  4. HILLFFEEE :( adapter verabschieden sich nach Stromausfall
fehlerhilfe
58 Beiträge 2 Kommentatoren 6.4k Aufrufe 2 Beobachtet
    @Wieger-Daniel
    Ausgabe von
    dmesg
    bitte.
    Wieger DanielW Offline
    Wieger Daniel
    gerne... geht sowas leichter zu kopieren? ^^
    root@debian:~# dmesg
    [    0.000000] Linux version 4.19.0-13-amd64 (debian-kernel@lists.debian.org) (g        cc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.160-2 (2020-11-28)
    [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-13-amd64 root=UUID=        6c2bdec8-8f1e-431a-a913-4c793ad41719 ro quiet
    [    0.000000] x86/fpu: x87 FPU will use FXSAVE
    [    0.000000] BIOS-provided physical RAM map:
    [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
    [    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
    [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
    [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bffd9fff] usable
    [    0.000000] BIOS-e820: [mem 0x00000000bffda000-0x00000000bfffffff] reserved
    [    0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
    [    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
    [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000013fffffff] usable
    [    0.000000] NX (Execute Disable) protection: active
    [    0.000000] SMBIOS 2.8 present.
    [    0.000000] DMI: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.13.0-0-gf        21b5a4aeb02-prebuilt.qemu.org 04/01/2014
    [    0.000000] Hypervisor detected: KVM
    [    0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
    [    0.000001] kvm-clock: cpu 0, msr 4a3eb001, primary cpu clock
    [    0.000001] kvm-clock: using sched offset of 1987970813620 cycles
    [    0.000004] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1c        d42e4dffb, max_idle_ns: 881590591483 ns
    [    0.000007] tsc: Detected 1497.600 MHz processor
    [    0.002682] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
    [    0.002685] e820: remove [mem 0x000a0000-0x000fffff] usable
    [    0.093325] AGP: No AGP bridge found
    [    0.094139] last_pfn = 0x140000 max_arch_pfn = 0x400000000
    [    0.094186] MTRR default type: write-back
    [    0.094187] MTRR fixed ranges enabled:
    [    0.094189]   00000-9FFFF write-back
    [    0.094190]   A0000-BFFFF uncachable
    [    0.094192]   C0000-FFFFF write-protect
    [    0.094193] MTRR variable ranges enabled:
    [    0.094195]   0 base 00C0000000 mask FFC0000000 uncachable
    [    0.094196]   1 disabled
    [    0.094197]   2 disabled
    [    0.094197]   3 disabled
    [    0.094198]   4 disabled
    [    0.094199]   5 disabled
    [    0.094200]   6 disabled
    [    0.094200]   7 disabled
    [    0.094218] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- UC
    [    0.094229] last_pfn = 0xbffda max_arch_pfn = 0x400000000
    [    0.098932] found SMP MP-table at [mem 0x000f5a80-0x000f5a8f]
    [    0.099329] RAMDISK: [mem 0x34e75000-0x36731fff]
    [    0.099357] ACPI: Early table checksum verification disabled
    [    0.099438] ACPI: RSDP 0x00000000000F5880 000014 (v00 BOCHS )
    [    0.099451] ACPI: RSDT 0x00000000BFFE15A0 000034 (v01 BOCHS  BXPCRSDT 0000000        1 BXPC 00000001)
    [    0.099459] ACPI: FACP 0x00000000BFFE139A 000074 (v01 BOCHS  BXPCFACP 0000000        1 BXPC 00000001)
    [    0.099466] ACPI: DSDT 0x00000000BFFDF040 00235A (v01 BOCHS  BXPCDSDT 0000000        1 BXPC 00000001)
    [    0.099470] ACPI: FACS 0x00000000BFFDF000 000040
    [    0.099473] ACPI: APIC 0x00000000BFFE140E 000090 (v01 BOCHS  BXPCAPIC 0000000        1 BXPC 00000001)
    [    0.099477] ACPI: SSDT 0x00000000BFFE149E 0000CA (v01 BOCHS  VMGENID  0000000        1 BXPC 00000001)
    [    0.099481] ACPI: HPET 0x00000000BFFE1568 000038 (v01 BOCHS  BXPCHPET 0000000        1 BXPC 00000001)
    [    0.099491] ACPI: Local APIC address 0xfee00000
    [    0.100017] No NUMA configuration found
    [    0.100018] Faking a node at [mem 0x0000000000000000-0x000000013fffffff]
    [    0.100024] NODE_DATA(0) allocated [mem 0x13fff8000-0x13fffcfff]
    [    0.100073] Zone ranges:
    [    0.100075]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
    [    0.100077]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
    [    0.100078]   Normal   [mem 0x0000000100000000-0x000000013fffffff]
    [    0.100079]   Device   empty
    [    0.100081] Movable zone start for each node
    [    0.100081] Early memory node ranges
    [    0.100083]   node   0: [mem 0x0000000000001000-0x000000000009efff]
    [    0.100084]   node   0: [mem 0x0000000000100000-0x00000000bffd9fff]
    [    0.100085]   node   0: [mem 0x0000000100000000-0x000000013fffffff]
    [    0.100104] Zeroed struct page in unavailable ranges: 136 pages
    [    0.100106] Initmem setup node 0 [mem 0x0000000000001000-0x000000013fffffff]
    [    0.100108] On node 0 totalpages: 1048440
    [    0.100110]   DMA zone: 64 pages used for memmap
    [    0.100111]   DMA zone: 21 pages reserved
    [    0.100112]   DMA zone: 3998 pages, LIFO batch:0
    [    0.100265]   DMA32 zone: 12224 pages used for memmap
    [    0.100266]   DMA32 zone: 782298 pages, LIFO batch:63
    [    0.132239]   Normal zone: 4096 pages used for memmap
    [    0.132244]   Normal zone: 262144 pages, LIFO batch:63
    [    0.143846] ACPI: PM-Timer IO Port: 0x608
    [    0.143852] ACPI: Local APIC address 0xfee00000
    [    0.143868] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
    [    0.143948] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
    [    0.143952] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
    [    0.143954] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 high level)
    [    0.143955] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
    [    0.143957] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 high level)
    [    0.143958] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 high level)
    [    0.143959] ACPI: IRQ0 used by override.
