  4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    6.7k
sourceanalytixtestenadapterupdate
1.1k Beiträge 103 Kommentatoren 441.4k Aufrufe 93 Beobachtet
  • E Ecke
    Hallo, seitdem ich meinen Shelly resetet habe und der Energy-Wert wieder bei 0 angefangen hat läuft mein log voll:
    2020-10-25 15:24:25.593 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.8886800000000001 to value of reset
    2020-10-25 15:25:59.926 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.8886800000000001 to value of reset
    2020-10-25 15:26:59.908 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.8895100000000002 to value of reset
    2020-10-25 15:27:59.913 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.8912800000000003 to value of reset
    2020-10-25 15:28:59.928 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.8939600000000003 to value of reset
    2020-10-25 15:29:59.892 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.8974900000000003 to value of reset
    2020-10-25 15:30:59.950 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9018100000000004 to value of reset
    2020-10-25 15:31:59.936 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9068100000000003 to value of reset
    2020-10-25 15:32:59.946 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9124600000000003 to value of reset
    2020-10-25 15:33:59.958 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9187100000000004 to value of reset
    2020-10-25 15:34:59.963 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9255400000000003 to value of reset
    2020-10-25 15:35:59.970 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9329200000000002 to value of reset
    2020-10-25 15:36:59.982 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9408500000000002 to value of reset
    2020-10-25 15:37:59.986 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9493000000000003 to value of reset
    2020-10-25 15:38:59.904 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9582200000000003 to value of reset
    2020-10-25 15:40:00.000 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9675700000000003 to value of reset
    2020-10-25 15:40:59.919 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9773500000000002 to value of reset
    2020-10-25 15:41:59.912 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9875300000000002 to value of reset
    2020-10-25 15:42:59.920 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 1.9981300000000002 to value of reset
    2020-10-25 15:43:59.943 - warn: sourceanalytix.0 (28040) Device reset detected for 0_userdata.0.PV_Erzeugung store current value 2.0091300000000003 to value of reset
    Soll das so aussehen? Die Meldung soll doch sicher nur einmalig erscheinen?
    guergen
    #738
    @Ecke Adapter mal neu gestartet?
    • DutchmanD Dutchman
      Aktuelle Test Version v0.4.8-alpha.0
      Veröffentlichungsdatum 09.09.2020
      Github Link https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix
      Major release v0.4.8-alpha.0
      Um die weitere Entwicklung von SourceAnalytix mit neuen Funktionen möglich zu machen habe ich mich dazu entschlossen den vorige SourceCode (0.3.0) komplett neu auf zu bauen.
      Da die vorige version mit Erweiterungen undurchsichtig geworden war, und auch einige performance/Berechnung Probleme auftraten, war ein redesign die beste Entscheidung.
      Die neue version kennt einige performance Verbesserungen, die alten Funktionalität sind weitestgehend gleich geblieben.
      Die wichtigsten Änderungen in 0.4.x :
      • Änderung der Datenstruktur, diese fängt jetzt an beim Jahr anstatt "current_year"
      • Datenstruktur Migration : Noch nicht implementiert, wird später folgen
      • Quartale werden berechnet
      • Redesign der Watt ==> kWh Berechnung (genauer)
      • Redesign der Unit Definitionen (Sollte Fehler "kann unit nicht erkennen" beheben)
      • Reset des Messgerätes, anstatt minus werte wird jetzt der Haupt-Wert Kumuliert
      • Gesamt werte werden per Kategorie (kosten / verbrauch / Zählerwerte) wieder gegeben
      • Redesign alle Berechnungen, alle read/write zugriffe von iO (object DB) in den Arbeitsspeicher verschoben. Hiermit sollte performance Problemen behoben sein vor allen bei ein-platineng Systemen und langsamen Festplatten
      • Logging redesigned, bei neu installation ist die log-stufe WARN, bereits bestehen Installationen stehen auf INFO bitte Manuel auf WARN stellen
      Ich bitte euch diese version zu testen, bei erfolg werden ich SourceAnalytix in die stable releasen und danach anfangen neue Funktionen ein zu bauen.
      (Vorschläge und bug reports bitte über git !)
      Danke für eure mithilfe
      hetti72
      #739
      mal ne Frage: Ist es geplant eine "Betriebsstundenzähler" Funktion zu implementieren?
      Hintergrund: Ich habe per Shelly i3 unsere Zentralheizung "angezapft". Wenn der Brenner läuft geht ein DP auf true. Über diesen Datenpunkt kann man dann den Ölverbrauch berechnen.
