  4. Twinkly - Basisfunktionen mit ioBroker steuern
    apollon77A
69 Beiträge 8 Kommentatoren 15.2k Aufrufe 9 Beobachtet
  • W W0RSCHD
    @patrickbs96
    ich bekomme folgende Fehlermeldungen im Log
    javascript.0	2020-12-03 20:55:29.616	error	(1036) script.js.Schaltungen.Twinkly: setForeignState: undefined is not a valid state value
    javascript.0	2020-12-03 20:55:29.616	warn	(1036) at Pipe.<anonymous> (net.js:675:12)
    javascript.0	2020-12-03 20:55:29.616	warn	(1036) at Socket.EventEmitter.emit (domain.js:483:12)
    javascript.0	2020-12-03 20:55:29.615	warn	(1036) at Socket.emit (events.js:314:20)
    javascript.0	2020-12-03 20:55:29.615	warn	(1036) at Socket.<anonymous> (internal/child_process.js:444:11)
    javascript.0	2020-12-03 20:55:29.615	warn	(1036) at maybeClose (internal/child_process.js:1022:16)
    javascript.0	2020-12-03 20:55:29.614	warn	(1036) at ChildProcess.EventEmitter.emit (domain.js:483:12)
    javascript.0	2020-12-03 20:55:29.614	warn	(1036) at ChildProcess.emit (events.js:314:20)
    javascript.0	2020-12-03 20:55:29.614	warn	(1036) at ChildProcess.exithandler (child_process.js:315:5)
    javascript.0	2020-12-03 20:55:29.613	warn	(1036) at script.js.Schaltungen.Twinkly:10:5
    javascript.0	2020-12-03 20:55:29.613	warn	(1036) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1411:20)
    javascript.0	2020-12-03 20:55:29.611	warn	(1036) You are assigning a undefined to the state "0_userdata.0.devices.twinkly1.token" which expects a string. Please fix your code to use a string or change the state type to undefined. This warning
    javascript.0	2020-12-03 20:55:29.610	info	(1036) script.js.Schaltungen.Twinkly: Starte Tokenerstellung
    javascript.0	2020-12-03 20:55:29.600	error	(1036) script.js.Schaltungen.Twinkly: setForeignState: undefined is not a valid state value
    Direkt nach erstellen des Skriptes hat alles funktioniert, jetzt wo der Token abgelaufen ist geht nichts mehr.
    Wenn ich den Befehl zum erstellen des Tokens manuell per Telnet eingebe klappt das einwandfrei.
    Was mach ich falsch?
    siggi85S
    siggi85S
    siggi85
    @W0RSCHD Ich würde dir auch das Skript von @patrickbs96 empfehlen.
    Sobald es bei mir ohne Fehler läuft, poste ich den Verweis und eine klare Empfehlung darauf auch in meinem ersten Post. :)
    • siggi85S siggi85
      @patrickbs96 Anbei der Logauszug aufgrund der neusten Github Version.
      Fehlermeldungen beim Pollintervall:
      javascript.1	2020-12-04 08:04:00.535	error	(19045) script.js.05_Helper.Twinkly_Test: [Twinkly.Festoon.on] Error: HTTP Error 401
      javascript.1	2020-12-04 08:04:00.532	error	(19045) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.1	2020-12-04 08:04:00.532	error	(19045) at runMicrotasks (<anonymous>)
      javascript.1	2020-12-04 08:04:00.532	error	(19045) at script.js.05_Helper.Twinkly_Test:324:27
      javascript.1	2020-12-04 08:04:00.531	error	(19045) script.js.05_Helper.Twinkly_Test: Error: Error: <POST /verify> - 1102 (Error), Data: {"challenge-response":"b23cd3aff1e30c76891c60dc199485f1a28fd2d6"}, Headers: {"X-Auth-Token":"kyI6bBLT3FY="}
      javascript.1	2020-12-04 08:04:00.326	error	(19045) script.js.05_Helper.Twinkly_Test: [Twinkly.Lichterkette.on] Error: HTTP Error 401
      javascript.1	2020-12-04 08:04:00.322	error	(19045) script.js.05_Helper.Twinkly_Test: [Twinkly.Lichterkette.on] Error: HTTP Error 401
      javascript.1	2020-12-04 08:04:00.319	error	(19045) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.1	2020-12-04 08:04:00.319	error	(19045) at runMicrotasks (<anonymous>)
      javascript.1	2020-12-04 08:04:00.318	error	(19045) at script.js.05_Helper.Twinkly_Test:324:27
      javascript.1	2020-12-04 08:04:00.317	error	(19045) script.js.05_Helper.Twinkly_Test: Error: Error: <POST /verify> - 1102 (Error), Data: {"challenge-response":"4ecffc0c669796ea843c4ef4dc7d2a33cf081d92"}, Headers: {"X-Auth-Token":"49O85fx9Vb4="}
      Fehlermeldung nach anlegen des neuen Skriptes mit Test An/Aus (was allerdings funktioniert hat).
