  4. Test Adapter WhatsAPP-CMB
    6.5k
testeradapter
172 Beiträge 47 Kommentatoren 56.6k Aufrufe 51 Beobachtet
  • liv-in-skyL liv-in-sky
    @sigi234
    habe dieses blockly
     <variables>
       <variable id="TF3()M^!V42=QkiyOm+f">nachricht</variable>
       <variable id="my?#k2uA64T5eQ0-#.Wi">empfaenger</variable>
       <variable id="0/b1Xq;3ErYPhA!,E|A~">fritzboxDaten</variable>
     </variables>
     <block type="on" id="3mAnq90XGX#sQcRw+Da-" x="62" y="37">
       <field name="OID">0_userdata.0.Whatsapp.Nachricht</field>
       <statement name="STATEMENT">
         <block type="variables_set" id="Gx8{1il!]D/d|O(NfNuF">
           <field name="VAR" id="TF3()M^!V42=QkiyOm+f">nachricht</field>
           <value name="VALUE">
             <block type="get_value" id="?7y)#g+teW$xgMU,;|#C">
             </block>
           </value>
           <next>
             <block type="variables_set" id="ggiKBm9h^*~wYW|-d:=5">
               <field name="VAR" id="my?#k2uA64T5eQ0-#.Wi">empfaenger</field>
                 <block type="get_value" id="ii[@en/*KayJ13sH76({">
                   <field name="OID">0_userdata.0.Whatsapp.Empfaenger</field>
                 </block>
               </value>
               <next>
                 <block type="whatsapp-cmb" id="]KokBjSl=4abZZNgZ2M,">
                   <field name="INSTANCE">.0</field>
                   <field name="LOG"></field>
                   <value name="MESSAGE">
                     <shadow type="text" id="y~./:CUX~M|;Y$dwx6~.">
                     </shadow>
                     <block type="variables_get" id="t:/f?u9[,vh)gkv,HOt+">
                     </block>
                   </value>
                   <value name="PHONE">
                     <block type="variables_get" id="ix`%.`_jeB:5qyNP43V+">
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
     <block type="comment" id="P/;:xv6E`R%m#tbg-67q" x="713" y="12">
       <field name="COMMENT">beispiel fritzbox  anrufer weiterleiten</field>
       <next>
         <block type="on" id="C~|R!i$v7we|RhweNTap">
           <field name="OID">tr-064.0.callmonitor.inbound.json</field>
             <block type="variables_set" id="1ZRUV,C{kr{,:ZF2}k5F">
               <field name="VAR" id="0/b1Xq;3ErYPhA!,E|A~">fritzboxDaten</field>
                 <block type="procedures_callcustomreturn" id="L%Zm9CFNu/,v?j+;1415">
                   <mutation name="etwas tun"></mutation>
                 </block>
               </value>
               <next>
                 <block type="control" id="NkK=xjWivX9PS(r$0fsc">
                     <block type="variables_get" id="NN?$T#qfvJ:v2liYNzH^">
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
     <block type="procedures_defcustomreturn" id="V?trlfmJQv7Kn*3CT+da" x="713" y="287">
       <mutation statements="false"></mutation>
       <field name="NAME">etwas tun</field>
       <field name="SCRIPT">DQpsZXQgbXlEYXRhID0gSlNPTi5wYXJzZShnZXRTdGF0ZSgidHItMDY0LjAuY2FsbG1vbml0b3IuaW5ib3VuZC5qc29uIikudmFsKQ0KDQoNCg0KcmV0dXJuIGBBbnJ1ZiBhbiBGcml0emJveA0KTnVtbWVyOiAke215RGF0YS5jYWxsZXJ9XG4NCk5hbWU6ICR7bXlEYXRhLmNhbGxlck5hbWV9XG4NClVocnplaXQ6ICR7bXlEYXRhLnRpbWVzdGFtcH1gOw==</field>
     </block>
    </xml>
    das hat 2 datenpunkte - empfänger und nachricht (selber anlegen) - wenn nun jmd in der fritzbox anruft - schreibt die nummer und den empfänger in den datenpunkt nachricht- dann kommt die message - natürlich ist bis dahin der anruf vorbei - aber wenn du unterwegs bist, weißt du, wer angerufen hat - ich habe im moment nur meine nummer im dp empfänger
    das blockly triggert auf nachricht dp - wenn du eine andere nummer angeben willst, zuerst den empfänger datenpunkt schreiben und dann den text - dann wird getriggert
    sigi234S Online
    sigi234S Online
    @liv-in-sky sagte in Test Adapter WhatsAPP-CMB:
    Welche Werte?
    Wo?
    liv-in-skyL 3 Antworten Letzte Antwort
    • sigi234S sigi234
      Welche Werte?
      Wo?
      liv-in-skyL Offline
      liv-in-skyL Offline
      @sigi234 du mußt die beiden datenpunkte selber in deinem system anlegen (beide sind zeichenfolge/strings)) und dann im blockly korrigieren
      bei mir
      • sigi234S sigi234
        Welche Werte?
        Wo?
        liv-in-skyL Offline
        liv-in-skyL Offline
        @sigi234
        um eine nachricht (alarm) zu senden, schreibst du nach dem einrichten der datenpunkte und des scriptes in jedem anderen script, in dem du einen alarm versenden willst einfach nur in den datenpunkt "nachricht" - dann wird das gesendet an den empfänger der im datenpunkt empfänger steht (bei mir ist das nur eine nummer, daher steht im datenpunkt empfänger immer meine telefonnummer
        möchte man an einen andere nummer senden, mußt du zuerst den datenpunjkt empfänger schreiben (mit der gewünschten nummer) und dann erst den datenpunkt nachricht - denn auf diesen wird getriggert
        • sigi234S sigi234
          Welche Werte?
