  4. Emails empfangen.
Emails empfangen.
119 Beiträge 31 Kommentatoren 38.9k Aufrufe 28 Beobachtet
    @gelberlemmy normalerweise installiert der javascript-adapter die Pakete beim Neustart des Adapters.
    gelberlemmyG
    gelberlemmyG
    gelberlemmy
    schrieb am zuletzt editiert von gelberlemmy
    @ilovegym sagte in Emails empfangen.:
    Ich habe das jetzt mal über Putty angeschoben und sieht wie folgt aus. Am Ende gibt eine Warnung. Ist diese normal ?
    pi@raspberrypi:~ $ npm install imap
    [..................] - rollbackFailedOptional: verb npm-session 6f2886487ff7552
    [..................] \ rollbackFailedOptional: verb npm-session 6f2886487ff7552
    [..................] / fetchMetadata: sill resolveWithNewModule imap@0.8.19 che
    [..................] - fetchMetadata: sill resolveWithNewModule imap@0.8.19 che
    [..................] \ fetchMetadata: sill resolveWithNewModule imap@0.8.19 che
    [..................] / fetchMetadata: sill resolveWithNewModule readable-stream
    [..................] | fetchMetadata: sill resolveWithNewModule readable-stream
    [..................] \ fetchMetadata: sill resolveWithNewModule readable-stream
    [  ................] - fetchMetadata: sill resolveWithNewModule string_decoder@
    [      ............] - diffTrees: sill install generateActionsToTake
    [       ...........] | postinstall: sill install executeActions
    [       ...........] - extract:imap: verb lock using /home/pi/.npm/_locks/stagi
    [       ...........] / extract:imap: verb lock using /home/pi/.npm/_locks/stagi
    [            ......] | finalize:imap: sill doSerial finalize 64
    [            ......] / refresh-package-json:imap: timing action:finalize Comple
    [            ......] | refresh-package-json:imap: timing action:finalize Comple
    [            ......] \ postinstall: info lifecycle imap@0.8.19~postinstall: ima
    npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
    npm notice created a lockfile as package-lock.json. You should commit this file.
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    + imap@0.8.19
    added 8 packages from 4 contributors and audited 8 packages in 1.604s
    found 0 vulnerabilities
    [            ......] \ postinstall: sill install printInstalled
      @Marty56 hmm da kommt bei mir nur ein [object Object], wenn ich aber die einzelnen variablen in einen State schreibe, gehts, also die Daten werden ausgelesen, aber nicht Email_Reception eingetragen.. ?
      Ich brauchs nicht unbedingt, möchte aber wissen, warum das nicht geht.. :-)
      Hier mal mein Script, es wird unter javascript.0. ein Verzeichnis Email angelegt, wo alle Datenpunkte dann eingetragen werden ( so habe ich mehr übersicht )
      var mailobj = {val:
                          topic: "",
                          text: "",
      createState("Email.Reception",mailobj);
      createState("Email.from_address");
      createState("Email.from_name");
      createState("Email.mail_subject");
      createState("Email.mail_text");
      schedule("*/2 * * * *", function (obj) {
          var MailListener = require("mail-listener2");
          var mailListener = new MailListener({
            username: "blabla.com",    // hier Email Adresse eintragen
            password: "geheimespassword",	      // hier Passwort eintragen
            host: "imap.gmail.com",
            port: 993, // imap port
            tls: true,
            connTimeout: 10000, // Default by node-imap
            authTimeout: 5000, // Default by node-imap,
            debug: null, // Or your custom function with only one incoming argument. Default: null
            tlsOptions: { rejectUnauthorized: false },
            mailbox: "INBOX", // mailbox to monitor
            searchFilter: ["UNSEEN"], // the search filter being used after an IDLE notification has been retrieved
            markSeen: true, // all fetched email willbe marked as seen and not fetched next time
            fetchUnreadOnStart: true, // use it only if you want to get all unread email on lib start. Default is `false`,
            mailParserOptions: {streamAttachments: true}, // options to be passed to mailParser lib.
