Adapterversion springt zurück auf alte Version
- Raspberry mit Raspbian lite
- Stable
Versionen: JS-Controller 4.6.17 / Node 12.18.3 / Nodejs 12.18.3 / Admin 4.0.10
Fehlermeldungen zum Zigbee, den ich als letztes versucht habe zu updaten:
host.raspberrypi 2020-09-07 20:34:59.821 error instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
host.raspberrypi 2020-09-07 20:34:59.821 error Caught by controller[0]: }
host.raspberrypi 2020-09-07 20:34:59.821 error Caught by controller[0]: ]
host.raspberrypi 2020-09-07 20:34:59.821 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
host.raspberrypi 2020-09-07 20:34:59.821 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.821 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.820 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.820 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.18.3/linux/arm/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.820 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.820 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.820 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.820 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.820 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.820 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.819 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.819 error Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node',
host.raspberrypi 2020-09-07 20:34:59.819 error Caught by controller[0]: tries: [
host.raspberrypi 2020-09-07 20:34:59.819 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30) {
host.raspberrypi 2020-09-07 20:34:59.819 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
host.raspberrypi 2020-09-07 20:34:59.819 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
host.raspberrypi 2020-09-07 20:34:59.819 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
host.raspberrypi 2020-09-07 20:34:59.818 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
host.raspberrypi 2020-09-07 20:34:59.818 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
host.raspberrypi 2020-09-07 20:34:59.818 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
host.raspberrypi 2020-09-07 20:34:59.818 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
host.raspberrypi 2020-09-07 20:34:59.818 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
host.raspberrypi 2020-09-07 20:34:59.818 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
host.raspberrypi 2020-09-07 20:34:59.818 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
host.raspberrypi 2020-09-07 20:34:59.817 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
host.raspberrypi 2020-09-07 20:34:59.817 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
host.raspberrypi 2020-09-07 20:34:59.817 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
host.raspberrypi 2020-09-07 20:34:59.817 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.18.3/linux/arm/bindings.node
host.raspberrypi 2020-09-07 20:34:59.817 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
host.raspberrypi 2020-09-07 20:34:59.817 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
host.raspberrypi 2020-09-07 20:34:59.817 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
host.raspberrypi 2020-09-07 20:34:59.816 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
host.raspberrypi 2020-09-07 20:34:59.816 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
host.raspberrypi 2020-09-07 20:34:59.816 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
host.raspberrypi 2020-09-07 20:34:59.816 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
host.raspberrypi 2020-09-07 20:34:59.816 error Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
host.raspberrypi 2020-09-07 20:34:59.816 error Caught by controller[0]: Error: Could not locate the bindings file. Tried:
host.raspberrypi 2020-09-07 20:34:59.816 error Caught by controller[0]: ^
host.raspberrypi 2020-09-07 20:34:59.815 error Caught by controller[0]: throw err;
host.raspberrypi 2020-09-07 20:34:59.815 error Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135@graubi77 sagte in Adapterversion springt zurück auf alte Version:
das ist nicht die Version vom Js-controller, sonder von JavaScript. JS-Controller findest du, wenn du links im Reiter auf Hosts klickst.
Scheinbar funktioniert dein Zigbee Stick nicht mehr/wird nicht mehr erkannt -
ich habe seit einiger Zeit das Problem, dass ich mehrere Adapter Updates angezeigt bekomme, für die es Updates gibt. Das Update eines Adapters funktioniert dann auch und es wird in der Übersicht die neue Version angezeigt. Sobald ich nun aber ein weiteres Update mache, springt der zuerst aktualisierte Adapter wieder zurück auf die ursprüngliche Version.
Ich weiß aktuell nicht mal, wo ich ansetzen könnte. Bis vor 2 Monaten haben die Updates auf dem gleichen Weg immer funktioniert :-(.
Kennt jemand das Problem eventuell?@graubi77 sagte in Adapterversion springt zurück auf alte Version:
Das könnte auch ein Hinweis auf eine sterbende SD Karte sein.
@Homoran Ja, deswegen wäre die Ausgabe von dmesg ganz hilfreich, da sieht man das ggf.
Habe das gleiche Problem.
Aktualisierung von Adaptern läuft ohne Fehler durch, auch im log keine Fehler.
Anschließen springt der Adapter auf die alte Version zurück.Was ich probiert habe: Raspbian auf neue SD installiert, iobroker neu aufgesetzt.
Backup von iobroker eingespielt. Anschließend updaten sich die Adapter automatisch auf die neueste Version.
Sobald ein aktualisierter Adapter verfügbar ist, bei mir iCal Calendar, die Aktualisierung gestartet. Der Adapter springt auf die alte Version zurück! -
@diet68NE sagte in Adapterversion springt zurück auf alte Version:
dann gilt für dich natürlich auch das gleiche
@Thomas-Braun sagte in Adapterversion springt zurück auf alte Version:
pi@raspberrypi:~ $ dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.4.51-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:45:19 BST 2020 [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 242688 [ 0.000000] Normal zone: 2133 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 242688 pages, LIFO batch:63 [ 0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920 [ 0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 881516K/970752K available (8192K kernel code, 689K rwdata, 2552K rodata, 1024K init, 825K bss, 23700K reserved, 65536K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 28275 entries in 56 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] random: get_random_bytes called from start_kernel+0x328/0x500 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns [ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns [ 0.000022] Switching to timer-based delay loop, resolution 52ns [ 0.000290] Console: colour dummy device 80x30 [ 0.000873] printk: console [tty1] enabled [ 0.000938] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000) [ 0.000987] pid_max: default: 32768 minimum: 301 [ 0.001388] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.001433] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.002815] Disabling memory control group subsystem [ 0.002937] CPU: Testing write buffer coherency: ok [ 0.003517] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.004471] Setting up static identity map for 0x100000 - 0x10003c [ 0.004685] rcu: Hierarchical SRCU implementation. [ 0.005380] smp: Bringing up secondary CPUs ... [ 0.006513] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.007772] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.008919] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.009071] smp: Brought up 1 node, 4 CPUs [ 0.009160] SMP: Total of 4 processors activated (153.60 BogoMIPS). [ 0.009188] CPU: All CPU(s) started in HYP mode. [ 0.009212] CPU: Virtualization extensions available. [ 0.010286] devtmpfs: initialized [ 0.026538] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4 [ 0.026828] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.026885] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.030019] pinctrl core: initialized pinctrl subsystem [ 0.031231] NET: Registered protocol family 16 [ 0.035450] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.041768] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.041809] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.042059] Serial: AMBA PL011 UART driver [ 0.044031] bcm2835-mbox 3f00b880.mailbox: mailbox enabled [ 0.060077] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-06 16:24, variant start [ 0.070090] raspberrypi-firmware soc:firmware: Firmware hash is af3edc2de473197cdfe1ff5a8ff2d34095d5b336 [ 0.121593] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1 [ 0.123852] SCSI