu cpu0: Dropping the link to regulator.5
    [    8.541672] cpu cpu0: Linked as a consumer to regulator.5
    [    8.543466] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
    [    8.543493] cpu cpu0: _opp_add: OPP not supported by regulators (1056000000)
    [    8.543650] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
    [    8.543664] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
    [    8.543875] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
    [    8.543889] cpu cpu0: _opp_add: OPP not supported by regulators (1152000000)
    [    8.544121] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
    [    8.544139] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
    [    8.544308] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
    [    8.544321] cpu cpu0: _opp_add: OPP not supported by regulators (1224000000)
    [    8.544504] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
    [    8.544519] cpu cpu0: _opp_add: OPP not supported by regulators (1248000000)
    [    8.544715] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
    [    8.544729] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
    [    8.544882] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
    [    8.544896] cpu cpu0: _opp_add: OPP not supported by regulators (1344000000)
    [    8.545088] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
    [    8.545102] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
    [    8.561858] Adding 63144k swap on /dev/zram1.  Priority:5 extents:1 across:63144k SSFS
    [    8.571709] zram2: detected capacity change from 0 to 64663552
    [    8.631755] Adding 63144k swap on /dev/zram2.  Priority:5 extents:1 across:63144k SSFS
    [    8.635976] zram3: detected capacity change from 0 to 64663552
    [    8.697856] Adding 63144k swap on /dev/zram3.  Priority:5 extents:1 across:63144k SSFS
    [    8.702025] zram4: detected capacity change from 0 to 64663552
    [    8.754871] Adding 63144k swap on /dev/zram4.  Priority:5 extents:1 across:63144k SSFS
    [    8.865852] sun8i_ths 1c25000.thermal-sensor: no memory resources defined
    [    8.865891] sun8i_ths: probe of 1c25000.thermal-sensor failed with error -22
    [    8.870890] usbcore: registered new interface driver usbserial_generic
    [    8.871109] usbserial: USB Serial support registered for generic
    [    8.899647] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.901368] usbcore: registered new interface driver ftdi_sio
    [    8.901508] usbserial: USB Serial support registered for FTDI USB Serial Device
    [    8.901989] ftdi_sio 6-1:1.0: FTDI USB Serial Device converter detected
    [    8.902207] usb 6-1: Detected FT232RL
    [    8.909774] usb 6-1: FTDI USB Serial Device converter now attached to ttyUSB0
    [    8.953395] thermal thermal_zone0: failed to read out thermal zone (-110)
    [    8.954578] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.969389] lima 1c40000.gpu: bus rate = 200000000
    [    8.969404] lima 1c40000.gpu: mod rate = 384000000
    [    8.972786] [TTM] Zone  kernel: Available graphics memory: 252578 kiB
    [    8.972798] [TTM] Initializing pool allocator
    [    8.973856] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
    [    8.973916] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
    [    8.973985] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
    [    8.974032] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
    [    8.994112] [drm] Initialized lima 1.0.0 20170325 for 1c40000.gpu on minor 0
    [    9.036663] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    9.036679] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
    [    9.100037] zram0: detected capacity change from 0 to 52428800
    [    9.334423] xradio_wlan mmc1:0001:1:    Input buffers: 30 x 1632 bytes
                      Hardware: 7.9
                      WSM firmware ver: 8, build: 5258, api: 1060, cap: 0x0003
    [    9.334437] xradio_wlan mmc1:0001:1: Firmware Label:XR_C01.08.52.58 Jul 19 2018 18:53:57
    [    9.340290] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
    [    9.489037] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
    [   10.131889] cfg80211: failed to load regulatory.db
    [   10.259942] random: crng init done
    [   10.259958] random: 7 urandom warning(s) missed due to ratelimiting
    [   17.874328] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   17.876396] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
    [   17.878696] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
    [   17.878718] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
    [   17.878728] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
    [   17.879378] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   17.917526] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [   17.918381] ieee80211 phy0: Interface ID:0 of type:2 added
    [   17.918911] ieee80211 phy0: vif 0, configuring tx
    [   17.919895] ieee80211 phy0: vif 0, configuring tx
    [   17.920273] ieee80211 phy0: vif 0, configuring tx
    [   17.920556] ieee80211 phy0: vif 0, configuring tx
    [   17.920916] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (1)IEEE80211_CONF_CHANGE_IDLE (1)
    [   17.921273] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [   18.441233] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [   20.006177] wlan0: authenticate with c8:0e:14:18:d7:84
    [   20.006273] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (0)IEEE80211_CONF_CHANGE_IDLE (1)
    [   20.011842] wlan0: send auth to c8:0e:14:18:d7:84 (try 1/3)
    [   20.114673] xradio_wlan mmc1:0001:1: received frame has no key status
    [   20.116249] xradio_wlan mmc1:0001:1: received frame has no key status
    [   20.121866] wlan0: authenticated
    [   20.127009] wlan0: associate with c8:0e:14:18:d7:84 (try 1/3)
    [   20.133867] wlan0: RX AssocResp from c8:0e:14:18:d7:84 (capab=0x1031 status=0 aid=10)
    [   20.133966] ieee80211 phy0: vif 0, configuring tx
    [   20.134306] ieee80211 phy0: vif 0, configuring tx
    [   20.134592] ieee80211 phy0: vif 0, configuring tx
    [   20.134896] ieee80211 phy0: vif 0, configuring tx
    [   20.137742] wlan0: associated
    [   20.217593] cryptd: max_cpu_qlen set to 1000
    [   20.299255] ieee80211 phy0: CCMP_PAIRWISE keylen=16!
