  4. Ble.0 Adapter bremst ganzen IObroker in 2 Min.
    5.5k
ble adapter
124 Beiträge 12 Kommentatoren 15.7k Aufrufe 11 Beobachtet
  • Peter.bleP Offline
    Peter.bleP Offline
    Peter.ble
    Raspberrz 4 4G
    Original Netzteil
    NPM 6.14.5
    JS Controller 3.1.6
    BLE 0.11.6
    Admin 4.1.1
    node 12.18.2
    Wenn der Adapter gestoppt ist lauft alles.
      Peter.bleP Offline
      Peter.ble
      hier der LOG Eintrag:
      2020-07-22 11:15:10.291 - debug: daswetter.0 (17557) hourly forecast done
      2020-07-22 11:15:10.294 - debug: daswetter.0 (17557) exit, all done
      2020-07-22 11:15:10.295 - info: daswetter.0 (17557) Terminated (NO_ERROR): Without reason
      2020-07-22 11:15:10.817 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-07-22 11:16:24.134 - info: fhem.0 (781) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
      2020-07-22 11:21:24.136 - info: fhem.0 (781) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
      2020-07-22 11:26:24.137 - info: fhem.0 (781) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
      2020-07-22 11:27:04.725 - info: host.raspberrypi "system.adapter.ble.0" enabled
      2020-07-22 11:27:04.776 - info: host.raspberrypi instance system.adapter.ble.0 started with pid 18815
      2020-07-22 11:27:06.846 - info: ble.0 (18815) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.18.2, js-controller: 3.1.6
      2020-07-22 11:27:06.934 - info: ble.0 (18815) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
      2020-07-22 11:27:06.935 - info: ble.0 (18815) enabled plugins: Xiaomi, _default
      2020-07-22 11:27:06.937 - info: ble.0 (18815) monitored services: fe95
      2020-07-22 11:27:07.263 - info: ble.0 (18815) starting scan for services ["fe95"]
      2020-07-22 11:27:20.508 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: read ETIMEDOUT
      2020-07-22 11:27:21.138 - info: host.raspberrypi "system.adapter.ble.0" disabled
      2020-07-22 11:27:21.140 - info: host.raspberrypi stopInstance system.adapter.ble.0 (force=false, process=true)
      2020-07-22 11:27:21.144 - info: host.raspberrypi stopInstance system.adapter.ble.0 send kill signal
      2020-07-22 11:27:21.145 - info: ble.0 (18815) Got terminate signal TERMINATE_YOURSELF
      2020-07-22 11:27:21.148 - info: ble.0 (18815) stopping scan
      2020-07-22 11:27:21.149 - info: ble.0 (18815) terminating
      2020-07-22 11:27:21.150 - info: ble.0 (18815) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-07-22 11:27:21.682 - info: host.raspberrypi instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-07-22 11:28:32.714 - info: host.raspberrypi "system.adapter.ble.0" enabled
      2020-07-22 11:28:32.767 - info: host.raspberrypi instance system.adapter.ble.0 started with pid 18972
      2020-07-22 11:28:34.375 - info: ble.0 (18972) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.18.2, js-controller: 3.1.6
      2020-07-22 11:28:34.460 - info: ble.0 (18972) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
      2020-07-22 11:28:34.461 - info: ble.0 (18972) enabled plugins: Xiaomi, _default
      2020-07-22 11:28:34.462 - info: ble.0 (18972) monitored services: fe95
      2020-07-22 11:28:34.667 - info: ble.0 (18972) starting scan for services ["fe95"]
      2020-07-22 11:28:49.308 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: read ETIMEDOUT
      2020-07-22 11:28:49.615 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      2020-07-22 11:28:49.927 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      2020-07-22 11:28:50.236 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      2020-07-22 11:28:50.543 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      2020-07-22 11:28:50.850 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      2020-07-22 11:28:51.142 - error: mihome-vacuum.0 (893) Cannot send command: Error: send ENETUNREACH 192.168.0.120:54321
      2020-07-22 11:28:51.158 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      • apollon77A Offline
        Laos wenn ich das log so sehe sieht es für mich so aus als ob dein Netzerk zusammenrbicht ... Frage: Wie stark ist das Netzteil? BLE "On board" oder über extra USB Stick?
          Peter.bleP Offline
          Peter.ble
          Bluetooth und wlan on board. Original Raspberry 4 netzteil mit5,1V 3A laut Aufdruck
          • JohGreJ Offline
            JohGreJ Offline
            JohGre
            Hatte mit dem radar-Adapter mal ein ähnliches Problem. Da war arp-scan schuld. Weiß jetzt allerdings nicht ob der BLE-Adapter arp-scan nutzt. Hab damals den arp-scan deinstalliert und siehe da kein Problem mehr.
            nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
              Peter.bleP Offline
              Peter.ble
              Mit meinem oppo netzteil mit 5V 4A funktioniert es auch nicht. Also ich denke Netzteil kann man ausschließen
              • JohGreJ JohGre
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @JohGre sagte in Ble.0 Adapter bremst ganzen IObroker in 2 Min.:
                Tut er nicht. Aus dem obigen Log werde ich aber auch nicht schlau. Sieht seitens des Adapters alles unauffällig aus.
