  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.4k Aufrufe 35 Beobachtet
  • T TheAriba
    @Jey-Cee der TF100L lässt sich nicht einlernen. Ist in der Liste unter Gerät hinzufügen auszuwählen. Starte anschließend teachin mit einem Taster und es wird aber kein Objekt angelegt.
    enocean.0	2020-12-10 15:16:30.692	debug	(22792) Message for ID 05846863 has been received.
    enocean.0	2020-12-10 15:16:30.689	debug	(22792) 55000707017ad509058468630100ffffffff4700
    enocean.0	2020-12-10 15:16:23.139	info	(22792) state enocean.0.gateway.teachin deleted
    enocean.0	2020-12-10 15:16:23.130	info	(22792) Teachin mode de-activated
    enocean.0	2020-12-10 15:16:08.213	debug	(22792) 55000707017ad509058492cb0000ffffffff5000
    enocean.0	2020-12-10 15:15:53.496	debug	(22792) 55000d0701fdd100d0ff0000041405936c5e0000ffffffff3a00
    enocean.0	2020-12-10 15:15:52.744	debug	(22792) 55000707017af600fef5796b2000ffffffff3d00
    enocean.0	2020-12-10 15:15:50.857	debug	(22792) 55000707017af67005936c5e3000ffffffff2b00
    enocean.0	2020-12-10 15:15:50.585	debug	(22792) 55000707017af67005936c5e3000ffffffff3700
    enocean.0	2020-12-10 15:15:50.537	debug	(22792) 55000707017af630fef5796b3000ffffffff3d00
    enocean.0	2020-12-10 15:15:50.329	debug	(22792) 55000707017af600fef5796b2000ffffffff3d00
    enocean.0	2020-12-10 15:15:50.169	debug	(22792) 55000707017af630fef5796b3000ffffffff3d00
    enocean.0	2020-12-10 15:15:50.025	debug	(22792) 55000707017af67005936c5e3000ffffffff3a00
    enocean.0	2020-12-10 15:15:49.913	debug	(22792) 55000707017af600fef5796b2000ffffffff3d00
    enocean.0	2020-12-10 15:15:49.753	debug	(22792) 55000707017af630fef5796b3000ffffffff3d00
    enocean.0	2020-12-10 15:15:49.705	debug	(22792) 55000707017af65005936c5e3000ffffffff3700
    enocean.0	2020-12-10 15:15:49.529	debug	(22792) 55000707017af600fef5796b2000ffffffff3d00
    enocean.0	2020-12-10 15:15:49.337	debug	(22792) 55000707017af630fef5796b3000ffffffff4000
    enocean.0	2020-12-10 15:15:49.177	debug	(22792) 55000707017af67005936c5e3100ffffffff4900
    enocean.0	2020-12-10 15:15:49.081	debug	(22792) 55000707017af600fef5796b2000ffffffff3d00
    enocean.0	2020-12-10 15:15:48.905	debug	(22792) 55000707017af630fef5796b3000ffffffff4100
    enocean.0	2020-12-10 15:15:41.306	debug	(22792) 55000707017ad5090584925c0100ffffffff4700
    enocean.0	2020-12-10 15:15:38.764	debug	(22792) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-10 15:15:38.761	debug	(22792) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-10 15:15:38.760	debug	(22792) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
    enocean.0	2020-12-10 15:15:38.759	info	(22792) ["/dev/ttyAMA0","/dev/ttyUSB0"]
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    #310
    @EnoceanEltako ok hab den Fehler gefunden und gefixt.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    • Jey CeeJ Jey Cee
      @pgBroker Dann installier den Adaptr mal neu von Github, der hat die letzten Tage einige Updates bekommen auch wenn die Version die gleiche geblieben ist.
      pgBroker
      schrieb am zuletzt editiert von pgBroker
      #311
      @Jey-Cee schon besser. :-)
      Gerät ist verbunden und es wurde ein kompletter Baum mit Datenpunkten unter der ID des Sensors angelegt. Unter anderem auch einer mit Namen ILL, der vermutlich den Helligkeitswert enthalten soll. Allerdings hat der keinen Wert.
      Im Log steht:
      (22659) Object enocean.0.ID is invalid: obj.type has to exist
      (22659) This object will not be created in future versions. Please report this to the developer.
      Die EEP schaut für mich komisch aus: TF-13-10
      Habe eben noch einen weiteren FAH60B hinzugefügt. Gleiches Ergebnis, gleiche Warnung im Log.
