<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[iobroker installation]]></title><description><![CDATA[<p dir="auto">Hallo in die Runde, ich hatte heute einen Plattencrash. Nun möchte ich iobroker neu installieren, ich bekomme aber während der Installation immer folgende Fehlermeldungen:</p>
<pre><code>Installing ioBroker (3/4)
In file included from ../src/main.cpp:3:
../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
 2294 |     , reinterpret_cast&lt;uv_after_work_cb&gt;(AsyncExecuteComplete)
In file included from ../../nan/nan.h:56,
../src/main.cpp: At global scope:
/home/winni/.cache/node-gyp/12.18.4/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(v8::Local&lt;v8::Object&gt;)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local&lt;v8::Object&gt;, v8::Local&lt;v8::Value&gt;, void*)’} [-Wcast-function-type]
  608 |       (node::addon_register_func) (regfunc),                          \
/home/winni/.cache/node-gyp/12.18.4/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
  642 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
   42 | NODE_MODULE(diskusage, Init)
In file included from ../src/unix_dgram.cc:5:
../src/unix_dgram.cc: At global scope:
../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
  404 | NODE_MODULE(unix_dgram, Initialize)
ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
ioBroker wants to make sure to deliver the most stable smart home system.
To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
If you want to disable the error reporting you can use the command
'iobroker plugin disable sentry'
This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
    Finalizing installation (4/4)
Enabling autostart...
Autostart enabled!
    ioBroker was installed successfully
    Open http://192.168.1.42:8081 in a browser and start configuring!
</code></pre>
<p dir="auto">Iobroker startet dann zwar, aber es sind nur 3 Adapter in der Auswahl und die lassen sich auch nicht intallieren, es kommt die Fehlermeldung: Fertig mit Fehler: this adapter does not allow multiple instances on one host<br />
Hab jetzt keine Idee mehr was ich falsch gemacht habe. node -v bringt v12.18.4, npm -v<br />
6.13.4 und nodejs -v v12.18.4.</p>
]]></description><link>https://forum.iobroker.net/topic/37174/iobroker-installation</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 11:23:17 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/37174.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Sep 2020 17:54:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to iobroker installation on Sun, 27 Sep 2020 18:15:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a> und Thomas Braun, jetzt sind sie wieder alle da <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /> <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title=":blush:" alt="😊" /> Tausend Dank euch beiden, jetzt kann ich weiter kämpfen <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></p>
]]></description><link>https://forum.iobroker.net/post/495015</link><guid isPermaLink="true">https://forum.iobroker.net/post/495015</guid><dc:creator><![CDATA[Winni]]></dc:creator><pubDate>Sun, 27 Sep 2020 18:15:14 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker installation on Sun, 27 Sep 2020 18:08:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winni" aria-label="Profile: Winni">@<bdi>Winni</bdi></a> Joa,<br />
bei diesem Symptom bitte mal testweise umstellen, wie es <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> schreibt</p>
]]></description><link>https://forum.iobroker.net/post/495006</link><guid isPermaLink="true">https://forum.iobroker.net/post/495006</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 27 Sep 2020 18:08:20 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker installation on Sun, 27 Sep 2020 18:07:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a></p>
<pre><code>host.winni-NUC6CAYH	2020-09-27 20:05:50.544	warn	warning: empty repo received!
host.winni-NUC6CAYH	2020-09-27 20:05:50.544	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
host.winni-NUC6CAYH	2020-09-27 20:05:42.179	warn	warning: empty repo received!
host.winni-NUC6CAYH	2020-09-27 20:05:42.178	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
host.winni-NUC6CAYH	2020-09-27 20:05:26.438	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
host.winni-NUC6CAYH	2020-09-27 20:05:22.126	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
host.winni-NUC6CAYH	2020-09-27 20:04:51.121	warn	warning: empty repo received!
host.winni-NUC6CAYH	2020-09-27 20:04:51.120	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
host.winni-NUC6CAYH	2020-09-27 20:04:32.671	warn	warning: empty repo received!
host.winni-NUC6CAYH	2020-09-27 20:04:32.670	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
host.winni-NUC6CAYH	2020-09-27 20:04:31.068	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
host.winni-NUC6CAYH	2020-09-27 20:04:12.616	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
</code></pre>
]]></description><link>https://forum.iobroker.net/post/495004</link><guid isPermaLink="true">https://forum.iobroker.net/post/495004</guid><dc:creator><![CDATA[Winni]]></dc:creator><pubDate>Sun, 27 Sep 2020 18:07:51 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker installation on Sun, 27 Sep 2020 18:05:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winni" aria-label="Profile: Winni">@<bdi>Winni</bdi></a><br />
Stell mal den 'Verwahrort' auf</p>
<pre><code>http://iobroker.live/repo/sources-dist.json
</code></pre>
]]></description><link>https://forum.iobroker.net/post/494998</link><guid isPermaLink="true">https://forum.iobroker.net/post/494998</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 27 Sep 2020 18:05:17 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker installation on Sun, 27 Sep 2020 18:03:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winni" aria-label="Profile: Winni">@<bdi>Winni</bdi></a> sagte in <a href="/post/494993">iobroker installation</a>:</p>
<blockquote>
<p dir="auto">aber normalerweise sind doch im Adapter Tab eine riesen Auswahl von Adaptern</p>
</blockquote>
<p dir="auto">Das ist jetzt eine andere Aussage ;-)</p>
<p dir="auto">drück mal oben links auf den reload button un poste dann die Ausgabe aus dem log</p>
]]></description><link>https://forum.iobroker.net/post/494996</link><guid isPermaLink="true">https://forum.iobroker.net/post/494996</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 27 Sep 2020 18:03:41 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker installation on Sun, 27 Sep 2020 18:02:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a> erst mal danke für die Antwort, aber normalerweise sind doch im Adapter Tab eine riesen Auswahl von Adaptern und bei mir schaut das so aus:<br />
<img src="/assets/uploads/files/1601229766137-zwischenablage-1.jpg" alt="Zwischenablage-1.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/494993</link><guid isPermaLink="true">https://forum.iobroker.net/post/494993</guid><dc:creator><![CDATA[Winni]]></dc:creator><pubDate>Sun, 27 Sep 2020 18:02:48 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker installation on Sun, 27 Sep 2020 17:57:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winni" aria-label="Profile: Winni">@<bdi>Winni</bdi></a> sagte in <a href="/post/494979">iobroker installation</a>:</p>
<blockquote>
<p dir="auto">ich bekomme aber während der Installation immer folgende Fehlermeldungen:</p>
</blockquote>
<p dir="auto">die dürften harmlos (und normal) sein.</p>
<blockquote>
<p dir="auto">Iobroker startet dann zwar, aber es sind nur 3 Adapter in der Auswahl</p>
</blockquote>
<p dir="auto">Das ist normal</p>
<blockquote>
<p dir="auto">die lassen sich auch nicht intallieren, es kommt die Fehlermeldung: Fertig mit Fehler: this adapter does not allow multiple instances on one host</p>
</blockquote>
<p dir="auto">weil die bereits installiert sind</p>
<blockquote>
<p dir="auto">was ich falsch gemacht habe</p>
</blockquote>
<p dir="auto">nix!</p>
<p dir="auto">alles so wie es sein soll!</p>
]]></description><link>https://forum.iobroker.net/post/494982</link><guid isPermaLink="true">https://forum.iobroker.net/post/494982</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 27 Sep 2020 17:57:25 GMT</pubDate></item></channel></rss>
