  4. [Vorlage] Variable Zeitsteuerung mit VIS Editor
    6.6k
vistemplate
919 Beiträge 47 Kommentatoren 344.3k Aufrufe 75 Beobachtet
  • smartboartS Offline
    smartboartS Offline
    smartboart
    schrieb am zuletzt editiert von smartboart
    #647
    @GiuseppeS
    Hi Giuseppe....
    Wenn ich selbst weitere Bedingungen hinzufügen möchte, reicht es aus folgende Scriptteile einfach fortlaufend hinzuzufügen?
    createState("Timer.Editor.Condition3");
    createState("Timer.Editor.Cond3State");
    createState("Timer.Editor.Cond3Comp");
    createState("Timer.Editor.Cond3Value");
    createState("Timer.Editor.Cond3Result");
    EditSubsArr[4] = on({id: ["javascript." + instance + ".Timer.Editor.Cond3Comp","javascript." + instance + ".Timer.Editor.Cond3State","javascript." + instance + ".Timer.Editor.Cond3Value"], change: "any", ack: false}, function (obj) {
            var ConditionJSON = JSON.parse(getState("javascript." + instance + ".Timer.Editor.ConditionJSON").val);
            var Cond3State = getState("javascript." + instance + ".Timer.Editor.Cond3State").val
            var Cond3Comp = getState("javascript." + instance + ".Timer.Editor.Cond3Comp").val
            var Cond3Value = getState("javascript." + instance + ".Timer.Editor.Cond3Value").val
            var strCond3 = "getState(\"" + ConditionJSON[Cond3State] + "\").val " + Cond3Comp + " " + Cond3Value
            setState("javascript." + instance + ".Timer.Editor.Condition3", strCond3);
            if (Cond3State != "" && Cond3Comp != "" && Cond3Value != "") {
                setState("javascript." + instance + ".Timer.Editor.Cond3Result", eval(strCond3));
            case 3:
                strEval1 = eval(DeviceJSON.Conditions[1].ConditionStr);
                strEval2 = eval(DeviceJSON.Conditions[2].ConditionStr);
                strEval3 = eval(DeviceJSON.Conditions[3].ConditionStr);
                sumEval = (strEval1 && strEval2 && strEval3);
                break;
                "3":{
                    "ConditionStr": "",
                    "CondState": "",
                    "CondComp": "==",
                    "CondValue": ""
    G 1 Antwort Letzte Antwort
    • smartboartS smartboart
      @GiuseppeS
      Hi Giuseppe....
              case 3:
                  break;
                  "3":{
                      "ConditionStr": "",
                      "CondState": "",
                      "CondComp": "==",
                      "CondValue": ""
      GiuseppeS
      #648
      @smartboart
      Ich müsste mir das am PC genauer anschauen. Was definitiv fehlt ist die Auswertung der Bedingungen:
      function condEval(DeviceJSON){
      Da eine zukünftige Version höhere Anzahl von Bedingungen unterstützen soll, müsste ich genau diese Funktion mit einem generischen Ansatz programmieren.
      Es wären einige Neuerungen notwendig...
      Vorerst kannst du es probieren, selbst die Erweiterung einzupflegen 😉 können in der Testphase auch chatten, wenns zeitlich passt.
      Aktuell bin ich dabei, eine HTML Ansicht des Editors zu erstellen. Es geht voran, aber mühselig, dass es gut ausschaut 😂
      Im nächsten Schritt muss der html Code im Skript erstellt werden.
      Das Projekt dauert daher noch ca. 2 Wochen.
      • G GiuseppeS
        @smartboart
        smartboartS Offline
        smartboartS Offline
        smartboart
        #649
        @GiuseppeS
        danke für das Anbgebot...hab jetzt überall mal angepasst wo ich denke dass es sinn macht...
        Mit Vortlaufenden Nummern macht aber im Code an den
        EditSubsArr[5]
        spätesten Robleme, da dise bereits vortlaufend sind...
