  3. Entwicklung
  4. Adapter: broadlink2
Adapter: broadlink2
broad2broadlinkrm prorm3 minirm4
1.4k Beiträge 169 Kommentatoren 892.2k Aufrufe 93 Beobachtet
  • D deta
    So hab es jetzt mal umgestellt... Hatte aber schon mal funktioniert.
    broadlink2.0	2020-07-15 14:12:48.298	info	(13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控
    broadlink2.0	2020-07-15 14:12:48.297	info	(13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev
    broadlink2.0	2020-07-15 14:12:48.295	info	(13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903030092707aa7df2400000000afbe0000, res={cmd: 170,co
    broadlink2.0	2020-07-15 14:12:47.974	info	(13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控
    broadlink2.0	2020-07-15 14:12:47.973	info	(13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev
    broadlink2.0	2020-07-15 14:12:47.971	info	(13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903020092707aa7df2400000000afbe0000, res={cmd: 170,co
    broadlink2.0	2020-07-15 14:12:47.646	info	(13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控
    broadlink2.0	2020-07-15 14:12:47.645	info	(13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev
    broadlink2.0	2020-07-15 14:12:47.641	info	(13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903010092707aa7df2400000000afbe0000, res={cmd: 170,co
    broadlink2.0	2020-07-15 14:12:47.608	info	(13129) debug: UDP listening on 0.0.0.0:54804
    GarganoG
    GarganoG
    Gargano
    schrieb am zuletzt editiert von Gargano
    #1032
    @deta Ich sehe rechts die chinesischen Zeichen für den Device Namen, kannst Du den mal ändern in der e-control App
    Und dann nochmal die Instanz restarten
    • GarganoG Gargano
      D
      D
      deta
      #1033
      @Gargano sagte in Adapter: broadlink2:
      Diese Zeichen stehen in keiner App, da steht ein anderer Device Name, der Name wird in der Broadlink als auch in der ihc For EU angezeigt. Aber nicht diese Zeichen. Woher diese auch immer kommen.
      GarganoG 2 Antworten Letzte Antwort
      • D deta
        GarganoG
        GarganoG
        Gargano
        #1034
        @deta Mit welcher App hast Du den RM ins Netz gebracht ?
        • D deta
          GarganoG
          GarganoG
          Gargano
          #1035
          @deta Wenn es die App Broadlink war, dann ist dies nicht richtig. Broadlink versetzt den RM in den Cloud modus, das kann der Adapter nicht. Nimm e-Control und mach einen Reset beim RM. Dann ins Netz bringen und im e-Control den Namen ändern.
          D R 2 Antworten Letzte Antwort
          • GarganoG Gargano
            D
            D
            deta
            #1036
            e-Controll geht mit meinen Handy nicht, ist zu alt die App.
            Hab immer schon mit ihc For Eu ins WLAN gebracht. Ging immer.
            GarganoG 1 Antwort Letzte Antwort
            • D deta
              GarganoG
              GarganoG
              Gargano
              #1037
              @deta Schau mal auf die Notes in https://github.com/frankjoke/ioBroker.broadlink2
              • D
                D
                deta
                #1038
                Hab Ihn jetzt noch mal komplett rausgekickt über all. Und wieder ins WLAN gebracht. Man bekommt Ihn nur noch per Broadlink App ins WLAN. Mit keiner anderen App mehr.
                • D
                  D
                  deta
                  #1039
                  Um dieses Problem zu vermeiden, bringen Sie das Gerät mit älteren Broadlink-Apps wie e smart homeoder in das Netzwerk e-controlund stellen Sie sicher, dass sich Ihr Telefon im selben 2,4-GHz-WLAN-Netzwerk befindet, in das Sie es einbinden möchten!
                  beide Apps funktionieren nicht mehr.
                  • D deta
                    GarganoG
                    GarganoG
                    Gargano
                    #1040
                    @deta Wenn Du über Broadlink ins Netz bringst , ist der RM im Cloud Modus und den kann der Adapter nicht.
                    Mal sehen was frankejoke heute Abend sagt.
                    • D
                      D
                      deta
                      #1041
                      So jetzt hab ich mal ein altes Handy rausgekramt und e-controll installiert drauf.
