  4. admin nicht erreichbar
admin
74 Beiträge 4 Kommentatoren 7.4k Aufrufe 3 Beobachtet
  • P patrick039212
    @Homoran
    hab jetzt nochmal neu gestartet anbei das log
    2020-10-04 19:38:01.413  - debug: mihome-vacuum.0 (11384) sendMsg[1] >>> {"id":33,"method":"get_map_v1"}
    2020-10-04 19:38:01.422  - debug: mihome-vacuum.0 (11384) Receive <<< {"result":["robomap%2F260326544%2F4"],"id":33}
    2020-10-04 19:38:01.425  - debug: mihome-vacuum.0 (11384) Mappointer_updated
    2020-10-04 19:38:01.696  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:01.699  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:01.700  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:01.701  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:01.701  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:01.702  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:01.703  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:01.704  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:01.705  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:01.706  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:01.706  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:01.707  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:01.708  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:01.709  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:01.709  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:01.710  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:01.711  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:01.712  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:01.712  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:01.713  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:01.714  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:01.715  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:01.716  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:01.716  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:01.717  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:01.718  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:01.719  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:01.720  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:01.720  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:01.721  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:01.722  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:01.723  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:01.723  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:01.724  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:01.725  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:01.726  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:01.727  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:01.728  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:01.729  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:02.425  - debug: mihome-vacuum.0 (11384) sendMsg[1] >>> {"id":34,"method":"get_room_mapping"}
    2020-10-04 19:38:02.433  - debug: mihome-vacuum.0 (11384) Receive <<< {"result":[],"id":34}
    2020-10-04 19:38:02.434  - debug: mihome-vacuum.0 (11384) Empty array try to get from Map
    2020-10-04 19:38:02.435  - debug: mihome-vacuum.0 (11384) get rooms from map
    2020-10-04 19:38:02.436  - debug: mihome-vacuum.0 (11384) update_Map Mimap enabled
    2020-10-04 19:38:02.437  - debug: mihome-vacuum.0 (11384) update_Map need new mapurl
    2020-10-04 19:38:02.586  - debug: mihome-vacuum.0 (11384) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260326544/4?Expires=1601834882000&GalaxyAccessKeyId=5271733786445&Signature=T//Y3nTzxGW/AQcCSZ+YG3eTc34=
    2020-10-04 19:38:02.587  - debug: mihome-vacuum.0 (11384) update_Map got new expires:1601834882
    2020-10-04 19:38:02.588  - debug: mihome-vacuum.0 (11384) update_Map got new time:1601833082
    2020-10-04 19:38:02.770  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 11920
    2020-10-04 19:38:03.812  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 11933
    2020-10-04 19:38:07.339  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:07.341  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:07.343  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:07.344  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:07.345  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:07.346  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:07.348  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:07.349  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:07.351  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:07.352  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:07.352  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:07.354  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:07.355  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:07.356  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:07.358  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:07.359  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:07.360  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:07.361  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:07.362  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:07.364  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:07.365  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:07.366  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:07.368  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:07.369  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:07.371  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:07.372  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:07.373  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:07.375  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:07.376  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:07.377  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:07.379  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:07.380  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:07.381  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:07.383  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:07.384  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:07.385  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:07.386  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:07.387  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:07.388  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:07.936  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:07.937  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:07.938  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:07.938  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:07.939  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:07.940  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/send/index.js
    2020-10-04 19:38:07.940  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/utils.js
    2020-10-04 19:38:07.941  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/application.js
    2020-10-04 19:38:07.942  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/express.js
    2020-10-04 19:38:07.943  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/index.js
    2020-10-04 19:38:07.944  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/lib/web.js
    2020-10-04 19:38:07.944  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2020-10-04 19:38:07.945  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:07.946  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:07.947  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:07.947  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:07.948  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/send/index.js:24:12)
    2020-10-04 19:38:07.949  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:07.949  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:07.950  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:07.951  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:07.952  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19) {
    2020-10-04 19:38:07.952  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:07.953  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:07.955  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/send/index.js',
    2020-10-04 19:38:07.955  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/utils.js',
    2020-10-04 19:38:07.956  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/application.js',
    2020-10-04 19:38:07.956  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/express.js',
    2020-10-04 19:38:07.957  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/index.js',
    2020-10-04 19:38:07.958  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/lib/web.js',
    2020-10-04 19:38:07.959  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
    2020-10-04 19:38:07.959  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:07.960  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:07.960  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:07.961  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2020-10-04 19:38:07.983  - debug: zigbee.0 (11355) system.adapter.admin.0: logging false
    2020-10-04 19:38:07.991  - debug: mihome-vacuum.0 (11384) system.adapter.admin.0: logging false
    2020-10-04 19:38:07.992  - debug: cloud.0 (10174) system.adapter.admin.0: logging false
    2020-10-04 19:38:07.982  - debug: scenes.0 (11238) system.adapter.admin.0: logging false
    2020-10-04 19:38:08.429  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12003
    2020-10-04 19:38:12.168  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:12.170  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:12.171  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:12.172  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:12.173  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:12.174  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:12.175  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:12.176  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:12.177  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:12.178  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:12.179  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:12.180  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:12.181  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:12.182  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:12.183  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:12.184  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:12.185  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:12.185  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:12.186  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:12.187  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:12.188  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:12.189  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:12.190  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:12.191  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:12.192  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:12.193  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:12.193  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:12.194  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:12.195  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:12.196  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:12.196  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:12.197  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:12.198  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:12.199  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:12.200  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:12.200  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:12.201  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:12.202  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:12.202  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:13.453  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12041
    2020-10-04 19:38:13.575  - info: host.raspberrypi instance system.adapter.web.0 started with pid 12047
    2020-10-04 19:38:15.015  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:15.016  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:15.017  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:15.021  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:15.023  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:15.024  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/send/index.js
    2020-10-04 19:38:15.024  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/utils.js
    2020-10-04 19:38:15.025  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/application.js
    2020-10-04 19:38:15.026  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/express.js
    2020-10-04 19:38:15.027  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/index.js
    2020-10-04 19:38:15.027  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2020-10-04 19:38:15.028  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:15.029  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:15.030  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:15.032  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:15.033  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/send/index.js:24:12)
    2020-10-04 19:38:15.034  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:15.035  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:15.036  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:15.037  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:15.039  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19) {
    2020-10-04 19:38:15.040  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:15.040  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:15.042  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/send/index.js',
    2020-10-04 19:38:15.043  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/utils.js',
    2020-10-04 19:38:15.044  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/application.js',
    2020-10-04 19:38:15.045  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/express.js',
    2020-10-04 19:38:15.046  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/index.js',
    2020-10-04 19:38:15.047  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.web/main.js'
    2020-10-04 19:38:15.048  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:15.049  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:15.051  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:15.052  - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
    2020-10-04 19:38:17.770  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:17.771  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:17.772  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:17.773  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:17.773  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:17.774  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:17.775  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:17.775  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:17.776  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:17.776  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:17.777  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:17.778  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:17.778  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:17.779  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:17.780  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:17.780  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:17.781  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:17.782  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:17.782  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:17.783  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:17.784  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:17.784  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:17.785  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:17.785  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:17.786  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:17.787  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:17.787  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:17.788  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:17.789  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:17.789  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:17.790  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:17.790  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:17.791  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:17.792  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:17.792  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:17.793  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:17.793  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:17.794  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:17.795  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:18.939  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-10-04 19:38:18.941  - error: zigbee.0 (11355) unhandled promise rejection: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
    2020-10-04 19:38:18.943  - error: zigbee.0 (11355) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
        at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:97:28)
        at Generator.next (<anonymous>)
        at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71
        at new Promise (<anonymous>)
        at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12)
        at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:95:45)
        at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
        at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    2020-10-04 19:38:18.946  - info: zigbee.0 (11355) cleaned everything up...
