  4. Nach Update zigbee-adapter kein Start mit cc2531 möglich...
zigbee cc2531 cc2530
16 Beiträge 3 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • V voellig_egal
    @arteck k8mmt gleich... Aber wenn ich lsusb sende, wird nur einmal der Texasinstrument angezeigt, beim zweiten mal nur noch 3 usb-ports
    zigbee.0	2020-12-02 11:09:15.313	error	(10928) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B886CF-if00' at Znp.<ano
    zigbee.0	2020-12-02 11:09:15.312	error	(10928) Failed to start Zigbee
    zigbee.0	2020-12-02 11:09:15.302	info	(10928) Starting Zigbee npm ...
    zigbee.0	2020-12-02 11:09:15.300	info	(10928) Try to reconnect. 1 attempts left
    zigbee.0	2020-12-02 11:09:05.299	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0	2020-12-02 11:09:05.299	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0	2020-12-02 11:09:05.299	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
    zigbee.0	2020-12-02 11:09:05.299	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
    zigbee.0	2020-12-02 11:09:05.299	error	at new Promise (<anonymous>)
    zigbee.0	2020-12-02 11:09:05.299	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
    zigbee.0	2020-12-02 11:09:05.299	error	at Generator.next (<anonymous>)
    zigbee.0	2020-12-02 11:09:05.299	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
    zigbee.0	2020-12-02 11:09:05.299	error	(10928) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B886CF-if00'
    zigbee.0	2020-12-02 11:09:05.297	error	(10928) Failed to start Zigbee
    zigbee.0	2020-12-02 11:09:05.166	info	(10928) Starting Zigbee npm ...
    zigbee.0	2020-12-02 11:09:05.082	info	(10928) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
    host.raspberrypi4iob	2020-12-02 11:09:03.468	info	instance system.adapter.zigbee.0 started with pid 10928
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @voellig_egal
    Der Adapter kann die serielle Schnittstelle nicht finden:
    Bist du sicher das der verbünde ist und unter diesem Namen auch auftaucht ?
    gibt bitte auf der Console den Folgenden Befehl ein und poste die Antwort:
    ls -al /dev/serial/by-id
    V 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      @voellig_egal
      V Offline
      V Offline
      voellig_egal
      schrieb am zuletzt editiert von voellig_egal
      @Asgothian genau...das ist denke ich auch mein Problem.
      Folgendes Phänomen:
      Wenn ich den cc2531 in den Raspberry reinstecke. "lsusb" sende und dann die ID abfrage kommt der Schlüssel. Wenn ich jetzt nochmal das gleiche mache, wird der USB-Port mit dem cc2531 nicht mehr gelistet. Ziehe ich ihn ab, stecke ihn wieder an... fängt der Spaß von vorne an. Beim 2. Mal abfragen werden nur 3 USB-Ports (also keiner mit Texas-Instrument im Namen) aufgelistet... :-(
      • V voellig_egal
        Folgendes Phänomen:
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @voellig_egal
        Ich kann dir nicht folgen. Poste bitte mal die von Dir beschriebenen Unterschiedlichen Ausgaben.
        V arteckA 2 Antworten Letzte Antwort
          @voellig_egal
          V Offline
          V Offline
          voellig_egal
          @Asgothian cc2531 einstecken und wie folgt abfragen:
          pi@raspberrypi4iob:/opt/iobroker $ lsusb
          Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
          Bus 001 Device 101: ID 0451:16a8 Texas Instruments, Inc.
          Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
          pi@raspberrypi4iob:/opt/iobroker $ ls -la /dev/serial/by-id
          insgesamt 0
          drwxr-xr-x 2 root root 60 Dez  2 13:09 .
          drwxr-xr-x 4 root root 80 Dez  2 13:09 ..
          lrwxrwxrwx 1 root root 13 Dez  2 13:09 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B886CF-if00 -> ../../ttyACM0
          pi@raspberrypi4iob:/opt/iobroker $ ls -la /dev/serial/by-id        ls: Zugriff auf '/dev/serial/by-id' nicht möglich: Datei oder Verzeichnis nicht gefunden
          Bei einer 2. Abfrage kommt keine RM mehr von der Schnittstelle.
