  4. Adapterinstallation
Adapterinstallation
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
fehleradapterinstallationmqttneuling
17 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • Z ZER0
    Tabell hab ich angepasst.
    Bekomme leider auch beim cache clean eine Fehlermeldung.
    npm cache clean --force
    npm WARN using --force I sure hope you know what you are doing.
    npm ERR! Unexpected end of input
    npm ERR!     /home/iobroker/.npm/_logs/2020-11-10T18_50_05_370Z-debug.log
    0 info it worked if it ends with ok
    1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'cache', 'clean', '--force' ]
    2 info using npm@6.14.8
    3 info using node@v12.19.0
    4 warn using --force I sure hope you know what you are doing.
    5 verbose stack /usr/lib/node_modules/npm/node_modules/byline/lib/byline.js:155
    5 verbose stack
    5 verbose stack
    5 verbose stack
    5 verbose stack SyntaxError: Unexpected end of input
    5 verbose stack     at wrapSafe (internal/modules/cjs/loader.js:931:16)
    5 verbose stack     at Module._compile (internal/modules/cjs/loader.js:979:27)
    5 verbose stack     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1035:10)
    5 verbose stack     at Module.load (internal/modules/cjs/loader.js:879:32)
    5 verbose stack     at Function.Module._load (internal/modules/cjs/loader.js:724:14)
    5 verbose stack     at Module.require (internal/modules/cjs/loader.js:903:19)
    5 verbose stack     at require (internal/modules/cjs/helpers.js:74:18)
    5 verbose stack     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:18:16)
    5 verbose stack     at Module._compile (internal/modules/cjs/loader.js:1015:30)
    5 verbose stack     at Object.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:4:19)
    6 verbose cwd /opt/iobroker
    7 verbose Linux 5.4.72-v7+
    8 verbose argv "/usr/bin/node" "/usr/bin/npm" "cache" "clean" "--force"
    9 verbose node v12.19.0
    10 verbose npm  v6.14.8
    11 error Unexpected end of input
    12 verbose exit [ 1, true ]
    UncleSamU Offline
    UncleSamU Offline
    UncleSam
    @ZER0 sagte in Adapterinstallation:
    Meine Vermutung: korrupte Installation oder SD Karte kaputt. Ein Modul, das von NPM selbst verwendet wird, ist defekt.
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    • UncleSamU UncleSam
      @UncleSam
      Ja, das denke ich auch.
      • Z Offline
        Z Offline
        ZER0
        Dann wird mir wohl nichts anderes übrig bleiben als das System neu aufsetzen.
        • Z ZER0
          @ZER0
          Und das Speichermedium nicht wiederverwenden (wenn es denn wirklich daran liegt).
          Die Ausgabe von
          dmesg
          kann dich auch schlauer machen.
          Ein kaputte Installation von node könnte man vielleicht auch mit einem reinstall in den Griff kriegen.
          Aber ohne Rückmeldungen von dir kann man da gar nichts raten.
          Z 2 Antworten Letzte Antwort
            @ZER0
            Die Ausgabe von
            dmesg
            Z Offline
            Z Offline
            ZER0
            @Thomas-Braun
            Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l
            permitted by applicable law.
            Last login: Tue Nov 10 22:02:45 2020 from 192.168.178.35
            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.19.0
            /usr/bin/node
            v12.19.0
            /usr/bin/npm
            6.14.8
            nodejs:
              Installiert:           12.19.0-1nodesource1
              Installationskandidat: 12.19.0-1nodesource1
              Versionstabelle:
             *** 12.19.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                 10.21.0~dfsg-1~deb10u1+rpi1 500
            pi@raspberrypi:~ $
              @ZER0
              Die Ausgabe von
              dmesg
              Z Offline
              Z Offline
              ZER0
              @Thomas-Braun
              id)
              [    3.505467] systemd[1]: Detected architecture arm.
              [    3.531608] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c1:92:96
              [    3.605654] systemd[1]: Set hostname to <raspberrypi>.
              [    4.253086] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
              [    4.255550] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
              [    4.543541] random: systemd: uninitialized urandom read (16 bytes read)
              [    4.558089] random: systemd: uninitialized urandom read (16 bytes read)
              [    4.561694] systemd[1]: Created slice system-getty.slice.
              [    4.562460] random: systemd: uninitialized urandom read (16 bytes read)
              [    4.563182] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
              [    4.563624] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
              [    4.564381] systemd[1]: Listening on fsck to fsckd communication Socket.
              [    4.564516] systemd[1]: Reached target Swap.
              [    4.748055] i2c /dev entries driver
              [    5.345921] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              [    5.485858] systemd-journald[112]: Received request to flush runtime journal from PID 1
              [    6.145977] mc: Linux media interface: v0.10
              [    6.193301] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
              [    6.196040] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
              [    6.196061] [vc_sm_connected_init]: start
              [    6.198227] videodev: Linux video capture interface: v2.00
              [    6.207919] [vc_sm_connected_init]: installed successfully
              [    6.253264] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              [    6.282608] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              [    6.286182] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
              [    6.293691] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
              [    6.301465] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
              [    6.302132] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
              [    6.302813] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
              [    6.303302] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
              [    6.303335] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
              [    6.303360] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
              [    6.303379] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
              [    6.303417] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
              [    6.303669] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
              [    6.312726] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
              [    6.338662] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
              [    6.342013] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
              [    6.342063] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
              [    6.353798] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
              [    6.353959] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
              [    6.377515] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
              [    6.377747] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
              [    6.529049] bcm2835_audio bcm2835_audio: card created with 8 channels
              [    6.943846] cfg80211: Loading compiled-in X.509 certificates for regulatory database
              [    7.079946] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
              [    7.218268] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
              [    7.240485] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
              [    7.240804] usbcore: registered new interface driver brcmfmac
              [    7.269751] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.txt failed with error -2
              [    7.484306] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
              [    7.484447] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
              [    7.486207] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
              [   10.029037] random: crng init done
              [   10.029056] random: 7 urandom warning(s) missed due to ratelimiting
              [   10.126250] uart-pl011 3f201000.serial: no DMA platform data
              [   10.391452] 8021q: 802.1Q VLAN Support v1.8
              [   11.927214] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
              [   12.054557] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