    2020-10-04 19:38:18.956  - info: zigbee.0 (11355) Zigbee: disabling joining new devices.
    2020-10-04 19:38:18.963  - error: zigbee.0 (11355) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
        at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
        at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
        at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
        at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
        at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
        at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
        at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
        at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:307:33))
    2020-10-04 19:38:18.967  - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-10-04 19:38:18.968  - error: zigbee.0 (11355) unhandled promise rejection: Cannot read property 'getEntries' of null
    2020-10-04 19:38:18.979  - error: zigbee.0 (11355) TypeError: Cannot read property 'getEntries' of null
        at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:214:55)
        at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:234:16)
        at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:252:31)
        at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:200:49)
        at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:118:43)
        at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:186:42)
        at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:303:20)
        at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:442:41)
        at Zigbee.emit (events.js:315:20)
        at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
    2020-10-04 19:38:19.389  - debug: mihome-vacuum.0 (11384) sendMsg[1] >>> {"id":35,"method":"get_status"}
    2020-10-04 19:38:19.401  - debug: mihome-vacuum.0 (11384) Receive <<< {"result":[{"msg_ver":3,"msg_seq":3030,"state":8,"battery":100,"clean_time":1479,"clean_area":23770000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":35}
    2020-10-04 19:38:19.471  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12123
    2020-10-04 19:38:19.541  - info: zigbee.0 (11355) terminating
    2020-10-04 19:38:19.545  - info: zigbee.0 (11355) Terminated (NO_ERROR): Without reason
    2020-10-04 19:38:19.551  - info: zigbee.0 (11355) terminating
    2020-10-04 19:38:20.130  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
    2020-10-04 19:38:20.131  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
    2020-10-04 19:38:22.750  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:22.751  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:22.751  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:22.751  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:22.752  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:22.752  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:22.752  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:22.753  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:22.753  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:22.753  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:22.754  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:22.754  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:22.754  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:22.754  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:22.755  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:22.755  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:22.755  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:22.756  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:22.756  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:22.756  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:22.756  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:22.757  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:22.757  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:22.757  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:22.757  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:22.758  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:22.758  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:22.758  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:22.759  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:22.759  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:22.759  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:22.759  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:22.760  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:22.760  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:22.760  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:22.760  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:22.761  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:22.761  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:22.761  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:23.035  - info: alexa2.0 (10513) Subscribing to states...
    2020-10-04 19:38:23.803  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12155
    2020-10-04 19:38:26.970  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:26.972  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:26.972  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:26.973  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:26.974  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:26.975  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:26.976  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:26.976  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:26.977  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:26.978  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:26.978  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:26.979  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:26.980  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:26.980  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:26.981  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:26.982  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:26.982  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:26.983  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:26.983  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:26.984  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:26.985  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:26.985  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:26.986  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:26.987  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:26.987  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:26.988  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:26.989  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:26.989  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:26.990  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:26.991  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:26.991  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:26.992  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:26.993  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:26.993  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:26.994  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:26.995  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:26.995  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:26.996  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:26.997  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:28.760  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12225
    2020-10-04 19:38:32.433  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:32.434  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:32.435  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:32.436  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:32.436  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:32.437  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:32.438  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:32.439  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:32.439  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:32.440  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:32.441  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:32.441  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:32.442  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:32.443  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:32.443  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:32.444  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:32.445  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:32.445  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:32.446  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:32.447  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:32.447  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:32.448  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:32.449  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:32.449  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:32.450  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:32.451  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:32.451  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:32.452  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:32.453  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:32.453  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:32.454  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:32.455  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:32.455  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:32.456  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:32.457  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:32.457  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:32.458  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:32.459  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:32.460  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:33.489  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12262
    2020-10-04 19:38:36.820  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:36.822  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:36.823  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:36.823  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:36.824  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:36.825  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:36.825  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:36.826  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:36.827  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:36.828  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:36.828  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:36.829  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:36.830  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:36.830  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:36.831  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:36.832  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:36.832  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:36.833  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:36.834  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:36.834  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:36.837  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:36.838  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:36.839  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:36.840  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:36.841  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:36.842  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:36.842  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:36.843  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:36.844  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:36.845  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:36.846  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:36.847  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:36.847  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:36.848  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:36.849  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:36.849  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:36.850  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:36.851  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:36.852  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:37.879  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12332
    2020-10-04 19:38:37.992  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 12338
