Adapter: broadlink2
So hab es jetzt mal umgestellt... Hatte aber schon mal funktioniert.
broadlink2.0 2020-07-15 14:12:48.298 info (13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 broadlink2.0 2020-07-15 14:12:48.297 info (13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev broadlink2.0 2020-07-15 14:12:48.295 info (13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903030092707aa7df2400000000afbe0000, res={cmd: 170,co broadlink2.0 2020-07-15 14:12:47.974 info (13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 broadlink2.0 2020-07-15 14:12:47.973 info (13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev broadlink2.0 2020-07-15 14:12:47.971 info (13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903020092707aa7df2400000000afbe0000, res={cmd: 170,co broadlink2.0 2020-07-15 14:12:47.646 info (13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 broadlink2.0 2020-07-15 14:12:47.645 info (13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev broadlink2.0 2020-07-15 14:12:47.641 info (13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903010092707aa7df2400000000afbe0000, res={cmd: 170,co broadlink2.0 2020-07-15 14:12:47.608 info (13129) debug: UDP listening on 0.0.0.0:54804 -
@deta Ich sehe rechts die chinesischen Zeichen für den Device Namen, kannst Du den mal ändern in der e-control App
Und dann nochmal die Instanz restarten@Gargano sagte in Adapter: broadlink2:
Und dann nochmal die Instanz restartenDiese Zeichen stehen in keiner App, da steht ein anderer Device Name, der Name wird in der Broadlink als auch in der ihc For EU angezeigt. Aber nicht diese Zeichen. Woher diese auch immer kommen.
@deta Wenn es die App Broadlink war, dann ist dies nicht richtig. Broadlink versetzt den RM in den Cloud modus, das kann der Adapter nicht. Nimm e-Control und mach einen Reset beim RM. Dann ins Netz bringen und im e-Control den Namen ändern.
e-Controll geht mit meinen Handy nicht, ist zu alt die App.
Hab immer schon mit ihc For Eu ins WLAN gebracht. Ging immer. -
Hab Ihn jetzt noch mal komplett rausgekickt über all. Und wieder ins WLAN gebracht. Man bekommt Ihn nur noch per Broadlink App ins WLAN. Mit keiner anderen App mehr.
Um dieses Problem zu vermeiden, bringen Sie das Gerät mit älteren Broadlink-Apps wie e smart homeoder in das Netzwerk e-controlund stellen Sie sicher, dass sich Ihr Telefon im selben 2,4-GHz-WLAN-Netzwerk befindet, in das Sie es einbinden möchten!beide Apps funktionieren nicht mehr.
So jetzt hab ich mal ein altes Handy rausgekramt und e-controll installiert drauf.
Da läuft die App. Hab den Broadlink jetzt komplett aus dem WLAN gelöscht, Broadlink Reset und konnte Ihn mit dem e-controll einbinden. der Mini wurde als unbekannt erkannt, ok, war aber jetzt im WLAN, unter Geräteliste ist er als unbekannt aufgeführt. Dort konnte ich aber den Namen , alt Chinazeichen, jetzt auf einen neuen Namen setzen, aber leider das selbe Ergebniss im broadlink2 Adapter, ja hab Ihn neu gestartet gehabt.broadlink2.0 2020-07-15 16:26:41.745 info (1549) debug: Dev RM4, RM:RM3-7a-70-92, 24:df:a7:7a:70:92, 192.168.178.29, RM3mini returned err `The device storage is full` Check response from 0x22: fbff365fee03050092707aa7df2401000000afbe000049913 -
@deta Die Fehlermeldung hab ich auch, geht aber trotzdem.
Wird denn ein _Learn angelegt ?
Kannst Du mal den ganzen Log vom Restart posten. -
@Gargano soweit hab ich jetzt gar nicht geschaut gehabt! Tatsächlich, er ist auch in den Objekten drinnen, Ja Learn geht auch.... Klasse. Danke
Also altes Handy suchen , mit alter Android und e-controll. Boa ey war das ne Aktion. Danke.
möchte jetzt nicht unnötig darauf rumreiten. Aber irgendwann wird es das e-Control nicht mehr geben. Und dann wird es mit den Broadlinks schwierig. Ist es denn nicht möglich eine Erkennung von Geräten in den Adapter zu integrieren, wenngleich die Frage wohl eher and frankejoke zu richten ist.
Würde in meinen Augen das System in der Summe stabilisieren, da bei einer Änderung des WLAN Passwords alles neu angelernt werden muss, d.h, Reset aller Geräte.
