  4. Test Adapter device-reminder v0.x
    6.5k
device-remindergeräteüberwachungadaptertest
458 Beiträge 34 Kommentatoren 119.1k Aufrufe 50 Beobachtet
  • F Fridolin01
    @Xenon
    Leider keine Reaktion vom Sayit Adapter
    Hier mal ein Log Auszug vieleicht hilft das.
    Sehe nichts aussergewöhnliches:
    2020-11-02 19:12:22.824 - debug: device-reminder.0 (29909) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-11-02 19:12:22.935 - debug: device-reminder.0 (29909) Objects client ready ... initialize now
    2020-11-02 19:12:23.063 - debug: device-reminder.0 (29909) Objects create System PubSub Client
    2020-11-02 19:12:23.065 - debug: device-reminder.0 (29909) Objects create User PubSub Client
    2020-11-02 19:12:23.066 - debug: device-reminder.0 (29909) Objects client initialize lua scripts
    2020-11-02 19:12:23.148 - debug: device-reminder.0 (29909) Objects connected to redis: 127.0.0.1:9001
    2020-11-02 19:12:23.165 - debug: device-reminder.0 (29909) objectDB connected
    2020-11-02 19:12:23.178 - debug: device-reminder.0 (29909) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-11-02 19:12:23.190 - debug: device-reminder.0 (29909) States create User PubSub Client
    2020-11-02 19:12:23.195 - debug: device-reminder.0 (29909) States create System PubSub Client
    2020-11-02 19:12:23.207 - debug: device-reminder.0 (29909) States connected to redis: 127.0.0.1:9000
    2020-11-02 19:12:23.208 - debug: device-reminder.0 (29909) statesDB connected
    2020-11-02 19:12:23.656 - info: device-reminder.0 (29909) starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v10.19.0, js-controller: 3.1.6
    2020-11-02 19:12:23.702 - debug: device-reminder.0 (29909) ARR INPUT [{"enabled":true,"deviceName":"Test","deviceType":"Trockner","pathConsumption":"shelly.0.SHPLG-S#9DD06E#1.Relay0.Power","pathSwitch":"shelly.0.SHPLG-S#9DD06E#1.Relay0.Switch","startText":"Start Testlauf","endText":"Ende Testlauf","idTelegram":[""],"idAlexa":[""],"idsayit":["sayit.0.tts.text"],"autoOff":false,"idTimer":"2"}]
    2020-11-02 19:12:23.743 - debug: device-reminder.0 (29909) arrPruef [{"pConsumption":"shelly.0.SHPLG-S#9DD06E#1.Relay0.Power","pSwitch":"shelly.0.SHPLG-S#9DD06E#1.Relay0.Switch"}]
    2020-11-02 19:12:23.763 - debug: device-reminder.0 (29909) sayit "SayIt" was created successfully
    2020-11-02 19:12:23.763 - debug: device-reminder.0 (29909) ARRTEMP SAYIT "[{"enabled":true,"sayitName":"SayIt","sayitPath":"sayit.0.tts.text","sayitVol":"60","timeMin":"6:00","timeMax":"22:59"}]"
    2020-11-02 19:12:23.770 - debug: device-reminder.0 (29909) RETURN {"geraeteName":"Test","geraeteTyp":"Trockner","currentConsumption":"shelly.0.SHPLG-S#9DD06E#1.Relay0.Power","switchPower":"shelly.0.SHPLG-S#9DD06E#1.Relay0.Switch","pfadZustand":"Test.Zustand","pfadVerbrauchLive":"Test.Verbrauch aktuell","startnachrichtText":"Start Testlauf","endenachrichtText":"Ende Testlauf","startnachrichtVersendet":false,"endenachrichtVersendet":false,"gestartet":false,"autoOff":false,"verbrauch":null,"resultStart":null,"resultEnd":null,"startValue":120,"endValue":10,"startCount":5,"endCount":50,"startZeit":0,"endZeit":0,"gesamtZeit":"Test.Laufzeit","arrStart":[],"arrAbbruch":[],"startnachricht":true,"endenachricht":true,"timeoutInMS":120000,"timer":true,"timeout":null,"telegramUser":"","telegram":true,"alexa":false,"sayItID":[{"enabled":true,"sayitName":"SayIt","sayitPath":"sayit.0.tts.text","sayitVol":"60","timeMin":"6:00","timeMax":"22:59"}],"sayIt":true}