    2020-10-04 19:38:39.401  - debug: mihome-vacuum.0 (11384) sendMsg[1] >>> {"id":36,"method":"get_status"}
    2020-10-04 19:38:39.428  - debug: mihome-vacuum.0 (11384) Receive <<< {"result":[{"msg_ver":3,"msg_seq":3032,"state":8,"battery":100,"clean_time":1479,"clean_area":23770000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":36}
    2020-10-04 19:38:42.965  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:42.969  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:42.972  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:42.974  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:42.977  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:42.980  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:42.984  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:42.986  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:42.988  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:42.990  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:42.993  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:42.995  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:42.999  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:43.011  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:43.014  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:43.016  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:43.019  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:43.021  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:43.024  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:43.026  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:43.028  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:43.030  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:43.033  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:43.138  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:43.141  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:43.144  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:43.146  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:43.149  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:43.154  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:43.157  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:43.160  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:43.162  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:43.165  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:43.167  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:43.169  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:43.171  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:43.173  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:43.175  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:43.178  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:43.333  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:43.335  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:43.336  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:43.337  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:43.339  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:43.340  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/send/index.js
    2020-10-04 19:38:43.342  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/utils.js
    2020-10-04 19:38:43.343  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/application.js
    2020-10-04 19:38:43.345  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/express.js
    2020-10-04 19:38:43.347  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/index.js
    2020-10-04 19:38:43.348  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/lib/web.js
    2020-10-04 19:38:43.350  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2020-10-04 19:38:43.352  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:43.354  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:43.356  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:43.357  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:43.358  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/send/index.js:24:12)
    2020-10-04 19:38:43.359  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:43.361  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:43.363  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:43.365  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:43.366  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19) {
    2020-10-04 19:38:43.368  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:43.371  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:43.372  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/send/index.js',
    2020-10-04 19:38:43.374  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/utils.js',
    2020-10-04 19:38:43.376  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/application.js',
    2020-10-04 19:38:43.377  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/express.js',
    2020-10-04 19:38:43.378  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/index.js',
    2020-10-04 19:38:43.379  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/lib/web.js',
    2020-10-04 19:38:43.381  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
    2020-10-04 19:38:43.382  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:43.384  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:43.386  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:43.388  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2020-10-04 19:38:43.421  - debug: scenes.0 (11238) system.adapter.admin.0: logging false
    2020-10-04 19:38:43.426  - debug: mihome-vacuum.0 (11384) system.adapter.admin.0: logging false
    2020-10-04 19:38:43.444  - debug: cloud.0 (10174) system.adapter.admin.0: logging false
    2020-10-04 19:38:44.216  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12406
    2020-10-04 19:38:45.098  - info: host.raspberrypi instance system.adapter.web.0 started with pid 12420
    2020-10-04 19:38:47.435  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:47.438  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:47.449  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:47.451  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:47.454  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:47.457  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/send/index.js
    2020-10-04 19:38:47.459  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/utils.js
    2020-10-04 19:38:47.461  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/application.js
    2020-10-04 19:38:47.463  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/lib/express.js
    2020-10-04 19:38:47.465  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/express/index.js
    2020-10-04 19:38:47.467  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2020-10-04 19:38:47.470  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:47.472  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:47.474  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:47.475  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:47.477  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/send/index.js:24:12)
    2020-10-04 19:38:47.478  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:47.485  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:47.487  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:47.489  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:47.491  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19) {
    2020-10-04 19:38:47.493  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:47.495  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:47.498  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/send/index.js',
    2020-10-04 19:38:47.500  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/utils.js',
    2020-10-04 19:38:47.502  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/application.js',
    2020-10-04 19:38:47.504  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/lib/express.js',
    2020-10-04 19:38:47.506  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/express/index.js',
    2020-10-04 19:38:47.508  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.web/main.js'
    2020-10-04 19:38:47.510  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:47.511  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:47.513  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:47.525  - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
    2020-10-04 19:38:49.604  - error: host.raspberrypi Caught by controller[0]: internal/modules/cjs/loader.js:968
    2020-10-04 19:38:49.607  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2020-10-04 19:38:49.610  - error: host.raspberrypi Caught by controller[0]:   ^
    2020-10-04 19:38:49.612  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module 'mime'
    2020-10-04 19:38:49.614  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2020-10-04 19:38:49.615  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
    2020-10-04 19:38:49.616  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
    2020-10-04 19:38:49.618  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
    2020-10-04 19:38:49.620  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    2020-10-04 19:38:49.622  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    2020-10-04 19:38:49.623  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:49.625  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:49.627  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:14:14)
    2020-10-04 19:38:49.630  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:49.637  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:49.641  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:49.643  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:49.645  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:49.647  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:49.653  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/index.js:12:20)
    2020-10-04 19:38:49.655  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:49.656  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:49.657  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32)
    2020-10-04 19:38:49.659  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    2020-10-04 19:38:49.660  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1025:19)
    2020-10-04 19:38:49.663  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
    2020-10-04 19:38:49.664  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:19:21)
    2020-10-04 19:38:49.666  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1137:30)
    2020-10-04 19:38:49.668  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    2020-10-04 19:38:49.669  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:985:32) {
    2020-10-04 19:38:49.671  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2020-10-04 19:38:49.673  - error: host.raspberrypi Caught by controller[0]:   requireStack: [
    2020-10-04 19:38:49.675  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
    2020-10-04 19:38:49.685  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
    2020-10-04 19:38:49.686  - error: host.raspberrypi Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.telegram/main.js'
    2020-10-04 19:38:49.687  - error: host.raspberrypi Caught by controller[0]:   ]
    2020-10-04 19:38:49.689  - error: host.raspberrypi Caught by controller[0]: }
    2020-10-04 19:38:49.690  - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-10-04 19:38:49.690  - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2020-10-04 19:38:50.175  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12489
    2020-10-04 19:38:50.740  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 12497
    und das gefunden
    @patrick039212 sagte in admin nicht erreichbar:
    und das gefunden
    das ist aber nicht alles!
    Da ist wohl einiges im Argen.
    Das log beginnt aber doch nicht mit dem Neustart???
    Was hattest du gemacht? nur rebooted??
    P 1 Antwort Letzte Antwort
      und das gefunden
      patrick039212
      @Homoran
      ja ... mein Telegram hat keine verbindung mehr aufgebaut habe ich mir gedacht ich starte mal das system mit sudo reboot neu ... das wars ...
      HomoranH GlasfaserG 2 Antworten Letzte Antwort
      • P patrick039212
        @Homoran
        das sucht ein angeblich nicht vorhandenes modul. Das passiert aber nicht einfach so
        Wenn das alles war dann stoppe mal den telegram mit
        iobroker stop telegram.0
        iobroker disable telegram.0
        iobroker restart admin
        • P patrick039212
          @Homoran
          GlasfaserG Offline
          GlasfaserG Offline
          @patrick039212
          Da ist einiges geschrottet !