              [   12.797219] Under-voltage detected! (0x00050005)
              [   12.869868] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
              [   14.313535] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xDDE1
              [   16.791420] Bluetooth: Core ver 2.22
              [   16.791489] NET: Registered protocol family 31
              [   16.791495] Bluetooth: HCI device and connection manager initialized
              [   16.791516] Bluetooth: HCI socket layer initialized
              [   16.791526] Bluetooth: L2CAP socket layer initialized
              [   16.791543] Bluetooth: SCO socket layer initialized
              [   16.800731] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
              [   17.385809] Bluetooth: HCI UART driver ver 2.3
              [   17.385823] Bluetooth: HCI UART protocol H4 registered
              [   17.385872] Bluetooth: HCI UART protocol Three-wire (H5) registered
              [   17.386032] Bluetooth: HCI UART protocol Broadcom registered
              [   18.246173] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
              [   18.246197] Bluetooth: BNEP filters: protocol multicast
              [   18.246244] Bluetooth: BNEP socket layer initialized
              [   18.404787] Bluetooth: RFCOMM TTY layer initialized
              [   18.404825] Bluetooth: RFCOMM socket layer initialized
              [   18.404868] Bluetooth: RFCOMM ver 1.11
              [   23.197044] Voltage normalised (0x00000000)
              [   28.168887] fuse: init (API version 7.31)
              [   37.757225] Under-voltage detected! (0x00050005)
              [   43.997129] Voltage normalised (0x00000000)
              [   46.077178] Under-voltage detected! (0x00050005)
              [   50.237097] Voltage normalised (0x00000000)
              [  478.720553] rpi_firmware_get_throttled: 6 callbacks suppressed
              [  478.720565] Under-voltage detected! (0x00050005)
              [  484.960422] rpi_firmware_get_throttled: 6 callbacks suppressed
              [  484.960429] Voltage normalised (0x00000000)
              [  487.040523] Under-voltage detected! (0x00050005)
              [  493.280470] Voltage normalised (0x00000000)
              [  932.162176] Under-voltage detected! (0x00050005)
              [  936.321265] Voltage normalised (0x00000000)
              [  938.401261] Under-voltage detected! (0x00050005)
              [  942.561232] Voltage normalised (0x00000000)
              [  950.881543] Under-voltage detected! (0x00050005)
              [  957.121305] Voltage normalised (0x00000000)
              [ 1352.325392] rpi_firmware_get_throttled: 2 callbacks suppressed
              [ 1352.325402] Under-voltage detected! (0x00050005)
              [ 1356.485384] rpi_firmware_get_throttled: 2 callbacks suppressed
              [ 1356.485392] Voltage normalised (0x00000000)
              [ 1832.808769] Under-voltage detected! (0x00050005)
              [ 1836.968670] Voltage normalised (0x00000000)
              [ 2011.689642] Under-voltage detected! (0x00050005)
              [ 2017.930032] Voltage normalised (0x00000000)
              [ 2373.611906] Under-voltage detected! (0x00050005)
              [ 2377.771936] Voltage normalised (0x00000000)
              [ 3573.778806] Under-voltage detected! (0x00050005)
              [ 3577.938813] Voltage normalised (0x00000000)
              [ 4339.223783] Under-voltage detected! (0x00050005)
              [ 4343.383836] Voltage normalised (0x00000000)
              [ 4351.703869] Under-voltage detected! (0x00050005)
              [ 4357.943891] Voltage normalised (0x00000000)
              [ 5013.148246] Under-voltage detected! (0x00050005)
              [ 5017.308261] Voltage normalised (0x00000000)
              [ 5073.468619] Under-voltage detected! (0x00050005)
              [ 5077.628551] Voltage normalised (0x00000000)
              [ 5252.349839] Under-voltage detected! (0x00050005)
              [ 5256.509858] Voltage normalised (0x00000000)
              [ 5433.310827] Under-voltage detected! (0x00050005)
              [ 5437.470880] Voltage normalised (0x00000000)
              [ 6213.315728] Under-voltage detected! (0x00050005)
              [ 6217.475846] Voltage normalised (0x00000000)
              [ 7232.522948] Under-voltage detected! (0x00050005)
              [ 7236.683003] Voltage normalised (0x00000000)
              [ 7292.843341] Under-voltage detected! (0x00050005)
              [ 7297.003361] Voltage normalised (0x00000000)
              [ 7652.685629] Under-voltage detected! (0x00050005)
              [ 7656.845672] Voltage normalised (0x00000000)
              [ 8108.208490] Under-voltage detected! (0x00050005)
              [ 8112.368499] Voltage normalised (0x00000000)
              [ 8811.253552] Under-voltage detected! (0x00050005)
              [ 8815.414183] Voltage normalised (0x00000000)
              [ 9391.577317] Under-voltage detected! (0x00050005)
              [ 9395.737325] Voltage normalised (0x00000000)
              [ 9992.701182] Under-voltage detected! (0x00050005)
              [ 9996.861224] Voltage normalised (0x00000000)
              [10113.341991] Under-voltage detected! (0x00050005)
              [10117.501916] Voltage normalised (0x00000000)
              [11253.190193] Under-voltage detected! (0x00050005)
              [11257.350103] Voltage normalised (0x00000000)
              [12513.678825] Under-voltage detected! (0x00050005)
              [12517.838782] Voltage normalised (0x00000000)
              [12992.082283] Under-voltage detected! (0x00050005)
              [12998.322336] Voltage normalised (0x00000000)
              [13412.245118] Under-voltage detected! (0x00050005)
              [13416.405082] Voltage normalised (0x00000000)
              [14073.689631] Under-voltage detected! (0x00050005)
              [14077.849582] Voltage normalised (0x00000000)
              [14134.009994] Under-voltage detected! (0x00050005)
              [14138.170078] Voltage normalised (0x00000000)
              [15273.856285] Under-voltage detected! (0x00050005)
              [15278.016217] Voltage normalised (0x00000000)
              [16534.344531] Under-voltage detected! (0x00050005)
              [16538.504572] Voltage normalised (0x00000000)
              [17923.795142] Under-voltage detected! (0x00050005)
              [17927.955261] Voltage normalised (0x00000000)
              [18034.035919] Under-voltage detected! (0x00050005)
              [18038.195934] Voltage normalised (0x00000000)
              [18152.596718] Under-voltage detected! (0x00050005)
              [18156.756781] Voltage normalised (0x00000000)
              [18872.281982] Under-voltage detected! (0x00050005)
              [18876.441974] Voltage normalised (0x00000000)
              [20673.574695] Under-voltage detected! (0x00050005)
              [20677.734696] Voltage normalised (0x00000000)
              [21272.618916] Under-voltage detected! (0x00050005)
              [21276.778899] Voltage normalised (0x00000000)
              [22173.265161] Under-voltage detected! (0x00050005)
              [22177.425143] Voltage normalised (0x00000000)
              [22233.585578] Under-voltage detected! (0x00050005)
              [22237.745560] Voltage normalised (0x00000000)
              [22293.905962] Under-voltage detected! (0x00050005)
              [22298.066057] Voltage normalised (0x00000000)
              [22653.748060] Under-voltage detected! (0x00050005)
              [22657.907893] Voltage normalised (0x00000000)
              [23494.071733] Under-voltage detected! (0x00050005)
              [23498.231721] Voltage normalised (0x00000000)
              [23612.632434] Under-voltage detected! (0x00050005)
              [23616.792412] Voltage normalised (0x00000000)
              [23620.952496] Under-voltage detected! (0x00050005)
              [23625.112539] Voltage normalised (0x00000000)
              [25112.321806] rpi_firmware_get_throttled: 2 callbacks suppressed
              [25112.321816] Under-voltage detected! (0x00050005)
              [25118.561806] rpi_firmware_get_throttled: 2 callbacks suppressed
              [25118.561813] Voltage normalised (0x00000000)
              [25172.642216] Under-voltage detected! (0x00050005)
              [25176.802233] Voltage normalised (0x00000000)
              [25232.962569] Under-voltage detected! (0x00050005)
              [25237.122583] Voltage normalised (0x00000000)
              [25413.924056] rpi_firmware_get_throttled: 1 callbacks suppressed
              [25413.924066] Under-voltage detected! (0x00050005)
              [25474.244218] Under-voltage detected! (0x00050005)
