  4. JavaScript
  5. E3DC Hauskraftwerk steuern
    1.0k
3.6k Beiträge 73 Kommentatoren 2.2m Aufrufe 64 Beobachtet
  • A ArnoD
    @smartboart sagte in E3DC Hauskraftwerk steuern:
    Hi Arno, hab folgenden Fehler im Log zu dem aktualisierten script...
    javascript.1	2020-07-21 14:35:40.670	warn	(1706) at processImmediate (internal/timers.js:456:21)
    javascript.1	2020-07-21 14:35:40.670	warn	(1706) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.1	2020-07-21 14:35:40.669	warn	(1706) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.1	2020-07-21 14:35:40.669	warn	(1706) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.1	2020-07-21 14:35:40.668	warn	(1706) at Object.<anonymous> (script.js.common.PVAnlage.E3DCS10EPro:1990:5)
    javascript.1	2020-07-21 14:35:40.668	warn	(1706) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    javascript.1	2020-07-21 14:35:40.666	warn	(1706) You are assigning a object to the state "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON" which expects a string. Please fix your code to use a string or change the state type to object
    javascript.1	2020-07-21 14:35:40.665	warn	(1706) at processImmediate (internal/timers.js:456:21)
    javascript.1	2020-07-21 14:35:40.665	warn	(1706) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.1	2020-07-21 14:35:40.664	warn	(1706) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.1	2020-07-21 14:35:40.663	warn	(1706) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.1	2020-07-21 14:35:40.662	warn	(1706) at Object.<anonymous> (script.js.common.PVAnlage.E3DCS10EPro:1988:22)
    javascript.1	2020-07-21 14:35:40.649	warn	(1706) getState "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON_17" not found (3)
    und
    1. getState "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON_17" not found (3)
    die objekte gehen auch nur bis 12 bei mir...
    Kann es sein das du im State, HistorySelect über VIS den Wert 17 eingetragen hast ?
    Habe gerade gesehen das ich hier einen falschen Wert größer 12 nicht abfange.
    smartboartS Offline
    smartboartS Offline
    smartboart
    schrieb am zuletzt editiert von smartboart
    #187
    @ArnoD hi , hoffe nicht...denke es war die 7...Kann esaber nicht mit gewissheit sagen..hatte alle states gelöscht und neu gestartet bevor du geantwortet hast...
    malne Frage zur Ausrichtungder panels und deinem hinweis im script...
    const nAzimuth2 = 52                            // Ausrichtung der Module (-180=north, -90=east, 0=south, 90=west, 180=north)
    laut solcast sieht das anders aus...
    • S stevie77
      @stevie77 sagte in E3DC Hauskraftwerk steuern:
      @ArnoD Achso, perfekt. Dann sollte sich ja heute Abend um 22 Uhr erstmals eine näherungsweise passende Summe in der Statistik abzeichnen.
      Das funktioniert! Danke Arno.
      Um die Schätzungen nun etwas vorsichtiger zu fahren, muss ich nun mit dem const nKorrFaktor = 1 spielen, ne? Also mal auf 0.8 stellen oder so damit die Schätzungen kleiner werden?!
      Das waren die realen Werte (ans Finanzamt würde ich Sourceanalytix-Werte nicht melden, knapp 5 kWh Ungenauigkeit an nur einem Tag/bei nur 60 erzeugten kWh):
      Dann gibt es da noch die Anzeige "PV-Leistung heute" in dem Kästchen auf der Seite mit den Schaltern, die momentan sourceanalytix.0.modbus__0__holdingRegisters__40068_PV_Leistung.delivery.01_current_day anzeigt. Wie wäre die beste Vorgehensweise um die beiden kumulierten Werte PV1 und PV2 den Tag über immer wieder aktualisieren zu lassen? Ein eigenes Skript, das mit on(sourceanalytix-Wert) beide Werte in nen eigenen State schreibt, oder? Für die Anzeige der aktuellen PV-Gesamtleistung mache ich so was mit den beiden Modbus-Werten, das müsste dann ja auch mit den Sourceanalytix-Werten gehen...
      stevie77
      #188
      @stevie77 Kann man in ioBroker eigentlich Funktionen aufrufen oder Werte aus Variablen auslesen, die in einem anderen Script erstellt wurden? Anwendungsfall wäre z.B. auf die Konfigurationsdaten in deinem Skript zuzugreifen um sie nicht selbst in nem eigenen Skript nochmals angeben zu müssen...
