  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • T tobitobsta
    @Thomas-Braun
    here we go (dmesg):
    [    0.872784] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    0.873037] io scheduler mq-deadline registered
    [    0.873066] io scheduler kyber registered
    [    0.877118] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    0.877163] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [    0.877268] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
    [    0.877359] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
    [    0.936694] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
    [    0.937034] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    0.937069] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.937103] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
    [    0.937183] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    0.937467] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    0.940741] PCI: bus0: Fast back to back transfers disabled
    [    0.940990] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    0.941153] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    0.941602] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    0.944910] PCI: bus1: Fast back to back transfers disabled
    [    0.944986] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    0.945024] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [    0.945125] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.945164] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    0.945492] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    0.945754] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
    [    0.946174] pcieport 0000:00:00.0: AER: enabled with IRQ 55
    [    0.946534] pci 0000:01:00.0: enabling device (0140 -> 0142)
    [    0.953506] iproc-rng200 fe104000.rng: hwrng registered
    [    0.953858] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    0.954521] vc-sm: Videocore shared memory driver
    [    0.955174] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [    0.967382] brd: module loaded
    [    0.979746] loop: module loaded
    [    0.981183] Loading iSCSI transport class v2.0-870.
    [    0.983154] libphy: Fixed MDIO Bus: probed
    [    0.983801] bcmgenet fd580000.ethernet: failed to get enet clock
    [    0.983837] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [    0.983875] bcmgenet fd580000.ethernet: failed to get enet-wol clock
    [    0.983911] bcmgenet fd580000.ethernet: failed to get enet-eee clock
    [    0.983954] bcmgenet: Skipping UMAC reset
    [    0.994628] libphy: bcmgenet MII bus: probed
    [    1.084660] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [    1.085698] usbcore: registered new interface driver r8152
    [    1.085779] usbcore: registered new interface driver lan78xx
    [    1.085853] usbcore: registered new interface driver smsc95xx
    [    1.086309] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.086358] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [    1.088980] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
    [    1.090301] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [    1.090340] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.090375] usb usb1: Product: xHCI Host Controller
    [    1.090403] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
    [    1.090432] usb usb1: SerialNumber: 0000:01:00.0
    [    1.091051] hub 1-0:1.0: USB hub found
    [    1.091175] hub 1-0:1.0: 1 port detected
    [    1.091773] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.091815] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [    1.091857] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    1.092403] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    [    1.092442] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.092476] usb usb2: Product: xHCI Host Controller
    [    1.092505] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
    [    1.092534] usb usb2: SerialNumber: 0000:01:00.0
    [    1.093132] hub 2-0:1.0: USB hub found
    [    1.093248] hub 2-0:1.0: 4 ports detected
    [    1.094789] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    1.095098] dwc_otg: FIQ enabled
    [    1.095111] dwc_otg: NAK holdoff enabled
    [    1.095123] dwc_otg: FIQ split-transaction FSM enabled
    [    1.095139] Module dwc_common_port init
    [    1.095581] usbcore: registered new interface driver uas
    [    1.095704] usbcore: registered new interface driver usb-storage
    [    1.095912] mousedev: PS/2 mouse device common for all mice
    [    1.097794] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    1.101249] sdhci: Secure Digital Host Controller Interface driver
    [    1.101281] sdhci: Copyright(c) Pierre Ossman
    [    1.101909] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    1.102495] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.106361] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.106691] hidraw: raw HID events driver (C) Jiri Kosina
    [    1.106903] usbcore: registered new interface driver usbhid
    [    1.106931] usbhid: USB HID core driver
    [    1.107978] vchiq: vchiq_init_state: slot_zero = (ptrval)
    [    1.111604] [vc_sm_connected_init]: start
    [    1.120598] [vc_sm_connected_init]: end - returning 0
    [    1.122844] Initializing XFRM netlink socket
    [    1.122898] NET: Registered protocol family 17
    [    1.123030] Key type dns_resolver registered
    [    1.123414] Registering SWP/SWPB emulation handler
    [    1.123733] registered taskstats version 1
    [    1.123766] Loading compiled-in X.509 certificates
    [    1.124310] Key type ._fscrypt registered
    [    1.124338] Key type .fscrypt registered
    [    1.135099] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    1.135193] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
    [    1.141319] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    1.142324] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    1.142356] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    1.194371] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    1.196125] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.197983] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.201000] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    1.202690] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.209837] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [    1.213028] of_cfs_init
    [    1.213159] of_cfs_init: OK
    [    1.214435] Waiting for root device PARTUUID=7482b1ce-02...