      javascript.1	2020-12-04 08:02:47.343	error	(19045) script.js.05_Helper.Twinkly_Test: [Twinkly.Lichterkette.on] Error: HTTP Error 401
      javascript.1	2020-12-04 08:02:47.331	error	(19045) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.1	2020-12-04 08:02:47.331	error	(19045) at runMicrotasks (<anonymous>)
      javascript.1	2020-12-04 08:02:47.331	error	(19045) at script.js.05_Helper.Twinkly_Test:324:27
      javascript.1	2020-12-04 08:02:47.330	error	(19045) script.js.05_Helper.Twinkly_Test: Error: Error: <POST /verify> - 1102 (Error), Data: {"challenge-response":"4ecffc0c669796ea843c4ef4dc7d2a33cf081d92"}, Headers: {"X-Auth-Token":"LbN35KLgGC0="
      Der Vollständigkeit halber, meine Anpassungen der Settings.
      * Settings
      const PATH_ID = '0_userdata.0.devices.';
      const devices = {
         Lichterkette : {
             name           : 'Lichterkette',               // Name für ioBroker
             ipAdresse      : '192.168.1.241',               // IP-Adresse von der Twinkly-Lichterkette
             connectedState : 'ping.0.ioBroker.192_168_1_241' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
         Festoon : {
             name           : 'Festoon',               // Name für ioBroker
             ipAdresse      : '192.168.1.243',               // IP-Adresse von der Twinkly-Lichterkette
             connectedState : 'ping.0.ioBroker.192_168_1_243' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
      patrickbs96P
      patrickbs96P
      patrickbs96
      @siggi85 said in Twinkly - Basisfunktionen mit ioBroker steuern:
      Error: Error:
      So ich habe ein paar Anpassungen gemacht. Beim Verifizieren war noch ein kleiner Fehler drin, der bei mir aber nie aufgetreten ist :man-shrugging: Falls von Twinkly aus eine Fehlermeldung geschickt wird (code != 1000) erstelle ich eine Warnung im Log aber breche die Funktion nicht mehr ab. Falls es nur am ersten Fehler lag dann baue ich das Abbrechen später wieder ein :D
      Das Skript habe ich aktualisiert.
      siggi85S 1 Antwort Letzte Antwort
      • patrickbs96P patrickbs96
        Error: Error:
        siggi85S
        siggi85S
        siggi85
        @patrickbs96 Also vorher hat eigentlich alles funktioniert (an/aus, bri), hatte halt nur das Log voller Fehler. Jetzt ist das Log zumindest nur voller Warnings. :P
        javascript.1	2020-12-04 13:25:00.287	warn	(19045) script.js.05_Helper.Twinkly_Test: [POST.verify] 1102 (Error), Data: {"challenge-response":"b23cd3aff1e30c76891c60dc199485f1a28fd2d6"}, Headers: {"X-Auth-Token":"wuyiL1bNgz4="}, Body: {"code":1
        javascript.1	2020-12-04 13:25:00.068	warn	(19045) script.js.05_Helper.Twinkly_Test: [POST.verify] 1102 (Error), Data: {"challenge-response":"4ecffc0c669796ea843c4ef4dc7d2a33cf081d92"}, Headers: {"X-Auth-Token":"7zg0w+1S47A="}, Body: {"code":1
        javascript.1	2020-12-04 13:24:00.306	warn	(19045) script.js.05_Helper.Twinkly_Test: [POST.verify] 1102 (Error), Data: {"challenge-response":"b23cd3aff1e30c76891c60dc199485f1a28fd2d6"}, Headers: {"X-Auth-Token":"0fX2ONXNhW4="}, Body: {"code":1
        javascript.1	2020-12-04 13:24:00.061	warn	(19045) script.js.05_Helper.Twinkly_Test: [POST.verify] 1102 (Error), Data: {"challenge-response":"4ecffc0c669796ea843c4ef4dc7d2a33cf081d92"}, Headers: {"X-Auth-Token":"rvW9IkCWS3M="}, Body: {"code":1
        Ich habe bei meinen Tests aber bereits bemerkt, dass ich öfter mal einen neuen Token generieren musste, weil mein Twinkly Devices den aktuellen regelmäßig nicht mehr akzeptiert hat (daher auch der Token Counter aus meinem Skript). Keine Ahnung wieso das so ist?!
