  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 133.8k Aufrufe
  • D
    D
    DAndre
    #217
    Перебрался на "новую" железку, вроде все работает. НО не могу обновить iobroker.js-controller до 0.11.0
    ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    ! npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
    ! npm WARN iobroker No description
    ! npm WARN iobroker No repository field.
    ! npm WARN iobroker No README data
    ! npm WARN iobroker No license field.
    ! npm ERR! Linux 4.4.0-31-generic
    ! npm ERR! argv "/usr/bin/nodejs" "/usr/local/bin/npm" "install" "iobroker.js-controller"
    ! npm ERR! node v4.4.7
    ! npm ERR! npm v3.10.5
    ! npm ERR! path /opt/iobroker/node_modules/.staging/abbrev-bc1a4de2
    ! npm ERR! code ENOENT
    ! npm ERR! errno -2
    ! npm ERR! syscall rename
    ! npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/abbrev-bc1a4de2' -> '/opt/iobroker/node_modules/npm/node_modules/abbrev'
    ! npm ERR! enoent This is most likely not a problem with npm itself
    ! npm ERR! enoent and is related to npm not being able to find a file.
    ! npm ERR! enoent
    ! npm ERR! Please include the following file with any support request:
    ! npm ERR! /opt/iobroker/npm-debug.log
    <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
    Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
    • H
      H
      Haus
      #218
      @DAndre:
      ! npm ERR! errno -2
      ! npm ERR! enoent
      ! npm ERR! /opt/iobroker/npm-debug.log `
      cd /opt/iobroker
      iobroker stop
      npm install iobroker.js-controller
      iobroker start
      js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
      admin: 3.6.0
      javascript: 4.1.10
      web: 2.4.1 vis: 1.1.10
      cloud: 2.6.2
      Server: DELL FX170 / linux: Debian 9.5 Stretch
      Adapter: MegaD-2561, Mega-ES…
      • D
        D
        DAndre
        #219
        :( Увы не хочет обновляться :(
        ! Xshell 4 (Build 0142)
        ! Copyright © 2002-2014 NetSarang Computer, Inc. All rights reserved.
        ! Type `help' to learn how to use Xshell prompt.
        ! Xshell:>
        ! Connecting to 192.168.2.9:22...
        ! Connection established.
        ! To escape to local shell, press 'Ctrl+Alt+]'.
        ! Welcome to Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)
        ! * Documentation: https://help.ubuntu.com
        ! * Management: https://landscape.canonical.com
        ! * Support: https://ubuntu.com/advantage
        ! 0 packages can be updated.
        ! 0 updates are security updates.
        ! Last login: Thu Jul 28 22:48:20 2016
        ! andrey@server:~$ sudo cd /opt/iobroker
        ! [sudo] пароль для andrey:
        ! sudo: cd: команда не найдена
        ! andrey@server:~$ cd /opt/iobroker
        ! andrey@server:/opt/iobroker$ sudo iobroker stop
        ! Stopping iobroker controller daemon…
        ! iobroker controller daemon stopped.
        ! Exit code for "killall.sh": 0
        ! andrey@server:/opt/iobroker$ sudo npm install iobroker.js-controller
        ! /opt/iobroker
        ! ├─┬ iobroker.terminal@0.1.2
        ! │ └── authenticate-pam@1.0.2
        ! └─┬ kodi-ws@2.4.0
        ! ├── UNMET PEER DEPENDENCY eslint@<2.3.0
        ! └─┬ ws@0.7.2
        ! ├─┬ bufferutil@1.1.0
        ! │ └── nan@1.8.4
        ! └── utf-8-validate@1.1.0
        ! npm ERR! errno -2
        ! npm ERR! enoent
        ps стоит nvm. Почему так?
