  4. [gelöst] Raspberry Pi inizialisierung Conbee II, iobroker
iobrokerconbee 2raspberry pi 4deconz
46 Beiträge 3 Kommentatoren 7.9k Aufrufe 2 Beobachtet
    @silbroker
    In welchem Terminal?
    Mit STRG-C kommst du da wieder raus.
    silbroker
    @Thomas-Braun
    pi@raspberrypi:~ $ systemctl status deconz
    ● deconz.service - deCONZ: ZigBee gateway -- REST API
       Loaded: loaded (/lib/systemd/system/deconz.service; disabled; vendor preset:
       Active: inactive (dead)
     ESCOC
    y -- REST API
    econz.service; disabled; vendor preset: enabled)
    lines 1-3/3 (END)...skipping...
    y -- REST API
    • S silbroker
      @Thomas-Braun
       ESCOC
      y -- REST API
      y -- REST API
      @silbroker Und
      systemctl status deconz-gui
      sagt?
        @silbroker Und
        sagt?
        silbroker
        @Thomas-Braun
        ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
           Loaded: loaded (/lib/systemd/system/deconz-gui.service; disabled; vendor pres
        Oct 31 13:50:22 raspberrypi systemd[1]: /lib/systemd/system/deconz-gui.service:1
        Oct 31 13:53:13 raspberrypi systemd[1]: /lib/systemd/system/deconz-gui.service:1
        • S silbroker
          @Thomas-Braun
          @silbroker
          sudo systemctl enable deconz
          sudo systemctl start deconz
            @silbroker
            silbroker
            schrieb am zuletzt editiert von silbroker
            @Thomas-Braun
            pi@raspberrypi:~ $ sudo systemctl enable deconz
            Created symlink /etc/systemd/system/multi-user.target.wants/deconz.service → /lib/systemd/system/deconz.service.
            pi@raspberrypi:~ $ sudo systemctl start deconz
            pi@raspberrypi:~ $ sudo systemctl status deconz
               Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: e
               Active: active (running) since Sat 2020-10-31 13:56:22 GMT; 17s ago
             Main PID: 2514 (deCONZ)
                Tasks: 6 (limit: 4915)
               CGroup: /system.slice/deconz.service
                       └─2514 /usr/bin/deCONZ -platform minimal --http-port=80
            Oct 31 13:56:22 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST A
            Oct 31 13:56:23 raspberrypi deCONZ[2514]: QStandardPaths: XDG_RUNTIME_DIR not se
            Oct 31 13:56:23 raspberrypi deCONZ[2514]: libpng warning: iCCP: known incorrect
            Oct 31 13:56:24 raspberrypi deCONZ[2514]: This plugin does not support propagate
            Oct 31 13:56:25 raspberrypi deCONZ[2514]: This plugin does not support propagate
            Jetzt kann ich die Webinterface von Deconz aufrufen
            • S silbroker
              @Thomas-Braun
              @silbroker
              Passt.
              Jetzt sollte die sog. phoscon app über den Browser zu erreichen sein.
                @silbroker
                Passt.
                silbroker
                @Thomas-Braun
                Genau, Top Danke
                Muss ich noch etwas anpassen auf dem Raspberry Pi oder sollte alles in Ordnung sein.
                Gibt es noch etwas wichtiges zu wissen beim Conbee II wo ich einen Fehler machen kann?
                haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                • S silbroker
                  @Thomas-Braun
                  Genau, Top Danke
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @silbroker
                  Naja, 38 Beiträge waren eigentlich umsonst, wenn du dich strikt an die Anleitung gehalten hättest ;)
                  Ob offiziell oder nicht.
                  Bei deiner Anleitung stand sogar am Schluss der Befehl drin:
                  Sieh es als learning by doing :)
                  • S silbroker
                    @Thomas-Braun
                    Genau, Top Danke
                    @silbroker Sollte eigentlich passen.
                    Du kannst aber mal schauen, ob der Service auch nach einem Reboot richtig auf die Beine kommt.
                    • haselchenH haselchen
                      @silbroker
                      silbroker
                      @haselchen
                      das Problem war ja das ich gar nie so weit gekommen bin das ich diesen Befehl brauchen konnte.
                      und ich werde deinen Tipp beherzigen und nicht solche dummen "smarthome" Anleitungen folgen.
                      • S silbroker
                        @haselchen
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @silbroker
                        Nimm das nicht als Vorwurf sondern als Rat.
                        Logisch kannst Du hier auch weiterhin alle Art von Fragen stellen 😬
                        • S silbroker
                          @haselchen
                          @silbroker sagte in Raspberry Pi inizialisierung Conbee II, iobroker:
                          So dumm war die ja nicht. Da habe ich schon ganz anderen Krampf lesen müssen.
                            silbroker
                            @Thomas-Braun
                            Danke viel mals Thomas
                            Nach reboot habe ich immer noch zugriff auf Webinterface von iobroker, deconz
                            Werde jetzt meine Geräte versuchen einzubinden.
                            Ist jetzt der richtige moment den Adapter auf iobroker starten?
                              @silbroker
                              silbroker
                              @haselchen
                              Danke das werde ich mir merken. Und sobald ich nicht weiter komme werde ich wieder Fragen
                              • S silbroker
                                @Thomas-Braun
                                @silbroker
                                Ja, der Adapter sollte jetzt auf den Stick via deconz-Adapter zugreifen können.
