  4. Javascript Adapter startet nicht
javascript adapter
20 Beiträge 5 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • M Meev
    pi@raspberrypi:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.118-v7l+ (dom@buildbot) (gcc version 4.9.3 (cr                                      osstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:26:42 BST 2                                      020
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
    [    0.000000] On node 0 totalpages: 1012736
    [    0.000000]   DMA zone: 1728 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
    [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with                                       crng_init=0
    [    0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
    [    0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd                                      _bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headp                                      hones=1 cma=256M  smsc95xx.macaddr=DC:A6:32:5F:B5:BB vc_mem.mem_base=0x3ec00000                                       vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e52a                                      9d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 3735552K/4050944K available (8192K kernel code, 690K rwda                                      ta, 2420K rodata, 2048K init, 860K bss, 53248K reserved, 262144K cma-reserved, 3                                      264512K highmem)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                       lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                       pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                       modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                         .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                         .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                         .data : 0x(ptrval) - 0x(ptrval)   ( 691 kB)
                          .bss : 0x(ptrval) - 0x(ptrval)   ( 861 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 28928 entries in 85 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:                                       0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000002] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980                                      46511102ns
    [    0.000009] Switching to timer-based delay loop, resolution 18ns
    [    0.000110] Console: colour dummy device 80x30
    [    0.000298] console [tty1] enabled
    [    0.000324] Calibrating delay loop (skipped), value calculated using timer fr                                      equency.. 108.00 BogoMIPS (lpj=540000)
    [    0.000339] pid_max: default: 32768 minimum: 301
    [    0.000460] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000474] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000838] CPU: Testing write buffer coherency: ok
    [    0.001047] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001330] Setting up static identity map for 0x200000 - 0x20003c
    [    0.001404] rcu: Hierarchical SRCU implementation.
    [    0.001773] smp: Bringing up secondary CPUs ...
    [    0.002157] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.002578] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.002976] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.003024] smp: Brought up 1 node, 4 CPUs
    [    0.003052] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.003062] CPU: All CPU(s) started in HYP mode.
    [    0.003070] CPU: Virtualization extensions available.
    [    0.003466] devtmpfs: initialized
    [    0.007949] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8                                       rev 0
    [    0.008055] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma                                      x_idle_ns: 19112604462750000 ns
    [    0.008074] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.011263] pinctrl core: initialized pinctrl subsystem
    [    0.011738] NET: Registered protocol family 16
    [    0.013185] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.013824] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint                                       registers.
    [    0.013836] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.013968] Serial: AMBA PL011 UART driver
    [    0.015263] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.030016] raspberrypi-firmware soc:firmware: Attached to firmware from 2020                                      -06-01 13:23, variant start
    [    0.040021] raspberrypi-firmware soc:firmware: Firmware hash is 6379679d1ec6a                                      8c746d7e77e015f5b56b939976f
    [    0.063164] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dma                                      chans=0x1
    [    0.064501] vgaarb: loaded
    [    0.064665] SCSI subsystem initialized
    [    0.064753] usbcore: registered new interface driver usbfs
    [    0.064781] usbcore: registered new interface driver hub
    [    0.064826] usbcore: registered new device driver usb
    [    0.065422] clocksource: Switched to clocksource arch_sys_counter
    [    0.098442] VFS: Disk quotas dquot_6.6.0
    [    0.098496] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.098583] FS-Cache: Loaded
    [    0.098682] CacheFiles: Loaded
    [    0.098940] simple-framebuffer: probe of 0.framebuffer failed with error -12
    [    0.102575] NET: Registered protocol family 2
    [    0.102874] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144                                       bytes)
    [    0.102892] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.102927] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.102962] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.103032] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.103056] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.103153] NET: Registered protocol family 1
    [    0.103411] RPC: Registered named UNIX socket transport module.
    [    0.103422] RPC: Registered udp transport module.
    [    0.103431] RPC: Registered tcp transport module.