subsystem initialized [ 0.124130] usbcore: registered new interface driver usbfs [ 0.124213] usbcore: registered new interface driver hub [ 0.124357] usbcore: registered new device driver usb [ 0.126314] clocksource: Switched to clocksource arch_sys_counter [ 1.287137] VFS: Disk quotas dquot_6.6.0 [ 1.287281] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.287501] FS-Cache: Loaded [ 1.287780] CacheFiles: Loaded [ 1.298678] thermal_sys: Registered thermal governor 'step_wise' [ 1.299077] NET: Registered protocol family 2 [ 1.300035] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 1.300110] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 1.300250] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 1.300459] TCP: Hash tables configured (established 8192 bind 8192) [ 1.300641] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.300714] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.301025] NET: Registered protocol family 1 [ 1.301832] RPC: Registered named UNIX socket transport module. [ 1.301863] RPC: Registered udp transport module. [ 1.301889] RPC: Registered tcp transport module. [ 1.301915] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.303645] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available [ 1.307019] Initialise system trusted keyrings [ 1.307299] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 1.319140] FS-Cache: Netfs 'nfs' registered for caching [ 1.319981] NFS: Registering the id_resolver key type [ 1.320053] Key type id_resolver registered [ 1.320080] Key type id_legacy registered [ 1.320117] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.321437] Key type asymmetric registered [ 1.321467] Asymmetric key parser 'x509' registered [ 1.321536] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 1.321573] io scheduler mq-deadline registered [ 1.321599] io scheduler kyber registered [ 1.326616] bcm2708_fb soc:fb: FB found 1 display(s) [ 1.373891] Console: switching to colour frame buffer device 160x64 [ 1.395205] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1280x1024 [ 1.400722] bcm2835-rng 3f104000.rng: hwrng registered [ 1.401383] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB) [ 1.402311] vc-sm: Videocore shared memory driver [ 1.402932] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000 [ 1.416091] brd: module loaded [ 1.429037] loop: module loaded [ 1.430545] Loading iSCSI transport class v2.0-870. [ 1.431620] libphy: Fixed MDIO Bus: probed [ 1.431866] usbcore: registered new interface driver lan78xx [ 1.432091] usbcore: registered new interface driver smsc95xx [ 1.432276] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 2.160658] Core Release: 2.80a [ 2.160783] Setting default values for core params [ 2.160955] Finished setting default values for core params [ 2.361519] Using Buffer DMA mode [ 2.361630] Periodic Transfer Interrupt Enhancement - disabled [ 2.361802] Multiprocessor Interrupt Enhancement - disabled [ 2.361967] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 2.362117] Dedicated Tx FIFOs mode [ 2.362929] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024 [ 2.363226] FIQ FSM acceleration enabled for : Non-periodic Split Transactions Periodic Split Transactions High-Speed Isochronous Endpoints Interrupt/Control Split Transaction hack enabled [ 2.363819] dwc_otg: Microframe scheduler enabled [ 2.363883] WARN::hcd_init_fiq:457: FIQ on core 1 [ 2.364026] WARN::hcd_init_fiq:458: FIQ ASM at 806d89f4 length 36 [ 2.364203] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000 [ 2.371583] dwc_otg 3f980000.usb: DWC OTG Controller [ 2.378889] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1 [ 2.386171] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000 [ 2.393396] Init: Port Power? op_state=1 [ 2.400471] Init: Power Port (0) [ 2.407826] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 [ 2.414953] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.422094] usb usb1: Product: DWC OTG Controller [ 2.429150] usb usb1: Manufacturer: Linux 5.4.51-v7+ dwc_otg_hcd [ 2.436210] usb usb1: SerialNumber: 3f980000.usb [ 2.443965] hub 1-0:1.0: USB hub found [ 2.451148] hub 1-0:1.0: 1 port detected [ 2.459030] dwc_otg: FIQ enabled [ 2.459040] dwc_otg: NAK holdoff enabled [ 2.459049] dwc_otg: FIQ split-transaction FSM enabled [ 2.459063] Module dwc_common_port init [ 2.459439] usbcore: registered new interface driver usb-storage [ 2.466764] mousedev: PS/2 mouse device common for all mice [ 2.475176] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [ 2.484477] sdhci: Secure Digital Host Controller Interface driver [ 2.491608] sdhci: Copyright(c) Pierre Ossman [ 2.499211] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe [ 2.506992] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe [ 2.514378] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.523774] ledtrig-cpu: registered to indicate activity on CPUs [ 2.531449] hidraw: raw HID events driver (C) Jiri Kosina [ 2.538899] usbcore: registered new interface driver usbhid [ 2.546119] usbhid: USB HID core driver [ 2.554304] vchiq: vchiq_init_state: slot_zero = (ptrval) [ 2.563301] [vc_sm_connected_init]: start [ 2.573058] [vc_sm_connected_init]: end - returning 0 [ 2.582249] Initializing XFRM netlink socket [ 2.589409] NET: Registered protocol family 17 [ 2.596637] Key type dns_resolver registered [ 2.604301] Registering SWP/SWPB emulation handler [ 2.611590] registered taskstats version 1 [ 2.618456] Loading compiled-in X.509 certificates [ 2.625764] Key type ._fscrypt registered [ 2.632485] Key type .fscrypt registered [ 2.649781] uart-pl011 3f201000.serial: cts_event_workaround enabled [ 2.656683] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2 [ 2.665505] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver [ 2.674034] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0 [ 2.681059] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated [ 2.688473] Indeed it is in host mode hprt0 = 00021501 [ 2.769543] sdhost: log_buf @ (ptrval) (f7507000) [ 2.780621] random: fast init done [ 2.813743] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 2.822430] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 2.829450] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1) [ 2.839164] of_cfs_init [ 2.846211] of_cfs_init: OK [ 2.853923] Waiting for root device PARTUUID=6c586e13-02... [ 2.857778] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 2.870588] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 2.906364] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 2.913254] Indeed it is in host mode hprt0 = 00001101 [ 2.983728] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.993922] mmc0: new high speed SDHC card at address 0007 [ 3.002089] mmcblk0: mmc0:0007 SD16G 14.5 GiB [ 3.012036] mmcblk0: p1 p2 [ 3.049713] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [ 3.056733] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [ 3.084576] mmc1: new high speed SDIO card at address 0001 [ 3.156709] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00 [ 3.163877] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.171699] hub 1-1:1.0: USB hub found [ 3.178939] hub 1-1:1.0: 5 ports detected [ 3.506357] usb 1-1.1: new high-speed USB device number 3 using dwc_otg [ 3.636672] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00 [ 3.643769] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.653555] smsc95xx v1.0.6 [ 3.750771] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:24:76:b9 [ 3.856354] usb 1-1.2: new low-speed USB device number 4 using dwc_otg [ 4.004054] usb 1-1.2: New USB device found, idVendor=0458, idProduct=003e, bcdDevice= 1.00 [ 4.011647] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.019197] usb 1-1.2: Product: Wireless Mini Navigator [ 4.026693] usb 1-1.2: Manufacturer: Genius [ 4.047904] input: Genius Wireless Mini Navigator as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0458:003E.0001/input/input0 [ 4.116851] hid-generic 0003:0458:003E.0001: input,hidraw0: USB HID v1.00 Mouse [Genius Wireless Mini Navigator] on usb-3f980000.usb-1.2/input0 [ 4.416355] usb 1-1.3: new full-speed USB device number 5 using dwc_otg [ 4.552554] usb 1-1.3: New USB device found, idVendor=24ae, idProduct=1001, bcdDevice= 1.07 [ 4.560594] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.568568] usb 1-1.3: Product: Rapoo 2.4G Wireless Touch Desktop [ 4.576536] usb 1-1.3: Manufacturer: MOSART Semi. [ 4.589018] input: MOSART Semi. Rapoo 2.4G Wireless Touch Desktop as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:24AE:1001.0002/input/input1 [ 4.666956] hid-generic 0003:24AE:1001.0002: input,hidraw1: USB HID v1.10 Keyboard [MOSART Semi. Rapoo 2.4G Wireless Touch Desktop ] on usb-3f980000.usb-1.3/input0 [ 4.693038] input: MOSART Semi. Rapoo 2.4G Wireless Touch Desktop Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:1001.0003/input/input2 [ 4.712112] input: MOSART Semi. Rapoo 2.4G Wireless Touch Desktop Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:1001.0003/input/input3 [ 4.796561] input: MOSART Semi. Rapoo 2.4G Wireless Touch Desktop System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:1001.0003/input/input4 [ 4.817226] input: MOSART Semi. Rapoo 2.4G Wireless Touch Desktop as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:1001.0003/input/input5 [ 4.839055] hid-generic 0003:24AE:1001.0003: input,hiddev96,hidraw2: USB HID v1.10 Mouse [MOSART Semi. Rapoo 2.4G Wireless Touch Desktop ] on usb-3f980000.usb-1.3/input1 [ 14.606857] EXT4-fs (mmcblk0p2): recovery complete [ 14.654127] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 14.665241] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 14.684993] devtmpfs: mounted [ 14.703901] Freeing unused kernel memory: 1024K [ 14.715331] Run /sbin/init as init process [ 15.486873] systemd[1]: System time before build time, advancing clock. [ 15.666284] NET: Registered protocol family 10 [ 15.679262] Segment Routing with IPv6 [ 15.729270] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 15.767777] systemd[1]: Detected architecture arm. [ 15.878524] systemd[1]: Set hostname to <raspberrypi>. [ 16.843533] random: systemd: uninitialized urandom read (16 bytes read) [ 16.869755] random: systemd: uninitialized urandom read (16 bytes read) [ 16.882422] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 16.938139] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 16.950351] random: systemd: uninitialized urandom read (16 bytes read) [ 16.963377] systemd[1]: Listening on Journal Socket. [ 16.999387] systemd[1]: Starting Load Kernel Modules... [ 17.027729] systemd[1]: Created slice system-getty.slice. [ 17.054315] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 17.081579] systemd[1]: Listening on udev Kernel Socket. [ 18.019523] random: crng init done [ 18.019539] random: 7 urandom warning(s) missed due to ratelimiting [ 18.109699] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 18.237690] systemd-journald[120]: Received request to flush runtime journal from PID 1 [ 18.945107] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned. [ 18.948932] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [ 18.948957] [vc_sm_connected_init]: start [ 18.963695] [vc_sm_connected_init]: installed successfully [ 19.030793] mc: Linux media interface: v0.10 [ 19.125179] videodev: Linux video capture interface: v2.00 [ 19.138717] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 19.176475] bcm2835_audio bcm2835_audio: card created with 4 channels [ 19.189515] bcm2835_audio bcm2835_audio: card created with 4 channels [ 19.242195] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 19.251052] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 19.254877] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 19.346610] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [ 19.349287] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [ 19.370204] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 19.416844] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [ 19.418469] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [ 19.423436] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [ 19.425133] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [ 19.425230] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [ 19.425326] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [ 19.425418] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [ 19.425511] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [ 19.426482] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [ 19.431823] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 19.432010] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 19.434448] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 19.439964] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 19.440037] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 19.459888] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 19.460065] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 19.639408] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 19.779861] brcmfmac: F1 signature read @0x18000000=0x1541a9a6 [ 19.791474] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1 [ 19.791812] usbcore: registered new interface driver brcmfmac [ 19.819295] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.txt failed with error -2 [ 20.062793] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1 [ 20.062917] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 20.063761] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd [ 21.356573] Under-voltage detected! (0x00050000) [ 22.082634] uart-pl011 3f201000.serial: no DMA platform data [ 22.145088] 8021q: 802.1Q VLAN Support v1.8 [ 22.586442] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS [ 22.629850] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled [ 23.129589] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 24.606303] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 [ 26.239034] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead [ 26.623123] Bluetooth: Core ver 2.22 [ 26.623224] NET: Registered protocol family 31 [ 26.623237] Bluetooth: HCI device and connection manager initialized [ 26.623268] Bluetooth: HCI socket layer initialized [ 26.623290] Bluetooth: L2CAP socket layer initialized [ 26.623321] Bluetooth: SCO socket layer initialized [ 26.633876] Bluetooth: HCI UART driver ver 2.3 [ 26.633889] Bluetooth: HCI UART protocol H4 registered [ 26.633939] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 26.634100] Bluetooth: HCI UART protocol Broadcom registered [ 26.913172] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 26.913185] Bluetooth: BNEP filters: protocol multicast [ 26.913207] Bluetooth: BNEP socket layer initialized [ 29.676460] Voltage normalised (0x00000000) pi@raspberrypi:~ $MOD-Edit: Code in code-tags gesetzt!
@graubi77
Ausgabe vondmesgsagt?
Ansonsten gerne auch komplette Eingabezeile inkl. Loginprompt vonwho -r whoami@Thomas-Braun - War ein paar Tage nicht am Rechner, deswegen erst jetzt...
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.93-v7l+ (dom@buildbot) (gcc version 4.9.3 (cro sstool-NG crosstool-ng-1.22.0-88-g8460611)) #1290 SMP Fri Jan 10 16:45:11 GMT 20 20 [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000 [ 0.000000] On node 0 totalpages: 1012736 [ 0.000000] DMA zone: 1728 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63 [ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0 [ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632 [ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma =256M smsc95xx.macaddr=DC:A6:32:2D:68:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_ size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 roo tfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 3735568K/4050944K available (8192K kernel code, 687K rwda ta, 2408K rodata, 2048K init, 850K bss, 53232K reserved, 262144K cma-reserved, 3 264512K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0x(ptrval) - 0x(ptrval) (10208 kB) .init : 0x(ptrval) - 0x(ptrval) (2048 kB) .data : 0x(ptrval) - 0x(ptrval) ( 688 kB) .bss : 0x(ptrval) - 0x(ptrval) ( 851 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 28682 entries in 85 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980 46511102ns [ 0.000021] Switching to timer-based delay loop, resolution 18ns [ 0.000244] Console: colour dummy device 80x30 [ 0.000698] console [tty1] enabled [ 0.000752] Calibrating delay loop (skipped), value calculated using timer fr equency.. 