  4. [ Geklärt ] Problem bei Influx Installation
    6.4k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
    @Altersrentner probier mal bei Host, anstatt "localhost" die Ip deines Rechners bei den Settings einzutragen.
    Edit:
    was gibt folgendes aus?
    systemctl status influxdb
    Altersrentner
    @crunchip
    Brachte keine Änderung
    influxdb.0	2020-12-20 11:36:27.294	error	(14640) Error: connect ECONNREFUSED 192.168.178.41:8086
    influxdb.0	2020-12-20 11:36:27.290	info	(14640) Connecting http://192.168.178.41:8086 ...
    fhem.0	2020-12-20 11:36:25.223	info	(835) Update channel: WattUsageAnDummy | fhem.0.WattUsageAnDummy - native
    fhem.0	2020-12-20 11:36:25.218	info	(835) check channel fhem.0.WattUsageAnDummy | name: WattUsa
      Edit:
      Altersrentner
      @crunchip
      pi@raspberrypi:~ $ sudo systemctl status influxdb
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabl
         Active: failed (Result: exit-code) since Sun 2020-12-20 11:12:30 CET; 27min ago
           Docs: https://docs.influxdata.com/influxdb/
        Process: 12273 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLU
       Main PID: 12273 (code=exited, status=1/FAILURE)
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms exp
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, resta
      Dec 20 11:12:30 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distribute
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Start request repeated too q
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-cod
      Dec 20 11:12:30 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, di
      lines 1-13/13 (END)...skipping...
      lines 1-13/13 (END)
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
        Process: 12273 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, s
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restar
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
      Dec 20 11:12:30 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
      Dec 20 11:12:30 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series
      lines 1-13/13 (END)
        Process: 12273 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
      Dec 20 11:12:30 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
      Dec 20 11:12:30 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
      Dec 20 11:12:30 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
      lines 1-13/13 (END)
      lines 1-13/13 (END)
      crunchipC Thomas BraunT 2 Antworten Letzte Antwort
      • A Altersrentner
        @crunchip
        lines 1-13/13 (END)
        lines 1-13/13 (END)
        lines 1-13/13 (END)
        lines 1-13/13 (END)
        crunchipC Abwesend
        crunchipC Abwesend
        @Altersrentner ok, also da kann auch keine Verbindung zustande kommen, da dein Influx gar nicht läuft.
        wie oder nach welcher Anleitung hast du denn installiert?
        • A Altersrentner
          @crunchip
          lines 1-13/13 (END)
          lines 1-13/13 (END)
          lines 1-13/13 (END)
          lines 1-13/13 (END)
          @Altersrentner
          Ganz doofe Frage:
          apt policy influxdb
            Altersrentner
            @crunchip
            wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
            source /etc/os-release
            echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
            sudo apt-get update
            sudo apt-get install influxdb
            sudo service influxdb start
            sudo influx
            Jetzt sollte es eigentlich laufen
              @Altersrentner
              Ganz doofe Frage:
              apt policy influxdb
              Altersrentner
              @Thomas-Braun said in Problem bei Influx Installation:
              pi@raspberrypi:~ $ sudo service influxdb start
              pi@raspberrypi:~ $ sudo influx
              Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
              Please check your connection settings and ensure 'influxd' is running.
              pi@raspberrypi:~ $ sudo apt policy influxdb
              influxdb:
                Installed: 1.8.3-1
                Candidate: 1.8.3-1
                Version table:
               *** 1.8.3-1 500
                      500 https://repos.influxdata.com/debian buster/stable armhf Packages
                   1.6.4-1 500
              pi@raspberrypi:~ $
              • crunchipC Abwesend
                crunchipC Abwesend
                ok, hast zwar noch die "alte" Version aber sollte passen.
                ist dein Port vllt belegt?