    2020-11-02 19:12:23.808 - debug: device-reminder.0 (29909) state objSwitch true
    2020-11-02 19:12:23.876 - debug: device-reminder.0 (29909) objFinal {"shelly.0.SHPLG-S#9DD06E#1.Relay0.Power":{"geraeteName":"Test","geraeteTyp":"Trockner","currentConsumption":"shelly.0.SHPLG-S#9DD06E#1.Relay0.Power","switchPower":"shelly.0.SHPLG-S#9DD06E#1.Relay0.Switch","pfadZustand":"Test.Zustand","pfadVerbrauchLive":"Test.Verbrauch aktuell","startnachrichtText":"Start Testlauf","endenachrichtText":"Ende Testlauf","startnachrichtVersendet":false,"endenachrichtVersendet":false,"gestartet":false,"autoOff":false,"verbrauch":null,"resultStart":null,"resultEnd":null,"startValue":120,"endValue":10,"startCount":5,"endCount":50,"startZeit":0,"endZeit":0,"gesamtZeit":"Test.Laufzeit","arrStart":[],"arrAbbruch":[],"startnachricht":true,"endenachricht":true,"timeoutInMS":120000,"timer":true,"timeout":null,"telegramUser":"","telegram":true,"alexa":false,"sayItID":[{"enabled":true,"sayitName":"SayIt","sayitPath":"sayit.0.tts.text","sayitVol":"60","timeMin":"6:00","timeMax":"22:59"}],"sayIt":true}}
    2020-11-02 19:12:23.880 - debug: device-reminder.0 (29909) subscribe "shelly.0.SHPLG-S#9DD06E#1.Relay0.Power"
    2020-11-02 19:15:00.036 - info: host.iobrokermain instance system.adapter.daswetter.0 started with pid 30872
    2020-11-02 19:15:03.814 - info: daswetter.0 (30872) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0, js-controller: 3.1.6
    2020-11-02 19:15:15.367 - debug: sayit.0 (4683) system.adapter.admin.0: logging false
    2020-11-02 19:15:15.366 - debug: device-reminder.0 (29909) system.adapter.admin.0: logging false
    2020-11-02 19:15:21.234 - info: daswetter.0 (30872) got wrong data structure! trying to repair...
    2020-11-02 19:15:25.909 - info: daswetter.0 (30872) Terminated (NO_ERROR): Without reason
    2020-11-02 19:15:26.429 - info: host.iobrokermain instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2020-11-02 19:16:15.986 - debug: sayit.0 (4683) system.adapter.admin.0: logging true
    2020-11-02 19:16:15.995 - debug: device-reminder.0 (29909) system.adapter.admin.0: logging true
    2020-11-02 19:17:55.472 - debug: sayit.0 (4683) system.adapter.admin.0: logging false
    2020-11-02 19:17:55.474 - debug: device-reminder.0 (29909) system.adapter.admin.0: logging false
    2020-11-02 19:18:35.654 - debug: sayit.0 (4683) system.adapter.admin.0: logging true
    da_WoodyD Online
    da_WoodyD Online
    #100
    @Fridolin01 bitte! logs in code tags! da hauts einem die augen ein...
    • SlowmanS Slowman
      @Xenon
      OK, dann lasse ich das Leer, will ja nur das Alexa/Telegramm den Status ausgibt. Glaube ich habe es kapiert 😊
      Danke für die Hilfe
      da_WoodyD Online
      da_WoodyD Online
      #101
      @Slowman said in Test Adapter device-reminder v0.x:
      noch nicht so ganz. ;) du musst dich entscheiden ob speak, oder announce. speak ist die reine textausgabe, announce ist mit dem "padumm" davor. da wird der text ausgegeben den du eingetragen hast. das hat mit sayit nichts zu tun.