108.00 BogoMIPS (lpj=540000) [ 0.000789] pid_max: default: 32768 minimum: 301 [ 0.001070] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001102] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001869] CPU: Testing write buffer coherency: ok [ 0.002294] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002951] Setting up static identity map for 0x200000 - 0x20003c [ 0.003124] rcu: Hierarchical SRCU implementation. [ 0.003996] smp: Bringing up secondary CPUs ... [ 0.004817] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.005748] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.006642] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.006777] smp: Brought up 1 node, 4 CPUs [ 0.006842] SMP: Total of 4 processors activated (432.00 BogoMIPS). [ 0.006864] CPU: All CPU(s) started in HYP mode. [ 0.006884] CPU: Virtualization extensions available. [ 0.007684] devtmpfs: initialized [ 0.017783] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0 [ 0.018010] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns [ 0.018052] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.025436] pinctrl core: initialized pinctrl subsystem [ 0.026303] NET: Registered protocol family 16 [ 0.029189] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.030593] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.030626] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.030828] Serial: AMBA PL011 UART driver [ 0.033864] bcm2835-mbox fe00b880.mailbox: mailbox enabled [ 0.069149] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dma chans=0x1 [ 0.071610] vgaarb: loaded [ 0.072000] SCSI subsystem initialized [ 0.072217] usbcore: registered new interface driver usbfs [ 0.072285] usbcore: registered new interface driver hub [ 0.072373] usbcore: registered new device driver usb [ 0.090374] raspberrypi-firmware soc:firmware: Attached to firmware from 2020 -01-10 16:52, variant start [ 0.100118] raspberrypi-firmware soc:firmware: Firmware hash is fdb5c37e330e7 cb3027ac4fcc5b1cd5f244b351f [ 0.111578] clocksource: Switched to clocksource arch_sys_counter [ 0.188989] VFS: Disk quotas dquot_6.6.0 [ 0.189092] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.189253] FS-Cache: Loaded [ 0.189445] CacheFiles: Loaded [ 0.189965] simple-framebuffer: probe of 0.framebuffer failed with error -12 [ 0.199109] NET: Registered protocol family 2 [ 0.199773] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 0.199818] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.199899] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.199983] TCP: Hash tables configured (established 8192 bind 8192) [ 0.200119] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.200162] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.200387] NET: Registered protocol family 1 [ 0.200939] RPC: Registered named UNIX socket transport module. [ 0.200965] RPC: Registered udp transport module. [ 0.200987] RPC: Registered tcp transport module. [ 0.201008] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.201037] PCI: CLS 0 bytes, default 64 [ 0.204040] Initialise system trusted keyrings [ 0.204224] workingset: timestamp_bits=14 max_order=20 bucket_order=6 [ 0.213112] FS-Cache: Netfs 'nfs' registered for caching [ 0.213616] NFS: Registering the id_resolver key type [ 0.213653] Key type id_resolver registered [ 0.213674] Key type id_legacy registered [ 0.213705] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.215969] Key type asymmetric registered [ 0.215995] Asymmetric key parser 'x509' registered [ 0.216116] bounce: pool size: 64 pages [ 0.216170] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 50) [ 0.216347] io scheduler noop registered [ 0.216371] io scheduler deadline registered (default) [ 0.216537] io scheduler cfq registered [ 0.216560] io scheduler mq-deadline registered (default) [ 0.216583] io scheduler kyber registered [ 0.247554] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, thres hold 0x00000000c0000000 [ 0.247601] brcm-pcie fd500000.pcie: could not get clock [ 0.247675] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges: [ 0.247726] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf800 0000 [ 0.301608] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC) [ 0.301884] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00 [ 0.301915] pci_bus 0000:00: root bus resource [bus 00-01] [ 0.301945] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff]) [ 0.302008] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [ 0.302145] pci 0000:00:00.0: PME# supported from D0 D3hot [ 0.304854] PCI: bus0: Fast back to back transfers disabled [ 0.304885] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec onfiguring [ 0.305108] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [ 0.305232] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [ 0.305548] pci 0000:01:00.0: PME# supported from D0 D3cold [ 0.308252] PCI: bus1: Fast back to back transfers disabled [ 0.308281] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01 [ 0.308327] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff] [ 0.308361] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64 bit] [ 0.308449] pci 0000:00:00.0: PCI bridge to [bus 01] [ 0.308479] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff] [ 0.308701] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [ 0.308889] pcieport 0000:00:00.0: Signaling PME with IRQ 53 [ 0.309058] pcieport 0000:00:00.0: AER enabled with IRQ 53 [ 0.309238] pci 0000:01:00.0: enabling device (0140 -> 0142) [ 0.313129] iproc-rng200 fe104000.rng: hwrng registered [ 0.313365] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000 000(1024 MiB) [ 0.313872] vc-sm: Videocore shared memory driver [ 0.314275] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2 00000 [ 0.324365] brd: module loaded [ 0.333874] loop: module loaded [ 0.334651] Loading iSCSI transport class v2.0-870. [ 0.336321] libphy: Fixed MDIO Bus: probed [ 0.336748] bcmgenet fd580000.genet: failed to get enet clock [ 0.336778] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000 [ 0.336808] bcmgenet fd580000.genet: failed to get enet-wol clock [ 0.336838] bcmgenet fd580000.genet: failed to get enet-eee clock [ 0.336873] bcmgenet: Skipping UMAC reset [ 0.337120] unimac-mdio unimac-mdio.-19: DMA mask not set [ 0.351607] libphy: bcmgenet MII bus: probed [ 0.392104] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrva l) [ 0.393024] usbcore: registered new interface driver r8152 [ 0.393100] usbcore: registered new interface driver lan78xx [ 0.393168] usbcore: registered new interface driver smsc95xx [ 0.393480] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 0.393524] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe r 1 [ 0.395817] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu irks 0x0000001000000890 [ 0.396154] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of ir q 54 [ 0.397030] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 4.19 [ 0.397065] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 0.397094] usb usb1: Product: xHCI Host Controller [ 0.397117] usb usb1: Manufacturer: Linux 4.19.93-v7l+ xhci-hcd [ 0.397141] usb usb1: SerialNumber: 0000:01:00.0 [ 0.397660] hub 1-0:1.0: USB hub found [ 0.397752] hub 1-0:1.0: 1 port detected [ 0.398229] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 0.398265] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe r 2 [ 0.398301] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [ 0.398719] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc dDevice= 4.19 [ 0.398751] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 0.398779] usb usb2: Product: xHCI Host Controller [ 0.398802] usb usb2: Manufacturer: Linux 4.19.93-v7l+ xhci-hcd [ 0.398825] usb usb2: SerialNumber: 0000:01:00.0 [ 0.399316] hub 2-0:1.0: USB hub found [ 0.399398] hub 2-0:1.0: 4 ports detected [ 0.400567] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 0.400766] dwc_otg: FIQ enabled [ 0.400775] dwc_otg: NAK holdoff enabled [ 0.400784] dwc_otg: FIQ split-transaction FSM enabled [ 0.400797] Module dwc_common_port init [ 0.400997] usbcore: registered new interface driver uas [ 0.401111] usbcore: registered new interface driver usb-storage [ 0.401305] mousedev: PS/2 mouse device common for all mice [ 0.402506] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [ 0.403923] sdhci: Secure Digital Host Controller Interface driver [ 0.403948] sdhci: Copyright(c) Pierre Ossman [ 0.404349] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe [ 0.404754] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.407743] ledtrig-cpu: registered to indicate activity on CPUs [ 0.407906] hidraw: raw HID events driver (C) Jiri Kosina [ 0.408039] usbcore: registered new interface driver usbhid [ 0.408061] usbhid: USB HID core driver [ 0.408845] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0 [ 0.410575] [vc_sm_connected_init]: start [ 0.419440] [vc_sm_connected_init]: end - returning 0 [ 0.420594] Initializing XFRM netlink socket [ 0.420636] NET: Registered protocol family 17 [ 0.420728] Key type dns_resolver registered [ 0.420993] Registering SWP/SWPB emulation handler [ 0.421627] registered taskstats version 1 [ 0.421657] Loading compiled-in X.509 certificates [ 0.428597] uart-pl011 fe201000.serial: cts_event_workaround enabled [ 0.428676] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2 [ 0.431742] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive r [ 0.432279] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor d river [ 0.432926] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [ 0.432953] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [ 0.458992] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1 [ 0.479282] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 0.480891] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 0.482500] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 0.485366] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 0.486968] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 0.494291] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using A DMA [ 0.496781] of_cfs_init [ 0.496876] of_cfs_init: OK [ 0.497460] Waiting for root device PARTUUID=6c586e13-02... [ 0.543438] random: fast init done [ 0.554826] mmc1: new high speed SDIO card at address 0001 [ 0.598444] mmc0: new ultra high speed DDR50 SDHC card at address aaaa [ 0.599597] mmcblk0: mmc0:aaaa SC32G 29.7 GiB [ 0.601751] mmcblk0: p1 p2 [ 0.615623] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst em [ 0.615659] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [ 0.761622] usb 1-1: new high-speed USB device number 2 using xhci_hcd [ 0.944247] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcd Device= 4.21 [ 0.944287] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 0.944314] usb 1-1: Product: USB2.0 Hub [ 0.946015] hub 1-1:1.0: USB hub found [ 0.946345] hub 1-1:1.0: 4 ports detected [ 1.016655] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [ 1.040421] EXT4-fs (mmcblk0p2): 7 orphan inodes deleted [ 1.040450] EXT4-fs (mmcblk0p2): recovery complete [ 1.066976] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null) [ 1.067055] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 1.073118] devtmpfs: mounted [ 1.080788] Freeing unused kernel memory: 2048K [ 1.081840] Run /sbin/init as init process [ 1.271624] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd [ 1.410654] usb 1-1.1: New USB device found, idVendor=0451, idProduct=16a8, b cdDevice= 0.09 [ 1.410695] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber =3 [ 1.410725] usb 1-1.1: Product: TI CC2531 USB CDC [ 1.410749] usb 1-1.1: Manufacturer: Texas Instruments [ 1.410772] usb 1-1.1: SerialNumber: __0X00124B0014D90EEB [ 1.522915] systemd[1]: System time before build time, advancing clock. [ 1.615721] NET: Registered protocol family 10 [ 1.616937] Segment Routing with IPv6 [ 1.651766] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL + XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr id) [ 1.652473] systemd[1]: Detected architecture arm. [ 1.668055] systemd[1]: Set hostname to <raspberrypi>. [ 1.670033] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argumen t [ 2.266872] random: systemd: uninitialized urandom read (16 bytes read) [ 2.274876] random: systemd: uninitialized urandom read (16 bytes read) [ 2.279015] systemd[1]: Created slice User and Session Slice. [ 2.279667] random: systemd: uninitialized urandom read (16 bytes read) [ 2.279988] systemd[1]: Started Forward Password Requests to Wall Directory W atch. [ 2.281333] systemd[1]: Set up automount Arbitrary Executable File Formats Fi le System Automount Point. [ 2.288877] systemd[1]: Listening on Syslog Socket. [ 2.310035] systemd[1]: Condition check resulted in Journal Audit Socket bein g skipped. [ 2.310887] systemd[1]: Listening on Journal Socket. [ 2.935935] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 3.046276] systemd-journald[102]: Received request to flush runtime journal from PID 1 [ 3.537489] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Reg isters at 0xfeb00000 length 0x0000ffff [ 3.539254] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised : Registers at 0xfeb10000 length 0x00000fff [ 3.539974] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Reg isters at 0xfeb20000 length 0x0000ffff [ 3.540519] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Regis ters at 0xfeb30000 length 0x0000ffff [ 3.569184] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 3.575373] bcm2835_audio soc:audio: card created with 8 channels [ 3.590158] media: Linux media interface: v0.10 [ 3.629738] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned. [ 3.640177] videodev: Linux video capture interface: v2.00 [ 3.641004] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [ 3.641019] [vc_sm_connected_init]: start [ 3.651951] [vc_sm_connected_init]: installed successfully [ 3.699141] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned. [ 3.699488] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned. [ 3.728657] bcm2835_v4l2: module is from the staging directory, the quality i s unknown, you have been warned. [ 3.758919] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 3.808023] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 3.808060] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 3.818923] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 3.818959] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 3.828000] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [ 3.828113] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 3.828142] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 3.861396] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase [ 3.909137] [drm] No displays found. Consider forcing hotplug if HDMI is atta ched [ 3.909232] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc 4]) [ 3.917723] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1 [ 3.917737] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.917746] [drm] No driver support for vblank timestamp query. [ 3.917756] [drm] Setting vblank_disable_immediate to false because get_vblan k_timestamp == NULL [ 3.963731] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.050101] brcmfmac: F1 signature read @0x18000000=0x15264345 [ 4.061525] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f or chip BCM4345/6 [ 4.062358] usbcore: registered new interface driver brcmfmac [ 4.064570] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device [ 4.074289] usbcore: registered new interface driver cdc_acm [ 4.074302] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters [ 4.294305] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f or chip BCM4345/6 [ 4.309421] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04 [ 6.155224] random: crng init done [ 6.155243] random: 7 urandom warning(s) missed due to ratelimiting [ 6.246312] uart-pl011 fe201000.serial: no DMA platform data [ 6.297752] 8021q: 802.1Q VLAN Support v1.8 [ 6.404641] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:1 02396k SSFS [ 6.504947] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 6.504956] brcmfmac: power management disabled [ 6.744933] bcmgenet: Skipping UMAC reset [ 6.852071] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay) [ 6.852296] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 7.911810] bcmgenet fd580000.genet eth0: Link is Down [ 12.071862] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow cont rol rx/tx [ 12.071900] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 12.945349] Bluetooth: Core ver 2.22 [ 12.945422] NET: Registered protocol family 31 [ 12.945432] Bluetooth: HCI device and connection manager initialized [ 12.945460] Bluetooth: HCI socket layer initialized [ 12.945476] Bluetooth: L2CAP socket layer initialized [ 12.945519] Bluetooth: SCO socket layer initialized [ 12.963241] Bluetooth: HCI UART driver ver 2.3 [ 12.963255] Bluetooth: HCI UART protocol H4 registered [ 12.963339] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 12.963580] Bluetooth: HCI UART protocol Broadcom registered [ 13.130797] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 13.130804] Bluetooth: BNEP filters: protocol multicast [ 13.130814] Bluetooth: BNEP socket layer initialized [ 14.153708] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net .ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead [ 111.559515] FS-Cache: Netfs 'cifs' registered for caching [ 111.559791] Key type cifs.spnego registered [ 111.559802] Key type cifs.idmap registered pi@raspberrypi:~ $ dmesg text.txt dmesg: bad usage Try 'dmesg --help' for more information. pi@raspberrypi:~ $ dmesg>text.txt pi@raspberrypi:~ $ dmesg >text.txt pi@raspberrypi:~ $ ls -l insgesamt 608 -rw-r--r-- 1 pi pi 312748 Aug 11 2019 pi_buster_motion_4.2.2-1_armhf.deb -rw-r--r-- 1 pi pi 282082 Dez 11 2017 pi_stretch_motion_4.1.1-1_armhf.deb -rw-r--r-- 1 pi pi 23096 Sep 10 17:57 text.txt pi@raspberrypi:~ $ text.txt -bash: text.txt: Kommando nicht gefunden. pi@raspberrypi:~ $ vi text.txt [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.93-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1290 SMP Fri Jan 10 16:45:11 GMT 2020 [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000 [ 0.000000] On node 0 totalpages: 1012736 [ 0.000000] DMA zone: 1728 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63 [ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0 [ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632 [ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M smsc95xx.macaddr=DC:A6:32:2D:68:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 3735568K/4050944K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 53232K reserved, 262144K cma-reserved, 3264512K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0x(ptrval) - 0x(ptrval) (10208 kB) .init : 0x(ptrval) - 0x(ptrval) (2048 kB) .data : 0x(ptrval) - 0x(ptrval) ( 688 kB) .bss : 0x(ptrval) - 0x(ptrval) ( 851 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 28682 entries in 85 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [ 0.000021] Switching to timer-based delay loop, resolution 18ns [ 0.000244] Console: colour dummy device 80x30 [ 0.000698] console [tty1] enabled [ 0.000752] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000) [ 0.000789] pid_max: default: 32768 minimum: 301 [ 0.001070] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001102] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001869] CPU: Testing write buffer coherency: ok [ 0.002294] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002951] Setting up static identity map for 0x200000 - 0x20003c [ 0.003124] rcu: Hierarchical SRCU implementation. [ 0.003996] smp: Bringing up secondary CPUs ... [ 0.004817] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.005748] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.006642] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.006777] smp: Brought up 1 node, 4 CPUs [ 0.006842] SMP: Total of 4 processors activated (432.00 BogoMIPS). [ 0.006864] CPU: All CPU(s) started in HYP mode. [ 0.006884] CPU: Virtualization extensions available. [ 0.007684] devtmpfs: initialized -
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.93-v7l+ (dom@buildbot) (gcc version 4.9.3 (cro sstool-NG crosstool-ng-1.22.0-88-g8460611)) #1290 SMP Fri Jan 10 16:45:11 GMT 20 20 [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000 [ 0.000000] On node 0 totalpages: 1012736 [ 0.000000] DMA zone: 1728 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63 [ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0 [ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632 [ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma =256M smsc95xx.macaddr=DC:A6:32:2D:68:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_ size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 roo tfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 3735568K/4050944K available (8192K kernel code, 687K rwda ta, 2408K rodata, 2048K init, 850K bss, 53232K reserved, 262144K cma-reserved, 3 264512K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0x(ptrval) - 0x(ptrval) (10208 kB) .init : 0x(ptrval) - 0x(ptrval) (2048 kB) .data : 0x(ptrval) - 0x(ptrval) ( 688 kB) .bss : 0x(ptrval) - 0x(ptrval) ( 851 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 28682 entries in 85 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980 46511102ns [ 0.000021] Switching to timer-based delay loop, resolution 18ns [ 0.000244] Console: colour dummy device 80x30 [ 0.000698] console [tty1] enabled [ 0.000752] Calibrating delay loop (skipped), value calculated using timer fr equency.. 108.00 BogoMIPS (lpj=540000) [ 0.000789] pid_max: default: 32768 minimum: 301 [ 0.001070] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001102] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001869] CPU: Testing write buffer coherency: ok [ 0.002294] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002951] Setting up static identity map for 0x200000 - 0x20003c [ 0.003124] rcu: Hierarchical SRCU implementation. [ 0.003996] smp: Bringing up secondary CPUs ... [ 0.004817] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.005748] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.006642] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.006777] smp: Brought up 1 node, 4 CPUs [ 0.006842] SMP: Total of 4 processors activated (432.00 BogoMIPS). [ 0.006864] CPU: All CPU(s) started in HYP mode. [ 0.006884] CPU: Virtualization extensions available. [ 0.007684] devtmpfs: initialized [ 0.017783] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0 [ 0.018010] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns [ 0.018052] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.025436] pinctrl core: initialized pinctrl subsystem [ 0.026303] NET: Registered protocol family 16 [ 0.029189] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.030593] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.030626] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.030828] Serial: AMBA PL011 UART driver [ 0.033864] bcm2835-mbox fe00b880.mailbox: mailbox enabled [ 0.069149] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dma chans=0x1 [ 0.071610] vgaarb: loaded [ 0.072000] SCSI subsystem initialized [ 0.072217] usbcore: registered new interface driver usbfs [ 0.072285] usbcore: registered new interface driver hub [ 0.072373] usbcore: registered new device driver usb [ 0.090374] raspberrypi-firmware soc:firmware: Attached to firmware from 2020 -01-10 16:52, variant start [ 0.100118] raspberrypi-firmware soc:firmware: Firmware hash is fdb5c37e330e7 cb3027ac4fcc5b1cd5f244b351f [ 0.111578] clocksource: Switched to clocksource arch_sys_counter [ 0.188989] VFS: Disk quotas dquot_6.6.0 [ 0.189092] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.189253] FS-Cache: Loaded [ 0.189445] CacheFiles: Loaded [ 0.189965] simple-framebuffer: probe of 0.framebuffer failed with error -12 [ 0.199109] NET: Registered protocol family 2 [ 0.199773] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 0.199818] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.199899] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.199983] TCP: Hash tables configured (established 8192 bind 8192) [ 0.200119] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.200162] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.200387] NET: Registered protocol family 1 [ 0.200939] RPC: Registered named UNIX socket transport module. [ 0.200965] RPC: Registered udp transport module. [ 0.200987] RPC: Registered tcp transport module. [ 0.201008] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.201037] PCI: CLS 0 bytes, default 64 [ 0.204040] Initialise system trusted keyrings [ 0.204224] workingset: timestamp_bits=14 max_order=20 bucket_order=6 [ 0.213112] FS-Cache: Netfs 'nfs' registered for caching [ 0.213616] NFS: Registering the id_resolver key type [ 0.213653] Key type id_resolver registered [ 0.213674] Key type id_legacy registered [ 0.213705] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.215969] Key type asymmetric registered [ 0.215995] Asymmetric key parser 'x509' registered [ 0.216116] bounce: pool size: 64 pages [ 0.216170] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 50) [ 0.216347] io scheduler noop registered [ 0.216371] io scheduler deadline registered (default) [ 0.216537] io scheduler cfq registered [ 0.216560] io scheduler mq-deadline registered (default) [ 0.216583] io scheduler kyber registered [ 0.247554] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, thres hold 0x00000000c0000000 [ 0.247601] brcm-pcie fd500000.pcie: could not get clock [ 0.247675] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges: [ 0.247726] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf800 0000 [ 0.301608] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC) [ 0.301884] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00 [ 0.301915] pci_bus 0000:00: root bus resource [bus 00-01] [ 0.301945] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff]) [ 0.302008] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [ 0.302145] pci 0000:00:00.0: PME# supported from D0 D3hot [ 0.304854] PCI: bus0: Fast back to back transfers disabled [ 0.304885] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec onfiguring [ 0.305108] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [ 0.305232] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [ 0.305548] pci 0000:01:00.0: PME# supported from D0 D3cold [ 0.308252] PCI: bus1: Fast back to back transfers disabled [ 0.308281] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01 [ 0.308327] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff] [ 0.308361] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64 bit] [ 0.308449] pci 0000:00:00.0: PCI bridge to [bus 01] [ 0.308479] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff] [ 0.308701] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [ 0.308889] pcieport 0000:00:00.0: Signaling PME with IRQ 53 [ 0.309058] pcieport 0000:00:00.0: AER enabled with IRQ 53 [ 0.309238] pci 0000:01:00.0: enabling device (0140 -> 0142) [ 0.313129] iproc-rng200 fe104000.rng: hwrng registered [ 0.313365] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000 000(1024 MiB) [ 0.313872] vc-sm: Videocore shared memory driver [ 0.314275] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2 00000 [ 0.324365] brd: module loaded [ 0.333874] loop: module loaded [ 0.334651] Loading iSCSI transport class v2.0-870. [ 0.336321] libphy: Fixed MDIO Bus: probed [ 0.336748] bcmgenet fd580000.genet: failed to get enet clock [ 0.336778] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000 [ 0.336808] bcmgenet fd580000.genet: failed to get enet-wol clock [ 0.336838] bcmgenet fd580000.genet: failed to get enet-eee clock [ 0.336873] bcmgenet: Skipping UMAC reset [ 0.337120] unimac-mdio unimac-mdio.