                netstat -tulpen
                  netstat -tulpen
                  Altersrentner
                  @crunchip said in Problem bei Influx Installation:
                  netstat -tulpen
                  Leider das selbe Ergebnis😧
                  pi@raspberrypi:~ $ sudo netstat -tulpen
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17609      637/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17608      637/iobroker.js-con
                  tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       20269      1195/io.hm-rpc.2
                  tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       20769      1156/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15904      644/sshd
                  tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       285748     16680/sshd: pi@pts/
                  tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       20759      1175/io.hm-rpc.1
                  tcp6       0      0 :::61991                :::*                    LISTEN      1001       19711      903/io.harmony.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17670      662/io.admin.0
                  tcp6       0      0 :::8083                 :::*                    LISTEN      1001       17292      1127/io.web.0
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16792      731/io.socketio.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          15906      644/sshd
                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       20792      1237/io.terminal.0
                  tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       285747     16680/sshd: pi@pts/
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14271      402/avahi-daemon: r
                  udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       19712      903/io.harmony.0
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17212      1093/io.shelly.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15151      636/dhcpcd
                  udp        0      0 0.0.0.0:43619           0.0.0.0:*                           108        14273      402/avahi-daemon: r
                  udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       18957      869/io.mihome.0
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18929      858/io.mihome-vacuu
                  udp6       0      0 :::5353                 :::*                                108        14272      402/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          18566      636/dhcpcd
                  udp6       0      0 :::51291                :::*                                108        14274      402/avahi-daemon: r
                  pi@raspberrypi:~ $
                  • A Altersrentner
                    netstat -tulpen
                    pi@raspberrypi:~ $
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @Altersrentner
                    Standardmäßig verwendet InfluxDB die folgenden Netzwerkports:
                    Der TCP-Port 8086 ist für die Client-Server-Kommunikation über die InfluxDB-API verfügbar.
                    Der TCP-Port 8088 steht dem RPC-Dienst zur Verfügung, um Sicherungs- und Wiederherstellungsvorgänge durchzuführen.
                    bei dir ist, siehe Zeile 16 dein iobroker terminal auf port 8088, bin mir da nicht sicher ob das Probleme bereitet
                    @Altersrentner änder mal deinen terminal port in iobroker und probier es dann nochmal den Service enable, start....
                    siehe auch hier
                    https://forum.iobroker.net/post/378412
                      @Altersrentner
                      siehe auch hier
                      Altersrentner
                      schrieb am zuletzt editiert von Altersrentner
                      @crunchip
                      ich verzweifle bald
                      Zustand wie gehabt
                      Habe jetzt mal
                      influxd eingegeben
                      pi@raspberrypi:~ $ sudo influxd
                       8888888           .d888 888                   8888888b.  888888b.
                         888            d88P"  888                   888  "Y88b 888  "88b
                         888            888    888                   888    888 888  .88P
                         888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
                         888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
                         888   888  888 888    888 888  888   X88K   888    888 888    888
                         888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
                       8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
                      2020-12-20T13:31:40.279443Z     info    InfluxDB starting       {"log_id": "0RC5QVTG000", "version": "1.8.3", "branch": "1.8", "commit": "563e6                            c3d1a7a2790763c6289501095dbec19244e"}
                      2020-12-20T13:31:40.280532Z     info    Go runtime      {"log_id": "0RC5QVTG000", "version": "go1.13.8", "maxprocs": 4}
                      2020-12-20T13:31:41.290904Z     info    Using data dir  {"log_id": "0RC5QVTG000", "service": "store", "path": "/var/lib/influxdb/data"}
                      2020-12-20T13:31:41.293624Z     info    Compaction settings     {"log_id": "0RC5QVTG000", "service": "store", "max_concurrent_compactions": 2,                             "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
