  4. [Gelöst] Max-Werte speichern
38 Beiträge 4 Kommentatoren 5.4k Aufrufe 1 Beobachtet
  • NegaleinN Negalein
    @paul53 sagte in [Gelöst] Max-Werte speichern:
    Das liegt sicher nicht am Script. Da ist etwas anderes faul ?
    hab gerade noch das im Log entdeckt.
    javascript.0	2020-08-17 12:05:02.073	warn	(597) at process.topLevelDomainCallback (domain.js:126:23)
    javascript.0	2020-08-17 12:05:02.072	warn	(597) at processImmediate (timers.js:658:5)
    javascript.0	2020-08-17 12:05:02.072	warn	(597) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-08-17 12:05:02.072	warn	(597) at runCallback (timers.js:705:18)
    javascript.0	2020-08-17 12:05:02.072	warn	(597) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.0	2020-08-17 12:05:02.072	warn	(597) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:457:25)
    javascript.0	2020-08-17 12:05:02.072	warn	(597) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1042:38)
    javascript.0	2020-08-17 12:05:02.072	warn	(597) at Object.<anonymous> (script.js.Steckdosen.Strom:27:7)
    javascript.0	2020-08-17 12:05:02.071	warn	(597) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1345:20)
    javascript.0	2020-08-17 12:05:02.070	warn	(597) You are assigning a string to the state "javascript.0.Strom.Max" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an err
    javascript.0	2020-08-17 12:05:00.717	warn	(597) at process.topLevelDomainCallback (domain.js:126:23)
    javascript.0	2020-08-17 12:05:00.713	warn	(597) at processImmediate (timers.js:658:5)
    javascript.0	2020-08-17 12:05:00.713	warn	(597) at tryOnImmediate (timers.js:676:5)
    javascript.0	2020-08-17 12:05:00.713	warn	(597) at runCallback (timers.js:705:18)
    javascript.0	2020-08-17 12:05:00.712	warn	(597) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.0	2020-08-17 12:05:00.712	warn	(597) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:457:25)
    javascript.0	2020-08-17 12:05:00.712	warn	(597) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1042:38)
    javascript.0	2020-08-17 12:05:00.712	warn	(597) at Object.<anonymous> (script.js.Steckdosen.Strom:27:7)
    javascript.0	2020-08-17 12:05:00.712	warn	(597) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1345:20)
    javascript.0	2020-08-17 12:05:00.707	warn	(597) You are assigning a string to the state "javascript.0.Strom.Max" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an err
    Vielleicht hilft das?
    Soll ich javascript.0.Strom.Maxauf String ändern?
    @Negalein sagte:
    Nein, dann funktioniert die Max-Ermittlung nicht. Liefert der Datenpunkt 'sourceanalytix.0.javascript__0__Volkszaehler__AKTUELLER_VERBRAUCH.consumption.01_current_day' keine Zahl ? Dann muss der Wert aus dem Datenpunkt jedesmal mit parseFloat() in eine Zahl gewandelt werden.
    var max = parseFloat(getState(idWind).val);
    if(existsState('javascript.' + instance + '.' + idMax)) max = getState(idMax).val;
    else createState(idMax, max, {
    und
    on(idWind, function(dp) {
       if(parseFloat(dp.state.val) > max) {
          max = parseFloat(dp.state.val);
          setState(idMax, max, true);
    NegaleinN 2 Antworten Letzte Antwort
      @Negalein sagte:
      und
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      Ist als Zahl
        "from": "system.adapter.sourceanalytix.0",
        "user": "system.user.admin",
        "ts": 1597148627809,
        "common": {
          "name": "current Day ",
          "type": "number",
          "role": "value.week",
          "unit": "kWh",
          "def": 0,
          "read": true
        "native": {},
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "state": 1636
        "_id": "sourceanalytix.0.javascript__0__Volkszaehler__AKTUELLER_VERBRAUCH.consumption.01_current_day",
        "type": "state"
      ° Fixer ---> iob fix
        Ist als Zahl
          "common": {
            "type": "number",
            "unit": "kWh",
            "def": 0,
            "read": true
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "type": "state"
        @Negalein sagte:
        Ist als Zahl
        Wenn common.type = "number" steht, bedeutet es leider nicht, dass auch wirklich eine Zahl enthalten ist.
          @Negalein sagte:
          Ist als Zahl
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          Ok, wie kann ich prüfen, ob es tatsächlich eine Zahl ist?
