  4. Mit Traccar eine geofence Alternative für Iphone und Android
    6.8k
traccargeofenceanwesenheitserkennungtrackingtraccar2iobroker
173 Beiträge 26 Kommentatoren 47.7k Aufrufe 32 Beobachtet
  • Palm_ManiacP Palm_Maniac
    @Headhunter70
    Hi, bei deinem Blockly werden jetzt andere Datenpunkte bemeckert, aber klappen tuts auch nicht.
    javascript.1	2020-09-18 16:40:10.074	error	(2864) script.js.Traccar.Thomas: Cannot parse "accuracy;address;altitude;cour"SyntaxError: Unexpected token a in JSON at position 0
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at processTicksAndRejections (internal/process/task_queues.js:84:21)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at endReadableNT (_stream_readable.js:1220:12)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at IncomingMessage.EventEmitter.emit (domain.js:483:12)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at IncomingMessage.emit (events.js:327:22)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at Object.onceWrapper (events.js:421:28)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at IncomingMessage.<anonymous> (D:\iobroker\KuhnHome\node_modules\iobroker.javascript\node_modules\request\request.js:1076:12)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at Request.EventEmitter.emit (domain.js:483:12)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at Request.emit (events.js:315:20)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at Request.<anonymous> (D:\iobroker\KuhnHome\node_modules\iobroker.javascript\node_modules\request\request.js:1154:10)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at Request.self.callback (D:\iobroker\KuhnHome\node_modules\iobroker.javascript\node_modules\request\request.js:185:22)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at Request._callback (D:\iobroker\KuhnHome\node_modules\iobroker.javascript\lib\request.js:27:17)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at script.js.Traccar.Thomas:104:9
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at setStateDelayed (D:\iobroker\KuhnHome\node_modules\iobroker.javascript\lib\sandbox.js:1402:25)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at Object.setState (D:\iobroker\KuhnHome\node_modules\iobroker.javascript\lib\sandbox.js:1358:20)
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) You are assigning a object to the state "0_userdata.0.traccar.Thomas.longitude" which expects a number. Please fix your code to use a number or change the state type to object. This warning mig
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at script.js.Traccar.Thomas:103:9
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) You are assigning a object to the state "0_userdata.0.traccar.Thomas.latitude" which expects a number. Please fix your code to use a number or change the state type to object. This warning migh
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at script.js.Traccar.Thomas:102:9
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) You are assigning a object to the state "0_userdata.0.traccar.Thomas.Kurs" which expects a number. Please fix your code to use a number or change the state type to object. This warning might be
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at script.js.Traccar.Thomas:100:9
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) You are assigning a object to the state "0_userdata.0.traccar.Thomas.InBewegung" which expects a boolean. Please fix your code to use a boolean or change the state type to object. This warning
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at script.js.Traccar.Thomas:99:9
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) You are assigning a object to the state "0_userdata.0.traccar.Thomas.Entfernung" which expects a number. Please fix your code to use a number or change the state type to object. This warning mi
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) at script.js.Traccar.Thomas:98:9
    javascript.1	2020-09-18 16:40:10.074	warn	(2864) You are assigning a object to the state "0_userdata.0.traccar.Thomas.BatterieLevel" which expects a number. Please fix your code to use a number or change the state type to object. This warning
    javascript.1	2020-09-18 16:40:10.058	info	(2864) script.js.Traccar.Thomas: request: http://iobroker:iobroker@192.168.1.11:8083/api/positions?deviceId=1&from=2020-09-18T15:39:00Z&to=2020-09-18T15:40:10Z
    javascript.1	2020-09-18 16:40:00.013	info	(2864) script.js.Traccar.Thomas: request: http://iobroker:iobroker@192.168.1.11:8083/api/devices/1?all=true
    Auf welchem TS bist du Zuhause? Ich könnte auch meinen anbieten: dhdh.eu
    Freaknet
    @Palm_Maniac
    Hey, kurzes Updaten von mir...
    Jetzt läuft bei mir alles!
    Hatte einfach mal den Java-Script-Adapter neu gestartet und plötzlich waren meine Fehlermeldungen alle verschwunden.
    Mal sehen ob jetzt die Datenpunkte alle gefüllt werden.
    Palm_ManiacP 1 Antwort Letzte Antwort
    • F Freaknet
      @Palm_Maniac
      Palm_ManiacP Offline
      Palm_Maniac
      @Freaknet
      Habs gerade mal getestet. Bei mir tut sich leider nix, die Fehler bleiben. Du hast es mit den original Skripten getestet?