                      2020-12-20T13:31:41.296007Z     info    Open store (start)      {"log_id": "0RC5QVTG000", "service": "store", "trace_id": "0RC5QZRl000", "op_na                            me": "tsdb_open", "op_event": "start"}
                      2020-12-20T13:31:41.298469Z     info    Open store (end)        {"log_id": "0RC5QVTG000", "service": "store", "trace_id": "0RC5QZRl000", "op_na                            me": "tsdb_open", "op_event": "end", "op_elapsed": "2.477ms"}
                      2020-12-20T13:31:41.300868Z     info    Opened service  {"log_id": "0RC5QVTG000", "service": "subscriber"}
                      2020-12-20T13:31:41.310202Z     info    Starting monitor service        {"log_id": "0RC5QVTG000", "service": "monitor"}
                      2020-12-20T13:31:41.312167Z     info    Registered diagnostics client   {"log_id": "0RC5QVTG000", "service": "monitor", "name": "build"}
                      2020-12-20T13:31:41.312781Z     info    Registered diagnostics client   {"log_id": "0RC5QVTG000", "service": "monitor", "name": "runtime"}
                      2020-12-20T13:31:41.313403Z     info    Registered diagnostics client   {"log_id": "0RC5QVTG000", "service": "monitor", "name": "network"}
                      2020-12-20T13:31:41.313732Z     info    Registered diagnostics client   {"log_id": "0RC5QVTG000", "service": "monitor", "name": "system"}
                      2020-12-20T13:31:41.314463Z     info    Starting precreation service    {"log_id": "0RC5QVTG000", "service": "shard-precreation", "check_interv                            al": "10m", "advance_period": "30m"}
                      2020-12-20T13:31:41.315897Z     info    Starting snapshot service       {"log_id": "0RC5QVTG000", "service": "snapshot"}
                      2020-12-20T13:31:41.316280Z     info    Storing statistics      {"log_id": "0RC5QVTG000", "service": "monitor", "db_instance": "_internal", "db                            _rp": "monitor", "interval": "10s"}
                      2020-12-20T13:31:41.317118Z     info    Starting continuous query service       {"log_id": "0RC5QVTG000", "service": "continuous_querier"}
                      2020-12-20T13:31:41.319668Z     info    Starting HTTP service   {"log_id": "0RC5QVTG000", "service": "httpd", "authentication": false}
                      2020-12-20T13:31:41.321326Z     info    opened HTTP access log  {"log_id": "0RC5QVTG000", "service": "httpd", "path": "stderr"}
                      2020-12-20T13:31:41.322670Z     info    Listening on HTTP       {"log_id": "0RC5QVTG000", "service": "httpd", "addr": "[::]:8086", "https": fal                            se}
                      2020-12-20T13:31:41.326261Z     info    Starting retention policy enforcement service   {"log_id": "0RC5QVTG000", "service": "retention", "chec                            k_interval": "30m"}
                      2020-12-20T13:31:41.327863Z     info    Sending usage statistics to usage.influxdata.com        {"log_id": "0RC5QVTG000"}
                      2020-12-20T13:31:41.331840Z     info    Listening for signals   {"log_id": "0RC5QVTG000"}
                      2020-12-20T13:31:44.084613Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "SHOW DATABASES"}
                      [httpd] 192.168.178.41 - admin [20/Dec/2020:14:31:44 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=admin HTTP                            /1.1" 200 84 "-" "-" b3681eb6-42c7-11eb-8001-dca6321bbd83 9249
                      2020-12-20T13:31:54.107193Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "SHOW DATABASES"}
                      [httpd] 192.168.178.41 - admin [20/Dec/2020:14:31:54 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=admin HTTP                            /1.1" 200 84 "-" "-" b9620632-42c7-11eb-8002-dca6321bbd83 1031
                      2020-12-20T13:32:04.115541Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "SHOW DATABASES"}
                      [httpd] 192.168.178.41 - admin [20/Dec/2020:14:32:04 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=admin HTTP                            /1.1" 200 109 "-" "-" bf592910-42c7-11eb-8003-dca6321bbd83 2055833
                      2020-12-20T13:32:06.177505Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "CREATE DATABASE iobroker"}
                      [httpd] 192.168.178.41 - admin [20/Dec/2020:14:32:06 +0100] "POST /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=create+database+%22iobroke                            r%22&u=admin HTTP/1.1" 200 33 "-" "-" c093ce61-42c7-11eb-8004-dca6321bbd83 468972
                      2020-12-20T13:32:06.651822Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "CREATE RETENTION POLICY global                             ON iobroker DURATION 365d REPLICATION 1 DEFAULT"}
                      [httpd] 192.168.178.41 - admin [20/Dec/2020:14:32:06 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=CREATE+RETENTION+POLICY+%22                            global%22+ON+iobroker+DURATION+31536000s+REPLICATION+1+DEFAULT&u=admin HTTP/1.1" 200 232 "-" "-" c0dc2b88-42c7-11eb-8005-dca6321bbd83 2247119
                      2020-12-20T13:32:08.905601Z     info    Executing query {"log_id": "0RC5QVTG000", "service": "query", "query": "SHOW DATABASES"}
                      [httpd] 192.168.178.41 - admin [20/Dec/2020:14:32:08 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=admin HTTP                            /1.1" 200 122 "-" "-" c234151c-42c7-11eb-8006-dca6321bbd83 2841
                      Kannst Du hier etwas lokalisierne?