    [    1.253748] random: fast init done
    [    1.287420] mmc1: new high speed SDIO card at address 0001
    [    1.320454] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.321388] mmcblk0: mmc0:aaaa SH32G 29.7 GiB
    [    1.323765]  mmcblk0: p1 p2
    [    1.345587] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.345677] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.351019] devtmpfs: mounted
    [    1.359759] Freeing unused kernel memory: 2048K
    [    1.374863] Run /sbin/init as init process
    [    1.454614] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    1.637382] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [    1.637426] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.637458] usb 1-1: Product: USB2.0 Hub
    [    1.639630] hub 1-1:1.0: USB hub found
    [    1.639915] hub 1-1:1.0: 4 ports detected
    [    1.815053] systemd[1]: System time before build time, advancing clock.
    [    1.912629] NET: Registered protocol family 10
    [    1.914054] Segment Routing with IPv6
    [    1.943043] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    1.943863] systemd[1]: Detected architecture arm.
    [    1.964604] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
    [    2.034737] systemd[1]: Set hostname to <iobroker>.
    [    2.105077] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
    [    2.105125] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.105161] usb 1-1.3: Product: TI CC2531 USB CDC
    [    2.105190] usb 1-1.3: Manufacturer: Texas Instruments
    [    2.105219] usb 1-1.3: SerialNumber: __0X00124B000BE8A20E
    [    2.707077] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.721301] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.721858] systemd[1]: Listening on udev Kernel Socket.
    [    2.722800] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.728270] systemd[1]: Listening on Syslog Socket.
    [    2.731895] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    2.732758] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    2.733855] systemd[1]: Listening on fsck to fsckd communication Socket.
    [    2.734760] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.736088] systemd[1]: Listening on Journal Socket.
    [    3.365389] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.457918] systemd-journald[113]: Received request to flush runtime journal from PID 1
    [    3.966447] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [    3.966956] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [    3.970164] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [    3.976805] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [    4.107110] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.107282] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.111882] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    4.111908] [vc_sm_connected_init]: start
    [    4.117593] [vc_sm_connected_init]: installed successfully
    [    4.134353] mc: Linux media interface: v0.10
    [    4.194400] bcm2835_audio bcm2835_audio: card created with 8 channels
    [    4.200184] videodev: Linux video capture interface: v2.00
    [    4.265102] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.270376] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.285473] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [    4.289686] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [    4.292951] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [    4.293715] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [    4.293751] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [    4.293775] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [    4.293821] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [    4.293842] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [    4.293847] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.294064] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [    4.349366] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    4.352132] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.370527] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    4.370572] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    4.387377] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    4.387420] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    4.427223] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    4.427266] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    4.497829] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    4.508478] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [    4.593744] brcmfmac: F1 signature read @0x18000000=0x15264345
    [    4.611429] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    4.611868] usbcore: registered new interface driver brcmfmac
    [    4.635275] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    [    4.666016] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    [    4.666506] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [    4.666559] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    4.666591] [drm] No driver support for vblank timestamp query.
