  4. ioBroker als Standard User anmelden
userbenutzer
56 Beiträge 3 Kommentatoren 9.6k Aufrufe 2 Beobachtet
    @Homoran
    top?
    Eher
    ps aux | grep iobroker
    Aber
    dmesg
    ist auch immer gern gesehen, stimmt.
    @Thomas-Braun sagte in ioBroker als Standard User anmelden:
    Eher
    ne df -h
    H 1 Antwort Letzte Antwort
      @Homoran
      top?
      Eher
      Aber
      dmesg
      Habedere
      dmesg
      pi@orangepizero:~$ dmesg
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 4.19.13-sunxi (root@nightly) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5.69 SMP Wed Jan 9 16:26:48 CET 2019
      [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Zero
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] cma: Reserved 128 MiB at 0x57c00000
      [    0.000000] On node 0 totalpages: 131072
      [    0.000000]   Normal zone: 1152 pages used for memmap
      [    0.000000]   Normal zone: 0 pages reserved
      [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
      [    0.000000] psci: probing for conduit method from DT.
      [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
      [    0.000000] random: get_random_bytes called from start_kernel+0x8d/0x3c2 with crng_init=0
      [    0.000000] percpu: Embedded 18 pages/cpu @(ptrval) s41484 r8192 d24052 u73728
      [    0.000000] pcpu-alloc: s41484 r8192 d24052 u73728 alloc=18*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
      [    0.000000] Kernel command line: root=UUID=9cecf84e-027e-40ad-b711-ae5d323d9043 rootwait rootfstype=ext4 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=3b2f264b-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
      [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
      [    0.000000] allocated 524288 bytes of page_ext
      [    0.000000] Memory: 368240K/524288K available (8192K kernel code, 896K rwdata, 2420K rodata, 1024K init, 316K bss, 24976K reserved, 131072K cma-reserved, 0K highmem)
      [    0.000000] Virtual kernel memory layout:
                         vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                         fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                         vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
                         lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
                         pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                         modules : 0xbf800000 - 0xbfe00000   (   6 MB)
                           .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                           .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                           .data : 0x(ptrval) - 0x(ptrval)   ( 897 kB)
                            .bss : 0x(ptrval) - 0x(ptrval)   ( 317 kB)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 36585 entries in 72 pages
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
      [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] GIC: Using split EOI/Deactivate mode
      [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
      [    0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000026] Switching to timer-based delay loop, resolution 41ns
      [    0.000341] Console: colour dummy device 80x30
      [    0.000429] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
      [    0.000449] pid_max: default: 32768 minimum: 301
      [    0.000904] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000921] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.002445] CPU: Testing write buffer coherency: ok
      [    0.003192] CPU0: update cpu_capacity 1024
      [    0.003205] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.004232] Setting up static identity map for 0x40100000 - 0x40100054
      [    0.004511] rcu: Hierarchical SRCU implementation.
      [    0.005902] smp: Bringing up secondary CPUs ...
      [    0.017138] CPU1: update cpu_capacity 1024
      [    0.017150] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.028529] CPU2: update cpu_capacity 1024
      [    0.028540] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.039816] CPU3: update cpu_capacity 1024
      [    0.039827] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.039996] smp: Brought up 1 node, 4 CPUs
      [    0.040009] SMP: Total of 4 processors activated (192.00 BogoMIPS).
      [    0.040016] CPU: All CPU(s) started in HYP mode.
      [    0.040021] CPU: Virtualization extensions available.