      P 1 Antwort Letzte Antwort
      • T TheAriba
        @mustang darf ich fragen wie du sie steuerst? Hast du ein Skript welches dir die Zeiten in Prozent umrechnet?
        mustang
        schrieb am zuletzt editiert von mustang
        #312
        @EnoceanEltako
        Nein, das nicht. Momentan brauche ich noch keine Steuerung um sie nur teilweise zu fahren. Ich steuere per Blocklyscript (ist noch nicht sicher, das alles so wie gedacht funktioniert) nach verschiedenen Bedingungen immer komplett auf oder zu. Das teilweise fahren mache ich dann automatisiert bei einigen Rollläden, wenn ich einen Außenhelligkeitssensor gekauft habe. Das ist eher für die helleren Monate interessant. Außerdem muß jetzt erst noch diverse Aktoren für die betreffenden Rollläden kaufen, welche dann teilweise gesteuert werden sollen.
        Für das Handy ist dann noch in VIS eine manuelle Steuerung jedes einzelnen Rollladen eingebaut.
        Habe gerade noch mal einen an sich nicht mehr verfügbaren Eltako FAH65S-wg Helligkeitssensor bestellt. Sollte genauso funktionieren wie der FAH60(B).
        • Jey CeeJ Jey Cee
          @mane444 Die Reihenfolge der EEPs im Objekt vom FL62NP ist fasch oder es Fehlt eine EEP. Das ist leider noch ein Bug.
          Die hier in dieser Reihenfolge müssen da drin sein:
          "TF-13-11",
          "TF-14-02"
          Das Objekt kannst du im Objekt tab mit dem Stift ganz rechts öffnen und dann Raw bearbeiten.
          mane444
          #313
          @Jey-Cee Hi, zweite EEP eingetragen , eingelernt läuft. Danke
          • Jey CeeJ Jey Cee
            TheAriba
            #314
            @Jey-Cee TF100L funktionieren nun auch. TOP!
            • Jey CeeJ Jey Cee
              "TF-13-11",
              "TF-14-02"
              mane444
              schrieb am zuletzt editiert von mane444
              #315
              @Jey-Cee Hi, hab gerade nochmal Tests mit der neusten Version vom Github gemacht.
              Die Geräte FL62NP-230V , FUD61NPN-230V und FT55 sind eingelernt und laufen ohne Probleme.
              Den einzigen Unterschied zur Steuerung mit FHEM der Dimmer dimmt langsamer.
              Super Arbeit.
              • M mustang
                @EnoceanEltako
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                #316
                @mustang sagte in Test Adapter EnOcean (2) v0.2.x:
                Hast du mir da Dokummente oder Links? Ich finde nur den FAH65S und der Untescheidet sich vom FAH60.
                • P pgBroker
                  Im Log steht:
                  pgBroker
                  #317
                  @Jey-Cee kannst du damit was anfangen?
                  • P pgBroker
                    Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    #318
                    @pgBroker ehrlich gesagt nicht. Kannst du mir einen Screenshot vom Ausgeklappten Baum machen.
                    • Jey CeeJ Jey Cee
                      mustang
                      #319
                      @Jey-Cee
                      Die Bedienungsanleitung ist leider nicht sehr aussagekräftig. Nur in der allgemeinen Telegrammbeschreibung findet sich das hier:
                      FAH65S, FIH65S (EEP A5-06-01 EXCEPTIONS BY ELTAKO)
                      ORG = 0x07
                      Data_byte3 = Helligkeit 0..100 lux (0..100)
                      (nur gültig, wenn DB2 = 0x00)
                      Data_byte2 = Helligkeit 300..30.000 lux (0..255)
                      Data_byte1 = -
                      Data_byte0 = 0x0F
                      Lerntelegramm: 0x18080D87
                      Der soll übrigens heute geliefert werden.
                      • M mustang
                        @Jey-Cee
                        ORG = 0x07
                        Data_byte1 = -
                        Data_byte0 = 0x0F
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #320
                        @mustang ok das ist was ich auch gefunden hab, aber keine Garantie das es wirklich der selbe ist den du hast. Das Anhängsel -wg kann einen großen Unterschied machen, das hab ich bei den FTKBs gesehen.
                        Ich bau den FAH65S mal so ein, dann kannst du ihn Testen.