Mal eine ganz andere Frage, gibt es eigentlich eine Möglichkeit die Broadlinks zu flashen ala Sonoff. Das wäre natürlich das Beste.Andreas
@RandyAndy Da stimme ich Dir zu, autark zu sein ist immer besser.
Also Frage geht an frankjoke, ob er so etwas machen will.
Zu machen ist es sicher, die App kann es ja auch. -
Zu machen ist es sicher, die App kann es ja auch.Das hat weniger mit machen wollen als mit machen können zu tun!
Der Grund ist dass man da das wlan-Netz programmieren muss was leider nicht standardisiert ist und in jedem Linux und Treiber anders funktioniert.
Der Adapter müsste direkten Zugriff auf Wlan haben (um das Gerät zu finden welches ein eigenes WLAN aufbaut an das sich der Adapter dann als Client anmeldet und dem Gerät die WL-Adresse und das Passwort übergibt in welches sich das Gerät dann anmelden kann.
Wenn wer eine Ahnung hat wie das gemacht werden kann dann kann ich den code zum Senden der W-Lan-Daten von Python auf javascript übersetzten und es versuchen!
broadlink2.0 2020-07-15 14:12:48.298 info (13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 broadlink2.0 2020-07-15 14:12:48.297 info (13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev broadlink2.0 2020-07-15 14:12:48.295 info (13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903030092707aa7df2400000000afbe0000, res={cmd: 170,co broadlink2.0 2020-07-15 14:12:47.974 info (13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 broadlink2.0 2020-07-15 14:12:47.973 info (13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev broadlink2.0 2020-07-15 14:12:47.971 info (13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903020092707aa7df2400000000afbe0000, res={cmd: 170,co broadlink2.0 2020-07-15 14:12:47.646 info (13129) debug: Error 'Authentication failed' in device.checkError for RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 broadlink2.0 2020-07-15 14:12:47.645 info (13129) debug: host={address: '192.168.178.29',port: 80,devtype: 24374,oname: '智能遥控',cloud: 1,maco: <Buffer 92 70 7a a7 df 24>,mac: '24:df:a7:7a:70:92',type: 'RM4',name: '0x5f36_24:df:a7:7a:70:92',dev broadlink2.0 2020-07-15 14:12:47.641 info (13129) debug: Dev RM4, undefined, 24:df:a7:7a:70:92, 192.168.178.29, 智能遥控 returned err `Authentication failed` Check response from 0x22: ffff365fe903010092707aa7df2400000000afbe0000, res={cmd: 170,co broadlink2.0 2020-07-15 14:12:47.608 info (13129) debug: UDP listening on 0.0.0.0:54804Ich sehe gerade dass die Abfrage auf cloud-mode anscheinend funktioniert (im debug-log sieht man dass der Adapter sich mit cloud:1 gemeldet hat)!
Ich werde das versuchen zu checken und vielleicht dann mit eioner besserern Fehlermeldung im log versehen dass man immer weiß dass der Adapter auf cloud-mode ist und deshalb nicht angesprochen werden kann.Vielleicht gibt's auch Leute die sich gut mit Netzwerk-sniffern auskennen und sich das neue cloud-mode-Protokoll entschlüsseln damit man auch die Adapter verwenden kann!
@frankjoke Auf https://blog.ipsumdomus.com/broadlink-smart-home-devices-complete-protocol-hack-bc0b4b397af1
gibt es mehr infos dazu -
gibt es mehr infos dazuDas kenne ich und das ist vom März 2017 und beschreibt rein das alte Protokoll welches der Adapter ja kann, aber nicht das neue Protokoll der RM4x, LBx und einiger RM3 Mini's.
Ich habe allerdings auch nach Lösungen gesucht und etwas gefunden was ich morgend Abend hoffentlich testen kann (wenn ich wieder zu Hause bin, momentan nur am Handy online).
Damit könnte man auch die neue App verwenden um den RM in das Netz zu holen und es würde eben dieser Fehler angezeigt werden wenn das Gerät in cloud-Modus ist.
Übrigens, Ich hätte einen Original RM3-Mini mit ID id=0x2737 zum Austausch für einen mit ID=0x5f36 falls es wem egal ist. Ich brauche ihn nicht (habe noch einen RM2 Pro+ und einen RM4Mini zum Testen aber eben keinen neuen RM3-Mini).
We so einen Tausch vornehmen will/kannn sende mir einen privaten Chat zu Austausch der Adressen, aber nur zu Info, ich lebe in Österreich!