            @Negalein sagte:
            Was ergibt zusätzlich als Zeile 7 ?
            log(typeof max);
              @Negalein sagte:
              log(typeof max);
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              javascript.0	2020-08-17 12:24:08.050	warn	(597) at process.topLevelDomainCallback (domain.js:126:23)
              javascript.0	2020-08-17 12:24:08.050	warn	(597) at processImmediate (timers.js:658:5)
              javascript.0	2020-08-17 12:24:08.050	warn	(597) at tryOnImmediate (timers.js:676:5)
              javascript.0	2020-08-17 12:24:08.050	warn	(597) at runCallback (timers.js:705:18)
              javascript.0	2020-08-17 12:24:08.050	warn	(597) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
              javascript.0	2020-08-17 12:24:08.049	warn	(597) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:457:25)
              javascript.0	2020-08-17 12:24:08.049	warn	(597) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1042:38)
              javascript.0	2020-08-17 12:24:08.049	warn	(597) at Object.<anonymous> (script.js.Steckdosen.Strom:28:7)
              javascript.0	2020-08-17 12:24:08.049	warn	(597) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1345:20)
              javascript.0	2020-08-17 12:24:08.048	warn	(597) You are assigning a string to the state "javascript.0.Strom.Max" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an err
                @Negalein
                Der Info-Log von Zeile 7 ist nicht dabei. Er muss gleich als erstes nach Skriptstart erscheinen.
                  @Negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  javascript.0	2020-08-17 12:31:28.240	warn	(597) at process.topLevelDomainCallback (domain.js:126:23)
                  javascript.0	2020-08-17 12:31:28.240	warn	(597) at processImmediate (timers.js:658:5)
                  javascript.0	2020-08-17 12:31:28.240	warn	(597) at tryOnImmediate (timers.js:676:5)
                  javascript.0	2020-08-17 12:31:28.240	warn	(597) at runCallback (timers.js:705:18)
                  javascript.0	2020-08-17 12:31:28.240	warn	(597) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                  javascript.0	2020-08-17 12:31:28.240	warn	(597) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:457:25)
                  javascript.0	2020-08-17 12:31:28.240	warn	(597) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1042:38)
                  javascript.0	2020-08-17 12:31:28.239	warn	(597) at Object.<anonymous> (script.js.Steckdosen.Strom:28:7)
                  javascript.0	2020-08-17 12:31:28.239	warn	(597) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1345:20)
                  javascript.0	2020-08-17 12:31:28.237	warn	(597) You are assigning a string to the state "javascript.0.Strom.Max" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an err
                  javascript.0	2020-08-17 12:31:22.851	info	(597) script.js.Steckdosen.Strom: registered 1 subscription and 1 schedule
                  javascript.0	2020-08-17 12:31:22.839	info	(597) script.js.Steckdosen.Strom: string
                  javascript.0	2020-08-17 12:31:22.830	info	(597) Start javascript script.js.Steckdosen.Strom
                  Lt. Log ist es ein String
                    @Negalein sagte:
                    und
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    Ich glaub, das hab ich falsch eingetragen.
                    const idWind = 'sourceanalytix.0.javascript__0__Volkszaehler__AKTUELLER_VERBRAUCH.consumption.01_current_day'; // Datenpunkt-ID Windgeschwindigkeit https://forum.iobroker.net/viewtopic.php?t=13149
                    const idMax = 'Strom.Max';
                    const days = ['So','Mo','Di','Mi','Do','Fr','Sa'];
                    const maxDay = 'Strom.Tagesmaximum_';
                       type: 'number',
                       unit: 'Watt',
                       min: 0
                    for(var i = 0; i < 7; i++) {
                       var idMaxDay = maxDay + days[i];
                       createState(idMaxDay, max, {
                          type: 'number',
                          unit: 'Watt',
                          min: 0
                    schedule('59 23 * * *', function() { // täglich 1 Minute vor Mitternacht
                       var wd = new Date().getDay();
                       var idMaxDay = maxDay + days[wd];
                       setState(idMaxDay, max, true);
                       max = getState(idWind).val;
                    javascript.0	2020-08-17 12:45:32.344	error	(597) at process._tickCallback (internal/process/next_tick.js:68:7)
                    javascript.0	2020-08-17 12:45:32.344	error	(597) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    javascript.0	2020-08-17 12:45:32.344	error	(597) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    javascript.0	2020-08-17 12:45:32.344	error	(597) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
                    javascript.0	2020-08-17 12:45:32.343	error	(597) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1124:17)
                    javascript.0	2020-08-17 12:45:32.343	error	(597) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1533:17)
                    javascript.0	2020-08-17 12:45:32.343	error	(597) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1480:37)
                    javascript.0	2020-08-17 12:45:32.343	error	(597) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1257:28)
                    javascript.0	2020-08-17 12:45:32.343	error	(597) at Object.createScript (vm.js:277:10)
                    javascript.0	2020-08-17 12:45:32.342	error	(597) at new Script (vm.js:83:7)
                    javascript.0	2020-08-17 12:45:32.342	error	(597) SyntaxError: Unexpected string
                    javascript.0	2020-08-17 12:45:32.342	error	(597) ^^^^^^^^
                    javascript.0	2020-08-17 12:45:32.341	error	(597) type: 'number',
                    javascript.0	2020-08-17 12:45:32.340	error	at script.js.Steckdosen.Strom:11
                    javascript.0	2020-08-17 12:45:32.340	error	(597) script.js.Steckdosen.Strom compile failed:
                    javascript.0	2020-08-17 12:45:32.333	info	(597) Start javascript script.js.Steckdosen.Strom
                         type: 'number',
                         unit: 'Watt',
                         min: 0
                            type: 'number',
                            unit: 'Watt',
                            min: 0
                      @Negalein sagte:
                      Ja.
