  4. Probleme wegen dasWetter Icons bei Installation von hm-rpc
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
15 Beiträge 3 Kommentatoren 1.3k Aufrufe 1 Beobachtet
  • hananH hanan
    @Thomas-Braun
    pi@ioBrokerM:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] On node 0 totalpages: 2061312
    [    0.000000]   DMA zone: 2304 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 1864704 pages, LIFO batch:63
    [    0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
    [    0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2059008
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:B1:8D:7A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b6325533-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x14c00000-0x18c00000] (64MB)
    [    0.000000] Memory: 7800764K/8245248K available (10240K kernel code, 725K rwdata, 2740K rodata, 2048K init, 853K bss, 182340K reserved, 262144K cma-reserved, 7458816K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 30051 entries in 59 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0
    [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [    0.000030] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [    0.000112] bcm2835: system timer (irq = 17)
    [    0.000788] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000808] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000829] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [    0.000845] Switching to timer-based delay loop, resolution 18ns
    [    0.001090] Console: colour dummy device 80x30
    [    0.001583] printk: console [tty1] enabled
    [    0.001643] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [    0.001685] pid_max: default: 32768 minimum: 301
    [    0.002008] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.002049] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.003224] Disabling memory control group subsystem
    [    0.003339] CPU: Testing write buffer coherency: ok
    [    0.003827] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.004672] Setting up static identity map for 0x200000 - 0x20003c
    [    0.004874] rcu: Hierarchical SRCU implementation.
    [    0.005509] smp: Bringing up secondary CPUs ...
    [    0.006667] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.007933] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.009140] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.009283] smp: Brought up 1 node, 4 CPUs
    [    0.009351] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.009376] CPU: All CPU(s) started in HYP mode.
    [    0.009399] CPU: Virtualization extensions available.
    [    0.010176] devtmpfs: initialized
    [    0.023412] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [    0.023684] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.023731] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.031481] pinctrl core: initialized pinctrl subsystem
    [    0.032507] NET: Registered protocol family 16
    [    0.036080] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.037714] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.037748] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.038088] Serial: AMBA PL011 UART driver
    [    0.041682] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.060851] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-09-02 21:13, variant start
    [    0.070866] raspberrypi-firmware soc:firmware: Firmware hash is 4439d2aaa6c376a2d1ef4402f142e1cf4de37c43
    [    0.124094] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [    0.128445] vgaarb: loaded
    [    0.128919] SCSI subsystem initialized
    [    0.129142] usbcore: registered new interface driver usbfs
    [    0.129234] usbcore: registered new interface driver hub
    [    0.129364] usbcore: registered new device driver usb
    [    0.130824] clocksource: Switched to clocksource arch_sys_counter
    [    0.881458] VFS: Disk quotas dquot_6.6.0
    [    0.881578] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.881747] FS-Cache: Loaded
    [    0.881953] CacheFiles: Loaded
    [    0.882751] simple-framebuffer: probe of 0.framebuffer failed with error -12
    [    0.892237] thermal_sys: Registered thermal governor 'step_wise'
    [    0.892835] NET: Registered protocol family 2
    [    0.893574] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    0.893625] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.893718] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.893806] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.893961] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.894010] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.894267] NET: Registered protocol family 1
    [    0.894961] RPC: Registered named UNIX socket transport module.
    [    0.894990] RPC: Registered udp transport module.
    [    0.895013] RPC: Registered tcp transport module.
    [    0.895037] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.895070] PCI: CLS 0 bytes, default 64
    [    0.896828] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.898950] Initialise system trusted keyrings
    [    0.899177] workingset: timestamp_bits=14 max_order=21 bucket_order=7
    [    0.909876] FS-Cache: Netfs 'nfs' registered for caching
    [    0.910585] NFS: Registering the id_resolver key type
    [    0.910673] Key type id_resolver registered
    [    0.910698] Key type id_legacy registered
    [    0.910732] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.911865] Key type asymmetric registered
    [    0.911893] Asymmetric key parser 'x509' registered
    [    0.912073] bounce: pool size: 64 pages
    [    0.912132] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    0.912377] io scheduler mq-deadline registered
    [    0.912404] io scheduler kyber registered
    [    0.916159] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    0.916200] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [    0.916285] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
    [    0.916368] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
    [    0.972968] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
    [    0.973287] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    0.973320] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.973352] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
    [    0.973427] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    0.973677] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    0.977140] PCI: bus0: Fast back to back transfers disabled
    [    0.977374] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    0.977532] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    0.977965] pci 0000:01:00.0: PME# supported from D0 D3hot
    [    0.981462] PCI: bus1: Fast back to back transfers disabled
    [    0.981534] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    0.981572] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [    0.981669] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.981704] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    0.982011] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    0.982252] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
    [    0.982637] pcieport 0000:00:00.0: AER: enabled with IRQ 55
    [    0.982974] pci 0000:01:00.0: enabling device (0140 -> 0142)
    [    1.029440] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x7b8 took 45395 usecs
    [    1.035979] iproc-rng200 fe104000.rng: hwrng registered
    [    1.036321] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    1.036972] vc-sm: Videocore shared memory driver
    [    1.037523] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [    1.049169] brd: module loaded
    [    1.061089] loop: module loaded
    [    1.062423] Loading iSCSI transport class v2.0-870.