            attachments: false, // download attachments as they are encountered to the project directory
            attachmentOptions: { directory: "attachments/" } // specify a download directory for attachments
          mailListener.start();
          mailListener.on("server:connected", function(){console.log("imapconconnected");});
          mailListener.on("server:disconnected", function(){console.log("imapDisconnected");});
          mailListener.on("error", function(err){console.log(err);});
          mailListener.on("mail", function(mail, seqno, attributes){
              log(mail.from[0].address);
              log(mail.from[0].name);
              log(mail.subject);
              log( mail.text);
              var mailobj = {val:
                          topic: mail.subject,
                          text:  mail.text
              setState("Email.Reception", mailobj);
              setState("Email.from_address", mail.from[0].address);
              setState("Email.from_name", mail.from[0].name);
              setState("Email.mail_subject", mail.subject);
              setState("Email.mail_text", mail.text);
          mailListener.on("attachment", function(attachment){console.log(attachment.path);});
          setTimeout(function(){mailListener.stop();},20000);
      liv-in-skyL
      liv-in-skyL
      @ilovegym
      würde gerne die mails mit dem status nicht gelesen belassen - habe dazu markseen_= false; geändert
      die mails werden trotzdem als gelesen markiert - ist das bei dir auch so ?
      • liv-in-skyL
        liv-in-skyL
        @ilovegym
        hat sich erledigt - habe mal eine andere mailbox eingetragen - jetzt funktioniert es
        • gelberlemmyG gelberlemmy
          + imap@0.8.19
          @gelberlemmy hast nicht im richtigen Verzeichnis installiert, würde ich sagen..
          gelberlemmyG 1 Antwort Letzte Antwort
          • liv-in-skyL liv-in-sky
            @ilovegym
            @liv-in-sky ja, kann an der Mailbox liegen, hatte das ab und zu mal, störte mich aber weniger..
              liv-in-skyL
              liv-in-skyL
              @ilovegym
              ist auch ein anderer provider - vielleicht liegt es daran ?
                gelberlemmyG
                gelberlemmyG
                gelberlemmy
                @ilovegym lustigerweise funktioniert das jetzt. Bekomme die eMails in meinen Datenpunkten. Wo hätte ich das denn installieren sollen ? Hab dies ohne Verzeichnisangabe installiert....
                  liv-in-skyL
                  liv-in-skyL
                  #66
                  @ilovegym
                  habe dein script noch ein wenig aufgebohrt - ne tabelle - was sonst :-)
                  bis jetzt kann man sortieren
                  • wieviele mails angezeigt werden sollen
                  • welche sender abgefragt werden sollen
                  Master67M 1 Antwort Letzte Antwort
                    #67
                    @gelberlemmy normal installiert iobroker die npm pakete im ordner /opt/iobroker/node_modules, im direkten iobroker ordner gehts auch, solange die files gefunden werden und die rechte stimmen.
                    Ist besser wegen benutzerrechten und pfadangaben.. solange es jetzt läuft, lass es so.
                    Daher auch der Hinweis, einfach im Javascript-Adapter das Paket zu hinterlegen, wie die anderen auch dort.
                    Bei einem Neustart des Adapters werden die fehlenden Pakete installiert.
                      @M-A-X
                      du kannst ganz ohne vpn und mit tasker einen oder mehrere datenpunkt in iobroker schreiben
                      https://forum.iobroker.net/post/274658
                      M
                      M
                      M-A-X
                      #68
                      @liv-in-sky danke
                      Das klappt theoretisch. Aber leider kommt der tasker Befehl zum 'URL öffnen' nicht durch, wenn das Handy gesperrt ist :(
                      • M M-A-X
                        @liv-in-sky danke
                        liv-in-skyL
                        liv-in-skyL
                        #69
                        @M-A-X ja - könnte sein - hast du das energiesparen für tasker abgeschalten ? - dann verbindet sich aber das handy auch nicht mit dem wlan bzw - findet den standort - dann kannst du aber eigentlich keine lösung finden
                        macht du anwesenheit mit wlan oder gps - tasker kann auch gps lesen und einen home-bereich definieren - evtl noch mit einem zeitgesteuerten task öfter abfragen, damit das handy nicht einschläft
                          M
                          M
                          M-A-X
                          #70
                          @liv-in-sky
                          Ich benutze derzeit Autolocation inkl. Tasker plugin und dann sendeintent. Das habe ich gerade parallel versucht zu 'deinem' weg.
                          Das sendeintent geht durch, die URL öffnen nicht. Manuell bei entsperrem Handy klappt es und er öffnet den Standard Browser mit der URL
                          • M M-A-X
                            @liv-in-sky
                            liv-in-skyL
                            liv-in-skyL
                            #71
                            @M-A-X
                            sendintent - habe ich noch nicht gerafft - was startet der ? den browser ?
                            dann sollte tasker aber auch einen http get an iobroker wegbekommen
                              @M-A-X
                              M
                              M
                              M-A-X
                              schrieb am zuletzt editiert von M-A-X
                              #72
                              @liv-in-sky
                              Oh man ich schmeiße alles durch einander. Natürlich mit nem GET http request.
