  4. [Gelöst] Probleme bei update VIS & Flot, Invalid version of "web"
23 Beiträge 6 Kommentatoren 5.5k Aufrufe
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    @nobody:
    Vis fehlt auch noch. Das sollte auch manuell installierbar sein
    Gesendet von meinem SM-G900F mit Tapatalk `
    Hat leider nichts gebracht, über NPM lädt er wohl flot und upload geht auch aber er bleibt auf alter versions:
    ***@***:/opt/iobroker$ sudo npm install iobroker.flot@1.3.4
    iobroker.js-controller@0.10.0 /opt/iobroker
    └── iobroker.flot@1.3.4
    ***@***:/opt/iobroker$ sudo iobroker upload flot
    got /home/rafal/iobroker/node_modules/iobroker.flot/admin
    upload [1] flot.admin /home/rafal/iobroker/node_modules/iobroker.flot/admin/index.html index.html text/html
    upload [0] flot.admin /home/rafal/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
    Update "system.adapter.flot.0"
    got /home/rafal/iobroker/node_modules/iobroker.flot/www
    upload [22] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.time.min.js lib/js/jquery.flot.time.min.js application/javascript
    upload [21] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.spline.min.js lib/js/jquery.flot.spline.min.js application/javascript
    upload [20] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.selection.min.js lib/js/jquery.flot.selection.min.js application/javascript
    upload [19] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.resize.min.js lib/js/jquery.flot.resize.min.js application/javascript
    upload [18] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.pie.min.js lib/js/jquery.flot.pie.min.js application/javascript
    upload [17] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.navigate.min.js lib/js/jquery.flot.navigate.min.js application/javascript
    upload [16] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.navigate.js lib/js/jquery.flot.navigate.js application/javascript
    upload [15] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.min.js lib/js/jquery.flot.min.js application/javascript
    upload [14] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.hiddengraphs.js lib/js/jquery.flot.hiddengraphs.js application/javascript
    upload [13] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.grow.js lib/js/jquery.flot.grow.js application/javascript
    upload [12] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.categories.min.js lib/js/jquery.flot.categories.min.js application/javascript
    upload [11] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jquery-deparam.js lib/js/jquery-deparam.js application/javascript
    upload [10] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/jqColorPicker.min.js lib/js/jqColorPicker.min.js application/javascript
    upload [9] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/lib/js/curvedLines.js lib/js/curvedLines.js application/javascript
    upload [8] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/js/words.js js/words.js application/javascript
    upload [7] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/js/settings.js js/settings.js application/javascript
    upload [6] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/js/data.js js/data.js application/javascript
    upload [5] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/js/chart.js js/chart.js application/javascript
    upload [4] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
    upload [3] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/img/resetZoom.png img/resetZoom.png image/png
    upload [2] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
    upload [1] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/img/edit.svg img/edit.svg image/svg+xml
    upload [0] flot /home/rafal/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
    dan iobroker update wieder "Adapter    "flot"          : 1.3.4    , installed 1.3.3 [Updateable]"
    • N Offline
      N Offline
      nobody
      Wo sind denn bei dir die Installationsordner für iobroker?
      So wie es aussieht scheint iobroker nicht unter /opt/iobroker sondern im home-Verzeichnis installiert zu sein:
        Sputnik24
        Bei mir hat das manuell installieren funktioniert.
        Danke @nobody für die Hilfe.
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          @nobody:
          got /home/rafal/iobroker/node_modules/iobroker.flot/admin `
          hmm ich habe Biobroker im /opt/iobroker installiert auf ubuntu, eventuell had er dadurch node ins home gesetzt.
          Biobroker ist auch im opt:
          ***@***:~$ cd /home/rafal/iobroker/
          etc/           iobroker-data/ log/           node_modules/
          ***@***:~/iobroker$ cd /opt/iobroker/
          conf/         .git/         lib/          node_modules/ tasks/        test/         tmp/
          • N Offline
            N Offline
            nobody
            ok. Auf jeden Fall scheint sich der js-controller unter /home/rafal/iobroker/node_modules/js-controller zu befinden und deswegen erfolgt der upload relativ zu diesem Verzeichnis.