                        M 3 Antworten Letzte Antwort
                        • Jey CeeJ Jey Cee
                          mustang
                          #321
                          @Jey-Cee
                          ok danke. Der muß jetzt erst mal aufladen...
                          Ich berichte dann.
                          • Jey CeeJ Jey Cee
                            mustang
                            #322
                            @Jey-Cee
                            So - eine Stunde laden muß erstmal reichen. Ist der schon im Adapter auf github? Habe den Adapter aktualisiert - da taucht er bei mir noch nicht auf.
                            Habe jetzt mit dem FAH60B installiert, und was soll ich sagen - wie es aussieht funktioniert er. Das Log:
                            enocean.0	2020-12-12 15:20:20.155	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:20:20.151	debug	(151964) 55000a0701eba57101000f019723730000ffffffff4900
                            enocean.0	2020-12-12 15:18:50.075	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:18:50.074	debug	(151964) 55000a0701eba57301000f019723730000ffffffff4900
                            enocean.0	2020-12-12 15:18:40.064	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:18:40.062	debug	(151964) 55000a0701eba58525000f019723730000ffffffff5300
                            enocean.0	2020-12-12 15:18:20.056	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:18:20.056	debug	(151964) 55000a0701eba57c01000f019723730000ffffffff4f00
                            enocean.0	2020-12-12 15:18:10.044	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:18:10.042	debug	(151964) 55000a0701eba5781d000f019723730000ffffffff5500
                            enocean.0	2020-12-12 15:18:00.047	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:18:00.046	debug	(151964) 55000a0701eba57714000f019723730000ffffffff4c00
                            enocean.0	2020-12-12 15:16:58.871	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:16:58.870	debug	(151964) 55000a0701eba518080d87019723730000ffffffff5000
                            enocean.0	2020-12-12 15:16:19.563	debug	(151964) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
                            enocean.0	2020-12-12 15:16:19.559	info	(151964) Create objects for TF-13-10 from ELTAKO with id: 01972373
                            enocean.0	2020-12-12 15:16:00.864	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:16:00.861	debug	(151964) 55000a0701eba518080d87019723730000ffffffff4f00
                            enocean.0	2020-12-12 15:15:32.493	debug	(151964) Message for ID 01972373 has been received.
                            enocean.0	2020-12-12 15:15:32.489	debug	(151964) 55000a0701eba57001000f019723730000ffffffff4900
                            Ist ja momentan recht dunkel draußen, jedoch reagiert er auch schon auf meine Schreibtischlampe.
                            Mir scheint es allerdings, als ob die Werte noch zu niedrig interpretiert werden...(Unterschied zum FAH60?)
                            • M mane444
                              Super Arbeit.
                              mane444
                              #323
                              @mane444 Nachtrag:
                              Ich hab mich leider zu früh gefreut. Ich wollte nun meine anderen zwei FUD61NPN-230V anlernen, leider ohne Erfolg.
                              Der funktionierende Dimmaktor (Fertigungswoche 10/19) sendet ein Telegramm sobald ich den auf "LRN" stelle. Die anderen beiden (Fertigungswoche 08/19) nicht. Scheinbar hat hier die Fa. Eltako auch eine Änderung gemacht.
                              Ich hab dann mal versucht die beiden mit der Einstellung "FUD61NPN-230V (< 46/17)" an zu lernen. Das klappt soweit aber hier reagieren alle gleichzeitig sobald ein Befehl vom IoBroker gesendet wird.
                              • M mane444
                                @mane444 Nachtrag:
                                Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                #324
                                @mane444 danke für die Rückmeldung. Hab den Fehler gefunden und behoben, die neue Version ist auf Github verfügbar.
                                Bevor du sie installierst musst du noch deine Aktoren Zurücksetzen oder ioBroker aus dem Speicher löschen.
                                Einzelne eingelernte Sensoren löschen wie bei
                                dem Einlernen, nur den oberen Drehschalter
                                auf CLR anstatt LRN stellen und den Sensor
                                betätigen. Die zuvor aufgeregt blinkende LED
                                erlischt.
                                Ich denke es spielt keine Rolle was für einen Befehl du an den Aktor sendest.
                                Danach löscht du die Objekte der beiden Aktoren, anschließend Installierst du die neue Version und lernst die Aktoren erneut an.
