  4. Ble.0 Adapter bremst ganzen IObroker in 2 Min.
    5.5k
ble adapter
124 Beiträge 12 Kommentatoren 15.7k Aufrufe 11 Beobachtet
  • Peter.bleP Offline
    Peter.bleP Offline
    Peter.ble
    Habe das gleiche problem, dass Iobroker nach dem Starten vom BLE Adapter nicht mehr reagiert.
    Gibt es hierzu schon eine Loesung?
      Peter.bleP Offline
      Peter.ble
      Raspberrz 4 4G
      Original Netzteil
      NPM 6.14.5
      JS Controller 3.1.6
      BLE 0.11.6
      Admin 4.1.1
      node 12.18.2
      Wenn der Adapter gestoppt ist lauft alles.
        Peter.bleP Offline
        Peter.ble
        hier der LOG Eintrag:
        2020-07-22 11:15:10.291 - debug: daswetter.0 (17557) hourly forecast done
        2020-07-22 11:15:10.294 - debug: daswetter.0 (17557) exit, all done
        2020-07-22 11:15:10.295 - info: daswetter.0 (17557) Terminated (NO_ERROR): Without reason
        2020-07-22 11:15:10.817 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2020-07-22 11:16:24.134 - info: fhem.0 (781) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2020-07-22 11:21:24.136 - info: fhem.0 (781) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2020-07-22 11:26:24.137 - info: fhem.0 (781) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2020-07-22 11:27:04.725 - info: host.raspberrypi "system.adapter.ble.0" enabled
        2020-07-22 11:27:04.776 - info: host.raspberrypi instance system.adapter.ble.0 started with pid 18815
        2020-07-22 11:27:06.846 - info: ble.0 (18815) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.18.2, js-controller: 3.1.6
        2020-07-22 11:27:06.934 - info: ble.0 (18815) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
        2020-07-22 11:27:06.935 - info: ble.0 (18815) enabled plugins: Xiaomi, _default
        2020-07-22 11:27:06.937 - info: ble.0 (18815) monitored services: fe95
        2020-07-22 11:27:07.263 - info: ble.0 (18815) starting scan for services ["fe95"]
        2020-07-22 11:27:20.508 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: read ETIMEDOUT
        2020-07-22 11:27:21.138 - info: host.raspberrypi "system.adapter.ble.0" disabled
        2020-07-22 11:27:21.140 - info: host.raspberrypi stopInstance system.adapter.ble.0 (force=false, process=true)
        2020-07-22 11:27:21.144 - info: host.raspberrypi stopInstance system.adapter.ble.0 send kill signal
        2020-07-22 11:27:21.145 - info: ble.0 (18815) Got terminate signal TERMINATE_YOURSELF
        2020-07-22 11:27:21.148 - info: ble.0 (18815) stopping scan
        2020-07-22 11:27:21.149 - info: ble.0 (18815) terminating
        2020-07-22 11:27:21.150 - info: ble.0 (18815) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-07-22 11:27:21.682 - info: host.raspberrypi instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2020-07-22 11:28:32.714 - info: host.raspberrypi "system.adapter.ble.0" enabled
        2020-07-22 11:28:32.767 - info: host.raspberrypi instance system.adapter.ble.0 started with pid 18972
        2020-07-22 11:28:34.375 - info: ble.0 (18972) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.18.2, js-controller: 3.1.6
        2020-07-22 11:28:34.460 - info: ble.0 (18972) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
        2020-07-22 11:28:34.461 - info: ble.0 (18972) enabled plugins: Xiaomi, _default
        2020-07-22 11:28:34.462 - info: ble.0 (18972) monitored services: fe95
        2020-07-22 11:28:34.667 - info: ble.0 (18972) starting scan for services ["fe95"]
        2020-07-22 11:28:49.308 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: read ETIMEDOUT
        2020-07-22 11:28:49.615 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
        2020-07-22 11:28:49.927 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
        2020-07-22 11:28:50.236 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
        2020-07-22 11:28:50.543 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
        2020-07-22 11:28:50.850 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
        2020-07-22 11:28:51.142 - error: mihome-vacuum.0 (893) Cannot send command: Error: send ENETUNREACH 192.168.0.120:54321
        2020-07-22 11:28:51.158 - warn: telegram.0 (1186) polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
        • apollon77A Offline
          Laos wenn ich das log so sehe sieht es für mich so aus als ob dein Netzerk zusammenrbicht ... Frage: Wie stark ist das Netzteil? BLE "On board" oder über extra USB Stick?
