  2. English
  3. Visualization
  4. VIS formula in Object ID SOLVED
    1.0k
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
4 Beiträge 3 Kommentatoren 2.4k Aufrufe 2 Beobachtet
    ap2017
    schrieb am zuletzt editiert von ap2017
    I am using WeatherCustom widget, is there a way to convert temperature from Celsius to Fahrenheit, for example by using formula in Temperature ID. Something like
    (ObjectID *9/5)+32
    ![6b39a171-bae5-4d64-9c66-9103fb6a7a71-image.png]
    (/assets/uploads/files/1585194027712-6b39a171-bae5-4d64-9c66-9103fb6a7a71-image.png)
    Apparently, this feature works only for widgets with HTML property. It will be great to clarify it in VIS Wiki
    CrunkFXC 1 Antwort Letzte Antwort
    • A ap2017
      (ObjectID *9/5)+32
      CrunkFXC Offline
      CrunkFXC Offline
      CrunkFX
      Forum Testing
      schrieb am zuletzt editiert von CrunkFX
      @ap2017 Install the Javascript Adapter and in Userdata.0 create a new Datapoint as Number.
      The goto Javascript and create a new "Javascript".
      Insert this and Edit for your needs:
      on({id: 'accuweather.0.Current.Temperature'/* <<< This has to be your AccuWeather Temp. No matter which one*/, change: "ne"}, function (obj) {
        setState("0_userdata.0.New_Object"/*<<<This has to be your new Datapoint*/, (getState("accuweather.0.Current.Temperature"/*<<< This has to be the same AccuWeather Temp. as above*/).val * (9 / 5) + 32), true);
      then goto VIS and select the Object created in Userdata.0
      • CrunkFXC CrunkFX
        ap2017
        @CrunkFX Thank you. Can same be done by binding ObjectID in widget? Something like:
        {objectID;*(9);/(5);+(32);} For some reason it does not work for me.
        • A ap2017
          DutchmanD Offline
          DutchmanD Offline
          Dutchman
          schrieb am zuletzt editiert von Dutchman
          @ap2017 sagte in VIS formula in Object ID:
          Yes you can just use bindings in vis for calculations.
          “ You can use this pattern in any text, like
          My calculations with {objectID1;operation1;operation2;...} are {objectID2;operation3;operation4;...}
          or color calculations:
          #{objectRed;/(100);*(255);HEX2}{objectGreen;HEX2}{objectBlue;HEX2}
          https://github.com/ioBroker/ioBroker.vis