    [    0.103439] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.103452] PCI: CLS 0 bytes, default 64
    [    0.104258] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counte                                      rs available
    [    0.105186] Initialise system trusted keyrings
    [    0.105288] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    0.109132] FS-Cache: Netfs 'nfs' registered for caching
    [    0.109377] NFS: Registering the id_resolver key type
    [    0.109396] Key type id_resolver registered
    [    0.109405] Key type id_legacy registered
    [    0.109419] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.111336] Key type asymmetric registered
    [    0.111349] Asymmetric key parser 'x509' registered
    [    0.111401] bounce: pool size: 64 pages
    [    0.111429] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2                                      50)
    [    0.111514] io scheduler noop registered
    [    0.111525] io scheduler deadline registered (default)
    [    0.111601] io scheduler cfq registered
    [    0.111610] io scheduler mq-deadline registered (default)
    [    0.111620] io scheduler kyber registered
    [    0.125323] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, thres                                      hold 0x00000000c0000000
    [    0.125345] brcm-pcie fd500000.pcie: could not get clock
    [    0.125377] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    0.125399] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf800                                      0000
    [    0.185435] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
    [    0.185581] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    0.185594] pci_bus 0000:00: root bus resource [bus 00-01]
    [    0.185606] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff]                                       (bus address [0xf8000000-0xfbffffff])
    [    0.185634] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    0.185699] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    0.186849] PCI: bus0: Fast back to back transfers disabled
    [    0.186862] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec                                      onfiguring
    [    0.186973] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    0.187009] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    0.187120] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    0.188242] PCI: bus1: Fast back to back transfers disabled
    [    0.188255] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
    [    0.188277] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    0.188291] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64                                      bit]
    [    0.188342] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.188354] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    0.188460] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    0.188548] pcieport 0000:00:00.0: Signaling PME with IRQ 54
    [    0.188621] pcieport 0000:00:00.0: AER enabled with IRQ 54
    [    0.188714] pci 0000:01:00.0: enabling device (0140 -> 0142)
    [    0.190205] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
    [    0.191110] iproc-rng200 fe104000.rng: hwrng registered
    [    0.191209] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000                                      000(1024 MiB)
    [    0.191436] vc-sm: Videocore shared memory driver
    [    0.191603] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2                                      00000
    [    0.195862] brd: module loaded
    [    0.200420] loop: module loaded
    [    0.200804] Loading iSCSI transport class v2.0-870.
    [    0.201571] libphy: Fixed MDIO Bus: probed
    [    0.201766] bcmgenet fd580000.genet: failed to get enet clock
    [    0.201779] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
    [    0.201791] bcmgenet fd580000.genet: failed to get enet-wol clock
    [    0.201804] bcmgenet fd580000.genet: failed to get enet-eee clock
    [    0.201825] bcmgenet: Skipping UMAC reset
    [    0.201932] unimac-mdio unimac-mdio.-19: DMA mask not set
    [    0.215432] libphy: bcmgenet MII bus: probed
    [    0.255664] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrva                                      l)
    [    0.256068] usbcore: registered new interface driver r8152
    [    0.256105] usbcore: registered new interface driver lan78xx
    [    0.256135] usbcore: registered new interface driver smsc95xx
    [    0.256335] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    0.256354] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe                                      r 1
    [    0.257434] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu                                      irks 0x0000001000000890
    [    0.257591] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of ir                                      q 55
    [    0.257914] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc                                      dDevice= 4.19
    [    0.257927] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                                      1
    [    0.257939] usb usb1: Product: xHCI Host Controller
    [    0.257948] usb usb1: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
    [    0.257958] usb usb1: SerialNumber: 0000:01:00.0
    [    0.258186] hub 1-0:1.0: USB hub found
    [    0.258244] hub 1-0:1.0: 1 port detected
    [    0.258488] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    0.258505] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe                                      r 2
    [    0.258523] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    0.258733] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc                                      dDevice= 4.19
    [    0.258746] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=                                      1
    [    0.258758] usb usb2: Product: xHCI Host Controller
    [    0.258767] usb usb2: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
    [    0.258777] usb usb2: SerialNumber: 0000:01:00.0
    [    0.258979] hub 2-0:1.0: USB hub found
    [    0.259035] hub 2-0:1.0: 4 ports detected
    [    0.259609] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    0.259695] dwc_otg: FIQ enabled
    [    0.259698] dwc_otg: NAK holdoff enabled
    [    0.259702] dwc_otg: FIQ split-transaction FSM enabled
    [    0.259707] Module dwc_common_port init
    [    0.259804] usbcore: registered new interface driver uas
    [    0.259850] usbcore: registered new interface driver usb-storage
    [    0.259933] mousedev: PS/2 mouse device common for all mice
    [    0.260443] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    0.260992] sdhci: Secure Digital Host Controller Interface driver
    [    0.261002] sdhci: Copyright(c) Pierre Ossman
    [    0.261178] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    0.261359] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.263330] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.263398] hidraw: raw HID events driver (C) Jiri Kosina
    [    0.263463] usbcore: registered new interface driver usbhid
    [    0.263472] usbhid: USB HID core driver
    [    0.263886] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
    [    0.264863] [vc_sm_connected_init]: start
    [    0.270688] [vc_sm_connected_init]: end - returning 0
    [    0.271172] Initializing XFRM netlink socket
    [    0.271190] NET: Registered protocol family 17
    [    0.271242] Key type dns_resolver registered
    [    0.271407] Registering SWP/SWPB emulation handler
    [    0.271661] registered taskstats version 1
    [    0.271675] Loading compiled-in X.509 certificates
    [    0.278329] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 35, base_baud = 6250000                                      0) is a 16550
    [    0.278535] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive                                      r
    [    0.278784] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor d                                      river
    [    0.279077] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    0.279088] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    0.304608] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
    [    0.304652] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
    [    0.324195] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    0.325709] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.327219] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.329928] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    0.331438] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.335432] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using A                                      DMA
    [    0.336528] of_cfs_init
    [    0.336573] of_cfs_init: OK
    [    0.336848] Waiting for root device PARTUUID=e52a9d10-02...