    [    4.666623] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
    [    4.682271] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [    4.721812] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
    [    4.725955] usbcore: registered new interface driver cdc_acm
    [    4.726028] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    4.872041] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    4.887639] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
    [    6.649834] uart-pl011 fe201000.serial: no DMA platform data
    [    6.793534] 8021q: 802.1Q VLAN Support v1.8
    [    6.833530] random: crng init done
    [    6.833547] random: 7 urandom warning(s) missed due to ratelimiting
    [    7.004588] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:307200k SSFS
    [    7.231550] bcmgenet: Skipping UMAC reset
    [    7.233099] bcmgenet fd580000.ethernet: configuring instance for external RGMII
    [    7.233291] bcmgenet fd580000.ethernet eth0: Link is Down
    [   12.394731] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   12.394778] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   13.390194] Bluetooth: Core ver 2.22
    [   13.390278] NET: Registered protocol family 31
    [   13.390292] Bluetooth: HCI device and connection manager initialized
    [   13.390319] Bluetooth: HCI socket layer initialized
    [   13.390339] Bluetooth: L2CAP socket layer initialized
    [   13.390370] Bluetooth: SCO socket layer initialized
    [   13.400185] Bluetooth: HCI UART driver ver 2.3
    [   13.400204] Bluetooth: HCI UART protocol H4 registered
    [   13.400291] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   13.400609] Bluetooth: HCI UART protocol Broadcom registered
    [   13.645614] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   13.645624] Bluetooth: BNEP filters: protocol multicast
    [   13.645637] Bluetooth: BNEP socket layer initialized
    [   13.677962] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    [   36.486035] FS-Cache: Netfs 'cifs' registered for caching
    [   36.494244] Key type cifs.spnego registered
    [   36.494260] Key type cifs.idmap registered
    [   36.497493] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [  179.685049] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [  211.740935] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [  211.794216] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [  211.794274] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
    [ 2926.815460] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [ 3049.571700] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [ 3083.871685] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [ 3083.946733] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [ 3083.946792] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
    [ 4364.779967] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [ 4396.513037] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [ 4396.585580] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [ 4396.585637] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
    [ 4618.763633] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    [ 9755.613491] CIFS: Attempting to mount //server/tobi/Backup/iobroker
    pi@iobroker: sudo -u iobroker groups
    iobroker tty dialout audio video bluetooth redis gpio i2c
    pi@iobroker:/opt/iobroker $ groups
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    #791
    @tobitobsta sagte in Test Adapter Backitup v1.7.x:
    Du hättest ja auch mal verkünden können, das das ein gemountetes Dateisystem an der Stelle ist.
    Wie sehen die mount-Optionen aus?
      tobitobsta
      #792
      @Thomas-Braun ja das hätte ich tun können...
          "connectType": "CIFS",
          "cifsMount": "*****",
          "cifsDomain": "",
          "cifsUser": "******",
          "cifsPassword": "******",
          "smbType": "vers=3.0",
          "sudoMount": true,
          "cifsDeleteOldBackup": false,
          "cifsOwnDir": false,
          "wakeOnLAN": true,
      mounting scheint zumindest so weit zu funktionieren, dass ich die backups in der Auswahlliste sehe. Und acuh das Backup erstellen funktioniert auf dem mount ohne Probleme.
      • T tobitobsta
        @Thomas-Braun
        here we go (dmesg):
        simatecS Offline
        simatecS Offline
        simatec
        #793
        @tobitobsta
        Mache mal bitte den Restore Lokal. Cloud und NAS ist immer nicht so das Gelbe vom Ei ;-) ....
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • T tobitobsta
              "cifsDomain": "",
              "sudoMount": true,
              "wakeOnLAN": true,
          #794
          @tobitobsta
          Wird über die fstab gemounted?
          Dann bitte die dortigen Einträge nennen.
          Ansonsten das was @simatec sagt.
            @tobitobsta
            tobitobsta
            #795
            @Thomas-Braun mounting passiert über den Adapter
            @simatec vielen Dank für den Hinweis. So funktioniert es dann. Dann verstehe ich zwar noch nicht warum das auf dem alten System ohne weiteres ging - aber erstmal bin ich natürlich glücklich das es so geht. Danke Dir!!!
            Was ich noch nicht verstehe ist, dass mein Redis-Backup, was ich drauf spiele, ca 3.7MB groß ist und nach einem Zurückspielen und erneutem Backup das Redis-Backup nur noch 650KB groß ist. Aber wie ihr ja bereits merkt - meine Mittel sind begrenzt ;-)
            • T tobitobsta
              simatecS Offline
              simatecS Offline
              simatec
              #796
              @tobitobsta
              Prüfe mal die Rechte auf deinem NAS. So wie es aussieht, hat iobroker bzw. Backitup keine Schreibrechte
                Bibo*13
                schrieb am zuletzt editiert von Bibo*13
                #797
                seit 2 Tagen werden keine iobroker Archive mehr in mein NAS Drive geschrieben.
                Pushover sagt immer erfolgreich im VIS HTML steht aber immer name undefined.
                redis und zigbee.0 kommen an und werden auch geschrieben.
                Ich habe jetzt backitup mit debug laufen lassen und hänge mal das Log mit an.
                Ebenso das log wenn ich den Adapter zum backuppen händisch starte.
