  4. Zigbee Adapter nach ioBroker-Import immer gelb
cc2531conbeeimportexportneuinstallation
19 Beiträge 3 Kommentatoren 924 Aufrufe 3 Beobachtet
  • P puls200
    @Jan1 said in Zigbee Adapter nach ioBroker-Import immer gelb:
    nodejs -v && node -v && npm -v && which nodejs && which node && which npm
    Antwort war:
    v12.20.0
    v12.20.0
    6.14.8
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    Jan1
    @puls200
    So Node passt schon mal und war nur zur Sicherheit mal abgefragt.
    Editiere bitte noch Deine Posts oben, Du weißt ja jetzt wie das mit den Code Tags funktioniert :)
    P 1 Antwort Letzte Antwort
    • J Jan1
      @puls200
      puls200
      @Jan1 : habe ich meines Erachtens gemacht...
      • P puls200
        Und das vom CC2531:
        zigbee.0	2020-12-18 09:14:28.753	info	(4393) Starting Zigbee npm ...
        zigbee.0	2020-12-18 09:14:28.646	info	(4393) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.1.6
        host.raspberrypi	2020-12-18 09:14:26.867	info	instance system.adapter.zigbee.0 started with pid 4393
        host.raspberrypi	2020-12-18 09:14:24.381	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        zigbee.0	2020-12-18 09:14:23.864	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
        zigbee.0	2020-12-18 09:14:23.864	error	at Zigbee.emit (events.js:314:20)
        zigbee.0	2020-12-18 09:14:23.864	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:450:41)
        zigbee.0	2020-12-18 09:14:23.864	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:304:20)
        zigbee.0	2020-12-18 09:14:23.864	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:187:42)
        zigbee.0	2020-12-18 09:14:23.864	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:120:43)
        zigbee.0	2020-12-18 09:14:23.864	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:201:49)
        zigbee.0	2020-12-18 09:14:23.864	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:252:31)
        zigbee.0	2020-12-18 09:14:23.864	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:236:16)
        zigbee.0	2020-12-18 09:14:23.864	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55)
        zigbee.0	2020-12-18 09:14:23.864	error	(3960) TypeError: Cannot read property 'getEntries' of null
        zigbee.0	2020-12-18 09:14:23.858	error	(3960) unhandled promise rejection: Cannot read property 'getEntries' of null
        Unhandled	2020-12-18 09:14:23.857	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0	2020-12-18 09:14:23.855	info	(3960) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0	2020-12-18 09:14:23.853	info	(3960) terminating
        zigbee.0	2020-12-18 09:14:23.851	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:308:33))
        zigbee.0	2020-12-18 09:14:23.851	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
        zigbee.0	2020-12-18 09:14:23.851	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
        zigbee.0	2020-12-18 09:14:23.851	error	at new Promise (<anonymous>)
        zigbee.0	2020-12-18 09:14:23.851	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
        zigbee.0	2020-12-18 09:14:23.851	error	at Generator.next (<anonymous>)
        zigbee.0	2020-12-18 09:14:23.851	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
        zigbee.0	2020-12-18 09:14:23.851	error	at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
        zigbee.0	2020-12-18 09:14:23.851	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
        zigbee.0	2020-12-18 09:14:23.851	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
        zigbee.0	2020-12-18 09:14:23.851	error	(3960) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
        zigbee.0	2020-12-18 09:14:23.846	info	(3960) Zigbee: disabling joining new devices.
        zigbee.0	2020-12-18 09:14:23.837	info	(3960) cleaned everything up...
        zigbee.0	2020-12-18 09:14:23.834	info	(3960) Got terminate signal TERMINATE_YOURSELF
        host.raspberrypi	2020-12-18 09:14:23.827	info	stopInstance system.adapter.zigbee.0 send kill signal
        host.raspberrypi	2020-12-18 09:14:23.825	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @puls200
        Zu deconz:
        • stimmt die konfigurierte IP ?
        • stimmt der konfigurierte port ?
        • läuft der deconz service (sudo systemctl status deconz / sudo sytemctl status deconz-gui) - einer der beiden muss laufen
        • hast du einen neuen API Key erstellen lassen (das ist nach Restore auf anderer Hardware üblich)
        Zu iobroker.zigbee:
        • bitte den Adapter auf debug stellen
        • erneut starten
        • log posten.
        A.
        • P Offline
          puls200
          Update:
          1. Conbee II:
          • Conbee ist nun grün... nach der Erstellung eines neuen API Keys konnte ich den Stick verbinden.
          • leider erkennt er keinen Netzwerkteilnehmer, die ich zuvor alle bereits abgelernt hatte
            --> muss ich das erneut machen oder gibt es eine Lösung dazu?
          1. CC2531:
          • bin ich noch nicht weiter...
          AsgothianA 2 Antworten Letzte Antwort
          • P puls200
            Update:
            1. Conbee II:
            1. CC2531:
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @puls200 Wenn du die Deconz Software neu installiert hast musst du das hoffentlich vorhandene Backup über die Phoscon Software wieder einspielen. Wenn du keins hast musst du alles neu anlernen.
            A.
            Wichtig - dabei kann nicht garantiert werden das die Aktoren und Sensoren identische Nummern bekommen. Bei Verwendung des deconz Adapters 1.3.x musst du also im Nachgang ALLE Skripte / Aliasdatenpunkte / History Einstellungen verifizieren !
            • P puls200
              Update:
              1. Conbee II:
              1. CC2531:
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @puls200 sagte in Zigbee Adapter nach ioBroker-Import immer gelb:
              CC2531:
              Du hast auch noch kein Log des Startes des Adapters im Debug gepostet.
              A.
              • P Offline
                puls200
                schrieb am zuletzt editiert von puls200
                1. Conbee:
                • OK, dann muss ich wohl alles neu anlernen... habe natürlich KEIN Backup der Deconz-Software gemacht. Grrrrr......😤
                • dennoch weiss ich nun, was ich in Bezug auf den Conbee noch machen muss! Vielen Dank schonmal...
                1. CC2531:
                • Log habe ich doch oben gepostet... oder welcher Log ist gemeint?
                Gruss
                Puls
                • AsgothianA Asgothian
                  @puls200
                  Zu deconz:
                  Zu iobroker.zigbee:
                  • erneut starten
                  • log posten.
                  A.
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @puls200 Ich hatte um folgendes Gebeten:
                  @Asgothian sagte in Zigbee Adapter nach ioBroker-Import immer gelb:
                  Zu iobroker.zigbee:
                  • erneut starten
                  • log posten.
                  A.
                  A.
                    Zu iobroker.zigbee:
                    • erneut starten
                    • log posten.
                    A.
                    A.
                    puls200
                    @Asgothian Entschuldige.... stimmt, hatte ich vergessen...
                    Ich hatte vergessen zu sagen, dass ich den Conbee-Stick mit dem Deconz-Adapter verwende und den CC2531-Stick mit dem Zigbee-Adapter. Wie stelle ich den Zigbee-Adapter auf Debug?
                    • P Offline
                      puls200
                      Habe es geschafft!
                      Der COM-Anschluss war der Falsche!!! Ich hatte ihn immer auf ... ACM0... nach Umstellung auf ...ACM1 hat es funktioniert und er hat sofort alle Teilnehmer erkannt.
                      Sorry für den Aufwand, aber vielen Dank für Eure Hilfe!
                      Gruss
                      Puls
