  4. (gelöst) Hilfe! iobroker Upgrade schlägt fehl!
    1.7k
iobroker upgrade js-controller
13 Beiträge 5 Kommentatoren 1.2k Aufrufe 4 Beobachtet
  • E Offline
    eMarcus
    schrieb am zuletzt editiert von eMarcus
    Ich hab versucht mein System mit
    sudo ./iobroker stop
    sudo ./iobroker update
    sudo ./iobroker upgrade self
    auf den neuesten Stand zu bringen. Leider gabs dann den folgenden Output:
    marcus@iobroker:/opt/iobroker$ sudo ./iobroker upgrade self
    Update js-controller from @1.4.2 to @3.1.6
    NPM version: 6.13.4
    npm install iobroker.js-controller@3.1.6 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    /opt/iobroker/node_modules/iobroker.js-controller/lib/cli/cliPlugin.js:253
                        } catch {
    SyntaxError: Unexpected token {
        at createScript (vm.js:80:10)
        at Object.runInThisContext (vm.js:139:10)
        at Module._compile (module.js:617:28)
        at Object.Module._extensions..js (module.js:664:10)
        at Module.load (module.js:566:32)
        at tryModuleLoad (module.js:506:12)
        at Function.Module._load (module.js:498:3)
        at Module.require (module.js:597:17)
        at require (internal/module.js:11:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/cli/index.js:19:17)
    npm WARN notsup Unsupported engine for iobroker.js-controller@3.1.6: wanted: {"node":">=10.0.0"} (current: {"node":"8.17.0","npm":"6.13.4"})
    npm WARN notsup Not compatible with your version of node/npm: iobroker.js-controller@3.1.6
    npm WARN notsup Unsupported engine for mkdirp@1.0.4: wanted: {"node":">=10"} (current: {"node":"8.17.0","npm":"6.13.4"})
    npm WARN notsup Not compatible with your version of node/npm: mkdirp@1.0.4
    npm WARN notsup Unsupported engine for semver@7.3.2: wanted: {"node":">=10"} (current: {"node":"8.17.0","npm":"6.13.4"})
    npm WARN notsup Not compatible with your version of node/npm: semver@7.3.2
    npm WARN notsup Unsupported engine for tar@6.0.5: wanted: {"node":">= 10"} (current: {"node":"8.17.0","npm":"6.13.4"})
    npm WARN notsup Not compatible with your version of node/npm: tar@6.0.5
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN notsup Unsupported engine for rsa-compat@2.0.8: wanted: {"node":">=10.12"} (current: {"node":"8.17.0","npm":"6.13.4"})
    npm WARN notsup Not compatible with your version of node/npm: rsa-compat@2.0.8
    npm WARN notsup Unsupported engine for rsa-compat@1.9.4: wanted: {"node":">=10.12"} (current: {"node":"8.17.0","npm":"6.13.4"})
    npm WARN notsup Not compatible with your version of node/npm: rsa-compat@1.9.4
    npm WARN notsup Unsupported engine for chownr@2.0.0: wanted: {"node":">=10"} (current: {"node":"8.17.0","npm":"6.13.4"})
    npm WARN notsup Not compatible with your version of node/npm: chownr@2.0.0
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.4 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@3.1.6 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.1.6 install script.
    npm ERR!     /home/marcus/.npm/_logs/2020-09-26T09_17_50_457Z-debug.log
    Host "iobroker" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    Jetzt gibt jeder ./iobroker Befehl nur mehr die folgende Fehlermeldung aus:
    marcus@iobroker:/opt/iobroker$ ./iobroker start
    module.js:550
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (module.js:548:15)
        at Function.Module._load (module.js:475:25)
        at Function.Module.runMain (module.js:694:10)
        at startup (bootstrap_node.js:204:16)
        at bootstrap_node.js:625:3
    Mein System:
    Ubuntu 18.04 LTS
    KVM VM
    marcus@iobroker:/opt/iobroker$ node -v
    v8.17.0
    marcus@iobroker:/opt/iobroker$ nodejs -v
    v8.17.0
    marcus@iobroker:/opt/iobroker$ npm -v
    6.13.4
    Wie kann ich das Upgrade fixen?
    Danke,
    Marcus.
    Thomas BraunT ? 2 Antworten Letzte Antwort
    • E eMarcus
      NPM version: 6.13.4
                          } catch {
      npm ERR! errno 1
      npm ERR!
      module.js:550
          throw err;
      Mein System:
      Ubuntu 18.04 LTS
      KVM VM
      v8.17.0
      v8.17.0
      6.13.4
      Danke,
      Marcus.
