  4. iobroker installation
8 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • WinniW
    WinniW
    Winni
    Hallo in die Runde, ich hatte heute einen Plattencrash. Nun möchte ich iobroker neu installieren, ich bekomme aber während der Installation immer folgende Fehlermeldungen:
    Installing ioBroker (3/4)
    In file included from ../src/main.cpp:3:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:56,
    ../src/main.cpp: At global scope:
    /home/winni/.cache/node-gyp/12.18.4/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      608 |       (node::addon_register_func) (regfunc),                          \
    /home/winni/.cache/node-gyp/12.18.4/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
      642 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       42 | NODE_MODULE(diskusage, Init)
    In file included from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc: At global scope:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.1.42:8081 in a browser and start configuring!
    Iobroker startet dann zwar, aber es sind nur 3 Adapter in der Auswahl und die lassen sich auch nicht intallieren, es kommt die Fehlermeldung: Fertig mit Fehler: this adapter does not allow multiple instances on one host
    Hab jetzt keine Idee mehr was ich falsch gemacht habe. node -v bringt v12.18.4, npm -v
    6.13.4 und nodejs -v v12.18.4.
    • WinniW Winni
      Autostart enabled!
      @Winni sagte in iobroker installation:
      die dürften harmlos (und normal) sein.
      Das ist normal
      weil die bereits installiert sind
      nix!
      alles so wie es sein soll!
      WinniW 1 Antwort Letzte Antwort
        Das ist normal
        nix!
        WinniW
        WinniW
        Winni
        @Homoran erst mal danke für die Antwort, aber normalerweise sind doch im Adapter Tab eine riesen Auswahl von Adaptern und bei mir schaut das so aus:
        • WinniW Winni
          Das ist jetzt eine andere Aussage ;-)
          drück mal oben links auf den reload button un poste dann die Ausgabe aus dem log
          • WinniW Winni
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            @Winni
            Stell mal den 'Verwahrort' auf
            http://iobroker.live/repo/sources-dist.json
              WinniW
              WinniW
              Winni
              @Homoran
              host.winni-NUC6CAYH	2020-09-27 20:05:50.544	warn	warning: empty repo received!
              host.winni-NUC6CAYH	2020-09-27 20:05:50.544	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
              host.winni-NUC6CAYH	2020-09-27 20:05:42.179	warn	warning: empty repo received!
              host.winni-NUC6CAYH	2020-09-27 20:05:42.178	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
              host.winni-NUC6CAYH	2020-09-27 20:05:26.438	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
              host.winni-NUC6CAYH	2020-09-27 20:05:22.126	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
              host.winni-NUC6CAYH	2020-09-27 20:04:51.121	warn	warning: empty repo received!
              host.winni-NUC6CAYH	2020-09-27 20:04:51.120	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
              host.winni-NUC6CAYH	2020-09-27 20:04:32.671	warn	warning: empty repo received!
              host.winni-NUC6CAYH	2020-09-27 20:04:32.670	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
              host.winni-NUC6CAYH	2020-09-27 20:04:31.068	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
              host.winni-NUC6CAYH	2020-09-27 20:04:12.616	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
              • WinniW Winni
                @Homoran
                @Winni Joa,
                bei diesem Symptom bitte mal testweise umstellen, wie es @Thomas-Braun schreibt
                WinniW GlasfaserG 2 Antworten Letzte Antwort
                  @Winni Joa,
                  WinniW
                  WinniW
                  Winni
                  schrieb am zuletzt editiert von Winni
                  @Homoran und Thomas Braun, jetzt sind sie wieder alle da 👍 😊 Tausend Dank euch beiden, jetzt kann ich weiter kämpfen 😉
                  33.2k
                  84.4k