        patrickbs96P 1 Antwort Letzte Antwort
        • siggi85S siggi85
          patrickbs96P
          patrickbs96P
          patrickbs96
          schrieb am zuletzt editiert von patrickbs96
          @siggi85 Versuche es jetzt nochmal. Ich hatte noch einen Fehler in der Zeitermittlung ab wann der Token abgelaufen ist. Dadurch wurde jedesmal ein neuer Token generiert. Eventuell kommt die 1102 Fehlermeldung davon. Falls das nicht hilft blende ich die dann einfach aus. Scheint ja kein Fehler zu sein :-)
          EDIT: Ich habe gerade meine zweite Lichterkette angeschlossen und bekomme jetzt die gleiche Fehlermeldung wie du. Ich gehe jetzt mal davon aus, dass Twinkly die Challenge-Response nicht mag. Muss ich mir mal anschauen... Aber mit diesem Update nur alle 4 Stunden pro Gerät ;-)
          W 1 Antwort Letzte Antwort
            W
            W
            W0RSCHD
            @patrickbs96
            Ich hab die aktuelle Version des Scripts mal geladen und bin am testen, allerdings klappt da nix.
            Ich seh in den States zwar jetzt die Firmware Version usw. (Habe noch eine der alten Twinkly aus 2017),
            aber der Zustand ob sie an oder aus ist ändert sich nicht und ich kann auch nicht schalten damit, also ob ich auf true oder false setze an der Lichterkette passiert dann nichts.
            Hier mal ein Auszug aus dem Log:
            17:22:18.016	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607098913269,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607097243493}
            17:22:18.040	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.on] HTTP Error 401
            17:22:31.596	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607098943471,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607097243493}
            17:22:31.617	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.on] HTTP Error 401
            17:22:43.389	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607098943471,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607097243493}
            17:22:43.389	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.MyDevices.Twinkly.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            17:22:43.409	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.mode] HTTP Error 401
            17:22:43.425	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.bri] HTTP Error 401
            17:22:43.443	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.name] HTTP Error 401
            17:22:43.461	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.mqtt] HTTP Error 401
            17:22:43.486	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.timer] HTTP Error 401
            17:22:43.507	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.MyDevices.Twinkly.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"1786705\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            17:22:43.526	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.MyDevices.Twinkly.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            • W W0RSCHD
              @patrickbs96
              siggi85S
              siggi85S
              siggi85
              @W0RSCHD
              Deine Firmware ist auf 2.3.5. Ist das die neueste Version für deine Twinkly oder wird dir über die App ein Update angeboten?
              @patrickbs96
              Bei der neuen Version des Skriptes kam nur beim Start für jede Kette eine Fehlermeldung, seit dem alles ruhig. :)👍 Wahrscheinlich kommt jetzt alle 4 Stunden die Meldung, aber damit kann ich locker leben.
              Achja, auch externe Änderungen (bspw. wenn die Kette über die App an/aus geschaltet wird), wird jede volle Minute in ioBroker aktualisiert. 👍 Vielen Dank für deine Version des Skriptes!
              patrickbs96P W 2 Antworten Letzte Antwort
              • siggi85S siggi85
                @W0RSCHD
                @patrickbs96
                patrickbs96P
                patrickbs96P
                patrickbs96
                @siggi85 Ich habe diesbezüglich auch schon eine Lösung, habe nämlich den Verursacher gefunden :D Die Befehle werden nämlich doppelt abgeschickt und dann kam es zu Überschneidungen mit dem Token.