              [25476.324122] rpi_firmware_get_throttled: 2 callbacks suppressed
              [25476.324130] Voltage normalised (0x00000000)
              [25532.484494] Under-voltage detected! (0x00050005)
              [25538.724532] Voltage normalised (0x00000000)
              [25596.965024] Voltage normalised (0x00000000)
              [25773.766095] rpi_firmware_get_throttled: 3 callbacks suppressed
              [25773.766105] Under-voltage detected! (0x00050005)
              [25777.926061] rpi_firmware_get_throttled: 2 callbacks suppressed
              [25777.926069] Voltage normalised (0x00000000)
              [25834.086417] Under-voltage detected! (0x00050005)
              [25838.246443] Voltage normalised (0x00000000)
              [25892.326787] Under-voltage detected! (0x00050005)
              [25898.566836] Voltage normalised (0x00000000)
              [26133.608336] rpi_firmware_get_throttled: 4 callbacks suppressed
              [26133.608345] Under-voltage detected! (0x00050005)
              [26137.768352] rpi_firmware_get_throttled: 4 callbacks suppressed
              [26137.768361] Voltage normalised (0x00000000)
              [26193.928812] Under-voltage detected! (0x00050005)
              [26198.088740] Voltage normalised (0x00000000)
              [26252.169134] Under-voltage detected! (0x00050005)
              [26258.409121] Voltage normalised (0x00000000)
              [26493.450604] rpi_firmware_get_throttled: 3 callbacks suppressed
              [26493.450614] Under-voltage detected! (0x00050005)
              [26497.610709] rpi_firmware_get_throttled: 3 callbacks suppressed
              [26497.610719] Voltage normalised (0x00000000)
              [26553.770980] Under-voltage detected! (0x00050005)
              [26557.931040] Voltage normalised (0x00000000)
              [26614.091415] Under-voltage detected! (0x00050005)
              [26618.251430] Voltage normalised (0x00000000)
              [26978.094567] Under-voltage detected! (0x00050005)
              [26982.254588] Voltage normalised (0x00000000)
              [27034.255030] Under-voltage detected! (0x00050005)
              [27038.415047] Voltage normalised (0x00000000)
              [28292.664236] Under-voltage detected! (0x00050005)
              [28298.904287] Voltage normalised (0x00000000)
              [29043.548502] Under-voltage detected! (0x00050005)
              [29047.718604] Voltage normalised (0x00000000)
              [29636.351897] Under-voltage detected! (0x00050005)
              [29640.511877] Voltage normalised (0x00000000)
              [29792.352898] Under-voltage detected! (0x00050005)
              [29798.592861] Voltage normalised (0x00000000)
              [30753.318924] Under-voltage detected! (0x00050005)
              [30757.478917] Voltage normalised (0x00000000)
              [32080.367226] Under-voltage detected! (0x00050005)
              [32084.527235] Voltage normalised (0x00000000)
              [32253.008397] Under-voltage detected! (0x00050005)
              [32257.168350] Voltage normalised (0x00000000)
              [32612.850704] Under-voltage detected! (0x00050005)
              [32617.010639] Voltage normalised (0x00000000)
              [32631.570788] Under-voltage detected! (0x00050005)
              [32637.810808] Voltage normalised (0x00000000)
              [33035.094205] Under-voltage detected! (0x00050005)
              [33039.254299] Voltage normalised (0x00000000)
              [33153.655116] Under-voltage detected! (0x00050005)
              [33157.815219] Voltage normalised (0x00000000)
              [33301.336318] Under-voltage detected! (0x00050005)
              [33305.496431] Voltage normalised (0x00000000)
              [33513.497989] rpi_firmware_get_throttled: 1 callbacks suppressed
              [33513.497998] Under-voltage detected! (0x00050005)
              [33517.657994] rpi_firmware_get_throttled: 1 callbacks suppressed
              [33517.658003] Voltage normalised (0x00000000)
              [34112.542362] Under-voltage detected! (0x00050005)
              [34118.782458] Voltage normalised (0x00000000)
              [34374.624208] Under-voltage detected! (0x00050005)
              [34380.864329] Voltage normalised (0x00000000)
              [34532.705281] Under-voltage detected! (0x00050005)
              [34536.865315] Voltage normalised (0x00000000)
              [35420.871296] Under-voltage detected! (0x00050005)
              [35425.031326] Voltage normalised (0x00000000)
              [35974.155018] Under-voltage detected! (0x00050005)
              [35978.315034] Voltage normalised (0x00000000)
              [37114.002568] Under-voltage detected! (0x00050005)
              [37118.162573] Voltage normalised (0x00000000)
              [37652.725926] Under-voltage detected! (0x00050005)
              [37656.885955] Voltage normalised (0x00000000)
              [37773.366769] Under-voltage detected! (0x00050005)
              [37777.526752] Voltage normalised (0x00000000)
              [38253.849947] Under-voltage detected! (0x00050005)
              [38258.009979] Voltage normalised (0x00000000)
              [38913.214366] Under-voltage detected! (0x00050005)
              [38917.374403] Voltage normalised (0x00000000)
              [39154.495758] Under-voltage detected! (0x00050005)
              [39158.655750] Voltage normalised (0x00000000)
              [39397.857313] Under-voltage detected! (0x00050005)
              [39402.017326] Voltage normalised (0x00000000)
              [40654.185574] Under-voltage detected! (0x00050005)
              [40658.345535] Voltage normalised (0x00000000)
              [41138.828326] Under-voltage detected! (0x00050005)
              [41145.068317] Voltage normalised (0x00000000)
              [42393.075345] Under-voltage detected! (0x00050005)
              [42397.235284] Voltage normalised (0x00000000)
              [42915.158506] Under-voltage detected! (0x00050005)
              [42921.398544] Voltage normalised (0x00000000)
              [43472.602016] Under-voltage detected! (0x00050005)
              [43478.842489] Voltage normalised (0x00000000)
              [44109.085988] Under-voltage detected! (0x00050005)
              [44115.326205] Voltage normalised (0x00000000)
              [45334.214383] Under-voltage detected! (0x00050005)
              [45338.374425] Voltage normalised (0x00000000)
              [46474.062856] Under-voltage detected! (0x00050005)
              [46478.222838] Voltage normalised (0x00000000)
              [46490.702891] Under-voltage detected! (0x00050005)
              [46494.862889] Voltage normalised (0x00000000)
              [46865.105489] Under-voltage detected! (0x00050005)
              [46869.265570] Voltage normalised (0x00000000)
              [46954.546080] Under-voltage detected! (0x00050005)
              [46958.706108] Voltage normalised (0x00000000)
              [47073.106880] Under-voltage detected! (0x00050005)
              [47077.267325] Voltage normalised (0x00000000)
              [47493.270027] Under-voltage detected! (0x00050005)
              [47497.430002] Voltage normalised (0x00000000)
              [47778.232064] Under-voltage detected! (0x00050005)
              [47782.392060] Voltage normalised (0x00000000)
              [48633.117993] Under-voltage detected! (0x00050005)
              [48637.278090] Voltage normalised (0x00000000)
              [50253.449026] Under-voltage detected! (0x00050005)
              [50257.609079] Voltage normalised (0x00000000)
              [51813.459389] Under-voltage detected! (0x00050005)
              [51817.619396] Voltage normalised (0x00000000)
              [53252.828962] Under-voltage detected! (0x00050005)
              [53259.069997] Voltage normalised (0x00000000)
              [53373.469685] Under-voltage detected! (0x00050005)
              [53377.629597] Voltage normalised (0x00000000)
              [55054.120568] Under-voltage detected! (0x00050005)
              [55058.280513] Voltage normalised (0x00000000)
              [56013.005870] Under-voltage detected! (0x00050005)
              [56017.165851] Voltage normalised (0x00000000)
              [56614.129486] Under-voltage detected! (0x00050005)
              [56618.289502] Voltage normalised (0x00000000)
              [56674.449853] Under-voltage detected! (0x00050005)
              [56678.609868] Voltage normalised (0x00000000)
              [58294.780965] Under-voltage detected! (0x00050005)
              [58298.940941] Voltage normalised (0x00000000)
              [58506.942484] Under-voltage detected! (0x00050005)
              [58511.102513] Voltage normalised (0x00000000)
              [59734.149581] Under-voltage detected! (0x00050005)
