  4. Erster Werte des Tages aus History auslesen
    5.6k
javascriptblockly
52 Beiträge 6 Kommentatoren 8.1k Aufrufe 4 Beobachtet
  • G glitzi
    so es läuft... aber noch eine Frage:
    Wenn ich mit den Werten rechne, bekomme ich als Ergebnis
    0.020000000000000018
    Sollte doch eigentlich 0,02 ergeben?
    }, function (result) {
        log(result.result[1].val + ' ' + formatDate(result.result[1].ts, 'DD.MM.YYYY hh:mm:ss'));
        log(getState("javascript.0.Guntamatic_Brenstoffzähler_89").val);
        setState('Guntamatic_Brennstoff_Tageswert', (getState("javascript.0.Guntamatic_Brenstoffzähler_89").val - result.result[1].val), true);
    LOG
    13:12:35.310	info	javascript.0 (1126) script.js.Guntamatic.Guntamatic_Brennstoff_Tageswert: 1.55 24.11.2020 04:51:50
    13:12:35.310	info	javascript.0 (1126) script.js.Guntamatic.Guntamatic_Brennstoff_Tageswert: 1.57
    @glitzi sagte:
    Das passiert bei Berechnungen mit Floating point. Abhilfe: Runden
    Math.round(diff * 100) / 100 // 2 Nachkommastellen
    • M MCU
      @Chrille1507 Beschreibung zum Adapter:
      start - (optional) time in ms - new Date().getTime()'
      end - (optional) time in ms - new Date().getTime()', by default is (now + 5000 seconds)
      step - (required if aggregate is not "none") used for aggregate functions (max, min, average, total, count) step in ms of intervals
      count - (optional) number of values if aggregate is 'onchange'/'none' or number of intervals if other aggregate method. Count will be ignored if step is set.
      limit - do not return more entries than limit (only used if aggregate is 'onchange'/'none')
      addId - if id field should be included in answer
      aggregate - aggregate method:
        max - Splice the whole time range in small intervals and find for every interval max value and use it for this interval (nulls will be ignored).
        min - Same as max, but take minimal value.
        average - Same as max, but take average value.
        total - Same as max, but calculate total value.
        count - Same as max, but calculate number of values (nulls will be calculated).
        none/onchange - No aggregation at all. Only raw values in given period.
      Chrille1507
      @MCU Die Readme habe ich gelesen (leider aufgrund schlechter Englischkenntnisse) aber nur halbwegs verstanden. Welchen Intervall gebe ich bei "step" denn an?
      "start" und "end" scheinen mir richtig zu sein mit meiner Konfiguration.
      Die ganze Funktion hängt bei mir einem Zeitplan und schreibt den Wert alle 24 Stunden in einen eigenen Datenpunkt. Ist das vielleicht noch wichtig zu wissen?
      • C Chrille1507
        M Online
        M Online
        MCU
        @Chrille1507 step: 60000 -> entspricht 1Minute (in ms) , dem Abstand zum nächsten Wert.
        C 1 Antwort Letzte Antwort
        • M MCU
          Chrille1507
          @MCU Eine doofe Nachfrage bitte noch. Abstand zum nächsten Wert innerhalb der Datenbank? Also wenn jede Sekunde ein Wert in die Datenbank geschrieben wird, könnte ich theoretisch bei Step auch 1000 eintragen?
          • C Chrille1507
            M Online
            M Online
            MCU
            @Chrille1507 Bei 7 Tagen, die du mit Abfrage auswertest, würde ich mir das gut überlegen! Das kommt evtl einiges an Daten zusammen? Das kann dann auch ein System auslasten!
            • M MCU
              Chrille1507
              schrieb am zuletzt editiert von Chrille1507
              @MCU Sehr guter Hinweis, vielen Dank.
              Dann macht es vielleicht mehr Sinn, die Abfrage auf einen Tag zu beschränken und einen zweiten Datenpunkt anzulegen, der nur seinen Wert mit dem ersten Datenpunkt vergleicht und diesen für 7 Tage festzulegen.
              Sind zwar etwas mehr Datenpunkte entlastet das System wahrscheinlich.