    [    0.143961] ACPI: IRQ5 used by override.
    [    0.143962] ACPI: IRQ9 used by override.
    [    0.143962] ACPI: IRQ10 used by override.
    [    0.143963] ACPI: IRQ11 used by override.
    [    0.143965] Using ACPI (MADT) for SMP configuration information
    [    0.143967] ACPI: HPET id: 0x8086a201 base: 0xfed00000
    [    0.143976] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
    [    0.144006] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
    [    0.144008] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
    [    0.144009] PM: Registered nosave memory: [mem 0x000a0000-0x000effff]
    [    0.144010] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
    [    0.144012] PM: Registered nosave memory: [mem 0xbffda000-0xbfffffff]
    [    0.144012] PM: Registered nosave memory: [mem 0xc0000000-0xfeffbfff]
    [    0.144013] PM: Registered nosave memory: [mem 0xfeffc000-0xfeffffff]
    [    0.144014] PM: Registered nosave memory: [mem 0xff000000-0xfffbffff]
    [    0.144015] PM: Registered nosave memory: [mem 0xfffc0000-0xffffffff]
    [    0.144018] [mem 0xc0000000-0xfeffbfff] available for PCI devices
    [    0.144019] Booting paravirtualized kernel on KVM
    [    0.144023] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffff        ffff, max_idle_ns: 7645519600211568 ns
    [    0.331551] random: get_random_bytes called from start_kernel+0x93/0x52a with        crng_init=0
    [    0.331565] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_nod        e_ids:1
    [    0.332420] percpu: Embedded 45 pages/cpu s144536 r8192 d31592 u524288
    [    0.332433] pcpu-alloc: s144536 r8192 d31592 u524288 alloc=1*2097152
    [    0.332435] pcpu-alloc: [0] 0 1 2 3
    [    0.332477] KVM setup async PF for cpu 0
    [    0.332516] kvm-stealtime: cpu 0, msr 13ba161c0
    [    0.332527] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes)
    [    0.332536] Built 1 zonelists, mobility grouping on.  Total pages: 1032035
    [    0.332538] Policy zone: Normal
    [    0.332541] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-13-amd64 roo        t=UUID=6c2bdec8-8f1e-431a-a913-4c793ad41719 ro quiet
    [    0.354464] AGP: Checking aperture...
    [    0.446735] AGP: No AGP bridge found
    [    0.447561] Calgary: detecting Calgary via BIOS EBDA area
    [    0.447563] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
    [    0.475509] Memory: 4011336K/4193760K available (10252K kernel code, 1242K rw        data, 3320K rodata, 1596K init, 2264K bss, 182424K reserved, 0K cma-reserved)
    [    0.475708] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.475718] Kernel/User page tables isolation: enabled
    [    0.475789] ftrace: allocating 31960 entries in 125 pages
    [    0.492356] rcu: Hierarchical RCU implementation.
    [    0.492360] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [    0.492362] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.497119] NR_IRQS: 33024, nr_irqs: 456, preallocated irqs: 16
    [    0.529372] Console: colour VGA+ 80x25
    [    0.529379] console [tty0] enabled
    [    0.529429] ACPI: Core revision 20180810
    [    0.529892] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_i        dle_ns: 19112604467 ns
    [    0.530083] hpet clockevent registered
    [    0.530131] APIC: Switch to symmetric I/O mode setup
    [    0.530587] x2apic enabled
    [    0.531061] Switched APIC routing to physical x2apic.
    [    0.532907] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
    [    0.532962] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x15        9647815e3, max_idle_ns: 440795269835 ns
    [    0.532985] Calibrating delay loop (skipped) preset value.. 2995.20 BogoMIPS        (lpj=5990400)
    [    0.532989] pid_max: default: 32768 minimum: 301
    [    0.533052] Security Framework initialized
    [    0.533054] Yama: disabled by default; enable with sysctl kernel.yama.*
    [    0.533086] AppArmor: AppArmor initialized
    [    0.537579] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes        )
    [    0.538548] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
    [    0.538614] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.538650] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.539196] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
    [    0.539199] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
    [    0.539202] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user poin        ter sanitization
    [    0.539204] Spectre V2 : Mitigation: Full generic retpoline
    [    0.539205] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on c        ontext switch
    [    0.539206] Speculative Store Bypass: Vulnerable
    [    0.539252] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
    [    0.539436] Freeing SMP alternatives memory: 24K
    [    0.649711] smpboot: CPU0: Intel Common KVM processor (family: 0xf, model: 0x        6, stepping: 0x1)
    [    0.649992] Performance Events: unsupported Netburst CPU model 6 no PMU drive        r, software events only.
    [    0.650054] rcu: Hierarchical SRCU implementation.
    [    0.650516] NMI watchdog: Perf NMI watchdog permanently disabled
    [    0.650701] smp: Bringing up secondary CPUs ...