      [    0.042020] devtmpfs: initialized
      [    0.054509] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.054892] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.054921] futex hash table entries: 1024 (order: 4, 65536 bytes)
      [    0.064069] xor: measuring software checksum speed
      [    0.103906]    arm4regs  :   598.000 MB/sec
      [    0.144015]    8regs     :   356.000 MB/sec
      [    0.184149]    32regs    :   365.000 MB/sec
      [    0.224269]    neon      :   605.000 MB/sec
      [    0.224277] xor: using function: neon (605.000 MB/sec)
      [    0.224385] pinctrl core: initialized pinctrl subsystem
      [    0.226143] NET: Registered protocol family 16
      [    0.230542] DMA: preallocated 2048 KiB pool for atomic coherent allocations
      [    0.231502] audit: initializing netlink subsys (disabled)
      [    0.231819] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
      [    0.232663] cpuidle: using governor ladder
      [    0.232723] cpuidle: using governor menu
      [    0.233706] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.233716] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.328928] raid6: int32x1  gen()    89 MB/s
      [    0.397143] raid6: int32x1  xor()    76 MB/s
      [    0.465314] raid6: int32x2  gen()   122 MB/s
      [    0.533438] raid6: int32x2  xor()    94 MB/s
      [    0.601603] raid6: int32x4  gen()   123 MB/s
      [    0.670085] raid6: int32x4  xor()    92 MB/s
      [    0.738306] raid6: int32x8  gen()   118 MB/s
      [    0.806356] raid6: int32x8  xor()    82 MB/s
      [    0.874429] raid6: neonx1   gen()   235 MB/s
      [    0.942637] raid6: neonx1   xor()   219 MB/s
      [    1.010974] raid6: neonx2   gen()   316 MB/s
      [    1.079094] raid6: neonx2   xor()   282 MB/s
      [    1.147305] raid6: neonx4   gen()   379 MB/s
      [    1.215560] raid6: neonx4   xor()   318 MB/s
      [    1.283817] raid6: neonx8   gen()   341 MB/s
      [    1.351968] raid6: neonx8   xor()   288 MB/s
      [    1.351975] raid6: using algorithm neonx4 gen() 379 MB/s
      [    1.351981] raid6: .... xor() 318 MB/s, rmw enabled
      [    1.351988] raid6: using neon recovery algorithm
      [    1.354762] SCSI subsystem initialized
      [    1.355156] libata version 3.00 loaded.
      [    1.355513] usbcore: registered new interface driver usbfs
      [    1.355588] usbcore: registered new interface driver hub
      [    1.355725] usbcore: registered new device driver usb
      [    1.356046] media: Linux media interface: v0.10
      [    1.356105] videodev: Linux video capture interface: v2.00
      [    1.356324] pps_core: LinuxPPS API ver. 1 registered
      [    1.356333] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    1.356363] PTP clock support registered
      [    1.358970] clocksource: Switched to clocksource arch_sys_counter
      [    1.530678] VFS: Disk quotas dquot_6.6.0
      [    1.530834] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    1.546089] NET: Registered protocol family 2
      [    1.547496] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
      [    1.547546] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
      [    1.547652] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
      [    1.547774] TCP: Hash tables configured (established 4096 bind 4096)
      [    1.547948] UDP hash table entries: 256 (order: 1, 8192 bytes)
      [    1.548010] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
      [    1.548348] NET: Registered protocol family 1
      [    1.549326] RPC: Registered named UNIX socket transport module.
      [    1.549335] RPC: Registered udp transport module.
      [    1.549341] RPC: Registered tcp transport module.
      [    1.549347] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    1.549766] Trying to unpack rootfs image as initramfs...
      [    2.154854] Freeing initrd memory: 4820K
      [    2.158179] Initialise system trusted keyrings
      [    2.158551] workingset: timestamp_bits=14 max_order=17 bucket_order=3
      [    2.169924] zbud: loaded
      [    2.174057] NFS: Registering the id_resolver key type
      [    2.174097] Key type id_resolver registered
      [    2.174104] Key type id_legacy registered
      [    2.174126] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    2.174135] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
      [    2.176383] JFS: nTxBlock = 3938, nTxLock = 31508
      [    2.197263] Key type asymmetric registered
      [    2.197280] Asymmetric key parser 'x509' registered
      [    2.197397] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
      [    2.197662] io scheduler noop registered
      [    2.197671] io scheduler deadline registered
      [    2.198011] io scheduler cfq registered (default)
      [    2.198020] io scheduler mq-deadline registered
      [    2.198028] io scheduler kyber registered
      [    2.198290] io scheduler bfq registered
      [    2.200531] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
      [    2.208281] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
      [    2.211205] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
      [    2.308627] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
      [    2.312989] console [ttyS0] disabled
      [    2.333244] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A
      [    2.333340] console [ttyS0] enabled
      [    2.343874] brd: module loaded
      [    2.354349] loop: module loaded
      [    2.358571] libphy: Fixed MDIO Bus: probed
