[Neuer Adapter] Proxmox VM
Hallo in die Runde,
nachdem mein SATA-Controller vom NUC abgeraucht ist, hab ich mir das neue Proxmox auf ne SSD gemacht und an USB3 dran (war ne ganz schöne Aktion herauszufinden, dass der Controller hinüber ist :( )
Hab nun Proxmox 6.1 druff...und leider tuts der Adapter damit anscheinend (noch) nicht? Erhalte im Log folgende Fehler beim Start vom Adapter:host.ioBroker2 2020-03-28 23:48:49.277 info Restart adapter system.adapter.proxmox.0 because enabled host.ioBroker2 2020-03-28 23:48:49.276 info instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at IncomingMessage.emit (events.js:203:15) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at Object.onceWrapper (events.js:286:20) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at Request.emit (events.js:198:13) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at Request.emit (events.js:198:13) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.proxmox/lib/proxmox.js:167:21) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at _get.then.data (/opt/iobroker/node_modules/iobroker.proxmox/lib/proxmox.js:43:9) host.ioBroker2 2020-03-28 23:48:49.276 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.proxmox/main.js:342:27 host.ioBroker2 2020-03-28 23:48:49.275 error Caught by controller[0]: TypeError: Cannot read property 'uptime' of undefined proxmox.0 2020-03-28 23:48:48.755 info (9713) Terminated (NO_ERROR): Without reason proxmox.0 2020-03-28 23:48:48.753 info (9713) terminating proxmox.0 2020-03-28 23:48:48.746 info (9713) cleaned everything up... proxmox.0 2020-03-28 23:48:48.745 error (9713) TypeError: Cannot read property 'uptime' of undefined at /opt/iobroker/node_modules/iobroker.proxmox/main.js:342:27 at _get.then.data (/opt/iobroker/node_modules/iobroker.proxmox/lib/pr proxmox.0 2020-03-28 23:48:48.745 error (9713) uncaught exception: Cannot read property 'uptime' of undefined proxmox.0 2020-03-28 23:48:45.526 info (9713) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v10.16.0Jemand ne Idee?? Danke euch.
Viele Grüße, Thorsten@Kueppert den Fehler hab ich auch, issue ist erstellt...
@ilovegym Hi, meinst du deinen Eintrag an diesem Issue https://github.com/iobroker-community-adapters/ioBroker.proxmox/issues/54 ? Das Ticket ist ja bereits geschlossen. Ich weiß nicht ob der Entwickler (@Meistertr ) Tickets verfolgt, welcher bereits geschlossen sind.
Bei mir hab ich den Fehler noch nicht gesehen. Wie provozierst du den Fehler?
@Feuersturm gar nicht, er tritt alle stunde oder so auf.. dann läufts mal wieder.. hab leider keine Regelmässigkeit oder Abhängigkeit von irgendwas gefunden...
Die VMs sind alle immer online.. und die Node ist auch immer erreichbar.. -
hab nen neuen Issue aufgemacht: https://github.com/iobroker-community-adapters/ioBroker.proxmox/issues/56 -
Hallo, ist es irgendwie möglich bei der Konfiguration die IP Adresse von Proxmox mit https:// einzugeben?
Ich bekomme nur eine Fehlermeldung im Log:
Ohne https:// 404:Error: connect ECONNREFUSED 192.168.178.64:8006
mit https:// 404:Error: getaddrinfo ENOTFOUND https
Danke,David
Hat sich erledigt, Adapter erneut installiert. Läuft
@frana120500 sagte in [Neuer Adapter] Proxmox VM:
über den Adapter einen Shutdown Befehl senden für das komplette System
Ja
@FredF said in [Neuer Adapter] Proxmox VM:
Ja
Hi
ich denke ich hab das Problem mit dem Shutdown des Nodes über IOBroker gelöst. Hab einen PR #72 gestellt, vielleicht mag der eine oder andere mal einen Betatest mit meiner neuen Version der main.js und proxmox.js machen
T -
Ja
Hi
T@ThetaGamma was müsste ich denn machen, um deinen Pullrequest bei mir testen zu können?
@Feuersturm ich glaube die einfachste Variante wäre meinen Fork zu clonen
git clone https://github.com/ThetaGamma/ioBroker.proxmox.git)und dann in deinem iobroker-Verzeichnis im proxmox-Adapter (liegt bei mir unter /opt/iobroker/node_modules/iobroker.proxmox die Dateien "main.js" und "lib/proxmox.js" zu ersetzen (vorher ein Kopie der Original-Dateien irgendwo ablegen ;-) )
@ThetaGamma Danke für die Erklärung, ich werde heute Abend einmal versuchen deine neue Version auszuprobieren.
Ja
Hi
T@ThetaGamma
Habe deinen Fork über die Katze auf meinem Testsystem installiert.