    [    0.650897] x86: Booting SMP configuration:
    [    0.650899] .... node  #0, CPUs:      #1
    [    0.035667] kvm-clock: cpu 1, msr 4a3eb041, secondary cpu clock
    [    0.663418] KVM setup async PF for cpu 1
    [    0.663418] kvm-stealtime: cpu 1, msr 13ba961c0
    [    0.663418]  #2
    [    0.035667] kvm-clock: cpu 2, msr 4a3eb081, secondary cpu clock
    [    0.677002] KVM setup async PF for cpu 2
    [    0.677008] kvm-stealtime: cpu 2, msr 13bb161c0
    [    0.677174]  #3
    [    0.035667] kvm-clock: cpu 3, msr 4a3eb0c1, secondary cpu clock
    [    0.689001] KVM setup async PF for cpu 3
    [    0.689010] kvm-stealtime: cpu 3, msr 13bb961c0
    [    0.689018] smp: Brought up 1 node, 4 CPUs
    [    0.689018] smpboot: Max logical packages: 1
    [    0.689018] smpboot: Total of 4 processors activated (11980.80 BogoMIPS)
    [    0.689502] devtmpfs: initialized
    [    0.689502] x86/mm: Memory block size: 128MB
    [    0.689774] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 7645041785100000 ns
    [    0.689774] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.693059] pinctrl core: initialized pinctrl subsystem
    [    0.693544] NET: Registered protocol family 16
    [    0.693657] audit: initializing netlink subsys (disabled)
    [    0.693733] audit: type=2000 audit(1608417860.685:1): state=initialized audit        _enabled=0 res=1
    [    0.693733] cpuidle: using governor ladder
    [    0.693733] cpuidle: using governor menu
    [    0.693733] ACPI: bus type PCI registered
    [    0.693733] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
    [    0.693871] PCI: Using configuration type 1 for base access
    [    0.694197] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.698462] ACPI: Added _OSI(Module Device)
    [    0.698462] ACPI: Added _OSI(Processor Device)
    [    0.698462] ACPI: Added _OSI(3.0 _SCP Extensions)
    [    0.698462] ACPI: Added _OSI(Processor Aggregator Device)
    [    0.698462] ACPI: Added _OSI(Linux-Dell-Video)
    [    0.698462] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
    [    0.698824] ACPI: 2 ACPI AML tables successfully acquired and loaded
    [    0.701089] ACPI: Interpreter enabled
    [    0.701112] ACPI: (supports S0 S3 S4 S5)
    [    0.701114] ACPI: Using IOAPIC for interrupt routing
    [    0.701145] PCI: Using host bridge windows from ACPI; if necessary, use "pci=        nocrs" and report a bug
    [    0.701418] ACPI: Enabled 3 GPEs in block 00 to 0F
    [    0.709107] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
    [    0.709115] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI]
    [    0.709122] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
    [    0.709132] acpi PNP0A03:00: fail to add MMCONFIG information, can't access e        xtended PCI configuration space under this bridge.
    [    0.709613] acpiphp: Slot [3] registered
    [    0.709671] acpiphp: Slot [4] registered
    [    0.709729] acpiphp: Slot [5] registered
    [    0.709787] acpiphp: Slot [6] registered
    [    0.709844] acpiphp: Slot [7] registered
    [    0.709900] acpiphp: Slot [8] registered
    [    0.709956] acpiphp: Slot [9] registered
    [    0.710012] acpiphp: Slot [10] registered
    [    0.710067] acpiphp: Slot [11] registered
    [    0.710125] acpiphp: Slot [12] registered
    [    0.710183] acpiphp: Slot [13] registered
    [    0.710238] acpiphp: Slot [14] registered
    [    0.710297] acpiphp: Slot [15] registered
    [    0.710356] acpiphp: Slot [16] registered
    [    0.710411] acpiphp: Slot [17] registered
    [    0.710472] acpiphp: Slot [18] registered
    [    0.710529] acpiphp: Slot [19] registered
    [    0.710585] acpiphp: Slot [20] registered
    [    0.710640] acpiphp: Slot [21] registered
    [    0.710695] acpiphp: Slot [22] registered
    [    0.710770] acpiphp: Slot [23] registered
    [    0.710830] acpiphp: Slot [24] registered
    [    0.710886] acpiphp: Slot [25] registered
    [    0.710941] acpiphp: Slot [26] registered
    [    0.710997] acpiphp: Slot [27] registered
    [    0.711052] acpiphp: Slot [28] registered
    [    0.711107] acpiphp: Slot [29] registered
    [    0.711173] PCI host bridge to bus 0000:00
    [    0.711177] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
    [    0.711179] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
    [    0.711180] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff win        dow]
    [    0.711182] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff win        dow]
    [    0.711184] pci_bus 0000:00: root bus resource [mem 0x140000000-0x1bfffffff w        indow]
    [    0.711186] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.711249] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
    [    0.711977] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
    [    0.712892] pci 0000:00:01.1: [8086:7010] type 00 class 0x010180
    [    0.716091] pci 0000:00:01.1: reg 0x20: [io  0xe0a0-0xe0af]
    [    0.717344] pci 0000:00:01.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
    [    0.717348] pci 0000:00:01.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
    [    0.717349] pci 0000:00:01.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
    [    0.717351] pci 0000:00:01.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
