  4. Zigbee Adapter nach ioBroker-Import immer gelb
cc2531conbeeimportexportneuinstallation
19 Beiträge 3 Kommentatoren 924 Aufrufe 3 Beobachtet
  • P Offline
    puls200
    schrieb am zuletzt editiert von puls200
    Und das vom CC2531:
    zigbee.0	2020-12-18 09:14:28.753	info	(4393) Starting Zigbee npm ...
    zigbee.0	2020-12-18 09:14:28.646	info	(4393) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.1.6
    host.raspberrypi	2020-12-18 09:14:26.867	info	instance system.adapter.zigbee.0 started with pid 4393
    host.raspberrypi	2020-12-18 09:14:24.381	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zigbee.0	2020-12-18 09:14:23.864	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
    zigbee.0	2020-12-18 09:14:23.864	error	at Zigbee.emit (events.js:314:20)
    zigbee.0	2020-12-18 09:14:23.864	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:450:41)
    zigbee.0	2020-12-18 09:14:23.864	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:304:20)
    zigbee.0	2020-12-18 09:14:23.864	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:187:42)
    zigbee.0	2020-12-18 09:14:23.864	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:120:43)
    zigbee.0	2020-12-18 09:14:23.864	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:201:49)
    zigbee.0	2020-12-18 09:14:23.864	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:252:31)
    zigbee.0	2020-12-18 09:14:23.864	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:236:16)
    zigbee.0	2020-12-18 09:14:23.864	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55)
    zigbee.0	2020-12-18 09:14:23.864	error	(3960) TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-12-18 09:14:23.858	error	(3960) unhandled promise rejection: Cannot read property 'getEntries' of null
    Unhandled	2020-12-18 09:14:23.857	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2020-12-18 09:14:23.855	info	(3960) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2020-12-18 09:14:23.853	info	(3960) terminating
    zigbee.0	2020-12-18 09:14:23.851	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:308:33))
    zigbee.0	2020-12-18 09:14:23.851	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
    zigbee.0	2020-12-18 09:14:23.851	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
    zigbee.0	2020-12-18 09:14:23.851	error	at new Promise (<anonymous>)
    zigbee.0	2020-12-18 09:14:23.851	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
    zigbee.0	2020-12-18 09:14:23.851	error	at Generator.next (<anonymous>)
    zigbee.0	2020-12-18 09:14:23.851	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
    zigbee.0	2020-12-18 09:14:23.851	error	at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
    zigbee.0	2020-12-18 09:14:23.851	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
    zigbee.0	2020-12-18 09:14:23.851	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
    zigbee.0	2020-12-18 09:14:23.851	error	(3960) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-12-18 09:14:23.846	info	(3960) Zigbee: disabling joining new devices.
    zigbee.0	2020-12-18 09:14:23.837	info	(3960) cleaned everything up...
    zigbee.0	2020-12-18 09:14:23.834	info	(3960) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi	2020-12-18 09:14:23.827	info	stopInstance system.adapter.zigbee.0 send kill signal
    host.raspberrypi	2020-12-18 09:14:23.825	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    J AsgothianA 2 Antworten Letzte Antwort
    • P puls200
      Und das vom CC2531:
      Jan1
      @puls200
      Das packen wir jetzt noch schön in Code Tags, sonst kann das keiner lesen ;)
      • P Offline
        puls200
        Wie geht das? :-(
        • P puls200
          Wie geht das? :-(
          Jan1
          @puls200
          Beim Posten dass 5. Symbol von links oben ;)
          • J Jan1
            @puls200
            Zum Restoren brauchst das Zigbee Backup eigentlich gar nicht, sollte eh alles im IOBrker BAckup drin sein. Dein eigentliches Problem wird nun wohl eher die USB Zurodnung sein. Schau mal wo die Sticks erkannt werden und ob das noch mit der Konfiguration des Adapter übereinstimmt. Wenn ja versuch mal Geräte zu pairen.
            Wegen Node mal die Ausgabe davon posten:
            nodejs -v && node -v && npm -v && which nodejs && which node && which npm
            puls200
            @Jan1 said in Zigbee Adapter nach ioBroker-Import immer gelb:
            Antwort war:
            v12.20.0
            v12.20.0
            6.14.8
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            • P puls200
              Antwort war:
              v12.20.0
              v12.20.0
              6.14.8
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              Jan1
              @puls200
              So Node passt schon mal und war nur zur Sicherheit mal abgefragt.