      F 1 Antwort Letzte Antwort
        @Freaknet
        Freaknet
        schrieb am zuletzt editiert von Freaknet
        @Palm_Maniac
        Ja, aber grad das andere Script versucht und jetzt kommen auch wieder die Error-Logs bei mir... auch bei dem, was vorher funktioniert hatte :-(
        Ich weiß auch nicht was ich noch versuchen kann... bin am verzweifeln.
        Edit:
        Neustart javascript-Adapter und jetzt läuft wieder alles bei mir... echt sehr merkwürdig.
        • F Freaknet
          @Palm_Maniac
          Edit:
          Freaknet
          @Palm_Maniac
          versuch mal die Zeiten (Frequenz) in der App und in der Konfiguration (GPS_Aktualisierungs_Frequenz) zu ändern auf z.B. 300/500 (App/ioBroker)...
          Ich habe das grad mal versucht und die Daten kommen jetzt sehr gut rüber von der App.
          Werde aber final auf 90/120 gehen... mal sehen wie der Akku über den Tag so aushält :-)
          Edit:
          Nach 1 Tag Test hab ich jetzt 90/170 (App/GPS_Aktualisierungs_Frequenz) als für mich (iPhone) als gut funktionierende Einstellung gefunden. Damit hatte ich immer gefüllte DP´s. Vielleicht hilfreich für den ein oder anderen.
            @Dutchman
            Bei Ben, Gordon, Raik, Steffen u.v.a kommt Json zurück und die DP werden gefüllt.
            Bei Tristan und einigen anderen kommt eine CSV zurück, DP bleiben leer. Wenn es bei allen funktionieren soll, kommen wir nicht um einen Adapter herum.
            https://www.traccar.org/forums/topic/positions-api-string/
            DutchmanD Offline
            DutchmanD Offline
            Dutchman
            @J_Paul sagte in Mit Traccar eine geofence Alternative für Iphone und Android:
            @Dutchman
            Na Dan gehen wir die Sache an sobald du aus dem Urlaub bist :)
            Die Art der Ausgabe kan man denke ich mal mit dem request Header erzwingen
            • F Freaknet
              @Palm_Maniac
              Edit:
              Palm_Maniac
              @Freaknet
              Alles schon versucht. Das Problem ist wohl, dass bei dem Abfruf der Daten statt einer JSON Datei eine .csv Datei geladen wird. Das verursacht die Syntax-Error Fehler und füllt dadurch auch nicht alle Felder. Es wird ja bald einen Adapter geben, dann ist das alles Geschichte und bis dahin kann ich weitere Anwender mit der App versorgen und in das System einpflegen.
                @Freaknet
                @Palm_Maniac
                Es wurde mir inzwischen berichtet, dass bei Denjenigen, bei denen immer CSC kamen, mittlerweile JSON kommt und damit alles funktioniert, vielleicht lohnt es sich, mal mit Neustarts zu probieren.
                Aber ja: mit einem Adapter dürfte alles besser laufen.
                • E Offline
                  el_malto
                  Ich finde Traccar sehr interessant. Im Moment mache ich das mit OwnTracks und OwnTracks recorder. Da musste man immer in der jeweiligen Client App die Areas einrichten. Das war für mehrere Geräte immer sehr aufwendig. Da ist die Verwaltung usw. bei Traccar viel besser und angenehmer. Da wird alles auf den Server verwaltet und die Clients liefern nur die Koordinaten usw.
                  Freue mich schon wirklich auf den Adapter. Werde den auf jeden Fall testen und Feedback geben.
                  Vielen Dank das ihr mich auf Traccar aufmerksam gemacht habt👍
                  • E el_malto
                    Palm_Maniac
                    @el_malto
                    Dann kannste ja schon mal den Server installieren und einrichten. Die Arbeit haste dann schon hinter dir. :)
                    @J_Paul
                    Habe ich alles schon durch ohne Änderung. Ich hoffe mindestens auf den Adapter, oder vorher, auf einen Tipp. Da ich aktuell aber noch andere Baustellen offen habe, brennt es nicht so. :)
                    Q 1 Antwort Letzte Antwort
                      @el_malto
                      @J_Paul
                      Q Offline
                      Q Offline
                      quorle
                      Eine gute Alternative, aber Portöffnung?
                      Portöffnung ist doch dann eine Sicherheitslücke, oder sehe ich das falsch?
                      E ? 2 Antworten Letzte Antwort
                      • Q quorle
                        el_malto
                        @quorle wenn man nicht weiß was man macht ist eine Portöffnung immer eine Sicherheitslücke. Ein Gerät kann sich aber nur mit dem Server verbinden wenn es im Server eingetragen ist und die Gerätekennung korrekt ist.