    [    0.717693] pci 0000:00:01.2: [8086:7020] type 00 class 0x0c0300
    [    0.721354] pci 0000:00:01.2: reg 0x20: [io  0xe040-0xe05f]
    [    0.723298] pci 0000:00:01.3: [8086:7113] type 00 class 0x068000
    [    0.724735] pci 0000:00:01.3: quirk: [io  0x0600-0x063f] claimed by PIIX4 ACP        I
    [    0.724753] pci 0000:00:01.3: quirk: [io  0x0700-0x070f] claimed by PIIX4 SMB
    [    0.725264] pci 0000:00:02.0: [1234:1111] type 00 class 0x030000
    [    0.727187] pci 0000:00:02.0: reg 0x10: [mem 0xfd000000-0xfdffffff pref]
    [    0.729765] pci 0000:00:02.0: reg 0x18: [mem 0xfea50000-0xfea50fff]
    [    0.737763] pci 0000:00:02.0: reg 0x30: [mem 0xfea40000-0xfea4ffff pref]
    [    0.738290] pci 0000:00:03.0: [1af4:1002] type 00 class 0x00ff00
    [    0.739500] pci 0000:00:03.0: reg 0x10: [io  0xe060-0xe07f]
    [    0.744358] pci 0000:00:03.0: reg 0x20: [mem 0xfe400000-0xfe403fff 64bit pref        ]
    [    0.749066] pci 0000:00:05.0: [1af4:1004] type 00 class 0x010000
    [    0.751176] pci 0000:00:05.0: reg 0x10: [io  0xe000-0xe03f]
    [    0.752852] pci 0000:00:05.0: reg 0x14: [mem 0xfea51000-0xfea51fff]
    [    0.757864] pci 0000:00:05.0: reg 0x20: [mem 0xfe404000-0xfe407fff 64bit pref        ]
    [    0.762296] pci 0000:00:12.0: [1af4:1000] type 00 class 0x020000
    [    0.763985] pci 0000:00:12.0: reg 0x10: [io  0xe080-0xe09f]
    [    0.765700] pci 0000:00:12.0: reg 0x14: [mem 0xfea52000-0xfea52fff]
    [    0.769781] pci 0000:00:12.0: reg 0x20: [mem 0xfe408000-0xfe40bfff 64bit pref        ]
    [    0.773787] pci 0000:00:12.0: reg 0x30: [mem 0xfea00000-0xfea3ffff pref]
    [    0.774996] pci 0000:00:1e.0: [1b36:0001] type 01 class 0x060400
    [    0.776900] pci 0000:00:1e.0: reg 0x10: [mem 0xfea53000-0xfea530ff 64bit]
    [    0.779175] pci 0000:00:1f.0: [1b36:0001] type 01 class 0x060400
    [    0.781559] pci 0000:00:1f.0: reg 0x10: [mem 0xfea54000-0xfea540ff 64bit]
    [    0.785228] pci_bus 0000:01: extended config space not accessible
    [    0.785720] acpiphp: Slot [0] registered
    [    0.785781] acpiphp: Slot [1] registered
    [    0.786223] acpiphp: Slot [2] registered
    [    0.786313] acpiphp: Slot [3-2] registered
    [    0.786377] acpiphp: Slot [4-2] registered
    [    0.786475] acpiphp: Slot [5-2] registered
    [    0.786539] acpiphp: Slot [6-2] registered
    [    0.786610] acpiphp: Slot [7-2] registered
    [    0.786672] acpiphp: Slot [8-2] registered
    [    0.786736] acpiphp: Slot [9-2] registered
    [    0.786799] acpiphp: Slot [10-2] registered
    [    0.786861] acpiphp: Slot [11-2] registered
    [    0.786926] acpiphp: Slot [12-2] registered
    [    0.786990] acpiphp: Slot [13-2] registered
    [    0.787053] acpiphp: Slot [14-2] registered
    [    0.788227] acpiphp: Slot [15-2] registered
    [    0.788302] acpiphp: Slot [16-2] registered
    [    0.788365] acpiphp: Slot [17-2] registered
    [    0.788429] acpiphp: Slot [18-2] registered
    [    0.788498] acpiphp: Slot [19-2] registered
    [    0.788562] acpiphp: Slot [20-2] registered
    [    0.788625] acpiphp: Slot [21-2] registered
    [    0.789021] acpiphp: Slot [22-2] registered
    [    0.789084] acpiphp: Slot [23-2] registered
    [    0.789145] acpiphp: Slot [24-2] registered
    [    0.789209] acpiphp: Slot [25-2] registered
    [    0.789272] acpiphp: Slot [26-2] registered
    [    0.789333] acpiphp: Slot [27-2] registered
    [    0.789395] acpiphp: Slot [28-2] registered
    [    0.789457] acpiphp: Slot [29-2] registered
    [    0.789515] acpiphp: Slot [30] registered
    [    0.789573] acpiphp: Slot [31] registered
    [    0.789954] pci 0000:00:1e.0: PCI bridge to [bus 01]
    [    0.789984] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
    [    0.790011] pci 0000:00:1e.0:   bridge window [mem 0xfe800000-0xfe9fffff]
    [    0.790061] pci 0000:00:1e.0:   bridge window [mem 0xfe200000-0xfe3fffff 64bi        t pref]
    [    0.793182] pci_bus 0000:02: extended config space not accessible
    [    0.794988] acpiphp: Slot [0-2] registered
    [    0.796159] acpiphp: Slot [1-2] registered
    [    0.796224] acpiphp: Slot [2-2] registered
    [    0.796286] acpiphp: Slot [3-3] registered
    [    0.796349] acpiphp: Slot [4-3] registered
    [    0.796411] acpiphp: Slot [5-3] registered
    [    0.796986] acpiphp: Slot [6-3] registered
    [    0.797120] acpiphp: Slot [7-3] registered
    [    0.797183] acpiphp: Slot [8-3] registered
    [    0.797246] acpiphp: Slot [9-3] registered
    [    0.797309] acpiphp: Slot [10-3] registered
    [    0.797372] acpiphp: Slot [11-3] registered
    [    0.797441] acpiphp: Slot [12-3] registered
    [    0.797504] acpiphp: Slot [13-3] registered
    [    0.797566] acpiphp: Slot [14-3] registered
    [    0.797628] acpiphp: Slot [15-3] registered
    [    0.797691] acpiphp: Slot [16-3] registered
    [    0.797753] acpiphp: Slot [17-3] registered
    [    0.797817] acpiphp: Slot [18-3] registered
    [    0.797899] acpiphp: Slot [19-3] registered
    [    0.797963] acpiphp: Slot [20-3] registered
    [    0.798027] acpiphp: Slot [21-3] registered
    [    0.798174] acpiphp: Slot [22-3] registered
    [    0.798238] acpiphp: Slot [23-3] registered
    [    0.798306] acpiphp: Slot [24-3] registered
    [    0.798369] acpiphp: Slot [25-3] registered
    [    0.798432] acpiphp: Slot [26-3] registered