    [    0.382162] random: fast init done
    [    0.391922] mmc1: new high speed SDIO card at address 0001
    [    0.433578] mmc0: new ultra high speed DDR50 SDHC card at address 59b4
    [    0.434199] mmcblk0: mmc0:59b4       29.8 GiB
    [    0.435209]  mmcblk0: p1 p2
    [    0.462772] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O                                      pts: (null)
    [    0.462808] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    0.463227] devtmpfs: mounted
    [    0.466198] Freeing unused kernel memory: 2048K
    [    0.505523] Run /sbin/init as init process
    [    0.625445] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    0.625668] xhci_hcd 0000:01:00.0: WARNING: Host System Error
    [    0.641685] xhci_hcd 0000:01:00.0: Host halt failed, -110
    [    0.832960] systemd[1]: System time before build time, advancing clock.
    [    0.900644] NET: Registered protocol family 10
    [    0.901206] Segment Routing with IPv6
    [    0.918769] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL                                      INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +                                      XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr                                      id)
    [    0.919077] systemd[1]: Detected architecture arm.
    [    0.924642] systemd[1]: Set hostname to <raspberrypi>.
    [    1.243678] systemd[1]: /lib/systemd/system/pivccu.service:8: PIDFile= refere                                      nces path below legacy directory /var/run/, updating /var/run/pivccu3.pid → /run                                      /pivccu3.pid; please update the unit file accordingly.
    [    1.285124] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.288621] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.288840] systemd[1]: Listening on udev Kernel Socket.
    [    1.289233] random: systemd: uninitialized urandom read (16 bytes read)
    [    1.291602] systemd[1]: Created slice system-getty.slice.
    [    1.292611] systemd[1]: Created slice User and Session Slice.
    [    1.304682] systemd[1]: Condition check resulted in Journal Audit Socket bein                                      g skipped.
    [    1.305106] systemd[1]: Listening on Journal Socket.
    [    1.307997] systemd[1]: Mounting Kernel Debug File System...
    [    1.723374] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    1.761205] systemd-journald[122]: Received request to flush runtime journal                                       from PID 1
    [    2.015900] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Reg                                      isters at 0xfeb00000 length 0x0000ffff
    [    2.016089] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised                                      : Registers at 0xfeb10000 length 0x00000fff
    [    2.016270] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Reg                                      isters at 0xfeb20000 length 0x0000ffff
    [    2.016463] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Regis                                      ters at 0xfeb30000 length 0x0000ffff
    [    2.056474] generic_raw_uart: loading out-of-tree module taints kernel.
    [    2.103099] vc_sm_cma: module is from the staging directory, the quality is u                                      nknown, you have been warned.
    [    2.104251] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    2.104279] [vc_sm_connected_init]: start
    [    2.104721] [vc_sm_connected_init]: installed successfully
    [    2.108888] media: Linux media interface: v0.10
    [    2.111971] snd_bcm2835: module is from the staging directory, the quality is                                       unknown, you have been warned.
    [    2.117339] bcm2835_audio soc:audio: card created with 8 channels
    [    2.132052] videodev: Linux video capture interface: v2.00
    [    2.146173] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [    2.169448] bcm2835_mmal_vchiq: module is from the staging directory, the qua                                      lity is unknown, you have been warned.
    [    2.172993] bcm2835_mmal_vchiq: module is from the staging directory, the qua                                      lity is unknown, you have been warned.
    [    2.187035] [drm] No displays found. Consider forcing hotplug if HDMI is atta                                      ched
    [    2.187081] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc                                      4])
    [    2.187292] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
    [    2.187297] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    2.187301] [drm] No driver support for vblank timestamp query.
    [    2.187305] [drm] Setting vblank_disable_immediate to false because get_vblan                                      k_timestamp == NULL
    [    2.190573] bcm2835_v4l2: module is from the staging directory, the quality i                                      s unknown, you have been warned.
    [    2.199142] bcm2835_codec: module is from the staging directory, the quality                                       is unknown, you have been warned.
