  4. (Gelöst, wechsel auf Debian)Neuinstallation schlägt fehl
einrichtungsfehler 404 lizenz
140 Beiträge 6 Kommentatoren 9.4k Aufrufe 4 Beobachtet
    Habe mal folgendes gemacht, da in der Anleitung gefunden:
    georg@nucserver:/opt/iobroker$ node node_modules/iobroker.js-controller/controller.js --logs
    2020-08-14 12:23:29.556 - info: host.nucserver iobroker.js-controller version 3.1.6 js-controller starting
    2020-08-14 12:23:29.562 - info: host.nucserver Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2020-08-14 12:23:29.562 - info: host.nucserver hostname: nucserver, node: v12.18.3
    2020-08-14 12:23:29.564 - info: host.nucserver ip addresses: 192.168.178.57 2003:d1:370f:3d00:f64d:30ff:fe6b:9621 fe80::f6 4d:30ff:fe6b:9621
    2020-08-14 12:23:30.731 - info: host.nucserver Error inMem-objects listening on port 9001
    2020-08-14 12:23:31.435 - info: host.nucserver Error inMem-states listening on port 9000
    2020-08-14 12:23:31.603 - info: host.nucserver connected to Objects and States
    2020-08-14 12:23:33.590 - info: host.nucserver 13 instances found
    host.nucserver check instance "system.adapter.admin.0" for host "nucserver"
    host.nucserver check instance "system.adapter.discovery.0" for host "nucserver"
    host.nucserver check instance "system.adapter.info.0" for host "nucserver"
    host.nucserver check instance "system.adapter.tr-064.0" for host "nucserver"
    host.nucserver check instance "system.adapter.tr-064.1" for host "nucserver"
    host.nucserver check instance "system.adapter.tr-064.2" for host "nucserver"
    host.nucserver check instance "system.adapter.ping.0" for host "nucserver"
    host.nucserver check instance "system.adapter.fritzdect.0" for host "nucserver"
    host.nucserver check instance "system.adapter.mpd.0" for host "nucserver"
    host.nucserver check instance "system.adapter.squeezebox.0" for host "nucserver"
    host.nucserver check instance "system.adapter.squeezeboxrpc.0" for host "nucserver"
    host.nucserver check instance "system.adapter.emby.0" for host "nucserver"
    host.nucserver check instance "system.adapter.web.0" for host "nucserver"
    2020-08-14 12:23:33.615 - info: host.nucserver starting 13 instances
    2020-08-14 12:23:33.776 - info: host.nucserver instance system.adapter.admin.0 started with pid 2390
    2020-08-14 12:23:38.289 - info: host.nucserver instance system.adapter.discovery.0 started with pid 2418
    2020-08-14 12:23:41.731 - info: host.nucserver instance system.adapter.info.0 started with pid 2429
    2020-08-14 12:23:45.731 - info: host.nucserver instance system.adapter.tr-064.0 started with pid 2448
    2020-08-14 12:23:49.733 - info: host.nucserver instance system.adapter.tr-064.1 started with pid 2459
    2020-08-14 12:23:53.729 - info: host.nucserver instance system.adapter.tr-064.2 started with pid 2470
    2020-08-14 12:23:57.730 - info: host.nucserver instance system.adapter.ping.0 started with pid 2481
    2020-08-14 12:24:02.523 - info: host.nucserver instance system.adapter.fritzdect.0 started with pid 2492
    2020-08-14 12:24:05.635 - info: host.nucserver instance system.adapter.mpd.0 started with pid 2503
    2020-08-14 12:24:09.633 - info: host.nucserver instance system.adapter.squeezebox.0 started with pid 2514
    2020-08-14 12:24:13.747 - info: host.nucserver instance system.adapter.squeezeboxrpc.0 started with pid 2525
    2020-08-14 12:24:17.631 - info: host.nucserver instance system.adapter.emby.0 started with pid 2536
    2020-08-14 12:24:21.764 - info: host.nucserver instance system.adapter.web.0 started with pid 2547
    ^C2020-08-14 12:24:43.932 - info: host.nucserver received SIGINT
    2020-08-14 12:24:43.935 - info: host.nucserver stopInstance system.adapter.admin.0 (force=false, process=true)
    2020-08-14 12:24:43.935 - info: host.nucserver stopInstance system.adapter.discovery.0 (force=false, process=true)
    2020-08-14 12:24:43.936 - info: host.nucserver stopInstance system.adapter.info.0 (force=false, process=true)
    2020-08-14 12:24:43.937 - info: host.nucserver stopInstance system.adapter.tr-064.0 (force=false, process=true)