    [   20.299532] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by c8:0e:14:18:d7:84
    [   20.302282] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [  275.696807] systemd[1]: apt-daily-upgrade.timer: Adding 11min 14.362993s random time.
    [  277.244225] systemd[1]: apt-daily-upgrade.timer: Adding 40min 10.947107s random time.
    [  278.170027] systemd[1]: apt-daily-upgrade.timer: Adding 37min 28.839862s random time.
    [  498.332260] xradio_wlan mmc1:0001:1: missed interrupt
    [  518.300641] xradio_wlan mmc1:0001:1: missed interrupt
    [  540.317080] xradio_wlan mmc1:0001:1: missed interrupt
    [  650.399274] xradio_wlan mmc1:0001:1: missed interrupt
    [ 1202.653551] xradio_wlan mmc1:0001:1: missed interrupt
    [ 1246.686418] xradio_wlan mmc1:0001:1: missed interrupt
    [ 1268.702843] xradio_wlan mmc1:0001:1: missed interrupt
    [ 1716.888283] systemd[1]: apt-daily-upgrade.timer: Adding 15min 12.398056s random time.
    [ 1718.436747] systemd[1]: apt-daily-upgrade.timer: Adding 44min 26.648198s random time.
    [ 1719.363112] systemd[1]: apt-daily-upgrade.timer: Adding 9min 19.548196s random time.
    [ 2191.140592] xradio_wlan mmc1:0001:1: missed interrupt
    [ 2235.173476] xradio_wlan mmc1:0001:1: missed interrupt
    [ 2277.158377] xradio_wlan mmc1:0001:1: missed interrupt
    [ 2299.174757] xradio_wlan mmc1:0001:1: missed interrupt
    [ 2321.191152] xradio_wlan mmc1:0001:1: missed interrupt
      Eher
      ne df -h
      Habedere
      @Homoran sagte in ioBroker als Standard User anmelden:
      df -h
      pi@orangepizero:~$ df -h
      Filesystem      Size  Used Avail Use% Mounted on
      udev            180M     0  180M   0% /dev
      tmpfs            50M  3.3M   47M   7% /run
      /dev/mmcblk0p1   29G  2.2G   27G   8% /
      tmpfs           247M     0  247M   0% /dev/shm
      tmpfs           5.0M     0  5.0M   0% /run/lock
      tmpfs           247M     0  247M   0% /sys/fs/cgroup
      tmpfs           247M  4.0K  247M   1% /tmp
      /dev/zram0       49M   29M   16M  65% /var/log
      tmpfs            50M     0   50M   0% /run/user/1001
      • H Habedere
        df -h
        @Habedere Karte hat noch reichlich Platz, wenn die noch beschreibbar ist.
        Das wird uns Thomas gleich sagen
          @Homoran @Habedere
          dmesg schaut eigentlich ganz gesund aus.
          Keine Ahnung was / wo es da klemmt.
            @Homoran @Habedere
            Dann sind wir schon zwei!
            RAM swapped minimal, CPU dümpelt, Karte ist noch reichlich Platz.....