    [    2.220534] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    2.220552] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    2.238942] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    2.238959] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    2.247287] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    2.247305] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    2.268793] pl011_raw_uart fe201000.serial: Initialized pl011 device; mapbase                                      =0xfe201000; irq=34; clockrate=48000001
    [    2.269985] Unable to handle kernel paging request at virtual address 510d41c                                      9
    [    2.270005] pgd = (ptrval)
    [    2.270014] [510d41c9] *pgd=00000000
    [    2.270026] Internal error: Oops: 205 [#1] SMP ARM
    [    2.270036] Modules linked in: rfkill bcm2835_codec(C) bcm2835_v4l2(C) v4l2_m                                      em2mem vc4 bcm2835_mmal_vchiq(C) videobuf2_dma_contig v4l2_common videobuf2_vmal                                      loc drm_kms_helper videobuf2_memops videobuf2_v4l2 videobuf2_common snd_soc_core                                       v3d videodev snd_compress snd_bcm2835(C) gpu_sched snd_pcm_dmaengine media sysc                                      opyarea snd_pcm vc_sm_cma(C) raspberrypi_hwmon sysfillrect hwmon drm sysimgblt f                                      b_sys_fops snd_timer drm_panel_orientation_quirks snd pl011_raw_uart(O) generic_                                      raw_uart(O) i2c_bcm2835 rpivid_mem uio_pdrv_genirq uio ip_tables x_tables ipv6
    [    2.270121] CPU: 0 PID: 156 Comm: systemd-udevd Tainted: G         C O      4                                      .19.118-v7l+ #1311
    [    2.270132] Hardware name: BCM2835
    [    2.270149] PC is at strlen+0xc/0x38
    [    2.270165] LR is at load_module+0x934/0x2408
    [    2.270178] pc : [<c09d2abc>]    lr : [<c02ba7b4>]    psr: 20000013
    [    2.270187] sp : dbae9e30  ip : dbae9e40  fp : dbae9e3c
    [    2.270196] r10: c1004d88  r9 : f110ef00  r8 : f10c1858
    [    2.270207] r7 : f110eed8  r6 : 0000089a  r5 : dbae9f30  r4 : 000096aa
    [    2.270220] r3 : 60008d51  r2 : 0000004b  r1 : f110e370  r0 : 510d41c9
    [    2.270230] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
    [    2.270240] Control: 30c5383d  Table: 1c7c1e00  DAC: fffffffd
    [    2.270255] Process systemd-udevd (pid: 156, stack limit = 0x(ptrval))
    [    2.270265] Stack: (0xdbae9e30 to 0xdbaea000)
    [    2.270274] 9e20:                                     dbae9f0c dbae9e40 c02ba                                      7b4 c09d2abc
    [    2.270286] 9e40: 00000000 dbae9e50 c03d57c8 c0420314 00000000 f1037000 f10b7                                      f00 f1037000
    [    2.270299] 9e60: f10b8034 000012b3 b6e018e0 000008f1 dbae9e94 c0c2c9f8 c03d5                                      814 c03d5680
    [    2.270319] 9e80: dbae9ea0 db9d5d80 dbae9edc dbae9e98 c03dc2c0 c03d57e8 000d7                                      f28 00000000
    [    2.270333] 9ea0: 000d7f28 00000000 00000000 491a6648 00000000 db9d5d80 db9d5                                      d80 dbae9f28
    [    2.270351] 9ec0: dbae9f24 7fffffff 00000000 0000017b dbae9f0c dbae9ee0 c03dc                                      438 491a6648
    [    2.270363] 9ee0: 7fffffff c1004d88 00000000 0000000e b6e018e0 7fffffff 00000                                      000 0000017b
    [    2.270377] 9f00: dbae9fa4 dbae9f10 c02bc4a4 c02b9e8c 7fffffff 00000000 00000                                      003 00000000
    [    2.270392] 9f20: 00000000 f1037000 000d7f28 00000000 f10a1c8d f10b7f00 f1037                                      000 000d7f28
    [    2.270404] 9f40: f110e370 f10b8650 f10cb478 00000000 00000000 00000000 00000                                      000 00000000
    [    2.270416] 9f60: 00000000 00000049 0000004a 00000040 0000002d 00000021 00000                                      000 491a6648
    [    2.270427] 9f80: f2348d00 00000000 00000000 0000017b c02011c4 dbae8000 00000                                      000 dbae9fa8
    [    2.270440] 9fa0: c02011a4 c02bc3f4 f2348d00 00000000 0000000e b6e018e0 00000                                      000 01d8c6d0