          Zeige erstmal die Ausgabe von ... bevor noch mehr in die Hose geht :
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          • GlasfaserG Glasfaser
            @patrick039212
            patrick039212
            @Glasfaser
            /usr/bin/nodejs
            v12.18.4
            /usr/bin/node
            v12.18.4
            /usr/bin/npm
            6.14.6
            nodejs:
              Installiert:           12.18.4-1nodesource1
              Installationskandidat: 12.18.4-1nodesource1
              Versionstabelle:
             *** 12.18.4-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                 10.21.0~dfsg-1~deb10u1+rpi1 500
            pi@raspberrypi:~ $
            Telegram stoppen hat leider auch nichts bewirkt...
            • P patrick039212
              @Glasfaser
              /usr/bin/nodejs
              v12.18.4
              /usr/bin/node
              v12.18.4
              /usr/bin/npm
              6.14.6
              nodejs:
                Versionstabelle:
              pi@raspberrypi:~ $
              GlasfaserG Offline
              GlasfaserG Offline
              @patrick039212
              cd /opt/iobroker
              sudo npm install mime
              P HomoranH 2 Antworten Letzte Antwort
                @patrick039212
                cd /opt/iobroker
                patrick039212
                @Glasfaser
                gestern nacht war ich mit Filezilla auf dem FTP aber da kann ja auch nichts schiefgegangen sein normal... hab mir nur eine Karte gezogen ... das ich unabsichtlich einen ordner gelöscht habe ? O.O
                wird gerade installiert
                GlasfaserG HomoranH 2 Antworten Letzte Antwort
                  @patrick039212
                  cd /opt/iobroker
                  @Glasfaser https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo
                  • P patrick039212
                    @Glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @patrick039212
                    sorry ... ohne sudo !!!
                    • P patrick039212
                      @Glasfaser
                      das passt aber nicht zu dem "nichts gemacht" ;-)
                      wenn man nichts zurückspeichert oder verschiebt oder löscht oder....
                        patrick039212
                        @Homoran
                        habe nur die karte vom Staubsauger auf den Laptop gezogen....
                        wird gerade nochmal ohne sudo ausgeführt ...
                          @patrick039212
                          patrick039212
                          @Glasfaser
                          pi@raspberrypi:/opt/iobroker $ npm install mime
                          npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is ins                          talled. You must install peer dependencies yourself.
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zig                          bee-herdsman-converters/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                          2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                          )
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zi                          gbee-herdsman/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                          1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"                          })
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zig                          bee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
                          + mime@2.4.6
                          updated 1 package in 163.018s
                          58 packages are looking for funding
                            run `npm fund` for details
                          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                          • P patrick039212
                            @Glasfaser
                            + mime@2.4.6
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @patrick039212
                            ... jetzt neu durchstarten
                            • P patrick039212
                              @Glasfaser
                              + mime@2.4.6
                              @patrick039212
                              iobroker update
                              iobroker upgrade
                              Ich vermute da sind noch mehr Bits umgekippt.
                                @patrick039212
                                patrick039212
                                @Glasfaser
                                danke danke danke, es funktioniert wieder :=)
                                aber was war jetzt der fehler ? ...
                                  @Homoran sagte in admin nicht erreichbar:
                                  aber ohne weitere Wasserstandsmeldungen deinerseits ist es rühren im Kaffesatz
                                  Den Spruch .... hab ich von dir noch nie gelesen 😂
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @patrick039212
                                  @Glasfaser sagte in admin nicht erreichbar:
                                  Unsauberes runterfahren ... sagt eventuell der Kaffeesatz ;)
                                    @patrick039212
                                    patrick039212
                                    schrieb am zuletzt editiert von patrick039212
                                    @Glasfaser @Homoran
                                    Hallo muss mich leider wieder melden, Admin funktioniert aber EXTREM langsam... zudem verliere ich alle 2 - 3 Minuten die verbindung zur Cloud - Admin - FTP und Putty...
                                    Hab mir jetzt ein wenig die ganzen Adapter angesehen und mir ist etwas aufgefallen wo ich einen Rat benötigen würde... und zwar funktionieren meine Shellys nicht mehr, der Adapter hat Verbindung aber es gibt keinen Status úpdate...
                                    Meine frage nun kann es sein das aufgrund der ganzen Anfragen der PI so lahmgelegt wird ? bzw. was löst die ganzen Anfragen aus ? (bitte die Zeit beachten)
                                    shelly.0	2020-10-06 20:01:07.625	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(1)
                                    shelly.0	2020-10-06 20:01:07.175	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:01:05.622	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(0)
                                    shelly.0	2020-10-06 20:01:05.620	debug	(11126) Status update received for SHSW-1#32CC2C#2: {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 20:01:05.618	debug	(11126) CoAP status package received: {"3332":"SHSW-1#32CC2C#2","3412":38400,"3420":23042,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 20:01:05.344	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:01:05.171	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:01:05.020	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(2)
                                    shelly.0	2020-10-06 20:01:04.400	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(2)
                                    shelly.0	2020-10-06 20:01:04.159	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:01:04.146	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(2)
                                    shelly.0	2020-10-06 20:01:03.792	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:01:03.328	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:01:03.167	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:01:03.165	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,50.67],[0,4103,407649],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:01:03.162	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":35756,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,50.67],[0,4103,407649],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:01:03.016	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(1)
                                    shelly.0	2020-10-06 20:01:02.395	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(1)
                                    shelly.0	2020-10-06 20:01:02.157	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:01:02.140	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(1)
                                    shelly.0	2020-10-06 20:01:01.789	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:01:01.325	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:01:01.323	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,47.34],[0,4103,407649],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:01:01.322	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":35500,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,47.34],[0,4103,407649],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:01:01.013	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(0)
                                    shelly.0	2020-10-06 20:01:01.011	debug	(11126) Status update received for SHSW-25#B8AA46#2: {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,20384],[0,6102,0],[0,
                                    shelly.0	2020-10-06 20:01:01.010	debug	(11126) CoAP status package received: {"3332":"SHSW-25#B8AA46#2","3412":38400,"3420":44137,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,
                                    shelly.0	2020-10-06 20:01:00.393	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(0)
                                    shelly.0	2020-10-06 20:01:00.392	debug	(11126) Status update received for SHPLG-S#8013F0#2: {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,39.64],[0,3105,103.34],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:01:00.390	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#8013F0#2","3412":38400,"3420":17193,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,39
                                    shelly.0	2020-10-06 20:01:00.154	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:01:00.153	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,71.15],[0,4103,407649],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:01:00.151	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":35244,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,71.15],[0,4103,407649],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:01:00.134	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(0)
                                    shelly.0	2020-10-06 20:01:00.133	debug	(11126) Status update received for SHSW-1#BCDDC27706F1#2: {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,"S"],[0,2103,79]]}
                                    shelly.0	2020-10-06 20:01:00.130	debug	(11126) CoAP status package received: {"3332":"SHSW-1#BCDDC27706F1#2","3412":38400,"3420":44288,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,"S"],[0,2103,79]]}
                                    shelly.0	2020-10-06 20:00:59.785	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:59.784	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,147.58],[0,4103,407649],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:59.782	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":34988,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,147.58],[0,4103,407649],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 20:00:57.417	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:55.413	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:53.411	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:53.410	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,76.27],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.79],[0,3105,103.61],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:53.408	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":34220,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,76.27],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:00:53.042	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:51.039	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:50.290	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(2)