                      • A Altersrentner
                        @crunchip
                        ich verzweifle bald
                        Zustand wie gehabt
                        Habe jetzt mal
                        influxd eingegeben
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @Altersrentner es läuft immer noch auf port 8088, gegebenenfalls system neustarten.
                        danach nochmal prüfen, wenn dieser port dann auf 8090 läuft
                        nochmal
                        sudo systemctl daemon-reload
                        sudo systemctl enable influxdb
                        sudo systemctl start influxdb
                        anschliessend prüfen, ob influx läuft mit
                        @Altersrentner sagte in Problem bei Influx Installation:
                        dein influx läuft noch nicht
                          nochmal
                          Altersrentner
                          @crunchip
                          jetzt wird influx nicht mehr gefunden
                          pi@raspberrypi:~ $ sudo iobroker stop
                          pi@raspberrypi:~ $ sudo iobroker restart
                          pi@raspberrypi:~ $ sudo systemctl daemon-reload
                          pi@raspberrypi:~ $ sudo systemctl enable influxdb
                          pi@raspberrypi:~ $ sudo systemctl start influxdb
                          Unit influx.service could not be found.
                          pi@raspberrypi:~ $
                          • A Altersrentner
                            @crunchip
                            pi@raspberrypi:~ $
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @Altersrentner mein Fehler
                              Altersrentner
                              @crunchip
                                 Active: failed (Result: exit-code) since Sun 2020-12-20 14:47:04 CET; 12min ago
                                Process: 22523 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
                               Main PID: 22523 (code=exited, status=1/FAILURE)
                              Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                              Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                              Dec 20 14:47:04 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                              Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                              Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                              Dec 20 14:47:04 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                              pi@raspberrypi:~ $
                              konnte nicht gestartet werden
                              • A Altersrentner
                                @crunchip
                                pi@raspberrypi:~ $
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @Altersrentner weil ich gerade systemd.... lese
                                geb mal folgendes ein
                                sudo systemctl unmask influxdb.service
                                und prüfe danach ob der service läuft
                                  Altersrentner
                                  @crunchip
                                  pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
                                  2020-12-20T14:15:35.152027Z     info    InfluxDB starting       {"log_id": "0RC7wJwl000", "version": "1.8.3", "branch": "1.8", "commit": "563e6c3d1a7a2790763c6289501095dbec19244e"}
                                  2020-12-20T14:15:35.152128Z     info    Go runtime      {"log_id": "0RC7wJwl000", "version": "go1.13.8", "maxprocs": 4}
                                  2020-12-20T14:15:35.253479Z     info    Using data dir  {"log_id": "0RC7wJwl000", "service": "store", "path": "/var/lib/influxdb/data"}
                                  2020-12-20T14:15:35.253597Z     info    Compaction settings     {"log_id": "0RC7wJwl000", "service": "store", "max_concurrent_compactions": 2, "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
                                  2020-12-20T14:15:35.253674Z     info    Open store (start)      {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "start"}
                                  2020-12-20T14:15:35.257327Z     info    Reading file    {"log_id": "0RC7wJwl000", "engine": "tsm1", "service": "cacheloader", "path": "/var/lib/influxdb/wal/_internal/monitor/1/_00001.wal", "size": 132881}