              [59738.309534] Voltage normalised (0x00000000)
              [59763.269646] Under-voltage detected! (0x00050005)
              [59769.509597] Voltage normalised (0x00000000)
              [61231.757599] Under-voltage detected! (0x00050005)
              [61235.917580] Voltage normalised (0x00000000)
              [61294.157973] Under-voltage detected! (0x00050005)
              [61298.318016] Voltage normalised (0x00000000)
              [61533.359357] Under-voltage detected! (0x00050005)
              [61537.519376] Voltage normalised (0x00000000)
              [62914.487561] Under-voltage detected! (0x00050005)
              [62918.647586] Voltage normalised (0x00000000)
              [62974.807925] Under-voltage detected! (0x00050005)
              [62978.967930] Voltage normalised (0x00000000)
              [63214.009344] Under-voltage detected! (0x00050005)
              [63218.169389] Voltage normalised (0x00000000)
              [63634.172536] Under-voltage detected! (0x00050005)
              [63638.332542] Voltage normalised (0x00000000)
              [64414.179496] Under-voltage detected! (0x00050005)
              [64418.339523] Voltage normalised (0x00000000)
              [64534.820428] Under-voltage detected! (0x00050005)
              [64538.980452] Voltage normalised (0x00000000)
              [65793.228820] Under-voltage detected! (0x00050005)
              [65799.468855] Voltage normalised (0x00000000)
              [65814.028933] Under-voltage detected! (0x00050005)
              [65818.188953] Voltage normalised (0x00000000)
              [65913.869443] Under-voltage detected! (0x00050005)
              [65918.029468] Voltage normalised (0x00000000)
              [66334.031917] Under-voltage detected! (0x00050005)
              [66338.191964] Voltage normalised (0x00000000)
              [66394.352274] Under-voltage detected! (0x00050005)
              [66398.512287] Voltage normalised (0x00000000)
              [66454.672678] Under-voltage detected! (0x00050005)
              [66458.832659] Voltage normalised (0x00000000)
              [66754.194558] rpi_firmware_get_throttled: 3 callbacks suppressed
              [66754.194569] Under-voltage detected! (0x00050005)
              [66758.354565] rpi_firmware_get_throttled: 3 callbacks suppressed
              [66758.354574] Voltage normalised (0x00000000)
              [66814.514895] Under-voltage detected! (0x00050005)
              [66818.674943] Voltage normalised (0x00000000)
              [66874.835303] Under-voltage detected! (0x00050005)
              [66878.995301] Voltage normalised (0x00000000)
              [67114.036837] rpi_firmware_get_throttled: 3 callbacks suppressed
              [67114.036846] Under-voltage detected! (0x00050005)
              [67118.196827] rpi_firmware_get_throttled: 3 callbacks suppressed
              [67118.196836] Voltage normalised (0x00000000)
              [67174.357179] Under-voltage detected! (0x00050005)
              [67178.517249] Voltage normalised (0x00000000)
              [67234.677803] Under-voltage detected! (0x00050005)
              [67238.837600] Voltage normalised (0x00000000)
              [67473.879150] rpi_firmware_get_throttled: 3 callbacks suppressed
              [67473.879159] Under-voltage detected! (0x00050005)
              [67478.039141] rpi_firmware_get_throttled: 3 callbacks suppressed
              [67478.039150] Voltage normalised (0x00000000)
              [67534.199536] Under-voltage detected! (0x00050005)
              [67538.359552] Voltage normalised (0x00000000)
              [67594.519936] Under-voltage detected! (0x00050005)
              [67598.679946] Voltage normalised (0x00000000)
              [67856.601208] rpi_firmware_get_throttled: 1 callbacks suppressed
              [67856.601218] Under-voltage detected! (0x00050005)
              [67860.761185] rpi_firmware_get_throttled: 1 callbacks suppressed
              [67860.761194] Voltage normalised (0x00000000)
              [68374.524051] Under-voltage detected! (0x00050005)
              [68378.684127] Voltage normalised (0x00000000)
              [68902.847204] Under-voltage detected! (0x00050005)
              [68907.007234] Voltage normalised (0x00000000)
              [70533.579005] Under-voltage detected! (0x00050005)
              [70537.738985] Voltage normalised (0x00000000)
              [70552.299155] Under-voltage detected! (0x00050005)
              [70556.459174] Voltage normalised (0x00000000)
              [71074.382736] Under-voltage detected! (0x00050005)
              [71078.542808] Voltage normalised (0x00000000)
              [72033.268364] Under-voltage detected! (0x00050005)
              [72039.508358] Voltage normalised (0x00000000)
              [72513.750989] Under-voltage detected! (0x00050005)
              [72517.910902] Voltage normalised (0x00000000)
              [72755.032410] Under-voltage detected! (0x00050005)
              [72759.192472] Voltage normalised (0x00000000)
              [73389.436123] Under-voltage detected! (0x00050005)
              [73393.596174] Voltage normalised (0x00000000)
              [73894.879692] Under-voltage detected! (0x00050005)
              [73899.039761] Voltage normalised (0x00000000)
              [74681.125747] Under-voltage detected! (0x00050005)
              [74685.285825] Voltage normalised (0x00000000)
              [75446.571017] Under-voltage detected! (0x00050005)
              [75452.811048] Voltage normalised (0x00000000)
              [75459.051131] Under-voltage detected! (0x00050005)
              [75463.211105] Voltage normalised (0x00000000)
              [75633.772349] Under-voltage detected! (0x00050005)
              [75637.932265] Voltage normalised (0x00000000)
              [75937.453780] Under-voltage detected! (0x00050005)
              [75941.613830] Voltage normalised (0x00000000)
              [77133.459843] Under-voltage detected! (0x00050005)
              [77139.699843] Voltage normalised (0x00000000)
              [77314.420891] Under-voltage detected! (0x00050005)
              [77318.580885] Voltage normalised (0x00000000)
              [78574.909975] Under-voltage detected! (0x00050005)
              [78579.070006] Voltage normalised (0x00000000)
              [79053.313322] Under-voltage detected! (0x00050005)
              [79059.553349] Voltage normalised (0x00000000)
              [79157.314021] Under-voltage detected! (0x00050005)
              [79161.474044] Voltage normalised (0x00000000)
              [79473.476143] Under-voltage detected! (0x00050005)
              [79479.716140] Voltage normalised (0x00000000)
              [79646.117259] Under-voltage detected! (0x00050005)
              [79650.277340] Voltage normalised (0x00000000)
              [79893.638945] Under-voltage detected! (0x00050005)
              [79899.878933] Voltage normalised (0x00000000)
              [79953.959339] Under-voltage detected! (0x00050005)
              [79958.119369] Voltage normalised (0x00000000)
              [80794.285518] Under-voltage detected! (0x00050005)
              [80798.445451] Voltage normalised (0x00000000)
              [82233.655410] Under-voltage detected! (0x00050005)
              [82239.895488] Voltage normalised (0x00000000)
              [82474.937165] Under-voltage detected! (0x00050005)
              [82479.097259] Voltage normalised (0x00000000)
              [83013.660967] Under-voltage detected! (0x00050005)
              [83019.900992] Voltage normalised (0x00000000)
              [84575.749794] Under-voltage detected! (0x00050005)
              [84579.909816] Voltage normalised (0x00000000)
              [84754.630701] Under-voltage detected! (0x00050005)
              [84758.790726] Voltage normalised (0x00000000)
              [84933.511709] Under-voltage detected! (0x00050005)
              [84937.671599] Voltage normalised (0x00000000)
              [84941.831734] Under-voltage detected! (0x00050005)
              [84945.991632] Voltage normalised (0x00000000)
              [84954.311844] Under-voltage detected! (0x00050005)
              [84958.471763] Voltage normalised (0x00000000)
              [85235.113327] Under-voltage detected! (0x00050005)
              [85239.273375] Voltage normalised (0x00000000)
              [85773.836432] Under-voltage detected! (0x00050005)
              [85780.076487] Voltage normalised (0x00000000)
              [85894.477194] Under-voltage detected! (0x00050005)
              [85898.637245] Voltage normalised (0x00000000)
              [86133.678855] Under-voltage detected! (0x00050005)
              [86139.918917] Voltage normalised (0x00000000)
