  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 319.8k Aufrufe 67 Beobachtet
  • L lemuba
    @liv-in-sky Ja, einige Debian Buster Container - bin gerade schrittweise am umziehen auf den Esprimo Nuc...
    linux-control.0	2020-09-11 18:42:48.679	debug	(1419) system.adapter.admin.0: logging true
    linux-control.0	2020-09-11 18:42:46.407	info	(1419) [getConnection] Host 'weewx' (192.168.12.5:22) seems not to be online
    linux-control.0	2020-09-11 18:42:46.398	info	(1419) getting data from weewx (192.168.12.5:22, Adapter start)
    linux-control.0	2020-09-11 18:42:46.379	info	(1419) starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.18.3, js-controller: 3.1.6
    linux-control.0	2020-09-11 18:42:46.319	debug	(1419) Plugin sentry Initialize Plugin (enabled=true)
    linux-control.0	2020-09-11 18:42:46.097	debug	(1419) statesDB connected
    linux-control.0	2020-09-11 18:42:46.097	debug	(1419) States connected to redis: 127.0.0.1:9000
    linux-control.0	2020-09-11 18:42:46.091	debug	(1419) States create System PubSub Client
    linux-control.0	2020-09-11 18:42:46.090	debug	(1419) States create User PubSub Client
    linux-control.0	2020-09-11 18:42:46.086	debug	(1419) Redis States: Use Redis connection: 127.0.0.1:9000
    linux-control.0	2020-09-11 18:42:46.086	debug	(1419) objectDB connected
    linux-control.0	2020-09-11 18:42:46.083	debug	(1419) Objects connected to redis: 127.0.0.1:9001
    linux-control.0	2020-09-11 18:42:46.074	debug	(1419) Objects client initialize lua scripts
    linux-control.0	2020-09-11 18:42:46.073	debug	(1419) Objects create User PubSub Client
    linux-control.0	2020-09-11 18:42:46.073	debug	(1419) Objects create System PubSub Client
    linux-control.0	2020-09-11 18:42:46.072	debug	(1419) Objects client ready ... initialize now
    linux-control.0	2020-09-11 18:42:46.054	debug	(1419) Redis Objects: Use Redis connection: 127.0.0.1:9001
    Da Log bringt mich noch nicht wirklich weiter...
    Ping aus jeder Richtung auf die Weewx IP 192.168.12.5 ohne Probleme... Wir gesagt, putty ssh Zugriff und sftp/Filezilla Alles problemlos.
    liv-in-skyL
    liv-in-skyL
    #150
    @lemuba dann warten wir mal auf @scrounger - vielleicht sieh der etwas, was uns entgeht
    L 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      L
      L
      lemuba
      #151
      @liv-in-sky
      Ok, danke! Ich hab auch gerade nochmal auf eine andere DietiPi VM versucht, diese Debian 9 VM liegt auf meiner Diskstion, auch kein Erfolg/keine Verbindung.
      Warte ich ab, der Rest läuft bis Dato 1a, aber dieser Adapter wäre für einige meiner Anwendungsfälle schon echt praktisch...
      • L lemuba
        @liv-in-sky
        liv-in-skyL
        liv-in-skyL
        #152
        @lemuba
        das ist der code - wenn der ping "falsch" zurückkommt - kommt deine meldung - ganz untem im else - wenn man es aufwendig machen will, könnte man ein script mit der ping-node machen und mal schauen, was da so kommt - aber warten wir damit lieber auf scrounger - du hast aber mal einen ping vom iobroker server ( in der console) auf die devices gemacht - ob das funktioniert - nicht nur ping vom windows-client
        irgendwas blockiert da
        if (pingResult.alive) {
           			let obj = await this.getForeignObjectAsync('system.config');
           			let password = await this.getPassword(host);
           			let ssh = new NodeSSH();
           			let options = {
           				host: host.ip,
           				port: host.port,
           				username: host.user,
           				password: password,
           				readyTimeout: parseInt(host.timeout) * 1000 || 5000
           			if (host.rsakey && host.rsakey.length > 0) {
           				this.log.debug(`[getConnection] Host '${host.name}' (${host.ip}:${host.port}): using rsa key for authentification`);
           				options.passphrase = password;
           				options.privateKey = host.rsakey;
           			} else if (host.useSudo) {
           				this.log.debug(`[getConnection] Host '${host.name}' (${host.ip}:${host.port}): using sudo for authentification`);
           			return await ssh.connect(options);
           		} else {
           			this.log.info(`[getConnection] Host '${host.name}' (${host.ip}:${host.port}) seems not to be online`);
           			return undefined;
        • L lemuba
          ScroungerS
          ScroungerS
          Scrounger
          #153
          @lemuba
          genau das was @liv-in-sky sagt mach Mal nen Ping von deinem iob Rechner auf den Host. Wenn das auch nicht gehen sollte, dann liegt es nicht am Adapter. Evtl. Firewall rule oder sowas.
