  4. YAHKA Shelly Dimmer läuft nicht mehr
    1.9k
  • Weihnachtsangebot 2025! 🎄
    2.2k
shellydimmeryahka adapter
18 Beiträge 2 Kommentatoren 1.5k Aufrufe 2 Watching
    DomDom
    habe festgetellt dass der Yak nicht mehr läuft. Habe dann ne 2 Instanz erstellt und konnte alle Shellys wieder einbinden. Nur die Dimmer nicht in dem Moment in dem ich die Dimmer einbinden möchte läuft er nicht mehr.
    Folgendes steht im Log:
    host.raspberrypi	2020-11-04 16:35:30.363	error	Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    host.raspberrypi	2020-11-04 16:35:30.362	error	Caught by controller[1]: at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    host.raspberrypi	2020-11-04 16:35:30.362	error	Caught by controller[1]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.raspberrypi	2020-11-04 16:35:30.362	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:572:33
    host.raspberrypi	2020-11-04 16:35:30.361	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.yahka/main.js:3468:21
    host.raspberrypi	2020-11-04 16:35:30.361	error	Caught by controller[1]: at changeInterceptor (/opt/iobroker/node_modules/iobroker.yahka/main.js:3455:85)
    host.raspberrypi	2020-11-04 16:35:30.361	error	Caught by controller[1]: at TIoBrokerInOutFunction_Homematic_Dimmer_On../yahka.functions/functions.base.ts.TYahkaFunctionBase.subscriptionEvent (/opt/iobroker/node_modules/iobroker.yahka/main.js:1
    host.raspberrypi	2020-11-04 16:35:30.361	error	Caught by controller[1]: at TIoBrokerInOutFunction_Homematic_Dimmer_On../yahka.functions/iofunc.homematic.dimmer.ts.TIoBrokerInOutFunction_Homematic_Dimmer_Base.cacheChanged (/opt/iobroker/node_mo
    host.raspberrypi	2020-11-04 16:35:30.361	error	Caught by controller[1]: TypeError: Cannot read property 'val' of null
    host.raspberrypi	2020-11-04 16:35:30.360	error	Caught by controller[0]: Wed, 04 Nov 2020 15:35:29 GMT EventedHTTPServer Server listening on port 44329
    Allerdings kann ich damit nichts anfangen.
    Danke für eure Hilfe.
    Dominik
    • D DomDom
      Dominik
      @DomDom
      Versionen von z. B. nodeJS und dem Adapter?
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      D 2 Antworten Letzte Antwort
        @DomDom
        DomDom
        @Thomas-Braun
        Danke für dein Feedback
        Yahka 0.11.0
        Meinst du JS Engine?
        Das wäre 4.8.4
        • D DomDom
          @Thomas-Braun
          Yahka 0.11.0
          Das wäre 4.8.4
          @DomDom Und die node-Installation? Sieht man mit der obigen Befehlskette.
            @DomDom
            DomDom
            @Thomas-Braun
            Übrigens die Homematic Dimmer funktionieren nicht (über Homekit) werden aber angezeigt.
              DomDom
              @Thomas-Braun
              Sorry wo gebe ich diese Befehlskette ein? Bin eher neu hier
              • D DomDom
                @Thomas-Braun
                @DomDom In die Konsole / Terminal / Shell / tty / Eingabeaufforderung...
                  DomDom
                  @Thomas-Braun
                  Habe die Info in der Übersicht gefunden
                  12.16.3
                  • D DomDom
                    @Thomas-Braun
                    12.16.3
                    @DomDom
                    Das reicht nicht. Obige Befehlszeile eingeben, Rückmeldung wieder hier rein
                      @DomDom
                      DomDom
                      @Thomas-Braun
                      /usr/bin/nodejs
                      v12.16.3
                      /usr/bin/node
                      v12.16.3
                      /usr/bin/npm
                      6.14.4
                      nodejs:
                        Installed: 12.16.3-1nodesource1
                        Candidate: 12.16.3-1nodesource1
                        Version table:
                       *** 12.16.3-1nodesource1 500
                              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                           10.19.0~dfsg1-1+rpi1 500
                      Meinst diese Info?
                      • D DomDom
                        @Thomas-Braun
                        /usr/bin/nodejs
                        v12.16.3
                        /usr/bin/node
                        v12.16.3
                        /usr/bin/npm
                        6.14.4
                        nodejs:
                          Version table:
                        Meinst diese Info?
                        @DomDom
                        Ja.
                        Das passt soweit, sollte allerdings aktualisiert werden:
                        iobroker stop
                        sudo apt update
                        sudo apt dist-upgrade
                        sudo reboot
                          @DomDom
                          Ja.
                          iobroker stop
                          sudo apt update
                          sudo reboot
                          DomDom
                          @Thomas-Braun
                          /usr/bin/nodejs
                          v12.16.3
                          /usr/bin/node
                          v12.16.3
                          /usr/bin/npm
                          6.14.4
                          nodejs:
                            Candidate: 12.19.0-1nodesource1
                            Version table:
                               12.19.0-1nodesource1 500
                           *** 12.16.3-1nodesource1 100
                               10.21.0~dfsg-1~deb10u1+rpi1 500
                          es bleibt dabei wenn ich die Shelly einbringen möchte läuft er nicht
                          • D DomDom
                            @Thomas-Braun
                            /usr/bin/nodejs
                            v12.16.3
                            /usr/bin/node
                            v12.16.3
                            /usr/bin/npm
                            6.14.4
                            nodejs:
                              Version table:
                            @DomDom Hat zwar mit dem Problem nix zu tun, aber du solltest die Updates dann auch zu Ende bringen.
                            Befehle siehe oben.
                              Befehle siehe oben.
                              DomDom
                              @Thomas-Braun
                              Ne Idee bezüglich dem Problem?
                              • D DomDom
                                @Thomas-Braun
                                @DomDom Nö.
                                Aber ist die Grundlage jetzt richtig?
                                  @DomDom Nö.
                                  DomDom
                                  @Thomas-Braun
                                  /usr/bin/nodejs
                                  v12.19.0
                                  /usr/bin/node
                                  v12.19.0
                                  /usr/bin/npm
                                  6.14.8
                                  nodejs:
                                    Installed: 12.19.0-1nodesource1
                                    Version table:
                                   *** 12.19.0-1nodesource1 500
                                  • D DomDom
                                    @Thomas-Braun
                                    /usr/bin/nodejs
                                    v12.19.0
                                    /usr/bin/node
                                    v12.19.0
                                    /usr/bin/npm
                                    6.14.8
                                    nodejs:
                                      Version table:
                                    @DomDom
                                    Ist eigentlich deine Systemzeit korrekt?
                                    Mal
                                    date -u && date
                                    prüfen.
                                      @DomDom
                                      Mal
                                      date -u && date
                                      prüfen.
                                      DomDom
                                      @Thomas-Braun
                                      ja passt
                                      32.6k
                                      82.2k