              [86193.999410] Under-voltage detected! (0x00050005)
              [86200.239359] Voltage normalised (0x00000000)
              [86555.922056] Under-voltage detected! (0x00050005)
              [86560.082041] Voltage normalised (0x00000000)
              [87350.487404] Under-voltage detected! (0x00050005)
              [87358.807358] Voltage normalised (0x00000000)
              [87362.967455] Under-voltage detected! (0x00050005)
              [87371.287515] Voltage normalised (0x00000000)
              [87394.167660] Under-voltage detected! (0x00050005)
              [87398.327687] Voltage normalised (0x00000000)
              [88084.732079] rpi_firmware_get_throttled: 1 callbacks suppressed
              [88084.732089] Under-voltage detected! (0x00050005)
              [88090.972186] rpi_firmware_get_throttled: 1 callbacks suppressed
              [88090.972195] Voltage normalised (0x00000000)
              [88473.694964] Under-voltage detected! (0x00050005)
              [88479.935007] Voltage normalised (0x00000000)
              [88837.697510] Under-voltage detected! (0x00050005)
              [88843.937542] Voltage normalised (0x00000000)
              [89155.939648] Under-voltage detected! (0x00050005)
              [89162.179643] Voltage normalised (0x00000000)
              [89494.981860] Under-voltage detected! (0x00050005)
              [89499.141852] Voltage normalised (0x00000000)
              [91054.992301] Under-voltage detected! (0x00050005)
              [91059.152338] Voltage normalised (0x00000000)
              [92373.720451] Under-voltage detected! (0x00050005)
              [92379.960517] Voltage normalised (0x00000000)
              [92434.040775] Under-voltage detected! (0x00050005)
              [92438.200747] Voltage normalised (0x00000000)
              [93875.488699] Under-voltage detected! (0x00050005)
              [93879.648655] Voltage normalised (0x00000000)
              [94175.010463] Under-voltage detected! (0x00050005)
              [94179.170438] Voltage normalised (0x00000000)
              [94235.330841] Under-voltage detected! (0x00050005)
              [94239.490839] Voltage normalised (0x00000000)
              [94414.212505] Under-voltage detected! (0x00050005)
              [94418.372578] Voltage normalised (0x00000000)
              [95574.861190] Under-voltage detected! (0x00050005)
              [95579.021271] Voltage normalised (0x00000000)
              [95614.381563] Under-voltage detected! (0x00050005)
              [95620.621504] Voltage normalised (0x00000000)
              [96591.988429] Under-voltage detected! (0x00050005)
              [96598.228478] Voltage normalised (0x00000000)
              [96619.028661] Under-voltage detected! (0x00050005)
              [96623.188712] Voltage normalised (0x00000000)
              [97355.353962] Under-voltage detected! (0x00050005)
              [97359.513936] Voltage normalised (0x00000000)
              [97833.757235] Under-voltage detected! (0x00050005)
              [97839.997319] Voltage normalised (0x00000000)
              [98855.042868] Under-voltage detected! (0x00050005)
              [98859.202809] Voltage normalised (0x00000000)
              [98915.363136] Under-voltage detected! (0x00050005)
              [98919.523136] Voltage normalised (0x00000000)
              [99393.765806] Under-voltage detected! (0x00050005)
              [99400.005859] Voltage normalised (0x00000000)
              [101405.139302] Under-voltage detected! (0x00050005)
              [101411.379331] Voltage normalised (0x00000000)
              [101914.742857] Under-voltage detected! (0x00050005)
              [101918.902732] Voltage normalised (0x00000000)
              [102035.383534] Under-voltage detected! (0x00050005)
              [102039.543569] Voltage normalised (0x00000000)
              [102095.703924] Under-voltage detected! (0x00050005)
              [102099.864007] Voltage normalised (0x00000000)
              [102574.107396] rpi_firmware_get_throttled: 1 callbacks suppressed
              [102574.107405] Under-voltage detected! (0x00050005)
              [102578.267440] rpi_firmware_get_throttled: 1 callbacks suppressed
              [102578.267448] Voltage normalised (0x00000000)
              [102933.950302] Under-voltage detected! (0x00050005)
              [102940.190317] Voltage normalised (0x00000000)
              [103414.433843] Under-voltage detected! (0x00050005)
              [103418.593863] Voltage normalised (0x00000000)
              [103535.074684] Under-voltage detected! (0x00050005)
              [103539.234700] Voltage normalised (0x00000000)
              [103595.395143] Under-voltage detected! (0x00050005)
              [103599.555153] Voltage normalised (0x00000000)
              [103894.917412] Under-voltage detected! (0x00050005)
              [103899.077190] Voltage normalised (0x00000000)
              [104554.281610] Under-voltage detected! (0x00050005)
              [104558.441653] Voltage normalised (0x00000000)
              [104674.922086] Under-voltage detected! (0x00050005)
              [104679.082096] Voltage normalised (0x00000000)
              [104735.242203] Under-voltage detected! (0x00050005)
              [104739.402251] Voltage normalised (0x00000000)
              [105095.084017] Under-voltage detected! (0x00050005)
              [105099.244063] Voltage normalised (0x00000000)
              [105155.404427] Under-voltage detected! (0x00050005)
              [105159.564415] Voltage normalised (0x00000000)
              [105814.768292] Under-voltage detected! (0x00050005)
              [105818.928269] Voltage normalised (0x00000000)
              [105875.088675] Under-voltage detected! (0x00050005)
              [105879.248615] Voltage normalised (0x00000000)
              [106295.251323] Under-voltage detected! (0x00050005)
              [106299.411339] Voltage normalised (0x00000000)
              [106415.892106] Under-voltage detected! (0x00050005)
              [106420.052093] Voltage normalised (0x00000000)
              [106474.132514] Under-voltage detected! (0x00050005)
              [106478.292427] Voltage normalised (0x00000000)
              [106655.093985] rpi_firmware_get_throttled: 1 callbacks suppressed
              [106655.093994] Under-voltage detected! (0x00050005)
              [106659.254042] rpi_firmware_get_throttled: 1 callbacks suppressed
              [106659.254051] Voltage normalised (0x00000000)
              [106894.296041] Under-voltage detected! (0x00050005)
              [106898.456083] Voltage normalised (0x00000000)
              [107135.577960] Under-voltage detected! (0x00050005)
              [107139.737997] Voltage normalised (0x00000000)
              [107195.898454] Under-voltage detected! (0x00050005)
              [107200.058437] Voltage normalised (0x00000000)
              [107366.459688] Under-voltage detected! (0x00050005)
              [107372.699733] Voltage normalised (0x00000000)
              [107674.301873] Under-voltage detected! (0x00050005)
              [107680.541951] Voltage normalised (0x00000000)
              [107794.942853] Under-voltage detected! (0x00050005)
              [107799.102714] Voltage normalised (0x00000000)
              [108154.785214] Under-voltage detected! (0x00050005)
              [108158.945223] Voltage normalised (0x00000000)
              [108275.426074] Under-voltage detected! (0x00050005)
              [108279.586128] Voltage normalised (0x00000000)
              [108454.307325] Under-voltage detected! (0x00050005)
              [108460.547343] Voltage normalised (0x00000000)
              [108574.948157] Under-voltage detected! (0x00050005)
              [108579.108176] Voltage normalised (0x00000000)
              [108635.268618] Under-voltage detected! (0x00050005)
              [108639.428648] Voltage normalised (0x00000000)
              [108755.909558] Under-voltage detected! (0x00050005)
              [108995.111304] Under-voltage detected! (0x00050005)
              [108999.271348] rpi_firmware_get_throttled: 1 callbacks suppressed
              [108999.271356] Voltage normalised (0x00000000)
              [109055.431752] Under-voltage detected! (0x00050005)
              [109059.591767] Voltage normalised (0x00000000)
              [109388.234195] Under-voltage detected! (0x00050005)
              [109392.394163] Voltage normalised (0x00000000)
              [109535.915240] Under-voltage detected! (0x00050005)
              [109540.075228] Voltage normalised (0x00000000)
              [109594.155645] Under-voltage detected! (0x00050005)
              [109600.395989] Voltage normalised (0x00000000)
              [109895.757748] Under-voltage detected! (0x00050005)