                         type: 'number',
                         unit: 'Watt',
                         min: 0
                            type: 'number',
                            unit: 'Watt',
                            min: 0
                        @Negalein sagte:
                        Ja.
                           type: 'number',
                           unit: 'Watt',
                           min: 0
                              type: 'number',
                              unit: 'Watt',
                              min: 0
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        Ja.
                        Schaut gut aus!
                        Bekommst ein 🍺 😁
                          Ja.
                          Schaut gut aus!
                          Bekommst ein 🍺 😁
                          @Negalein sagte:
                          Schaut gut aus!
                          Noch nicht ganz: In Zeile 34 fehlt noch ein parseFloat().
                          NegaleinN Basti97B 2 Antworten Letzte Antwort
                            @Negalein sagte:
                            Schaut gut aus!
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            läuft
                              @al-79:
                              Kann da jemand nen kleines Script schreiben? `
                              const idWind = '...'; // Datenpunkt-ID Windgeschwindigkeit
                              const idMax = 'Wind.Max_Geschwindigkeit';
                              const idMaxWoche = 'Wind.Wochenmaximum';
                              var max = getState(idWind).val;
                              if(getObject('javascript.' + instance + '.' + idMax)) max = getState(idMax).val;
                                 type: 'number',
                                 unit: 'km/h',
                                 min: 0
                              createState(idMaxWoche, max, {
                                 type: 'number',
                                 unit: 'km/h',
                                 min: 0
                                 if(dp.state.val > max) {
                                    max = dp.state.val;
                              schedule('0 0 * * 0', function() { // Sonntags um Mitternacht
                                 setState(idMaxWoche, max, true);
                              Basti97B Offline
                              Basti97B Offline
                              Basti97
                              schrieb am zuletzt editiert von Basti97
                              @paul53 Ich bin gerade auf deinem Script gestoßen und habe es abgeändert für meine Temperatur. Würde es so funktionieren. Bis jetzt werden mir noch keine Fehler angezeigt.
                              Zur besseren Verständnis der Datenpunkt
                              "idmax" wird immer aktualisiert wenn der vorherige Wert höher ist.
                              und der "idmaxWoche" auch aber dieser wird nur 1 mal pro Woche zurückgesetzt.
                              const idTemperatur = 'ds18b20.0.sensors.28-3c01e076ac31'/*Temperatur Aquarium*/ // Datenpunkt-ID Temperatur
                              const idMax = 'Temperatur.Max_Temperatur';
                              const idMaxWoche = 'Temperatur.Wochenmaximum';
                              var max = getState(idTemperatur).val;
                                 type: 'number',
                                 unit: '°C',
                                 min: 0
                                 type: 'number',
                                 unit: '°C',
                                 min: 0
                              on(idTemperatur, function(dp) {
                                    max = dp.state.val;
                              Wie müsste es jetzt aussehen wenn ich mit den Script auch den Minimalen Wert ermitteln möchte. Müsste ich dann einfach anstatt max nur min schreiben. Und bei Zeile 20 das "Zeichen drehen".
                              Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                                @Negalein sagte:
                                Schaut gut aus!
                                Basti97B Offline
                                Basti97B Offline
                                Basti97
                                @paul53 Ich habe mich mal an den min Wert herangetraut ist es so weit richtig wie ich es gemacht habe.
                                const idMin = 'Temperatur.Min_Temperatur';
                                const idMinWoche = 'Temperatur.Wochenminimum';
                                var min = getState(idTemperatur).val;
                                if(getObject('javascript.' + instance + '.' + idMin)) min = getState(idMin).val;
                                createState(idMin, min, { //Temperatur minimal
                                   type: 'number',
                                   unit: '°C',
                                   min: 0
                                createState(idMinWoche, min, { //Temperatur Woche minimal
                                   type: 'number',
                                   unit: '°C',
                                   min: 0
                                   if(dp.state.val < min) {
                                      min = dp.state.val;
                                      setState(idMin, min, true);
                                   setState(idMinWoche, min, true);
                                PS Fehler sind bis jetzt keine gekommen und es werden schon mal Werte angezeigt. :)
                                • Basti97B Basti97
                                     type: 'number',
                                     unit: '°C',
                                     min: 0
                                     type: 'number',
                                     unit: '°C',
                                     min: 0
                                        max = dp.state.val;
                                  @basti97 sagte: "idmax" wird immer aktualisiert wenn der vorherige Wert höher ist.