                                    shelly.0	2020-10-06 20:00:49.353	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(2)
                                    shelly.0	2020-10-06 20:00:49.051	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(2)
                                    shelly.0	2020-10-06 20:00:49.037	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:49.036	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,19.75],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,40.01],[0,3105,104.02],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:49.034	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":33708,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,19.75],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:00:48.285	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(1)
                                    shelly.0	2020-10-06 20:00:47.350	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(1)
                                    shelly.0	2020-10-06 20:00:47.047	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(1)
                                    shelly.0	2020-10-06 20:00:46.280	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:46.269	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(0)
                                    shelly.0	2020-10-06 20:00:46.267	debug	(11126) Status update received for SHSW-25#B8AA46#2: {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,20384],[0,6102,0],[0,
                                    shelly.0	2020-10-06 20:00:46.265	debug	(11126) CoAP status package received: {"3332":"SHSW-25#B8AA46#2","3412":38400,"3420":43881,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,
                                    shelly.0	2020-10-06 20:00:45.347	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(0)
                                    shelly.0	2020-10-06 20:00:45.345	debug	(11126) Status update received for SHPLG-S#8013F0#2: {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,39.56],[0,3105,103.21],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:45.343	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#8013F0#2","3412":38400,"3420":16937,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,39
                                    shelly.0	2020-10-06 20:00:45.045	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(0)
                                    shelly.0	2020-10-06 20:00:45.044	debug	(11126) Status update received for SHSW-1#BCDDC27706F1#2: {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,"S"],[0,2103,79]]}
                                    shelly.0	2020-10-06 20:00:45.042	debug	(11126) CoAP status package received: {"3332":"SHSW-1#BCDDC27706F1#2","3412":38400,"3420":44288,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,"S"],[0,2103,79]]}
                                    shelly.0	2020-10-06 20:00:44.275	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:44.128	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:42.272	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:42.270	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,51.38],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:42.268	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":33452,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,51.38],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:00:42.125	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:41.058	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:40.122	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:40.121	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,59.05],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.71],[0,3105,103.48],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:40.119	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":33196,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,59.05],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:00:39.230	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(2)
                                    shelly.0	2020-10-06 20:00:39.054	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:38.294	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:37.225	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(1)
                                    shelly.0	2020-10-06 20:00:37.082	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:37.050	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:37.049	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,111.28],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.71],[0,3105,103.48],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:37.047	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":32684,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,111.28],[0,4103,407574],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 20:00:36.291	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:35.233	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(2)
                                    shelly.0	2020-10-06 20:00:35.222	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(0)
                                    shelly.0	2020-10-06 20:00:35.221	debug	(11126) Status update received for SHSW-1#32CC2C#2: {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 20:00:35.219	debug	(11126) CoAP status package received: {"3332":"SHSW-1#32CC2C#2","3412":38400,"3420":23042,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 20:00:35.078	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:34.300	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:34.288	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:34.286	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,145.16],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.79],[0,3105,103.61],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:34.280	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":32428,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,145.16],[0,4103,407574],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 20:00:33.220	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(1)
                                    shelly.0	2020-10-06 20:00:33.073	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:33.071	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,124.99],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.79],[0,3105,103.61],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:33.069	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":32172,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,124.99],[0,4103,407574],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 20:00:32.297	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:31.217	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(0)
                                    shelly.0	2020-10-06 20:00:31.215	debug	(11126) Status update received for SHSW-25#B8AA46#2: {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,20384],[0,6102,0],[0,
                                    shelly.0	2020-10-06 20:00:31.214	debug	(11126) CoAP status package received: {"3332":"SHSW-25#B8AA46#2","3412":38400,"3420":43881,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,
                                    shelly.0	2020-10-06 20:00:30.293	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:30.292	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,111.93],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:30.291	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":31916,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,111.93],[0,4103,407574],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 20:00:28.156	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:26.153	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:24.162	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(2)
                                    shelly.0	2020-10-06 20:00:24.151	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:24.150	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,86.17],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:24.148	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":30892,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,86.17],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:00:23.242	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:22.334	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:22.159	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(1)
                                    shelly.0	2020-10-06 20:00:21.239	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:20.312	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:20.174	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(2)
                                    shelly.0	2020-10-06 20:00:20.157	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(0)
                                    shelly.0	2020-10-06 20:00:20.156	debug	(11126) Status update received for SHSW-1#32CC2C#2: {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 20:00:20.154	debug	(11126) CoAP status package received: {"3332":"SHSW-1#32CC2C#2","3412":38400,"3420":23042,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 20:00:19.266	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(2)
                                    shelly.0	2020-10-06 20:00:19.236	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:19.234	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,5.12],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.79],[0,3105,103.61],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:19.232	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":30380,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,5.12],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104
                                    shelly.0	2020-10-06 20:00:18.967	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(2)
                                    shelly.0	2020-10-06 20:00:18.951	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(2)
                                    shelly.0	2020-10-06 20:00:18.310	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:18.309	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,6.4],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.79],[0,3105,103.61],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:18.307	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":30124,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,6.4],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,
                                    shelly.0	2020-10-06 20:00:18.170	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(1)
                                    shelly.0	2020-10-06 20:00:17.262	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(1)
                                    shelly.0	2020-10-06 20:00:16.963	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(1)
                                    shelly.0	2020-10-06 20:00:16.946	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(1)
                                    shelly.0	2020-10-06 20:00:16.486	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:16.168	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(0)
                                    shelly.0	2020-10-06 20:00:16.166	debug	(11126) Status update received for SHSW-25#B8AA46#2: {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,20384],[0,6102,0],[0,
                                    shelly.0	2020-10-06 20:00:16.164	debug	(11126) CoAP status package received: {"3332":"SHSW-25#B8AA46#2","3412":38400,"3420":43881,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,
