  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 133.8k Aufrufe
  • BluefoxB
    #220
    @DAndre:
    :( Увы не хочет обновляться :(
    ! Xshell 4 (Build 0142)
    ! Copyright © 2002-2014 NetSarang Computer, Inc. All rights reserved.
    ! Type `help' to learn how to use Xshell prompt.
    ! Xshell:>
    ! Connecting to 192.168.2.9:22...
    ! Connection established.
    ! To escape to local shell, press 'Ctrl+Alt+]'.
    ! Welcome to Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)
    ! * Documentation: https://help.ubuntu.com
    ! * Management: https://landscape.canonical.com
    ! * Support: https://ubuntu.com/advantage
    ! 0 packages can be updated.
    ! 0 updates are security updates.
    ! Last login: Thu Jul 28 22:48:20 2016
    ! andrey@server:~$ sudo cd /opt/iobroker
    ! [sudo] пароль для andrey:
    ! sudo: cd: команда не найдена
    ! andrey@server:~$ cd /opt/iobroker
    ! andrey@server:/opt/iobroker$ sudo iobroker stop
    ! Stopping iobroker controller daemon…
    ! iobroker controller daemon stopped.
    ! Exit code for "killall.sh": 0
    ! andrey@server:/opt/iobroker$ sudo npm install iobroker.js-controller
    ! /opt/iobroker
    ! ├─┬ iobroker.terminal@0.1.2
    ! │ └── authenticate-pam@1.0.2
    ! └─┬ kodi-ws@2.4.0
    ! ├── UNMET PEER DEPENDENCY eslint@<2.3.0
    ! └─┬ ws@0.7.2
    ! ├─┬ bufferutil@1.1.0
    ! │ └── nan@1.8.4
    ! └── utf-8-validate@1.1.0
    ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    ! npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
    ! npm WARN iobroker No description
    ! npm WARN iobroker No repository field.
    ! npm WARN iobroker No README data
    ! npm WARN iobroker No license field.
    ! npm ERR! Linux 4.4.0-31-generic
    ! npm ERR! argv "/usr/bin/nodejs" "/usr/local/bin/npm" "install" "iobroker.js-controller"
    ! npm ERR! node v4.4.7
    ! npm ERR! npm v3.10.5
    ! npm ERR! path /opt/iobroker/node_modules/.staging/abbrev-bc1a4de2
    ! npm ERR! code ENOENT
    ! npm ERR! errno -2
    ! npm ERR! syscall rename
    ! npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/abbrev-bc1a4de2' -> '/opt/iobroker/node_modules/npm/node_modules/abbrev'
    ! npm ERR! enoent This is most likely not a problem with npm itself
    ! npm ERR! enoent and is related to npm not being able to find a file.
    ! npm ERR! enoent
    ! npm ERR! Please include the following file with any support request:
    ! npm ERR! /opt/iobroker/npm-debug.log
    ps стоит nvm. Почему так?
    andrey@server:/opt/iobroker$ npm -v
    2.14.2
    andrey@server:/opt/iobroker$ sudo npm -v
    3.10.5 `
    Поставь 2 npm:
    cd /opt/iobroker
    sudo npm install -g npm@latest-2
    sudo npm install iobroker.js-controller --production
    • D
      D
      DAndre
      #221
      Не хочет
      ` > Поставь 2 npm:
      Код:
      cd /opt/iobroker
      sudo npm install iobroker.js-controller –production `
      andrey@server:/opt/iobroker$ sudo npm install iobroker.js-controller --production
      ! > iobroker.js-controller@0.11.1 install /opt/iobroker/node_modules/iobroker.js-controller
      node lib/setup.js setup first
      ! fs.js:549
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      ! Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
      at Error (native)
      at Object.fs.openSync (fs.js:549:18)
      at Object.fs.writeFileSync (fs.js:1156:15)
      at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:536:23
      at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:557:11)
      at Module._compile (module.js:409:26)
      at Object.Module._extensions..js (module.js:416:10)
      at Module.load (module.js:343:32)
      at Function.Module._load (module.js:300:12)
      npm ERR! argv "/usr/bin/nodejs" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
      npm ERR! npm v2.15.9
      npm ERR! code ELIFECYCLE
      ! npm ERR! iobroker.js-controller@0.11.1 install: node lib/setup.js setup first
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@0.11.1 install script 'node lib/setup.js setup first'.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node lib/setup.js setup first
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs iobroker.js-controller
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR! npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      andrey@server:/opt/iobroker$</anonymous>
      <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
      Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
      • BluefoxB
        #222
        cd /opt/iobroker
        sudo chmod 777 * -R
        • D
          D
          DAndre
          #223
          не…...