    [    0.798495] acpiphp: Slot [27-3] registered
    [    0.798580] acpiphp: Slot [28-3] registered
    [    0.798645] acpiphp: Slot [29-3] registered
    [    0.798715] acpiphp: Slot [30-2] registered
    [    0.798810] acpiphp: Slot [31-2] registered
    [    0.799193] pci 0000:00:1f.0: PCI bridge to [bus 02]
    [    0.799223] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
    [    0.799250] pci 0000:00:1f.0:   bridge window [mem 0xfe600000-0xfe7fffff]
    [    0.799299] pci 0000:00:1f.0:   bridge window [mem 0xfe000000-0xfe1fffff 64bi        t pref]
    [    0.801715] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10 11)
    [    0.801901] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 *10 11)
    [    0.802064] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10 *11)
    [    0.802226] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10 *11)
    [    0.802319] ACPI: PCI Interrupt Link [LNKS] (IRQs *9)
    [    0.805032] pci 0000:00:02.0: vgaarb: setting as boot VGA device
    [    0.805036] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=i        o+mem,locks=none
    [    0.805040] pci 0000:00:02.0: vgaarb: bridge control possible
    [    0.805042] vgaarb: loaded
    [    0.805176] pps_core: LinuxPPS API ver. 1 registered
    [    0.805178] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome        tti <giometti@linux.it>
    [    0.805181] PTP clock support registered
    [    0.805192] EDAC MC: Ver: 3.0.0
    [    0.805722] PCI: Using ACPI for IRQ routing
    [    0.805722] PCI: pci_cache_line_size set to 64 bytes
    [    0.805722] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
    [    0.805722] e820: reserve RAM buffer [mem 0xbffda000-0xbfffffff]
    [    0.805722] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
    [    0.805722] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
    [    0.805722] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
    [    0.813479] clocksource: Switched to clocksource kvm-clock
    [    0.831667] VFS: Disk quotas dquot_6.6.0
    [    0.831692] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.831868] AppArmor: AppArmor Filesystem Enabled
    [    0.831900] pnp: PnP ACPI init
    [    0.832000] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
    [    0.832059] pnp 00:01: Plug and Play ACPI device, IDs PNP0303 (active)
    [    0.832102] pnp 00:02: Plug and Play ACPI device, IDs PNP0f13 (active)
    [    0.832118] pnp 00:03: [dma 2]
    [    0.832141] pnp 00:03: Plug and Play ACPI device, IDs PNP0700 (active)
    [    0.832742] pnp: PnP ACPI: found 4 devices
    [    0.844759] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_id        le_ns: 2085701024 ns
    [    0.844788] pci 0000:00:1e.0: PCI bridge to [bus 01]
    [    0.844819] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
    [    0.845914] pci 0000:00:1e.0:   bridge window [mem 0xfe800000-0xfe9fffff]
    [    0.846593] pci 0000:00:1e.0:   bridge window [mem 0xfe200000-0xfe3fffff 64bi        t pref]
    [    0.847804] pci 0000:00:1f.0: PCI bridge to [bus 02]
    [    0.847829] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
    [    0.848819] pci 0000:00:1f.0:   bridge window [mem 0xfe600000-0xfe7fffff]
    [    0.849526] pci 0000:00:1f.0:   bridge window [mem 0xfe000000-0xfe1fffff 64bi        t pref]
    [    0.850813] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
    [    0.850816] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
    [    0.850818] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
    [    0.850820] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xfebfffff window]
    [    0.850822] pci_bus 0000:00: resource 8 [mem 0x140000000-0x1bfffffff window]
    [    0.850825] pci_bus 0000:01: resource 0 [io  0xd000-0xdfff]
    [    0.850827] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe9fffff]
    [    0.850828] pci_bus 0000:01: resource 2 [mem 0xfe200000-0xfe3fffff 64bit pref        ]
    [    0.850831] pci_bus 0000:02: resource 0 [io  0xc000-0xcfff]
    [    0.850832] pci_bus 0000:02: resource 1 [mem 0xfe600000-0xfe7fffff]
    [    0.850834] pci_bus 0000:02: resource 2 [mem 0xfe000000-0xfe1fffff 64bit pref        ]
    [    0.851010] NET: Registered protocol family 2
    [    0.851289] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 3276        8 bytes)
    [    0.851331] TCP established hash table entries: 32768 (order: 6, 262144 bytes        )
    [    0.851469] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
    [    0.851674] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.851784] UDP hash table entries: 2048 (order: 4, 65536 bytes)
    [    0.851826] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
    [    0.851933] NET: Registered protocol family 1
    [    0.851941] NET: Registered protocol family 44
    [    0.852013] pci 0000:00:01.0: PIIX3: Enabling Passive Release
    [    0.852035] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
    [    0.852055] pci 0000:00:01.0: Activating ISA DMA hang workarounds
    [    0.888476] PCI Interrupt Link [LNKD] enabled at IRQ 11
    [    0.931199] pci 0000:00:01.2: quirk_usb_early_handoff+0x0/0x6c1 took 77240 us        ecs
    [    0.931313] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c00        00-0x000dffff]
    [    0.931405] PCI: CLS 0 bytes, default 64
    [    0.931488] Unpacking initramfs...