                        • Q quorle
                          @quorle
                          Stimmt schon, aber mit diese Lösung geht die Portweiterleitung in einen unprivilegierten LXC Container, der nix weiß, oder kann. Vorher hab ich Geofence App benutzt und hierzu war ein Port bis zum offenen Herzen der iobrokers offen.
                            @quorle
                            Q Offline
                            Q Offline
                            quorle
                            @J_Paul
                            Ich nutze auch Geofence, jedoch habe ich keinen Sport diesbezüglich in meiner Fritzbox geöffnet. Funktioniert bislang tadellos.
                            • Q quorle
                              @J_Paul
                              @quorle
                              Beweis, dass es Wunder gibt, oder dass das Gute jedes Hindernis überwinden kann.
                              Oder du die Einrichtung der Port Weiterleitung vergessen hast. ;-)
                              • braindeadB Offline
                                braindeadB Offline
                                braindead
                                Ich habe heute auch mal einen Traccar Server aufgesetzt und den Client auf meinem Handy installiert. Erste Tests sind sehr vielversprechend. Jetzt habe ich zwei Fragen:
                                Woran hapert es denn beim Adapter? Die API ist doch komplett dokumentiert und das Script scheint doch eine gute Basis für den Adapter zu sein.
                                Welchen Tracker könnt Ihr fürs Auto empfehlen?
                                H 1 Antwort Letzte Antwort
                                • braindeadB braindead
                                  Headhunter70
                                  @braindead Es happert noch an dem Wissen, wie man einen Adapter baut. Darum haben Jörg und ich uns überlegt wie man auch ohne Adaper den Traccar in den Iobroker bekommt. Das Ergebniss siehst Du ja hier. Unterstütze GPS devices kannst Du hier finden https://www.traccar.org/devices/
                                  • smartmoodS Offline
                                    smartmoodS Offline
                                    smartmood
                                    schrieb am zuletzt editiert von smartmood
                                    das ist ja mal richtig TOP!
                                    Werde ich auf jeden Fall verfolgen, natürlich selber ausprobieren und hier Feedback geben :)
                                    Ich würde dann 2 Android Smartphones einbinden und schaue gerade schon nach einem GPS Tracker fürs Auto zum einbinden...
                                    Angefangen beim Server...
                                    Mir stehen hierfür nur zur Verfügung:
                                    • ein Raspberry Pi 4 (genutzt für iobroker und Phoscon )
                                    • ein Raspberry Pi 3B+ (genutzt für motioneye)
                                    • eine Synology DS 415+ (keine VM möglich - nur Docker)
                                    ich habe gesehen, dass für Traccar eine Docker Registrierung zur Verfügung steht... meint ihr das ist zu empfehlen bzw. hat das vielleicht schon jemand gemacht?
                                    Edit: für die Docker Installation bzw. besser gesagt die Einrichtung war ich irgendwie zu doof^^
                                    habe es jetzt auf meinem Raspi 3B+ installiert :)
                                    LG
                                    Mein Youtubekanal: https://www.youtube.com/channel/UCCHBGD-bByzOnCGW0YOL0Ww Technik - Smarthome - Automatisierung
                                    L H 2 Antworten Letzte Antwort
                                    • smartmoodS smartmood
                                      LG
                                      lindi200000
                                      @smartmood said in Mit Traccar eine geofence Alternative für Iphone und Android:
                                      LG
                                      Ich habe den Server bei mir als Docker laufen, auch mit anderen Ports dadurch. Funktioniert wunderbar. Man muss nur die traccar.xml bearbeiten und den Container neustarten wenn man was geändert hat.
                                        LG
                                        Headhunter70
                                        LG
                                        Lief bei mir fast 2Jahre in Docker auf QNAP, jetzt in LXC auf Proxmox, alles kein Problem.
                                        • Palm_ManiacP Offline
                                          Palm_Maniac
                                          ich versuche gerade Traccar als Docker zu installieren. Da es meine erste Docker-Installation ist, breche ich mir natürlich dabei einen ab und verstehe die Anleitung dazu nicht.
                                          Ich habe Docker für Windows laufen und dort Portainer erfolgreich installiert per Anleitung.
                                          Jetzt bräuchte ichmal ne Schritt-für-Schritt Anleitung welche Befehle ich eingeben muß, damit es was wird.
                                          Vielen Dank im voraus.
                                          L 1 Antwort Letzte Antwort