        Für ene 4 Bedingung müsste nach meiner denke dann für den EditSubsArr[] ne ander Nummer herhalten..
        Worauf das wieder Auswirkungen hat, steige ich noch nicht durch....
          @GiuseppeS
          EditSubsArr[5]
          GiuseppeS
          #650
          @smartboart
          Das kannst du ruhig machen mit der fortlaufenden Nummer bei EditSubsArr[]
          Nimm die nächste freie Ziffer. Die letzte müsstest du ganz unten finden, in dieser Reihe von Subscribtions. Beim Löschen dieser Subscribtions wird die Länge ermittelt, bedeutet, dass deins auch gelöscht wird.
          Hintergrund dieser optionalen Subsribtions:
          Bei der Verwendung von nur einem Editor-PopUp musst ich steuern welches Skript auf die Editor-Eingaben reagieren soll. Diese Subscribtions werden aktiviert, sobald ein Click in Tabelle erfolgt. Wird auch im Log ausgegeben, wenn Debug im Skript aktiviert wird.
            smartboartS Offline
            smartboart
            #651
            @GiuseppeS sagte in [Vorlage] Variable Zeitsteuerung mit VIS Editor:
            EditSubsArr[]
            ok, verstanden...
                    //for (let i = 1; i <= 3; i++){
                    //selbst geändert
                    for (let i = 1; i <= 4; i++){
            habe alle for Schleifen auf 4 geändert...
            Jetzt ist beim ofnnen der Konfiguration folgendes Fehlerbild...
            javascript.1	2020-07-26 16:33:06.122	error	(1703) at processImmediate (internal/timers.js:456:21)
            javascript.1	2020-07-26 16:33:06.122	error	(1703) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
            javascript.1	2020-07-26 16:33:06.121	error	(1703) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
            javascript.1	2020-07-26 16:33:06.121	error	(1703) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
            javascript.1	2020-07-26 16:33:06.120	error	(1703) at Object.<anonymous> (script.js.common.Zeitsteuerung.Variable_Zeitsteuerung_Vis:804:17)
            javascript.1	2020-07-26 16:33:06.120	error	(1703) at openEditor (script.js.common.Zeitsteuerung.Variable_Zeitsteuerung_Vis:711:112)
            javascript.1	2020-07-26 16:33:06.119	error	(1703) Error in callback: TypeError: Cannot read property 'ConditionStr' of undefined
              EditSubsArr[]
              ok, verstanden...
                      //selbst geändert
              GiuseppeS
              schrieb am zuletzt editiert von GiuseppeS
              #652
              @smartboart sagte in [Vorlage] Variable Zeitsteuerung mit VIS Editor:
              ConditionStr
              Das JSON, welches alle Timer beinhaltet muss natürlich auch aufgebohrt werden.
              Unter dem Key Conditions sind nur 3 Objekte angesiedelt, hier müsste das 4. noch ergänzt werden. Könntest du erstmal mit einem Online-JSON-Editor bewerkstelligen; ansonsten gehts natürlich auch im Code.
              So schaut es aktuell aus:
              Es ist nur Vorhalt für 3 Timer vorhanden, denke daher kommt dein Fehler...
              • G GiuseppeS
                ConditionStr
                smartboartS Offline
                smartboartS Offline
                smartboart
                #653
                JSON
                ja tatsächlich... Geräte welche ich später in die Enumeration DeviceEnum aufgenommen haben, haben nun bereits meine 4 conditions hinterlegt...
                Bzw Geräte welche schon hinterlegt waren aber nocht nicht programmiert..
                Geräte welche bereits eine Zeitsteuerung im editor erfahren haben, haben meine 4. Bedingung nocht nicht.. Sollte so also funktionieren...