                                    shelly.0	2020-10-06 20:00:15.255	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(0)
                                    shelly.0	2020-10-06 20:00:15.252	debug	(11126) Status update received for SHPLG-S#8013F0#2: {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,39.64],[0,3105,103.34],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:15.244	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#8013F0#2","3412":38400,"3420":16937,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,39
                                    shelly.0	2020-10-06 20:00:14.960	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(0)
                                    shelly.0	2020-10-06 20:00:14.958	debug	(11126) Status update received for SHSW-1#BCDDC27706F1#2: {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,"S"],[0,2103,79]]}
                                    shelly.0	2020-10-06 20:00:14.956	debug	(11126) CoAP status package received: {"3332":"SHSW-1#BCDDC27706F1#2","3412":38400,"3420":44288,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,"S"],[0,2103,79]]}
                                    shelly.0	2020-10-06 20:00:14.937	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(0)
                                    shelly.0	2020-10-06 20:00:14.935	debug	(11126) Status update received for SHSW-25#68D390#2: {"G":[[0,9103,0],[0,1101,1],[0,1201,0],[0,2101,1],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,31.22],[0,4103,23142],[0,6102,0]
                                    shelly.0	2020-10-06 20:00:14.933	debug	(11126) CoAP status package received: {"3332":"SHSW-25#68D390#2","3412":38400,"3420":47142,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,1201,0],[0,2101,1],[0,2102,""],[0,2103,0],[0,2201,1],[0,
                                    shelly.0	2020-10-06 20:00:14.484	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:13.105	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:12.850	debug	(11126) system.adapter.admin.0: logging true
                                    shelly.0	2020-10-06 20:00:11.276	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:11.100	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:10.037	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:09.266	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:09.112	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(2)
                                    shelly.0	2020-10-06 20:00:09.097	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:09.096	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,74.49],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.94],[0,3105,103.89],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:09.094	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":29100,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,74.49],[0,4103,407574],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 20:00:08.200	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:08.033	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:07.262	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:07.260	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,180.67],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.94],[0,3105,103.89],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:07.258	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":28844,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,180.67],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3
                                    shelly.0	2020-10-06 20:00:07.109	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(1)
                                    shelly.0	2020-10-06 20:00:06.197	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:06.030	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:06.028	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,35.29],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:06.026	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":28588,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,35.29],[0,4103,407574],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 20:00:05.157	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:05.127	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(2)
                                    shelly.0	2020-10-06 20:00:05.107	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(0)
                                    shelly.0	2020-10-06 20:00:05.105	debug	(11126) Status update received for SHSW-1#32CC2C#2: {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 20:00:05.104	debug	(11126) CoAP status package received: {"3332":"SHSW-1#32CC2C#2","3412":38400,"3420":23042,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 20:00:04.502	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(2)
                                    shelly.0	2020-10-06 20:00:04.204	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:04.194	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:04.188	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,21.42],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:04.186	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":28332,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,21.42],[0,4103,407574],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 20:00:03.908	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(2)
                                    shelly.0	2020-10-06 20:00:03.899	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:03.142	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:03.122	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(1)
                                    shelly.0	2020-10-06 20:00:02.498	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(1)
                                    shelly.0	2020-10-06 20:00:02.195	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:02.062	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:01.905	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(1)
                                    shelly.0	2020-10-06 20:00:01.892	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 20:00:01.132	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:01.130	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,68.3],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:01.129	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":28076,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,68.3],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:00:01.118	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(0)
                                    shelly.0	2020-10-06 20:00:01.114	debug	(11126) Status update received for SHSW-25#B8AA46#2: {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,20384],[0,6102,0],[0
                                    shelly.0	2020-10-06 20:00:01.112	debug	(11126) CoAP status package received: {"3332":"SHSW-25#B8AA46#2","3412":38400,"3420":43881,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0
                                    shelly.0	2020-10-06 20:00:00.494	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(0)
                                    shelly.0	2020-10-06 20:00:00.493	debug	(11126) Status update received for SHPLG-S#8013F0#2: {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,39.41],[0,3105,102.94],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:00.491	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#8013F0#2","3412":38400,"3420":16937,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,3
                                    shelly.0	2020-10-06 20:00:00.193	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 20:00:00.192	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,64.8],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 20:00:00.190	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":27820,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,64.8],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 20:00:00.057	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:59.903	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(0)
                                    shelly.0	2020-10-06 19:59:59.902	debug	(11126) Status update received for SHSW-25#68D390#2: {"G":[[0,9103,0],[0,1101,1],[0,1201,0],[0,2101,1],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,31.24],[0,4103,23142],[0,6102,0
                                    shelly.0	2020-10-06 19:59:59.900	debug	(11126) CoAP status package received: {"3332":"SHSW-25#68D390#2","3412":38400,"3420":47142,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,1201,0],[0,2101,1],[0,2102,""],[0,2103,0],[0,2201,1],[0
                                    shelly.0	2020-10-06 19:59:59.889	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:59.887	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,62.1],[0,4103,407574],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:59.884	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":27564,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,62.1],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 19:59:59.315	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:58.055	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:58.054	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,60.1],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:58.052	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":27308,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,60.1],[0,4103,407511],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 19:59:57.311	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:56.217	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:55.307	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:55.306	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,116.59],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,39.56],[0,3105,103.21],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:55.304	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":27052,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,116.59],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3
                                    shelly.0	2020-10-06 19:59:55.290	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:54.213	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:54.070	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(2)
                                    shelly.0	2020-10-06 19:59:53.284	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:52.209	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:52.206	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,12.31],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,39.56],[0,3105,103.21],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:52.205	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":26540,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,12.31],[0,4103,407511],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 19:59:52.064	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(1)
                                    shelly.0	2020-10-06 19:59:51.279	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:51.278	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,9.14],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,39.86],[0,3105,103.75],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:51.276	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":26284,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,9.14],[0,4103,407511],[0,6102,0],[0,6109,0],[0,310
                                    shelly.0	2020-10-06 19:59:50.108	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(2)
                                    shelly.0	2020-10-06 19:59:50.085	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:50.061	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(0)