          IP Adresse ist auch wirklich korrekt?
          L 2 Antworten Letzte Antwort
          • ScroungerS Scrounger
            @lemuba
            L
            L
            lemuba
            schrieb am zuletzt editiert von lemuba
            #154
            @Scrounger
            Schön das meine Systeme so weit gut funktionieren ;-) - Ping von Iobroker in Richtung Weewx, sowie anders herum...:
            Müssen auf dem Iobroker Host oder auf der anderen Seite noch irgendwelche weiteren Dienste laufen, oder Adapter im Iobroker? Noch habe ich Alles relativ neu/frisch... viellleicht fehlt ja noch was?
            Gruß,
            Matthias
            ScroungerS 1 Antwort Letzte Antwort
              @lemuba
              L
              L
              lemuba
              #155
              @Scrounger
              Ich habe den Adapter nochmal auf meiner aktuellen Iobroker Production Instanz installiert (Diskstation 718, DietPi Debian 9 VM Instanz).
              Da funktioniert es in Richtung auf meine Weewx Instanz unter Proxmox/Esprimo Nuc...
              Ich habe nun echt keine Ahnung, warum es auf meiner Proxmox Iobroker Instanz nicht genauso laufen sollte, oder was ich noch testen könnte???
              Firewall ist weder auf Proxmox noch auf Iobroker Ebene/Container aktiviet.
              • L lemuba
                @Scrounger
                Gruß,
                Matthias
                ScroungerS
                ScroungerS
                Scrounger
                schrieb am zuletzt editiert von Scrounger
                #156
                @lemuba sagte in Test Adapter Linux Control v0.x.x:
                Nee da muss nichts speziell installiert sein.
                @Scrounger
                Hmm sehr komisch.
                Evtl. timeout problem, stell den mal auf einen höheren Wert ein z.B. 20s.
                Könntest auch mal testen ob Pingen mit dem Ping Adapter geht.
                • L lemuba
                  @Scrounger
                  liv-in-skyL
                  liv-in-skyL
                  #157
                  @lemuba könnte es sein, dass bei deinen umstellungen gleiche ip adressen sind
                    L
                    L
                    lemuba
                    #158
                    @liv-in-sky
                    das überprüfe ich "nochmal"...
                    Meine Fritzbox: 192.168.12.1
                    DHCP über die Fritzbox ab 192.168.12.100 bis 200
                    Proxmox Server über DHCP bei 161
                    Für die Proxmox Container habe ich jetzt feste IP-Adressen vergeben im Bereich unter 100, ab 5,6,7 u.s.w
                    Fahre aber jetzt mal alles runter und boote meine Fritzbox neu - schaue dann nach was im einstelligen Bereich noch angemledet ist, da sollte aber nichts sein....
                    • L lemuba
                      @liv-in-sky
                      ChaotC
                      ChaotC
                      Chaot
                      #159
                      @lemuba Proxmox Server über DHCP hat bei mir nicht funktioniert. Alle Container hatten Verbindungsprobleme. Obwohl diese feste IPs hatten.
                        @Scrounger
                        Hmm sehr komisch.
                        L
                        L
                        lemuba
                        #160
                        @liv-in-sky
                        Proxmox Server runter gefahren.
                        Fritzbox rebootet.
                        Hat nur DHCP Adressen ab 100 vergeben.
                        Proxmox Server und Container wieder hochgefahren - Fritzbox, zeigt sauber die fest vergeben Addressen 5,6,7 etc. an...
                        Ping Adapter installiert und zwei Adressen 5 Weewx und 1 Fritzbox aktiviert = FALSE :-(
                        Auf der anderen Seite läuft der Node-Red Adapter im Ibroker in alle Richtungen sauber - sendet und empfängt aus allen Adressbereichen.
