  4. Anfänger hat Probleme beim Anmelden in iobroker
admin anmeldung
85 Beiträge 8 Kommentatoren 9.5k Aufrufe 2 Beobachtet
  • Sam RubberduckS Sam Rubberduck
    @Homoran
    2020-09-28 14:26:36.195  - info: host.raspberrypi-iob All instances are stopped.
    2020-09-28 14:26:36.347  - info: host.raspberrypi-iob terminated
    2020-09-28 14:26:56.010  - info: host.raspberrypi-iob iobroker.js-controller version 3.1.6 js-controller starting
    2020-09-28 14:26:56.016  - info: host.raspberrypi-iob Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2020-09-28 14:26:56.017  - info: host.raspberrypi-iob hostname: raspberrypi-iob, node: v12.18.4
    2020-09-28 14:26:56.019  - info: host.raspberrypi-iob ip addresses: 192.168.178.29 2a02:810d:82bf:e2d8:dcc8:3391:2fe5:50ff fe80::dde0:86a0:a8b9:e9e4
    2020-09-28 14:26:56.395  - info: host.raspberrypi-iob connected to Objects and States
    2020-09-28 14:26:56.811  - info: host.raspberrypi-iob 13 instances found
    2020-09-28 14:26:56.849  - info: host.raspberrypi-iob starting 13 instances
    2020-09-28 14:26:56.887  - info: host.raspberrypi-iob instance system.adapter.admin.0 started with pid 629
    2020-09-28 14:26:59.342  - info: admin.0 (629) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.admin, node: v12.18.4, js-controller: 3.1.6
    2020-09-28 14:26:59.446  - info: admin.0 (629) requesting all states
    2020-09-28 14:26:59.448  - info: admin.0 (629) requesting all objects
    2020-09-28 14:27:00.182  - info: admin.0 (629) received all objects
    2020-09-28 14:27:00.340  - info: admin.0 (629) http server listening on port 8081
    2020-09-28 14:27:00.341  - info: admin.0 (629) Use link "http://localhost:8081" to configure.
    2020-09-28 14:27:00.886  - info: host.raspberrypi-iob instance system.adapter.discovery.0 started with pid 693
    2020-09-28 14:27:02.331  - info: discovery.0 (693) starting. Version 2.3.7 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.18.4, js-controller: 3.1.6
    2020-09-28 14:27:04.886  - info: host.raspberrypi-iob instance system.adapter.info.0 started with pid 708
    2020-09-28 14:27:08.160  - info: info.0 (708) starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.info, node: v12.18.4, js-controller: 3.1.6
    MOD-Edit: Code in code-tags gesetzt!
    sieht für mich alles ok aus :-(
    @Sam-Rubberduck sagte in Anfänger hat Probleme beim Anmelden in iobroker:
    192.168.178.29
    mit http://192.168.178.29:8081 rufst du den admin auf?
    kein https!
    Sam RubberduckS 1 Antwort Letzte Antwort
      192.168.178.29
      kein https!
      Sam RubberduckS Offline
      Sam Rubberduck
      @Homoran Ja, ohne https.
        Ja, ohne https.
        und die IP stimmt?
        Sam RubberduckS 2 Antworten Letzte Antwort
          Ja, ohne https.
          und die IP stimmt?
          Sam Rubberduck
          @Homoran Klar, so erreiche ich den Raspi ja übers Terminal.
            Ja, ohne https.
            und die IP stimmt?
            Sam Rubberduck
            @Homoran Wie Eingangs geschildert sehe ich ja das Eingangsbild nur eben ohne die Leiste links. Das ist ja das Verrückte.
              @paul53 Ich rufe das am Mac unter Safari auf.
              @Sam-Rubberduck:
              Wie alt ist der Mac ? Wenn Du auf die Seite ip:8081/configs.html kommst, aber auf der Seite ip:8081/index.html nur der blaue Balken bleibt, ist es wohl doch ein Problem mit der Leistung vom Frontend.
                @Sam-Rubberduck jetzt gehen mir langsam die Ideen aus.
                Klar, Safari läuft nicht gut. Firefox sollte aber keine Probleme haben, zumindest unter WIN.
                Hast du es mal mit einem Handy versucht?
                  @Sam-Rubberduck:
                  Sam Rubberduck
                  @paul53 Das glaube ich nicht. Ist ein 15" Macbook mit 16 GB RAM etc. Es hat ja schon einmal funktioniert.
                    Sam Rubberduck
                    @Homoran Geht auch nicht
                      Sam Rubberduck
                      @Homoran Ich glaube ich setze das Ding noch einmal neu auf und installiere step by step einen Adapter nach dem anderen. Bevor ich hier alle nerve.
                      Aber wehe er mag dann wieder nicht .......😠
                        hattest du etwas im admin umkonfiguriert?
                          Sam Rubberduck
                          @Sam-Rubberduck Erst mal Danke an alle für euer Feedback !!
                            so schnell kommst du uns nicht davon!
                            Jetzt will ich wissen was los ist!
                              Sam Rubberduck
                              @Homoran Nein, überhaupt nicht. Ich wüsste gar nicht wie das geht. Aber gut ich mach das Ding heute Abend platt und alles neu.
                                Sam Rubberduck
                                @Homoran Du bist hartnäckig😊
                                  @Sam-Rubberduck
                                  OK - dann mal janz höösch!
                                  • Bei der Grundinstallation sind admin, info und discovery fertig drauf. Die kannst du nicht einzeln installieren.
                                  • Habe mir gerade noch einmal deine Screenshots von zu Beginn angesehen. Warum sind die auf englisch?
                                  Thomas BraunT Sam RubberduckS 2 Antworten Letzte Antwort
                                    @Sam-Rubberduck
                                    @Homoran sagte in Anfänger hat Probleme beim Anmelden in iobroker:
                                    Vermutlich weil beim Raspberry die LOCALE nicht auf deutsch gesetzt wurde.
                                    Bei der Neuinstallation das mal anschauen und auch gleich die Zeitzone auf 'Berlin' setzen.
                                      @Sam-Rubberduck
                                      Sam Rubberduck
                                      @Homoran said in Anfänger hat Probleme beim Anmelden in iobroker:
                                      @Sam-Rubberduck
                                      Ich mache das nach der Anleitung von "haus-automatisierung.com", da ich das image nach der Anleitung von "verdrahtet" mit dem bakery tool nicht gebacken kriege. Muss das alles einzeln zusammenkramen.
                                        Außerdem glaube ich mich ganz schwach an ein Phänomen zu erinnern, dass bei fehlendem Internetzugriff diese Seite ewig brauchen soll.
                                        Finde aber nichts im log
                                          @Sam-Rubberduck
                                          Ähhhh - nein!