      Aktuell mache ich das über den Statistics-Adapter, aber ich finde in Source Analytix wäre so eine funktion auch sinnvoll.
      gruß,
      Frank
      G 1 Antwort Letzte Antwort
      • ? Offline
        #740
        Es ist Schade das es mit dem Adapter nicht weiter geht bezüglich previous
        MichMeinM 1 Antwort Letzte Antwort
        -2
          MichMeinM Offline
          MichMeinM Offline
          MichMein
          schrieb am zuletzt editiert von MichMein
          #741
          @Yetiberg sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
          Ist vielleicht nicht die richtige Wortwahl meinerseits, dafür entschuldige ich mich jetzt schon mal. Aber wenn es Dir zu lange dauert kannst Du es ja selber für Dich weiterentwickeln.
          Ich denke das @Dutchman das schon machen wird wenn er dafür die Zeit in seiner Freizeit findet.
          Gruß Michael
          Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
          KnallochseK 1 Antwort Letzte Antwort
          • MichMeinM MichMein
            KnallochseK Nicht stören
            Knallochse
            #742
            @MichMein das hätte ich nicht besser formulieren können 👍
            • H hetti72
              gruß,
              Frank
              guergen
              #743
              @hetti72 Betriebstundenzähler ist doch ganz einfach:
              H 1 Antwort Letzte Antwort
              • G guergen
                hetti72
                #744
                @guergen sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                @hetti72 Betriebstundenzähler ist doch ganz einfach.
                Ich weiss das ein Betriebstundenzähler keine Rocketscience ist und sich mit ein paar Scriptzeilen realisieren lässt, das war aber nicht der Inhalt meines Posts.
                Ich fände es gut wenn eine solche Funktion in den Adapter integriert werden würde und meine Frage ob eine solche Funktion geplant ist.
                Der Adapter macht ja auch schon andere Berechnungen wie Watt in KWh. Und da sich aus den Betriebsstunden eines Geräts verschiedene Verbräuche wie Öl, Wasser oder Strom ableiten lassen würde das auch gut zur "Kernkompetenz" des Adpaters passen.
                gruß,
                Frank
                  @XBiT sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                  Wie erfolgt die Rechnung von Watt nach KWh? bei den Shellys 2.5 habe ich festgestellt das der Watt Wert nicht immer im gleichen Intervall übertragen wird es kann sein das ein neuer Wert alle 2 Sekunden kommt es können aber auch bis zu 14 Sekunden sein (Je nach Änderung der Leistung).
                  Schönen Abend noch ...
                  die Berechnung findet bei jeder aenderung des DP Statt, bei watt Berechnungen ist es also SEHR wichtig das die werte Regelmäßig (also jede Sekunde) reinkommen wen da abstände von 10-30 Sekunden drin sind kannste das Resultat vergessen (Berechnung ist Leistung * zeit, also watt * zeit = watt stunde)
                  Was mach dann der Adapter mit dem kleineren Wert als vorher... ist die Rechnung dann noch richtig?
                  er kumuliert (also sieht den reset und zählt weiter)
                  @MichMein sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                  Ne weitere Möglichkeit wäre es eventuell über ein Script zu lösen, das greift wenn der Wert 0kWh erkannt wird und dann weiter aufaddiert.
                  nicht noetig, macht SA vom haus aus
                  Es können ja Maximal 60 Watt Werte pro Minute ankommen damit könnte man auch was basteln auch wenn dann die Anzeige 1Min verzögert ist.
                  wie gesagt das macht SA fuer dich, hier der code zur Berechnung :
                  calckWh = (((readingData.currentReadingWattTs - readingData.previousReadingWattTs)) * readingData.previousReadingWatt / 3600000);
                  https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/blob/a2647455c3109cb9069effd5491574c11eca2783/main.js#L1209-L1253
                  @hg6806 sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                  Nochmal die Frage ob und wie man Daten aus den alten Ordnern "...........consumption/delivery.current_year" jede Werte in den Ordner 2020 kopiert.
                  Einzeln wäre das ja eine Sträflingsarbeit.
                  das waehre mit einem script moeglich, hatte aber leider noch keine zeit das zu. machen als Ergänzung
                  @Xsev sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                  So wie es aussieht werden die einzelnen Wochentage aus current week auch nicht in die previous week übernommen. Schätze selbes Problem wie beim pervious day, welches du ja schon bestätigt hast.
                  previous ist noch buggy
                  Sollte current week nicht Sonntag Nacht 0Uhr alle Tage auf 0 gesetzt werden?
                  ja, wie gesagt die Funktion klappt leider noch nicht und hatte die letzten tage keine zeit :/
                  Ich logge aktuell einen 3em, ich hab die letzten Tage mal mit dem Shellyverbrauch (App) verglichen und die Daten stimmen bei mir relativ gut überein.