                      Da läuft die App. Hab den Broadlink jetzt komplett aus dem WLAN gelöscht, Broadlink Reset und konnte Ihn mit dem e-controll einbinden. der Mini wurde als unbekannt erkannt, ok, war aber jetzt im WLAN, unter Geräteliste ist er als unbekannt aufgeführt. Dort konnte ich aber den Namen , alt Chinazeichen, jetzt auf einen neuen Namen setzen, aber leider das selbe Ergebniss im broadlink2 Adapter, ja hab Ihn neu gestartet gehabt.
                      broadlink2.0	2020-07-15 16:26:41.745	info	(1549) debug: Dev RM4, RM:RM3-7a-70-92, 24:df:a7:7a:70:92, 192.168.178.29, RM3mini returned err `The device storage is full` Check response from 0x22: fbff365fee03050092707aa7df2401000000afbe000049913
                      • D deta
                        GarganoG
                        GarganoG
                        Gargano
                        #1042
                        @deta Die Fehlermeldung hab ich auch, geht aber trotzdem.
                        Wird denn ein _Learn angelegt ?
                        Kannst Du mal den ganzen Log vom Restart posten.
                        • GarganoG Gargano
                          D
                          D
                          deta
                          #1043
                          @Gargano soweit hab ich jetzt gar nicht geschaut gehabt! Tatsächlich, er ist auch in den Objekten drinnen, Ja Learn geht auch.... Klasse. Danke
                          Also altes Handy suchen , mit alter Android und e-controll. Boa ey war das ne Aktion. Danke.
                          • D deta
                            GarganoG
                            GarganoG
                            Gargano
                            #1044
                            @deta gern geschehen
                            • GarganoG Gargano
                              R
                              R
                              RandyAndy
                              schrieb am zuletzt editiert von RandyAndy
                              #1045
                              @Gargano
                              möchte jetzt nicht unnötig darauf rumreiten. Aber irgendwann wird es das e-Control nicht mehr geben. Und dann wird es mit den Broadlinks schwierig. Ist es denn nicht möglich eine Erkennung von Geräten in den Adapter zu integrieren, wenngleich die Frage wohl eher and frankejoke zu richten ist.
                              Würde in meinen Augen das System in der Summe stabilisieren, da bei einer Änderung des WLAN Passwords alles neu angelernt werden muss, d.h, Reset aller Geräte.
                              Mal eine ganz andere Frage, gibt es eigentlich eine Möglichkeit die Broadlinks zu flashen ala Sonoff. Das wäre natürlich das Beste.
                              Andreas
                              • R RandyAndy
                                @Gargano
                                Andreas
                                GarganoG
                                GarganoG
                                Gargano
                                #1046
                                @RandyAndy Da stimme ich Dir zu, autark zu sein ist immer besser.
                                Also Frage geht an frankjoke, ob er so etwas machen will.
                                Zu machen ist es sicher, die App kann es ja auch.
                                frankjokeF 1 Antwort Letzte Antwort
                                • GarganoG Gargano
                                  frankjokeF
                                  frankjokeF
                                  frankjoke
                                  #1047
                                  @Gargano
                                  Das hat weniger mit machen wollen als mit machen können zu tun!
                                  Der Grund ist dass man da das wlan-Netz programmieren muss was leider nicht standardisiert ist und in jedem Linux und Treiber anders funktioniert.
                                  Der Adapter müsste direkten Zugriff auf Wlan haben (um das Gerät zu finden welches ein eigenes WLAN aufbaut an das sich der Adapter dann als Client anmeldet und dem Gerät die WL-Adresse und das Passwort übergibt in welches sich das Gerät dann anmelden kann.
                                  Wenn wer eine Ahnung hat wie das gemacht werden kann dann kann ich den code zum Senden der W-Lan-Daten von Python auf javascript übersetzten und es versuchen!
                                  Frank,
                                  NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
                                  Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
                                  • D deta
                                    frankjokeF
                                    frankjokeF
                                    frankjoke
                                    #1048
                                    @deta , @Gargano und alle,
                                    Ich sehe gerade dass die Abfrage auf cloud-mode anscheinend funktioniert (im debug-log sieht man dass der Adapter sich mit cloud:1 gemeldet hat)!
                                    Ich werde das versuchen zu checken und vielleicht dann mit eioner besserern Fehlermeldung im log versehen dass man immer weiß dass der Adapter auf cloud-mode ist und deshalb nicht angesprochen werden kann.
                                    Vielleicht gibt's auch Leute die sich gut mit Netzwerk-sniffern auskennen und sich das neue cloud-mode-Protokoll entschlüsseln damit man auch die Adapter verwenden kann!