    [    1.064381] libphy: Fixed MDIO Bus: probed
    [    1.064967] bcmgenet fd580000.ethernet: failed to get enet clock
    [    1.065001] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [    1.065036] bcmgenet fd580000.ethernet: failed to get enet-wol clock
    [    1.065070] bcmgenet fd580000.ethernet: failed to get enet-eee clock
    [    1.065110] bcmgenet: Skipping UMAC reset
    [    1.080866] libphy: bcmgenet MII bus: probed
    [    1.170924] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [    1.171930] usbcore: registered new interface driver r8152
    [    1.172020] usbcore: registered new interface driver lan78xx
    [    1.172094] usbcore: registered new interface driver smsc95xx
    [    1.172519] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.172566] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [    1.174750] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
    [    1.176011] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [    1.176048] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.176081] usb usb1: Product: xHCI Host Controller
    [    1.176107] usb usb1: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
    [    1.176134] usb usb1: SerialNumber: 0000:01:00.0
    [    1.176732] hub 1-0:1.0: USB hub found
    [    1.176838] hub 1-0:1.0: 1 port detected
    [    1.177389] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.177430] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [    1.177471] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    1.177949] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    [    1.177985] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.178017] usb usb2: Product: xHCI Host Controller
    [    1.178044] usb usb2: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
    [    1.178071] usb usb2: SerialNumber: 0000:01:00.0
    [    1.178641] hub 2-0:1.0: USB hub found
    [    1.178722] hub 2-0:1.0: 4 ports detected
    [    1.180100] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    1.180392] dwc_otg: FIQ enabled
    [    1.180404] dwc_otg: NAK holdoff enabled
    [    1.180415] dwc_otg: FIQ split-transaction FSM enabled
    [    1.180430] Module dwc_common_port init
    [    1.180884] usbcore: registered new interface driver uas
    [    1.181005] usbcore: registered new interface driver usb-storage
    [    1.181220] mousedev: PS/2 mouse device common for all mice
    [    1.183284] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    1.185761] sdhci: Secure Digital Host Controller Interface driver
    [    1.185792] sdhci: Copyright(c) Pierre Ossman
    [    1.186363] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    1.186895] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.190669] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.191033] hidraw: raw HID events driver (C) Jiri Kosina
    [    1.191224] usbcore: registered new interface driver usbhid
    [    1.191250] usbhid: USB HID core driver
    [    1.192271] vchiq: vchiq_init_state: slot_zero = (ptrval)
    [    1.194158] [vc_sm_connected_init]: start
    [    1.203035] [vc_sm_connected_init]: end - returning 0
    [    1.205033] Initializing XFRM netlink socket
    [    1.205083] NET: Registered protocol family 17
    [    1.205202] Key type dns_resolver registered
    [    1.205578] Registering SWP/SWPB emulation handler
    [    1.205920] registered taskstats version 1
    [    1.205952] Loading compiled-in X.509 certificates
    [    1.206441] Key type ._fscrypt registered
    [    1.206467] Key type .fscrypt registered
    [    1.216437] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    1.216522] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
    [    1.222452] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    1.223384] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    1.223414] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    1.273833] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    1.275487] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.277138] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.280076] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    1.281746] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.289328] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [    1.292177] of_cfs_init
    [    1.292432] of_cfs_init: OK
    [    1.293543] Waiting for root device PARTUUID=b6325533-02...
