  4. Wo liegt die Statistik?
statistikdatei
19 Beiträge 3 Kommentatoren 1.7k Aufrufe 3 Beobachtet
    @AlCalzone
    Nee, da ist nix in den Objekten mit irgendeinem Bezug zu rtspStream.
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @Thomas-Braun Was liefert auf der Konsole iob object get system.adapter.rtspStream (großes S)?
    • AlCalzoneA AlCalzone
      @AlCalzone sagte in Wo liegt die Statistik?:
      pi@raspberrypi:~ $ iob object get system.adapter.rtspStream
      {"common":{"name":"rtspStream","version":"0.0.2","news":{"0.0.2":{"en":"Multiple rtsp-Streams, set video resolution","de":"Mehrere Streams möglich, Auflösung setzen"},"0.0.1":{"en":"initial Commit","de":"Erstveröffentlichung"}},"title":"Rtsp Stream","titleLang":{"en":"Rtsp Stream","de":"Rtsp Stream"},"desc":{"en":"Stream rtsp","de":"Adapter für rtsp-Streams"},"authors":["Dominic Blattmann <nick@dbweb.ch>"],"keywords":["ioBroker","rtsp","camera","Smart Home","home automation"],"license":"MIT","platform":"Javascript/Node.js","main":"main.js","icon":"rtsp.png","enabled":false,"extIcon":"https://raw.githubusercontent.com/dbweb-ch/ioBroker.rtspStream/master/admin/rtsp.png","readme":"https://github.com/dbweb-ch/ioBroker.rtspStream/blob/master/README.md","loglevel":"info","messagebox":true,"subscribe":"messagebox","restartAdapters":["rtspStream"],"mode":"daemon","type":"general","compact":true,"materialize":true,"materializeTab":false,"supportCustoms":false,"dependencies":[{"js-controller":">=1.4.2"}],"installedFrom":"https://github.com/dbweb-ch/ioBroker.rtspStream/tarball/3891a8545b5566946b89b6f4dbfeac1e2a6527a5","installedVersion":"0.0.2"},"native":{"rtspUrl":"","port":""},"protectedNative":[],"encryptedNative":[],"instanceObjects":[{"_id":"startStream","type":"state","common":{"name":"Start the stream","type":"boolean","role":"state","write":true,"def":false},"native":{}}],"objects":[],"type":"adapter","from":"system.host.raspberrypi.cli","ts":1598207551293,"_id":"system.adapter.rtspStream","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      In den Objekten finde ich wie gesagt nix:
        @Thomas-Braun sagte in Wo liegt die Statistik?:
        Das sind die Instanzen. Suche mal weiter unten. Sonst probiere im Script:
        deleteObject('system.adapter.rtspStream');
          Da ist auch nix:
          In welchem script meinst du?
            Da ist auch nix:
            @Thomas-Braun sagte:
            Ein neues Script, das nur einmal kurz gestartet wird.
              Ich hab Null Peil von scripting.
              Muss das eingeleitet werden?
              Wie ein shell-skript mit shebang?
                @Thomas-Braun:
                Hast Du den Javascript-Adapter nicht installiert ?
                  @Thomas-Braun:
                  @paul53 Doch. Aber immer nur Blöckchen verschoben. Was da für ein skript draus gekocht wird hab ich mir noch nie angeschaut... :-D
                    @Thomas-Braun:
                    Dann erstelle mal kein Blockly, sondern ein Javascript mit der Codezeile oben und starte es.
                      @Thomas-Braun:
                      Ich trau mich nich... :-)
                      Das log haut mir auch gleich auf die Finger:
                      (4929) Function "deleteObject" is not allowed. Use adapter settings to allow it.
                      Jetzt aber:
                      The object system.adapter.rtspStream was not found!
                      Danke schön, @AlCalzone & @paul53 , jetzt ist die Statistik auch wieder richtig. Der rtspStream Adapter ist wie Kaugummi, klebt an zig Stellen fest.
                      Ich denke, das hat mit dem Großbuchstaben im Namen zu tun.
                        Jetzt aber:
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @Thomas-Braun über die Konsole wäre es auch gegangen mit
                        iobroker object del objekt-id