                Müsste halt die json löschen und alles neu programmieren....oder wie due sagst im editor ändern...Unbenannt.JPG
                  JSON
                  GiuseppeS
                  #654
                  @smartboart
                  Hängt nun davon ab, wie komplex deine bisherigen Timer waren... Komplett bei null anfangen könnte aufwendiger sein, als diesen weiteren Key zu ergänzen. Ich würde es deine Stelle zumindest nicht programmatisch lösen.
                  • G GiuseppeS
                    @smartboart
                    smartboartS Offline
                    smartboartS Offline
                    smartboart
                    #655
                    @GiuseppeS
                    ja
                    ich war noch am Testen, so viele habe ich noch nicht programmiert...
                    Werde das jetzt erstmal testen ob meine 4. Bedingung tut, dann packe ich noch 2 drauf ...Dann werde ich die Timer neu programmieren...
                    Vielen Dank für die Unterstützung...
                    • G Offline
                      GiuseppeS
                      #656
                      Habe nun einen ersten (zufriedenstellenden) Entwurf des Editors in HTML.
                      Aus dem Code werden folgende Optionen der Darstellung herausgelöst:
                      • Schriftfarbe bei Texten und Button/Select (hier: weiß)
                      • Rahmen der Button/Select (hier: weiß); Grün/Rot sind "funktional", daher nicht einfach editierbar
                      • Füllfarbe der Button/Select (hier: schwarz); es funktioniert übrigens auch "transparent" oder rgba mit Alphawerten
                      Bedingungen werden über Plus-Button ergänzt und mit Del-Button gelöscht. Klasse ist, dass bei manueller Zeitauswahl die Funktionalität des Browsers genutzt wird, d.h. bei Android-Geräten schaut das z.B. so aus:
                      • G Offline
                        GiuseppeS
                        #657
                        So würde es mit "rgba(255,255,255,0.2)" ausschauen, statt "#fff":
                        Wenn keine Gegen- bzw. Verbesserungsvorschläge eingehen, würde ich damit weitermachen.
                        EDIT:
                        Astro1 und Astro2 sind zwei alternative Darstellungen. Im Fall1 wird "manuell" ausgewählt, d.h. rechts erscheint ein Zeiteingabefeld. Im Fall2 wird eine Astrozeit gewählt, d.h. rechts erscheint eine Möglichkeit für die Offset-Korrektur.
                        sigi234S GlasfaserG 3 Antworten Letzte Antwort
                        • G GiuseppeS
                          EDIT:
                          sigi234S Online
                          sigi234S Online
                          #658
                          Ist der Hintergrund auswählbar? Kann man umschalten Helles/Dunkles Design?
                          • G GiuseppeS
                            EDIT:
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #659
                            Ist halt Geschmacksache .... ist ein wenig aufgebläht ..
                            finde es immer noch so besser ... strukturierter Aufbau .
                            • G GiuseppeS
                              EDIT:
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #660
                              @GiuseppeS
                              • sigi234S sigi234
                                GiuseppeS
                                #661
                                @sigi234
                                Meinst du den Hintergrund der Buttons? Der blaue Hintergrund ist von mir.
                                • G GiuseppeS
                                  @sigi234
                                  sigi234S Online
                                  sigi234S Online
                                  #662
                                  Den blauen
                                  • GlasfaserG Glasfaser
                                    @GiuseppeS
                                    GiuseppeS
                                    #663
                                    @Glasfaser sagte in [Vorlage] Variable Zeitsteuerung mit VIS Editor:
                                    @GiuseppeS
                                    Scherzkeks 😆
                                    Was den Punkt bzgl. Optik betrifft: Bin selbst auch hin- und hergerissen.
                                    In HTML wären mehrere Vorteile:
                                    • Darstellung ist dynamisch, d.h. es werden keine Elemente aktiviert oder deaktiviert, sie werden so erstellt wie benötigt. Das macht sich in der Höhe bemerkbar; so gering wie möglich.
                                    • Bedingungen sind dynamischer zu ergänzen/löschen.
