  4. [gelöst]HM.RPC HomematicIP verbindet nicht
homematic iphomematic rpcconnection refused
24 Beiträge 5 Kommentatoren 4.8k Aufrufe 3 Beobachtet
  • painkillerdeP painkillerde
    @Homoran
    Callback-Adresse hatte ich bisher nie drin - habs grad probiert - ohne Erfolg.
    Firewall sieht gut aus:
    GlasfaserG Offline
    GlasfaserG Offline
    @painkillerde sagte in HM.RPC HomematicIP verbindet nicht:
    Stelle mal Remote ... API auf Vollzugriff
    painkillerdeP 1 Antwort Letzte Antwort
      @Homoran
      LEider nix verwertbares. das verückte is ja das die anderen HM-Adapter alle laufen
      hm-rpc.2	2020-09-08 14:59:34.106	error	(25440) init error: Error: connect ECONNREFUSED 192.168.178.37:2010
      hm-rpc.2	2020-09-08 14:59:34.049	debug	(25440) start connecting interval
      hm-rpc.2	2020-09-08 14:59:33.999	debug	(25440) xmlrpc -> 192.168.178.37:2010/ init ["http://192.168.178.105:2010","hm-rpc.2"]
      hm-rpc.2	2020-09-08 14:59:33.997	debug	(25440) Connect...
      hm-rpc.2	2020-09-08 14:59:33.983	info	(25440) xmlrpc client is trying to connect to 192.168.178.37:2010/ with ["http://192.168.178.105:2010","hm-rpc.2"]
      hm-rpc.2	2020-09-08 14:59:33.982	info	(25440) xmlrpc server is trying to listen on 192.168.178.34:2010
      hm-rpc.2	2020-09-08 14:59:33.359	info	(25440) starting. Version 1.14.15 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v10.21.0, js-controller: 3.1.4
      hm-rpc.2	2020-09-08 14:59:32.840	debug	(25440) Plugin sentry Initialize Plugin (enabled=true)
      hm-rpc.2	2020-09-08 12:59:23.569	info	(25369) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      hm-rpc.2	2020-09-08 12:59:23.568	debug	(25369) Plugin sentry destroyed
      hm-rpc.2	2020-09-08 12:59:23.254	info	(25369) xmlrpc -> 192.168.178.37:42010/ init ["http://192.168.178.105:42010",""]
      hm-rpc.2	2020-09-08 12:59:22.806	debug	(25369) system.adapter.admin.1: logging false
      hm-rpc.2	2020-09-08 12:59:22.047	debug	(25369) [MSSG] Received: {"command":"stopInstance","message":null,"from":"system.host.NAS","callback":{"message":null,"id":20,"ack":false,"time":1599569962026},"_id":96615419}
      HomoranH Offline
      HomoranH Offline
      ich finde in deinen Konfigurationen die 42010 nicht
        @Homoran
        @painkillerde sagte:
        Weshalb taucht eine IP-Adresse mit .105 auf anstelle .34 ?
          painkillerdeP Offline
          painkillerde
          ich hatte heute beim testen auf SSL umgestellt und das mit dem umstellen auf Debuglog wieder rausgenommen. das ist noch der Resteintrag bevor ich neu gestartet hab.
          Die .105 ist die NAS auf der der Docker-Container läuft. hab das bei den laufenden RPCs testweise auch eingetragen (wie gesagt hatte ich früher nie eine Callbackadresse drin) um es zu testen da lief es deswegen hab ich es hier auch reingemacht da @Homoran sagte ich soll die Callback eintragen.
          Grüße Daniel
          ioBroker auf Qnap TS-251A 8GB (Docker), Homamatic CCU2 + ca 50 Geräte (Aktoren, Sender, Sensoren), Alexa Echo, Alexa Echo Dot, Vu+ Duo2, Logitech Harmony Elite, Fronius Wechselrichter, Viessman Heizung + vControl
          • GlasfaserG Glasfaser
            painkillerde
            @Glasfaser
            hab auf Vollzugriff umgestellt - hat nix gebracht.
            Grüße Daniel
              HomoranH Offline
              HomoranH Offline
              bei Docker benötigst du sie aber. Genau dafür ist sie hinzugekommen.
                painkillerde
                @Homoran
                Hi hab ich so auch gelesen.
                Bisher hab ich es nie gebraucht. Steht auch bei den anderen nicht drin - geht trotz allem.
                .34 is mein io.Broker
                .105 die Nas mit dem Docker-Container (die IP müsste rein wenn ich es richtig verstehe)
                Hab beide eingetragen - zum Test - ohne Erfolg.
                Grüße Daniel
                  @Homoran
                  HomoranH Offline
                  HomoranH Offline
                  Gut dass du das nochmal erwähnst - sonst würden wir weitersuchen
                  nein - die IP von ioBroker muss da rein sonst landet die Antwort der CCU, genau wie ohne Callback-Adresse auf der 105, wo sie nicht hingehört
                    painkillerde
                    @Homoran
                    Also das hab ich jetzt kapiert ;)
                    Hab die Callback jetzt auf iobroker Adresse gesetzt.