    2020-08-14 12:24:43.937 - info: host.nucserver stopInstance system.adapter.tr-064.1 (force=false, process=true)
    2020-08-14 12:24:43.938 - info: host.nucserver stopInstance system.adapter.tr-064.2 (force=false, process=true)
    2020-08-14 12:24:43.938 - info: host.nucserver stopInstance system.adapter.ping.0 (force=false, process=true)
    2020-08-14 12:24:43.939 - info: host.nucserver stopInstance system.adapter.fritzdect.0 (force=false, process=true)
    2020-08-14 12:24:43.939 - info: host.nucserver stopInstance system.adapter.mpd.0 (force=false, process=true)
    2020-08-14 12:24:43.940 - info: host.nucserver stopInstance system.adapter.squeezebox.0 (force=false, process=true)
    2020-08-14 12:24:43.940 - info: host.nucserver stopInstance system.adapter.squeezeboxrpc.0 (force=false, process=true)
    2020-08-14 12:24:43.941 - info: host.nucserver stopInstance system.adapter.emby.0 (force=false, process=true)
    2020-08-14 12:24:43.941 - info: host.nucserver stopInstance system.adapter.web.0 (force=false, process=true)
    2020-08-14 12:24:43.943 - info: host.nucserver stopInstance system.adapter.admin.0 send kill signal
    2020-08-14 12:24:43.944 - info: host.nucserver stopInstance system.adapter.discovery.0 send kill signal
    2020-08-14 12:24:43.945 - info: host.nucserver stopInstance system.adapter.info.0 send kill signal
    2020-08-14 12:24:43.946 - info: host.nucserver stopInstance system.adapter.tr-064.0 send kill signal
    2020-08-14 12:24:43.947 - info: host.nucserver stopInstance system.adapter.tr-064.1 send kill signal
    2020-08-14 12:24:43.947 - info: host.nucserver stopInstance system.adapter.tr-064.2 send kill signal
    2020-08-14 12:24:43.949 - info: host.nucserver stopInstance system.adapter.ping.0 send kill signal
    2020-08-14 12:24:43.950 - info: host.nucserver stopInstance system.adapter.fritzdect.0 send kill signal
    2020-08-14 12:24:43.951 - info: host.nucserver stopInstance system.adapter.mpd.0 send kill signal
    2020-08-14 12:24:43.951 - info: host.nucserver stopInstance system.adapter.squeezebox.0 send kill signal
    2020-08-14 12:24:43.952 - info: host.nucserver stopInstance system.adapter.squeezeboxrpc.0 send kill signal
    2020-08-14 12:24:43.953 - info: host.nucserver stopInstance system.adapter.emby.0 send kill signal
    2020-08-14 12:24:43.954 - info: host.nucserver stopInstance system.adapter.web.0 send kill signal
    2020-08-14 12:24:44.944 - info: host.nucserver stopInstance system.adapter.admin.0 killing pid 2390
    2020-08-14 12:24:44.946 - info: host.nucserver stopInstance system.adapter.discovery.0 killing pid 2418
    2020-08-14 12:24:44.947 - info: host.nucserver stopInstance system.adapter.info.0 killing pid 2429
    2020-08-14 12:24:44.948 - info: host.nucserver stopInstance system.adapter.tr-064.0 killing pid 2448
    2020-08-14 12:24:44.949 - info: host.nucserver stopInstance system.adapter.tr-064.1 killing pid 2459
    2020-08-14 12:24:44.950 - info: host.nucserver stopInstance system.adapter.tr-064.2 killing pid 2470
    2020-08-14 12:24:44.950 - info: host.nucserver stopInstance system.adapter.ping.0 killing pid 2481
    2020-08-14 12:24:44.951 - info: host.nucserver stopInstance system.adapter.fritzdect.0 killing pid 2492
    2020-08-14 12:24:44.952 - info: host.nucserver stopInstance system.adapter.mpd.0 killing pid 2503
    2020-08-14 12:24:44.953 - info: host.nucserver stopInstance system.adapter.squeezebox.0 killing pid 2514
    2020-08-14 12:24:44.954 - info: host.nucserver stopInstance system.adapter.squeezeboxrpc.0 killing pid 2525
    2020-08-14 12:24:44.955 - info: host.nucserver stopInstance system.adapter.emby.0 killing pid 2536
    2020-08-14 12:24:44.956 - info: host.nucserver stopInstance system.adapter.web.0 killing pid 2547
    2020-08-14 12:24:58.945 - info: host.nucserver force terminating
    Die Startseite ist nicht erreichbar, sehe wieder nur den Dauerlaufbalken.
    HomoranH Offline
    HomoranH Offline
    @Boogie2005 sagte in Neuinstallation schlägt fehl auf Ubuntu 20.04 LTS Server:
    Wo kommt das Strg-C her?
    Das ergibt dann
      Das ergibt dann
      @Homoran kannst du das für nicht Spezis übersetzen? Ich selbst mache nichts?