                Vielleicht gibt es ja einen Tip von Euch
                vielen Dank
                Backitup2.txt Backitup1.txt
                • simatecS simatec
                  @tobitobsta
                  tobitobsta
                  #798
                  @simatec Aber dann könnte er ja das Backup auch dort nicht erstellen - aber das geht ja wunderbar. Oder er hängt es beim Backup "anders" ein als beim Wiederherstellen... Aber ich Denke im Grunde hast Du recht: Es scheint ein Rechte-Problem zu sein. Der Mount Befehl für die Wiederherstellung im log sieht für mich jetzt auch okay aus:
                  sudo mount -t cifs -o username=tobi,password=****,rw,file_mode=0777,dir_mode=0777 //server/tobi/Backup/iobroker /opt/iobroker/backups
                  Unterschied: der Ordner "backups" gehört vor dem mounten user iobroker - nachdem mounten "root" - aber er ist tatsächlich 0777 Rechten versehen.
                  • HALH HAL
                    @simatec mal eine "unverschämte" Frage. Da ich seit kurzem eine PV Anlage mit Speicher + Wallbox habe, nutze ich für die Speicherung der Werte eine influxdb und zur grafischen Anzeige Grafana. Das läuft auch prima mit iobroker zusammen.
                    Es wäre toll wenn ich zur Sicherung auch den backitup Adapter nutzen könnte :-)
                    Backup für influxdb ist eigentlich ganz einfach:
                    sudo influxd backup -portable /opt/backups/influx.backup
                    restore auch
                    influxd restore -portable /opt/backups/influx.backup
                    für Grafana ist es komplizierter (siehe: https://www.bachmann-lan.de/grafana-backup-dashboards-data-sources/)
                    Momentan starte ich zwei scripte über die shell.
                    Ob man das "irgendwann mal" in den Backitup Adapter aufnehmen könnte ?
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #799
                    @HAL
                    Wenn du Influxdb mal testen willst, kannst du gerne mal die DEV Version testen.
                    Im Moment geht noch kein Restore
                    https://github.com/simatec/ioBroker.backitup/tarball/dev
                    HALH 1 Antwort Letzte Antwort
                    • simatecS simatec
                      @HAL
                      HALH Offline
                      HALH Offline
                      HAL
                      #800
                      @simatec
                      Mal sehen ob übermorgen ( morgen bin ich unterwegs ) auf meinen NAS etwas zu finden ist.
                      Manuell kann man den Backup aber nicht anstoßen, korrekt ?
                      Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
                      (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
                      • HALH HAL
                        @simatec
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #801
                        @HAL
                        Nein ... es wird als Option wie die anderen Datenbanken bei einem iobroker Backup mit ausgeführt
                        • P Offline
                          Phil82
                          schrieb am zuletzt editiert von Phil82
                          #802
                          Guten Morgen,
                          ich habe hier einige Error im Log. Sicherung startet täglich um 2Uhr und soll die IoBroker sowie Zigbee Daten in Google Drive sichern.
                          Iobroker läuft auf einem NUC unter Proxmox mit Ubuntu Server
                          Node.js v10.22.0
                          NPM 6.14.6
                          Systeminfos
                          iobroker_server
                          Platform
                          linux
                          Betriebssystem
                          linux
                          Architektur
                          x64
                          CPUs
                          Geschwindigkeit
                          2165 MHz
                          Modell
                          Common KVM processor
                          RAM
                          3.85 GB
                          System Betriebszeit
                          1 T. 20:30:01
                          Node.js
                          v10.22.0 (Es gibt eine neuere Version: v10.23.0 - Empfohlene Version v12.19.1)
                          NPM
                          6.14.6
                          Festplatte Größe
                          15.64 GB
                          Festplatte frei
                          8.32 GB
                          Anzahl der Adapter
                          312
                          Betriebszeit
                          1 T. 20:29:37
                          Aktive Instanzen
                          15
                          Hostname
                          iobroker_server
                          Log
                          2020-11-18 02:00:10.045 - debug: backitup.0 (4228) Backup has started ...