                        Proxmox kommt auch sauber auf InfluxDb im Iobroker - etc., etc.
                        Auch auf der Iobroker Konsole komme ich ja sauber in alle Richtungen.
                        a) Hat sich vielleicht beim Backup einspielen was im Iobroker geschossen?
                        b) Schiesst vielleicht meine noch aktive Production Iobroker Instanz auf 192.168.12.127 (als Fest ID in Fritzbox reserviert) quer?
                        Egal, ich installiere mir nochmal einen neuen Iobroker auf Proxmox und schaue weiter. Aber nicht mehr heute...
                        Es wird sicherlich nicht am Adapter liegen und damit nun hier Offtopic - Aber vielen Dank nochmal! Auch an @Scrounger !
                        • ChaotC Chaot
                          L
                          L
                          lemuba
                          #161
                          @Chaot sagte in Test Adapter Linux Control v0.x.x:
                          Keiner meine Proxmox Container hat irgendwelche Verbindungsproblmen, nur Iobroker selber im Container.
                          • L lemuba
                            @liv-in-sky
                            Fritzbox rebootet.
                            liv-in-skyL
                            liv-in-skyL
                            #162
                            @lemuba
                            du kannst auch mal in google suchen - proxmox ping not working ....
                            vielleicht gibt es da noch mehr info ?
                            • L lemuba
                              liv-in-skyL
                              liv-in-skyL
                              #163
                              @lemuba
                              ohne genau zu wissen warum - im container unter options mal das nesting aktivieren und cont. neustarten
                              wenn das nix bringt, wieder rückgängig machen
                              ist nur ein versuch . kann es nicht wirklich erklären
                                @lemuba
                                L
                                L
                                lemuba
                                #164
                                @liv-in-sky sagte in Test Adapter Linux Control v0.x.x:
                                @lemuba
                                Bringt doch nichts...? In Proxmox, nach Proxmox, zwischen allen Proxmox Containern funktioniert der Ping auf der Konsole. Nur Iobroker selber und dessen Adapter haben Probleme.
                                • L lemuba
                                  @lemuba
                                  ScroungerS
                                  ScroungerS
                                  Scrounger
                                  #165
                                  @lemuba
                                  evtl. liegt das wirklich an der firewall. versuch mal das hier:
                                  https://askubuntu.com/questions/6995/how-to-enable-ufw-firewall-to-allow-icmp-response
                                    @lemuba
                                    L
                                    L
                                    lemuba
                                    #166
                                    @Scrounger
                                    Mache ich... Komme aber erst wieder ab Sonntag dazu. Werde dann auch nochmal parallel eine neue frische Debian/Iobroker Installation testen. Auf Proxmox ja alles zügig erledigt.
                                      @lemuba
                                      L
                                      L
                                      lemuba
                                      #167
                                      @Scrounger @liv-in-sky
                                      Nochmal gesucht und nun gefixt! :
                                      https://github.com/ioBroker/ioBroker.ping/issues/19
                                      Lösung: sudo apt-get install iputils-ping --reinstall
                                      Habe auch gleich sicherheitshalber meine ganzeren anderen Container damit übergebügelt - keine Ahnung wann ich mir das eingefangen habe.
                                      @Christoph @Dr-Bakterius Kann es sein, das das Debian 10 Proxmox Container Template ne Macke hat? Aber Danke für Eure Arbeit letztes Jahr! ;-)
                                      • L
                                        L
                                        lemuba
                                        #168
                                        Mein Nuc (Esprimo Q920) mit i5xxxxT Prozessor ist ja mit Proxmox bespielt - gibt es im Adapter einen Weg die CPU Temp als Datenpunkt zu erhalten? LMsensors hatte ich mal über die Konsole installiert und läuft auch gut...
                                        Auf der Konsole dann:
                                        watch -n 1 sensors
                                        • L lemuba
                                          watch -n 1 sensors
                                          liv-in-skyL
                                          liv-in-skyL
                                          #169
                                          @lemuba muss evtl bei dir angepasst werden - mal auf console testen - falls es nicht sofort funktioniert
                                          sensors | grep Package -m 1 | awk '{print $4}' | awk '{print substr($1, length($0)-6,2)}'
                                          33.2k
                                          84.3k