                  Man sieht im Log halt nur das das Netzwerk weg ist plötzlich ... als wenn der ble on board da blöd intragiert.
                  /var/log/syslog irgendwas oder "dmesg"?
                  Mal einen BLE USB Stick an nem aktiven switch versucht?
                  Würde gern "Hardware-Themen" ausschliessen
                    Peter.bleP Offline
                    Peter.ble
                    Habe keinen stick . Aber bei einem 2. Raspberry 4 4gb ist das gleiche
                    • Peter.bleP Peter.ble
                      @Peter-ble
                      • A arnold
                        hallo.
                        Habe noch mal versucht Ble.0 Adapter zu starten .
                        Diesmal aber iobroker Komplet neu installiert , und auf den noch "nackten" Iobroker Ble. adapter installiert,( ist sofort auf grün geschaltet und bekommt Daten von xiaomi -Temperatur ) ABER dann bricht das System zusamen so nach ca 2-5 min .
                        Ble Adapter ausschalten und System läuft stabil.
                        bin ich der einzige mt dem Problem.
                        @arnold Bei mir läuft eine ganz ähnliche Konstellation ganz unauffällig.
                          Peter.bleP Offline
                          Peter.ble
                          Danke für eure Hilfe. Hier das /var/log/syslog. Dmesg kann nicht nicht machen, da der ganze Raspberry nicht mehr erreichbar ist und nur ab Start gespeichert wird.
                          Wenn ich falsch liege bitte schreiben wie ich vorgehen soll.
                          Ab ca 8:15 Uhr habe ich den BLE Adapter gestartet. Das System lief vorher ohne Fehler.
                          Ca 8:17 Uhr war der IObroker nicht mehr erreichbar.
                          Habe dann den Raspberry neu gestaretet.
                          Jul 23 08:14:15 raspberrypi bash[587]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                          Jul 23 08:14:16 raspberrypi kernel: [43100.943995] device wlan0 left promiscuous mode
                          Jul 23 08:14:40 raspberrypi kernel: [43125.013973] device wlan0 entered promiscuous mode
                          Jul 23 08:14:45 raspberrypi kernel: [43130.901301] device wlan0 left promiscuous mode
                          Jul 23 08:15:10 raspberrypi kernel: [43155.134453] device wlan0 entered promiscuous mode
                          Jul 23 08:15:15 raspberrypi bash[587]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                          Jul 23 08:15:16 raspberrypi kernel: [43161.018161] device wlan0 left promiscuous mode
                          Jul 23 08:15:40 raspberrypi kernel: [43185.114958] device wlan0 entered promiscuous mode
                          Jul 23 08:15:46 raspberrypi kernel: [43191.094761] device wlan0 left promiscuous mode
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: bits received from HRNG source: 420064
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: bits sent to kernel pool: 363584
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: entropy added to kernel pool: 363584
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2 successes: 21
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2 failures: 0
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Poker: 0
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Runs: 0
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Long run: 0
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: HRNG source speed: (min=258.493; avg=472.699; max=514.657)Kibits/s
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS tests speed: (min=11.333; avg=14.298; max=31.268)Mibits/s
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: Lowest ready-buffers level: 2
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: Entropy starvations: 0
                          Jul 23 08:16:03 raspberrypi rngd[398]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                          Jul 23 08:16:10 raspberrypi kernel: [43214.965496] device wlan0 entered promiscuous mode
                          Jul 23 08:16:15 raspberrypi bash[587]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                          Jul 23 08:16:16 raspberrypi kernel: [43220.962913] device wlan0 left promiscuous mode
                          Jul 23 08:16:19 raspberrypi bash[587]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                          Jul 23 08:16:40 raspberrypi kernel: [43244.956144] device wlan0 entered promiscuous mode
                          Jul 23 08:16:46 raspberrypi kernel: [43250.948836] device wlan0 left promiscuous mode
                          Jul 23 08:17:01 raspberrypi CRON[14625]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                          Jul 23 08:17:10 raspberrypi kernel: [43274.956590] device wlan0 entered promiscuous mode
                          Jul 23 08:17:15 raspberrypi bash[587]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                          Jul 23 08:17:15 raspberrypi kernel: [43280.925821] device wlan0 left promiscuous mode
                          Jul 23 08:17:40 raspberrypi kernel: [43305.077096] device wlan0 entered promiscuous mode
                          ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@Jul 23 08:17:04 raspberrypi fake-hwclock[116]: Do 23. Jul 06:17:01 UTC 2020
                          Jul 23 08:17:04 raspberrypi systemd-fsck[133]: e2fsck 1.44.5 (15-Dec-2018)
                          Jul 23 08:17:04 raspberrypi systemd-fsck[133]: rootfs: clean, 242512/941616 files, 1446295/3830528 blocks
                          Jul 23 08:17:04 raspberrypi systemd[1]: Started File System Check on Root Device.