      • S stevie77
        ArnoD
        #189
        Es sind aktuell noch zwei Parameter mit denen man spielen kann.
        nWirkungsgradWR in Prozent
        nKorrFaktor in kWh
        Ich würde erst nWirkungsgradWR = 100 einstellen und nKorrFaktor = 0 um zu sehen wie gut die Prognose ohne Korrektur ist und dann rantasten.
        Stimmt habe ich übersehen, werde ich ändern und die Summe von PV1 und PV2 hier anzeigen.
        Ich werde auch das Diagramm bei Änderung der sourceanalytix-Werte aktualisieren so das man eine live Anzeige hat.
        • smartboartS smartboart
          ArnoD
          #190
          Habe mich an die API Beschreibung von Forecast gehalten:
          Restful API for Solar plant production
          • S stevie77
            ArnoD
            #191
            Ja, wenn die Funktion in einem Skript in der Gruppe global deklariert ist.
            Würde ich aber mit Vorsicht verwenden, da diese Funktionen in alle anderen Scripte kopiert werden.
            • A ArnoD
              stevie77
              #192
              @ArnoD sagte in E3DC Hauskraftwerk steuern:
              Danke, das habe ich auch inzwischen so recherchiert. Meine Passwörter brauch' ich nicht in jedes Script kopiert, da kopiere ich lieber die Werte in das zusätzliche Skript...schade, dass es da kein include o.ä. gibt wo man das programmatisch steuern kann.
              • A ArnoD
                nKorrFaktor in kWh
                stevie77
                #193
                Okay, probiere ich mal. Die 88% sind bei dir auch ein Schätzwert, wenn ich das richtig verstanden habe.
                Und welchen Wert dann zuerst runtersetzen wenn die Schätzung wie erwartbar zu hoch ist?
                Wenn ich den Code
                if (PrognoseMorgen_kWh > 87) {PrognoseMorgen_kWh = PrognoseMorgen_kWh + nKorrFaktor;}
                richtig verstehe, dann ist das gar kein Faktor (also Multiplikation), sondern ein Wert, der zur Prognose addiert wird. Ich dachte als Faktor wäre 1 neutral, deswegen hätte ich 0 jetzt auch nicht verstanden. Ich hab also immer 1 dazu addiert. Tatsächlich könne ich mit -2 beispielsweise 2 kWh Schätzung abziehen, korrekt?
                Und nWirkungsgradWR ist eigentlich der Faktor, 100 wäre neutral und ich sollte dann mal mit 70 oder so testen...
                Scheint wie bei Einstellung einer Heizkurve zu sein: nWirkungsgradWR bestimmt die Kurve und nKorrFaktor verschiebt diese dann nur noch nach oben oder unten. Also so ganz grob bildlich gesprochen. :-)
                Was bedeutet das? Also nicht mehr Erstellung des Diagramms mit tatsächlichem Verbrauch einmal um 22 Uhr, sondern fortwährend solange Strom erzeugt wird? Also quasi ein wachsender grüner Balken? Das wäre cool...wobei die Bekanntgabe der Werte um 22 Uhr auch was hatte... ;-)
                  stevie77
                  #194
                  @ArnoD Sourceanalytix hat heute 7 kWh zu wenig gezählt. Falls dir mal langweilig wird 😁, wäre ein Korrekturfaktor auf den Gesamtwert beider Anlagen interessant. Also einmalig abends das zu visualisierende Ergebnis für die Statistik mit dem Korrekturfaktor multiplizieren. Könnte man auch einmalig nach Sonnenuntergang auf die beiden Analytix-States machen?! Falls man die ohne Nebenwirkungen überschreiben kann...
                  • smartboartS Offline
                    smartboartS Offline
                    smartboart
                    #195
                    @ArnoD
                    Hallo Arno,
                    ich habe mir jetzt nen Modbuszähler als Erzeugungszähler zusätzlich eingebaut...