    [    2.270451] 9fc0: f2348d00 00000000 00000000 0000017b 01d8bf08 004c11dc 01d8c                                      6d0 00000000
    [    2.270463] 9fe0: be90d180 be90d170 b6df89d8 b6ee8af0 60000010 0000000e 00000                                      000 00000000
    [    2.270482] [<c09d2abc>] (strlen) from [<c02ba7b4>] (load_module+0x934/0x2408                                      )
    [    2.270499] [<c02ba7b4>] (load_module) from [<c02bc4a4>] (sys_finit_module+0x                                      bc/0xcc)
    [    2.270515] [<c02bc4a4>] (sys_finit_module) from [<c02011a4>] (__sys_trace_re                                      turn+0x0/0x1c)
    [    2.270526] Exception stack(0xdbae9fa8 to 0xdbae9ff0)
    [    2.270535] 9fa0:                   f2348d00 00000000 0000000e b6e018e0 00000                                      000 01d8c6d0
    [    2.270547] 9fc0: f2348d00 00000000 00000000 0000017b 01d8bf08 004c11dc 01d8c                                      6d0 00000000
    [    2.270558] 9fe0: be90d180 be90d170 b6df89d8 b6ee8af0
    [    2.270569] Code: e89da800 e1a0c00d e92dd800 e24cb004 (e5d02000)
    [    2.270589] ---[ end trace 60de28eb851c8863 ]---
    [    2.276199] Unable to handle kernel paging request at virtual address 50ffb1c                                      9
    [    2.276219] pgd = (ptrval)
    [    2.276228] [50ffb1c9] *pgd=00000000
    [    2.276241] Internal error: Oops: 205 [#2] SMP ARM
    [    2.276251] Modules linked in: rfkill bcm2835_codec(C) bcm2835_v4l2(C) v4l2_m                                      em2mem vc4 bcm2835_mmal_vchiq(C) videobuf2_dma_contig v4l2_common videobuf2_vmal                                      loc drm_kms_helper videobuf2_memops videobuf2_v4l2 videobuf2_common snd_soc_core                                       v3d videodev snd_compress snd_bcm2835(C) gpu_sched snd_pcm_dmaengine media sysc                                      opyarea snd_pcm vc_sm_cma(C) raspberrypi_hwmon sysfillrect hwmon drm sysimgblt f                                      b_sys_fops snd_timer drm_panel_orientation_quirks snd pl011_raw_uart(O) generic_                                      raw_uart(O) i2c_bcm2835 rpivid_mem uio_pdrv_genirq uio ip_tables x_tables ipv6
    [    2.276335] CPU: 2 PID: 164 Comm: systemd-udevd Tainted: G      D  C O      4                                      .19.118-v7l+ #1311
    [    2.276346] Hardware name: BCM2835
    [    2.276363] PC is at strlen+0xc/0x38
    [    2.276375] LR is at load_module+0x934/0x2408
    [    2.276384] pc : [<c09d2abc>]    lr : [<c02ba7b4>]    psr: 20000013
    [    2.276394] sp : dba35e30  ip : dba35e40  fp : dba35e3c
    [    2.276402] r10: c1004d88  r9 : f1035f00  r8 : f0fe8858
    [    2.276411] r7 : f1035ed8  r6 : 0000089a  r5 : dba35f30  r4 : 000096aa
    [    2.276420] r3 : 60008d51  r2 : 0000004b  r1 : f1035370  r0 : 50ffb1c9
    [    2.276430] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
    [    2.276439] Control: 30c5383d  Table: 1c7c19c0  DAC: 55555555
    [    2.276448] Process systemd-udevd (pid: 164, stack limit = 0x(ptrval))
    [    2.276457] Stack: (0xdba35e30 to 0xdba36000)
    [    2.276466] 5e20:                                     dba35f0c dba35e40 c02ba                                      7b4 c09d2abc
    [    2.276479] 5e40: 00000000 dba35e50 c03d57c8 c0420314 00000000 f0f5e000 f0fde                                      f00 f0f5e000
    [    2.276491] 5e60: f0fdf034 000012b3 b6e018e0 000008f1 dba35e94 c0c2c9f8 c03d5                                      814 c03d5680
    [    2.276503] 5e80: dba35ea0 db41b3c0 dba35edc dba35e98 c03dc2c0 c03d57e8 000d7                                      f28 00000000
    [    2.276515] 5ea0: 000d7f28 00000000 00000000 491a6648 00000000 db41b3c0 db41b                                      3c0 dba35f28
    [    2.276527] 5ec0: dba35f24 7fffffff 00000000 0000017b dba35f0c dba35ee0 c03dc                                      438 491a6648
    [    2.276540] 5ee0: 7fffffff c1004d88 00000000 0000000f b6e018e0 7fffffff 00000                                      000 0000017b
    [    2.276552] 5f00: dba35fa4 dba35f10 c02bc4a4 c02b9e8c 7fffffff 00000000 00000                                      003 00000000