              @Habedere
              iobroker -v
              H 2 Antworten Letzte Antwort
                @Habedere
                iobroker -v
                Habedere
                iobroker -v
                pi@orangepizero:~$ iobroker -v
                3.1.6
                  @Habedere
                  iobroker -v
                  Habedere
                  @Thomas-Braun
                  Keine Idee mehr? 😕
                  Bleibt wohl nur noch neu Aufsetzen 😖
                  • H Habedere
                    @Thomas-Braun
                    Keine Idee mehr? 😕
                    @Habedere
                    Nee, keine Idee mehr.
                    H 1 Antwort Letzte Antwort
                      @Habedere
                      Habedere
                      @Thomas-Braun
                      Nehme ich am besten wieder das ursprüngliche Image, damit das Backup klappt?
                      Wobei ich für den OrangePi Zero im Netzt eh keines mehr finde...
                      Habe das "Armbian_5.69_Orangepizero_Debian_stretch_next_4.19.13"
                      • H Habedere
                        @Thomas-Braun
                        @Habedere Ich würde gar keine Images nehmen. Ich kenne die Situation bei den Orangenhaut-Pi jetzt nicht, das Raspberry OS installiere ich immer 'zu Fuß'.
                        Ich würde dann auch was auf Debian Buster basierendes nehmen, Stretch läuft aus.
                        Ist hier nichts passendes dabei?
                        http://www.orangepi.org/downloadresources/
                          Habedere
                          @Thomas-Braun
                          Ja auf Debian habe ich was gefunden...
                          "OrangePi_zero_debian_stretch_server_linux5.3.5_v1.0.tar"
                          Sorry dass ich wieder mal so blöd Frage, aber sofern ich da ioBroker drauf bekomme, kann ich trotzdem das letzte Backup einspielen?
                          • H Habedere
                            @Thomas-Braun
                            @Habedere sieh mal ob du da was findest:
                            https://www.armbian.com/download/?tx_maker=xunlong
                            Ich kenne deinen OPi nicht - welcher genau das ist
                            • H Habedere
                              @Thomas-Braun
                              @Habedere Das ist doch auch Stretch.
                              Einem sauberen Backup ist es egal auf welchem System es wieder eingespielt wird. Sollte nur möglichst die gleiche nodeJS-Laufzeitumgebung sein. Kann auch auf deiner Kaffeemaschine laufen, solange da auch node drauf läuft.
                              • H Habedere
                                @Thomas-Braun
                                @Habedere sagte in ioBroker als Standard User anmelden:
                                was?????
                                Was ist denn das hier?
                                https://redirect.armbian.com/orangepizero/Buster_current
                                  was?????
                                  @Homoran Das sieht schon besser aus.
                                    Ich weiß aber immer noch nicht welchen OPi er genau hat.
                                    Lt- Armbian gibt es mindestens 5 unterschiedliche Zeros
                                      Habedere
                                      @Homoran
                                      Tja man tut sich wohl schon leichter wenn man weiß wo man suchen muss ;)
                                      Sollte ein Orange Pi Zero H2+ sein bzw. der "normale"
                                      @Thomas-Braun
                                      Hmm du hast recht, aber lt. der HP war von Debian die Rede - steht ja zusätzlich im Dateinamen. Seltsam...
                                      • H Habedere
                                        @Homoran
                                        @Thomas-Braun
                                        @Habedere Stretch und Buster sind die Releasenamen für Debian 9 (Stretch) bzw. Debian 10 (Buster).
                                          Habedere
                                          @Thomas-Braun
                                          Da soll mal einer durch blicken...
                                          Also ich hab mir jetzt das oben verlinkte Image gezogen...
                                          Mittels der Anleitung Armbian Quick Start Guide flashe ich das Image auf die SD-Karte.
                                          Anschließend mache ich Updates und installiere ioBroker mit der Anleitung - KLICK
                                          NPM etc. auf neuesten Stand prüfen...
                                          Dann auf jeden Fall wieder Standard User einrichten.
                                          Backup erstellen
                                          Altes Backup einspielen...
                                          Annähernd richtig?
                                          Ist schon etwas her wie ich den alten aufgesetzt habe. Und selbst da von Anleitung zu Anleitung gehangelt. ioBroker ist von Noobs recht gut zu bedienen - solange es läuft! Wenn nicht gehts schon ans Eingemachte...