                                  2020-12-20T14:15:37.573216Z     info    Opened shard    {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "index_version": "inmem", "path": "/var/lib/influxdb/data/_internal/monitor/1", "duration": "2317.079ms"}
                                  2020-12-20T14:15:37.573402Z     info    Open store (end)        {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "end", "op_elapsed": "2319.731ms"}
                                  2020-12-20T14:15:37.573525Z     info    Opened service  {"log_id": "0RC7wJwl000", "service": "subscriber"}
                                  2020-12-20T14:15:37.573570Z     info    Starting monitor service        {"log_id": "0RC7wJwl000", "service": "monitor"}
                                  2020-12-20T14:15:37.573611Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "build"}
                                  2020-12-20T14:15:37.573649Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "runtime"}
                                  2020-12-20T14:15:37.573688Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "network"}
                                  2020-12-20T14:15:37.573737Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "system"}
                                  2020-12-20T14:15:37.573810Z     info    Starting precreation service    {"log_id": "0RC7wJwl000", "service": "shard-precreation", "check_interval": "10m", "advance_period": "30m"}
                                  2020-12-20T14:15:37.573888Z     info    Starting snapshot service       {"log_id": "0RC7wJwl000", "service": "snapshot"}
                                  2020-12-20T14:15:37.573929Z     info    Starting continuous query service       {"log_id": "0RC7wJwl000", "service": "continuous_querier"}
                                  2020-12-20T14:15:37.573983Z     info    Starting HTTP service   {"log_id": "0RC7wJwl000", "service": "httpd", "authentication": false}
                                  2020-12-20T14:15:37.574022Z     info    opened HTTP access log  {"log_id": "0RC7wJwl000", "service": "httpd", "path": "stderr"}
                                  2020-12-20T14:15:37.574321Z     info    Storing statistics      {"log_id": "0RC7wJwl000", "service": "monitor", "db_instance": "_internal", "db_rp": "monitor", "interval": "10s"}
                                  2020-12-20T14:15:37.574445Z     info    Listening on HTTP       {"log_id": "0RC7wJwl000", "service": "httpd", "addr": "[::]:8086", "https": false}
                                  2020-12-20T14:15:37.574529Z     info    Starting retention policy enforcement service   {"log_id": "0RC7wJwl000", "service": "retention", "check_interval": "30m"}
                                  2020-12-20T14:15:37.574895Z     info    Sending usage statistics to usage.influxdata.com        {"log_id": "0RC7wJwl000"}
                                  2020-12-20T14:15:37.575398Z     info    Listening for signals   {"log_id": "0RC7wJwl000"}
                                  2020-12-20T14:15:43.954822Z     info    Executing query {"log_id": "0RC7wJwl000", "service": "query", "query": "SHOW DATABASES"}
                                  [httpd] 192.168.178.41 - MEB [20/Dec/2020:15:15:43 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=MEB HTTP/1.1" 200 122 "-" "-" d8e47f87-42cd-11eb-8001-dca6321bbd83 5504
                                  • A Altersrentner
                                    @crunchip
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @Altersrentner sudo systemctl status influxdb
                                      Altersrentner
                                      @crunchip
                                      Jetzt hat der influxdb.0 Adapter auf grün gewechselt.😊
                                      Wenn ich aber auf "Verbindung testen" gehe,
                                      gibt es keine Reaktion.
                                      Ist das normal?
                                      • A Altersrentner
                                        @crunchip
                                        Ist das normal?
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        im Iobroker? ja
                                          im Iobroker? ja
                                          Altersrentner
                                          @crunchip
                                          ja im ioBroker.
                                          Aber im Terminal wird immer noch "keine Verbindung" angezeigt.
                                          Womit soll er sich dann auch verbinden?
                                          Kann ich influxdb deinstallieren und neu aufsetzen?
                                          Könnte das zu einer Lösung beitragen?