-19: DMA mask not set [ 0.351607] libphy: bcmgenet MII bus: probed [ 0.392104] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrva l) [ 0.393024] usbcore: registered new interface driver r8152 [ 0.393100] usbcore: registered new interface driver lan78xx [ 0.393168] usbcore: registered new interface driver smsc95xx [ 0.393480] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 0.393524] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe r 1 [ 0.395817] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu irks 0x0000001000000890 [ 0.396154] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of ir q 54 [ 0.397030] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 4.19 [ 0.397065] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 0.397094] usb usb1: Product: xHCI Host Controller [ 0.397117] usb usb1: Manufacturer: Linux 4.19.93-v7l+ xhci-hcd [ 0.397141] usb usb1: SerialNumber: 0000:01:00.0 [ 0.397660] hub 1-0:1.0: USB hub found [ 0.397752] hub 1-0:1.0: 1 port detected [ 0.398229] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 0.398265] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe r 2 [ 0.398301] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [ 0.398719] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc dDevice= 4.19 [ 0.398751] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 0.398779] usb usb2: Product: xHCI Host Controller [ 0.398802] usb usb2: Manufacturer: Linux 4.19.93-v7l+ xhci-hcd [ 0.398825] usb usb2: SerialNumber: 0000:01:00.0 [ 0.399316] hub 2-0:1.0: USB hub found [ 0.399398] hub 2-0:1.0: 4 ports detected [ 0.400567] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 0.400766] dwc_otg: FIQ enabled [ 0.400775] dwc_otg: NAK holdoff enabled [ 0.400784] dwc_otg: FIQ split-transaction FSM enabled [ 0.400797] Module dwc_common_port init [ 0.400997] usbcore: registered new interface driver uas [ 0.401111] usbcore: registered new interface driver usb-storage [ 0.401305] mousedev: PS/2 mouse device common for all mice [ 0.402506] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [ 0.403923] sdhci: Secure Digital Host Controller Interface driver [ 0.403948] sdhci: Copyright(c) Pierre Ossman [ 0.404349] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe [ 0.404754] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.407743] ledtrig-cpu: registered to indicate activity on CPUs [ 0.407906] hidraw: raw HID events driver (C) Jiri Kosina [ 0.408039] usbcore: registered new interface driver usbhid [ 0.408061] usbhid: USB HID core driver [ 0.408845] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0 [ 0.410575] [vc_sm_connected_init]: start [ 0.419440] [vc_sm_connected_init]: end - returning 0 [ 0.420594] Initializing XFRM netlink socket [ 0.420636] NET: Registered protocol family 17 [ 0.420728] Key type dns_resolver registered [ 0.420993] Registering SWP/SWPB emulation handler [ 0.421627] registered taskstats version 1 [ 0.421657] Loading compiled-in X.509 certificates [ 0.428597] uart-pl011 fe201000.serial: cts_event_workaround enabled [ 0.428676] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2 [ 0.431742] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive r [ 0.432279] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor d river [ 0.432926] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [ 0.432953] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [ 0.458992] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1 [ 0.479282] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 0.480891] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 0.482500] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 0.485366] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 0.486968] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 0.494291] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using A DMA [ 0.496781] of_cfs_init [ 0.496876] of_cfs_init: OK [ 0.497460] Waiting for root device PARTUUID=6c586e13-02... [ 0.543438] random: fast init done [ 0.554826] mmc1: new high speed SDIO card at address 0001 [ 0.598444] mmc0: new ultra high speed DDR50 SDHC card at address aaaa [ 0.599597] mmcblk0: mmc0:aaaa SC32G 29.7 GiB [ 0.601751] mmcblk0: p1 p2 [ 0.615623] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst em [ 0.615659] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [ 0.761622] usb 1-1: new high-speed USB device number 2 using xhci_hcd [ 0.944247] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcd Device= 4.21 [ 0.944287] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 0.944314] usb 1-1: Product: USB2.0 Hub [ 0.946015] hub 1-1:1.0: USB hub found [ 0.946345] hub 1-1:1.0: 4 ports detected [ 1.016655] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [ 1.040421] EXT4-fs (mmcblk0p2): 7 orphan inodes deleted [ 1.040450] EXT4-fs (mmcblk0p2): recovery complete [ 1.066976] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null) [ 1.067055] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 1.073118] devtmpfs: mounted [ 1.080788] Freeing unused kernel memory: 2048K [ 1.081840] Run /sbin/init as init process [ 1.271624] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd [ 1.410654] usb 1-1.1: New USB device found, idVendor=0451, idProduct=16a8, b cdDevice= 0.09 [ 1.410695] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber =3 [ 1.410725] usb 1-1.1: Product: TI CC2531 USB CDC [ 1.410749] usb 1-1.1: Manufacturer: Texas Instruments [ 1.410772] usb 1-1.1: SerialNumber: __0X00124B0014D90EEB [ 1.522915] systemd[1]: System time before build time, advancing clock. [ 1.615721] NET: Registered protocol family 10 [ 1.616937] Segment Routing with IPv6 [ 1.651766] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL + XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr id) [ 1.652473] systemd[1]: Detected architecture arm. [ 1.668055] systemd[1]: Set hostname to <raspberrypi>. [ 1.670033] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argumen t [ 2.266872] random: systemd: uninitialized urandom read (16 bytes read) [ 2.274876] random: systemd: uninitialized urandom read (16 bytes read) [ 2.279015] systemd[1]: Created slice User and Session Slice. [ 2.279667] random: systemd: uninitialized urandom read (16 bytes read) [ 2.279988] systemd[1]: Started Forward Password Requests to Wall Directory W atch. [ 2.281333] systemd[1]: Set up automount Arbitrary Executable File Formats Fi le System Automount Point. [ 2.288877] systemd[1]: Listening on Syslog Socket. [ 2.310035] systemd[1]: Condition check resulted in Journal Audit Socket bein g skipped. [ 2.310887] systemd[1]: Listening on Journal Socket. [ 2.935935] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 3.046276] systemd-journald[102]: Received request to flush runtime journal from PID 1 [ 3.537489] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Reg isters at 0xfeb00000 length 0x0000ffff [ 3.539254] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised : Registers at 0xfeb10000 length 0x00000fff [ 3.539974] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Reg isters at 0xfeb20000 length 0x0000ffff [ 3.540519] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Regis ters at 0xfeb30000 length 0x0000ffff [ 3.569184] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 3.575373] bcm2835_audio soc:audio: card created with 8 channels [ 3.590158] media: Linux media interface: v0.10 [ 3.629738] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned. [ 3.640177] videodev: Linux video capture interface: v2.00 [ 3.641004] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [ 3.641019] [vc_sm_connected_init]: start [ 3.651951] [vc_sm_connected_init]: installed successfully [ 3.699141] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned. [ 3.699488] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned. [ 3.728657] bcm2835_v4l2: module is from the staging directory, the quality i s unknown, you have been warned. [ 3.758919] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 3.808023] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 3.808060] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 3.818923] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 3.818959] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 3.828000] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [ 3.828113] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 3.828142] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 3.861396] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase [ 3.909137] [drm] No displays found. Consider forcing hotplug if HDMI is atta ched [ 3.909232] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc 4]) [ 3.917723] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1 [ 3.917737] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.917746] [drm] No driver support for vblank timestamp query. [ 3.917756] [drm] Setting vblank_disable_immediate to false because get_vblan k_timestamp == NULL [ 3.963731] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.050101] brcmfmac: F1 signature read @0x18000000=0x15264345 [ 4.061525] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f or chip BCM4345/6 [ 4.062358] usbcore: registered new interface driver brcmfmac [ 4.064570] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device [ 4.074289] usbcore: registered new interface driver cdc_acm [ 4.074302] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters [ 4.294305] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f or chip BCM4345/6 [ 4.309421] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04 [ 6.155224] random: crng init done [ 6.155243] random: 7 urandom warning(s) missed due to ratelimiting [ 6.246312] uart-pl011 fe201000.serial: no DMA platform data [ 6.297752] 8021q: 802.1Q VLAN Support v1.8 [ 6.404641] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:1 02396k SSFS [ 6.504947] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 6.504956] brcmfmac: power management disabled [ 6.744933] bcmgenet: Skipping UMAC reset [ 6.852071] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay) [ 6.852296] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 7.911810] bcmgenet fd580000.genet eth0: Link is Down [ 12.071862] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow cont rol rx/tx [ 12.071900] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 12.945349] Bluetooth: Core ver 2.22 [ 12.945422] NET: Registered protocol family 31 [ 12.945432] Bluetooth: HCI device and connection manager initialized [ 12.945460] Bluetooth: HCI socket layer initialized [ 12.945476] Bluetooth: L2CAP socket layer initialized [ 12.945519] Bluetooth: SCO socket layer initialized [ 12.963241] Bluetooth: HCI UART driver ver 2.3 [ 12.963255] Bluetooth: HCI UART protocol H4 registered [ 12.963339] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 12.963580] Bluetooth: HCI UART protocol Broadcom registered [ 13.130797] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 13.130804] Bluetooth: BNEP filters: protocol multicast [ 13.130814] Bluetooth: BNEP socket layer initialized [ 14.153708] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net .ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead [ 111.559515] FS-Cache: Netfs 'cifs' registered for caching [ 111.559791] Key type cifs.spnego registered [ 111.559802] Key type cifs.idmap registered pi@raspberrypi:~ $ dmesg text.txt dmesg: bad usage Try 'dmesg --help' for more information. pi@raspberrypi:~ $ dmesg>text.txt pi@raspberrypi:~ $ dmesg >text.txt pi@raspberrypi:~ $ ls -l insgesamt 608 -rw-r--r-- 1 pi pi 312748 Aug 11 2019 pi_buster_motion_4.2.2-1_armhf.deb -rw-r--r-- 1 pi pi 282082 Dez 11 2017 pi_stretch_motion_4.1.1-1_armhf.deb -rw-r--r-- 1 pi pi 23096 Sep 10 17:57 text.txt pi@raspberrypi:~ $ text.txt -bash: text.txt: Kommando nicht gefunden. pi@raspberrypi:~ $ vi text.txt [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.93-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1290 SMP Fri Jan 10 16:45:11 GMT 2020 [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000 [ 0.000000] On node 0 totalpages: 1012736 [ 0.000000] DMA zone: 1728 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63 [ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0 [ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632 [ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M smsc95xx.macaddr=DC:A6:32:2D:68:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 3735568K/4050944K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 53232K reserved, 262144K cma-reserved, 3264512K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0x(ptrval) - 0x(ptrval) (10208 kB) .init : 0x(ptrval) - 0x(ptrval) (2048 kB) .data : 0x(ptrval) - 0x(ptrval) ( 688 kB) .bss : 0x(ptrval) - 0x(ptrval) ( 851 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 28682 entries in 85 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [ 0.000021] Switching to timer-based delay loop, resolution 18ns [ 0.000244] Console: colour dummy device 80x30 [ 0.000698] console [tty1] enabled [ 0.000752] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000) [ 0.000789] pid_max: default: 32768 minimum: 301 [ 0.001070] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001102] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001869] CPU: Testing write buffer coherency: ok [ 0.002294] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002951] Setting up static identity map for 0x200000 - 0x20003c [ 0.003124] rcu: Hierarchical SRCU implementation. [ 0.003996] smp: Bringing up secondary CPUs ... [ 0.004817] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.005748] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.006642] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.006777] smp: Brought up 1 node, 4 CPUs [ 0.006842] SMP: Total of 4 processors activated (432.00 BogoMIPS). [ 0.006864] CPU: All CPU(s) started in HYP mode. [ 0.006884] CPU: Virtualization extensions available. [ 0.007684] devtmpfs: initialized@graubi77 sagte in Adapterversion springt zurück auf alte Version:
[ 0.615623] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [ 0.615659] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [ 1.016655] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [ 1.040421] EXT4-fs (mmcblk0p2): 7 orphan inodes deleted [ 1.040450] EXT4-fs (mmcblk0p2): recovery complete [ 1.067055] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.Das Dateisystem ist durch / inodes platt. Neues Speichermedium organisieren und Backup (von einem Zeitpunkt VOR dem Defekt) einspielen. Am besten aber flugs neuinstallieren.
Hab ehrlich gesagt noch nie neu installiert. Ist immer noch der erste Stand. Daher die möglicherweise blöde Frage. Wenn ich alles von Grund auf neu hochziehe, muss ich alle Adaptereinstellungen und alle Scripte händisch wieder neu machen, bzw. bauen? Das wäre für jemanden wie mich, der sich nicht so in den tiefen des Systems auskennt echt nen immenser Aufwand :-(. Alleine auf dem Zigbee Adapter laufen über 30 Sensoren und die komplette VIS-Oberfläche würde nicht mehr funktionieren...
Das mit dem Backup ist auch eine gute Idee, aber ich kann nicht mal mehr genau sagen, wann das Problem auftrat. Ist schon echt ne Weile her. Und seitdem habe ich definitiv eine Menge am System geändert. -
Das mit dem Backup ist auch eine gute Idee, aber ich kann nicht mal mehr genau sagen, wann das Problem auftrat. Ist schon echt ne Weile her. Und seitdem habe ich definitiv eine Menge am System geändert.Ist immer noch der erste Stand.
Das habe ich am uralten Kernel schon gesehen...
So hart wie es klingt: Kein Backup - kein Mitleid.
Den backitup-Adapter zu betreiben ist kein Luxus. -
Den backitup-Adapter zu betreiben ist kein Luxus.Der Backitup Adapter läuft und hat auch für die letzten paar Tage Backups vom ioBroker, mySQL und Zigbee noch verfügbar. Aber der Fehler ist so bestimmt schon seit 2 Monaten und so alte Backups habe ich leider nicht mehr.
Also sehe ich es richtig, dass wenn ich den Pi neu aufsetze, dann aber ein aktuelles Backup des ioBroker einspiele, habe ich den gleichen Fehler wieder, oder?
@graubi77 Kommt halt drauf an, welche Daten im defekten Bereich lagen.
@Thomas-Braun
Konnte mit einem gespeicherten Backup das Problem lösen! Danke für die Hinweise