              [109899.917773] Voltage normalised (0x00000000)
              [109956.078195] Under-voltage detected! (0x00050005)
              [109960.238193] Voltage normalised (0x00000000)
              [110022.638673] Under-voltage detected! (0x00050005)
              [110026.798708] Voltage normalised (0x00000000)
              [110315.920705] Under-voltage detected! (0x00050005)
              [110320.080768] Voltage normalised (0x00000000)
              [110374.161116] Under-voltage detected! (0x00050005)
              [110378.321234] Voltage normalised (0x00000000)
              [110615.442768] Under-voltage detected! (0x00050005)
              [110619.602782] Voltage normalised (0x00000000)
              [110854.643852] Under-voltage detected! (0x00050005)
              [110858.813739] Voltage normalised (0x00000000)
              [111035.604798] Under-voltage detected! (0x00050005)
              [111039.764743] Voltage normalised (0x00000000)
              [111395.446706] Under-voltage detected! (0x00050005)
              [111399.606856] Voltage normalised (0x00000000)
              [112414.653048] Under-voltage detected! (0x00050005)
              [112418.813105] Voltage normalised (0x00000000)
              [114034.985465] Under-voltage detected! (0x00050005)
              [114039.145460] Voltage normalised (0x00000000)
              [115054.191761] Under-voltage detected! (0x00050005)
              [115060.431781] Voltage normalised (0x00000000)
              [115594.994813] Under-voltage detected! (0x00050005)
              [115599.154752] Voltage normalised (0x00000000)
              [115715.635537] Under-voltage detected! (0x00050005)
              [115719.795580] Voltage normalised (0x00000000)
              [116489.400556] Under-voltage detected! (0x00050005)
              [116493.560488] Voltage normalised (0x00000000)
              [116674.522639] Under-voltage detected! (0x00050005)
              [116680.761678] Voltage normalised (0x00000000)
              [116915.803584] Under-voltage detected! (0x00050005)
              [116919.963600] Voltage normalised (0x00000000)
              [117514.848438] Under-voltage detected! (0x00050005)
              [117519.008486] Voltage normalised (0x00000000)
              [118294.854106] Under-voltage detected! (0x00050005)
              [118299.014111] Voltage normalised (0x00000000)
              [118594.376326] Under-voltage detected! (0x00050005)
              [118600.616241] Voltage normalised (0x00000000)
              [120455.989304] Under-voltage detected! (0x00050005)
              [120460.149348] Voltage normalised (0x00000000)
              [120634.870663] Under-voltage detected! (0x00050005)
              [120639.030530] Voltage normalised (0x00000000)
              [121115.353058] Under-voltage detected! (0x00050005)
              [121119.513039] Voltage normalised (0x00000000)
              [121895.357252] Under-voltage detected! (0x00050005)
              [121899.517265] Voltage normalised (0x00000000)
              [121955.677628] Under-voltage detected! (0x00050005)
              [121959.837669] Voltage normalised (0x00000000)
              [122856.323305] Under-voltage detected! (0x00050005)
              [122858.403279] Voltage normalised (0x00000000)
              [122906.243594] Under-voltage detected! (0x00050005)
              [122910.403867] Voltage normalised (0x00000000)
              [122966.564123] Under-voltage detected! (0x00050005)
              [122970.724141] Voltage normalised (0x00000000)
              [123160.005567] rpi_firmware_get_throttled: 1 callbacks suppressed
              [123160.005573] Voltage normalised (0x00000000)
              [123395.047359] rpi_firmware_get_throttled: 2 callbacks suppressed
              [123395.047368] Under-voltage detected! (0x00050005)
              [123399.207398] Voltage normalised (0x00000000)
              [123455.367817] Under-voltage detected! (0x00050005)
              [123459.527791] Voltage normalised (0x00000000)
              [123634.249159] Under-voltage detected! (0x00050005)
              [123640.489161] Voltage normalised (0x00000000)
              [123700.809571] Voltage normalised (0x00000000)
              [123815.210411] rpi_firmware_get_throttled: 1 callbacks suppressed
              [123815.210420] Under-voltage detected! (0x00050005)
              [123819.370577] Voltage normalised (0x00000000)
              [124414.254483] Under-voltage detected! (0x00050005)
              [124420.494498] Voltage normalised (0x00000000)
              [124474.574879] Under-voltage detected! (0x00050005)
              [124480.814919] Voltage normalised (0x00000000)
              [124834.417282] Under-voltage detected! (0x00050005)
              [124840.657363] Voltage normalised (0x00000000)
              [124955.058207] Under-voltage detected! (0x00050005)
              [124959.218146] Voltage normalised (0x00000000)
              [125136.020124] Under-voltage detected! (0x00050005)
              [125140.179477] Voltage normalised (0x00000000)
              [125256.660318] Under-voltage detected! (0x00050005)
              [125260.820356] Voltage normalised (0x00000000)
              [125855.704579] Under-voltage detected! (0x00050005)
              [125859.864540] Voltage normalised (0x00000000)
              [125916.024999] Under-voltage detected! (0x00050005)
              [125920.185100] Voltage normalised (0x00000000)
              [126275.867643] Under-voltage detected! (0x00050005)
              [126280.027504] Voltage normalised (0x00000000)
              [126635.709936] Under-voltage detected! (0x00050005)
              [126639.869885] Voltage normalised (0x00000000)
              [126696.030403] Under-voltage detected! (0x00050005)
              [126700.190428] Voltage normalised (0x00000000)
              [126814.591173] Under-voltage detected! (0x00050005)
              [126818.751173] Voltage normalised (0x00000000)
              [126995.552397] rpi_firmware_get_throttled: 2 callbacks suppressed
              [126995.552406] Under-voltage detected! (0x00050005)
              [126999.712354] rpi_firmware_get_throttled: 2 callbacks suppressed
              [126999.712360] Voltage normalised (0x00000000)
              [127174.433186] Under-voltage detected! (0x00050005)
              [127180.673199] Voltage normalised (0x00000000)
              [128075.078262] Under-voltage detected! (0x00050005)
              [128079.238237] Voltage normalised (0x00000000)
              [128172.838859] Under-voltage detected! (0x00050005)
              [128176.998854] Voltage normalised (0x00000000)
              [128855.083363] Under-voltage detected! (0x00050005)
              [128859.243394] Voltage normalised (0x00000000)
              [128975.724159] Under-voltage detected! (0x00050005)
              [128979.884081] Voltage normalised (0x00000000)
              [129680.848505] Under-voltage detected! (0x00050005)
              [129685.008478] Voltage normalised (0x00000000)
              [130175.891842] Under-voltage detected! (0x00050005)
              [130180.051858] Voltage normalised (0x00000000)
              [130354.772877] Under-voltage detected! (0x00050005)
              [130361.012901] Voltage normalised (0x00000000)
              [130596.054691] Under-voltage detected! (0x00050005)
              [130600.214463] Voltage normalised (0x00000000)
              [130774.935993] Under-voltage detected! (0x00050005)
              [130779.095626] Voltage normalised (0x00000000)
              [130955.896773] Under-voltage detected! (0x00050005)
              [130960.056713] Voltage normalised (0x00000000)
              [131195.098371] Under-voltage detected! (0x00050005)
              [131199.258321] Voltage normalised (0x00000000)
              [131376.059477] Under-voltage detected! (0x00050005)
              [131380.219467] Voltage normalised (0x00000000)
              [131796.222312] Under-voltage detected! (0x00050005)
              [131800.382185] Voltage normalised (0x00000000)
              [132694.788061] Under-voltage detected! (0x00050005)
              [132698.948214] Voltage normalised (0x00000000)
              [132936.069629] Under-voltage detected! (0x00050005)
              [132940.229597] Voltage normalised (0x00000000)
              [133054.630388] Under-voltage detected! (0x00050005)
              [133058.790439] Voltage normalised (0x00000000)
              [133250.151657] Under-voltage detected! (0x00050005)
              [133254.311674] Voltage normalised (0x00000000)
              [133356.233718] Under-voltage detected! (0x00050005)
              [133360.392558] Voltage normalised (0x00000000)