    [    1.544441] Freeing initrd memory: 25332K
    [    1.544556] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
    [    1.544559] software IO TLB: mapped [mem 0xbbfda000-0xbffda000] (64MB)
    [    1.544609] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x15964781        5e3, max_idle_ns: 440795269835 ns
    [    1.545744] Initialise system trusted keyrings
    [    1.545761] Key type blacklist registered
    [    1.546293] workingset: timestamp_bits=40 max_order=20 bucket_order=0
    [    1.548035] zbud: loaded
    [    1.799898] Key type asymmetric registered
    [    1.799901] Asymmetric key parser 'x509' registered
    [    1.799930] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        47)
    [    1.800229] io scheduler noop registered
    [    1.800231] io scheduler deadline registered
    [    1.800303] io scheduler cfq registered (default)
    [    1.800304] io scheduler mq-deadline registered
    [    1.800843] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP        (\_SB_.PCI0.SF0_)
    [    1.800855] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP        (\_SB_.PCI0)
    [    1.800861] shpchp 0000:00:1e.0: Cannot get control of SHPC hotplug
    [    1.800935] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP        (\_SB_.PCI0.SF8_)
    [    1.800940] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP        (\_SB_.PCI0)
    [    1.800943] shpchp 0000:00:1f.0: Cannot get control of SHPC hotplug
    [    1.800957] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [    1.801456] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    1.802507] Linux agpgart interface v0.103
    [    1.802659] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
    [    1.802660] AMD IOMMUv2 functionality not available on this system
    [    1.803482] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x6        4 irq 1,12
    [    1.804702] serio: i8042 KBD port at 0x60,0x64 irq 1
    [    1.804715] serio: i8042 AUX port at 0x60,0x64 irq 12
    [    1.805060] mousedev: PS/2 mouse device common for all mice
    [    1.805284] rtc_cmos 00:00: RTC can wake from S4
    [    1.806323] input: AT Translated Set 2 keyboard as /devices/platform/i8042/se        rio0/input/input0
    [    1.806630] rtc_cmos 00:00: registered as rtc0
    [    1.806653] rtc_cmos 00:00: alarms up to one day, y3k, 114 bytes nvram, hpet        irqs
    [    1.807092] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.807509] NET: Registered protocol family 10
    [    1.822625] Segment Routing with IPv6
    [    1.822659] mip6: Mobile IPv6
    [    1.822663] NET: Registered protocol family 17
    [    1.822813] mpls_gso: MPLS GSO support
    [    1.823410] mce: Using 10 MCE banks
    [    1.823453] sched_clock: Marking stable (1791715442, 31667684)->(1824337168,        -954042)
    [    1.824922] registered taskstats version 1
    [    1.824925] Loading compiled-in X.509 certificates
    [    1.883113] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3d        d27dfcc5cbb419ea1'
    [    1.883148] Loaded X.509 cert 'Debian Secure Boot Signer 2020: 00b55eb3b9'
    [    1.883202] zswap: loaded using pool lzo/zbud
    [    1.884068] AppArmor: AppArmor sha1 policy hashing enabled
    [    1.884842] rtc_cmos 00:00: setting system clock to 2020-12-19 22:44:21 UTC (        1608417861)
    [    1.887664] Freeing unused kernel image memory: 1596K
    [    1.905134] Write protecting the kernel read-only data: 16384k
    [    1.907340] Freeing unused kernel image memory: 2028K
    [    1.907846] Freeing unused kernel image memory: 776K
    [    1.921530] x86/mm: Checked W+X mappings: passed, no W+X pages found.
    [    1.921675] x86/mm: Checking user space page tables
    [    1.934948] x86/mm: Checked W+X mappings: passed, no W+X pages found.
    [    1.934951] Run /init as init process
    [    2.096379] piix4_smbus 0000:00:01.3: SMBus Host Controller at 0x700, revisio        n 0
    [    2.113311] FDC 0 is a S82078B
    [    2.116280] SCSI subsystem initialized
    [    2.130037] ACPI: bus type USB registered
    [    2.130079] usbcore: registered new interface driver usbfs
    [    2.130091] usbcore: registered new interface driver hub
    [    2.130155] usbcore: registered new device driver usb
    [    2.136288] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/seri        o1/input/input3
    [    2.137594] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/seri        o1/input/input2
    [    2.144402] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.145362] PCI Interrupt Link [LNKC] enabled at IRQ 10
    [    2.149842] uhci_hcd: USB Universal Host Controller Interface driver
    [    2.150026] libata version 3.00 loaded.
    [    2.153493] ata_piix 0000:00:01.1: version 2.13
    [    2.155162] scsi host0: ata_piix
    [    2.155572] scsi host1: ata_piix
    [    2.155660] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xe0a0 irq 14
    [    2.155662] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xe0a8 irq 15
    [    2.222686] uhci_hcd 0000:00:01.2: UHCI Host Controller
    [    2.222707] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus numbe        r 1
    [    2.222739] uhci_hcd 0000:00:01.2: detected 2 ports
    [    2.222774] PCI Interrupt Link [LNKA] enabled at IRQ 10
    [    2.222999] uhci_hcd 0000:00:01.2: irq 11, io base 0x0000e040
    [    2.223197] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bc        dDevice= 4.19
    [    2.223199] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
    [    2.223201] usb usb1: Product: UHCI Host Controller
    [    2.223202] usb usb1: Manufacturer: Linux 4.19.0-13-amd64 uhci_hcd
    [    2.223204] usb usb1: SerialNumber: 0000:00:01.2
    [    2.223435] hub 1-0:1.0: USB hub found
    [    2.223446] hub 1-0:1.0: 2 ports detected
    [    2.263637] PCI Interrupt Link [LNKB] enabled at IRQ 11
    [    2.275507] scsi host2: Virtio SCSI HBA
    [    2.279117] scsi 2:0:0:0: Direct-Access     QEMU     QEMU HARDDISK    2.5+ PQ        : 0 ANSI: 5
    [    2.290113] virtio_net virtio2 ens18: renamed from eth0
    [    2.314220] ata2.01: NODEV after polling detection
    [    2.314622] ata2.00: ATAPI: QEMU DVD-ROM, 2.5+, max UDMA/100
    [    2.316436] scsi: waiting for bus probes to complete ...
    [    2.480271] random: fast init done
    [    2.511817] scsi 1:0:0:0: CD-ROM            QEMU     QEMU DVD-ROM     2.5+ PQ        : 0 ANSI: 5
    [    2.526196] sd 2:0:0:0: Power-on or device reset occurred
    [    2.527074] sd 2:0:0:0: [sda] 67108864 512-byte logical blocks: (34.4 GB/32.0        GiB)
    [    2.527139] sd 2:0:0:0: [sda] Write Protect is off
    [    2.527141] sd 2:0:0:0: [sda] Mode Sense: 63 00 00 08
    [    2.527264] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, does        n't support DPO or FUA
    [    2.531169] sr 1:0:0:0: [sr0] scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
    [    2.531174] cdrom: Uniform CD-ROM driver Revision: 3.20
    [    2.531930] sr 1:0:0:0: Attached scsi CD-ROM sr0
    [    2.539439]  sda: sda1 sda2 < sda5 >
    [    2.541458] sd 2:0:0:0: [sda] Attached SCSI disk
    [    2.561086] usb 1-1: new full-speed USB device number 2 using uhci_hcd
    [    2.691331] PM: Image not found (code -22)
    [    2.748086] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcd        Device= 0.00
    [    2.748090] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=1        0
    [    2.748092] usb 1-1: Product: QEMU USB Tablet
    [    2.748094] usb 1-1: Manufacturer: QEMU
    [    2.748095] usb 1-1: SerialNumber: 28754-0000:00:01.2-1
    [    2.762530] hidraw: raw HID events driver (C) Jiri Kosina
    [    2.773631] usbcore: registered new interface driver usbhid
    [    2.773634] usbhid: USB HID core driver
    [    2.782902] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/u        sb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input4
    [    2.783079] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mou        se [QEMU QEMU USB Tablet] on usb-0000:00:01.2-1/input0
    [    2.806551] cryptd: max_cpu_qlen set to 1000
    [    3.044857] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts:        (null)
    [    3.398111] systemd[1]: Inserted module 'autofs4'
    [    3.436704] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr        id)
    [    3.436827] systemd[1]: Detected virtualization kvm.
