<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehlermeldungen bei Adapterupdate]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">momentan erscheinen bei allen Updates Fehler.<br />
Die Adapter und ioBroker laufen aber.</p>
<p dir="auto">So z.B. beim Info-Adapter:</p>
<pre><code>$ ./iobroker upgrade info
Update info from @1.7.7 to @1.7.9
NPM version: 6.14.8
npm install iobroker.info@1.7.9 --loglevel error --prefix "/opt/iobroker" (System call)
info sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.10.0/libvips-8.10.0-linux-x64.tar.br
internal/fs/utils.js:269    throw err;    ^Error: EPERM: operation not permitted, copyfile '/tmp/5640-libvips-8.10.0-linux-x64.tar.br' -&gt; '/opt/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br'    at Object.copyFileSync (fs.js:1904:3)    at WriteStream.&lt;anonymous&gt; (/opt/iobroker/node_modules/sharp/install/libvips.js:121:16)    at WriteStream.emit (events.js:314:20)    at internal/fs/streams.js:247:14    at FSReqCallback.oncomplete (fs.js:156:23) {  errno: -1,  syscall: 'copyfile',  code: 'EPERM',  path: '/tmp/5640-libvips-8.10.0-linux-x64.tar.br',  dest: '/opt/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br'}
../src/common.cc:24:10: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include &lt;vips/vips8&gt;          ^~~~~~~~~~~~
compilation terminated.
make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Fehler 1
gyp
 ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR!
stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp
 ERR! System Linux 4.14.24-qnapgyp ERR!
command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp
 ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
Adapter "system.adapter.vis.0" restarted.
Update "system.adapter.info.0"
</code></pre>
<p dir="auto">Oder auch bei der Script Engine:</p>
<pre><code>$ ./iobroker upgrade javascript
Update javascript from @4.9.7 to @4.9.8
NPM version: 6.14.8
npm install iobroker.javascript@4.9.8 --loglevel error --prefix "/opt/iobroker" (System call)
internal/fs/utils.js:269    throw err;    ^Error: EPERM: operation not permitted, copyfile '/tmp/6215-libvips-8.10.0-linux-x64.tar.br' -&gt; '/opt/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br'    at Object.copyFileSync (fs.js:1904:3)    at WriteStream.&lt;anonymous&gt; (/opt/iobroker/node_modules/sharp/install/libvips.js:121:16)    at WriteStream.emit (events.js:314:20)    at internal/fs/streams.js:247:14    at FSReqCallback.oncomplete (fs.js:156:23) {  errno: -1,  syscall: 'copyfile',  code: 'EPERM',  path: '/tmp/6215-libvips-8.10.0-linux-x64.tar.br',  dest: '/opt/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br'}
make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Fehler 1gyp
 stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.14.24-qnapgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
Update "system.adapter.javascript.0"
</code></pre>
<p dir="auto">Welche Ursache hat das?</p>
<p dir="auto">Mein ioBroker läuft als Docker Container (buanet).<br />
Softwarestand Node.js: v12.19.0</p>
<p dir="auto">Tschau<br />
Uwe</p>
]]></description><link>https://forum.iobroker.net/topic/38266/fehlermeldungen-bei-adapterupdate</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 14:30:41 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/38266.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Nov 2020 20:54:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehlermeldungen bei Adapterupdate on Tue, 03 Nov 2020 09:47:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unclesam" aria-label="Profile: UncleSam">@<bdi>UncleSam</bdi></a><br />
Von uns Beiden bist definitiv Du der Experte.<br />
Ich lege mal als Laie ein kleines Veto ein :)<br />
Ich habe seit Jahr und Tag V3 des Iobroker Containers am Laufen.<br />
Mounte den Iobroker Ordner. Vor jedem (großen) Update kopiere ich den Ordner in einen angelegten Backup Ordner. Sollte etwas schief laufen , brauche ich den Ordner nur wieder zurückkopieren.<br />
Über das Terminal aktualisiere ich meine Nodejs Versionen und was sonst noch nötig ist. Mag sein, dass ich Glück habe oder es einfach richtig mache :)<br />