                                  "idMaxWoche" wird nur einmal in der Woche geschrieben und "idMax" wird einmal in der Woche zurück gesetzt.
                                  Man kann Maximum und Minimum in einem Skript ermitteln.
                                  var temp = getState(idTemperatur).val;
                                  var min = temp;
                                  var max = temp;
                                  if(existsState(idMin)) min = getState(idMin).val;
                                  else {
                                          type: 'number',
                                          unit: '°C',
                                          min: 0
                                          name: 'Temperatur Wochenminimum',
                                          type: 'number',
                                          unit: '°C',
                                          min: 0
                                  if(existsState(idMax)) max = getState(idMax).val;
                                  else {
                                      createState(idMax, max, { //Temperatur minimal
                                          type: 'number',
                                          unit: '°C',
                                          min: 0
                                      createState(idMaxWoche, max, { //Temperatur Woche minimal
                                          name: 'Temperatur Wochenmaximum',
                                          type: 'number',
                                          unit: '°C',
                                          min: 0
                                      temp = dp.state.val;
                                      if(temp < min) {
                                          min = temp;
                                      if(temp > max) {
                                          max = temp;
                                     min = temp;
                                     max = temp;
                                  Basti97B 3 Antworten Letzte Antwort
                                    var min = temp;
                                    var max = temp;
                                    else {
                                            type: 'number',
                                            unit: '°C',
                                            min: 0
                                            type: 'number',
                                            unit: '°C',
                                            min: 0
                                    else {
                                            type: 'number',
                                            unit: '°C',
                                            min: 0
                                            type: 'number',
                                            unit: '°C',
                                            min: 0
                                        if(temp < min) {
                                            min = temp;
                                        if(temp > max) {
                                            max = temp;
                                       min = temp;
                                       max = temp;
                                    Basti97B Offline
                                    Basti97B Offline
                                    Basti97
                                    @paul53 Super vielen Dank das funktioniert. :) :)Wusste gar nicht das man es auch in einem Schript machen kann. Naja wieder was dazu gelernt.
                                    Ich glaube ich muss auch mal mich in die Javascripte mich herein fuchsen dadurch kann man mehr programmieren als mit Blockly oderso.
                                    Ich wünsche dir eine schöne Ostern.😀
                                      var min = temp;
                                      var max = temp;
                                      else {
                                              type: 'number',
                                              unit: '°C',
                                              min: 0
                                              type: 'number',
                                              unit: '°C',
                                              min: 0
                                      else {
                                              type: 'number',
                                              unit: '°C',
                                              min: 0
                                              type: 'number',
                                              unit: '°C',
                                              min: 0
                                          if(temp < min) {
                                              min = temp;
                                          if(temp > max) {
                                              max = temp;
                                         min = temp;
                                         max = temp;
                                      Basti97B Offline
                                      Basti97B Offline
                                      Basti97
                                      @paul53 Ich habe noch mal eine Frage der idmax und idmin wird nachts bzw 00:00 nicht zurück gesetzt bzw auf die aktuelle Temperatur angepasst oder?
                                        var min = temp;
                                        var max = temp;
                                        else {
                                                type: 'number',
                                                unit: '°C',
                                                min: 0
                                                type: 'number',
                                                unit: '°C',
                                                min: 0
                                        else {
                                                type: 'number',
                                                unit: '°C',
                                                min: 0
                                                type: 'number',
                                                unit: '°C',
                                                min: 0
                                            if(temp < min) {
                                                min = temp;
                                            if(temp > max) {
                                                max = temp;
                                           min = temp;
                                           max = temp;
                                        Basti97B Offline
                                        Basti97B Offline
                                        Basti97
                                        Diese Zeile habe ich noch eingefügt das er 00:01 Uhr die max und min Werte gleich macht. Das funktioniert auch :) Das war meine ersten Zeilen in Java S. Ich glaube ich muss mich noch mehr einlesen. )
                                        schedule("01 00 * * *", function () { //Uhrzeit 00:01 Uhr
                                          setState("javascript.0.Temperatur.Min_Temperatur"/*Temperatur.Min_Temperatur*/, getState("ds18b20.0.sensors.28-3c01e076ac31").val);
                                          setState("javascript.0.Temperatur.Max_Temperatur"/*Temperatur.Max_Temperatur*/, getState("ds18b20.0.sensors.28-3c01e076ac31").val);