    [    2.276563] 5f20: 00000000 f0f5e000 000d7f28 00000000 f0fc8c8d f0fdef00 f0f5e                                      000 000d7f28
    [    2.276575] 5f40: f1035370 f0fdf650 f0ff2478 00000000 00000000 00000000 00000                                      000 00000000
    [    2.276587] 5f60: 00000000 00000049 0000004a 00000040 0000002d 00000021 00000                                      000 491a6648
    [    2.276599] 5f80: f2348d00 00000000 00000000 0000017b c02011c4 dba34000 00000                                      000 dba35fa8
    [    2.276611] 5fa0: c02011a4 c02bc3f4 f2348d00 00000000 0000000f b6e018e0 00000                                      000 01d8cc18
    [    2.276623] 5fc0: f2348d00 00000000 00000000 0000017b 01d8b7f8 004c11dc 01d8c                                      c18 00000000
    [    2.276634] 5fe0: be90d180 be90d170 b6df89d8 b6ee8af0 60000010 0000000f 00000                                      000 00000000
    [    2.276653] [<c09d2abc>] (strlen) from [<c02ba7b4>] (load_module+0x934/0x2408                                      )
    [    2.276670] [<c02ba7b4>] (load_module) from [<c02bc4a4>] (sys_finit_module+0x                                      bc/0xcc)
    [    2.276686] [<c02bc4a4>] (sys_finit_module) from [<c02011a4>] (__sys_trace_re                                      turn+0x0/0x1c)
    [    2.276696] Exception stack(0xdba35fa8 to 0xdba35ff0)
    [    2.276706] 5fa0:                   f2348d00 00000000 0000000f b6e018e0 00000                                      000 01d8cc18
    [    2.276717] 5fc0: f2348d00 00000000 00000000 0000017b 01d8b7f8 004c11dc 01d8c                                      c18 00000000
    [    2.276728] 5fe0: be90d180 be90d170 b6df89d8 b6ee8af0
    [    2.276739] Code: e89da800 e1a0c00d e92dd800 e24cb004 (e5d02000)
    [    2.276752] ---[ end trace 60de28eb851c8864 ]---
    [    2.277707] Unable to handle kernel paging request at virtual address 50f221c                                      9
    [    2.277725] pgd = (ptrval)
    [    2.277733] [50f221c9] *pgd=00000000
    [    2.277746] Internal error: Oops: 205 [#3] SMP ARM
    [    2.277757] Modules linked in: rfkill bcm2835_codec(C) bcm2835_v4l2(C) v4l2_m                                      em2mem vc4 bcm2835_mmal_vchiq(C) videobuf2_dma_contig v4l2_common videobuf2_vmal                                      loc drm_kms_helper videobuf2_memops videobuf2_v4l2 videobuf2_common snd_soc_core                                       v3d videodev snd_compress snd_bcm2835(C) gpu_sched snd_pcm_dmaengine media sysc                                      opyarea snd_pcm vc_sm_cma(C) raspberrypi_hwmon sysfillrect hwmon drm sysimgblt f                                      b_sys_fops snd_timer drm_panel_orientation_quirks snd pl011_raw_uart(O) generic_                                      raw_uart(O) i2c_bcm2835 rpivid_mem uio_pdrv_genirq uio ip_tables x_tables ipv6
    [    2.277861] CPU: 2 PID: 157 Comm: systemd-udevd Tainted: G      D  C O      4                                      .19.118-v7l+ #1311
    [    2.277872] Hardware name: BCM2835
    [    2.277889] PC is at strlen+0xc/0x38
    [    2.277900] LR is at load_module+0x934/0x2408
    [    2.277908] pc : [<c09d2abc>]    lr : [<c02ba7b4>]    psr: 20000013
    [    2.277917] sp : db6a9e30  ip : db6a9e40  fp : db6a9e3c
    [    2.277925] r10: c1004d88  r9 : f0f5cf00  r8 : f0f0f858
    [    2.277934] r7 : f0f5ced8  r6 : 0000089a  r5 : db6a9f30  r4 : 000096aa
    [    2.277942] r3 : 60008d51  r2 : 0000004b  r1 : f0f5c370  r0 : 50f221c9
    [    2.277952] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
    [    2.277962] Control: 30c5383d  Table: 1c7c1d40  DAC: 55555555
    [    2.277971] Process systemd-udevd (pid: 157, stack limit = 0x(ptrval))
    [    2.277980] Stack: (0xdb6a9e30 to 0xdb6aa000)
    [    2.277989] 9e20:                                     db6a9f0c db6a9e40 c02ba                                      7b4 c09d2abc
    [    2.278001] 9e40: 00000000 db6a9e50 c03d57c8 c0420314 00000000 f0e85000 f0f05                                      f00 f0e85000
    [    2.278013] 9e60: f0f06034 000012b3 b6e018e0 000008f1 db6a9e94 c0c2c9f8 c03d5                                      814 c03d5680
    [    2.278026] 9e80: db6a9ea0 db41b840 db6a9edc db6a9e98 c03dc2c0 c03d57e8 000d7                                      f28 00000000