                    Dafür habe ich ein Script geschrieben, welches täglich den Ertrag hochzählt, wie sourceanalytics. Wegen einem State wollte ich keinen ganzen Adapter laufen lassen.
                    Den TagesZähler resette ich jetzt täglich um 23:59Uhr.
                    Mit deinem Script würde ich die Werte gerne um 23:58 abholen...
                    Spricht da was dagegen, weil du die Werte von Source analytiys schon viel früher abrufst...
                      ArnoD
                      #196
                      Nein da spricht nichts dagegen.
                      Ich hole mir die Werte nur so früh, weil sich beim Zähler in der Nacht nichts mehr ändert und bei mir um 0:01 bereits einige Skripte laufen.
                      Wollte das Ganze etwas entzerren.
                      Werde am Wochenende eine neue Version 0.2.0 hochladen, in der ist dann auch die Abfrage von Proplanta integriert so das man das Proplanta Script nicht mehr benötigt.
                      Das Diagramm und die PV-Leistung, wird dann laufend aktualisiert.
                      • A ArnoD
                        smartboartS Offline
                        smartboartS Offline
                        smartboart
                        #197
                        @ArnoD Super! Ab morgen kann ich dann richtig mit machen...Dann kommt endlich der neue Zähler...War bis heute im Inselbetrieb.
                        Find ich klasse, das dann Proplanta integriert ist...
                        SuperArbeit...
                          Nachdem ich die Passwörter jetzt zum 20. mal am E3DC eingetragen habe, habe malim Anschluss einen neustart gemacht. jetzt hats geklappt..
                          Mal ne andere Frage...Bis zum ählerwechsel fahre ich gerade auf Notstrom...
                          Heute Nacht hat die Kiste bestimmt 4 mal den Strom abgeschaltet und hat dann immer wieder selbstständig zugeschaltet. Hat das auch mal jemand beobachtet?
                          smartboartS Offline
                          smartboartS Offline
                          smartboart
                          #198
                          falls es jemand interessiert...hatte beim support angerufen...die entwickler arbeiten schon daran...ist dort schon bekannt...
                          • A ArnoD
                            Sourceanalytix ist natürlich kein genauer Zähler, kommt aber ungefähr so hin.
                            Für die Umsatzsteuervoranmeldung lese ich meine Zähler mit der Homematic Zählersensor-Sendeeinheit HM-ES-TX-WM direkt aus und speichere die Werte jedes Monat.
                            Das sieht dann so aus:
                            smartboartS Offline
                            smartboartS Offline
                            smartboart
                            #199
                            Hey Arno, muss darauf nochmal zurück...
                            meinste hier findet sich jemand, der daraus bzw. aus deinem script ne schöne HTML Tabelle bastelt und vlt. noch ne Textdatei welche auf nem Nass abgelegt wird? Wollen wir hier mal einen neuen Threat aufmachen? Ist dein Script, deshalb will ich das nicht machen.
                              stevie77
                              #200
                              @ArnoD Hätte mal ne Verständnisfrage: Macht es Sinn den Parameter unload so sehr auszureizen? Bei mir war das heute so extrem, dass Parameter unload = 0 berechnet wurde:
                              Bin allerdings kein Freund davon so knapp auf Risiko zu fahren. Da hätte nur ne größere Wolke und ein noch höherer Verbrauch passieren müssen, als der SoC ganz unten war und ich hätte ohne Not Strombezug gehabt.
                              Davon abgesehen wurde die Ladekurve dadurch unnötig steil (Batteriestress) und bis auf 0% SoC zu entladen ist auch schädlich für die Batterie. Das führt den Gedanken von E3DC-Control ad absurdum...
                              Vorschlag/Idee: Könntest du einen weiteren Parameter einführen, mit dem man den Mindest-SoC/unload-Wert fest vorgeben kann? Also dass der berechnete unload-Wert auf mind. diesen Parameterwert gesetzt wird, selbst wenn ein niedrigerer unload-Wert berechnet wurde. Ich würde z.B. gerne nie unter unload = 50 gehen wollen...
                                ArnoD
                                #201
                                Ist kein Problem, kannst du gerne machen.
                                Ich brauche die Seite nur für das Finanzamt, habe mich deswegen nicht weiter darum gekümmert.