              [133474.793285] Under-voltage detected! (0x00050005)
              [133481.033304] Voltage normalised (0x00000000)
              [133516.393564] Under-voltage detected! (0x00050005)
              [133520.553596] Voltage normalised (0x00000000)
              [134075.917457] rpi_firmware_get_throttled: 1 callbacks suppressed
              [134075.917467] Under-voltage detected! (0x00050005)
              [134080.077447] rpi_firmware_get_throttled: 1 callbacks suppressed
              [134080.077453] Voltage normalised (0x00000000)
              [134674.961465] Under-voltage detected! (0x00050005)
              [134679.121447] Voltage normalised (0x00000000)
              [136536.574366] Under-voltage detected! (0x00050005)
              [136540.734444] Voltage normalised (0x00000000)
              [137555.780634] Under-voltage detected! (0x00050005)
              [137559.940608] Voltage normalised (0x00000000)
              [138566.666158] Under-voltage detected! (0x00050005)
              [138570.826161] Voltage normalised (0x00000000)
              [138695.626929] Under-voltage detected! (0x00050005)
              [138699.786906] Voltage normalised (0x00000000)
              [138755.947369] Under-voltage detected! (0x00050005)
              [138760.107430] Voltage normalised (0x00000000)
              [140555.160548] Under-voltage detected! (0x00050005)
              [140559.320603] Voltage normalised (0x00000000)
              [140615.480873] Under-voltage detected! (0x00050005)
              [140619.640831] Voltage normalised (0x00000000)
              [140707.001520] Under-voltage detected! (0x00050005)
              [140711.161477] Voltage normalised (0x00000000)
              [142115.171511] rpi_firmware_get_throttled: 1 callbacks suppressed
              [142115.171523] Under-voltage detected! (0x00050005)
              [142119.331487] rpi_firmware_get_throttled: 1 callbacks suppressed
              [142119.331495] Voltage normalised (0x00000000)
              [142175.491789] Under-voltage detected! (0x00050005)
              [142179.651804] Voltage normalised (0x00000000)
              [142475.013861] Under-voltage detected! (0x00050005)
              [142481.253904] Voltage normalised (0x00000000)
              [142895.176734] Under-voltage detected! (0x00050005)
              [142899.336796] Voltage normalised (0x00000000)
              [143614.861187] Under-voltage detected! (0x00050005)
              [143621.101137] Voltage normalised (0x00000000)
              [143795.821905] Under-voltage detected! (0x00050005)
              [143799.981928] Voltage normalised (0x00000000)
              [143835.342059] Under-voltage detected! (0x00050005)
              [143839.502097] Voltage normalised (0x00000000)
              [145295.510463] Under-voltage detected! (0x00050005)
              [145299.670480] Voltage normalised (0x00000000)
              [145640.792919] Under-voltage detected! (0x00050005)
              [145644.952995] Voltage normalised (0x00000000)
              [146555.999717] Under-voltage detected! (0x00050005)
              [146560.159726] Voltage normalised (0x00000000)
              [148055.688487] Under-voltage detected! (0x00050005)
              [148059.848610] Voltage normalised (0x00000000)
              [148355.210040] Under-voltage detected! (0x00050005)
              [148359.370071] Voltage normalised (0x00000000)
              [148956.334297] Under-voltage detected! (0x00050005)
              [148960.493513] Voltage normalised (0x00000000)
              [149135.214567] Under-voltage detected! (0x00050005)
              [149139.374620] Voltage normalised (0x00000000)
              [149316.185666] Under-voltage detected! (0x00050005)
              [149320.335678] Voltage normalised (0x00000000)
              [149975.540528] Under-voltage detected! (0x00050005)
              [149979.700627] Voltage normalised (0x00000000)
              [150936.507543] Under-voltage detected! (0x00050005)
              [150940.667583] Voltage normalised (0x00000000)
              [151055.068338] Under-voltage detected! (0x00050005)
              [151061.308328] Voltage normalised (0x00000000)
              [151115.398941] Under-voltage detected! (0x00050005)
              [151119.548905] Voltage normalised (0x00000000)
              [151414.910813] Under-voltage detected! (0x00050005)
              [151421.150770] Voltage normalised (0x00000000)
              [151595.872008] Under-voltage detected! (0x00050005)
              [151600.032118] Voltage normalised (0x00000000)
              [152375.877722] Under-voltage detected! (0x00050005)
              [152380.037723] Voltage normalised (0x00000000)
              [152436.198146] Under-voltage detected! (0x00050005)
              [152440.358184] Voltage normalised (0x00000000)
              [152974.921909] Under-voltage detected! (0x00050005)
              [152981.161911] Voltage normalised (0x00000000)
              [153515.725714] Under-voltage detected! (0x00050005)
              [153519.885723] Voltage normalised (0x00000000)
              [154154.288544] Under-voltage detected! (0x00050005)
              [154158.448588] Voltage normalised (0x00000000)
              [154416.369805] Under-voltage detected! (0x00050005)
              [154420.529867] Voltage normalised (0x00000000)
              [154534.930539] Under-voltage detected! (0x00050005)
              [154541.170427] Voltage normalised (0x00000000)
              [155136.053957] Under-voltage detected! (0x00050005)
              [155140.214029] Voltage normalised (0x00000000)
              [155441.815816] Under-voltage detected! (0x00050005)
              [155448.055855] Voltage normalised (0x00000000)
              [155697.657526] Under-voltage detected! (0x00050005)
              [155701.817419] Voltage normalised (0x00000000)
              [155714.297604] Under-voltage detected! (0x00050005)
              [155718.457464] Voltage normalised (0x00000000)
              [155795.418176] Under-voltage detected! (0x00050005)
              [155801.658109] Voltage normalised (0x00000000)
              [155882.778974] Under-voltage detected! (0x00050005)
              [155886.938891] Voltage normalised (0x00000000)
              [155901.499180] Under-voltage detected! (0x00050005)
              [155905.659204] Voltage normalised (0x00000000)
              [156248.861901] rpi_firmware_get_throttled: 1 callbacks suppressed
              [156248.861911] Under-voltage detected! (0x00050005)
              [156253.021910] rpi_firmware_get_throttled: 1 callbacks suppressed
              [156253.021919] Voltage normalised (0x00000000)
              [156305.022356] Under-voltage detected! (0x00050005)
              [156309.182318] Voltage normalised (0x00000000)
              [156311.262447] Under-voltage detected! (0x00050005)
              [156317.502415] Voltage normalised (0x00000000)
              [156696.065203] rpi_firmware_get_throttled: 1 callbacks suppressed
              [156696.065213] Under-voltage detected! (0x00050005)
              [156700.225241] rpi_firmware_get_throttled: 1 callbacks suppressed
              [156700.225250] Voltage normalised (0x00000000)
              [156910.306732] Under-voltage detected! (0x00050005)
              [156914.466691] Voltage normalised (0x00000000)
              [157236.868934] Under-voltage detected! (0x00050005)
              [157241.029050] Voltage normalised (0x00000000)
              [157771.432690] Under-voltage detected! (0x00050005)
              [157781.832580] Voltage normalised (0x00000000)
              [157869.193936] Under-voltage detected! (0x00050005)
              [157873.353067] Voltage normalised (0x00000000)
              [157956.553518] Under-voltage detected! (0x00050005)
              [157960.713556] Voltage normalised (0x00000000)
              [158073.034869] Under-voltage detected! (0x00050005)
              [158110.474281] Under-voltage detected! (0x00050005)
              [158114.634341] rpi_firmware_get_throttled: 1 callbacks suppressed
              [158114.634348] Voltage normalised (0x00000000)
              [158164.554398] Under-voltage detected! (0x00050005)
              [158170.794487] Voltage normalised (0x00000000)
              [158189.514493] Voltage normalised (0x00000000)
              [158376.715472] rpi_firmware_get_throttled: 9 callbacks suppressed
              [158376.715482] Under-voltage detected! (0x00050005)
              [158437.035943] Under-voltage detected! (0x00050005)
              [158441.195857] rpi_firmware_get_throttled: 9 callbacks suppressed
              [158441.195865] Voltage normalised (0x00000000)
              [158495.276120] Under-voltage detected! (0x00050005)