                                • Jey CeeJ Jey Cee
                                  mustang
                                  #325
                                  @Jey-Cee
                                  Nach gestrigem Update auf Version 0.3.0 ist der FAH65S ist jetzt korrekt eingerichtet, jedoch stimmt die Anzeige der Werte noch nicht. Wenn vom Sensor die folgenden Telegramme kommen werden die Werte so angezeigt:
                                  enocean.0	2020-12-15 11:24:06.956	debug	(427623) Message for ID 01972373 has been received.
                                  enocean.0	2020-12-15 11:24:06.950	debug	(427623) 55000a0701eba58511000f019723730000ffffffff5500
                                  enocean.0	2020-12-15 11:22:26.886	debug	(427623) Message for ID 01972373 has been received.
                                  enocean.0	2020-12-15 11:22:26.879	debug	(427623) 55000a0701eba58512000f019723730000ffffffff5500
                                  Vorausgesetzt ich interpretiere das jetzt richtig ist DB2=0x12 entspricht in der jetzigen Anzeige 22,50 und bei DB2=0x11 Anzeige 21,25.
                                  Ich verstehe die Vorgabe von Eltako so:
                                  DB2 hat einen Bereich von 300 bis 30000 lux bei Hex-Werten von 01 bis FF (bei 00 wird nur DB3 ausgewertet). Bedeutet rechnerisch für DB3=0x12 30000lx dividiert durch 255 (dez) (maximal Wert FF) und dann multipliziert mit 18 (dez) gleich 2117 und bei gleicher Rechnung für DB2=0x11 (17 dez) 30000/255*17 gleich 2000 gerundet, alles ohne Kommastellen (macht bei den Werten auch keinen Sinn).
                                  DB3 hat analog dazu den Wertebereich von 0 bis 100lx, also hex 00 bis 64 und eben nur wenn DB3=00.
                                  Ich habe die DB2-Werte mal mit einer App auf meinem Handy, welche mir die Lichtsensorwerte in Lux ausgibt, abgeglichen und es stimmt dann schon ganz grob mit meiner Rechnung.
                                  • M mustang
                                    @Jey-Cee
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #326
                                    @mustang Installier mal neu, der Multiplikator war falsch.
                                    M 2 Antworten Letzte Antwort
                                    • Jey CeeJ Jey Cee
                                      mustang
                                      #327
                                      @Jey-Cee
                                      Ahh - jetzt sieht es besser aus, vielen Dank 💪 ☺
                                      • Jey CeeJ Jey Cee
                                        mustang
                                        #328
                                        @Jey-Cee
                                        die Werte vom DB3 werden nicht korrekt angezeigt.
                                        enocean.0	2020-12-15 12:47:00.761	debug	(509836) Message for ID 01972373 has been received.
                                        enocean.0	2020-12-15 12:47:00.759	debug	(509836) 55000a0701eba52300000f019723730000ffffffff5300
                                        enocean.0	2020-12-15 12:45:50.710	debug	(509836) Message for ID 01972373 has been received.
                                        enocean.0	2020-12-15 12:45:50.707	debug	(509836) 55000a0701eba55b00000f019723730000ffffffff5200
                                        enocean.0	2020-12-15 12:44:10.622	debug	(509836) Message for ID 01972373 has been received.
                                        enocean.0	2020-12-15 12:44:10.619	debug	(509836) 55000a0701eba56400000f019723730000ffffffff5200
                                        enocean.0	2020-12-15 12:42:40.531	debug	(509836) Message for ID 01972373 has been received.
                                        enocean.0	2020-12-15 12:42:40.529	debug	(509836) 55000a0701eba55b00000f019723730000ffffffff4f00
                                        enocean.0	2020-12-15 12:42:30.534	debug	(509836) Message for ID 01972373 has been received.
                                        enocean.0	2020-12-15 12:42:30.532	debug	(509836) 55000a0701eba52a00000f019723730000ffffffff5200
                                        bei den o.a. Werten wird immer 0 lx angezeigt. Ich hab vorhin einen Wert im 200er Bereich gesehen - den darf es doch gar nicht geben - oder? DB3 geht doch nur bis 100.
                                        • M mustang
                                          @Jey-Cee
                                          Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          #329
                                          Richtig den darf es nicht geben.
                                          Rein Formal sieht alles richtig aus, der Wert wird 1:1 in das Objekt geschrieben. Warum da jetzt immer 0 lx kommt kann ich mir nicht erklären.
                                          Kannst du das bitte mal weiter beobachten, besonders würde mich ein telegram interessieren wenn ein wert zwischen 100 und 300 auftaucht.