      • F Fridolin01
        @Xenon
        XenonX Offline
        XenonX Offline
        Xenon
        Forum Testing Developer
        #102
        @Fridolin01 sagte in Test Adapter device-reminder v0.x:
        @Xenon
        Alsoes steht drin "sayit Was created succesfully". In deinem log steht aber nicht davon, dass das Gerät überhaupt gestartet wurde, dann wäre der log voll von Berechnungen usw. Außerdem würde da stehen, dass eine message versandt wurde. Die Einträge fehlen alle
        wenn euch mein Beitrag geholfen hat, bewertet ihn bitte unten rechts :)
        • XenonX Offline
          XenonX Offline
          Xenon
          #103
          Update auf Version 0.2.1
          • ab jetzt ist whatsapp integriert
          • index_m wurde komplett überarbeitet, bitte unbedingt die Readme lesen! Es ist auch zwingend nötig, den Adapter komplett zu deinstallieren, bevor man ihn auf die neue Version bringt!
          • XenonX Xenon
            da_WoodyD Online
            da_WoodyD Online
            #104
            @Xenon uff ;)
            kleiner tipp fehler auf github!
            kommt muss zingend alle Instanzen löschen und den
            XenonX 1 Antwort Letzte Antwort
            • da_WoodyD da_Woody
              @Xenon uff ;)
              XenonX Offline
              XenonX Offline
              Xenon
              #105
              @da_Woody sagte in Test Adapter device-reminder v0.x:
              @Xenon uff ;)
              du Erbsenzähler :D die readme wird im nächsten Schritt ohnehin gegen Wiki ersetzt :P
              • XenonX Xenon
                @Xenon uff ;)
                da_WoodyD Online
                da_WoodyD Online
                #106
                @Xenon hehe, sorry, is mich in die aug gehüpft!
                da werden sie geholfen! :D
                  da_WoodyD Online
                  da_WoodyD Online
                  #107
                  @da_Woody hüstel, bin ich blind? oder fehlt bei den devices das +?
                  wie soll ich ein device anlegen?
                    XenonX Offline
                    XenonX Offline
                    Xenon
                    #108
                    lies bitte die readme ;) die devices werden unter config angelegt und erscheinen dann automatisch. Aber um das richtig anzulegen, bitte UNBEDINGT die readme lesen
                    • XenonX Xenon
                      da_WoodyD Online
                      da_WoodyD Online
                      #109
                      @Xenon hüstel...
                        @Xenon hüstel...
                        XenonX Offline
                        XenonX Offline
                        Xenon
                        schrieb am zuletzt editiert von Xenon
                        #110
                        @Xenon hüstel...
                        hier wird erstellt:
                        hier wird angepasst:
                        • XenonX Xenon
                          @Xenon hüstel...
                          hier wird erstellt:
                          da_WoodyD Online
                          da_WoodyD Online
                          #111
                          @Xenon schon behirnt! ;)
                          • XenonX Xenon
                            Aktuelle Test Version 0.7.4
                            Veröffentlichungsdatum 20.10.2020
                            Github Link https://github.com/Xenon-s/ioBroker.device-reminder
                            Adapter ist seit dem 27.11.20 in der latest
                            ACHTUNG wer von einer Version kleiner 0.4 kommt muss zwingend alle Instanzen löschen und den Adapter danach erst updaten!
                            Hinweis: Der Intervall eurer Messsteckdose sollte nicht größer 10 Sekunden eingestellt sein, um Falschmeldungen vorzubeugen. Messwerte werden automatisch alle 10 Sekunden vom Adapter abgerufen
                            Dieser Adapter kann anhand von Messsteckdosen erkennen, ob ein Gerät eingeschaltet, in Betrieb oder ausgeschaltet wurde und darauf reagieren. Es kann x Geräte gleichzeitig überwachen (auch unterschiedliche). Derzeit können Nachrichten per (Mehrfachauswahl pro gerät möglich)
                            • Listenpunkt Telegram
                            • Listenpunkt Whatsapp
                            • Listenpunkt Alexa
                            • Listenpunkt sayit
                            automatisiert ausgegeben werden. Es ist ebenfalls möglich, die Steckdose nach Beendigung des Vorgangs automatisch (optional auch verzögert) abzuschalten.
                            Hintergrund: es kommen ununterbrochen Anfragen nach Scripten, die genau diese Funktionen erfüllen sollen, aber nie funktioniert ein Script für unterschiedlichste Geräte. Das Problem wollten wir lösen und es gerade Einsteigern erleichtern, auf ihre Geräteänderungen einfach reagieren zu können.
                            Die Version 0.7.4 ist in der stable zu finden. Es geht mit der Version 1.0 weiter!
