  4. Xiaomi Smartmi Air Humidifier2
121 Beiträge 23 Kommentatoren 24.4k Aufrufe 21 Beobachtet
  • K kenny384
    Jetzt hat es mich leider auch erwischt und der Adapter geht nicht mehr. Und zwar direkt nach dem Update auf den js-controller 3.1
    Jetzt kommt nur jeweils eine der folgenden Error messages:
    mihome-humidifier.0	2020-06-04 10:45:48.624	error	(28436) TypeError: adapter.objects.getObject is not a function at setNameInstanceAdapter (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:59:21) at main (/opt/iobroker/node_modul
    mihome-humidifier.0	2020-06-04 10:45:48.621	error	(28436) unhandled promise rejection: adapter.objects.getObject is not a function
    mihome-humidifier.0	2020-06-04 10:45:48.620	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Oder
    mihome-humidifier.0	2020-06-04 10:45:48.624	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    mihome-humidifier.0	2020-06-04 10:45:48.624	error	at promiseReadSecret.then.then (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8148:34)
    mihome-humidifier.0	2020-06-04 10:45:48.624	error	at Adapter.emit (events.js:198:13)
    mihome-humidifier.0	2020-06-04 10:45:48.624	error	at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:28:5)
    mihome-humidifier.0	2020-06-04 10:45:48.624	error	at main (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:32:5)
    mihome-humidifier.0	2020-06-04 10:45:48.624	error	at setNameInstanceAdapter (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:59:21)
    Unhandled	2020-06-04 10:45:48.620	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Neustart und Neuinstallation des Adapters haben nichts gebracht. Liest der gute Ersteller dieses Adapters hier wohl noch mit? Oder kann jemand anders noch Tipps geben?
    @kenny384 sagte in Xiaomi Smartmi Air Humidifier2:
    Naja der ist von einem ENtwickler ... hm ... kannst versuchen die angemeckerte Zeile zu patchen:
    https://github.com/mafof/ioBroker.mihome-humidifier/blob/master/main.js#L59
    --> adapter.getObject
    muss es sein (also das extra ".object" muss weg)
    Das gleiche dann in https://github.com/mafof/ioBroker.mihome-humidifier/blob/master/main.js#L63
    P 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Pittini
      @apollon77 sagte in Xiaomi Smartmi Air Humidifier2:
      Vielen herzlichen Dank, genau das wars offenbar. Bei mir läuft das nun, wers haben will, ich habs geforked:
      https://github.com/Pittini/ioBroker.mihome-humidifier
      K apollon77A K 3 Antworten Letzte Antwort
      • P Pittini
        kenny384
        @Pittini Danke, ich würde das auch gerne anwenden. Leider bin ich totaler Github-Noob. Kannst du mir kurz erklären was ich machen muss um die Änderung auch bei mir im Adapter vorzunehmen?
        • K kenny384
          Pittini
          Einfach mit obigem Link drüberinstallieren. Also Katze > Beliebig > Link eingeben, fertig.
          • P Pittini
            kenny384
            @Pittini Ja mega, läuft jetzt auch bei mir wieder. Danke dir und danke auch an @apollon77
            • P Pittini
              @Pittini Machst Du bitte ein PR gegen das originale Repo... wenn da nichts passiert in sagen wir 4 Wochen dann bitte nochmal bei mir melden, dann kann man sversichen das Repo auf npm zu übernehmen :-( Leider scheinbar vor der Zeit wo Bluefox überall NPM rechte hatte ...
              P 2 Antworten Letzte Antwort
                Pittini
                Machst Du bitte ein PR gegen das originale Repo... wenn da nichts passiert in sagen wir 4 Wochen dann bitte nochmal bei mir melden, dann kann man sversichen das Repo auf npm zu übernehmen Leider scheinbar vor der Zeit wo Bluefox überall NPM rechte hatte ...
                PR hatte ich schon gemacht. Ich geb Bescheid wenn sich was tut.
                • TottoT Offline
                  TottoT Offline
                  Totto
                  Weiß jemand zufällig, ob man mit dem Adapter auch den Smart Fan (Ventilator) von Xiaomi SmartMi steuern kann?