              Editiere bitte noch Deine Posts oben, Du weißt ja jetzt wie das mit den Code Tags funktioniert :)
              P 1 Antwort Letzte Antwort
              • J Jan1
                @puls200
                puls200
                @Jan1 : habe ich meines Erachtens gemacht...
                • P puls200
                  Und das vom CC2531:
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @puls200
                  Zu deconz:
                  • stimmt die konfigurierte IP ?
                  • stimmt der konfigurierte port ?
                  • läuft der deconz service (sudo systemctl status deconz / sudo sytemctl status deconz-gui) - einer der beiden muss laufen
                  • hast du einen neuen API Key erstellen lassen (das ist nach Restore auf anderer Hardware üblich)
                  Zu iobroker.zigbee:
                  • bitte den Adapter auf debug stellen
                  • erneut starten
                  • log posten.
                  A.
                  • P Offline
                    puls200
                    Update:
                    1. Conbee II:
                    • Conbee ist nun grün... nach der Erstellung eines neuen API Keys konnte ich den Stick verbinden.
                    • leider erkennt er keinen Netzwerkteilnehmer, die ich zuvor alle bereits abgelernt hatte
                      --> muss ich das erneut machen oder gibt es eine Lösung dazu?
                    1. CC2531:
                    • bin ich noch nicht weiter...
                    • P puls200
                      Update:
                      1. Conbee II:
                      1. CC2531:
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @puls200 Wenn du die Deconz Software neu installiert hast musst du das hoffentlich vorhandene Backup über die Phoscon Software wieder einspielen. Wenn du keins hast musst du alles neu anlernen.
                      A.
                      Wichtig - dabei kann nicht garantiert werden das die Aktoren und Sensoren identische Nummern bekommen. Bei Verwendung des deconz Adapters 1.3.x musst du also im Nachgang ALLE Skripte / Aliasdatenpunkte / History Einstellungen verifizieren !
                      • P puls200
                        Update:
                        1. Conbee II:
                        1. CC2531:
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @puls200 sagte in Zigbee Adapter nach ioBroker-Import immer gelb:
                        CC2531:
                        Du hast auch noch kein Log des Startes des Adapters im Debug gepostet.
                        A.
                        • P Offline
                          puls200
                          1. Conbee:
                          • OK, dann muss ich wohl alles neu anlernen... habe natürlich KEIN Backup der Deconz-Software gemacht. Grrrrr......😤
                          • dennoch weiss ich nun, was ich in Bezug auf den Conbee noch machen muss! Vielen Dank schonmal...
                          1. CC2531:
                          • Log habe ich doch oben gepostet... oder welcher Log ist gemeint?
                          Gruss
                          Puls
                          • AsgothianA Asgothian
                            @puls200
                            Zu deconz:
                            Zu iobroker.zigbee:
                            • erneut starten
                            • log posten.
                            A.
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @puls200 Ich hatte um folgendes Gebeten:
                            @Asgothian sagte in Zigbee Adapter nach ioBroker-Import immer gelb:
                            Zu iobroker.zigbee:
                            • erneut starten
                            • log posten.
                            A.
                            A.
                              Zu iobroker.zigbee:
                              • erneut starten
                              • log posten.
                              A.
                              A.
                              puls200
                              @Asgothian Entschuldige.... stimmt, hatte ich vergessen...
                              Ich hatte vergessen zu sagen, dass ich den Conbee-Stick mit dem Deconz-Adapter verwende und den CC2531-Stick mit dem Zigbee-Adapter. Wie stelle ich den Zigbee-Adapter auf Debug?
                              • P Offline
                                puls200
                                Habe es geschafft!
                                Der COM-Anschluss war der Falsche!!! Ich hatte ihn immer auf ... ACM0... nach Umstellung auf ...ACM1 hat es funktioniert und er hat sofort alle Teilnehmer erkannt.
                                Sorry für den Aufwand, aber vielen Dank für Eure Hilfe!
                                Gruss
                                Puls