    [    1.320747] random: fast init done
    [    1.326554] mmc0: new high speed SDHC card at address 5048
    [    1.327547] mmcblk0: mmc0:5048 SD32G 29.0 GiB
    [    1.329810]  mmcblk0: p1 p2
    [    1.344879] mmc1: new high speed SDIO card at address 0001
    [    1.364025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.364113] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.371767] devtmpfs: mounted
    [    1.379668] Freeing unused kernel memory: 2048K
    [    1.411126] Run /sbin/init as init process
    [    1.540877] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    1.723459] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [    1.723503] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.723533] usb 1-1: Product: USB2.0 Hub
    [    1.725371] hub 1-1:1.0: USB hub found
    [    1.725700] hub 1-1:1.0: 4 ports detected
    [    2.050876] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
    [    2.063607] systemd[1]: System time before build time, advancing clock.
    [    2.188152] usb 1-1.4: New USB device found, idVendor=0451, idProduct=16c8, bcdDevice= 1.00
    [    2.188196] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    2.188229] usb 1-1.4: Product: CC2538 USB CDC
    [    2.188256] usb 1-1.4: Manufacturer: Texas Instruments
    [    2.200548] NET: Registered protocol family 10
    [    2.202719] Segment Routing with IPv6
    [    2.239049] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    2.239863] systemd[1]: Detected architecture arm.
    [    2.290147] systemd[1]: Set hostname to <ioBrokerM>.
    [    2.995017] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.006512] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.009676] systemd[1]: Created slice system-getty.slice.
    [    3.010399] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.011541] systemd[1]: Created slice User and Session Slice.
    [    3.012854] systemd[1]: Listening on Journal Socket.
    [    3.018382] systemd[1]: Mounting RPC Pipe File System...
    [    3.027004] systemd[1]: Starting Set the console keyboard layout...
    [    3.034928] systemd[1]: Starting Create list of required static device nodes for the current kernel...
    [    3.048129] systemd[1]: Starting Load Kernel Modules...
    [    3.738060] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.830215] systemd-journald[114]: Received request to flush runtime journal from PID 1
    [    4.391394] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [    4.391865] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [    4.392286] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [    4.392664] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [    4.479115] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.482967] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    4.483031] [vc_sm_connected_init]: start
    [    4.486640] [vc_sm_connected_init]: installed successfully
    [    4.583788] mc: Linux media interface: v0.10
    [    4.605426] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.617942] bcm2835_audio bcm2835_audio: card created with 8 channels
    [    4.673411] videodev: Linux video capture interface: v2.00
    [    4.713570] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [    4.787785] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.790003] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.801769] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.802575] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.814893] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.897203] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [    4.897397] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    4.897458] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    4.900232] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [    4.903902] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [    4.907090] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    4.907131] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    4.908101] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [    4.908129] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [    4.908157] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [    4.908180] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [    4.908206] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [    4.909693] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    4.909825] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [    4.922533] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    4.922591] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    5.043860] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    5.073072] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    [    5.073195] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [    5.073220] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    5.073232] [drm] No driver support for vblank timestamp query.
    [    5.073244] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
    [    5.074636] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
    [    5.074771] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [    5.078369] usbcore: registered new interface driver cdc_acm
    [    5.078384] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    5.169399] brcmfmac: F1 signature read @0x18000000=0x15264345
    [    5.183826] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    5.184731] usbcore: registered new interface driver brcmfmac
    [    5.222489] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    [    5.461397] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    5.477816] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
    [    6.844552] uart-pl011 fe201000.serial: no DMA platform data
    [    6.985008] random: crng init done
    [    6.985027] random: 7 urandom warning(s) missed due to ratelimiting
    [    7.225650] 8021q: 802.1Q VLAN Support v1.8
    [    7.430855] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [    7.688584] bcmgenet: Skipping UMAC reset
    [    7.690037] bcmgenet fd580000.ethernet: configuring instance for external RGMII
    [    7.690215] bcmgenet fd580000.ethernet eth0: Link is Down
    [   12.891039] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [   12.891084] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   14.079079] Bluetooth: Core ver 2.22
    [   14.079150] NET: Registered protocol family 31
    [   14.079160] Bluetooth: HCI device and connection manager initialized
    [   14.079181] Bluetooth: HCI socket layer initialized
    [   14.079196] Bluetooth: L2CAP socket layer initialized
    [   14.079220] Bluetooth: SCO socket layer initialized
    [   14.088665] Bluetooth: HCI UART driver ver 2.3
    [   14.088680] Bluetooth: HCI UART protocol H4 registered
    [   14.088748] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   14.088993] Bluetooth: HCI UART protocol Broadcom registered
    [   14.318762] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   14.318770] Bluetooth: BNEP filters: protocol multicast
    [   14.318791] Bluetooth: BNEP socket layer initialized
    [ 1157.426989] mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
    pi@ioBrokerM:~ $
    @hanan
    Das passt soweit.
    sudo -u iobroker groups
    • hananH hanan
      Hallo zusammen
      Habe ein Multihost mit zwei PI4 und wollte heute den hm-rpc aktualisieren. Schwupp und er war weg...