      @eMarcus Ohne sudo vorweg. Und du musst node auf node12 aktualisieren.
      da hast du aber lange geschlafen.
      E 1 Antwort Letzte Antwort
      • E eMarcus
        NPM version: 6.13.4
                            } catch {
        npm ERR! errno 1
        npm ERR!
        module.js:550
            throw err;
        Mein System:
        Ubuntu 18.04 LTS
        KVM VM
        v8.17.0
        v8.17.0
        6.13.4
        Danke,
        Marcus.
        @eMarcus erstmal Node upgraden, mit V8 ist schon lange nix mehr..
          eMarcus
          @Thomas-Braun Ja eh, aber "never change a running system" - und wie man sieht hat mein Upgrade Versuch jetzt gleich mal in einer Downtime geendet ;-)
            eMarcus
            @ilovegym Hmm, dann sollte man die offizielle ioBroker Docu ev. auch anpassen, hab gestern erst nachgelesen bevor ich mit dem Update begonnen habe, und da wird noch davon gesprochen, dass 8 voll ok ist und 10 empfohlen und von 12 abgeraten!
            https://www.iobroker.net/#de/documentation/install/updatenode.md
            Aber Danke, dann werd ich das mal jetzt angehen!
            bye
            Marcus.
            crunchipC Thomas BraunT 2 Antworten Letzte Antwort
            • E eMarcus
              @eMarcus sagte in Hilfe! iobroker Upgrade schlägt fehl!:
              klar, weil das Grundsystem zu alt für die neuen Versionen ist.
              ist genau der Grund dafür.
              das muss schon sehr alt sein - sehe ich direkt nach, denn v8 ist EOL
              EDIT: Zuletzt geändert: 30.05.2019 steht drunter
              und 16 Monate sind schon Generationen bei EDV-Projekten
              • E eMarcus
                @eMarcus Falscher Ansatz. Jedenfalls über solch einen langen Zeitraum. Jetzt haste gleich 'ne Großbaustelle. Besser regelmäßig das System aktuell halten.
                • E eMarcus
                  bye
                  Marcus.
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @eMarcus aber dafür gibt es hier rechts so nen Kasten, er blinkt zwar nicht und gibt auch keinen laut von sich, aber er leuchtet in einem erfreulich strahlendem ROT
                  aber richtig, die Doku ist leider etwas hinterher(man kann sich zeitlich halt nun mal nicht um alles kümmern und wegen jeder Änderung sofort anpassen)
                  • E eMarcus
                    bye
                    Marcus.
                    @eMarcus Ist das Betriebssystem auch so aktuell wie der ioBroker?
                    Dann würde ich damit anfangen, dann node auf den 12er-Zweig und erst dann den ioBroker.
                      eMarcus
                      @Thomas-Braun Nein, das OS ist aktuell (also 18.04 LTS halt, aber regelmäßig mit apt dist-upgrade am Laufenden gehalten).
                        eMarcus
                        @Thomas-Braun, Also eigentlich lief das Update jetzt ziemlich problemlos. Wie von Dir geraten zuerst nodejs hochgezogen, danach ioBroker und die Adapter. Lief alles ohne Probleme durch!
                        Danke!
                        Marcus.
                        • E eMarcus
                          Danke!
                          Marcus.
                          @eMarcus
                          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                            @eMarcus
                            eMarcus
                            @Thomas-Braun said in Hilfe! iobroker Upgrade schlägt fehl!:
                            marcus@iobroker:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                            /usr/bin/nodejs
                            v12.18.4
                            /usr/bin/node
                            v12.18.4
                            /usr/bin/npm
                            6.14.6
                            nodejs:
                              Installiert:           12.18.4-1nodesource1
                              Installationskandidat: 12.18.4-1nodesource1
                              Versionstabelle:
                             *** 12.18.4-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x bionic/main amd64 Packages
                                 8.17.0-1nodesource1 500
                                    500 https://deb.nodesource.com/node_8.x bionic/main amd64 Packages
                                 8.10.0~dfsg-2ubuntu0.4 500
                                    500 http://at.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                                 8.10.0~dfsg-2ubuntu0.2 500
                                    500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                                 8.10.0~dfsg-2 500
                                    500 http://at.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                            marcus@iobroker:~$