          Wo?
          liv-in-skyL Offline
          liv-in-skyL Offline
          @sigi234
          oder ganz einfach - nur für die fritzbox benachrichtigung:
           <block type="comment" id="{Y]qq+v3Mbp[^/L0@|m$" x="512" y="237">
             <field name="COMMENT">fritzbox anruf</field>
             <next>
                       </shadow>
                       <block type="procedures_callcustomreturn" id="s!flgU^ekzRrm=m,Q?*f">
                       </block>
                     </value>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
           </block>
          </xml>
            @sigi234
               <next>
                         </shadow>
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
             </block>
            </xml>
            sigi234S Online
            sigi234S Online
            #66
            Danke, läuft.👍
            • harrymH Offline
              harrymH Offline
              harrym
              #67
              2020-09-02 19:51:19.846 - error: whatsapp-cmb.1 (32416) Cannot send message:
              Message to: xxxxxx
              Text to send: xxxxxx
              There was an ERROR!!!
              Error Num:2
              Error Text:mysqli::__construct(): (HY000/2002): Connection timed out
              Was will mir der Error genau sagen? Timed Out beim bot?
              ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
              • harrymH harrym
                Message to: xxxxxx
                Error Num:2
                M Online
                M Online
                michihorn
                schrieb am zuletzt editiert von michihorn
                #68
                Ich hatte den Adapter auch laufen, seit heute bekomme ich aber Fehler im LOG
                whatsapp-cmb.0	2020-09-02 22:26:00.227	error	(1784) Cannot send message: <p>Message to: +4915253938xxx<p>Text to send: Rtest<p>There was an ERROR!!!<p><u>Error Num:</u>2<p><u>Error Text:</u>mysqli::__construct(): (HY000/2002): Connection timed o
                whatsapp-cmb.0	2020-09-02 22:26:00.010	info	(1784) Send Rtest to +4915253938xxx
                whatsapp-cmb.0	2020-09-02 22:25:00.028	info	(1784) Send Rtest to +4915253938xxx
                Habe die 1.1.6 installiert
                Michael
                • E Offline
                  el_malto
                  #69
                  Warum sind die Telefonnummern auf Github und der Homepage unterschiedlich?
                  harrymH 1 Antwort Letzte Antwort
                  • E el_malto
                    harrymH Offline
                    harrymH Offline
                    harrym
                    #70
                    @el_malto und warum @Homoran und @sigi234 haben ösis 664 ala Freud im Kopf?
                    E 1 Antwort Letzte Antwort
                    • harrymH harrym
                      el_malto
                      #71
                      @harrym sagte in Test Adapter WhatsAPP-CMB:
                      • E el_malto
                        da_WoodyD Offline
                        da_WoodyD Offline
                        #72
                        @el_malto weil bei uns ein anbieter 664 als handyvorwahl hat und wir das automatisch lesen und statt 644 eingeben. die macht der gewohnheit... ;) ich bin auch auf die schnauze gefallen...
                        • da_WoodyD da_Woody
                          el_malto
                          #73
                          @da_Woody das war ja aber nur ein Tippfehler eurerseits. Auf Github und der HP stehen aber wirklich zwei unterschiedliche Nummern.
                          • E el_malto
                            da_WoodyD Offline
                            da_WoodyD Offline
                            #74
                            @el_malto jap, schau mal nach meinem posting vom 2. September. ;)
                            und dann schlug der tappfühler auch noch zu. :D
                              el_malto
                              #75
                              @da_Woody ja das ist mir alles klar. Erklärt aber nicht warum da nun zwei unterschiedliche Nummern stehen.
                              • E el_malto
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #76
                                @el_malto rischtisch, erklärts nicht. denk mal, dadurch das ganze ja noch beta ist, einfach vergessen wurde die nummer zu ändern.
                                edith: grad nachgelinst. der blogbeitrag ist von March 28, 2020...
                                • E Offline
                                  el_malto
                                  #77
                                  Vielleicht kann da @Bluefox ja was zu sagen.
                                  Des Weiteren würde mich die Privatsphäre interessieren. Die Nachrichten werden ja über einer dieser Nummern versendet. Der "Eigentümer" der Nummer müsste ja eigentlich alle Nachrichten einsehen können.
                                  da_WoodyD BluefoxB 2 Antworten Letzte Antwort
                                  • E el_malto
                                    da_WoodyD Offline
                                    da_WoodyD Offline
                                    #78
                                    @el_malto wie kommst du auf die idea?
                                    wenn du dir den link anschaust
                                    https://api.callmebot.com/whatsapp.php?phone=[phone_number]&text=[message]&apikey=[your_apikey]
                                    gibts da nur die nummer an den du verschickst, die message und deinen apikey.
                                      el_malto
                                      #79
                                      @da_Woody und von welcher Nummer bekommst du die Nachrichten?
                                      • E el_malto
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        #80
                                        @el_malto ja und? selbst wenn das jemand lesen sollte, weis er halt das die WaMa, oder der Trockner fertig ist. IMHO wird das einfach durchgereicht, wenn nicht sogar verschlüsselt. da bin ich etwas schmerzbefreit. privates geht sicher nicht über den broker raus.
                                          el_malto
                                          #81
                                          @da_Woody sieht halt jeder anders.