                Ich bekomme jetzt aber nach einer Weile die Meldung "Invalid Token" in Verbindung mit der "HTTP Error 401". Da es eine Weile dauert bis der Fehler auftritt kann ich noch nicht sagen wie lange ich dafür brauche...
                  siggi85S
                  siggi85S
                  siggi85
                  @patrickbs96 sagte in Twinkly - Basisfunktionen mit ioBroker steuern:
                  Jop, ich habe gerade geschaut und das mit dem "HTTP Error 401" ist mir gerade auch passiert. Musste das Skript neustarten. Mal schauen wie lange es jetzt läuft.
                  • siggi85S siggi85
                    patrickbs96P
                    patrickbs96P
                    patrickbs96
                    @siggi85 Ging dann doch schneller als gedacht. Ich habe es jetzt so ähnlich gelöst, wie du in deinem Skript. Seitdem kriege ich keine Fehlermeldungen mehr. Ich habe zusätzlich noch eine Konstante hinzugefügt um die Zeit für das Polling anzupassen :-)
                    • siggi85S siggi85
                      @W0RSCHD
                      @patrickbs96
                      W
                      W
                      W0RSCHD
                      @siggi85
                      Ja das ist die "neuste" für meine Lichterkette, also es wird in der App (App ist aktuell) auch kein Update angeboten. Wie gesagt die Kette ist schon etwas älter also noch die erste Version von Twinkly die es gab mit 225 LED´s.
                        siggi85S
                        siggi85S
                        siggi85
                        schrieb am zuletzt editiert von siggi85
                        @patrickbs96 Mh, durch die neue Version erhalte ich folgende Meldung und das Schalten funktioniert nicht mehr:
                        21:55:14.334	info	javascript.1 (19045) Start javascript script.js.05_Helper.Twinkly_Test
                        21:55:14.340	info	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: registered 0 subscriptions and 0 schedules
                        21:56:01.836	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Lichterkette.on] ReferenceError: logs is not defined
                        21:56:16.360	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.mode] TypeError: Cannot read property 'code' of undefined
                        21:56:16.375	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Lichterkette.mode] TypeError: Cannot read property 'code' of undefined
                        21:56:16.393	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.bri] TypeError: Cannot read property 'code' of undefined
                        21:56:16.405	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Lichterkette.bri] TypeError: Cannot read property 'code' of undefined
                        21:56:16.421	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.name] TypeError: Cannot read property 'code' of undefined
                        21:56:16.431	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Lichterkette.name] TypeError: Cannot read property 'code' of undefined
                        21:56:16.451	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.mqtt] TypeError: Cannot read property 'code' of undefined
                        21:56:16.461	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Lichterkette.mqtt] TypeError: Cannot read property 'code' of undefined
                        21:56:16.480	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.timer] TypeError: Cannot read property 'code' of undefined
                        21:56:16.494	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Lichterkette.timer] TypeError: Cannot read property 'code' of undefined
                        21:56:16.549	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.mode] TypeError: Cannot read property 'code' of undefined
                        21:56:16.580	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.bri] TypeError: Cannot read property 'code' of undefined
                        21:56:16.606	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.name] TypeError: Cannot read property 'code' of undefined
                        21:56:16.632	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.mqtt] TypeError: Cannot read property 'code' of undefined
                        21:56:16.656	error	javascript.1 (19045) script.js.05_Helper.Twinkly_Test: [Festoon.timer] TypeError: Cannot read property 'code' of undefined
                        EDIT: Das Polling wird minütlich durchgeführt, aber bringt halt die beschriebenen Fehlermeldungen.
                        • siggi85S siggi85
                          patrickbs96P
                          patrickbs96P
                          patrickbs96
                          @siggi85 Das das Steuern nicht mehr klappt war meine Schuld. Hatte eine Stelle übersehen, die ich ersetzen musste. Ich nutze meine eigene Logging-Komponente...
                          Könntest du das Skript noch einmal testen? Ich habe eine Prüfung ergänzt, vielleicht lag es daran.
                            siggi85S
                            siggi85S
                            siggi85
                            @patrickbs96 Logs und Funktionen sehen sehr gut aus! 👍 Ich werde weiter beobachten und noch eine Rückmeldung aus dem Dauerbetrieb gebe. Wenn das jetzt stabil läuft bin ich damit sehr zufrieden. :)
                            Es wäre natürlich mega, wenn man die jeweilige Szene über ein Attribut steuern könnte, allerdings gibt das die API aktuell leider nicht her. Da können wir wohl nur abwarten und hoffen, dass die API irgendwann offiziell und damit vollständig dokumentiert wird.