    [    3.436844] systemd[1]: Detected architecture x86-64.
    [    3.459298] systemd[1]: Set hostname to <debian>.
    [    3.768424] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.771150] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.771314] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.771495] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.771741] systemd[1]: Listening on fsck to fsckd communication Socket.
    [    3.779660] systemd[1]: Created slice system-getty.slice.
    [    3.780134] systemd[1]: Created slice User and Session Slice.
    [    3.780509] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.780783] systemd[1]: Listening on Syslog Socket.
    [    3.857298] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    [    3.932140] lp: driver loaded but no devices found
    [    3.961561] ppdev: user-space parallel port driver
    [    4.124455] systemd-journald[203]: Received request to flush runtime journal        from PID 1
    [    4.199563] audit: type=1400 audit(1608417863.812:2): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="nvidia_modprobe" pid=235 comm="ap        parmor_parser"
    [    4.199571] audit: type=1400 audit(1608417863.812:3): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=235 co        mm="apparmor_parser"
    [    4.203388] audit: type=1400 audit(1608417863.816:4): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="/usr/bin/man" pid=234 comm="appar        mor_parser"
    [    4.203395] audit: type=1400 audit(1608417863.816:5): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="man_filter" pid=234 comm="apparmo        r_parser"
    [    4.203399] audit: type=1400 audit(1608417863.816:6): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="man_groff" pid=234 comm="apparmor        _parser"
    [    4.209118] audit: type=1400 audit(1608417863.824:7): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=232 c        omm="apparmor_parser"
    [    4.232394] audit: type=1400 audit(1608417863.844:8): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" p        id=233 comm="apparmor_parser"
    [    4.232400] audit: type=1400 audit(1608417863.844:9): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=233 comm="ap        parmor_parser"
    [    4.232403] audit: type=1400 audit(1608417863.844:10): apparmor="STATUS" oper        ation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pi        d=233 comm="apparmor_parser"
    [    4.302592] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/inp        ut5
    [    4.302699] ACPI: Power Button [PWRF]
    [    4.538597] input: PC Speaker as /devices/platform/pcspkr/input/input6
    [    4.569860] sd 2:0:0:0: Attached scsi generic sg0 type 0
    [    4.570891] sr 1:0:0:0: Attached scsi generic sg1 type 5
    [    4.686678] [drm] Found bochs VGA, ID 0xb0c0.
    [    4.686683] [drm] Framebuffer size 16384 kB @ 0xfd000000, mmio @ 0xfea50000.
    [    4.695567] [TTM] Zone  kernel: Available graphics memory: 2020546 kiB
    [    4.695571] [TTM] Initializing pool allocator
    [    4.695578] [TTM] Initializing DMA pool allocator
    [    4.700913] fbcon: bochsdrmfb (fb0) is primary device
    [    4.732357] Console: switching to colour frame buffer device 128x48
    [    4.735641] bochs-drm 0000:00:02.0: fb0: bochsdrmfb frame buffer device
    [    4.761854] [drm] Initialized bochs-drm 1.0.0 20130925 for 0000:00:02.0 on mi        nor 0
    [    4.943401] Adding 2094076k swap on /dev/sda5.  Priority:-2 extents:1 across:        2094076k FS
    [    6.630477] random: crng init done
    [    6.630482] random: 7 urandom warning(s) missed due to ratelimiting
    [   89.002087] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
    [   89.080282] Bluetooth: Core ver 2.22
    [   89.080315] NET: Registered protocol family 31
    [   89.080317] Bluetooth: HCI device and connection manager initialized
    [   89.080323] Bluetooth: HCI socket layer initialized
    [   89.080326] Bluetooth: L2CAP socket layer initialized
    [   89.080335] Bluetooth: SCO socket layer initialized
      @Wieger-Daniel
      Ausgabe von
      dmesg
      bitte.
      Wieger Daniel
      bei dem versuch deconz zu installieren bekommen ich:
      $ ./iobroker add deconz  --host debian
      NPM version: 6.14.9
      npm install iobroker.deconz@1.3.11 --loglevel error --prefix "/opt/iobroker" (System call)
      npm
       ERR! code ENETUNREACHnpm ERR! errno ENETUNREACH
      npm ERR! request to https://registry.npmjs.org/iobroker.deconz failed, reason: connect ENETUNREACH 104.16.25.35:443 - Local (0.0.0.0:0)
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-12-19T23_23_13_853Z-debug.log
      ERROR: host.debian Cannot install iobroker.deconz@1.3.11: 1
      • Wieger DanielW Wieger Daniel
        [    0.663418]  #2
        [    0.677174]  #3
        @Wieger-Daniel sagte in HILLFFEEE :( adapter verabschieden sich nach Stromausfall:
        root@debian
        Ist schon mal Murks. Leg dir einen user mit sudo-Rechten an und hantier mit dem auf dem System rum.
        Das Grundsystem sieht aber auf den ersten Blick gesund aus.