                                    shelly.0	2020-10-06 19:59:50.059	debug	(11126) Status update received for SHSW-1#32CC2C#2: {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 19:59:50.057	debug	(11126) CoAP status package received: {"3332":"SHSW-1#32CC2C#2","3412":38400,"3420":23042,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 19:59:49.145	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:48.851	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(2)
                                    shelly.0	2020-10-06 19:59:48.105	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(1)
                                    shelly.0	2020-10-06 19:59:48.080	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:47.301	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:47.142	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:46.847	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(1)
                                    shelly.0	2020-10-06 19:59:46.120	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:46.100	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(0)
                                    shelly.0	2020-10-06 19:59:46.095	debug	(11126) Status update received for SHSW-25#B8AA46#2: {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,20384],[0,6102,0],[0
                                    shelly.0	2020-10-06 19:59:46.093	debug	(11126) CoAP status package received: {"3332":"SHSW-25#B8AA46#2","3412":38400,"3420":43625,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0
                                    shelly.0	2020-10-06 19:59:46.074	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:46.072	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,51.75],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,40.01],[0,3105,104.02],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:46.069	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":26028,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,51.75],[0,4103,407511],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 19:59:45.298	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:45.139	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:45.138	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,59.19],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,40.01],[0,3105,104.02],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:45.136	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":25772,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,59.19],[0,4103,407511],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 19:59:44.841	debug	(11126) CoAP device description request for SHSW-1#BCDDC27706F1#2 to 192.168.0.23(0)
                                    shelly.0	2020-10-06 19:59:44.840	debug	(11126) Status update received for SHSW-1#BCDDC27706F1#2: {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,"S"],[0,2103,79]]}
                                    shelly.0	2020-10-06 19:59:44.838	debug	(11126) CoAP status package received: {"3332":"SHSW-1#BCDDC27706F1#2","3412":38400,"3420":44288,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,"S"],[0,2103,79]]}
                                    shelly.0	2020-10-06 19:59:44.233	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:44.071	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:43.306	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:43.295	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:43.293	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,47.96],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,40.01],[0,3105,104.02],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:43.291	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":25516,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,47.96],[0,4103,407511],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 19:59:42.230	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:42.068	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:42.065	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,116.43],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,40.01],[0,3105,104.02],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:42.062	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":25260,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,116.43],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3
                                    shelly.0	2020-10-06 19:59:41.302	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:40.246	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:40.225	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:40.224	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,138.53],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,39.71],[0,3105,103.48],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:40.222	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":25004,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,138.53],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3
                                    shelly.0	2020-10-06 19:59:39.298	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:39.297	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,16.98],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,39.71],[0,3105,103.48],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:39.295	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":24748,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,16.98],[0,4103,407511],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 19:59:39.013	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(2)
                                    shelly.0	2020-10-06 19:59:38.234	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:38.087	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:37.174	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:37.009	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(1)
                                    shelly.0	2020-10-06 19:59:36.230	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:36.229	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,125.73],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,40.01],[0,3105,104.02],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:36.227	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":24236,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,125.73],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3
                                    shelly.0	2020-10-06 19:59:36.083	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:35.170	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:35.029	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(2)
                                    shelly.0	2020-10-06 19:59:35.006	debug	(11126) CoAP device description request for SHSW-1#32CC2C#2 to 192.168.0.9(0)
                                    shelly.0	2020-10-06 19:59:35.004	debug	(11126) Status update received for SHSW-1#32CC2C#2: {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 19:59:35.002	debug	(11126) CoAP status package received: {"3332":"SHSW-1#32CC2C#2","3412":38400,"3420":23042,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                    shelly.0	2020-10-06 19:59:34.399	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(2)
                                    shelly.0	2020-10-06 19:59:34.081	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:34.079	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,136.77],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,40.01],[0,3105,104.02],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:34.077	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":23980,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,136.77],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3
                                    shelly.0	2020-10-06 19:59:33.785	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(2)
                                    shelly.0	2020-10-06 19:59:33.166	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(0)
                                    shelly.0	2020-10-06 19:59:33.164	debug	(11126) Status update received for SHPLG-S#B8600B#2: {"G":[[0,9103,2],[0,1101,1],[0,4101,80.03],[0,4103,407511],[0,6102,0],[0,6109,0],[0,3104,40.01],[0,3105,104.02],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:33.162	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":23724,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,80.03],[0,4103,407511],[0,6102,0],[0,6109,0],[0,31
                                    shelly.0	2020-10-06 19:59:33.013	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(1)
                                    shelly.0	2020-10-06 19:59:32.394	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(1)
                                    shelly.0	2020-10-06 19:59:31.781	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(1)
                                    shelly.0	2020-10-06 19:59:31.009	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(0)
                                    shelly.0	2020-10-06 19:59:31.007	debug	(11126) Status update received for SHSW-25#B8AA46#2: {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,20384],[0,6102,0],[0
                                    shelly.0	2020-10-06 19:59:31.005	debug	(11126) CoAP status package received: {"3332":"SHSW-25#B8AA46#2","3412":38400,"3420":43625,"Uri-Path":"cit/s"} / {"G":[[0,9103,1],[0,1101,0],[0,1201,1],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,1],[0
                                    shelly.0	2020-10-06 19:59:30.391	debug	(11126) CoAP device description request for SHPLG-S#8013F0#2 to 192.168.0.36(0)
                                    shelly.0	2020-10-06 19:59:30.389	debug	(11126) Status update received for SHPLG-S#8013F0#2: {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,39.64],[0,3105,103.34],[0,6101,0]]}
                                    shelly.0	2020-10-06 19:59:30.387	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#8013F0#2","3412":38400,"3420":16681,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,4101,0],[0,4103,189667],[0,6102,0],[0,6109,0],[0,3104,3
                                    shelly.0	2020-10-06 19:59:29.778	debug	(11126) CoAP device description request for SHSW-25#68D390#2 to 192.168.0.19(0)
                                    shelly.0	2020-10-06 19:59:29.776	debug	(11126) Status update received for SHSW-25#68D390#2: {"G":[[0,9103,0],[0,1101,1],[0,1201,0],[0,2101,1],[0,2102,""],[0,2103,0],[0,2201,1],[0,2202,""],[0,2203,0],[0,4101,31.18],[0,4103,23111],[0,6102,0
                                    shelly.0	2020-10-06 19:59:29.774	debug	(11126) CoAP status package received: {"3332":"SHSW-25#68D390#2","3412":38400,"3420":46886,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,1201,0],[0,2101,1],[0,2102,""],[0,2103,0],[0,2201,1],[0
                                    shelly.0	2020-10-06 19:59:22.127	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:20.301	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 19:59:20.284	debug	(11126) CoAP device description request for SHSW-25#B8AA46#2 to 192.168.0.32(2)
                                    shelly.0	2020-10-06 19:59:20.122	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(1)
                                    shelly.0	2020-10-06 19:59:19.109	debug	(11126) CoAP device description request for SHPLG-S#B8600B#2 to 192.168.0.17(2)
                                    shelly.0	2020-10-06 20:00:09.094	debug	(11126) CoAP status package received: {"3332":"SHPLG-S#B8600B#2","3412":38400,"3420":29100,"Uri-Path":"cit/s"} / {"G":[[0,9103,2],[0,1101,1],[0,4101,74.49],[0,4103,407574],[0,6102,0],[0,6109,0],[0,310
                                    oder ist es besser ich setze gleich den ganzen PI neu auf ?...