                    Leider bleibt der Fehler bestehen.
                    hm-rpc.2	2020-09-08 15:43:28.308	error	(27446) init error: Error: connect ECONNREFUSED 192.168.178.37:2010
                    hm-rpc.2	2020-09-08 15:43:28.285	debug	(27446) start connecting interval
                    hm-rpc.2	2020-09-08 15:43:28.257	debug	(27446) xmlrpc -> 192.168.178.37:2010/ init ["http://192.168.178.34:2010","hm-rpc.2"]
                    hm-rpc.2	2020-09-08 15:43:28.255	debug	(27446) Connect...
                    hm-rpc.2	2020-09-08 15:43:28.252	info	(27446) xmlrpc client is trying to connect to 192.168.178.37:2010/ with ["http://192.168.178.34:2010","hm-rpc.2"]
                    hm-rpc.2	2020-09-08 15:43:28.251	info	(27446) xmlrpc server is trying to listen on 192.168.178.34:2010
                    hm-rpc.2	2020-09-08 15:43:28.032	info	(27446) starting. Version 1.14.15 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v10.21.0, js-controller: 3.1.4
                    hm-rpc.2	2020-09-08 15:43:27.623	debug	(27446) Plugin sentry Initialize Plugin (enabled=true)
                    hm-rpc.2	2020-09-08 13:43:18.318	info	(26615) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    hm-rpc.2	2020-09-08 13:43:18.316	debug	(26615) Plugin sentry destroyed
                    hm-rpc.2	2020-09-08 13:43:18.301	info	(26615) xmlrpc -> 192.168.178.37:2010/ init ["http://192.168.178.34:2010",""]
                    hm-rpc.2	2020-09-08 13:43:17.302	debug	(26615) [MSSG] Received: {"command":"stopInstance","message":null,"from":"system.host.NAS","callback":{"message":null,"id":25,"ack":false,"time":1599572597298},"_id":96615448}
                    Grüße Daniel
                      @Homoran
                      HomoranH Offline
                      HomoranH Offline
                      ist ja auch ein anderer, als der den wir jetzt verhindert haben ;-)
                      unter der Annahme, dass die 37 deine CCU ist hat diese die Verbindung abgelehnt.
                      Die Callback-Adresse käme erst im nächsten Schritt zum tragen.
                      HAst du irgendwelche Sicherheit in der CCU aktiv
                      User/Passwort?
                        User/Passwort?
                        painkillerde
                        @Homoran
                        nix besonderes. Klar Benutzer und Passwort fürs Web-UI aber auch die anderen RPCs laufen ohne besondere Einstellungen. Siehe Screens oben RPC.0 sowie RPC.1
                        Dort gibt es keinerlei Zusätzliche Einstellungen in der jeweiligen io.Broker-Instanz und sie laufen.
                        Grüße Daniel
                          @Homoran
                          HomoranH Offline
                          HomoranH Offline
                          @painkillerde hattest du schon mal die CCU rebooted?
                            painkillerde
                            @Homoran
                            na klar
                            ne natürlich noch nicht - mach ich jetzt.
                            Grüße Daniel
                            v522533V 1 Antwort Letzte Antwort
                              @Homoran
                              na klar
                              v522533V Offline
                              v522533V Offline
                              v522533
                              @painkillerde
                              gib mal die login daten ein, danach gings bei mir
                              Gruß Chris
                              • v522533V v522533
                                @painkillerde
                                painkillerde
                                @v522533
                                muss ich aber SSL also https aktivieren!?
                                Grüße Daniel
                                  @v522533
                                  v522533V Offline
                                  v522533V Offline
                                  v522533
                                  @painkillerde
                                  ja musst du.
                                  Gruß Chris
                                  • v522533V v522533
                                    @painkillerde
                                    ja musst du.
                                    painkillerde
                                    @v522533
                                    also ccu startet grad neu die beiden RPCs hab ich auf https+ Passwort ( hab beide XML-RPC Instanzen umgestellt damit ich nen Vergleich hab da die für rfd ja problemlos lief)
                                    Spannung steigt und die CCU2 wird sicher in 5 bis 10 Minuten wieder da sein - gähn
                                    Grüße Daniel
                                      @v522533
                                      painkillerde
                                      Also nun läuft alles wieder.
                                      https ging nicht - bei keinem der beiden Instanzen - aber ich denke der Reboot war es.
                                      Wie immer
                                      Reboot tut gut
                                      Sry und danke für die tolle Unterstützung!!!
                                      Grüße Daniel
                                        Wie immer
                                        Reboot tut gut
                                        HomoranH Offline
                                        HomoranH Offline
                                        da hätte auch in der CCU etwas umgestellt werden müssen
                                        ich auch