        @Boogie2005 Habe den Text aus Putty kopiert, kann es das sein?
          @Boogie2005
          Das Tastaturkürzel Strg-C beendet in Linux einen in der Konsole laufenden Prozess.
          Vermutlich hast du da in PuTTY versucht irgendwas zu kopieren?
          Lass den Installer einfach durchlaufen, das dauert ggf.
          Fehlende Adapter dann manuell nachinstallieren, die automatische Erkennung ist etwas 'unrund', je nachdem.
            @Boogie2005
            @Thomas-Braun Ich mach jetzt Pause, IoB will nicht starten, sehe noch immer nur blauen Laufbalken für Ladevorgang....
              @Boogie2005 Ich würde ja mal in das Log schauen:
              tail -f /opt/iobroker/log/iobroker.current.log
                @Thomas-Braun Habe noch mal kurz gemacht. Startet, ab dem Kurser unten passiert nichts mehr.
                  @Boogie2005 Ganz ehrlich: Keine Lust in Screenshot zu schauen. Viel Erfolg noch!
                    @Thomas-Braun Dann erklär mir mal, wie ich es anders machen soll? Keine Ahnung, wie ich aus Putty die Meldung noch kopieren kann? Finde ich jetzt nicht fair.
                    ? HomoranH 2 Antworten Letzte Antwort
                      Habs jetzt mal mit der Maus versucht:
                      georg@nucserver:~$ tail -f /opt/iobroker/log/iobroker.current.log
                      2020-08-14 13:36:15.426  - debug: squeezeboxrpc.0 (2210) States create System PubSub Client
                      2020-08-14 13:36:15.930  - debug: squeezeboxrpc.0 (2210) States connected to redis: 127.0.0.1:9000
                      2020-08-14 13:36:15.931  - debug: squeezeboxrpc.0 (2210) statesDB connected
                      2020-08-14 13:36:18.963  - info: squeezeboxrpc.0 (2210) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.squeezeboxrpc, node: v1            2.18.3, js-controller: 3.1.6
                      2020-08-14 13:37:45.858  - **error**: fritzdect.0 (674) fritzbox returned this {"error":{"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddr            info","hostname":"192.x.x.x"},"options":{"url":"http://192.x.x.x/login_sid.lua"}}
                      2020-08-14 13:37:45.859  - **error**: fritzdect.0 (674) no response part in returned message
                      2020-08-14 13:37:45.860  - **error**: fritzdect.0 (674) fritzbox returned this {"error":{"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddr            info","hostname":"192.x.x.x"},"options":{"url":"http://192.x.x.x/login_sid.lua"}}
                      2020-08-14 13:37:45.861  - **error:** fritzdect.0 (674) no response part in returned message
                      2020-08-14 13:37:45.863  - **error**: fritzdect.0 (674) fritzbox returned this {"error":{"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddr            info","hostname":"192.x.x.x"},"options":{"url":"http://192.x.x.x/login_sid.lua"}}
                      2020-08-14 13:37:45.864  - error: fritzdect.0 (674) no response part in returned message
                      Mod-Edit: Code in code-tags gesetzt!
                        HomoranH Offline
                        HomoranH Offline
                        einfach markieren!
                        Mehr nicht!
                          einfach markieren!
                          Mehr nicht!
                          @Homoran
                          Ist ja nicht so, dass ich nicht alles versuche selbst zu lösen, aber hier bin ich überfordert, ganz einfach.
                          Ich habe hier diese Seite gefunden: https://www.iobroker.net/docu/index-26.htm#Pruefen_ob_js-controller_laeuft
                          Danach eben jetzt auch mal das gemacht:
                          georg@nucserver:/opt/iobroker$ iobroker list instances
                            system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            system.adapter.discovery.0             : discovery             -  enabled
                            system.adapter.emby.0                  : emby                  -  enabled
                            system.adapter.fritzdect.0             : fritzdect             -  enabled
                            system.adapter.info.0                  : info                  -  enabled
                            system.adapter.mpd.0                   : mpd                   -  enabled, port: 6600
                            system.adapter.ping.0                  : ping                  -  enabled
                            system.adapter.squeezebox.0            : squeezebox            -  enabled, port: 9090
                            system.adapter.squeezeboxrpc.0         : squeezeboxrpc         -  enabled, port: 9000
                            system.adapter.tr-064.0                : tr-064                -  enabled
                            system.adapter.tr-064.1                : tr-064                -  enabled
                            system.adapter.tr-064.2                : tr-064                -  enabled
                            system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + instance is alive
                          Trotzdem kann ich die Webseite von IoBroker nicht erreichen, will nicht wieder ein Screen machen, gibt Ärger ;-)
                            @Homoran
                            + instance is alive
                            HomoranH Offline
                            HomoranH Offline
                            Wo?