          ! andrey@server:/opt/iobroker$ sudo chmod 777 * -R
          ! andrey@server:/opt/iobroker$ sudo npm install iobroker.js-controller –production
          ! > node lib/setup.js setup first
          ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/readable-stream requires isarray@'~1.0.0' but will load
          ! npm WARN unmet dependency /opt/iobroker/node_modules/isarray,
          ! npm WARN unmet dependency which is version 0.0.1
          ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires aws4@'^1.2.1' but will load
          ! npm WARN unmet dependency /opt/iobroker/node_modules/aws4,
          ! npm WARN unmet dependency which is version 0.4.2
          ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires qs@'~6.1.0' but will load
          ! npm WARN unmet dependency /opt/iobroker/node_modules/qs,
          ! npm WARN unmet dependency which is version 6.2.1
          ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires tough-cookie@'~2.2.0' but will load
          ! npm WARN unmet dependency /opt/iobroker/node_modules/tough-cookie,
          ! npm WARN unmet dependency which is version 2.3.0
          ! iobroker.js-controller@0.11.1 node_modules/iobroker.js-controller
          ! ├── semver@4.3.6
          ! └── yargs@3.32.0 (camelcase@2.1.1, window-size@0.1.4)
          100000 извинений. после sudo iobroker restart Обновился и кажется работает :D :D
          • Z
            Z
            znammut
            #224
            Здравствуйте, у вас там косяк давно продолжающийся, в шелл скриптах перенос каретки виндузовый наблюдается. От этого не все работают. Это при первоначальной инсталляции точно.
            С уважением
            • BluefoxB
              #225
              @znammut:
              С уважением `
              В следующей версии будет поправлено. Спасибо.
              • A
                A
                andrey99986
                #226
                Какая версия nodejs рекомендуется?
                Сейчас поставил последнюю - v6.5.0, работает, но мало ли что…
                Как правильно инсталлировать ( в каком каталоге) node-red-node-serialport (https://www.npmjs.com/package/node-red-node-serialport) , чтобы node-red нормально его увидел?
                Iobroker установлен в /home/iobroker.
                Node-red при запуске логах ругается на отсутствие файлов "serialport.node".
                • E
                  E
                  electric
                  #227
                  @andrey99986:
                  Сейчас поставил последнюю - v6.5.0, работает, но мало ли что… `
                  Рекомендуется версия LTS (на данный момент 4.5.0)
                  @andrey99986:
                  Node-red при запуске логах ругается на отсутствие файлов "serialport.node". `
                  Если открыть настройки node-red, то там есть строка для ввода "Дополнительные NPM Модули" (через запятую), туда можно ввести название нужного модуля.
                  • A
                    A
                    andrey99986
                    #228
                    @electric:
                    Если открыть настройки node-red, то там есть строка для ввода "Дополнительные NPM Модули" (через запятую), туда можно ввести название нужного модуля. `
                    Это понятно, но прежде чем вносить надо же его (serialport) установить - или драйвер сам с инета скачает и поставит?
                    • E
                      E
                      electric
                      #229
                      @andrey99986:
                      или драйвер сам с инета скачает и поставит? `
                      Именно! ;)
                      • A
                        A
                        andrey99986
                        #230
                        Отлично.
                        В данный момент в закладке "Драйвера" - только установленные, в логе "warning: Cannot read "http://download.iobroker.net/sources-dist.json""
                        Часто такое бывает?
                        • I
                          I
                          instalator
                          #231
                          @andrey99986:
                          Отлично.
                          Часто такое бывает? `
                          Бывает иногда, скоро заработает.
                          Высокий уровень Децибел вреден для здоровья!