                            @W0RSCHD Also derjenige, der die inofizielle API dokumentiert hat, hat anscheinend auch ein Gerät der ersten Generation. Er scheint auch mit der gleichen Firmware getestet zu haben, die auf deinen Twinklys drauf ist. (Siehe hier)
                            Prinzipiell müsste es meiner Meinung nach bei dir also funktionieren.
                            Versuche mal bitte auf der Kommadozeile, was ich hier beschrieben habe und gebe Rückmeldung, ob das klappt.
                            W patrickbs96P 2 Antworten Letzte Antwort
                            • siggi85S siggi85
                              W
                              W
                              W0RSCHD
                              schrieb am zuletzt editiert von W0RSCHD
                              @siggi85
                              Ja habe die manuellen Befehle gerade alle getestet, kann damit an und ausschalten, das funktioniert
                              Hab die neuste Version aus dem GIT mal reinkopiert und gestartet und auch nochmal alle Objekte im JS Adapter gelöscht das sie neu angelegt werden.
                              Sieht dann so aus und es wird quasi nur details und Firmware ausgefüllt, welcher modus aktiv ist usw., das bleibt alles leer.
                              Ebenso ändert sich dann auch nichts wenn ich den modus von Hand schalte, dadurch geht sie auch nicht aus oder an.
                              Ich habe ehrlich gesagt aber auch keine Ahnung wo ich suchen soll da ich auch dem verbose Log aus dem Skript nix entnehmen kann warum es hakt oder wo es hängt dass es nicht geht.
                              11:35:33.352	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607164512257,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607157356830}
                              11:35:33.353	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
                              11:35:33.386	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.413	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.453	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.480	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.512	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.mode] HTTP Error 401, "Invalid Token."
                              11:35:33.531	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.552	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.589	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.611	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.640	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.bri] HTTP Error 401, "Invalid Token."
                              11:35:33.657	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.678	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.711	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.735	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.760	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.name] HTTP Error 401, "Invalid Token."
                              11:35:33.778	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.795	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.832	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.858	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.885	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.mqtt] HTTP Error 401, "Invalid Token."
                              11:35:33.902	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.919	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:33.964	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:33.984	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:34.002	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.timer] HTTP Error 401, "Invalid Token."
                              11:35:34.017	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.login] 1106 (undefined), Body: {"code":1106}
                              11:35:34.034	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {}, Headers: {}, Body: {"code":1102}
                              11:35:34.066	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"2913607\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
                              11:35:34.089	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
                              • siggi85S siggi85
                                patrickbs96P
                                patrickbs96P
                                patrickbs96
                                @siggi85 Das freut mich zu hören :-) Theoretisch wäre das ja durch MQTT möglich aber ich weiß nicht wie genau ich es konfigurieren muss. Ich hatte es gestern versucht aber es gab keine Verbindung...
                                @W0RSCHD So wie ich das bei meinen Tests festgestellt habe ist, dass Details und Firmware keinen Token benötigen um die Daten abzurufen. Deshalb funktionieren dies beiden auch noch. In deinem Fall sieht es so aus als schlägt die Anmeldung fehl... Ich habe das Logging mal erweitern vielleicht finden wir so den Grund, weshalb es bei dir nicht mit dem Skript klappt.
                                Setzte dafür
                                const EXTENDED_LOGGING = true;
                                siggi85S W 2 Antworten Letzte Antwort
                                  Setzte dafür
                                  siggi85S
                                  siggi85S
                                  siggi85
                                  Anders als in der API beschrieben, ist die MQTT Verbindung mittlerweile verschlüsselt. Hätte man das passende Zertifikat könnte man eine MQTT Instanz mit diesem Zertifikat und einem eigenen Port aufmachen. Ohne Zertifikat sieht das aber schlecht aus.