                  Das freut mich 👍
                  babl
                  schrieb am zuletzt editiert von babl
                  #745
                  @Dutchman genau da liegt auch mein Problem,
                  Da ich meinen netzbezug und die netzeinspeisung berechnen lasse, habe ich natürlich nur Werte wenn der Fall auch ist. So kommt nun der Fall netzbezug zum Tragen dann wird durch ein blockly Script die vorhandenen wattzahlen in einen eigens angelegten datenpunkt geschrieben. Aus diesem datenpunkt rechnet dann SA. Und da fällt mir auf dass der 1. Wert der aktiv geschrieben wird irgendwie komplett berechnet werden und dann stimmt natürlich die Berechnung nicht mehr.
                  Bei datenpunkt die den ganzen Tag laufen z. B Verbrauch da stimmt die Berechnung des SA nahezu 100%
                  Kann man hier irgendwie das Problem lösen?
                  Gruß babl
                  Eventuell die Werte 0 wo eigentlich nichts kommt vom datenpunkt mit einem Wert von 0.0001 beschreiben lassen das wäre ein Lösungsvorschlag von mir weiss aber nicht ob das so umsetzbar ist.
                  • N Offline
                    N Offline
                    Naturfreund
                    schrieb am zuletzt editiert von Naturfreund
                    #746
                    Hi, ich hab SourceAnalytix in der Version 0.4.8.alpha 2 installiert und möchte damit den Stromverbrauch der Shellys (W) in kWh speichern. Die Shellys haben auch noch eine Funktion zum Stromzählen integriert, die wird aber bei Netzausfall oder Restart auf 0 gesetzt, ist also nicht für Langzeitmessungen geeignet.
                    Ich stand vor der Entscheidung SA Adapter oder Skript und hab ich für den Adapter entschieden.
                    Bisher hat auch alles geklappt. Nun hab ich gestern einen neuen Shelly für die Phase in der Küche in Betrieb genommen und wollte einen Vergleich zwischen Shelly interner Stromzählfunktion zu SourceAnalytix machen. Dabei ist folgendes heraus gekommen:
                    Küche SA = SourceAnalytix current_reading (Source ist Shelly Power in W)
                    Küche Shelly = Energy (Stromzähler aus dem Shelly)
                    Anfangs lief es noch ganz gut, aber in der Nacht ist der Stromzähler von SA wieder auf 0 zurück gegangen. Am Morgen dann gab es einen Lastpeak (Wasserkocher eingeschalten). Der Peak führte zu einer sehr hohen Verbrauchsberechnung in SA die weit von der Verbrauchsberechnung im Shelly 1 PM abweicht.
                    Bin natürlich jetzt verunsichert ob die errechneten Verbrauchswerte von SA verlässlich sind oder die vom Shelly stimmen. Aktuell traue ich den Werten der Shellys.
                    schönen Gruß
                      Das freut mich 👍
                      N Offline
                      N Offline
                      Naturfreund
                      #747
                      Ok, Lösung für die falsche Berechnung "Watt to kWh" wurde bereist weiter oben im Thread besprochen, sorry.
                      @Dutchman said in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                      Das freut mich 👍
                      • N Offline
                        N Offline
                        Naturfreund
                        #748
                        Nächstes Problem:
                        Ich hatte heute den Strom auf der Phase von der Küche für ca. 1/2h abgeschalten (Sicherungsautomat aus). Hinter dem Sicherungsautomaten hängt direkt der Shelly 1PM. Während der Strom abgeschalten war, hat der Adapter einen exorbitant hohen Verbrauch errechnet:
                        Legende wie oben, gelb = SA Wert, grün = Shelly intern gemessener Verbrauch.
                        Ich gehe davon aus, da der Shelly in dieser Zeit immer 0kWh liefert addiert SA den previous Wert ständig auf bis der "Stromausfall" vorbei ist?!
                        Schönen Gruß
                        [EDIT]
                        SourceAnalytix hat in der influxDB für meinen Shelly immer ein 0 eingetragen und damit den Wert vom Shelly überschrieben?!
                        B DutchmanD 2 Antworten Letzte Antwort
                        • N Naturfreund
                          Nächstes Problem:
                          Schönen Gruß
                          [EDIT]
                          babl
                          #749
                          @Naturfreund wie gesagtich habe das ganze jetzt über blockly so gelöst, sollten keine Werte eingehen dann lasse ich mit dem Script alle 2 Sekunden 0.01 Watt einrechnen und dann stimmen die Werte top mit dem geeichten 2 richtungszähler überein auch bei lastspitzen.