                          http://blog.instalator.ru/
                          • V
                            V
                            Vlad_k
                            #232
                            ставлю брокер на очередную плату от планшета на процике Allwinner A33, сам брокер встал работает но при установке Javascript драйвера вываливает ошибки:
                            ! android@localhost:/opt/iobroker$ sudo npm install iobroker.javascript –production --prefix "/opt/iobroker"
                            ! npm WARN engine form-data@2.0.0: wanted: {"node":">= 0.12"} (current: {"node":"0.10.47","npm":"2.15.1"})
                            ! npm ERR! tar.unpack untar error /root/.npm/har-validator/2.0.6/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/node-uuid/1.4.7/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/hawk/3.1.3/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/http-signature/1.1.1/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/delayed-stream/1.0.0/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/tough-cookie/2.3.1/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/qs/6.2.1/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/cron-parser/1.1.0/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/mime-db/1.24.0/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/asynckit/0.4.0/package.tgz
                            ! npm ERR! tar.unpack untar error /root/.npm/readable-stream/2.0.6/package.tgz
                            ! npm ERR! Linux 3.4.39
                            ! npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript" "--production" "--prefix" "/opt/iobroker"
                            ! npm ERR! node v0.10.47
                            ! npm ERR! npm v2.15.1
                            ! npm ERR! code ENOSPC
                            ! npm ERR! errno 54
                            ! npm ERR! nospc ENOSPC, write
                            ! npm ERR! nospc This is most likely not a problem with npm itself
                            ! npm ERR! nospc and is related to insufficient space on your system.
                            чем полечить?
                            • I
                              I
                              instalator
                              #233
                              @Vlad_k:
                              ! npm ERR! errno 54
                              чем полечить? `
                              Это не помогает?
                              • BluefoxB
                                #234
                                @Vlad_k:
                                ! npm ERR! errno 54
                                чем полечить? `
                                ENOSPC => error: no space
                                Так что полечи новой карточкой
                                • V
                                  V
                                  Vlad_k
                                  #235
                                  @Bluefox:
                                  Так что полечи новой карточкой `
                                  linux ставил на системную флешку забыл про сд карту… но подчистил место и все зашуршало.
                                  ПС только счас заметил при одинаковом кол-ве работающих драйверов, линукс брокер жрет всего 100 метров а под виндой 361 оперативы, почему такая разница большая?
                                  и еще хотелка появилась, надо сделать экспорт списка установленных драйверов, для импорта и установки на чистую систему
                                  • H
                                    H
                                    Haus
                                    #236
                                    @Vlad_k:
                                    @Bluefox:
                                    и еще хотелка появилась, надо сделать экспорт списка установленных драйверов, для импорта и установки на чистую систему `
                                    Копируешь папку iobroker-data и все твои наработки, драйвера в новой системе.
                                    Если смотришь в админе то это только ioBroker данные, если перезапустишь iob ситуация может изменится.
                                    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                                    admin: 3.6.0
                                    javascript: 4.1.10
                                    web: 2.4.1 vis: 1.1.10
                                    cloud: 2.6.2
                                    Server: DELL FX170 / linux: Debian 9.5 Stretch
                                    Adapter: MegaD-2561, Mega-ES…
                                    • R
                                      R
                                      radon
                                      #237
                                      Ставил на виртуальные машины:
                                      • на Debian так и не встал, жаловался то на curl, то на https, в конце концов что-то его не устроило в python-rpi.gpio
                                      т.е. по сути до iobroker так и не дошло.
                                      • На ubuntu встало без проблем, что на версию с графическим интерфейсом. что на версию админ (хотя тут в консоли что-то страшное с кодировкой) iobroker заработал нормально
                                      • На Windows встал тоже без проблем.
                                      Вопрос:
                                      Как поставить на Debian? какого пакета не хватает?
                                      Образ брал с официального сайта, DVD
                                      • H
                                        H
                                        Haus
                                        #238
                                        @radon:
                                        Вопрос:
                                        Образ брал с официального сайта, DVD `
                                        Голый Debian всё под root
                                        apt-get update
                                        apt-get upgrade
                                        apt-get install curl build-essential
                                        curl -sL https://deb.nodesource.com/setup_4.x | bash -
                                        apt-get install -y nodejs
                                        mkdir /opt/iobroker
                                        cd /opt/iobroker
                                        npm install iobroker --unsafe-perm
                                        как то так
                                        admin: 3.6.0
                                        javascript: 4.1.10
                                        cloud: 2.6.2
                                        • E
                                          E
                                          evgeny_nd
                                          #239
                                          @Haus:
                                          @radon:
                                          Вопрос:
                                          apt-get update
                                          apt-get upgrade
                                          mkdir /opt/iobroker
                                          cd /opt/iobroker
                                          как то так `
                                          Подтверждаю что на Debian это рабочая инструкция, за исключением того что нужно добавить еще одну строку до "npm istall iobroker…"
                                          ln -s /usr/bin/nodejs /usr/bin/node
                                          и было бы хорошо, если бы это все выложили на оф. сайт (русскоязычный) в разделе установка.
                                          84.2k