                            Hier wäre es richtig
                            https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
                            In deinem Fall sieht es aber aus, als ob die Installation mittendrin abgebrochen worden wäre.
                            Wenn nicht, mach mal iobroker start
                              Wo?
                              @Homoran ok danke für den Link!
                              Falls interessant, auf der anderen Seite sah ich den Befehl hier:
                              cat log/iobroker.2020-08-14.log
                              Das ergibt ein große Logdatei mit vielen Meldungen. Soll ich die mal anhängen als txt Datei?
                                @Boogie2005 Das bleibt irgendwann stehen, zumindest wird nichts weiter mehr angezeigt. ```
                                georg@nucserver:~$ cd /opt/iobroker
                                georg@nucserver:/opt/iobroker$ node node_modules/iobroker.js-controller/controll        er.js --logs
                                2020-08-14 13:57:00.228  - info: host.nucserver iobroker.js-controller version 3        .1.6 js-controller starting
                                2020-08-14 13:57:00.234  - info: host.nucserver Copyright (c) 2014-2020 bluefox,        2014 hobbyquaker
                                2020-08-14 13:57:00.234  - info: host.nucserver hostname: nucserver, node: v12.1        8.3
                                2020-08-14 13:57:00.236  - info: host.nucserver ip addresses: 192.168.178.57 200        3:d1:370f:3d00:f64d:30ff:fe6b:9621 fe80::f64d:30ff:fe6b:9621
                                2020-08-14 13:57:00.350  - info: host.nucserver  Error inMem-objects listening o        n port 9001
                                2020-08-14 13:57:02.299  - info: host.nucserver  Error inMem-states listening on        port 9000
                                2020-08-14 13:57:02.658  - info: host.nucserver connected to Objects and States
                                2020-08-14 13:57:05.378  - info: host.nucserver 13 instances found
                                host.nucserver check instance "system.adapter.squeezeboxrpc.0" for host "nucserv        er"
                                2020-08-14 13:57:05.405  - info: host.nucserver starting 13 instances
                                2020-08-14 13:57:05.436  - info: host.nucserver instance system.adapter.admin.0        started with pid 2734
                                2020-08-14 13:57:09.425  - info: host.nucserver instance system.adapter.discover        y.0 started with pid 2745
                                2020-08-14 13:57:13.428  - info: host.nucserver instance system.adapter.info.0 started with pid 2756
                                2020-08-14 13:57:17.429  - info: host.nucserver instance system.adapter.tr-064.0 started with pid 2792
                                2020-08-14 13:57:21.424  - info: host.nucserver instance system.adapter.tr-064.1 started with pid 2803
                                2020-08-14 13:57:25.424  - info: host.nucserver instance system.adapter.tr-064.2 started with pid 2814
                                2020-08-14 13:57:29.423  - info: host.nucserver instance system.adapter.ping.0 started with pid 2825
                                2020-08-14 13:57:35.419  - info: host.nucserver instance system.adapter.fritzdect.0 started with pid 2836
                                2020-08-14 13:57:37.423  - info: host.nucserver instance system.adapter.mpd.0 started with pid 2847
                                2020-08-14 13:57:41.423  - info: host.nucserver instance system.adapter.squeezebox.0 started with pid 2858
                                2020-08-14 13:57:45.424  - info: host.nucserver instance system.adapter.squeezeboxrpc.0 started with pid 2869
                                2020-08-14 13:57:49.423  - info: host.nucserver instance system.adapter.emby.0 started with pid 2880
                                2020-08-14 13:57:53.424  - info: host.nucserver instance system.adapter.web.0 started with pid 2891
                                  HomoranH Offline
                                  HomoranH Offline
                                  Was?
                                  Das hier?
                                  @Homoran sagte in Neuinstallation schlägt fehl auf Ubuntu 20.04 LTS Server:
                                    Was?
                                    Das hier?
                                    @Homoran IoBroker Start habe ich schon paar mal gemacht. Sogar den NUC neu gestartet. Kann ich den IOB mal ganz entfernen, um neu anzufangen?
                                      So, hatte die Nase voll von der Sucherrei. Habe Debian neu installiert. SSH läuft, User hat Sudo Rechte, Abfrage node/nodejs -v ergibt: Nicht vorhanden.
                                      Das nun beides installieren, und zwar Link Text danach, richtig hoffe ich.
                                        @Boogie2005 Nee, nur ein Paket namens 'nodejs' installieren. Steht aber auch so in der Anleitung.
                                          @Thomas-Braun OK, ist drauf, beide sind 12.8.3
                                          Jetzt hoffe ich so IoBroker installieren:
                                          curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