        andrey@server:/opt/iobroker$ npm -v
        2.14.2
        andrey@server:/opt/iobroker$ sudo npm -v
        3.10.5
        • BluefoxB
          #220
          @DAndre:
          ! Xshell:>
          ! /opt/iobroker
          ! └─┬ kodi-ws@2.4.0
          ! └─┬ ws@0.7.2
          ! │ └── nan@1.8.4
          ! npm ERR! errno -2
          ! npm ERR! enoent
          2.14.2
          3.10.5 `
          Поставь 2 npm:
          cd /opt/iobroker
          sudo npm install -g npm@latest-2
          sudo npm install iobroker.js-controller --production
          • D
            D
            DAndre
            #221
            Не хочет
            ` > Поставь 2 npm:
            Код:
            cd /opt/iobroker
            sudo npm install iobroker.js-controller –production `
            andrey@server:/opt/iobroker$ sudo npm install iobroker.js-controller --production
            ! > iobroker.js-controller@0.11.1 install /opt/iobroker/node_modules/iobroker.js-controller
            node lib/setup.js setup first
            ! fs.js:549
            return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
            ! Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
            at Error (native)
            at Object.fs.openSync (fs.js:549:18)
            at Object.fs.writeFileSync (fs.js:1156:15)
            at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:536:23
            at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:557:11)
            at Module._compile (module.js:409:26)
            at Object.Module._extensions..js (module.js:416:10)
            at Module.load (module.js:343:32)
            at Function.Module._load (module.js:300:12)
            npm ERR! argv "/usr/bin/nodejs" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
            npm ERR! npm v2.15.9
            npm ERR! code ELIFECYCLE
            ! npm ERR! iobroker.js-controller@0.11.1 install: node lib/setup.js setup first
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@0.11.1 install script 'node lib/setup.js setup first'.
            npm ERR! This is most likely a problem with the iobroker.js-controller package,
            npm ERR! not with npm itself.
            npm ERR! Tell the author that this fails on your system:
            npm ERR! node lib/setup.js setup first
            npm ERR! You can get information on how to open an issue for this project with:
            npm ERR! npm bugs iobroker.js-controller
            npm ERR! Or if that isn't available, you can get their info via:
            npm ERR!
            npm ERR! npm owner ls iobroker.js-controller
            npm ERR! There is likely additional logging output above.
            andrey@server:/opt/iobroker$</anonymous>
            • BluefoxB
              #222
              cd /opt/iobroker
              sudo chmod 777 * -R
              • D
                D
                DAndre
                #223
                не…...
                ! andrey@server:/opt/iobroker$ sudo chmod 777 * -R
                ! andrey@server:/opt/iobroker$ sudo npm install iobroker.js-controller –production
                ! > node lib/setup.js setup first
                ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/readable-stream requires isarray@'~1.0.0' but will load
                ! npm WARN unmet dependency /opt/iobroker/node_modules/isarray,
                ! npm WARN unmet dependency which is version 0.0.1
                ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires aws4@'^1.2.1' but will load
                ! npm WARN unmet dependency /opt/iobroker/node_modules/aws4,
                ! npm WARN unmet dependency which is version 0.4.2
                ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires qs@'~6.1.0' but will load
                ! npm WARN unmet dependency /opt/iobroker/node_modules/qs,
                ! npm WARN unmet dependency which is version 6.2.1
                ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires tough-cookie@'~2.2.0' but will load
                ! npm WARN unmet dependency /opt/iobroker/node_modules/tough-cookie,
                ! npm WARN unmet dependency which is version 2.3.0
                ! iobroker.js-controller@0.11.1 node_modules/iobroker.js-controller
                ! ├── semver@4.3.6
                ! └── yargs@3.32.0 (camelcase@2.1.1, window-size@0.1.4)
                100000 извинений. после sudo iobroker restart Обновился и кажется работает :D :D
                • Z
                  Z
                  znammut
                  #224
                  Здравствуйте, у вас там косяк давно продолжающийся, в шелл скриптах перенос каретки виндузовый наблюдается. От этого не все работают. Это при первоначальной инсталляции точно.
                  С уважением
                  • BluefoxB
                    #225
                    @znammut:
                    С уважением `
                    В следующей версии будет поправлено. Спасибо.
                    • A
                      A
                      andrey99986
                      #226
                      Какая версия nodejs рекомендуется?
                      Сейчас поставил последнюю - v6.5.0, работает, но мало ли что…
                      Как правильно инсталлировать ( в каком каталоге) node-red-node-serialport (https://www.npmjs.com/package/node-red-node-serialport) , чтобы node-red нормально его увидел?
                      Iobroker установлен в /home/iobroker.
                      Node-red при запуске логах ругается на отсутствие файлов "serialport.node".