                                    • In Bedingungen könnte ich als Zielwert dynamisch ein Select-true/false oder ein freies Input-Feld erzeugen. Aktuell kaum möglich...
                                    • Es wird nur noch ein View benötigt.
                                    Die HTML Ergänzung würde übrigens auf die aktuelle PopUp-Editor-Bedienung aufsetzen. Der alte Editor könnte wahrscheinlich weiter genutzt werden.
                                    Allerdings würde ich die HTML-Ergänzung ehrlich gesagt nicht weiter verfolgen, wenn es allgemein nicht akzeptiert wird. Habe bisher nicht viel Arbeit rein gesteckt. Das waren heute ca. 3 Stunden. Der programmatische Anteil wäre deutlich aufwendiger.
                                    • sigi234S sigi234
                                      Den blauen
                                      GiuseppeS
                                      #664
                                      @sigi234
                                      Wie erwähnt, der blaue Hintergrund ist von mir. So wie der Hintergrund aktuell in der Tabellenansicht der Timer ist, so wird auch der Hintergrund beim Editor sein. Das verändere ich nicht. Und ich überdecke den User-Hintergrund auch nicht. Deshalb können auch verschiedene Farben des Editors leicht verändert werden, damit jeder Hintergrund weiterhin genutzt werden kann.
                                      • G Offline
                                        GiuseppeS
                                        #665
                                        Wäre klasse, wenn sich weitere Anwender melden und ihre Wünsche äußern. PopUp weiter nutzen oder HTML.
                                        Mir ist jetzt erst aufgefallen, dass eine Zeile im PopUp-Editor eingespart werden kann. Zeile für Offset und Zeile für Zeitangabe wird nie gleichzeitig genutzt; könnte also in eine Zeile mit bedingter Darstellung zusammengefasst werden. Somit würde eine Bedingung Nr. 4 Platz finden.
                                        Allgemeine Frage:
                                        Finde die Lösung von Smartboat ehrlich gesagt auch gut, dass der Editor im Extra-View statt im PopUp angezeigt wird. Wie steht ihr zu dieser Lösung? Man hätte definitiv mehr Platz; andererseits kann man nicht auf die Tabelle "spicken" falls etwas von einem anderen Timer übernommen werden soll.
                                        smartboartS sigi234S 3 Antworten Letzte Antwort
                                        • G GiuseppeS
                                          Allgemeine Frage:
                                          smartboartS Offline
                                          smartboartS Offline
                                          smartboart
                                          #666
                                          @GiuseppeS
                                          Hallo Giuseppe,
                                          meine Antwort dazu kennst du ja schon, hatte ich ja oben erwähnt...Mir gefällt das mit dem PopUp sehr gut und Platz ist bei mir kein Thema... Ich arbeite generell nur mit einer main view...alle andern Views werden darin im view in Widget angezeigt.. Umschalten tue ich das mittels State Typ number...Jede View hat ne zugeordnete Nummer... Es ist somit immer nur eine view / main View aktiv, alle anderen werden über das Widget geladen...Spart Widgets die man eigentlich in jeder view gerne haette..
                                          Ich finde deine Arbeit super und die HTML Variante würde ich auch nutzen oder generell nutzen wenn ich jetzt erst dazu stoßen würde.. Bin also voreingenommen.
                                          Wenn mir was gefällt brauche ich nicht unbedingt ne Änderung..Erweiterungen in der Funktion wären mir lieber...
                                          • Z.B fände ich es gut wenn mehrere Aktoren mit einem Timer geschaltet werden könnten.
                                          • Mehere Bedingungen hatte ich ja schon geäussert. Habe ich aber so denke ich soweit im Code schon für mich aktiv..
                                          • Abschaltung wenn eine Bedingung wegfällt bei aktiv bleiben / gemerkten Timer..
                                          wenn das noch nicht implementiert ist...