          Wenn ich den Stick aus und wieder einstecken, kann ich 1x die ID abfragen, danach erreiche ich den Port nicht mehr. Er ist nicht mehr gelistet.
          Dann kommt:
          ls: Zugriff auf '/dev/serial/by-id' nicht möglich: Datei oder Verzeichnis nicht gefunden�����
          Irgendwie scheint sich der Port zu verabschieden... umstecken auf einen anderen USB bringt das gleiche Ergebnis...
          Bis zum Update lief der Stick und wunderbar...
          • V voellig_egal
            insgesamt 0
            Dann kommt:
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @voellig_egal Ich empfehle den Stick neu zu flashen.
            Wenn der nicht mehr geht ist ein Ersatz angesagt. Am besten nicht wieder ein cc2531
            A.
              A.
              V Offline
              V Offline
              voellig_egal
              @Asgothian und dass es am serial-port liegt...das der neu betankt werden muss? bevor ich da was neues kaufe, würde ich gern noch etwas anderes probieren...hast du da ne Idee? besten Dank
                @voellig_egal
                arteckA Offline
                arteckA Offline
                arteck
                @Asgothian frag wer noch .....
                • arteckA arteck
                  V Offline
                  V Offline
                  voellig_egal
                  @arteck ?? Verstehe ich nicht. Aber nochmal zur Frage. Das fing ja mit dem Update des Zigbee-Adapters an. Kann man hier vielleicht doch noch mit nem Reset oder sowas den Zigbee und Serial-port-Adapter zurücksetzen? Wenn, wie? Thx
                  • V voellig_egal
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @voellig_egal
                    Kurze Antwort: Nein.
                    Lange Antwort: Du verwechselst Ursache, Wirkung und Zusammenhang:
                    • Das der Stick bei 2 mal Auflisten des Ports am USB nicht gefunden wird kann nichts mit dem "Serialport" des Zigbee Adapters zu tun haben. Das ist Hardware / Firmware des Sticks.
                    • Ein Reset der USB Hardware findet beim Neustart des Systems statt. (AEG ?)
                    • Das die FW des Sticks durch einen Befehl vom Rechner aus abstürzt ist denkbar. Das deutet auf ein Problem bei deinem Stick hin. Wenn das ein allgemeines Problem wäre gäbe es haufenweise Meldungen dazu.
                    • Das FW Problem auf dem Stick ist entweder rein Software (neu flashen und dann geht es) oder Hardware (der Stick ist tot).
                    • Einen Zusammenhang zur neuen Version des Zigbee-Adapters (von welcher auf welche Version überhaupt ?) sehe ich nicht.
                    Ansonsten: Die Lösung Deines Problems ist hier beschrieben. Ich sehe keine Alternativen.
                    A.
                    Im Übrigen: 🤦
                    Nachtrag: Neu flashen heisst nicht etwas neu kaufen, sondern den Stick neu mit Firmware betanken.
                      @voellig_egal
                      A.
                      Im Übrigen: 🤦
                      V Offline
                      V Offline
                      voellig_egal
                      @Asgothian OK, das war ausführlich :-)... Danke. Flashen ist schon klar, aber ich habe keinen Programmer und daher ist auf die Schnelle nur neu kaufen drin... leider...
                      • V voellig_egal
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @voellig_egal Schau mal im Marktplatz. Da hat meiner Meinung nach jemand angeboten Sticks zu flashen. Kostet dann 2x Porto und nen Bier oder so.
                        Einen neuen cc2531 würde ich auf keinen Fall kaufen. Es sind zwar nur 20 Euro, aber fuer 20 Euro mehr bekommst du ein Board das
                        • besser funktioniert
                        • von Dir mit neuer Firmware betankt werden kann
                        • Zukunftssicher ist.
                        A.
                          A.
                          V Offline
                          V Offline
                          voellig_egal
                          @Asgothian welches Board meinst Du? Den Conbee-Stick?
                          Ich schau Mal im Marktplatz nach. Habe 2 Sticks, einer kam damals ohne FW
                          • V voellig_egal
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @voellig_egal
                            Siehe Hier
                            Conbee ist nicht ideal.
                            A.