    [    2.278039] 9ea0: 000d7f28 00000000 00000000 491a6648 00000000 db41b840 db41b                                      840 db6a9f28
    [    2.278051] 9ec0: db6a9f24 7fffffff 00000000 0000017b db6a9f0c db6a9ee0 c03dc                                      438 491a6648
    [    2.278064] 9ee0: 7fffffff c1004d88 00000000 0000000f b6e018e0 7fffffff 00000                                      000 0000017b
    [    2.278076] 9f00: db6a9fa4 db6a9f10 c02bc4a4 c02b9e8c 7fffffff 00000000 00000                                      003 00000000
    [    2.278092] 9f20: 00000000 f0e85000 000d7f28 00000000 f0eefc8d f0f05f00 f0e85                                      000 000d7f28
    [    2.278105] 9f40: f0f5c370 f0f06650 f0f19478 00000000 00000000 00000000 00000                                      000 00000000
    [    2.278116] 9f60: 00000000 00000049 0000004a 00000040 0000002d 00000021 00000                                      000 491a6648
    [    2.278128] 9f80: f2348d00 00000000 00000000 0000017b c02011c4 db6a8000 00000                                      000 db6a9fa8
    [    2.278139] 9fa0: c02011a4 c02bc3f4 f2348d00 00000000 0000000f b6e018e0 00000                                      000 01d8cc18
    [    2.278151] 9fc0: f2348d00 00000000 00000000 0000017b 01d8ce40 004c11dc 01d8c                                      c18 00000000
    [    2.278164] 9fe0: be90d180 be90d170 b6df89d8 b6ee8af0 60000010 0000000f 00000                                      000 00000000
    [    2.278184] [<c09d2abc>] (strlen) from [<c02ba7b4>] (load_module+0x934/0x2408                                      )
    [    2.278199] [<c02ba7b4>] (load_module) from [<c02bc4a4>] (sys_finit_module+0x                                      bc/0xcc)
    [    2.278214] [<c02bc4a4>] (sys_finit_module) from [<c02011a4>] (__sys_trace_re                                      turn+0x0/0x1c)
    [    2.278225] Exception stack(0xdb6a9fa8 to 0xdb6a9ff0)
    [    2.278234] 9fa0:                   f2348d00 00000000 0000000f b6e018e0 00000                                      000 01d8cc18
    [    2.278252] 9fc0: f2348d00 00000000 00000000 0000017b 01d8ce40 004c11dc 01d8c                                      c18 00000000
    [    2.278263] 9fe0: be90d180 be90d170 b6df89d8 b6ee8af0
    [    2.278274] Code: e89da800 e1a0c00d e92dd800 e24cb004 (e5d02000)
    [    2.278285] ---[ end trace 60de28eb851c8865 ]---
    [    2.409220] rtc-rx8130 1-0032: Unable to read registers #28..#30
    [    2.409241] i2c i2c-1: probing for rx8130 failed
    [    2.409259] rtc-rx8130: probe of 1-0032 failed with error -121
    [    3.263802] random: crng init done
    [    3.263824] random: 7 urandom warning(s) missed due to ratelimiting
    [    3.438812] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1                                      02396k SSFS
    [    9.924167] Bluetooth: Core ver 2.22
    [    9.924223] NET: Registered protocol family 31
    [    9.924233] Bluetooth: HCI device and connection manager initialized
    [    9.924250] Bluetooth: HCI socket layer initialized
    [    9.924262] Bluetooth: L2CAP socket layer initialized
    [    9.924286] Bluetooth: SCO socket layer initialized
    [    9.930931] Bluetooth: HCI UART driver ver 2.3
    [    9.930950] Bluetooth: HCI UART protocol H4 registered
    [    9.930992] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    9.931104] Bluetooth: HCI UART protocol Broadcom registered
    [   10.075081] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   10.075099] Bluetooth: BNEP filters: protocol multicast
    [   10.075115] Bluetooth: BNEP socket layer initialized
    [   10.725430] xhci_hcd 0000:01:00.0: xHCI host not responding to stop endpoint                                       command.
    [   10.741484] xhci_hcd 0000:01:00.0: Host halt failed, -110
    [   10.741495] xhci_hcd 0000:01:00.0: xHCI host controller not responding, assum                                      e dead
    [   10.741522] xhci_hcd 0000:01:00.0: HC died; cleaning up
    [   10.741708] usb usb1-port1: couldn't allocate usb_device
    [   10.898710] bridge: filtering via arp/ip/ip6tables is no longer available by                                       default. Update your scripts to load br_netfilter if you need this.