                          2020-11-18 02:00:12.693 - info: ical.0 (6395) processing URL: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                          2020-11-18 02:00:16.600 - debug: backitup.0 (4228) [iobroker/iobroker] host.iobroker_server 5248 states saved
                          2020-11-18 02:00:16.664 - debug: backitup.0 (4228) [iobroker/iobroker] host.iobroker_server 3577 objects saved
                          2020-11-18 02:00:18.420 - warn: host.iobroker_server Objects 127.0.0.1:45828 Error from InMemDB: Error: ERROR readDir id=0_userdata.0: Not exists
                          2020-11-18 02:00:18.421 - warn: host.iobroker_server Objects 127.0.0.1:45828 Error from InMemDB: Error: ERROR readDir id=admin.0: Not exists
                          2020-11-18 02:00:18.427 - warn: readFile will not read this file (css/vis-common-user.css) in future versions: vis is not an object of type "meta"
                          2020-11-18 02:00:18.428 - warn: host.iobroker_server Objects 127.0.0.1:45828 Error from InMemDB: Error: ERROR readDir id=web.0: Not exists
                          2020-11-18 02:00:19.868 - info: ical.0 (6395) Terminated (NO_ERROR): Without reason
                          2020-11-18 02:00:20.409 - info: host.iobroker_server instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                          2020-11-18 02:00:22.336 - debug: backitup.0 (4228) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_11_18-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:00:23.388 - debug: backitup.0 (4228) [iobroker/iobroker] done
                          2020-11-18 02:00:23.992 - debug: backitup.0 (4228) [iobroker/zigbee] found zigbee database: zigbee.0
                          2020-11-18 02:00:23.993 - debug: backitup.0 (4228) [iobroker/zigbee] done
                          2020-11-18 02:00:24.445 - debug: backitup.0 (4228) [iobroker/googledrive] Google Drive: Copy iobroker_2020_11_18-02_00_10_backupiobroker.tar.gz...
                          2020-11-18 02:00:24.460 - debug: backitup.0 (4228) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_11_14-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:00:24.461 - debug: backitup.0 (4228) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_11_13-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:00:24.465 - debug: backitup.0 (4228) [iobroker/clean] delete /opt/iobroker/backups/zigbee.0_2020_11_14-02_00_22_backupiobroker.tar.gz
                          2020-11-18 02:00:24.466 - debug: backitup.0 (4228) [iobroker/clean] delete /opt/iobroker/backups/zigbee.0_2020_11_13-02_00_22_backupiobroker.tar.gz
                          2020-11-18 02:00:24.467 - debug: backitup.0 (4228) [iobroker/clean] done
                          2020-11-18 02:00:24.968 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2020-11-18 02:00:24.969 - error: backitup.0 (4228) unhandled promise rejection: Rate Limit Exceeded
                          2020-11-18 02:00:25.054 - error: backitup.0 (4228) Error: Rate Limit Exceeded
                          at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:112:15)
                          at process._tickCallback (internal/process/next_tick.js:68:7)
                          2020-11-18 02:00:25.055 - info: backitup.0 (4228) cleaned everything up...
                          2020-11-18 02:00:25.121 - info: backitup.0 (4228) terminating
                          2020-11-18 02:00:25.122 - debug: backitup.0 (4228) Plugin sentry destroyed
                          2020-11-18 02:00:25.123 - info: backitup.0 (4228) Terminated (NO_ERROR): Without reason
                          2020-11-18 02:00:25.283 - debug: backitup.0 (4228) [iobroker/history] backitup.0.history.html
                          2020-11-18 02:00:25.284 - debug: backitup.0 (4228) [iobroker/history] backitup.0.history.json
                          2020-11-18 02:00:25.436 - debug: backitup.0 (4228) [iobroker] exec: done
                          2020-11-18 02:00:25.684 - error: host.iobroker_server Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          2020-11-18 02:00:25.690 - error: host.iobroker_server Caught by controller[1]: Error: Rate Limit Exceeded
                          2020-11-18 02:00:25.691 - error: host.iobroker_server Caught by controller[1]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:112:15)
                          2020-11-18 02:00:25.691 - error: host.iobroker_server Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:68:7)
                          2020-11-18 02:00:25.691 - info: host.iobroker_server instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                          2020-11-18 02:00:25.692 - info: host.iobroker_server Restart adapter system.adapter.backitup.0 because enabled
                          2020-11-18 02:00:25.796 - info: coronavirus-statistics.0 (6380) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2020-11-18 02:00:26.321 - info: host.iobroker_server instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2020-11-18 02:00:55.715 - info: host.iobroker_server instance system.adapter.backitup.0 started with pid 6421