      [    2.359647] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
      [    2.359720] dwmac-sun8i 1c30000.ethernet: No regulator found
      [    2.360249] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
      [    2.360286] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
      [    2.360297] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
      [    2.360308] dwmac-sun8i 1c30000.ethernet: COE Type 2
      [    2.360319] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
      [    2.360331] dwmac-sun8i 1c30000.ethernet: Normal descriptors
      [    2.360343] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
      [    2.360575] libphy: stmmac: probed
      [    2.361506] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
      [    2.361685] libphy: mdio_mux: probed
      [    2.361721] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
      [    2.361736] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
      [    2.370124] libphy: mdio_mux: probed
      [    2.371805] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    2.371814] ehci-platform: EHCI generic platform driver
      [    2.372140] ehci-platform 1c1a000.usb: EHCI Host Controller
      [    2.372210] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
      [    2.373540] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000
      [    2.386998] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
      [    2.387509] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      [    2.387525] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.387536] usb usb1: Product: EHCI Host Controller
      [    2.387548] usb usb1: Manufacturer: Linux 4.19.13-sunxi ehci_hcd
      [    2.387559] usb usb1: SerialNumber: 1c1a000.usb
      [    2.388618] hub 1-0:1.0: USB hub found
      [    2.388708] hub 1-0:1.0: 1 port detected
      [    2.390264] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    2.390309] ohci-platform: OHCI generic platform driver
      [    2.390601] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
      [    2.390639] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
      [    2.391056] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400
      [    2.455474] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
      [    2.455489] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.455501] usb usb2: Product: Generic Platform OHCI controller
      [    2.455513] usb usb2: Manufacturer: Linux 4.19.13-sunxi ohci_hcd
      [    2.455524] usb usb2: SerialNumber: 1c1a400.usb
      [    2.456460] hub 2-0:1.0: USB hub found
      [    2.456550] hub 2-0:1.0: 1 port detected
      [    2.458780] usbcore: registered new interface driver usb-storage
      [    2.460179] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
      [    2.460192] sun6i-rtc 1f00000.rtc: RTC enabled
      [    2.460554] i2c /dev entries driver
      [    2.463070] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    2.464504] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
      [    2.465394] ledtrig-cpu: registered to indicate activity on CPUs
      [    2.465498] sunxi-mmc 1c0f000.mmc: Got CD GPIO
      [    2.465530] hidraw: raw HID events driver (C) Jiri Kosina
      [    2.465776] usbcore: registered new interface driver usbhid
      [    2.465782] usbhid: USB HID core driver
      [    2.473488] Initializing XFRM netlink socket
      [    2.474717] NET: Registered protocol family 10
      [    2.491078] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
      [    2.504753] Segment Routing with IPv6
      [    2.504951] NET: Registered protocol family 17
      [    2.504994] NET: Registered protocol family 15
      [    2.505095] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
      [    2.505191] 8021q: 802.1Q VLAN Support v1.8
      [    2.505281] Key type dns_resolver registered
      [    2.506084] Registering SWP/SWPB emulation handler
      [    2.507168] registered taskstats version 1
      [    2.507176] Loading compiled-in X.509 certificates
      [    2.507351] zswap: loaded using pool lzo/zbud
      [    2.510923] Btrfs loaded, crc32c=crc32c-generic
      [    2.524087] Key type encrypted registered
      [    2.527236] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.530417] mmc0: new high speed SDHC card at address aaaa
      [    2.532781] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
      [    2.543617] ehci-platform 1c1b000.usb: EHCI Host Controller
      [    2.543673] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
      [    2.544057]  mmcblk0: p1
      [    2.545665] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000
      [    2.562983] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
      [    2.563393] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      [    2.563409] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.563421] usb usb3: Product: EHCI Host Controller
      [    2.563433] usb usb3: Manufacturer: Linux 4.19.13-sunxi ehci_hcd
      [    2.563443] usb usb3: SerialNumber: 1c1b000.usb
      [    2.564359] hub 3-0:1.0: USB hub found
      [    2.564433] hub 3-0:1.0: 1 port detected
      [    2.565914] ehci-platform 1c1c000.usb: EHCI Host Controller
      [    2.565973] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
      [    2.566460] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000
      [    2.578985] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