    [   10.908134] br0: port 1(eth0) entered blocking state
    [   10.908152] br0: port 1(eth0) entered disabled state
    [   10.908309] device eth0 entered promiscuous mode
    [   10.912724] bcmgenet: Skipping UMAC reset
    [   11.015787] bcmgenet fd580000.genet: configuring instance for external RGMII                                       (no delay)
    [   11.021087] IPv6: ADDRCONF(NETDEV_UP): br0: link is not ready
    [   12.085540] bcmgenet fd580000.genet eth0: Link is Down
    [   15.205562] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow cont                                      rol rx/tx
    [   15.205606] br0: port 1(eth0) entered blocking state
    [   15.205618] br0: port 1(eth0) entered forwarding state
    [   15.205696] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
    [   19.916707] raw-uart raw-uart: Reset radio module
    [   20.153965] capability: warning: `jsvc' uses 32-bit capabilities (legacy supp                                      ort in use)
    [   27.846670] br0: port 2(vethpivccu) entered blocking state
    [   27.846688] br0: port 2(vethpivccu) entered disabled state
    [   27.846832] device vethpivccu entered promiscuous mode
    [   27.847010] IPv6: ADDRCONF(NETDEV_UP): vethpivccu: link is not ready
    [   27.917428] eth0: renamed from veth84BLOG
    [   27.966088] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   27.967921] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   27.968032] IPv6: ADDRCONF(NETDEV_CHANGE): vethpivccu: link becomes ready
    [   27.968092] br0: port 2(vethpivccu) entered blocking state
    [   27.968104] br0: port 2(vethpivccu) entered forwarding state
    [   39.929373] eq3loop: created slave mmd_hmip
    [   39.929683] eq3loop: created slave mmd_bidcos
    [   41.990982] eq3loop: eq3loop_open_slave() mmd_bidcos
    [   50.167868] eq3loop: eq3loop_open_slave() mmd_hmip
    [   50.168051] eq3loop: eq3loop_close_slave() mmd_hmip
    [   50.169801] eq3loop: eq3loop_open_slave() mmd_hmip
    [   50.169963] eq3loop: eq3loop_close_slave() mmd_hmip
    [   50.175111] eq3loop: eq3loop_open_slave() mmd_hmip
    @Meev sagte in Javascript Adapter startet nicht:
    [ 0.625668] xhci_hcd 0000:01:00.0: WARNING: Host System Error [ 0.641685] xhci_hcd 0000:01:00.0: Host halt failed, -110
    Das sieht nicht gut aus. Sind auch noch ein paar andere Hilferufe drin.
    Ich würde das System komplett neu auf eine frische SD-Karte hauen. Backup vom ioBroker druff und dann biste im Nu wieder dabei.
    • M Meev
      harrymH Offline
      harrymH Offline
      harrym
      das gefällt mir auch nicht ;)
      ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
        Meev
        Ok, dann fang ich nochmal bei null an. 😫
        Hatte ein fertiges Image von ioBroker genommen. Soll ich das wieder machen oder soll ich alles einzeln aufsetzen??
        • M Meev
          @Meev Ich tendiere ganz klar zu 'mach es selber zu Fuß'
          • harrymH harrym
            @harrym sagte in Javascript Adapter startet nicht:
            Ja, den meinte ich auch mit 'da sind noch weitere Hilferufe' drin.
              Meev
              Ist die SD Karte denn jetzt Schrott oder hilft eine neue Formatierung?
              harrymH haselchenH 2 Antworten Letzte Antwort
              • M Meev
                harrymH Offline
                harrymH Offline
                harrym
                @Meev ich würd auf ssd boot "umbauen" .....
                • M Meev
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @Meev
                  Bei den Fehlermeldungen würde ich sagen : Schrott.
                  Kaputte Sektoren etc. kannste nicht mehr reparieren.
                  Entweder wie @harrym vorschlug SSD oder was namhaftes bei den SD Karten. SanDisk z.B.
                    Meev
                    Ist ne SanDisk
                    harrymH 1 Antwort Letzte Antwort
                    • M Meev
                      Ist ne SanDisk
                      harrymH Offline
                      harrymH Offline
                      harrym
                      @Meev schützt auch nicht vor schreibfehler ;)
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @Thomas-Braun sagte in Javascript Adapter startet nicht:
                        Und ich empfehle Anfängern: Nimm ein Image :)
                        • M Meev
                          Ich kann den defekt nicht ganz nachvollziehen.
                          Hab den Adapter jetzt mehrfach neu installiert aber im Log taucht immer im 30 sec Rythmus dieser Fehler auf.
                          Wenn es mit einem Defekt zu tuen hat, dann müssten doch auch noch andere Probleme auftauchen?!?
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          Wenn das Modul vorher schon drauf war, wird es beim Adapter-Installieren nicht erneut installiert.
                          • AlCalzoneA AlCalzone
                            harrymH Offline
                            harrymH Offline
                            harrym
                            @AlCalzone ist halt de quick&easy variante ggg