      Jetzt habe ich alle drei Adapter gelöscht und wollte diese neu auf dem Master installieren. Leider erhalte ich folgende Fehlermeldung: Fertig mit Fehler: host.ioBrokerM Cannot install iobroker.hm-rpc@1.14.24: 243
      $ ./iobroker add hm-rpc 0 --host ioBrokerM
      NPM version: 6.14.8
      npm install iobroker.hm-rpc@1.14.24 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EACCESnpm ERR! syscall unlinknpm ERR! path /opt/iobroker/node_modules/.iobroker.daswetter.DELETE/admin/icons/mond/1.pngnpm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.daswetter.DELETE/admin/icons/mond/1.png'npm ERR!  [OperationalError: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.daswetter.DELETE/admin/icons/mond/1.png'] {npm ERR!   cause: [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.daswetter.DELETE/admin/icons/mond/1.png'] {npm ERR!     errno: -13,npm ERR!     code: 'EACCES',npm ERR!     syscall: 'unlink',npm ERR!     path: '/opt/iobroker/node_modules/.iobroker.daswetter.DELETE/admin/icons/mond/1.png'npm ERR!   },npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'unlink',npm ERR!   path: '/opt/iobroker/node_modules/.iobroker.daswetter.DELETE/admin/icons/mond/1.png',npm ERR!   parent: 'iobroker'npm ERR! }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-10-28T14_58_24_496Z-debug.log
      ERROR: host.ioBrokerM Cannot install iobroker.hm-rpc@1.14.24: 243
      Habe bei beiden ein reboot durchgeführt und wollte den Adapter neu installieren, immer noch den gleichen Fehler.
      Hat mir bitte jemand einen Tipp.
      @hanan sagte in HM-RPC Verschieben auf Multihost schlägt fehl:
      Was um alles in der Welt hat der dasWetter-Adapter (oder hier ide icons) mit hm-rpc zu tun?
        @Homoran
        Nix... Da ist aber offenbar tiefer im System was borKed.
          @Homoran
          Dieser Beitrag wurde gelöscht!
            [[topic:post-is-deleted]]
            • hananH Offline
              hananH Offline
              hanan
              @Thomas-Braun sagte in HM-RPC Verschieben auf Multihost schlägt fehl:
              iobroker tty dialout audio video bluetooth gpio i2c
              Liebe Grüsse aus der Schweiz
              Andy
              ioBroker auf NUC unter Proxmox, Raspberrymatic-CCU auf NUC unter Proxmox mit RPI-RF-MOD Funkmodul und Omnidiraktional Antenne
              • hananH hanan
                @hanan
                iobroker stop
                iobroker fix
                iobroker start
                hananH 1 Antwort Letzte Antwort
                  @hanan
                  iobroker stop
                  iobroker fix
                  iobroker start
                  hananH Offline
                  hananH Offline
                  hanan
                  @Thomas-Braun
                  Supi, habe dieses durchgeführt und konnte den Adapter jetzt installieren.
                  Besten Dank für die schnelle Hilfe.
                  Andy
                  • hananH hanan
                    @Thomas-Braun
                    @hanan
                    Dann gewöhn dir den root-login ab, der vermutlich zu dem Fehler geführt hat.
                    • hananH Offline
                      hananH Offline
                      hanan
                      OK, ich loge mich zwar immer mit "pi" ein und arbeite mit "sudo".
                      Mache ich hier etwas falsch? Bin ja nicht so ein Linux-Profi und mache vieles via Forum.
                      Andy
                      • hananH hanan
                        @hanan War nur eine Vermutung von mir. Irgendwie hast du da die Rechte verbogen, das passiert halt bevorzugt und besonders leicht beim rumhantieren als root.
                        • hananH Offline
                          hananH Offline
                          hanan
                          OK, dann bin ich beruhigt.
                          Jedenfalls nochmals vielen Dank für die schelle Hilfe.
                          Und bleibt gesund...
                          Andy