      [    2.579358] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      [    2.579372] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.579383] usb usb4: Product: EHCI Host Controller
      [    2.579395] usb usb4: Manufacturer: Linux 4.19.13-sunxi ehci_hcd
      [    2.579406] usb usb4: SerialNumber: 1c1c000.usb
      [    2.580255] hub 4-0:1.0: USB hub found
      [    2.580326] hub 4-0:1.0: 1 port detected
      [    2.581670] ehci-platform 1c1d000.usb: EHCI Host Controller
      [    2.581710] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
      [    2.582130] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000
      [    2.594995] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
      [    2.595406] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      [    2.595421] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.595432] usb usb5: Product: EHCI Host Controller
      [    2.595444] usb usb5: Manufacturer: Linux 4.19.13-sunxi ehci_hcd
      [    2.595454] usb usb5: SerialNumber: 1c1d000.usb
      [    2.596319] hub 5-0:1.0: USB hub found
      [    2.596389] hub 5-0:1.0: 1 port detected
      [    2.597724] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
      [    2.597777] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
      [    2.598163] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400
      [    2.659336] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
      [    2.659351] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.659363] usb usb6: Product: Generic Platform OHCI controller
      [    2.659374] usb usb6: Manufacturer: Linux 4.19.13-sunxi ohci_hcd
      [    2.659385] usb usb6: SerialNumber: 1c1b400.usb
      [    2.660269] hub 6-0:1.0: USB hub found
      [    2.660341] hub 6-0:1.0: 1 port detected
      [    2.661672] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
      [    2.661715] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
      [    2.662063] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400
      [    2.723307] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
      [    2.723323] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.723335] usb usb7: Product: Generic Platform OHCI controller
      [    2.723346] usb usb7: Manufacturer: Linux 4.19.13-sunxi ohci_hcd
      [    2.723357] usb usb7: SerialNumber: 1c1c400.usb
      [    2.724215] hub 7-0:1.0: USB hub found
      [    2.724286] hub 7-0:1.0: 1 port detected
      [    2.725573] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
      [    2.725613] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
      [    2.726003] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400
      [    2.787324] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
      [    2.787341] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.787352] usb usb8: Product: Generic Platform OHCI controller
      [    2.787364] usb usb8: Manufacturer: Linux 4.19.13-sunxi ohci_hcd
      [    2.787374] usb usb8: SerialNumber: 1c1d400.usb
      [    2.788210] hub 8-0:1.0: USB hub found
      [    2.788291] hub 8-0:1.0: 1 port detected
      [    2.789673] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
      [    2.789781] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
      [    2.792217] of_cfs_init
      [    2.792376] of_cfs_init: OK
      [    2.792488] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4
      [    2.792645] vcc3v0: disabling
      [    2.792656] vcc5v0: disabling
      [    2.792663] vcc-wifi: disabling
      [    2.794100] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.4
      [    2.802999] Freeing unused kernel memory: 1024K
      [    2.815358] Run /init as init process
      [    2.900772] random: systemd-udevd: uninitialized urandom read (16 bytes read)
      [    2.901765] random: systemd-udevd: uninitialized urandom read (16 bytes read)
      [    2.901998] random: systemd-udevd: uninitialized urandom read (16 bytes read)
      [    3.227067] usb 6-1: new full-speed USB device number 2 using ohci-platform
      [    3.465293] usb 6-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
      [    3.465313] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    3.465325] usb 6-1: Product: FT232R USB UART
      [    3.465337] usb 6-1: Manufacturer: FTDI
      [    3.465347] usb 6-1: SerialNumber: A107NKE7
      [    3.474363] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4
      [    3.476236] sunxi-mmc 1c10000.mmc: Dropping the link to regulator.4
      [    3.744334] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4
      [    3.745890] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
      [    3.979087] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
      [    3.996058] mmc1: new high speed SDIO card at address 0001
      [    4.477932] random: fast init done
      [    4.831608] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
      [    5.455610] systemd[1]: System time before build time, advancing clock.
      [    5.542906] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
      [    5.543885] systemd[1]: Detected architecture arm.
      [    5.570102] systemd[1]: Set hostname to <orangepizero>.
      [    6.317508] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    6.336878] systemd[1]: Created slice User and Session Slice.
      [    6.351968] systemd[1]: Listening on Journal Audit Socket.
      [    6.363505] systemd[1]: Listening on RPCbind Server Activation Socket.
      [    6.375528] systemd[1]: Listening on Journal Socket (/dev/log).
      [    6.387405] systemd[1]: Listening on udev Kernel Socket.