Die meisten Container haben ne Backup Funktion (Button)..Pihole...Deconz....<br />
Bei Problemen einfach Container stoppen, löschen und wieder neu starten , Backup einspielen.<br />
Ist halt meine Erfahrung, mit der ich seitdem keine Probleme hatte.</p>
]]></description><link>https://forum.iobroker.net/post/514350</link><guid isPermaLink="true">https://forum.iobroker.net/post/514350</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Tue, 03 Nov 2020 09:47:55 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapterupdate on Tue, 03 Nov 2020 06:24:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> sagte in <a href="/post/514194">Fehlermeldungen bei Adapterupdate</a>:</p>
<blockquote>
<p dir="auto">Kannst ja versuchen im Container Terminal ein apt-get update und apt-get upgrade zu machen.</p>
</blockquote>
<p dir="auto">Mach das bitte nicht! Das ist einer der grössten Fehler bei Containern: die Kommandozeile sollte man nur im Notfall nutzen und Neues installieren darf man niemals im Container. Wenn du den Inhalt eines Containers ändern willst (mit Ausnahme vom ioBroker Adaptern), musst du dies sauber im Dockerfile machen, sonst gehen die Änderungen beim nächsten Update wieder verloren.</p>
]]></description><link>https://forum.iobroker.net/post/514276</link><guid isPermaLink="true">https://forum.iobroker.net/post/514276</guid><dc:creator><![CDATA[UncleSam]]></dc:creator><pubDate>Tue, 03 Nov 2020 06:24:06 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapterupdate on Mon, 02 Nov 2020 21:37:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uweklatt" aria-label="Profile: uweklatt">@<bdi>uweklatt</bdi></a></p>
<p dir="auto">Kannst ja versuchen im Container Terminal ein apt-get update und apt-get upgrade zu machen.<br />
Ob sudo davor musste die Infos im Terminal angucken.</p>
]]></description><link>https://forum.iobroker.net/post/514194</link><guid isPermaLink="true">https://forum.iobroker.net/post/514194</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Mon, 02 Nov 2020 21:37:29 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapterupdate on Mon, 02 Nov 2020 21:00:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uweklatt" aria-label="Profile: uweklatt">@<bdi>uweklatt</bdi></a><br />
Machen musst du da nix.<br />
Die Adapter sollten dennoch installiert werden.</p>
]]></description><link>https://forum.iobroker.net/post/514139</link><guid isPermaLink="true">https://forum.iobroker.net/post/514139</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 02 Nov 2020 21:00:45 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapterupdate on Mon, 02 Nov 2020 21:00:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a></p>
<p dir="auto">Und was kann ich da machen bzw. wie finde ich heraus, wer oder was dieses libvips (Imageprozessing) nutzt?  ;-)</p>
Uwe</p>
]]></description><link>https://forum.iobroker.net/post/514135</link><guid isPermaLink="true">https://forum.iobroker.net/post/514135</guid><dc:creator><![CDATA[uweklatt]]></dc:creator><pubDate>Mon, 02 Nov 2020 21:00:27 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapterupdate on Mon, 02 Nov 2020 20:57:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uweklatt" aria-label="Profile: uweklatt">@<bdi>uweklatt</bdi></a> sagte in <a href="/post/514129">Fehlermeldungen bei Adapterupdate</a>:</p>
<blockquote>
<p dir="auto">harp Downloading <a href="https://github.com/lovell/sharp-libvips/releases/download/v8.10.0/libvips-8.10.0-linux-x64.tar.br" rel="nofollow ugc">https://github.com/lovell/sharp-libvips/releases/download/v8.10.0/libvips-8.10.0-linux-x64.tar.br</a>        internal/fs/utils.js:269    throw err;    ^Error: EPERM:</p>
</blockquote>
<p dir="auto">Dein System versuch libvips zu bauen, vermutlich fehlen aber die dev-Pakete dazu. Von Docker-Zeuch lass ich aber die Finger.</p>
]]></description><link>https://forum.iobroker.net/post/514134</link><guid isPermaLink="true">https://forum.iobroker.net/post/514134</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 02 Nov 2020 20:57:44 GMT</pubDate></item></channel></rss>