                          Jul 23 08:17:04 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
                          Jul 23 08:17:04 raspberrypi systemd[1]: Started udev Coldplug all Devices.
                          Jul 23 08:17:04 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                          MOD-Edit: Code in code-tags gesetzt!
                            Peter.bleP Offline
                            Peter.ble
                            Habe gerade bemerkt, dass ohne den Radar2 Adapter das System mit laufenden BLE Adapter funktioniert. Benutze Radar2 Adapterversion 1.2.5
                            Folgende Einstellungen werden verwendet:
                            Verzögerung in Sekunden zwischen Abfragen (>=15):
                            30
                            Wie lange (in Minuten) sollte ein Gerät nicht erkannt wird, bevor es markiert als Weg' (>=1):
                            bei Linux: nummer des Bluetooth-Adapters (0 = hci0):
                            arp-scan Kommandozeile, muss aber geändert werden falls das 1. Netwerkinterface nicht default ist.
                            -lgq --retry=5 --timeout=400
                            Verzögerung in Minuten zwischen den externen Netwerkabfragen (wenn 0 dann ausgeschaltet):
                            60
                            Verzögerung in Minuten zwischen Druckerfüllstand-Abfrage (>=100):
                            720
                            Verzögerung in Minuten zwischen UWZ-Abfragen 0=UWZ ausgeschaltet:
                            120
                            IP-Adressen die bekannt sind und keine 'unknown'-Einträge generieren sollen, mit ',' separiert:
                            1.1.1.1
                            BT-Adressen die bekannt sind und keine 'unknown'-Einträge generieren sollen, mit ',' separiert:
                            01:12:23:34:45:56
                            Maximum Meldungen in UWZ 0=alle Meldungen zusammen:
                            Benutze langen Warnungstext mit genauer Beschreibung:
                            false
                            Liste der konfigurierten Objekte:Bitte Konfiguration speichern!
                            Vielen Dank
                            JohGreJ AlCalzoneA 2 Antworten Letzte Antwort
                              @Peter-ble Hey, Also diese "komischen Müll Zeichen" im Syslog bedeuten an sich das dein System gerade gecrasht ist - oder zumindestens ein Teil davon. Das würde auch den Sprung in der uhrzeit erklären weil fake-hwclock die Uhrzeit wieder neu setzt ... und auch der fs check weisst darauf hin.
                              Es siehrt aber so aus als ob er nicht komplett rebootet sondern nur ein teil...
                              Also kurz: Irgendetwas mag deine Hardware nicht an der Konstellation ... da kann fürchte ich der Adapter nix für
                                30
                                60
                                720
                                120
                                1.1.1.1
                                01:12:23:34:45:56
                                false
                                Vielen Dank
                                JohGreJ Offline
                                JohGreJ Offline
                                JohGre
                                @Peter-ble sagte in Ble.0 Adapter bremst ganzen IObroker in 2 Min.:
                                Wie schon geschrieben, bei mir war arp-scan beim radar2 Adapter schuld. Eine deinstallation half hier nachhaltig.
                                  30
                                  60
                                  720
                                  120
                                  1.1.1.1
                                  01:12:23:34:45:56
                                  false
                                  Vielen Dank
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  Du hast beide gleichzeitig laufen? Wenn beide auf die Bluetooth-Schnittstelle zugreifen, kann das Probleme machen.
                                    Peter.bleP Offline
                                    Peter.ble
                                    Habe beide Adapter gleichzeitig laufen.
                                      Peter.bleP Offline
                                      Peter.ble
                                      Leider zu früh gefreut. Auch ohne Radar2 Adapter friert das System ein. Dauert aber wesentlich länger. :-(
                                        Peter.bleP Offline
                                        Peter.ble
                                        Habe jetzt mit:
                                        sudo apt-get remove arp-scan
                                        arp-scan deinstalliert.
                                        Mal schauen ob es hilft. Melde mich
                                          Peter.bleP Offline
                                          Peter.ble
                                          arp-scan mit dem Befehl sudi remove arp-scan brachte keine besserung.
                                          Zudem ist es egal, ob Radar2 laeft oder nicht. Was ich aber herausgefunden habe, wenn sich der Raspberry per Wlan mit dem 5,8Ghz Netz verbindet laeuft es. Wenn er sich mit dem 2,4 Ghz Netz verbindet habe ich sofot schwierigkeiten.
                                          Kann mir jemand helfen. Bei wem l'uft die Kombi Rasbpi4 und Wlan2,4ghz und Ble und Radar. Welche Softwarestaende?