            Peter.bleP Offline
            Peter.ble
            Bluetooth und wlan on board. Original Raspberry 4 netzteil mit5,1V 3A laut Aufdruck
            • JohGreJ Offline
              JohGreJ Offline
              JohGre
              Hatte mit dem radar-Adapter mal ein ähnliches Problem. Da war arp-scan schuld. Weiß jetzt allerdings nicht ob der BLE-Adapter arp-scan nutzt. Hab damals den arp-scan deinstalliert und siehe da kein Problem mehr.
              nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
                Peter.bleP Offline
                Peter.ble
                Mit meinem oppo netzteil mit 5V 4A funktioniert es auch nicht. Also ich denke Netzteil kann man ausschließen
                • JohGreJ JohGre
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @JohGre sagte in Ble.0 Adapter bremst ganzen IObroker in 2 Min.:
                  Tut er nicht. Aus dem obigen Log werde ich aber auch nicht schlau. Sieht seitens des Adapters alles unauffällig aus.
                    Man sieht im Log halt nur das das Netzwerk weg ist plötzlich ... als wenn der ble on board da blöd intragiert.
                    /var/log/syslog irgendwas oder "dmesg"?
                    Mal einen BLE USB Stick an nem aktiven switch versucht?
                    Würde gern "Hardware-Themen" ausschliessen
                      Peter.bleP Offline
                      Peter.ble
                      Habe keinen stick . Aber bei einem 2. Raspberry 4 4gb ist das gleiche
                      • Peter.bleP Peter.ble
                        @Peter-ble
                        • A arnold
                          hallo.
                          Habe noch mal versucht Ble.0 Adapter zu starten .
                          Diesmal aber iobroker Komplet neu installiert , und auf den noch "nackten" Iobroker Ble. adapter installiert,( ist sofort auf grün geschaltet und bekommt Daten von xiaomi -Temperatur ) ABER dann bricht das System zusamen so nach ca 2-5 min .
                          Ble Adapter ausschalten und System läuft stabil.
                          bin ich der einzige mt dem Problem.
                          @arnold Bei mir läuft eine ganz ähnliche Konstellation ganz unauffällig.
                            Peter.bleP Offline
                            Peter.ble
                            Danke für eure Hilfe. Hier das /var/log/syslog. Dmesg kann nicht nicht machen, da der ganze Raspberry nicht mehr erreichbar ist und nur ab Start gespeichert wird.
                            Wenn ich falsch liege bitte schreiben wie ich vorgehen soll.
                            Ab ca 8:15 Uhr habe ich den BLE Adapter gestartet. Das System lief vorher ohne Fehler.
                            Ca 8:17 Uhr war der IObroker nicht mehr erreichbar.
                            Habe dann den Raspberry neu gestaretet.
                            Jul 23 08:14:15 raspberrypi bash[587]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                            Jul 23 08:14:16 raspberrypi kernel: [43100.943995] device wlan0 left promiscuous mode
                            Jul 23 08:14:40 raspberrypi kernel: [43125.013973] device wlan0 entered promiscuous mode
                            Jul 23 08:14:45 raspberrypi kernel: [43130.901301] device wlan0 left promiscuous mode
                            Jul 23 08:15:10 raspberrypi kernel: [43155.134453] device wlan0 entered promiscuous mode
                            Jul 23 08:15:15 raspberrypi bash[587]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                            Jul 23 08:15:16 raspberrypi kernel: [43161.018161] device wlan0 left promiscuous mode
                            Jul 23 08:15:40 raspberrypi kernel: [43185.114958] device wlan0 entered promiscuous mode
                            Jul 23 08:15:46 raspberrypi kernel: [43191.094761] device wlan0 left promiscuous mode
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: bits received from HRNG source: 420064
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: bits sent to kernel pool: 363584
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: entropy added to kernel pool: 363584
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2 successes: 21
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2 failures: 0
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Poker: 0
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Runs: 0
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Long run: 0
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: HRNG source speed: (min=258.493; avg=472.699; max=514.657)Kibits/s
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: FIPS tests speed: (min=11.333; avg=14.298; max=31.268)Mibits/s
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: Lowest ready-buffers level: 2
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: Entropy starvations: 0
                            Jul 23 08:16:03 raspberrypi rngd[398]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                            Jul 23 08:16:10 raspberrypi kernel: [43214.965496] device wlan0 entered promiscuous mode
                            Jul 23 08:16:15 raspberrypi bash[587]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                            Jul 23 08:16:16 raspberrypi kernel: [43220.962913] device wlan0 left promiscuous mode
                            Jul 23 08:16:19 raspberrypi bash[587]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                            Jul 23 08:16:40 raspberrypi kernel: [43244.956144] device wlan0 entered promiscuous mode
                            Jul 23 08:16:46 raspberrypi kernel: [43250.948836] device wlan0 left promiscuous mode
                            Jul 23 08:17:01 raspberrypi CRON[14625]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                            Jul 23 08:17:10 raspberrypi kernel: [43274.956590] device wlan0 entered promiscuous mode
                            Jul 23 08:17:15 raspberrypi bash[587]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                            Jul 23 08:17:15 raspberrypi kernel: [43280.925821] device wlan0 left promiscuous mode
                            Jul 23 08:17:40 raspberrypi kernel: [43305.077096] device wlan0 entered promiscuous mode
                            ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@Jul 23 08:17:04 raspberrypi fake-hwclock[116]: Do 23. Jul 06:17:01 UTC 2020
                            Jul 23 08:17:04 raspberrypi systemd-fsck[133]: e2fsck 1.44.5 (15-Dec-2018)
                            Jul 23 08:17:04 raspberrypi systemd-fsck[133]: rootfs: clean, 242512/941616 files, 1446295/3830528 blocks
                            Jul 23 08:17:04 raspberrypi systemd[1]: Started File System Check on Root Device.