      [    6.399537] systemd[1]: Listening on Journal Socket.
      [    6.683119] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
      [    6.767298] g_serial gadget: Gadget Serial v2.4
      [    6.767319] g_serial gadget: g_serial ready
      [    7.354518] systemd-journald[215]: Received request to flush runtime journal from PID 1
      [    8.253460] zram: Added device: zram0
      [    8.254754] zram: Added device: zram1
      [    8.257965] zram: Added device: zram2
      [    8.259548] zram: Added device: zram3
      [    8.263279] zram: Added device: zram4
      [    8.265691] zram: Added device: zram5
      [    8.392700] zram1: detected capacity change from 0 to 64663552
      [    8.541115] cpu cpu0: Linked as a consumer to regulator.5
      [    8.541266] cpu cpu0: Dropping the link to regulator.5
      [    8.541672] cpu cpu0: Linked as a consumer to regulator.5
      [    8.543466] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
      [    8.543493] cpu cpu0: _opp_add: OPP not supported by regulators (1056000000)
      [    8.543650] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
      [    8.543664] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
      [    8.543875] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
      [    8.543889] cpu cpu0: _opp_add: OPP not supported by regulators (1152000000)
      [    8.544121] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
      [    8.544139] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
      [    8.544308] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
      [    8.544321] cpu cpu0: _opp_add: OPP not supported by regulators (1224000000)
      [    8.544504] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
      [    8.544519] cpu cpu0: _opp_add: OPP not supported by regulators (1248000000)
      [    8.544715] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
      [    8.544729] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
      [    8.544882] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
      [    8.544896] cpu cpu0: _opp_add: OPP not supported by regulators (1344000000)
      [    8.545088] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
      [    8.545102] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
      [    8.561858] Adding 63144k swap on /dev/zram1.  Priority:5 extents:1 across:63144k SSFS
      [    8.571709] zram2: detected capacity change from 0 to 64663552
      [    8.631755] Adding 63144k swap on /dev/zram2.  Priority:5 extents:1 across:63144k SSFS
      [    8.635976] zram3: detected capacity change from 0 to 64663552
      [    8.697856] Adding 63144k swap on /dev/zram3.  Priority:5 extents:1 across:63144k SSFS
      [    8.702025] zram4: detected capacity change from 0 to 64663552
      [    8.754871] Adding 63144k swap on /dev/zram4.  Priority:5 extents:1 across:63144k SSFS
      [    8.865852] sun8i_ths 1c25000.thermal-sensor: no memory resources defined
      [    8.865891] sun8i_ths: probe of 1c25000.thermal-sensor failed with error -22
      [    8.870890] usbcore: registered new interface driver usbserial_generic
      [    8.871109] usbserial: USB Serial support registered for generic
      [    8.899647] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    8.901368] usbcore: registered new interface driver ftdi_sio
      [    8.901508] usbserial: USB Serial support registered for FTDI USB Serial Device
      [    8.901989] ftdi_sio 6-1:1.0: FTDI USB Serial Device converter detected
      [    8.902207] usb 6-1: Detected FT232RL
      [    8.909774] usb 6-1: FTDI USB Serial Device converter now attached to ttyUSB0
      [    8.953395] thermal thermal_zone0: failed to read out thermal zone (-110)
      [    8.954578] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    8.969389] lima 1c40000.gpu: bus rate = 200000000
      [    8.969404] lima 1c40000.gpu: mod rate = 384000000
      [    8.972786] [TTM] Zone  kernel: Available graphics memory: 252578 kiB
      [    8.972798] [TTM] Initializing pool allocator
      [    8.973856] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
      [    8.973916] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
      [    8.973985] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
      [    8.974032] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
      [    8.994112] [drm] Initialized lima 1.0.0 20170325 for 1c40000.gpu on minor 0
      [    9.036663] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    9.036679] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
      [    9.100037] zram0: detected capacity change from 0 to 52428800
      [    9.334423] xradio_wlan mmc1:0001:1:    Input buffers: 30 x 1632 bytes
                        Hardware: 7.9
                        WSM firmware ver: 8, build: 5258, api: 1060, cap: 0x0003