                                    • P patrick039212
                                      @Glasfaser @Homoran
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Meinst du die Datenverbindung im allgemeinen !?
                                      oder ist etwas im ioBroker Log vorhanden , Warn/Error Meldungen .
                                      mit Shelly kann ich nichts anfangen ......
                                      Zeige mal :
                                      ps auxww|grep io
                                        Zeige mal :
                                        ps auxww|grep io
                                        patrick039212
                                        @Glasfaser
                                        Richtig ja, die Datenverbindung bricht alle paar Minuten ab ...
                                        Wenn ich den Pi anpinge geht ca jede 2. Verbindung verloren (egal ob ich per Wlan oder Lankabel verbunden bin)
                                        Im Log habe ich nichts finden können ... kann ich aber ggf. gerne posten
                                        pi@raspberrypi:~ $ ps auxww|grep io
                                        root        12  0.0  0.0      0     0 ?        S    19:14   0:01 [migration/0]
                                        root        15  0.0  0.0      0     0 ?        S    19:14   0:00 [migration/1]
                                        root        20  0.0  0.0      0     0 ?        S    19:14   0:01 [migration/2]
                                        root        25  0.0  0.0      0     0 ?        S    19:14   0:01 [migration/3]
                                        root        42  0.0  0.0      0     0 ?        I<   19:14   0:00 [rpciod]
                                        root        44  0.0  0.0      0     0 ?        I<   19:14   0:00 [xprtiod]
                                        root        48  0.0  0.0      0     0 ?        I<   19:14   0:00 [nfsiod]
                                        root        73  0.0  0.0      0     0 ?        I<   19:14   0:00 [DWC Notificatio]
                                        message+   344  0.0  0.3   6556  3356 ?        Ss   19:15   0:02 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                        iobroker   601 13.6  9.9 182680 94820 ?        Ssl  19:15  10:41 iobroker.js-controller
                                        iobroker  1115  1.8  7.6 158548 72732 ?        Sl   19:15   1:27 io.admin.0
                                        iobroker  1331  0.3  4.6 135016 43860 ?        Sl   19:15   0:17 io.discovery.0
                                        iobroker  1371  0.5  5.4 142952 51804 ?        Sl   19:15   0:25 io.info.0
                                        iobroker  1468  0.5  5.2 141908 49484 ?        Sl   19:15   0:23 io.cloud.0
                                        iobroker  1485  0.5  5.8 146020 55740 ?        Sl   19:15   0:24 io.iot.0
                                        iobroker  1522  0.4  5.1 139456 48892 ?        Sl   19:15   0:21 io.web.0
                                        iobroker  1894  4.0 13.2 217168 125348 ?       Sl   19:16   3:08 io.javascript.0
                                        iobroker  2049  0.8  5.1 138128 49172 ?        Sl   19:16   0:37 io.ping.0
                                        iobroker  2196  0.3  4.5 133292 43080 ?        Sl   19:16   0:16 io.text2command.0
                                        iobroker  2389  0.3  4.5 133788 43396 ?        Sl   19:16   0:18 io.broadlink2.0
                                        iobroker  2395  1.2  5.5 143832 52760 ?        Sl   19:16   0:58 io.alexa2.0
                                        iobroker  2462  0.4  4.8 134152 45580 ?        Sl   19:16   0:19 io.scenes.0
                                        iobroker  2552  0.9  5.8 146100 55080 ?        Sl   19:16   0:44 io.radar2.0
                                        iobroker  2691  0.7  5.8 147192 55500 ?        Sl   19:16   0:33 io.telegram.0
                                        iobroker  2774  0.4  5.2 145780 49980 ?        Sl   19:16   0:22 io.mihome-vacuum.0
                                        iobroker 11126  3.8  6.8 152908 65220 ?        Sl   19:58   1:19 io.shelly.0
                                        iobroker 22776  0.0  0.0   2424   536 ?        Ss   20:33   0:00 /usr/bin/hcitool -i hci0 lescan --duplicates
                                        iobroker 23109  0.0  0.0   9376   780 ?        S    20:33   0:00 /bin/ping -n -w 2 -c 1 192.168.0.18
                                        pi       23117  0.0  0.0   7360   572 pts/0    S+   20:33   0:00 grep --color=auto io
                                        pi@raspberrypi:~ $
                                        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                        • P patrick039212
                                          @Glasfaser
                                          pi@raspberrypi:~ $
                                          @patrick039212
                                          Ausgabe von
                                          who -r
                                          und dann mal mit
                                          htop
                                          schauen.