                                    Frank,
                                    • frankjokeF frankjoke
                                      @Gargano
                                      GarganoG
                                      GarganoG
                                      Gargano
                                      #1049
                                      @frankjoke Auf https://blog.ipsumdomus.com/broadlink-smart-home-devices-complete-protocol-hack-bc0b4b397af1
                                      gibt es mehr infos dazu
                                      • GarganoG Gargano
                                        frankjokeF
                                        frankjokeF
                                        frankjoke
                                        #1050
                                        @Gargano
                                        Das kenne ich und das ist vom März 2017 und beschreibt rein das alte Protokoll welches der Adapter ja kann, aber nicht das neue Protokoll der RM4x, LBx und einiger RM3 Mini's.
                                        Ich habe allerdings auch nach Lösungen gesucht und etwas gefunden was ich morgend Abend hoffentlich testen kann (wenn ich wieder zu Hause bin, momentan nur am Handy online).
                                        Damit könnte man auch die neue App verwenden um den RM in das Netz zu holen und es würde eben dieser Fehler angezeigt werden wenn das Gerät in cloud-Modus ist.
                                        Übrigens, Ich hätte einen Original RM3-Mini mit ID id=0x2737 zum Austausch für einen mit ID=0x5f36 falls es wem egal ist. Ich brauche ihn nicht (habe noch einen RM2 Pro+ und einen RM4Mini zum Testen aber eben keinen neuen RM3-Mini).
                                        We so einen Tausch vornehmen will/kannn sende mir einen privaten Chat zu Austausch der Adressen, aber nur zu Info, ich lebe in Österreich!
                                        Frank,
                                        H GarganoG 2 Antworten Letzte Antwort
                                        -1
                                        • frankjokeF
                                          frankjokeF
                                          frankjoke
                                          #1051
                                          Habe heute einige Tests hinter mir und und schon mal folgendes rausgefunden/geändert:
                                          • Es gibt Geräte welche im cloud-Modus arbeiten können und mit dem Adapter angesprochen werden können (A1, SP3S z.B.)
                                          • es gibt Geräte wie den RM4 oder neuen RM3-Mini welche sich nicht authorisieren (sprich sie geben mir den key nicht den ich brauche um ihnen Befehle senden zu können) wenn sie im cloud-modus sind.
                                          • Wenn ich nun ein Gerät finde (durch den scan) welches den cloud-Modus gesetzt hat und einen Authorisierungsfehler hat wird nun ein Warning erzeugt mit einer Anleitung wie man das Gerät aus dem cloud-Modus befreien kann!
                                          • Bis jetzt habe(n) wir dazu die e-control App verwendet, nun hab ich es auch geschafft mit der neuen Broadlink-App das Gerät hereinzuholen ohne es in die cloud zu bringen:
                                            ** Das Telefon/Tablet mit der App soll im 2.4GHz Wlan sein das auch vom Broadlink verwendet wird.
                                            ** Das Gerät in der App löschen . (Meine App auf Android: https://play.google.com/store/apps/details?id=cn.com.broadlink.econtrol.international&hl=de). Dort das Gerät selektieren und auf das Menü ... schauen und dort nach "Attribute" oder ähnlichem suchen und da drin dann sollte irgendwo auch ein roter Delete device Befehl sein. Bitte drauf achten dass das Handy Zugriff auf die cloud hat um die Daten dort zu speichern/löschen!
                                            ** Reset am Gerät bis led schnell blinkt (ich stecke es dann auch aus und nach 5s neu an und es sollte dann auch schnell blinken).
                                            ** Dann in der App auf das + mit add device oder add Wifi
                                            ** Wenn dann nach einem kurzen Scan Geräte auftauchen und angezeigt werden "none of the above devices are the ones I want to setup" clicken denn dies sind Geräte die zwar im Wlan gefunden werden aber nicht in der cloud sind!
                                            ** Danach zeigt er an dass das Gerät schnell blinken soll und mit weiter wird das Gerät dann ins (angegebene) w-lan geholt.
                                            ** entweder wird dann wieder eine Liste von Geräten angezeigt -> in diesen Fall keines auswählen
                                            ** oder man wird gefragt welchen Namen/Raum/funktionen man den Gerät zuweisen will -> in diesem fall App einfach beenden und nichts zuweisen!
                                            ** Beim neuerlichen Start der App führt diese auch einen scan durch und findet natürlich Geräte die wir noch nicht in die cloud gelinkt haben. In diesem Fall auf Not now clicken um die Frage nach dem Setup der Geräte zu beenden.
                                          Frank,
                                          84.1k