                          • N Naturfreund
                            Nächstes Problem:
                            Schönen Gruß
                            [EDIT]
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            schrieb am zuletzt editiert von Dutchman
                            #750
                            @Naturfreund sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                            sourcanalytix aenders nicht den wert des Objektes selbes das sieht nach einen anzeigefehler aus.
                            noe der shelly liefert nix, also ist der letzte WATT wert ueber die zeit wo nix kam berechnet nach kWh (watt nach kWh = verbrauch * zeit)
                            N 1 Antwort Letzte Antwort
                              N Offline
                              N Offline
                              Naturfreund
                              #751
                              Das bezweifle ich, da die Auswertung in Grafana ebenso die Werte liefert. Die werden tatsächlich von SA in die Datenbank geschrieben.
                              Ich habe jetzt den SA Adapter gestoppt, die Datenpunkte für die Küche gelöscht, die Auswertung für den Shelly in der Küche neu angelegt und den Adapter wieder gestartet und jetzt läuft es auch. Seit dem werden keine Werte mehr von SA in den Datenpunkt vom Shelly geschrieben.
                              Siehe oben, SA hat den Wert 0 in die Datenbank geschrieben.
                              • N Naturfreund
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #752
                                Sa macht keinen set-state auf den source Datenpunkt !
                                Ich vermute den bekannten admin bug der dies verursacht es passiert nämlich das wen im admin was geändert wird er nicht admin dort anzeigt sondern den letzten source von Änderungen.
                                SA ändert keinen wert nur das object (schreibt startwerte rein) das SA den value ändert ist code technisch unmöglich
                                (siehe sourcecode, es gibt keinen this.setStateForeign() in meinen code und das ist die einzige function die sowas machen könnte)
                                  N Offline
                                  N Offline
                                  Naturfreund
                                  #753
                                  @Dutchman Wie auch immer das passiert ist weiß ich nicht. Jedenfalls war in dem Zeitraum des "Anzeigefehlers" auch der Wert in der Datenbank tatsächlich 0kWh obwohl vom Shelly mit einer niedrigeren Frequenz korrekte Werte übertragen wurden. Ich kann nur das Berichten was ich sehe, sorry. Wenn SA ausgeschlossen werden kann, dann danke für die Rückmeldung.
                                  Seit gestern läuft es.
                                  [EDIT]
                                  Vielleicht hab ich mich auch missverständlich ausgedrückt. Der Wert wurde in die InfluxDB zum Datenpunkt aus dem Shelly geschrieben.
                                  • N Naturfreund
                                    [EDIT]
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #754
                                    hatte ich schon verstanden und auch gesehen in deinem screenshot, ich kan mir aber nicht erklaehren wie da SA drin genannt wird da SA keinen setState macht auf der source daher kan ich es code-technisch auschliesen.
                                    einzige was mich triggert und die Ursache sein kan ist der DEF:0 bug in den Datenpunkte, wen SA dan los legt oder nachts die werte ins object schreibt macht der JS-controller da nen kleinen Fehler. Eventueel ist diese Ursache auch bei dir der fall aber dan in ner anderen situation
                                    Siehe hier das issue dazu, fix in der niesten version des JS-controller : https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/issues/191
                                    Thomas BraunT N 2 Antworten Letzte Antwort
                                      #755
                                      Habe jetzt nicht alles gelesen, allerdings ist mir bei einigen Setups eine Diskrepanz in den Versionen aufgefallen.
                                      Wenn man Adapter in AlphaStage laufen hat, dann sollte wenigstens die node-Version nicht hinterherhängen.
                                      node: v10.19.0
                                      könnte für einige Codeteile aus alpha zu alt sein.
                                        DL7MDX
                                        #756
                                        ich habe ein Problem mit den Zählerwerten.
                                        Habe ein paar Steckdosen mit der ausgabe "Watt", was mir SA zu einem kWh Wert rechnen sollte.
                                        Die letzten zwei Tage hat das auch geklappt...
                                        Eben habe ich rein geschaut, waren alle dieser Werte plötzlich im Minus bzw. auf Null...
                                        wie kann das sein gibt es Lösungen dafür?
                                        Gruß Harald
                                          node: v10.19.0
                                          DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #757
                                          @Thomas-Braun sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                                          node: v10.19.0
                                          verstehe nicht genau was du damit aussagen möchtest aber SourceAnalytix benötig node 8 oder hoeher :)