                                  Ich habe es bei meinen Tests auch nicht hinbekommen, die Verschlüsselung zu deaktivieren. Das wäre sonst die 2. Möglichkeit. :/
                                    Setzte dafür
                                    W
                                    W
                                    W0RSCHD
                                    @patrickbs96
                                    ok, habs mal geändert, hier mal das log dazu
                                    16:24:15.409	info	javascript.0 (11366) Stop script script.js.Schaltungen.Twinkly_JS
                                    16:24:17.614	info	javascript.0 (11366) Start javascript script.js.Schaltungen.Twinkly_JS
                                    16:24:17.662	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setTimeout(ms=2000)
                                    16:24:17.663	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: onStop(timeout=500)
                                    16:24:17.663	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: registered 0 subscriptions and 0 schedules
                                    16:24:17.674	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getObject(id=javascript.0.Weihnachtsbaum, enumName=undefined) => {"common":{"name":"Twinkly","role":"state","type":"mixed"},"native":{},"type":"channel","from":"system.adapter.javascript.0","user":"system.user.admin","ts":1607163615438,"_id":"javascript.0.Weihnachtsbaum","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                    16:24:17.675	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setObject(id=javascript.0.Weihnachtsbaum, obj={"common":{"name":"Twinkly","role":"state","type":"mixed"},"native":{},"type":"channel","from":"system.adapter.javascript.0","user":"system.user.admin","ts":1607163615438,"_id":"javascript.0.Weihnachtsbaum","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}})
                                    16:24:19.665	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: subscribe: {"pattern":{"id":{},"change":"ne","ack":false,"q":0},"name":"script.js.Schaltungen.Twinkly_JS"}
                                    16:24:19.669	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setInterval(ms=60000)
                                    16:25:19.673	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607181905606,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607157356830}
                                    16:25:19.677	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
                                    16:25:19.681	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <led/mode>
                                    16:25:19.682	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
                                    16:25:19.690	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] {"url":"http://192.168.178.175/xled/v1/login","body":{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="},"method":"POST","rejectUnauthorized":false,"timeout":3000,"json":true}
                                    16:25:19.810	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] response: {"statusCode":200,"body":{"code":1106},"headers":{"connection":"close","content-length":"13","content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.175","port":80,"hostname":"192.168.178.175","hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.175/xled/v1/login"},"method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                    16:25:19.811	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1106}
                                    16:25:19.822	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.mode] [Twinkly.POST.login] 1106 (Error - Login)
                                    16:25:19.823	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <led/out/brightness>
                                    16:25:19.824	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
                                    16:25:19.824	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] {"url":"http://192.168.178.175/xled/v1/login","body":{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="},"method":"POST","rejectUnauthorized":false,"timeout":3000,"json":true}
                                    16:25:19.855	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] response: {"statusCode":200,"body":{"code":1106},"headers":{"connection":"close","content-length":"13","content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.175","port":80,"hostname":"192.168.178.175","hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.175/xled/v1/login"},"method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                    16:25:19.856	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1106}
                                    16:25:19.857	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.bri] [Twinkly.POST.login] 1106 (Error - Login)
                                    16:25:19.858	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <device_name>
                                    16:25:19.859	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
                                    16:25:19.859	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] {"url":"http://192.168.178.175/xled/v1/login","body":{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="},"method":"POST","rejectUnauthorized":false,"timeout":3000,"json":true}
                                    16:25:19.901	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] response: {"statusCode":200,"body":{"code":1106},"headers":{"connection":"close","content-length":"13","content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.175","port":80,"hostname":"192.168.178.175","hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.175/xled/v1/login"},"method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                    16:25:19.903	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1106}
                                    16:25:19.904	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.name] [Twinkly.POST.login] 1106 (Error - Login)
                                    16:25:19.915	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <mqtt/config>
                                    16:25:19.916	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
                                    16:25:19.917	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] {"url":"http://192.168.178.175/xled/v1/login","body":{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="},"method":"POST","rejectUnauthorized":false,"timeout":3000,"json":true}
                                    16:25:19.975	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] response: {"statusCode":200,"body":{"code":1106},"headers":{"connection":"close","content-length":"13","content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.175","port":80,"hostname":"192.168.178.175","hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.175/xled/v1/login"},"method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                    16:25:19.976	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1106}
