  4. Fehlermeldungen bei Adapterupdate
    1.7k
adapter update fehler
7 Beiträge 4 Kommentatoren 702 Aufrufe 3 Beobachtet
  • uweklattU Offline
    uweklattU Offline
    uweklatt
    momentan erscheinen bei allen Updates Fehler.
    Die Adapter und ioBroker laufen aber.
    So z.B. beim Info-Adapter:
    $ ./iobroker upgrade info
    Update info from @1.7.7 to @1.7.9
    NPM version: 6.14.8
    npm install iobroker.info@1.7.9 --loglevel error --prefix "/opt/iobroker" (System call)
    info sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.10.0/libvips-8.10.0-linux-x64.tar.br
    internal/fs/utils.js:269    throw err;    ^Error: EPERM: operation not permitted, copyfile '/tmp/5640-libvips-8.10.0-linux-x64.tar.br' -> '/opt/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br'    at Object.copyFileSync (fs.js:1904:3)    at WriteStream.<anonymous> (/opt/iobroker/node_modules/sharp/install/libvips.js:121:16)    at WriteStream.emit (events.js:314:20)    at internal/fs/streams.js:247:14    at FSReqCallback.oncomplete (fs.js:156:23) {  errno: -1,  syscall: 'copyfile',  code: 'EPERM',  path: '/tmp/5640-libvips-8.10.0-linux-x64.tar.br',  dest: '/opt/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br'}
    ../src/common.cc:24:10: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>          ^~~~~~~~~~~~
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Fehler 1
    gyp
     ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR!
    stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp
     ERR! System Linux 4.14.24-qnapgyp ERR!
    command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp
     ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
    Adapter "system.adapter.vis.0" restarted.
    Update "system.adapter.info.0"
    Oder auch bei der Script Engine:
    $ ./iobroker upgrade javascript
    Update javascript from @4.9.7 to @4.9.8
    NPM version: 6.14.8
    npm install iobroker.javascript@4.9.8 --loglevel error --prefix "/opt/iobroker" (System call)
    internal/fs/utils.js:269    throw err;    ^Error: EPERM: operation not permitted, copyfile '/tmp/6215-libvips-8.10.0-linux-x64.tar.br' -> '/opt/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br'    at Object.copyFileSync (fs.js:1904:3)    at WriteStream.<anonymous> (/opt/iobroker/node_modules/sharp/install/libvips.js:121:16)    at WriteStream.emit (events.js:314:20)    at internal/fs/streams.js:247:14    at FSReqCallback.oncomplete (fs.js:156:23) {  errno: -1,  syscall: 'copyfile',  code: 'EPERM',  path: '/tmp/6215-libvips-8.10.0-linux-x64.tar.br',  dest: '/opt/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br'}
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Fehler 1gyp
     stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.14.24-qnapgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    Update "system.adapter.javascript.0"
    Welche Ursache hat das?
    Mein ioBroker läuft als Docker Container (buanet).
    Softwarestand Node.js: v12.19.0
    Tschau
    Uwe
    Intel i5/Proxmox/LXC/Docker/ioBroker
    • uweklattU uweklatt
      NPM version: 6.14.8
      gyp
      NPM version: 6.14.8
      gyp ERR! not ok
      Tschau
      Uwe
      @uweklatt sagte in Fehlermeldungen bei Adapterupdate:
      harp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.10.0/libvips-8.10.0-linux-x64.tar.br internal/fs/utils.js:269 throw err; ^Error: EPERM:
      Dein System versuch libvips zu bauen, vermutlich fehlen aber die dev-Pakete dazu. Von Docker-Zeuch lass ich aber die Finger.
      uweklattU 1 Antwort Letzte Antwort
        uweklattU Offline
        uweklattU Offline
        uweklatt
        schrieb am zuletzt editiert von uweklatt
        @Thomas-Braun
        Und was kann ich da machen bzw. wie finde ich heraus, wer oder was dieses libvips (Imageprozessing) nutzt? ;-)
        Tschau
        Uwe
        Thomas BraunT haselchenH 2 Antworten Letzte Antwort
          @Thomas-Braun
          Tschau
          Uwe
          @uweklatt
          Machen musst du da nix.
          Die Adapter sollten dennoch installiert werden.
            @Thomas-Braun
            Tschau
            Uwe
            haselchenH Offline
            haselchenH Offline
            haselchen
            @uweklatt
            Kannst ja versuchen im Container Terminal ein apt-get update und apt-get upgrade zu machen.
            Ob sudo davor musste die Infos im Terminal angucken.
            UncleSamU 1 Antwort Letzte Antwort
            • haselchenH haselchen
              @uweklatt
              UncleSamU Offline
              UncleSamU Offline
              UncleSam
              @haselchen sagte in Fehlermeldungen bei Adapterupdate:
              Mach das bitte nicht! Das ist einer der grössten Fehler bei Containern: die Kommandozeile sollte man nur im Notfall nutzen und Neues installieren darf man niemals im Container. Wenn du den Inhalt eines Containers ändern willst (mit Ausnahme vom ioBroker Adaptern), musst du dies sauber im Dockerfile machen, sonst gehen die Änderungen beim nächsten Update wieder verloren.
              Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
              ♡-lichen Dank an meine Sponsoren
              • UncleSamU UncleSam
                haselchenH Offline
                haselchenH Offline
                haselchen
                @UncleSam
                Von uns Beiden bist definitiv Du der Experte.
                Ich lege mal als Laie ein kleines Veto ein :)
                Ich habe seit Jahr und Tag V3 des Iobroker Containers am Laufen.
                Mounte den Iobroker Ordner. Vor jedem (großen) Update kopiere ich den Ordner in einen angelegten Backup Ordner. Sollte etwas schief laufen , brauche ich den Ordner nur wieder zurückkopieren.
                Über das Terminal aktualisiere ich meine Nodejs Versionen und was sonst noch nötig ist. Mag sein, dass ich Glück habe oder es einfach richtig mache :)
                Die meisten Container haben ne Backup Funktion (Button)..Pihole...Deconz....
                Bei Problemen einfach Container stoppen, löschen und wieder neu starten , Backup einspielen.
                Ist halt meine Erfahrung, mit der ich seitdem keine Probleme hatte.