                            Jul 23 08:17:04 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
                            Jul 23 08:17:04 raspberrypi systemd[1]: Started udev Coldplug all Devices.
                            Jul 23 08:17:04 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                            MOD-Edit: Code in code-tags gesetzt!
                              Peter.bleP Offline
                              Peter.ble
                              Habe gerade bemerkt, dass ohne den Radar2 Adapter das System mit laufenden BLE Adapter funktioniert. Benutze Radar2 Adapterversion 1.2.5
                              Folgende Einstellungen werden verwendet:
                              Verzögerung in Sekunden zwischen Abfragen (>=15):
                              30
                              Wie lange (in Minuten) sollte ein Gerät nicht erkannt wird, bevor es markiert als Weg' (>=1):
                              bei Linux: nummer des Bluetooth-Adapters (0 = hci0):
                              arp-scan Kommandozeile, muss aber geändert werden falls das 1. Netwerkinterface nicht default ist.
                              -lgq --retry=5 --timeout=400
                              Verzögerung in Minuten zwischen den externen Netwerkabfragen (wenn 0 dann ausgeschaltet):
                              60
                              Verzögerung in Minuten zwischen Druckerfüllstand-Abfrage (>=100):
                              720
                              Verzögerung in Minuten zwischen UWZ-Abfragen 0=UWZ ausgeschaltet:
                              120
                              IP-Adressen die bekannt sind und keine 'unknown'-Einträge generieren sollen, mit ',' separiert:
                              1.1.1.1
                              BT-Adressen die bekannt sind und keine 'unknown'-Einträge generieren sollen, mit ',' separiert:
                              01:12:23:34:45:56
                              Maximum Meldungen in UWZ 0=alle Meldungen zusammen:
                              Benutze langen Warnungstext mit genauer Beschreibung:
                              false
                              Liste der konfigurierten Objekte:Bitte Konfiguration speichern!
                              Vielen Dank
                              JohGreJ AlCalzoneA 2 Antworten Letzte Antwort
                                @Peter-ble Hey, Also diese "komischen Müll Zeichen" im Syslog bedeuten an sich das dein System gerade gecrasht ist - oder zumindestens ein Teil davon. Das würde auch den Sprung in der uhrzeit erklären weil fake-hwclock die Uhrzeit wieder neu setzt ... und auch der fs check weisst darauf hin.
                                Es siehrt aber so aus als ob er nicht komplett rebootet sondern nur ein teil...
                                Also kurz: Irgendetwas mag deine Hardware nicht an der Konstellation ... da kann fürchte ich der Adapter nix für
                                  30
                                  60
                                  720
                                  120
                                  1.1.1.1
                                  01:12:23:34:45:56
                                  false
                                  Vielen Dank
                                  JohGreJ Offline
                                  JohGreJ Offline
                                  JohGre
                                  @Peter-ble sagte in Ble.0 Adapter bremst ganzen IObroker in 2 Min.:
                                  Wie schon geschrieben, bei mir war arp-scan beim radar2 Adapter schuld. Eine deinstallation half hier nachhaltig.
                                    30
                                    60
                                    720
                                    120
                                    1.1.1.1
                                    01:12:23:34:45:56
                                    false
                                    Vielen Dank
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Du hast beide gleichzeitig laufen? Wenn beide auf die Bluetooth-Schnittstelle zugreifen, kann das Probleme machen.
                                      Peter.bleP Offline
                                      Peter.ble
                                      Habe beide Adapter gleichzeitig laufen.
                                        Peter.bleP Offline
                                        Peter.ble
                                        Leider zu früh gefreut. Auch ohne Radar2 Adapter friert das System ein. Dauert aber wesentlich länger. :-(
                                          Peter.bleP Offline
                                          Peter.ble
                                          Habe jetzt mit:
                                          sudo apt-get remove arp-scan
                                          arp-scan deinstalliert.
                                          Mal schauen ob es hilft. Melde mich