      [    9.334437] xradio_wlan mmc1:0001:1: Firmware Label:XR_C01.08.52.58 Jul 19 2018 18:53:57
      [    9.340290] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
      [    9.489037] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
      [   10.131889] cfg80211: failed to load regulatory.db
      [   10.259942] random: crng init done
      [   10.259958] random: 7 urandom warning(s) missed due to ratelimiting
      [   17.874328] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
      [   17.876396] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
      [   17.878696] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
      [   17.878718] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
      [   17.878728] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
      [   17.879378] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
      [   17.917526] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
      [   17.918381] ieee80211 phy0: Interface ID:0 of type:2 added
      [   17.918911] ieee80211 phy0: vif 0, configuring tx
      [   17.919895] ieee80211 phy0: vif 0, configuring tx
      [   17.920273] ieee80211 phy0: vif 0, configuring tx
      [   17.920556] ieee80211 phy0: vif 0, configuring tx
      [   17.920916] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (1)IEEE80211_CONF_CHANGE_IDLE (1)
      [   17.921273] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
      [   18.441233] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
      [   20.006177] wlan0: authenticate with c8:0e:14:18:d7:84
      [   20.006273] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (0)IEEE80211_CONF_CHANGE_IDLE (1)
      [   20.011842] wlan0: send auth to c8:0e:14:18:d7:84 (try 1/3)
      [   20.114673] xradio_wlan mmc1:0001:1: received frame has no key status
      [   20.116249] xradio_wlan mmc1:0001:1: received frame has no key status
      [   20.121866] wlan0: authenticated
      [   20.127009] wlan0: associate with c8:0e:14:18:d7:84 (try 1/3)
      [   20.133867] wlan0: RX AssocResp from c8:0e:14:18:d7:84 (capab=0x1031 status=0 aid=10)
      [   20.133966] ieee80211 phy0: vif 0, configuring tx
      [   20.134306] ieee80211 phy0: vif 0, configuring tx
      [   20.134592] ieee80211 phy0: vif 0, configuring tx
      [   20.134896] ieee80211 phy0: vif 0, configuring tx
      [   20.137742] wlan0: associated
      [   20.217593] cryptd: max_cpu_qlen set to 1000
      [   20.299255] ieee80211 phy0: CCMP_PAIRWISE keylen=16!
      [   20.299532] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by c8:0e:14:18:d7:84
      [   20.302282] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      [  275.696807] systemd[1]: apt-daily-upgrade.timer: Adding 11min 14.362993s random time.
      [  277.244225] systemd[1]: apt-daily-upgrade.timer: Adding 40min 10.947107s random time.
      [  278.170027] systemd[1]: apt-daily-upgrade.timer: Adding 37min 28.839862s random time.
      [  498.332260] xradio_wlan mmc1:0001:1: missed interrupt
      [  518.300641] xradio_wlan mmc1:0001:1: missed interrupt
      [  540.317080] xradio_wlan mmc1:0001:1: missed interrupt
      [  650.399274] xradio_wlan mmc1:0001:1: missed interrupt
      [ 1202.653551] xradio_wlan mmc1:0001:1: missed interrupt
      [ 1246.686418] xradio_wlan mmc1:0001:1: missed interrupt
      [ 1268.702843] xradio_wlan mmc1:0001:1: missed interrupt
      [ 1716.888283] systemd[1]: apt-daily-upgrade.timer: Adding 15min 12.398056s random time.
      [ 1718.436747] systemd[1]: apt-daily-upgrade.timer: Adding 44min 26.648198s random time.
      [ 1719.363112] systemd[1]: apt-daily-upgrade.timer: Adding 9min 19.548196s random time.
      [ 2191.140592] xradio_wlan mmc1:0001:1: missed interrupt
      [ 2235.173476] xradio_wlan mmc1:0001:1: missed interrupt
      [ 2277.158377] xradio_wlan mmc1:0001:1: missed interrupt
      [ 2299.174757] xradio_wlan mmc1:0001:1: missed interrupt
      [ 2321.191152] xradio_wlan mmc1:0001:1: missed interrupt
        Eher
        ne df -h
        Habedere
        @Homoran sagte in ioBroker als Standard User anmelden:
        df -h
        pi@orangepizero:~$ df -h
        Filesystem      Size  Used Avail Use% Mounted on
        udev            180M     0  180M   0% /dev
        tmpfs            50M  3.3M   47M   7% /run
        /dev/mmcblk0p1   29G  2.2G   27G   8% /
        tmpfs           247M     0  247M   0% /dev/shm
        tmpfs           5.0M     0  5.0M   0% /run/lock
        tmpfs           247M     0  247M   0% /sys/fs/cgroup
        tmpfs           247M  4.0K  247M   1% /tmp
        /dev/zram0       49M   29M   16M  65% /var/log
        tmpfs            50M     0   50M   0% /run/user/1001
        • H Habedere
          df -h
          @Habedere Karte hat noch reichlich Platz, wenn die noch beschreibbar ist.