                      • E
                        E
                        electric
                        #227
                        @andrey99986:
                        Сейчас поставил последнюю - v6.5.0, работает, но мало ли что… `
                        Рекомендуется версия LTS (на данный момент 4.5.0)
                        @andrey99986:
                        Node-red при запуске логах ругается на отсутствие файлов "serialport.node". `
                        Если открыть настройки node-red, то там есть строка для ввода "Дополнительные NPM Модули" (через запятую), туда можно ввести название нужного модуля.
                        • A
                          A
                          andrey99986
                          #228
                          @electric:
                          Если открыть настройки node-red, то там есть строка для ввода "Дополнительные NPM Модули" (через запятую), туда можно ввести название нужного модуля. `
                          Это понятно, но прежде чем вносить надо же его (serialport) установить - или драйвер сам с инета скачает и поставит?
                          • E
                            E
                            electric
                            #229
                            @andrey99986:
                            или драйвер сам с инета скачает и поставит? `
                            Именно! ;)
                            • A
                              A
                              andrey99986
                              #230
                              Отлично.
                              В данный момент в закладке "Драйвера" - только установленные, в логе "warning: Cannot read "http://download.iobroker.net/sources-dist.json""
                              Часто такое бывает?
                              • I
                                I
                                instalator
                                #231
                                @andrey99986:
                                Отлично.
                                Часто такое бывает? `
                                Бывает иногда, скоро заработает.
                                Высокий уровень Децибел вреден для здоровья!
                                http://blog.instalator.ru/
                                • V
                                  V
                                  Vlad_k
                                  #232
                                  ставлю брокер на очередную плату от планшета на процике Allwinner A33, сам брокер встал работает но при установке Javascript драйвера вываливает ошибки:
                                  ! android@localhost:/opt/iobroker$ sudo npm install iobroker.javascript –production --prefix "/opt/iobroker"
                                  ! npm WARN engine form-data@2.0.0: wanted: {"node":">= 0.12"} (current: {"node":"0.10.47","npm":"2.15.1"})
                                  ! npm ERR! tar.unpack untar error /root/.npm/har-validator/2.0.6/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/node-uuid/1.4.7/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/hawk/3.1.3/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/http-signature/1.1.1/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/delayed-stream/1.0.0/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/tough-cookie/2.3.1/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/qs/6.2.1/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/cron-parser/1.1.0/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/mime-db/1.24.0/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/asynckit/0.4.0/package.tgz
                                  ! npm ERR! tar.unpack untar error /root/.npm/readable-stream/2.0.6/package.tgz
                                  ! npm ERR! Linux 3.4.39
                                  ! npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript" "--production" "--prefix" "/opt/iobroker"
                                  ! npm ERR! node v0.10.47
                                  ! npm ERR! npm v2.15.1
                                  ! npm ERR! code ENOSPC
                                  ! npm ERR! errno 54
                                  ! npm ERR! nospc ENOSPC, write
                                  ! npm ERR! nospc This is most likely not a problem with npm itself
                                  ! npm ERR! nospc and is related to insufficient space on your system.
                                  чем полечить?
                                  • I
                                    I
                                    instalator
                                    #233
                                    @Vlad_k:
                                    ! npm ERR! errno 54
                                    чем полечить? `
                                    Это не помогает?
                                    • BluefoxB
                                      #234
                                      @Vlad_k:
                                      ! npm ERR! errno 54
                                      чем полечить? `
                                      ENOSPC => error: no space
                                      Так что полечи новой карточкой
                                      • V
                                        V
                                        Vlad_k
                                        #235
                                        @Bluefox:
                                        Так что полечи новой карточкой `
                                        linux ставил на системную флешку забыл про сд карту… но подчистил место и все зашуршало.
                                        ПС только счас заметил при одинаковом кол-ве работающих драйверов, линукс брокер жрет всего 100 метров а под виндой 361 оперативы, почему такая разница большая?
                                        и еще хотелка появилась, надо сделать экспорт списка установленных драйверов, для импорта и установки на чистую систему
                                        • H
                                          H
                                          Haus
                                          #236
                                          @Vlad_k:
                                          @Bluefox:
                                          и еще хотелка появилась, надо сделать экспорт списка установленных драйверов, для импорта и установки на чистую систему `
                                          Копируешь папку iobroker-data и все твои наработки, драйвера в новой системе.
                                          Если смотришь в админе то это только ioBroker данные, если перезапустишь iob ситуация может изменится.
                                          admin: 3.6.0
                                          javascript: 4.1.10
                                          cloud: 2.6.2
                                          84.2k