                          2020-11-18 02:00:59.737 - debug: backitup.0 (6421) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-11-18 02:00:59.785 - debug: backitup.0 (6421) Objects client ready ... initialize now
                          2020-11-18 02:00:59.792 - debug: backitup.0 (6421) Objects create System PubSub Client
                          2020-11-18 02:00:59.793 - debug: backitup.0 (6421) Objects create User PubSub Client
                          2020-11-18 02:00:59.794 - debug: backitup.0 (6421) Objects client initialize lua scripts
                          2020-11-18 02:00:59.814 - debug: backitup.0 (6421) Objects connected to redis: 127.0.0.1:9001
                          2020-11-18 02:00:59.859 - debug: backitup.0 (6421) objectDB connected
                          2020-11-18 02:00:59.862 - debug: backitup.0 (6421) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-11-18 02:00:59.872 - debug: backitup.0 (6421) States create User PubSub Client
                          2020-11-18 02:00:59.875 - debug: backitup.0 (6421) States create System PubSub Client
                          2020-11-18 02:00:59.889 - debug: backitup.0 (6421) States connected to redis: 127.0.0.1:9000
                          2020-11-18 02:00:59.890 - debug: backitup.0 (6421) statesDB connected
                          2020-11-18 02:01:01.712 - debug: backitup.0 (6421) Plugin sentry Initialize Plugin (enabled=true)
                          2020-11-18 02:01:01.958 - info: backitup.0 (6421) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.22.0, js-controller: 3.1.4
                          2020-11-18 02:01:02.076 - info: backitup.0 (6421) [iobroker] backup was activated at 02:00 every 1 day(s)
                          2020-11-18 02:01:05.499 - debug: backitup.0 (6421) detect backup file 1: iobroker_2020_11_17-09_51_33_backupiobroker.tar.gz
                          2020-11-18 02:01:05.500 - debug: backitup.0 (6421) detect backup file 2: iobroker_2020_11_17-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.500 - debug: backitup.0 (6421) detect backup file 3: iobroker_2020_11_11-09_37_06_backupiobroker.tar.gz
                          2020-11-18 02:01:05.501 - debug: backitup.0 (6421) detect backup file 4: iobroker_2020_11_11-09_23_21_backupiobroker.tar.gz
                          2020-11-18 02:01:05.501 - debug: backitup.0 (6421) detect backup file 5: iobroker_2020_11_03-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.502 - debug: backitup.0 (6421) detect backup file 6: iobroker_2020_10_31-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.502 - debug: backitup.0 (6421) detect backup file 7: iobroker_2020_10_23-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.503 - debug: backitup.0 (6421) detect backup file 8: iobroker_2020_10_20-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.503 - debug: backitup.0 (6421) detect backup file 9: iobroker_2020_10_18-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.503 - debug: backitup.0 (6421) detect backup file 10: iobroker_2020_10_16-02_00_20_backupiobroker.tar.gz
                          2020-11-18 02:01:05.504 - debug: backitup.0 (6421) detect backup file 11: iobroker_2020_10_14-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.504 - debug: backitup.0 (6421) detect backup file 12: iobroker_2020_10_13-13_21_49_backupiobroker.tar.gz
                          2020-11-18 02:01:05.505 - debug: backitup.0 (6421) detect backup file 13: iobroker_2020_10_13-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.505 - debug: backitup.0 (6421) detect backup file 14: iobroker_2020_10_12-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.505 - debug: backitup.0 (6421) detect backup file 15: iobroker_2020_10_11-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.506 - debug: backitup.0 (6421) detect backup file 16: iobroker_2020_10_10-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.506 - debug: backitup.0 (6421) detect backup file 17: iobroker_2020_10_09-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.507 - debug: backitup.0 (6421) detect backup file 18: iobroker_2020_10_08-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.507 - debug: backitup.0 (6421) detect backup file 19: iobroker_2020_10_07-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.508 - debug: backitup.0 (6421) detect backup file 20: iobroker_2020_10_06-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.508 - debug: backitup.0 (6421) detect backup file 21: iobroker_2020_10_05-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.508 - debug: backitup.0 (6421) detect backup file 22: iobroker_2020_10_04-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.509 - debug: backitup.0 (6421) detect backup file 23: iobroker_2020_10_03-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.509 - debug: backitup.0 (6421) detect backup file 24: iobroker_2020_10_02-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.510 - debug: backitup.0 (6421) detect backup file 25: iobroker_2020_10_01-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.510 - debug: backitup.0 (6421) detect backup file 26: iobroker_2020_09_30-07_40_09_backupiobroker.tar.gz