                              Ich versuche es gerade hier zu testen mit nem 'warte 5 Sekunden' vorher, damit ich das handy sperren kann, aber das klappt nicht. Muss es nochmal versuchen wenn ich die homezone verlasse.
                              Edit: ich war dumm. Hatte den state nicht geändert, sodass meine Bedingung nicht getriggert wurde. Es klappt jetzt. Vielen Dank
                              Edit2: habe es übrigens nie nur mit tasker (ohne Autolocation) hin bekommen. Der gps Bereich trigger von tasker war extrem unzuverlässig
                              • M M-A-X
                                @liv-in-sky
                                liv-in-skyL
                                liv-in-skyL
                                #73
                                @M-A-X
                                richtig testen kannst du wahrscheinlich nur, wenn das handy mal längere zeit nicht aktiv war - du wirst dir wohl einen anderen trigger überlegen müssen, sonst fragen sich die nachbarn, warum der kerl solange da steht :-)
                                ich kenne das aber gut - habe trigger wenn whatsapp kommt und soll dann auf vis angezeigt werden - auch bei mir funktioniert das nicht immer, weil das handy manchmal nicht aufwacht, wenn eine whatsapp kommt - funktioniert mit ca 80-90 % zuverlässigkeit
                                  @M-A-X
                                  M
                                  M
                                  M-A-X
                                  #74
                                  @liv-in-sky
                                  So. Habs getestet. Klappt recht gut. Leider habe ich bisher nur die kostenlose iobroker Version und jedes verlassen und betreten der zone zählt als Anfrage, sodass die 20 inklusivanfragen schnell aufgebraucht werden :) Muss wohl die pro Version her ;)
                                    @ilovegym
                                    Master67M
                                    Master67M
                                    Master67
                                    schrieb am zuletzt editiert von Master67
                                    #75
                                    @liv-in-sky sagte in Emails empfangen.:
                                    @ilovegym
                                    Das Script läuft, die Tabelle aber nicht, bin nicht so Fit in Vis (meine Vis ist nur Rudimentär) ich verstehe was ein "html-widget" ist aber nicht was ist mit "binding" gemeint ist!
                                    Gruß Master67
                                    • Master67M Master67
                                      @ilovegym
                                      liv-in-skyL
                                      liv-in-skyL
                                      #76
                                      @Master67 das binding bedeutet, dass in der vis anstatt ein fester wert, ein inhalt eines datenpunktes angezeigt wird
                                      z.b die höhe eines widgets wird normalerweise als fester wert eingegeben. wenn du aber ein binding anstatt eines festen wertes einträgst, wird die höhe des widgets aus einem anderen datenpunkt ausgelesen - damit ist die ganze sache dynamischer, weil du die höhe individuell berechnene kannst
                                      im html widget wird durch binding gesagt, die vis soll sich den inhalt(wert) in einem datenpunkt holen - der datenpunkt wird durch das script definiert
                                      beispiel 1 : im html widget wird eine feste tabelle eingegeben - unflexibel:
                                      beispiel2: hier wird ein binding angewendet - eine geschweifte klammer um einen datenpunkt - damit ist der inhalt des widgets dynamisch - wird der dp geändert - wird der inhalt geändert
                                      das binding kann in fast jedem vis feld genutzt werden - schriftgröße, schriftart, widgethöhe, widgetbreite, .............
                                      es können sogar kleine berechnungen mit diesem binding gemacht werden
                                      hier mal ein beispiel, wie sich ein widget durch binding vertikal bewegen läßt - im binding wird noch eine kleine berechnung mit einem dp gemacht
                                      {value:javascript.0.GETPROCESS.CPUIdleALL; value=Math.floor(290-(value*1.4))}
                                        Master67M
                                        Master67M
                                        Master67
                                        #77
                                        @liv-in-sky .... Danke für die Info..... aber da bin ich jetzt raus ;-)
                                        Das übersteigt das was ich mit "meiner" Vis und meinen Fähigkeiten machen kann!
                                        Gruß Master67
                                          liv-in-skyL
                                          liv-in-skyL
                                          #78
                                          @Master67 sorry wollt dich nicht abschrecken - aber das mit dem binding für die tabelle iist klar geworden - mehr brauchst du ja im moment nicht
                                          du nimmst deinen datenpunkt, welches das script schreibt und setzt ihn in geschweiften klammer in das widget
                                          33.2k
                                          84.4k