                            Vorschläge für Erweiterungen oder Änderungen als Issue auf github
                            Changelog
                            siehe github
                            sigi234S Online
                            sigi234S Online
                            #112
                            @Xenon
                            Ist auch eine Benachrichtigung per Email geplant?
                            • sigi234S sigi234
                              @Xenon
                              XenonX Offline
                              XenonX Offline
                              Xenon
                              #113
                              @sigi234 sagte in Test Adapter device-reminder v0.x:
                              @Xenon
                              zur Zeit nicht, ich wollte nur die größten Messenger und Alexa abfangen. Es gibt aber einen Datenpunkt, der dir zur gleichen Zeit wie die Messenger die Benachrichtigung zur Verfügung stellt. Da kannst du dann mit einem 5 Zeilen Script jeden weiteren Messenger einbinden
                              G 2 Antworten Letzte Antwort
                              • XenonX Xenon
                                @Xenon
                                guergen
                                #114
                                @Xenon Läuft soweit, abschaltung auch nach "0" Minuten gehtAllerdings sendet er mir, trotz (wohlweisslich) nicht angehaktem Telegram-Messenger eine Telegram Message:
                                Waschmaschine Telegram true---> Ralf [wird auch gesendet wie "bestellt"]
                                Wasserkocher Telegram true---> (leer) [wird dennoch gesendet]
                                {"deviceName":"Waschmaschine","deviceType":"Waschmaschine","currentConsumption":"sonoff.0.Waschmaschine.ENERGY_Power","switchPower":"sonoff.0.Waschmaschine.POWER","pathStatus":"Waschmaschine.Zustand","pathLiveConsumption":"Waschmaschine.Verbrauch aktuell","timeTotal":"Waschmaschine.Laufzeit","messageDP":"Waschmaschine.messageDP","startMessageText":"","endMessageText":"Waschmaschine ist fertig","startMessageSent":false,"endMessageSent":false,"started":false,"autoOff":true,"verbrauch":null,"resultStart":null,"resultEnd":null,"startValue":30,"endValue":15,"startCount":5,"endCount":65,"startZeit":0,"endZeit":0,"arrStart":[],"arrAbbruch":[],"startMessage":false,"endMessage":true,"timeoutInMS":300000,"timer":true,"timeout":null,"telegramUser":"Ralf","telegram":true,"alexaID":["1"],"alexa":true,"sayIt":false,"whatsappID":["1"],"whatsapp":true},"sonoff.0.Wasserkocher.ENERGY_Power":{"deviceName":"Wasserkocher","deviceType":"Wasserkocher","currentConsumption":"sonoff.0.Wasserkocher.ENERGY_Power","switchPower":"sonoff.0.Wasserkocher.POWER","pathStatus":"Wasserkocher.Zustand","pathLiveConsumption":"Wasserkocher.Verbrauch aktuell","timeTotal":"Wasserkocher.Laufzeit","messageDP":"Wasserkocher.messageDP","startMessageText":"","endMessageText":"Wasserkocher ist fertig","startMessageSent":false,"endMessageSent":false,"started":false,"autoOff":true,"verbrauch":null,"resultStart":null,"resultEnd":null,"startValue":10,"endValue":5,"startCount":2,"endCount":2,"startZeit":0,"endZeit":0,"arrStart":[],"arrAbbruch":[],"startMessage":false,"endMessage":true,"timeoutInMS":0,"timeout":null,"telegramUser":"","telegram":true,"alexaID":["1"],"alexa":true,"sayIt":false,"whatsappID":["1"],"whatsapp":true}}
                                • XenonX Xenon
                                  @Xenon
                                  guergen
                                  #115
                                  @Xenon Fällt mir grade auf: Vorher hatte der DP Zustand ein "ausgeschaltet", jetzt steht da immer nach beenden ein "undefined", macht mir nichts, ist nur so ins Auge geflogen
                                    michihorn
                                    #116
                                    Danke für den Adapter, was trage ich denn bei WhatsApp ein?
                                    Michael
                                    • M michihorn
                                      Michael
                                      da_WoodyD Online
                                      da_WoodyD Online
                                      #117
                                        michihorn
                                        #118
                                        @da_Woody Merci
                                        • M michihorn
                                          @da_Woody Merci
                                          da_WoodyD Online
                                          da_WoodyD Online
                                          #119
                                          @michihorn bittsche