Die Server Auswahl (PVE oder PAM) wird nicht gespeichert und einloggen geht nicht:2020-08-08 18:54:38.969 - info: host.ioBrokerNeu instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2020-08-08 18:54:41.470 - info: host.ioBrokerNeu instance system.adapter.proxmox.0 started with pid 26785 2020-08-08 18:54:41.709 - debug: proxmox.0 (26785) Redis Objects: Use Redis connection: 127.0.0.1:9001 2020-08-08 18:54:41.833 - debug: proxmox.0 (26785) Objects client ready ... initialize now 2020-08-08 18:54:41.834 - debug: proxmox.0 (26785) Objects create System PubSub Client 2020-08-08 18:54:41.835 - debug: proxmox.0 (26785) Objects create User PubSub Client 2020-08-08 18:54:41.835 - debug: proxmox.0 (26785) Objects client initialize lua scripts 2020-08-08 18:54:41.843 - debug: proxmox.0 (26785) Objects connected to redis: 127.0.0.1:9001 2020-08-08 18:54:41.846 - debug: proxmox.0 (26785) objectDB connected 2020-08-08 18:54:41.847 - debug: proxmox.0 (26785) Redis States: Use Redis connection: 127.0.0.1:9000 2020-08-08 18:54:41.849 - debug: proxmox.0 (26785) States create User PubSub Client 2020-08-08 18:54:41.850 - debug: proxmox.0 (26785) States create System PubSub Client 2020-08-08 18:54:41.852 - debug: proxmox.0 (26785) States connected to redis: 127.0.0.1:9000 2020-08-08 18:54:41.852 - debug: proxmox.0 (26785) statesDB connected 2020-08-08 18:54:41.891 - info: proxmox.0 (26785) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v12.18.2, js-controller: 3.1.6 2020-08-08 18:54:44.932 - error: proxmox.0 (26785) 401: wrong User data, could not log in, please try again with correct user and pwPasswort und Nutzer stimmen 100%tig
@ThetaGamma Ich hab wie du gesagt hast nur die beiden Dateien in meinem Dateisystem mit deinen Dateien ausgetauscht.
Ich kann einen Reboot und einen Shutdown vom Node pve durchführen.
Beim ersten reboot hatte ich den Fall, das proxmox nicht mehr erreichbar war. Hier half nur ein hartes ausschalten des Servers. Die einzelnen VMs wurden im Vorfeld durch den Reboot Prozess heruntergefahren.
Bei den nachfolgenden Reboots schien dann alles zu funktionieren. Ich werde nochmal ein paar weitere Reboots durchführen und schauen ob proxmox immer wieder startet.So wie ich das Verhalten bei mir beobachtet habe werden die aktiven VMs beendet, es wird ein Reboot durchgeführt aber es werden im Nachgang keine VMs gestartet. Ist das bei euch auch so?
@Feuersturm Du kannst im Proxmox der VM das Attribut "start on boot" setzen:
@ThetaGamma Perfekt. Funktioniert. Bisher gab es bei den ganzen Reboots über ioBroker bei mir keine Probleme (ich verwende Proxmox 6.1-7).
@ThetaGamma
@FredF Sorry, welche Katze?
Was auch immer deinen Fehler auslöst, kann ich Dir leider nicht sagen.
Meine Vorgehensweise: Ich habe in einem jungfräulichen IOBroker-Container einfach die "originale" proxmox installiert und dann auf der Kommandozeile im Verzeichnis mit einem "git clone" das alte überschrieben. da geht alles... -
@Feuersturm Vielen Dank für's Testen - der PR wurde übrigens angenommen
Damit dürfte es irgendwann auch offiziell verfügbar sein -
@Meistertr Gerade ist mir der Proxmox Adapter um die Ohren geflogen und ich bekomme keine Verbindung mehr hin (https://github.com/iobroker-community-adapters/ioBroker.proxmox/issues/82)
Habe auf meinem Testsystem js-controller 3.2.8 am laufen.Kennt jemand das Problem?
@feuersturm
Läuft hier bei mir mit js-controller 3.2.8, iobroker Proxmox Adapter 1.1.0 und Proxmox VE 6.3 zzt. fehlerfrei.
Gruß Marco -
@feuersturm
Gruß Marco@lonsimbt Lief bei mir heute auch unter js-controller 3.2.8 ohne Probleme bis ich auf die Idee kam das Interval in der Proxmox Instanz zu ändern. Ist bei dir in der Instanz Konfiguration das Feld "Server" gefüllt?
@feuersturm
Der Inhalt des Feldes wird bei mir auch nicht angezeigt, sondern "Please select the server". Einen Fehler erhalte ich nur, wenn ich dann die (für meine Installation) falsche Authentifizierungsmethode "pve" auswähle. Mit "pam" funktioniert alles.Gruß Marco