                                    16:25:19.979	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.mqtt] [Twinkly.POST.login] 1106 (Error - Login)
                                    16:25:19.993	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <timer>
                                    16:25:19.995	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
                                    16:25:20.001	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] {"url":"http://192.168.178.175/xled/v1/login","body":{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="},"method":"POST","rejectUnauthorized":false,"timeout":3000,"json":true}
                                    16:25:20.065	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] response: {"statusCode":200,"body":{"code":1106},"headers":{"connection":"close","content-length":"13","content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.175","port":80,"hostname":"192.168.178.175","hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.175/xled/v1/login"},"method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                    16:25:20.073	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1106}
                                    16:25:20.074	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.timer] [Twinkly.POST.login] 1106 (Error - Login)
                                    16:25:20.076	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <gestalt>
                                    16:25:20.085	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
                                    16:25:20.086	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] {"url":"http://192.168.178.175/xled/v1/login","body":{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="},"method":"POST","rejectUnauthorized":false,"timeout":3000,"json":true}
                                    16:25:20.151	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] response: {"statusCode":200,"body":{"code":1106},"headers":{"connection":"close","content-length":"13","content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.175","port":80,"hostname":"192.168.178.175","hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.175/xled/v1/login"},"method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                    16:25:20.152	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1106}
                                    16:25:20.153	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.details] [Twinkly.POST.login] 1106 (Error - Login)
                                    16:25:20.155	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <fw/version>
                                    16:25:20.156	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
                                    16:25:20.180	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] {"url":"http://192.168.178.175/xled/v1/login","body":{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="},"method":"POST","rejectUnauthorized":false,"timeout":3000,"json":true}
                                    16:25:20.242	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] response: {"statusCode":200,"body":{"code":1106},"headers":{"connection":"close","content-length":"13","content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.175","port":80,"hostname":"192.168.178.175","hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.175/xled/v1/login"},"method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                    16:25:20.253	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1106}
                                    16:25:20.261	error	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.firmware] [Twinkly.POST.login] 1106 (Error - Login)
                                    patrickbs96P siggi85S 2 Antworten Letzte Antwort
                                    • W W0RSCHD
                                      @patrickbs96
                                      patrickbs96P
                                      patrickbs96P
                                      patrickbs96
                                      @W0RSCHD said in Twinkly - Basisfunktionen mit ioBroker steuern:
                                      Weihnachtsbaum
                                      Ich habe deine Aufrufe mal mit meinen verglichen und die sind bis auf die Rückmeldung identisch:
                                      [httpRequest.POST] {"url":"http://192.168.178.52/xled/v1/login","body":{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="},"method":"POST","rejectUnauthorized":false,"timeout":3000,"json":true}
                                      Deins: [doPostRequest] response: {"statusCode":200,"body":{        "code":1106},"headers":{                         "connection":"close","content-length":"13","content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.175","port":80,"hostname":"192.168.178.175","hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.175/xled/v1/login"},"method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                      Meins: [doPostRequest] response: {"statusCode":200,"body":{"authentication_token":"BFJmAWqQ8+4=","authentication_token_expires_in":14400,"challenge-response":"b240d1a142fc8346c72453fa8b4bb62e7f44d64b","code":1000},"headers":{"server":"esp-httpd/0.5","connection":"close",                      "content-type":"application/json"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.52", "port":80,"hostname":"192.168.178.52", "hash":null,"search":null,"query":null,"pathname":"/xled/v1/login","path":"/xled/v1/login","href":"http://192.168.178.52/xled/v1/login"}, "method":"POST","headers":{"accept":"application/json","content-type":"application/json","content-length":60}}}
                                      Ich habe leider keine Erklärung dafür... @siggi85 hast du eventuell eine Idee?
                                      Es scheint ja irgend ein Fehler im Request zu sein, den die erste Generation der Twinkly nicht mag.
                                      Falls du keine Idee hast würde ich den Request gegen den curl Befehl ersetzen, der scheint ja zu funktionieren.
                                      • W W0RSCHD
                                        @patrickbs96
                                        siggi85S
                                        siggi85S
                                        siggi85
                                        @W0RSCHD Funktioniert denn zumindest mein Blockly bei dir? Das nutzt ja die curl Aufrufe, die anscheinend funktionieren.
                                        • siggi85S siggi85
                                          W
                                          W
                                          W0RSCHD
                                          @siggi85
                                          Das Blockly lief am Anfang 1a und irgendwann hat das auch gesponnen und es ging nix mehr (keine Ahnung wieso).
                                          @patrickbs96 kannst du mir mal eine Version machen mit den curl Anfragen, dann kann ich mal testen ob die bei meiner alten Version besser funktionieren.
                                          Danke euch beiden schon mal :)
                                          84.0k
