  4. Ja /npm Fehler bei Adapterinstallation
shelly js npm installieren
14 Beiträge 4 Kommentatoren 1.4k Aufrufe 4 Beobachtet
  • Benjamin RostB Benjamin Rost
    pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/@apollon/iobroker-tools
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/base64-js
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/bl
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/callback-stream
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/capitalize
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/coap-packet
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/ext/node_modules/type
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/follow-redirects
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/iobroker.shelly/node_modules/@types/iobroker
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/iobroker.shelly/node_modules/@iobroker/adapter-core
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/is-glob
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/is-negated-glob
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/is-windows
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/json-stable-stringify-without-jsonify
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/levennpm WARN checkPermissions Missing write access to /home/pi/node_modules/commist
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/lru-cache/node_modules/yallist
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/mqtt-packet
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/next-tick
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/node-rest-client/node_modules/ms
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/node-rest-client/node_modules/debug
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/ordered-read-streams
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/path-dirname
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/glob-parent
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/pseudomap
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/pumpify/node_modules/pump
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/q
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/reinterval
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/remove-trailing-separator
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/reusify
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/fastseries
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/sax
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/shellwords
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/split2
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/stream-shift
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/duplexify
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/through2
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/mqtt-connection
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/through2-filter
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/type
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/es6-symbol
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/es6-iterator
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/es5-ext
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/es6-set/node_modules/es6-symbol
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/event-emitter
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/es6-map
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/typedarray
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/concat-stream
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/unc-path-regex
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/is-unc-path
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/is-relative
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/is-absolute
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/to-absolute-glob
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/underscore
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/ping
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/unique-stream
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/glob-stream
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/help-me
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/websocket-stream/node_modules/ultron
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/websocket-stream/node_modules/ws
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/xml2js/node_modules/xmlbuilder
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/shelly-iot
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/xmlbuilder
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/iobroker.js-controller
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/@iobroker
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/@types
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/mqtt-packet/node_modules
    npm WARN checkPermissions Missing write access to /home/pi/node_modules/split2/node_modules
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /home/pi/node_modules/@apollon/iobroker-tools
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/@apollon/iobroker-tools'
    npm ERR!  [Error: EACCES: permission denied, access '/home/pi/node_modules/@apollon/iobroker-tools'] {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/home/pi/node_modules/@apollon/iobroker-tools'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/iobroker/.npm/_logs/2020-06-22T21_09_25_686Z-debug.log
    pi@raspberrypi:~ $
    @Benjamin-Rost
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    Und wenn das sauber ist ein
    iobroker fix
    npm-Befehle nie im ~ des users ausführen, immer im Installations-Order. Beim ioBroker wäre das /opt/iobroker. Aber das dürfte auch nicht dein Problem sein. Den ganzen Kram kannste jedenfalls löschen:
    rm -rf /home/pi/node_modules
    • Benjamin RostB Offline
      Benjamin Rost
      Guten Morgen,
      @Thomas-Braun danke !
      Habe ich gemacht und werd ich in Zukunft so machen..
      Gibt es noch etwas was ich tun kann um
      die Installation wieder zu ermöglichen?
      Bekomme immer diesen Fehler
      $ ./iobroker add shelly  --host raspberrypi
      ERROR: /opt/iobroker/node_modules/standard-as-callback/built/index.js:6        throw e;        ^TypeError: Cannot read property 'common' of undefined    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:486:29)    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:840:24    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:569:59    at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703    at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)    at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49    at processTicksAndRejections (internal/process/task_queues.js:97:5)
      ERROR: process exited with code 1
      J.A.R.V.I.S.J 1 Antwort Letzte Antwort
        Guten Morgen,
        J.A.R.V.I.S.J Offline
        J.A.R.V.I.S.
        @Benjamin-Rost hast du die Befehle von @Thomas-Braun mal eingegeben?
        Falls ja, was kommt beim ersten Befehl raus?
          Benjamin Rost
          Klar hatte ich gemacht ..hier die Ausgabe :-) @J-A-R-V-I-S @Thomas-Braun
          pi@raspberrypi:~ $ iobroker stop
          ipi@raspberrypi:~ $ iobroker fix
          library: loaded
          Library version=2020-06-12
              Welcome to the ioBroker installation fixer!
              Script version: 2020-04-12
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          Hit:1 http://phoscon.de/apt/deconz buster InRelease
          Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
          Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
          Hit:5 https://www.pivccu.de/piVCCU stable InRelease
          Fetched 15.0 kB in 1s (10.2 kB/s)
          Reading package lists... Done
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          /usr/bin/nodejs
          v12.18.1
          /usr/bin/node
          v12.18.1
          /usr/bin/npm
          6.14.5
          nodejs:
            Installed: 12.18.1-1nodesource1
            Candidate: 12.18.1-1nodesource1
            Version table:
           *** 12.18.1-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
               10.21.0~dfsg-1~deb10u1+rpi1 500
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            /usr/bin/nodejs
            v12.18.1
            /usr/bin/node
            v12.18.1
            /usr/bin/npm
            6.14.5
            nodejs:
              Version table:
            J.A.R.V.I.S.
            @Benjamin-Rost schaut gut aus.
            Hast du mal versucht eine bestimmte Version zu installieren?
            cd /opt/iobroker
            iob add shelly@3.0.1
              Benjamin Rost
              @J-A-R-V-I-S said in Ja /npm Fehler bei Adapterinstallation:
              cd /opt/iobroker iob add shelly@3.0.1
              pi@raspberrypi:~ $ cd /opt/iobroker
              pi@raspberrypi:/opt/iobroker $ iob add shelly@3.0.1
                      throw e;
              • AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                Hattest du schon irgendwo die JS-Controller-Version angegeben?
                iobroker -v
                  Benjamin Rost
                  Hi
                  Sorry bin wirklich nicht so fit im Thema und deshalb kommen die Infos auch so gestückelt..🙈
                  Bin wirklich sehr dankbar für jede Info
                  raspberrypi:~ $ iobroker -v
                  3.1.4
                  pi@raspberrypi:~
                    Hi
                    3.1.4
                    pi@raspberrypi:~
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @Benjamin-Rost Das ist ein Fehler im JS-Controller der nicht sauber abgefangen wird. Problem ist eine fehlende Datei in dem Adapter, den du hinzufügen willst.
                    Probier mal:
                    cd /opt/iobroker
                    npm install iobroker.shelly@3.0.1
                    iob upload shelly@3.0.1
                      Benjamin Rost
                      Hab Js neu installiert und dann hat es funktioniert.. vielen Dank noch einmal an alle für die Tipps