                  • TottoT Totto
                    @Totto Ventialtoren gehen über den miio Adapter
                    TottoT 1 Antwort Letzte Antwort
                      TottoT Offline
                      TottoT Offline
                      Totto
                      @Thomas-Braun Danke für die Info! Leider kann ich weder im ioBroker, noch bei github, einen Adapter namens miio finden.
                      Könntest Du mir hier bitte nochmal auf die Sprünge helfen? :)
                      • TottoT Totto
                        @Totto Geh Mal die Liste mit den Adaptern zu Mijia durch. Sind glaube ich 3 oder 4. Einer davon bezieht sich auf das miio Protokoll.
                          TottoT Offline
                          TottoT Offline
                          Totto
                          @Thomas-Braun Auch mit "mijia" konnte ich leider nichts finden... :(
                          Folgende Adapter finde ich bei github:
                          • mihome [ioBroker]
                          • mihome-lamp [MeisterTR]
                          • mihome-plug [iobroker-community-adapters]
                          • mihome-vacuum [iobroker-community-adapters]
                          Muss für den Smart Mi Ventilator eigentlich auch dieser Token ausgelesen werden?
                          Und weißt Du vielleicht, was man über den Adapter am Ventilator steuern kann, wenn er mal verbunden ist? Kann man die Lüfterdrehzahl und die Oszillation (Winkel des Schwenkens) einstellen?
                          Ich frage deshalb, weil - wenn man ihn über den ioBroker nur ein und ausschalten könnte, dann würde ich mir diese Arbeit nicht machen. Das kann ich auch per Sprachsteurung mit Google oder Alexa machen.
                          Schonmal vielen Dank für Deine Hilfe! :)
                          • TottoT Totto
                            • mihome [ioBroker]
                            @Totto Müsste ich zuhause nachschauen. Ich habe den Adapter nur installiert, habe aber keine Instanzen aktiv. Soweit ich mich erinnere kann man aber eigentlich alles, was über die mihome-App einzustellen ist auch über entsprechende Datenpunkte steuern.
                              TottoT Offline
                              TottoT Offline
                              Totto
                              @Thomas-Braun Ok, dann wäre es für mich doch wieder interessant.
                              Gibst Du mir dann bitte kurz Bescheid, wenn Du zu Hause nachgeschaut hast, welchen Adapter ich für den Ventilator verwenden muss?
                              Danke! :)
                              • TottoT Totto
                                Danke! :)
                                @Totto Kann auch sein, dass du für diesen Adapter mal kurz auf den Verwahrort 'latest' wechseln musst. Möglich, dass der noch nicht bis 'default' vorgedrungen ist.
                                Nach der Installation aber dann wieder auf 'default' zurücksetzen und auch keine anderen Adapter währenddessen aktualisieren.
                                  TottoT Offline
                                  TottoT Offline
                                  Totto
                                  @Thomas-Braun Habe jetzt einen Adapter namens "Xiaomi miIO Protokollgerät" gefunden. Ist das der, den Du meinst?
                                  • TottoT Totto
                                    @Totto Ja, das ist der richtige.
                                      TottoT Offline
                                      TottoT Offline
                                      Totto
                                      @Thomas-Braun Ok, hab' den jetzt installiert. Allerdings komme ich jetzt mit der Einrichtung nicht weiter... :(
                                      Die automatische Suche findet nichts, jetzt hab' ich mal das hier konfiguriert:
                                      Auch das klappt erstmal nicht. Gehe ich recht in der Annahme, dass ich erstmal diesen komplizierten Weg über die manuell zu installierende Android App gehen muss, um den Token des Ventilators auszulesen, um diesen dann bei "Zeichen" einzutragen?
                                      Die Doku zu dem Adapter ist leider noch etwas dürftig...
                                      • TottoT Totto
                                        @Totto Entweder so oder du installierst noch den Adapter für den Staubsauger, der kann nämlich die Token auslesen.
                                          TottoT Offline
                                          TottoT Offline
                                          Totto
                                          @Thomas-Braun Oh, das hört sich gut an. :)
                                          Ist das dann der Asapter "mihome-vacuum [iobroker-community-adapters]"?