                                Wenn jemand eine ansprechende HTML Seite daraus machen kann, würde ich mich freuen :-)
                                • S stevie77
                                  ArnoD
                                  #202
                                  Der berechnete Unload Wert wird im Script nicht verwendet.
                                  Ich lassen ihn mir im LOG nur anzeigen um zu sehen was passieren würde, wenn ich Unload automatisch einstellen lasse.
                                  In Zeile 327 wird er bereits auf min. 50% begrenzt wenn der berechnete Wert unter 50% ist, mehr zu entladen macht keinen Sinn.
                                  Im LOG angezeigt wird aber immer der berechnete Wert ohne Begrenzung.
                                  Wenn du das Entladen des Speichers automatisieren willst, müsstest du in Zeile 345
                                  sUnload[2] = UnloadSoC;
                                  eintragen.
                                  Ich habe für mich festgestellt, dass es ausreicht, das Laden am Morgen bis zum Start der Regelung von E3DC-Control zu verhindern.
                                  Das mache ich indem ich den aktuellen Speicher SoC auslese und den als Unload Wert verwende.
                                  Deswegen steht in der Zeile 345: sUnload[2] = AktSpeicherSoC;
                                  S 2 Antworten Letzte Antwort
                                  • A ArnoD
                                    eintragen.
                                    stevie77
                                    schrieb am zuletzt editiert von stevie77
                                    #203
                                    @ArnoD Missverständnis meinerseits...löschen des Beitrags nicht möglich mit meiner Berechtigung, sagt das Forum.
                                    • A ArnoD
                                      eintragen.
                                      stevie77
                                      #204
                                      @ArnoD Hat sich erledigt. habe deinen Beitrag nicht genau genug gelesen.
                                      • S stevie77
                                        stevie77
                                        #205
                                        @ArnoD Der falsch ermittelte Speicher-SoC von 0 % anstatt richtig 26 % gestern lag vielleicht an einem Update des Modbus-Adapters zuvor (möglicherweise < 24 h vorher). Deswegen ist bei mir dann unload auf 0 gesetzt worden. Ich hab den Code jetzt wie von dir beschrieben an der entsprechenden Stelle geändert und UnloadSoC benutzt. Dummerweise deinen Text nicht genau gelesen oder verstanden heute Nacht und jetzt eben selbst gedebugt und gefunden wo das Problem ist. ;-)
                                        Muss ich halt in Zukunft daran denken nach jedem Update des Skripts selbst noch die Zeile zu ändern.
                                        05:15:00.369	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Gepeichert wurde Prognose forecast 2/2 : 24115 :24445
                                        05:45:00.006	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Bewölkungsgrad 12 Uhr Proplanta 12.5
                                        05:45:00.007	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Bewölkungsgrad 15 Uhr Proplanta 12.5
                                        05:45:00.009	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Prognose Forecast in kWh = 100.971
                                        05:45:00.009	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Prognose Proplanta in kWh = 97.66950000000001
                                        05:45:00.010	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Globalstrahlung Proplante = 6.9
                                        05:45:00.010	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: AktSpeicherSoC in % = 0
                                        05:45:00.010	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: FreieKapBatterie_kWh = 11.7
                                        05:45:00.010	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Prognose_kWh für Berechnung = 87.90255
                                        05:45:00.011	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Ueberschuss in kWh = 64.20255
                                        05:45:00.011	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Ueberschuss in Prozent = 100
                                        05:45:00.011	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Berechneter Unload SoC ist = -100
                                        05:45:00.011	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: Einstellung 2 aktiv
                                        05:45:00.019	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: E3DC Config Datei gespeichert!
                                        05:45:01.023	info	javascript.0 (1770) script.js.e3dc-control.handleE3DCControl: E3DC Config Datei eingelesen!
                                          ArnoD
                                          #206
                                          Hat eigentlich das Speichern der History Daten Juli bei euch funktioniert ?
                                          Bei mir wurden die Daten nicht gespeichert.
                                          Da ich aber gestern einige Tests durchgeführt habe, kann es sein das mit dem ständigen stoppen und starten vom Script nur bei mir das speichern nicht funktioniert hat.