              Vielen Dank
              G 1 Antwort Letzte Antwort
              • C Chrille1507
                Vielen Dank
                glitzi
                Noch ein kleines Problem:
                Folgende Fehlermeldung erhalte ich bei angefügtem Skript:
                24.11.2020, 21:40:00.049	[warn ]: javascript.0 (1126) TypeError: Cannot read property 'val' of undefined
                    at Object.cb (script.js.Wasserzähler.Wasserzähler_Minuten_und_Tageswert:42:100)
                    at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5297:71)
                    at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:234:41)
                    at processImmediate (internal/timers.js:461:21)
                // Wasserzähler summieren
                createState('WasserzählerSumme', function () {
                  on({id: "mqtt.0.ESP_Easy.Wasser.Count"/*ESP_Easy/Wasser/Count*/, change: "any"}, function (obj) {
                    var value = obj.state.val;
                    setState('WasserzählerSumme'/*WasserzählerSumme*/, (getState('WasserzählerSumme').val + getState("mqtt.0.ESP_Easy.Wasser.Count").val / 60)
                    , true);
                // Wasser Tageswert
                schedule1 =  schedule('{"time":{"exactTime":true,"start":"23:59"},"period":{"days":1}}', function () {
                createState('Wasserzähler_Tageswert');
                sendTo('influxdb.0', 'getHistory', {
                    options: {
                        start:      getDateObject('00:00').getTime(),
                        count:      1,
                        aggregate: 'none' // or 'none' to get raw values
                    var berechnung = Math.round((getState('javascript.0.WasserzählerSumme').val - result.result[1].val) * 100) / 100;
                    setState('javascript.0.Wasserzähler_Tageswert', berechnung, true);
                //Wasser Tageswert hochlaufend
                schedule2 = schedule('* * * * *', function () {
                createState('Wasserzähler_Tageswert_hochlaufend');
                    options: {
                        count:      1,
                    setState('javascript.0.Wasserzähler_Tageswert_hochlaufend', berechnung, true);
                • G glitzi
                      , true);
                  // Wasser Tageswert
                      options: {
                          count:      1,
                      options: {
                          count:      1,
                  M Online
                  M Online
                  MCU
                  Da auch:
                  Und hier:
                  • M MCU
                    Da auch:
                    Und hier:
                    glitzi
                    @MCU
                    Was ist falsch, stehe auf dem Schlauch ;-)
                    • G glitzi
                      @MCU
                      M Online
                      M Online
                      MCU
                      @glitzi Ich denke das (javascript.0. ..... davor muß.
                      G paul53P 2 Antworten Letzte Antwort
                      • M MCU
                        glitzi
                        @MCU
                        Kommt trotzdem
                            setState('javascript.0.WasserzählerSumme'/*WasserzählerSumme*/, (getState('javascript.0.WasserzählerSumme').val + getState("mqtt.0.ESP_Easy.Wasser.Count").val / 60)
                            , true);
                        // Wasser Tageswert
                            options: {
                                count:      1,
                            options: {
                                count:      1,
                        • M MCU
                          @MCU sagte:
                          Wenn das Script unter der Instanz 0 läuft, funktionieren beide Versionen. Außerdem kommt die Warnung aus Zeile 42 zu
                          Ein eigener Test hat ergeben, dass bei count = 1 richtig wäre
                          result.result[0].val
                          • G glitzi
                            @MCU
                            Kommt trotzdem
                                , true);
                            // Wasser Tageswert
                                options: {
                                    count:      1,
                                options: {
                                    count:      1,
                            M Online
                            M Online
                            MCU
                            @glitzi Welcher Wert steht im DP: javascript.0.WasserzählerSumme
                            • M MCU
                              glitzi
                              @MCU
                              da steht 2
                              • G glitzi
                                @MCU
                                da steht 2
                                glitzi
                                @glitzi
                                so kommt der gleich Fehler in Zeile 42?
                                • G glitzi
                                  @glitzi
                                  @glitzi
                                  Ich erhalte die Warnung auch beim Test mit
                                  Mit count = 1 sollte das Array nur einen Wert enthalten und das ist
                                  result.result[0]
                                    @glitzi
                                    result.result[0]
                                    glitzi
                                    Ohh... das wars !!!!!
                                    • G glitzi
                                      @glitzi sagte:
                                      das wars
                                      Wie bist Du hierauf gekommen ?
                                        @glitzi sagte:
                                        das wars
                                        glitzi
                                        Gute Frage ;-) beim vielen probieren bestimmt etwas übersehen.
                                        • C Offline
                                          Chrille1507
                                          passend zum Thema habe ich eine ähnliche Lösung gefunden, die vielleicht auch in Zukunft anderen hilft, die wie ich Probleme mit 'getHistory' haben.
                                          Die gewünschten Daten können auch mit folgenden Befehl ausgegeben werden:
                                          sendTo('influxdb.0', 'query', 'SELECT max("value") FROM "***" WHERE time > now() - 7d'
                                          In diesem Beispiel wird der maximale Wert (max("value")) des Datenpunktes ("***") der letzten 7 Tage ("now() - 7d") ausgegeben. So funktioniert es bei mir wunderbar.
                                          Aber Achtung: Die Ausgabe erfolgt als Array.