        Was sagt
        uname -a
        Wieger DanielW 1 Antwort Letzte Antwort
          NPM version: 6.14.9
          npm
          Die IP 104.16.25.35 kann nicht erreicht werden.
          ping die mal an und check die Route:
          ping 104.16.25.35
          traceroute 104.16.25.35
            root@debian
            Was sagt
            uname -a
            Wieger Daniel
            @Thomas-Braun sagte in HILLFFEEE :( adapter verabschieden sich nach Stromausfall:
            uname -a
            ich hätte einen User mit root rechten, aber das funktioniert genau steine in putty :(
            root@debian:~# uname -a
            Linux debian 4.19.0-13-amd64 #1 SMP Debian 4.19.160-2 (2020-11-28) x86_64 GNU/Linux
              uname -a
              @Wieger-Daniel Ich bin ein alter Knacker, Jugendsprache verstehe ich nicht mehr. Was soll das mit den Steinen bedeuten?
                ping 104.16.25.35
                Wieger Daniel
                ping 104.16.25.35
                ich kenne diese IP nichtmal.
                system intern laufen alle mit 192.168.x.xxx
                und nach aussen kommuniziert eigtl nur der cloud. iot. telegramm. backup.
                root@debian:~# ping 104.16.25.35
                connect: Das Netzwerk ist nicht erreichbar
                root@debian:~# traceroute 104.16.25.35
                traceroute to 104.16.25.35 (104.16.25.35), 30 hops max, 60 byte packets
                root@debian:~#
                  Wieger Daniel
                  @Thomas-Braun
                  funktioniert steine:
                  funktioniert nicht :)
                    ping 104.16.25.35
                    root@debian:~#
                    @Wieger-Daniel Die IP ist von der npm registry. Die musst du erreichen können, um Adapter zu installieren.
                    ifconfig
                      @Thomas-Braun
                      @Wieger-Daniel Warum sollte ein normaler user sich nicht per puTTY anmelden können und dann per sudo von innerhalb root-Rechte erhalten? Das wäre das erste Debian bei dem das nicht funktionieren würde. (Wenn der user halt die richtigen Rechte erhalten hat).
                        ifconfig
                        Wieger Daniel
                        @Thomas-Braun
                        was mach ich mit ifconfig? da kommt
                        root@debian:~# bash: ifconfig: Kommando nicht gefunden.
                        bash: bash:: Kommando nicht gefunden.
                          Wieger Daniel
                          @Thomas-Braun wenn ich als normaler User mit root rechten einen sudo befehl eingebe kommt:
                          Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die
                          Regeln erklärt hat.  Normalerweise läuft es auf drei Regeln hinaus:
                              #1) Respektieren Sie die Privatsphäre anderer.
                              #2) Denken Sie nach, bevor Sie tippen.
                              #3) Mit großer Macht kommt große Verantwortung.
                          [sudo] Passwort für daniel:
                          Leider darf der Benutzer daniel »/usr/sbin/ifconfig« als root auf debian.Broker nicht ausführen.
                            @Thomas-Braun
                            @Wieger-Daniel
                            Da sollten eigentlich deine Netzwerkinterfaces auftauchen. Auf einem gesunden System schaut das so aus:
                            pi@ioBroker-RasPi4:~ $ ifconfig
                            eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                                    inet 192.168.178.51  netmask 255.255.255.0  broadcast 192.168.178.255
                                    inet6 IPV6ADRESSEHIER  prefixlen 64  scopeid 0x0<global>
                                    inet6 IPV6ADRESSEHIER  prefixlen 64  scopeid 0x20<link>
                                    ether MACHIER  txqueuelen 1000  (Ethernet)
                                    RX packets 16138  bytes 17464249 (16.6 MiB)
                                    RX errors 0  dropped 2  overruns 0  frame 0
                                    TX packets 5418  bytes 651393 (636.1 KiB)
                                    TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
                            lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                                    inet 127.0.0.1  netmask 255.0.0.0
                                    inet6 ::1  prefixlen 128  scopeid 0x10<host>
                                    loop  txqueuelen 1000  (Lokale Schleife)
                                    RX packets 2074  bytes 2296927 (2.1 MiB)
                                    RX errors 0  dropped 0  overruns 0  frame 0
                                    TX packets 2074  bytes 2296927 (2.1 MiB)
                            wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
                                    ether dc:a6:32:5a:4c:fb  txqueuelen 1000  (Ethernet)
                                    RX packets 0  bytes 0 (0.0 B)
                                    TX packets 0  bytes 0 (0.0 B)
                              @Wieger-Daniel Dann ist der user 'daniel' nicht als sudoer berechtigt.
                              usermod -aG sudo daniel
                              korrigiert das.
                                @Wieger-Daniel
                                Wieger Daniel
                                @Thomas-Braun ok, kann ich das beheben?
                                  @Wieger-Daniel
                                  apt install net-tools --reinstall
                                    @Wieger-Daniel
                                    Wobei ich dem System nicht wirklich vertrauen würde, selbst wenn das Paket reinstalliert wurde und vielleicht dieses Symptom behoben wäre.
                                    Ich würde es neuinstallieren und das Backup vom ioBroker einspielen. Das schaut mir zu wackelig aus.
                                      @Wieger-Daniel
                                      Wieger Daniel
                                      @Thomas-Braun
                                      liegts an der netconfig??
                                      hier wurde ach anleitung eine fixe IP geschrieben.
                                      # This file describes the network interfaces available on your system
                                      # and how to activate them. For more information, see interfaces(5).
                                      source /etc/network/interfaces.d/*
                                      # The loopback network interface
                                      auto lo
                                      iface lo inet loopback
                                      # The primary network interface
                                      allow-hotplug ens18
                                      iface ens18 inet static
                                      # gewünschte IP
                                      address 192.168.0.145
                                      #Adresse vom Router
                                      getway 192.168.0.1
                                      eigtl möchte ich mir eine neuinstallation echt sparen :( wäre die 2 diese Woche (hatte einen absturz der LXC)
                                        @Thomas-Braun
                                        auto lo
                                        allow-hotplug ens18
                                        # gewünschte IP
                                        #Adresse vom Router
                                        getway 192.168.0.1
                                        @Wieger-Daniel Trotzdem müssten die Interfaces angezeigt werden, statische IP hin oder her.
                                          @Thomas-Braun
                                          auto lo
                                          allow-hotplug ens18
                                          # gewünschte IP
                                          #Adresse vom Router
                                          getway 192.168.0.1
                                          #Adresse vom Router
                                          getway 192.168.0.1
                                          Muss das nicht
                                          #Adresse vom Router
                                          gateway 192.168.0.1
                                          heißen?