                          2020-11-18 02:01:05.510 - debug: backitup.0 (6421) detect backup file 27: iobroker_2020_09_30-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.511 - debug: backitup.0 (6421) detect backup file 28: iobroker_2020_09_29-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.511 - debug: backitup.0 (6421) detect backup file 29: iobroker_2020_09_28-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.512 - debug: backitup.0 (6421) detect backup file 30: iobroker_2020_09_27-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.512 - debug: backitup.0 (6421) detect backup file 31: iobroker_2020_09_26-02_00_10_backupiobroker.tar.gz
                          2020-11-18 02:01:05.512 - debug: backitup.0 (6421) detect backup file 32: iobroker_2020_09_25-14_11_27_backupiobroker.tar.gz
                          2020-11-18 02:01:05.516 - debug: backitup.0 (6421) detect last backup file: iobroker_2020_11_17-09_51_33_backupiobroker.tar.gz
                          Ich wäre über Hilfe dankbar.
                          LG Phil82
                          • P Phil82
                            Guten Morgen,
                            Node.js v10.22.0
                            NPM 6.14.6
                            Systeminfos
                            iobroker_server
                            Platform
                            linux
                            Betriebssystem
                            linux
                            Architektur
                            x64
                            CPUs
                            Geschwindigkeit
                            2165 MHz
                            Modell
                            RAM
                            3.85 GB
                            System Betriebszeit
                            1 T. 20:30:01
                            Node.js
                            NPM
                            6.14.6
                            Festplatte Größe
                            15.64 GB
                            Festplatte frei
                            8.32 GB
                            Anzahl der Adapter
                            312
                            Betriebszeit
                            1 T. 20:29:37
                            Aktive Instanzen
                            15
                            Hostname
                            iobroker_server
                            Log
                            LG Phil82
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #803
                            @Phil82
                            Es gibt mit der Cloud von Google leider Probleme, wo wir bereits ein Issue offen haben.
                            Wieviel Backups speicherst du in Drive? So wie ich das verstehe, sind es wohl zu viele Anfragen, was auf eine hohe Anzahl an Backups liegen könnte.
                            P 1 Antwort Letzte Antwort
                            • simatecS simatec
                              @Phil82
                              Phil82
                              #804
                              @simatec
                              Ich habe eben noch die Screenshots angehängt. Eigentlich 5 Stück sollen aufbehalten werden. Im Log stehen aber mehr, das verstehe ich nicht.
                              • P Phil82
                                @simatec
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #805
                                @Phil82
                                Schaue mal in deine Cloud und lösche die alten Backups ggfs mal händisch
                                • simatecS simatec
                                  @Phil82
                                  Phil82
                                  #806
                                  @simatec Okay, erledigt. Da waren ziemlich viele drin.
                                  • P Phil82
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #807
                                    @Phil82
                                    Schiebe nun mal ein Backup an und schaue, ob der Fehler weiterhin auftritt.
                                    Aktiviere auch das löschen alter Google Drive Backups in den Einstellungen.
                                    • B Bibo*13
                                      vielen Dank
                                      Bibo*13
                                      #808
                                      @Bibo-13 @simatec Was fehlt bei meiner Anfrage? oder ist es ein offensichtlicher Fehler im Ablauf der sich mir nicht erschließt?
                                      • B Bibo*13
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #809
                                        @Bibo-13
                                        Ich kann leider mit deiner Aussage nichts anfangen. Was kommt nicht an?
                                        Zeige mal deine Pushover Nachricht ...
                                        Der Log sieht OK aus
                                        • simatecS simatec
                                          @Bibo-13
                                          Bibo*13
                                          #810
                                          @simatec Hallo, es kommen an die Sicherung von redis und zigbee.0. Aber nicht die Iobroker Sicherung. Ich kann im Log auch nichts sehen. Aber auf dem NAS kommt kein Iobroker Backup an.