            Wenn du Flot und Vis manuell vom Verzeichnis /home/rafal/iobroker aus installierst und dann den Upload startest, sollte es erstmal klappen.
            Ob es langfristig sinnvoll ist, dies nochmal sauber unter /opt/iobroker zu installieren, musst du selbst beurteilen. Wichtig ist, dass deine Daten unter
            /home/rafal/iobroker/iobroker-data/ liegen und dann auch umgezogen werden müssten.
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              @nobody:
              /home/rafal/iobroker/iobroker-data/ liegen und dann auch umgezogen werden müssten. `
              Leider hat auch das nichts gebracht, selbe schritte durchlaufen aber dan im home Verzeichnis.
              Ergebnis is das gleich wie hiervor, de NPM install klappt und upload auch aber die neue version ist nicht in Biobroker installiert.
              Mit den Verzeichnissen kommt denke ich mal weg sudo command, ich habe alles auf ubuntu laufen und nicht ner raspberrypi.
              Auf raspberry macht man alles mit root und bleibst im Verzeichnis, auf ubuntu über sudo wodurch er doch noch machen ins home schreibt.
              Edit: Noch dazu vermelden, ich hatte vorher keine Problemen als install im Verzeichnis OPT lief immer gut.
              Also hab mehr das Gefühl das nicht die Verzeichnissen sonder doch die melding falsche web version das Problem verursachen.
              Alles is immer per console mit ioborker install commando aufgesetzt nicht über GUI.
              • DutchmanD Offline
                DutchmanD Offline
                Dutchman
                ok manchmal sieht man durch baume de Wald nicht meer :(
                Ist ja logisch das ich kein flot 1.4.0 finde nach update wen ich 1.3.4 installiere und uploads mit NPM….
                Problem gelöst ! Aber halt nur durch workarround, zusammengefasst:
                • Normales update/upgrade geht schief dat Flot und Vis eine höhere version von web erwarten
                • Upgrade web geht schief weil er controller 0.12 erwarte obwohl über upgrade self die altere version kommt.
                • Workaround: Flot und vis per NPM installieren und uploaden
                Mal shaun was nach de naesten update passiert, gestern post von bluefox gesehen über controller 0.12 als demnaest bestimmt wieder update.
                  dtp
                  habe da ein ähnliches Problem. Kann allerdings keine Instanz von Flot 1.4.0 installieren, obwohl web 1.7.0 installiert ist.
                  Jemand eine Idee?
                  Neben dem js-controller 0.12.2 sind noch admin 1.6.1, socket.io 1.7.0 und simpleAPI 1.3.0 installiert.
                  Gruß,
                  Thorsten
                    simpixo
                    Hatte das gleiche Problem! Ich habe erst den js-Controller upgedated und dann ging es trotzdem nicht erst nach einem reboot konnte ich dann Flot updaten
                    Gesendet von meinem iPhone mit Tapatalk
                      Mach mal ein
                       iobroker upload web
                        dtp
                        Hallo Rainer,
                        super. Das hat geholfen.
                        Gruß,
                        Thorsten
                          dtp
                          Hab gerade aber noch ein kleines kosmetisches Problem festgestellt.
                          Flot zeigt weiterhin die Version 1.3.0 an, obwohl es wegen der Bars wohl die Version 1.4.0 sein dürfte.
                          Gruß,
                          Thorsten
                          • DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            Hast du schon Reboot gemacht + eventuell iobroker Update auf der Console?
                            Wenn ja denke ich das muss in Jira als Bug gemeldet werden.
                            Mein Thread war kein Bug Report sondern issue Meldung bei Installation, oder sehe ich das jetzt falsch?
                            Letztlich war auch meine Installation das Problem und nicht ein allgemeiner Bug :)
                              dtp
                              @Dutchman:
                              Wenn ja denke ich das muss in Jira als Bug gemeldet werden. `
                              Falls Du mich meintest, dann hat sich das mittlerweile mit Flot 1.4.1 erledigt. Da stimmt nun auch die angezeigte Versionsnummer wieder.
                              Gruß,
                              Thorsten
                              • DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                @dtp:
                                @Dutchman:
                                Gruß,
                                Thorsten `
                                Jup meinte ich, danke für die Bestätigung und Test dass Update der fix ist für dieses Problem.