              [158501.516175] Voltage normalised (0x00000000)
              [158709.517319] Under-voltage detected! (0x00050005)
              [158713.677324] Voltage normalised (0x00000000)
              [158736.557465] Under-voltage detected! (0x00050005)
              [158769.838348] Under-voltage detected! (0x00050005)
              [158773.997659] rpi_firmware_get_throttled: 1 callbacks suppressed
              [158773.997667] Voltage normalised (0x00000000)
              [158801.037818] Voltage normalised (0x00000000)
              [159156.719923] rpi_firmware_get_throttled: 1 callbacks suppressed
              [159156.719932] Under-voltage detected! (0x00050005)
              [159160.879974] Voltage normalised (0x00000000)
              [159250.320490] Under-voltage detected! (0x00050005)
              [159254.480555] Voltage normalised (0x00000000)
              [159266.960592] Under-voltage detected! (0x00050005)
              [159271.120655] Voltage normalised (0x00000000)
              [159489.521952] rpi_firmware_get_throttled: 3 callbacks suppressed
              [159489.521962] Under-voltage detected! (0x00050005)
              [159493.681950] rpi_firmware_get_throttled: 3 callbacks suppressed
              [159493.681958] Voltage normalised (0x00000000)
              [159670.483062] Under-voltage detected! (0x00050005)
              [159674.643093] Voltage normalised (0x00000000)
              [159728.723405] Under-voltage detected! (0x00050005)
              [159734.963486] Voltage normalised (0x00000000)
              [159997.044841] Under-voltage detected! (0x00050005)
              [160001.204893] Voltage normalised (0x00000000)
              [160040.725075] Under-voltage detected! (0x00050005)
              [160044.885116] Voltage normalised (0x00000000)
              [160115.605489] Under-voltage detected! (0x00050005)
              [160119.765491] Voltage normalised (0x00000000)
              [160329.846597] Under-voltage detected! (0x00050005)
              [160334.006587] Voltage normalised (0x00000000)
              [160750.008880] Under-voltage detected! (0x00050005)
              [160754.168925] Voltage normalised (0x00000000)
              [160955.930083] Under-voltage detected! (0x00050005)
              [160960.090091] Voltage normalised (0x00000000)
              [161195.131499] Under-voltage detected! (0x00050005)
              [161201.371501] Voltage normalised (0x00000000)
              [161376.092538] Under-voltage detected! (0x00050005)
              [161380.252619] Voltage normalised (0x00000000)
              [161675.614374] Under-voltage detected! (0x00050005)
              [161679.774321] Voltage normalised (0x00000000)
              [162095.777297] Under-voltage detected! (0x00050005)
              [162102.017318] Voltage normalised (0x00000000)
              [162216.418229] Under-voltage detected! (0x00050005)
              [162220.578234] Voltage normalised (0x00000000)
              [162515.940428] Under-voltage detected! (0x00050005)
              [162520.100500] Voltage normalised (0x00000000)
              [162549.230782] Under-voltage detected! (0x00050005)
              [162553.380691] Voltage normalised (0x00000000)
              [162936.103323] Under-voltage detected! (0x00050005)
              [162940.263429] Voltage normalised (0x00000000)
              [163200.265267] Under-voltage detected! (0x00050005)
              [163206.505103] Voltage normalised (0x00000000)
              [163264.745546] Under-voltage detected! (0x00050005)
              [163268.905620] Voltage normalised (0x00000000)
              [163295.945786] Under-voltage detected! (0x00050005)
              [163300.105857] Voltage normalised (0x00000000)
              [163362.506172] Under-voltage detected! (0x00050005)
              [163368.746134] Voltage normalised (0x00000000)
              [165190.838592] rpi_firmware_get_throttled: 1 callbacks suppressed
              [165190.838602] Under-voltage detected! (0x00050005)
              [165194.998599] rpi_firmware_get_throttled: 1 callbacks suppressed
              [165194.998608] Voltage normalised (0x00000000)
              [165708.761993] Under-voltage detected! (0x00050005)
              [165712.922030] Voltage normalised (0x00000000)
              [165970.843716] Under-voltage detected! (0x00050005)
              [165975.003710] Voltage normalised (0x00000000)
              [166010.363950] Under-voltage detected! (0x00050005)
              [166014.524014] Voltage normalised (0x00000000)
              [166295.325923] Under-voltage detected! (0x00050005)
              [166301.565944] Voltage normalised (0x00000000)
              [166415.966726] Under-voltage detected! (0x00050005)
              [166420.126794] Voltage normalised (0x00000000)
              [166775.809128] Under-voltage detected! (0x00050005)
              [166782.049182] Voltage normalised (0x00000000)
              [166990.050543] Under-voltage detected! (0x00050005)
              [166994.210587] Voltage normalised (0x00000000)
              [167017.090764] Under-voltage detected! (0x00050005)
              [167021.250774] Voltage normalised (0x00000000)
              [167676.455107] Under-voltage detected! (0x00050005)
              [167680.615107] Voltage normalised (0x00000000)
              [168489.740688] Under-voltage detected! (0x00050005)
              [168493.900744] Voltage normalised (0x00000000)
              [168550.061103] Under-voltage detected! (0x00050005)
              [168554.221916] Voltage normalised (0x00000000)
              [168997.264238] Under-voltage detected! (0x00050005)
              [169001.424149] Voltage normalised (0x00000000)
              [169750.229228] Under-voltage detected! (0x00050005)
              [169754.389258] Voltage normalised (0x00000000)
              [169956.150611] Under-voltage detected! (0x00050005)
              [169960.310628] Voltage normalised (0x00000000)
              [170049.751263] Under-voltage detected! (0x00050005)
              [170053.911286] Voltage normalised (0x00000000)
              [171129.278516] Under-voltage detected! (0x00050005)
              [171133.438515] Voltage normalised (0x00000000)
              [171337.279926] Under-voltage detected! (0x00050005)
              [171341.439922] Voltage normalised (0x00000000)
              [171430.880580] Under-voltage detected! (0x00050005)
              [171435.040572] Voltage normalised (0x00000000)
              [171636.801912] Under-voltage detected! (0x00050005)
              [171640.961918] Voltage normalised (0x00000000)
              pi@raspberrypi:~ $
              Ein anderes Netzteil sollte ich mir wohl anschaffen.
              UncleSamU 1 Antwort Letzte Antwort
              • Z ZER0
                @Thomas-Braun
                /usr/bin/nodejs
                v12.19.0
                /usr/bin/node
                v12.19.0
                /usr/bin/npm
                6.14.8
                nodejs:
                  Versionstabelle:
                pi@raspberrypi:~ $
                @ZER0
                Du kannst mal versuchen nodejs nochmal drüber zu hauen.
                sudo apt install nodejs --reinstall
                Aus dmesg:
                Dein Netzteil ist wohl zu schwach (und/oder zu viel Kram läuft da mit (externes USB-Geraffel z. B.). Das kann auch zu so merkwürdigem Verhalten bei Installationen führen.
                Z 1 Antwort Letzte Antwort
                  @ZER0
                  Aus dmesg:
                  Z Offline
                  Z Offline
                  ZER0
                  @Thomas-Braun
                  Vielen vielen Dank, nodejs reinstall hat geholfen, ich konnte den Adapter installieren
                  Nichtsdestotrotz ein anderes Netzteil werde ich bestellen.
                  Klasse Forum hier, so schnelle und professionelle Hilfe wünsche ich mir überall. Nochmal danke an alle.
                  • Z ZER0
                    @Thomas-Braun
                    da_WoodyD Offline
                    da_WoodyD Offline
                    @ZER0 abgesehn davon das du mit nem PI3 / 1GB ram nicht lang glücklich bist.
                    • Z ZER0
                      @Thomas-Braun
                      id)
                      pi@raspberrypi:~ $
                      UncleSamU Offline
                      UncleSamU Offline
                      UncleSam
                      Ja, unbedingt!
                      • da_WoodyD da_Woody
                        @da_Woody @ZER0
                        Insbesondere wenn da auch noch ein X-Server unnötigerweise weiteren Speicher belegt.
                        Dringend die Kiste in RunLevel 3 versetzen.