          Das wird uns Thomas gleich sagen
            @Homoran @Habedere
            dmesg schaut eigentlich ganz gesund aus.
            Keine Ahnung was / wo es da klemmt.
              @Homoran @Habedere
              Dann sind wir schon zwei!
              RAM swapped minimal, CPU dümpelt, Karte ist noch reichlich Platz.....
                @Habedere
                iobroker -v
                H 2 Antworten Letzte Antwort
                  @Habedere
                  iobroker -v
                  Habedere
                  iobroker -v
                  pi@orangepizero:~$ iobroker -v
                  3.1.6
                    @Habedere
                    iobroker -v
                    Habedere
                    @Thomas-Braun
                    Keine Idee mehr? 😕
                    Bleibt wohl nur noch neu Aufsetzen 😖
                    • H Habedere
                      @Thomas-Braun
                      Keine Idee mehr? 😕
                      @Habedere
                      Nee, keine Idee mehr.
                        @Habedere
                        Habedere
                        @Thomas-Braun
                        Nehme ich am besten wieder das ursprüngliche Image, damit das Backup klappt?
                        Wobei ich für den OrangePi Zero im Netzt eh keines mehr finde...
                        Habe das "Armbian_5.69_Orangepizero_Debian_stretch_next_4.19.13"
                        • H Habedere
                          @Thomas-Braun
                          @Habedere Ich würde gar keine Images nehmen. Ich kenne die Situation bei den Orangenhaut-Pi jetzt nicht, das Raspberry OS installiere ich immer 'zu Fuß'.
                          Ich würde dann auch was auf Debian Buster basierendes nehmen, Stretch läuft aus.
                          Ist hier nichts passendes dabei?
                          http://www.orangepi.org/downloadresources/
                            Habedere
                            @Thomas-Braun
                            Ja auf Debian habe ich was gefunden...
                            "OrangePi_zero_debian_stretch_server_linux5.3.5_v1.0.tar"
                            Sorry dass ich wieder mal so blöd Frage, aber sofern ich da ioBroker drauf bekomme, kann ich trotzdem das letzte Backup einspielen?
                            • H Habedere
                              @Thomas-Braun
                              @Habedere sieh mal ob du da was findest:
                              https://www.armbian.com/download/?tx_maker=xunlong
                              Ich kenne deinen OPi nicht - welcher genau das ist
                              • H Habedere
                                @Thomas-Braun
                                @Habedere Das ist doch auch Stretch.
                                Einem sauberen Backup ist es egal auf welchem System es wieder eingespielt wird. Sollte nur möglichst die gleiche nodeJS-Laufzeitumgebung sein. Kann auch auf deiner Kaffeemaschine laufen, solange da auch node drauf läuft.
                                • H Habedere
                                  @Thomas-Braun
                                  @Habedere sagte in ioBroker als Standard User anmelden:
                                  was?????
                                  Was ist denn das hier?
                                  https://redirect.armbian.com/orangepizero/Buster_current
                                    was?????
                                    @Homoran Das sieht schon besser aus.
                                      Ich weiß aber immer noch nicht welchen OPi er genau hat.
                                      Lt- Armbian gibt es mindestens 5 unterschiedliche Zeros
                                        Habedere
                                        @Homoran
                                        Tja man tut sich wohl schon leichter wenn man weiß wo man suchen muss ;)
                                        Sollte ein Orange Pi Zero H2+ sein bzw. der "normale"
                                        @Thomas-Braun
                                        Hmm du hast recht, aber lt. der HP war von Debian die Rede - steht ja zusätzlich im Dateinamen. Seltsam...
                                        • H Habedere
                                          @Homoran
                                          @Thomas-Braun
                                          @Habedere Stretch und Buster sind die Releasenamen für Debian 9 (Stretch) bzw. Debian 10 (Buster).
